安装RNKK-ToolKit问题
Failed building wheel for dill
Running setup.py clean for dill
Building wheel for PyYAML failed: [Errno 28] No space left on device: ‘/root/.cache/pip/wheels/e4/76’
Building wheel for MarkupSafe failed: [Errno 28] No space left on device: ‘/root/.cache/pip/wheels/f2’
Successfully built ruamel.yaml
Failed to build scipy dill PyYAML MarkupSafe
Installing collected packages: numpy, h5py, psutil, itsdangerous, click, MarkupSafe, Jinja2, flask, ruamel.yaml, scipy, protobuf, dill, ply, typing, onnx, PyYAML, onnx-tf, requests, lmdb, decorator, networkx, flatbuffers, Pillow, rknn-toolkit
Exception:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 360, in run
prefix=options.prefix_path,
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 784, in install
**kwargs
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 851, in install
self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 1064, in move_wheel_files
isolated=self.isolated,
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 345, in move_wheel_files
clobber(source, lib_dir, True)
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 316, in clobber
ensure_dir(destdir)
File “/usr/lib/python3/dist-packages/pip/utils/init.py”, line 83, in ensure_dir
os.makedirs(path)
File “/usr/lib/python3.6/os.py”, line 220, in makedirs
mkdir(name, mode)
OSError: [Errno 28] No space left on device: ‘/root/.local/lib/python3.6/site-packages/numpy-1.16.3.dist-info’
请问下以上,安装RKNN出现这个问题是什么问题?有什么办法解决吗?
不是显示没有内存空间了吗?
解决办法:清点东西,或者 扩充容量(sudo resize2fs /dev/mmcblk1p5)不过这个扩充容量的方法没试过,你可以试一下
装完以后,转换模型的时候还是会出问题.内存会不够.
