slime
按照官方的要求按照了demo http://www.t-firefly.com/doc/case/416.html 可以运行,但是报错了。报错如下,求助
firefly@firefly:~$ sudo test_ff_rtsp_dec
performance
dri_path: /dev/dri/card0
prefer_w: 1920
prefer_h: 1080
code_type: 0
line_count: 1
dst_s_size: 4791x0
dst_size: 480x360
rotate: 0
url: rtsp://192.168.50.231:554
usr: admin
pwd: cetc12345
tcp: 0
0
mpi: mpp version: Without VCS info
mpp_device: mpp_device_init failed to find device for coding 16777220 type 0
mpp_rt: NOT found ion allocator
mpp_rt: found drm allocator
[2020/03/06 18:31:07] D/: listening rtp port 59135
[2020/03/06 18:31:07] D/: listening rtcp port 59146
[2020/03/06 18:31:07] D/: listening rtp port 59145
[2020/03/06 18:31:07] D/: listening rtcp port 59136
[2020/03/06 18:31:07] D/: curlto rtsp://192.168.50.231:554 , cli 59135:59145, tcp: 0
[2020/03/06 18:31:08] D/: # FOUND[0] media: video
[2020/03/06 18:31:08] D/: # FOUND[0] control: rtsp://192.168.50.231:554/trackID=1
[2020/03/06 18:31:08] D/: # FOUND[0] rtpmap: id:96 format:H264 bitrate:90000
[2020/03/06 18:31:08] D/: # TOTAL FOUND 1
[2020/03/06 18:31:08] D/: TRACK [0] : rtsp://192.168.50.231:554/trackID=1
[2020/03/06 18:31:08] D/: setup 59135 , 59136, uri: rtsp://192.168.50.231:554/trackID=1
mpp_log: decode_get_frame failed, return -8.
[2020/03/06 18:31:08] D/: Video SSRC Changed! 0 → 951525269
[2020/03/06 18:31:08] W/: (onTransmitIn in unit_rtp_h264_unpack.cpp:53): rtp lost one packet … mDebugCntRtpLost: 65535 > 15227
[2020/03/06 18:31:08] D/: RTP4UP_UNIT_SE [0x55832246b8] loss/recv:-1676.97/ 0.03 SEI|SPS|PPS|NI|I: 0.00|0.03|0.00|0.00|0.00
======== EXIT ========
[2020/03/06 18:31:09] D/: close curl rtsp://192.168.50.231:554
[2020/03/06 18:31:09] D/: destroying curl rtsp …
[2020/03/06 18:31:09] D/: destroying curl rtsp … done
mpp_device: mpp_device_deinit invalid negtive file handle,
[2020/03/06 18:31:09] D/: destroying RtspClientUnitEM …
[2020/03/06 18:31:09] D/: socket close fd=14
[2020/03/06 18:31:09] D/: SOCKET : Closed -1
[2020/03/06 18:31:09] D/: socket close fd=15
[2020/03/06 18:31:09] D/: socket close fd=16
[2020/03/06 18:31:10] D/: socket close fd=13
[2020/03/06 18:31:10] D/: SOCKET : Closed -1
[2020/03/06 18:31:10] D/: destroying RtspClientUnitEM … done
slime
2
部分配置文件,如下:
“basepara” : {
“dri_path” : “/dev/dri/card0”,
"prefer_monitor_w" : 1920,
"prefer_monitor_h" : 1080,
"code_type" : "H264",
"line_count" : 1,
"output_w" : 480,
"output_h" : 360,
"rotate" : 0
"rtsp" : [
"id" : 0,
"url" : "rtsp://192.168.50.231:554",
"usr" : "admin",
"pwd" : "cetc12345",
"tcp" : false
你好,应用程序有更新,
apt update
apt install firefly-multi-rtsp
更新一下应用,再重新测试,谢谢!
