I recently updated my firefly rk3399 board with android 7 industry version , first i get the boot logo , then i get erasing screen, again the board will reboot, after reboot the board is stuck at boot logo, we can put the board in to loader mode and maskrom mode. i also flashed the board with rockchip batch tool 1.8 by putting the board in to maskrom mode.
the result after flashing is same, that is i get the firefly logo, then i get erasing screen after that the board will reboot and it will freeze at boot logo. below is the log message
DDR Version 1.17 20190115
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1827
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66753
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x7a274
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):2bb878d
NOTICE: BL31: Built : 11:57:30, Jan 4 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Sep 19 2019 - 17:08:57)
CPU: rk3399
cpu version = 0
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
I2C Send Start Bit Timeout
No pmic detect.
can't find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-09-19#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 0
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0125a008)
ramdisk @ 0x04bf0000 (0x001adadc)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000004600000, end 0000000004616560 ... OK
Add bank:000000000a200000, 0000000075e00000
Starting kernel ...
[ 0.000000] Linux version 4.4.103 (chengd@tchipserver2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #67 SMP PREEMPT Thu Sep 19 17:10:50 CST 2019
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef9000 s45504 r8192 d32320 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30boa0
[ 0.000000] software IO TLB [mem 0x7eeb1000-0x7eef1000] (0MB) mapped at [ffffffc07eeb1000-ffffffc07eef0fff]
[ 0.000000] Memory: 1988592K/2064384K available (11006K kernel code, 1640K rwdata, 5260K rodata, 832K init, 1073K bss, 59408K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009070000 - 0xffffff8009140000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009070000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092da008 ( 1641 KB)
[ 0.001959] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002949] pid_max: default: 32768 minimum: 301
[ 0.003477] Security Framework initialized
[ 0.003877] SELinux: Initializing.
[ 0.004298] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004945] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006392] Initializing cgroup subsys freezer
[ 0.006831] Initializing cgroup subsys debug
[ 0.008143] sched-energy: Sched-energy-costs installed from DT
[ 0.008706] CPU0: update cpu_capacity 401
[ 0.009173] ASID allocator initialised with 65536 entries
[ 0.026002] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027285] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039397] Detected VIPT I-cache on CPU1
[ 0.039428] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039463] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039505] CPU1: update cpu_capacity 401
[ 0.039509] CPU1: Booted secondary processor [410fd034]
[ 0.049390] Detected VIPT I-cache on CPU2
[ 0.049410] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049442] CPU2: using LPI pending table @0x000000007c020000
[ 0.049471] CPU2: update cpu_capacity 401
[ 0.049474] CPU2: Booted secondary processor [410fd034]
[ 0.059429] Detected VIPT I-cache on CPU3
[ 0.059448] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059481] CPU3: using LPI pending table @0x000000007c060000
[ 0.059508] CPU3: update cpu_capacity 401
[ 0.059511] CPU3: Booted secondary processor [410fd034]
[ 0.069478] Detected PIPT I-cache on CPU4
[ 0.069507] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069546] CPU4: using LPI pending table @0x000000007c0a0000
[ 0.069586] CPU4: update cpu_capacity 1024
[ 0.069589] CPU4: Booted secondary processor [410fd082]
[ 0.079500] Detected PIPT I-cache on CPU5
[ 0.079517] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079554] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079581] CPU5: update cpu_capacity 1024
[ 0.079584] CPU5: Booted secondary processor [410fd082]
[ 0.079669] Brought up 6 CPUs
[ 0.092098] SMP: Total of 6 processors activated.
[ 0.092553] CPU features: detected feature: GIC system register CPU interface
[ 0.093241] CPU: All CPU(s) started at EL2
[ 0.093673] alternatives: patching kernel code
[ 0.095768] devtmpfs: initialized
[ 0.116262] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.117207] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.118516] pinctrl core: initialized pinctrl subsystem
[ 0.120571] Failed to find legacy iommu devices
[ 0.121382] NET: Registered protocol family 16
[ 0.122148] schedtune: init normalization constants...
[ 0.122635] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123249] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123862] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124487] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.125099] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.125712] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126325] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126937] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127549] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128167] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128885] schedtune: verify normalization constants...
