内核加载挂了
板子使用的sdk源码包:Firefly-RK3308_Linux_SDK_git_20181116
编译uboot 用的是 : .make.sh roc-rk3308-cc
内核编译命令: make arch=arm64 firefly-rk3308_linux_defconfig
文件系统是ext2 格式自己制作的。但是烧写到板子上,加载内核的时候挂了。能看出那块出问题了?
pwm-regulator(vdd-core): init 1044000 uV
regulator(vdd-core) init 1044000 uV
MMC: dwmmc@ff490000: 0
In: serial@ff0c0000
Out: serial@ff0c0000
Err: serial@ff0c0000
Model: Rockchip RK3308 EVB
MMC Device 1 not found
no mmc device at slot 1
mmc_init: -95, time 9
Device 0: No.1 FLASH ID:ef f1 0 95 0 0
SFTL version: 5.0.48 20180930
…FtlVpcCheckAndModify enter…
FtlCheckVpc 1ae = 40 30
Vendor: 0x0308 Rev: V1.00 Prod: rkflash-NandFlash
Type: Hard Disk
Capacity: 107.7 MB = 0.1 GB (220672 x 512)
… is now current device
enter Recovery mode!
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98303 KHz
pclk_audio 98303 KHz
Net: Net Initialization Skipped
No ethernet found.
FDT load addr 0x10f00000 size 260 KiB
Booting kernel at 0x4080000 with fdt at 4a45800…
## Booting Android Image at 0x04080000 …
Kernel load addr 0x02080000 size 4071 KiB
RAM disk load addr 0x11000000 size 5929 KiB
## Flattened Device Tree blob at 04a45800
Booting using the fdt blob at 0x4a45800
Uncompressing Kernel Image … OK
Loading Ramdisk to 0ef4a000, end 0f5140de … OK
Loading Device Tree to 000000000ef34000, end 000000000ef490b4 … OK
Adding bank: start=0x00200000, size=0x0fe00000
[ 0.000000] Linux version 4.4.143 (root@wyh-B85M-D3V) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #4 SMP PREEMPT Tue Nov 12 16:48:13 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0c0000 (options ‘’)
[ 0.000000] PERCPU: Embedded 18 pages/cpu @ffffffc00ff4e000 s35992 r8192 d29544 u73728
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64008
[ 0.000000] Kernel command line: storagemedia=nand androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rw rootwait earlycon=uart8250,mmio32,0xff0c0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext2 snd_aloop.index=7
[ 0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] software IO TLB [mem 0x0fead000-0x0feed000] (0MB) mapped at [ffffffc00fead000-ffffffc00feecfff]
[ 0.000000] Memory: 240408K/260096K available (5182K kernel code, 374K rwdata, 1768K rodata, 320K init, 490K bss, 19688K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008750000 - 0xffffff80087a0000 ( 320 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008590000 ( 5184 KB)
[ 0.000000] .rodata : 0xffffff8008590000 - 0xffffff8008750000 ( 1792 KB)
[ 0.000000] .data : 0xffffff80087a0000 - 0xffffff80087fd808 ( 375 KB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc010000000 ( 254 MB)
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001858] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002807] pid_max: default: 32768 minimum: 301
[ 0.003360] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.003962] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.005392] sched-energy: CPU device node has no sched-energy-costs
[ 0.006011] Invalid sched_group_energy for CPU0
[ 0.006430] CPU0: update cpu_capacity 1024
[ 0.006853] ASID allocator initialised with 65536 entries
[ 0.016582] Detected VIPT I-cache on CPU1
[ 0.016636] Invalid sched_group_energy for CPU1
[ 0.016642] CPU1: update cpu_capacity 1024
[ 0.016646] CPU1: Booted secondary processor [410fd042]
[ 0.019605] Detected VIPT I-cache on CPU2
[ 0.019642] Invalid sched_group_energy for CPU2
[ 0.019646] CPU2: update cpu_capacity 1024
[ 0.019650] CPU2: Booted secondary processor [410fd042]
[ 0.022644] Detected VIPT I-cache on CPU3
[ 0.022678] Invalid sched_group_energy for CPU3
[ 0.022683] CPU3: update cpu_capacity 1024
[ 0.022687] CPU3: Booted secondary processor [410fd042]
[ 0.022756] Brought up 4 CPUs
[ 0.027965] SMP: Total of 4 processors activated.