slime
4
penguin 发表于 2020-3-7 12:37
你好,应用程序有更新,
apt update
感谢你的答复,我现在重新升级后,目前firefly-multi-rtsp版本是1.1但是仍有错误,错误和以前不一样了,如下:
performance
prefer_w: 1920
prefer_h: 1080
code_type: 0
line_count: 1
dst_s_size: 4791x0
dst_size: 480x360
rotate: 0
url: rtsp://168.168.50.203:8554/live
usr: admin
pwd: admin
tcp: 0
0
hal_h264d_api: Assertion vcodec_type & ((0x00000200) | (0x00000001) | (0x00000002)) failed at hal_h264d_init:104
hal_h264d_api: hal_h264d_init hard mode error, value=0
hal_h264d_api: Assertion 0 failed at hal_h264d_init:154
mpp_device: mpp_device_init failed to find device for coding 7 type 0
Segmentation fault (core dumped)
你好,我刚刚测试了一下,发现并没有此类错误。我现在上传更新一个3399pro的ubuntu18.04的固件,你测试一下行不行,再回复我结果。以免技术支持不及时。
slime
6
895816513 发表于 2020-3-12 17:46
你好,我刚刚测试了一下,发现并没有此类错误。我现在上传更新一个3399pro的ubuntu18.04的固件,你测试一下 …
你好感谢你的答复,目前我把系统刷了最新的 AIO-RK3399PRO-JD4-UBUNTU18.04-GPT-20200312-1733,test_ff_trsp_dec用的 1.1版本。
但是还是有如下问题:
图像通过HDMI输出,会显示一下,然后自动退出。程序还是正常在跑。
performance
prefer_w: 1920
prefer_h: 1080
code_type: 0
line_count: 1
dst_s_size: 4791x0
dst_size: 480x360
rotate: 0
usr: admin
pwd: cetc12345
tcp: 0
0
[2020/03/13 14:05:12] D/: listening rtp port 39561
[2020/03/13 14:05:12] D/: listening rtp port 39571
[2020/03/13 14:05:12] D/: listening rtcp port 39572
[2020/03/13 14:05:12] D/: curlto rtsp://192.168.50.231:554 , cli 39561:39571, tcp: 0
[2020/03/13 14:05:12] D/: listening rtcp port 39562
[2020/03/13 14:05:12] D/: # FOUND[0] media: video
[2020/03/13 14:05:12] D/: # FOUND[0] control: rtsp://192.168.50.231:554/trackID=1
[2020/03/13 14:05:12] D/: # FOUND[0] rtpmap: id:96 format:H264 bitrate:90000
[2020/03/13 14:05:12] D/: # TOTAL FOUND 1
[2020/03/13 14:05:12] D/: TRACK [0] : rtsp://192.168.50.231:554/trackID=1
[2020/03/13 14:05:12] D/: setup 39561 , 39562, uri: rtsp://192.168.50.231:554/trackID=1
[2020/03/13 14:05:12] D/: Video SSRC Changed! 0 → 1885702819
[2020/03/13 14:05:12] W/: (onTransmitIn in unit_rtp_h264_unpack.cpp:53): rtp lost one packet … mDebugCntRtpLost: 65535 > 22382
[2020/03/13 14:05:12] D/: RTP4UP_UNIT_SE [0x55a05426d8] loss/recv:-1438.47/ 0.03 SEI|SPS|PPS|NI|I: 0.00|0.03|0.00|0.00|0.00
mpp_log: MppDecoderDequeueFrame mpp_frame_get_info_change: info changed found
mpp_dec: mpp_dec use internal frame buffer group
first_frame
frame size 1920x1080, code size 1920x1088
create rga thread
line 0: 25.12 FPS
line 0: 24.94 FPS
[2020/03/13 14:05:21] D/: close curl rtsp://192.168.50.231:554
[2020/03/13 14:05:22] D/: destroying curl rtsp …
[2020/03/13 14:05:22] D/: destroying curl rtsp … done
[2020/03/13 14:05:22] D/: destroying RtspClientUnitEM …
[2020/03/13 14:05:22] D/: socket close fd=15
[2020/03/13 14:05:22] D/: SOCKET : Closed -1
[2020/03/13 14:05:23] D/: socket close fd=18
[2020/03/13 14:05:23] D/: SOCKET : Closed -1
[2020/03/13 14:05:23] D/: socket close fd=17
[2020/03/13 14:05:23] D/: socket close fd=16
[2020/03/13 14:05:23] D/: destroying RtspClientUnitEM … done
看log,像是应用正常退出的。 demo运行过程中, 按enter键,demo会退出运行(因为没有窗口管理)。你确认一下。
slime
8
penguin 发表于 2020-3-13 14:39
看log,像是应用正常退出的。 demo运行过程中, 按enter键,demo会退出运行(因为没有窗口管理)。你确认一 …
命令行界面是我按了enter正常退出的,问题不在命令行。我的意思是,我执行命令后,HDMI会输出实时的图像,但是输出图像不到1秒,就自动返回桌面了。
你是怎么执行的, 只有在接收到enter之后, 才会打印上述的log。
slime
10
通过SSL工具,执行sudo test_ff_rtsp_dec
HDMI连接一个1920*1080的显示器,显示器显示出摄像头的图像。1秒不到就自动退出了。
然后我发现显示不正常,就在SSL工具里面输入了enter
是先闪退,我才手动退出。
slime
11
HDMI连接一个1920*1080的显示器,显示器显示出摄像头的 …
如果不按enter,就会这样一直下去。。但是,但是HDMI是没输出的!!!