[ 0.129384] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129908] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130431] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130955] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131478] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132006] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.132530] schedtune: configured to support 5 boost groups
[ 0.142043] cpuidle: using governor ladder
[ 0.152047] cpuidle: using governor menu
[ 0.152429] Registered FIQ tty driver
[ 0.153093] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009144000)
[ 0.153814] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.155849] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.176903] console [pstore0] enabled
[ 0.177480] pstore: Registered ramoops as persistent store backend
[ 0.178065] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.180784] fiq debugger fiq mode enabled
[ [ 0.181422] console [ttyFIQ0] enabled
[[ 0.182096] bootconsole [uart0] disabled
[ 0.183009] Registered fiq debugger ttyFIQ0
[ 0.213965] Rockchip hdmi driver version 2.0
[ 0.216285] iommu: Adding device ff650000.vpu_service to group 0
[ 0.216363] iommu: Adding device ff660000.rkvdec to group 1
[ 0.216428] iommu: Adding device ff670000.iep to group 2
[ 0.216522] iommu: Adding device ff8f0000.vop to group 3
[ 0.216597] iommu: Adding device ff900000.vop to group 4
[ 0.216705] iommu: Adding device ff910000.isp to group 5
[ 0.216785] iommu: Adding device ff920000.isp to group 6
[ 0.217499] rk_iommu ff670800.iommu: can't get aclk
[ 0.217520] rk_iommu ff670800.iommu: can't get hclk
[ 0.218382] SCSI subsystem initialized
[ 0.218722] usbcore: registered new interface driver usbfs
[ 0.218771] usbcore: registered new interface driver hub
[ 0.218850] usbcore: registered new device driver usb
[ 0.219251] media: Linux media interface: v0.10
[ 0.219292] Linux video capture interface: v2.00
[ 0.219425] pps_core: LinuxPPS API ver. 1 registered
[ 0.219438] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.219464] PTP clock support registered
[ 0.221029] Advanced Linux Sound Architecture Driver Initialized.
[ 0.221547] Bluetooth: Core ver 2.21
[ 0.221581] NET: Registered protocol family 31
[ 0.221593] Bluetooth: HCI device and connection manager initialized
[ 0.221610] Bluetooth: HCI socket layer initialized
[ 0.221627] Bluetooth: L2CAP socket layer initialized
[ 0.221656] Bluetooth: SCO socket layer initialized
[ 0.222692] rockchip-cpuinfo cpuinfo: Serial : f4b0799a58def9f8
[ 0.223192] clocksource: Switched to clocksource arch_sys_counter
[ 0.267242] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.267499] NET: Registered protocol family 2
[ 0.267942] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.268083] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.268361] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.268440] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.268502] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.268673] NET: Registered protocol family 1
[ 0.269187] Trying to unpack rootfs image as initramfs...
[ 0.358236] Freeing initrd memory: 1716K
[ 0.358757] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.358849] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.361438] audit: initializing netlink subsys (disabled)
[ 0.361507] audit: type=2000 audit(0.356:1): initialized
[ 0.366605] VFS: Disk quotas dquot_6.6.0
[ 0.366731] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.368115] fuse init (API version 7.23)
[ 0.369234]
[ 0.369234] TEE Core Framework initialization (ver 1:0.1)
[ 0.369266] TEE armv7 Driver initialization
[ 0.369636] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 0.369655] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 0.369832] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[ 0.373688] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.373714] io scheduler noop registered
[ 0.373884] io scheduler cfq registered (default)
[ 0.375167] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.380320] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.380348] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.380371] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.903261] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.904002] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.905967] iep: failed to find iep power down clock source.
[ 0.907053] IEP Power ON
[ 0.907509] IEP Power OFF
[ 0.907842] IEP Driver loaded succesfully
[ 0.908473] Module initialized.