[ 0.028404] CPU: All CPU(s) started at EL2
[ 0.028903] Invalid sched_group_energy for CPU3
[ 0.029325] Invalid sched_group_energy for Cluster3
[ 0.029772] Invalid sched_group_energy for CPU2
[ 0.030203] Invalid sched_group_energy for Cluster2
[ 0.030652] Invalid sched_group_energy for CPU1
[ 0.031068] Invalid sched_group_energy for Cluster1
[ 0.031526] Invalid sched_group_energy for CPU0
[ 0.031943] Invalid sched_group_energy for Cluster0
[ 0.032931] devtmpfs: initialized
[ 0.053191] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.054131] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.055082] pinctrl core: initialized pinctrl subsystem
[ 0.056567] NET: Registered protocol family 16
[ 0.062069] cpuidle: using governor menu
[ 0.062468] Registered FIQ tty driver
[ 0.063081] vdso: 2 pages (1 code @ ffffff8008596000, 1 data @ ffffff80087a4000)
[ 0.063787] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.064618] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.069029] console [pstore-1] enabled
[ 0.069381] pstore: Registered ramoops as persistent store backend
[ 0.069965] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.089649] fiq debugger fiq mode enabled
[[ 0.090400] console [ttyFIQ0] enabled
[ 0.091073] bootconsole [uart0] disabled
[ 0.091708] Registered fiq debugger ttyFIQ0
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.103947] vcc_1v8: regulator get failed, ret=-517
[ 0.104868] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.105771] vcc_1v8: supplied by vcc_io
[ 0.105887] vcc_1v8_codec: supplied by vcc_io
[ 0.109280] Advanced Linux Sound Architecture Driver Initialized.
[ 0.109970] Bluetooth: Core ver 2.21
[ 0.110037] NET: Registered protocol family 31
[ 0.110054] Bluetooth: HCI device and connection manager initialized
[ 0.110075] Bluetooth: HCI socket layer initialized
[ 0.110091] Bluetooth: L2CAP socket layer initialized
[ 0.110131] Bluetooth: SCO socket layer initialized
[ 0.111242] rockchip-cpuinfo cpuinfo: Serial : 2351742cfaa2a9b5
[ 0.111831] clocksource: Switched to clocksource arch_sys_counter
[ 0.114293] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.114623] NET: Registered protocol family 2
[ 0.115314] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.115376] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.115432] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.115513] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.115546] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.115756] NET: Registered protocol family 1
[ 0.116097] Unpacking initramfs…
[ 0.564461] Freeing initrd memory: 5928K
[ 0.565072] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.576280] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.579487] io scheduler noop registered (default)
[ 0.580665] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.584961] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.585003] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.587326] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.587364] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.587713] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.587895] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.589391] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.591732] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 6770833) is a 16550A
[ 0.593653] [drm] Initialized drm 1.1.0 20060810
[ 0.593843] random: nonblocking pool is initialized
[ 0.596539] Unable to detect cache hierarchy for CPU 0
[ 0.597126] Rockchip WiFi SYS interface (V1.00) …
[ 0.597562] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.597685] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.599938] dwc2 ff400000.usb: Configuration mismatch. dr_mode forced to device
[ 0.599978] dwc2 ff400000.usb: 128 invalid for host_nperio_tx_fifo_size. Check HW configuration.
[ 0.600001] dwc2 ff400000.usb: 256 invalid for host_perio_tx_fifo_size. Check HW configuration.
[ 0.600048] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.823309] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 0.824211] i2c /dev entries driver
[ 0.825390] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff80088b6000
[ 0.828297] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.828542] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.829145] Bluetooth: HCI UART driver ver 2.3
[ 0.829170] Bluetooth: HCI UART protocol H4 registered
[ 0.829182] Bluetooth: HCI UART protocol LL registered
[ 0.829446] cpu cpu0: leakage=15
[ 0.829737] cpu cpu0: Failed to get pvtm
[ 0.831068] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1200000000 h_limit=0
[ 0.832516] Synopsys Designware Multimedia Card Interface Driver
[ 0.833583] dwmmc_rockchip ff4a0000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.833733] dwmmc_rockchip ff4a0000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.833783] dwmmc_rockchip ff4a0000.dwmmc: Using internal DMA controller.