performance
prefer_w: 1920
prefer_h: 1080
code_type: 0
line_count: 1
dst_s_size: 4791x0
dst_size: 480x360
rotate: 0
usr: admin
pwd: cetc12345
tcp: 0
0
first_frame
create rga thread
line 0: 25.12 FPS
line 0: 24.94 FPS
line 0: 25.12 FPS
line 0: 24.94 FPS
line 0: 25.12 FPS
line 0: 24.94 FPS
line 0: 25.12 FPS
line 0: 24.94 FPS
贴一下你的/etc/X11/xorg.conf.d/20-modesettings.conf。 然后不要远程执行,直接在本地执行看看。
slime
13
以下是/etc/X11/xorg.conf.d$ cat 20-modesetting.conf 的配置:目前来看就是显示的问题了,我试了12路都能连上
firefly@firefly:/etc/X11/xorg.conf.d$ cat 20-modesetting.conf
Section “Device”
Identifier “Rockchip Graphics”
Driver “modesetting”
Option “AccelMethod” “exa”
# Option “AccelMethod” “glamor”
Option “DRI” “2”
Option “FlipFB” “always”
EndSection
Section “ServerFlags”
Option “BlankTime” “0”
Option “StandbyTime” “0”
Option “SuspendTime” “0”
Option “OffTime” “0”
EndSection
Section “Screen”
Identifier “Default Screen”
Device “Rockchip Graphics”
Monitor “Default Monitor”
EndSection
### Valid values for rotation are “normal”, “left”, “right”
Section “Monitor”
Identifier “Default Monitor”
Option “Rotate” “normal”
Option “DPMS” “false”
EndSection
在20-modesetting.conf 中删除 Option “FlipFB” “always”
再重启一下,测试一下。
performance
prefer_w: 1920
prefer_h: 1080
code_type: 0
line_count: 1
dst_s_size: 2228638540x127
dst_size: 480x360
rotate: 0
url: rtsp://192.168.1.181/stream1
usr: admin
pwd: admin
tcp: 1
0
[2020/03/18 12:09:10] D/: listening rtp port 55886
[2020/03/18 12:09:10] D/: listening rtp port 55896
[2020/03/18 12:09:10] D/: curlto rtsp://192.168.1.181/stream1 , cli 55886:55896, tcp: 0
[2020/03/18 12:09:10] D/: listening rtcp port 55897
[2020/03/18 12:09:10] D/: listening rtcp port 55887
[2020/03/18 12:09:10] D/: # FOUND[0] media: video
[2020/03/18 12:09:10] D/: # FOUND[0] rtpmap: id:96 format:H264 bitrate:90000
[2020/03/18 12:09:10] D/: # FOUND[0] control: track1
[2020/03/18 12:09:10] D/: # TOTAL FOUND 1
[2020/03/18 12:09:10] D/: TRACK [0] : track1
[2020/03/18 12:09:10] D/: setup 55886 , 55887, uri: rtsp://192.168.1.181/stream1/track1
[2020/03/18 12:09:16] W/: (threadRtpFunc in unit_rtsp_client.cpp:122): UDP-RTP receive timeout. rtsp://192.168.1.181/stream1 ; type = Video
[2020/03/18 12:09:16] W/: (threadRtpFunc in unit_rtsp_client.cpp:122): UDP-RTP receive timeout. rtsp://192.168.1.181/stream1 ; type = Audio
[2020/03/18 12:09:16] D/: close curl rtsp://19
你好,我也在弄这个,请教下,我的显示这个是什么原因呢?
你好,应用程序有更新,
apt update
更新一下应用,再重新测试,谢谢!
penguin 发表于 2020-3-19 09:00
你好,应用程序有更新,
apt update
“basepara” : {
"line_count" : 1,
"output_w" : 480,
"output_h" : 360,
"rotate" : 0
"rtsp" : [
"id" : 0,
"url" : "rtsp://192.168.1.181/stream1",
"usr" : "admin",
"pwd" : "admin",
"tcp" : true
这是我配置的参数,麻烦帮我看看
配置看上去没有问题,tcp 设为false.
你dpkg -l firefly-multi-rtsp , 我看下。
[2020/03/19 12:50:28] W/: (threadRtpFunc in unit_rtsp_client.cpp:122): UDP-RTP receive timeout. rtsp://192.168.1.181/stream1 ; type = Video
[2020/03/19 12:50:28] D/: close curl rtsp://192.168.1.181/stream1
[2020/03/19 12:50:28] D/: destroying curl rtsp …
[2020/03/19 12:50:28] D/: destroying curl rtsp … done
[2020/03/19 12:50:28] D/: ReEnable rtsp client [1] rtsp://192.168.1.181/stream1
[2020/03/19 12:50:28] D/: curlto rtsp://192.168.1.181/stream1 , cli 40658:40668, tcp: 0
[2020/03/19 12:50:28] W/: (threadRtpFunc in unit_rtsp_client.cpp:122): UDP-RTP receive timeout. rtsp://192.168.1.181/stream1 ; type = Audio
[2020/03/19 12:50:29] D/: # FOUND[0] media: video
[2020/03/19 12:50:29] D/: # FOUND[0] rtpmap: id:96 format:H264 bitrate:90000
[2020/03/19 12:50:29] D/: # FOUND[0] control: track1
[2020/03/19 12:50:29] D/: # TOTAL FOUND 1
[2020/03/19 12:50:29] D/: TRACK [0] : track1
[2020/03/19 12:50:29] D/: setup 40658 , 40659, uri: rtsp://192.168.1.181/stream1/track1
换flase也是这样的。
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii firefly-multi-rtsp 1.1 arm64 Firefly multiple RTSP stream decode demo