[ 0.909101] rk-vcodec ff650000.vpu_service: probe device
[ 0.909157] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2fa410
[ 0.909320] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.909374] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.909885] rk-vcodec ff650000.vpu_service: init success
[ 0.910505] rk-vcodec ff660000.rkvdec: probe device
[ 0.910552] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2fac10
[ 0.910691] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.910749] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.911081] rk-vcodec ff660000.rkvdec: init success
[ 0.912774] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.912793] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.914146] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.914165] dma-pl330 ff6e0000.dma-controller: ֫#�V֖�fVVkm_Chans-8 Num_Peri-20 Num_Events-16
[ 0.915781] Serial: 8250/16550 driver, 5 ports, �Q sharing disabled [ 0.918033] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) A
[ 0.918614] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[ 0.919008] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.923978] mali ff9a0000.gpu: Failed to get regulator
[ 0.924001] mali ff9a0000.gpu: Power control initialization failed
[ 0.924303] Unable to detect cache hierarchy from DT for CPU 0
[ 0.932115] brd: module loaded
[ 0.946693] loop: module loaded
[ 0.947220] zram: Added device: zram0
[ 0.947830] SCSI Media Changer driver v0.25
[ 0.949278] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 0.949308] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 0.949325] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 0.949344] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 0.949482] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.949496] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.950178] register spi return v = :0
[ 0.950229] tun: Universal TUN/TAP device driver, 1.6
[ 0.950240] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.951175] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.951264] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.951283] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.951298] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.951325] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.951496] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.956521] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.956645] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.956656] Ring mode enabled
[ 0.956665] DMA HW capability register supported
[ 0.956674] Normal descriptors
[ 0.956685] RX Checksum Offload Engine supported (type 2)
[ 0.956696] Wake-Up On Lan supported
[ 0.956740] Enable RX Mitigation via HW Watchdog Timer
[ 1.025921] libphy: stmmac: probed
[ 1.025943] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.025957] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.028188] PPP generic driver version 2.4.2
[ 1.028708] PPP BSD Compression module registered
[ 1.028728] PPP Deflate Compression module registered
[ 1.028759] PPP MPPE Compression module registered
[ 1.028778] NET: Registered protocol family 24
[ 1.028817] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.028831] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.028903] usbcore: registered new interface driver mt7601u
[ 1.028924] Rockchip WiFi SYS interface (V1.00) ...
[ 1.028990] usbcore: registered new interface driver catc
[ 1.029034] usbcore: registered new interface driver kaweth
[ 1.029051] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.029090] usbcore: registered new interface driver pegasus
[ 1.029133] usbcore: registered new interface driver rtl8150
[ 1.029179] usbcore: registered new interface driver r8152
[ 1.029194] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.029253] usbcore: registered new interface driver hso
[ 1.029301] usbcore: registered new interface driver asix
[ 1.029344] usbcore: registered new interface driver ax88179_178a
[ 1.029388] usbcore: registered new interface driver cdc_ether
[ 1.029434] usbcore: registered new interface driver cdc_eem
[ 1.029477] usbcore: registered new interface driver dm9601
[ 1.029527] usbcore: registered new interface driver smsc75xx
[ 1.029580] usbcore: registered new interface driver smsc95xx
[ 1.029626] usbcore: registered new interface driver gl620a
[ 1.029670] usbcore: registered new interface driver net1080
[ 1.029713] usbcore: registered new interface driver plusb
[ 1.029756] usbcore: registered new interface driver rndis_host
[ 1.029800] usbcore: registered new interface driver cdc_subset
[ 1.029843] usbcore: registered new interface driver zaurus
[ 1.029910] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.029970] usbcore: registered new interface driver int51x1
[ 1.030014] usbcore: registered new interface driver kalmia
[ 1.030057] usbcore: registered new interface driver ipheth
[ 1.030103] usbcore: registered new interface driver sierra_net
[ 1.030149] usbcore: registered new interface driver cx82310_eth
[ 1.030201] usbcore: registered new interface driver cdc_ncm
[ 1.030246] usbcore: registered new interface driver qmi_wwan
[ 1.030290] usbcore: registered new interface driver cdc_mbim
[ 1.031515] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.047342] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.047955] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.047974] ehci-pci: EHCI PCI platform driver