[ 0.833807] dwmmc_rockchip ff4a0000.dwmmc: Version ID is 270a
[ 0.833906] dwmmc_rockchip ff4a0000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.833988] dwmmc_rockchip ff4a0000.dwmmc: No vmmc regulator found
[ 0.834011] dwmmc_rockchip ff4a0000.dwmmc: No vqmmc regulator found
[ 0.834393] dwmmc_rockchip ff4a0000.dwmmc: allocated mmc-pwrseq
[ 0.845003] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.856004] dwmmc_rockchip ff4a0000.dwmmc: 1 slots initialized
[ 0.856793] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.880985] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 0.917903] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 0.957059] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.958966] mmc_host mmc0: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 1.058034] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.159049] is31fl32xx_init_regs, write to shutdown register failed
[ 1.159248] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.260093] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.361085] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.462658] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 1.463178] rockchip-dmc dmc: Failed to get leakage
[ 1.463384] rockchip-dmc dmc: Failed to get pvtm
[ 1.464009] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 1.464061] rockchip-dmc dmc: don’t add devfreq feature
[ 1.467782] rknandc_base v1.1 2017-01-11
[ 1.468515] rknandc ff4b0000.nandc: rknandc_probe clk rate = 147456000
[ 1.468639] rkflash_dev_init
[ 1.468671] init rkflash[0]
[ 1.468731] No.1 FLASH ID:ef f1 0 95 0 0
[ 1.468765] SFTL version: 5.0.50 20181227
[ 1.505697] …FtlVpcCheckAndModify enter…
[ 1.519622] FtlCheckVpc 1ae = 40 30
[ 1.520614] rkflash[0] init success
[ 1.521023] rkflashd vendor storage init ok !
[ 1.526131] rkflash0: p1 p2 p3 p4 p5
[ 1.527707] rksfc_base v1.1 2016-01-08
[ 1.532423] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 1.532460] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 1.532590] The acodec version is: a
[ 1.533223] 1-001a supply AVDD not found, using dummy regulator
[ 1.533308] 1-001a supply DVDD not found, using dummy regulator
[ 1.533381] 1-001a supply PVDD_A not found, using dummy regulator
[ 1.533435] 1-001a supply PVDD_B not found, using dummy regulator
[ 1.533492] 1-001a supply PVDD_C not found, using dummy regulator
[ 1.533550] 1-001a supply PVDD_D not found, using dummy regulator
[ 1.533783] tas571x 1-001a: error requesting pdn_gpio: -16
[ 1.534158] tas571x: probe of 1-001a failed with error -16
[ 1.538916] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.538961] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.539277] rk-multicodecs vad-sound: ASoC: CPU DAI (null) not registered
[ 1.540460] NET: Registered protocol family 10
[ 1.541702] NET: Registered protocol family 17
[ 1.541778] NET: Registered protocol family 15
[ 1.542067] Bluetooth: RFCOMM TTY layer initialized
[ 1.542102] Bluetooth: RFCOMM socket layer initialized
[ 1.542139] Bluetooth: RFCOMM ver 1.11
[ 1.542170] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.542196] Bluetooth: HIDP socket layer initialized
[ 1.542218] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.542793] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.542868] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 1.542887] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.542899] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.543003] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 1.
[ 1.543022] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.543033] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.543048] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.543139] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.543632] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 1.543683] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 1.543749] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 1.543770] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.543892] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.543960] [BT_RFKILL]: ** disable irq
[ 1.544175] [BT_RFKILL]: bt_default device registered.
[ 1.544745] flash vendor_init_thread!
[ 1.544769] flash vendor storage:20170308 ret = -1
[ 1.546970] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 1.548281] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.548318] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.620565] rk-multicodecs vad-sound: multicodec ↔ pdm-i2s-dais mapping ok
[ 1.624366] rk-multicodecs bluetooth-sound: dummy_codec ↔ ff350000.i2s mapping ok
[ 1.626243] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 1.626280] ======== dhd_wlan_init_plat_data ========
[ 1.626293] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.626311] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=35, oob_irq_flags=0x418
[ 1.626321] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.626332] dhd_wifi_platform_load: Enter
[ 1.626396] Power-up adapter ‘DHD generic adapter’
[ 1.626468] wifi_platform_set_power = 1
[ 1.626480] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.626492] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.626504] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.627222] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.627689] hctosys: unable to open rtc device (rtc0)
[ 1.641534] vcc_sd: disabling
[ 1.641587] vbus_host: disabling
[ 1.641602] vccio_sd: disabling
[ 1.642016] ALSA device list:
[ 1.642039] #0: rockchip,rk3308-vad
[ 1.642050] #1: rockchip,rk3308-pcm
[ 1.642060] #7: Loopback 1
[ 1.642476] Freeing unused kernel memory: 320K
Starting logging: [ 1.681294] Unable to handle kernel paging request at virtual address eff[ de f 1.c68012908] Unabble to3 a3h%a
dle kernel paging request at virtual address ffffefc00bf3a3%0
  1. 开发板要区分是ROC-RK3308-CC还是ROC-RK3308B-CC
  2. 编译方法参考各开发板的维基教程