[ 1.048035] ehci-platform: EHCI generic platform driver
[ 1.051844] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.051876] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.052083] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.059878] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.060063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.060079] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.060093] usb usb1: Product: EHCI Host Controller
[ 1.060105] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.060117] usb usb1: SerialNumber: fe3c0000.usb
[ 1.060623] hub 1-0:1.0: USB hub found
[ 1.060672] hub 1-0:1.0: 1 port detected
[ 1.061222] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.061260] ohci-platform: OHCI generic platform driver
[ 1.061735] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.061761] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.061887] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.117359] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.117387] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.117402] usb usb2: Product: Generic Platform OHCI controller
[ 1.117415] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.117428] usb usb2: SerialNumber: fe3e0000.usb
[ 1.118065] hub 2-0:1.0: USB hub found
[ 1.118115] hub 2-0:1.0: 1 port detected
[ 1.119601] usbcore: registered new interface driver cdc_acm
[ 1.119616] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.119700] usbcore: registered new interface driver usblp
[ 1.119763] usbcore: registered new interface driver cdc_wdm
[ 1.119827] usbcore: registered new interface driver uas
[ 1.119980] usbcore: registered new interface driver usb-storage
[ 1.120036] usbcore: registered new interface driver ums-alauda
[ 1.120099] usbcore: registered new interface driver ums-cypress
[ 1.120156] usbcore: registered new interface driver ums-datafab
[ 1.120210] usbcore: registered new interface driver ums_eneub6250
[ 1.120264] usbcore: registered new interface driver ums-freecom
[ 1.120319] usbcore: registered new interface driver ums-isd200
[ 1.120374] usbcore: registered new interface driver ums-jumpshot
[ 1.120429] usbcore: registered new interface driver ums-karma
[ 1.120484] usbcore: registered new interface driver ums-onetouch
[ 1.120544] usbcore: registered new interface driver ums-sddr09
[ 1.120599] usbcore: registered new interface driver ums-sddr55
[ 1.120655] usbcore: registered new interface driver ums-usbat
[ 1.120768] usbcore: registered new interface driver usbserial
[ 1.120821] usbcore: registered new interface driver usbserial_generic
[ 1.120862] usbserial: USB Serial support registered for generic
[ 1.120921] usbcore: registered new interface driver ch341
[ 1.120963] usbserial: USB Serial support registered for ch341-uart
[ 1.121021] usbcore: registered new interface driver cp210x
[ 1.121058] usbserial: USB Serial support registered for cp210x
[ 1.121129] usbcore: registered new interface driver option
[ 1.121169] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.121332] usbcore: registered new interface driver pl2303
[ 1.121369] usbserial: USB Serial support registered for pl2303
[ 1.121441] usbcore: registered new interface driver trancevibrator
[ 1.121460] usb20_otg: version 3.10a 21-DEC-2012
[ 1.121734] usb20_host: version 3.10a 21-DEC-2012
[ 1.126676] usbcore: registered new interface driver xpad
[ 1.126736] usbcore: registered new interface driver usb_acecad
[ 1.126787] usbcore: registered new interface driver aiptek
[ 1.126848] usbcore: registered new interface driver gtco
[ 1.126899] usbcore: registered new interface driver hanwang
[ 1.126947] usbcore: registered new interface driver kbtab
[ 1.126964] ==gsl_ts_init==
[ 1.126995] ret=0
[ 1.136812] .. rk pwm remotectl v1.1 init
[ 1.137036] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.137621] sensor_register_slave:mma8452,id=17
[ 1.137646] sensor_register_slave:lis3dh,id=7
[ 1.137664] sensor_register_slave:mma7660,id=18
[ 1.137681] sensor_register_slave:lsm303d,id=22
[ 1.137698] sensor_register_slave:gs_mc3230,id=23
[ 1.137708] [Gsensor] gsensor_init
[ 1.137726] sensor_register_slave:mpu6880_acc,id=24
[ 1.137743] sensor_register_slave:mpu6500_acc,id=25
[ 1.137761] sensor_register_slave:lsm330_acc,id=26
[ 1.137779] sensor_register_slave:akm8975,id=29
[ 1.137796] sensor_register_slave:akm8963,id=30
[ 1.137814] sensor_register_slave:l3g4200d,id=44
[ 1.137831] sensor_register_slave:l3g20d,id=45
[ 1.137849] sensor_register_slave:ewtsa,id=46
[ 1.137867] sensor_register_slave:lsm330_gyro,id=50
[ 1.137885] sensor_register_slave:cm3217,id=52
[ 1.137903] sensor_register_slave:cm3218,id=53
[ 1.138795] i2c /dev entries driver
[ 1.366539] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.490509] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.490542] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.490560] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.491125] hub 1-1:1.0: USB hub found
[ 1.491256] hub 1-1:1.0: 7 ports detected
[ 1.769871] usb 1-1.4: new low-speed USB device number 3 using ehci-platform
[ 1.874886] usb 1-1.4: New USB device found, idVendor=04ca, idProduct=004b
[ 1.874918] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.874936] usb 1-1.4: Product: USB Keyboard
[ 1.874952] usb 1-1.4: Manufacturer: Lite-On Technology Corp.
[ 2.139910] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x00, state: 1
[ 2.139962] fan53555-regulator 0-0040: Failed to get chip ID!
[ 2.140044] fan53555-regulator: probe of 0-0040 failed with error -110
[ 3.139903] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x00, state: 1
[ 3.139945] fan53555-regulator 0-0041: Failed to get chip ID!
[ 3.140006] fan53555-regulator: probe of 0-0041 failed with error -110
[ 4.139906] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x00, state: 1
[ 4.139950] rk808 0-001b: failed to read the chip id at 0x17
[ 4.140014] rk808: probe of 0-001b failed with error -110
[ 4.140049] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098ac000
[ 4.140807] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098ae000
[ 4.140926] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 4.140943] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 4.140959] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 4.140974] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 4.141432] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80098b0000
[ 4.142996] fusb302 4-0022: Can't get property of role, set role to default DRP
[ 5.139909] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 6.139900] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 7.139902] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 8.139909] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 9.139901] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 10.139900] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 11.139887] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 12.139901] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 13.139900] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 14.139898] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 15.139896] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 16.139907] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 17.139896] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 18.139897] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 19.139898] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 20.139903] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 21.139900] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x00, state: 1
[ 21.140390] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 21.140430] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098b2000
[ 21.141602] IR NEC protocol handler initialized
[ 21.141653] IR RC5(x/sz) protocol handler initialized
[ 21.141671] IR RC6 protocol handler initialized
[ 21.141688] IR JVC protocol handler initialized
[ 21.141704] IR Sony protocol handler initialized
[ 21.141718] IR SANYO protocol handler initialized
[ 21.141733] IR Sharp protocol handler initialized
[ 21.141748] IR MCE Keyboard/mouse protocol handler initialized
[ 21.141763] IR XMP protocol handler initialized
[ 21.142085] usbcore: registered new interface driver uvcvideo
[ 21.142096] USB Video Class driver (1.1.1)
[ 21.142115] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 21.148167] __power_supply_register: Expected proper parent device for 'test_ac'
[ 21.148338] __power_supply_register: Expected proper parent device for 'test_battery'
[ 21.148705] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 21.148828] __power_supply_register: Expected proper parent device for 'test_usb'
[ 21.151794] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 21.152908] device-mapper: uevent: version 1.0.3
[ 21.153409] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 21.153695] Bluetooth: HCI UART driver ver 2.3
[ 21.153709] Bluetooth: HCI UART protocol H4 registered
[ 21.153720] Bluetooth: HCI UART protocol LL registered
[ 21.153736] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 21.153746] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 21.153756] rtk_btusb: Register usb char device interface for BT driver
[ 21.154037] usbcore: registered new interface driver rtk_btusb
[ 21.154587] cpu cpu0: leakage=15
[ 21.154687] cpu cpu0: Failed to get cpu_reg
[ 21.154954] cpu cpu4: leakage=26
[ 21.154993] cpu cpu4: Failed to get cpu_reg
[ 21.156163] sdhci: Secure Digital Host Controller Interface driver
[ 21.156175] sdhci: Copyright(c) Pierre Ossman
[ 21.156191] Synopsys Designware Multimedia Card Interface Driver
[ 21.157407] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 21.157567] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 21.157589] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 21.157653] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 21.157699] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 21.157733] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 21.157746] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 21.158836] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 21.158913] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 21.158934] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 21.158998] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 21.159025] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 21.159060] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 21.159545] sdhci-pltfm: SDHCI platform and OF driver helper
[ 21.161535] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 21.161550] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 21.189975] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 21.193827] hidraw: raw HID events driver (C) Jiri Kosina
[ 21.201698] input: Lite-On Technology Corp. USB Keyboard as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:04CA:004B.0001/input/input1
[ 21.231257] mmc0: MAN_BKOPS_EN bit is not set
[ 21.246407] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 21.247819] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 21.249149] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 21.250699] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 21.251945] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 21.253069] rkpart: partition size too small (0)
[ 21.253096] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 21.253109] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 21.253121] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 21.253132] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 21.253144] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 21.253156] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 21.253167] recovery: 0x005800000 -- 0x007800000 (32 MB)
[ 21.253230] backup: 0x007800000 -- 0x00e800000 (112 MB)
