Demon 发表于 2020-3-11 10:18
您好,麻烦log发一下,还有您的驱动文件。
debug 端口已经被我设置成disabled了,下面的是linux kernel log, 红色两行是我在/kernel/drivers/pwm/pwm-rockchip.c中加的日志,该文件未做其他修改。附件是相关的dts文件。
请帮我看看,谢谢!
– Logs begin at Sun 2017-01-01 12:06:50 UTC, end at Tue 2020-01-14 08:13:35 UTC. –
Jan 01 12:06:50 firefly kernel: Booting Linux on physical CPU 0x500
Jan 01 12:06:50 firefly kernel: Initializing cgroup subsys cpuset
Jan 01 12:06:50 firefly kernel: Initializing cgroup subsys cpuacct
Jan 01 12:06:50 firefly kernel: Linux version 4.4.154 (wlgy@ubuntu) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #13 SMP Mon Mar 9 21:00:16 PDT 2020
Jan 01 12:06:50 firefly kernel: CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
Jan 01 12:06:50 firefly kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jan 01 12:06:50 firefly kernel: Machine model: Firefly-RK3288 Board (Linux Opensource)
Jan 01 12:06:50 firefly kernel: cma: Reserved 16 MiB at 0x7f000000
Jan 01 12:06:50 firefly kernel: Memory policy: Data cache writealloc
Jan 01 12:06:50 firefly kernel: On node 0 totalpages: 520704
Jan 01 12:06:50 firefly kernel: free_area_init_node: node 0, pgdat c13eed80, node_mem_map eeffa000
Jan 01 12:06:50 firefly kernel: Normal zone: 1536 pages used for memmap
Jan 01 12:06:50 firefly kernel: Normal zone: 0 pages reserved
Jan 01 12:06:50 firefly kernel: Normal zone: 193024 pages, LIFO batch:31
Jan 01 12:06:50 firefly kernel: HighMem zone: 327680 pages, LIFO batch:31
Jan 01 12:06:50 firefly kernel: psci: probing for conduit method from DT.
Jan 01 12:06:50 firefly kernel: psci: PSCIv65535.65535 detected in firmware.
Jan 01 12:06:50 firefly kernel: psci: Using standard PSCI v0.2 function IDs
Jan 01 12:06:50 firefly kernel: psci: MIGRATE_INFO_TYPE not supported.
Jan 01 12:06:50 firefly kernel: PERCPU: Embedded 14 pages/cpu @eef7c000 s24728 r8192 d24424 u57344
Jan 01 12:06:50 firefly kernel: pcpu-alloc: s24728 r8192 d24424 u57344 alloc=14*4096
Jan 01 12:06:50 firefly kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jan 01 12:06:50 firefly kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519168
Jan 01 12:06:50 firefly kernel: Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 earlyprintk rw rootwait console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 systemd.gpt_auto=0
Jan 01 12:06:50 firefly kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Jan 01 12:06:50 firefly kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Jan 01 12:06:50 firefly kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 01 12:06:50 firefly kernel: Memory: 2027088K/2082816K available (12288K kernel code, 993K rwdata, 3408K rodata, 1024K init, 641K bss, 39344K reserved, 16384K cma-reserved, 1293716K highmem)
Jan 01 12:06:50 firefly kernel: Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1300000 (1024 kB)
.data : 0xc1300000 - 0xc13f8434 ( 994 kB)
.bss : 0xc13fa000 - 0xc149a4b0 ( 642 kB)
Jan 01 12:06:50 firefly kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jan 01 12:06:50 firefly kernel: Hierarchical RCU implementation.
Jan 01 12:06:50 firefly kernel: Build-time adjustment of leaf fanout to 32.
Jan 01 12:06:50 firefly kernel: NR_IRQS:16 nr_irqs:16 16
Jan 01 12:06:50 firefly kernel: rockchip_mmc_get_phase: invalid clk rate
Jan 01 12:06:50 firefly kernel: Architected cp15 timer(s) running at 24.00MHz (phys).
Jan 01 12:06:50 firefly kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Jan 01 12:06:50 firefly kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Jan 01 12:06:50 firefly kernel: Switching to timer-based delay loop, resolution 41ns
Jan 01 12:06:50 firefly kernel: Console: colour dummy device 80x30
Jan 01 12:06:50 firefly kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
Jan 01 12:06:50 firefly kernel: pid_max: default: 32768 minimum: 301
Jan 01 12:06:50 firefly kernel: Security Framework initialized
Jan 01 12:06:50 firefly kernel: Yama: becoming mindful.
Jan 01 12:06:50 firefly kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 01 12:06:50 firefly kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 01 12:06:50 firefly kernel: Initializing cgroup subsys devices
Jan 01 12:06:50 firefly kernel: Initializing cgroup subsys freezer
Jan 01 12:06:50 firefly kernel: CPU: Testing write buffer coherency: ok
Jan 01 12:06:50 firefly kernel: ftrace: allocating 44049 entries in 130 pages
Jan 01 12:06:50 firefly kernel: CPU0: update cpu_capacity 430
Jan 01 12:06:50 firefly kernel: CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
Jan 01 12:06:50 firefly kernel: Setting up static identity map for 0x100000 - 0x100058
Jan 01 12:06:50 firefly kernel: CPU1: update cpu_capacity 430
Jan 01 12:06:50 firefly kernel: CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
Jan 01 12:06:50 firefly kernel: CPU2: update cpu_capacity 430
Jan 01 12:06:50 firefly kernel: CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
Jan 01 12:06:50 firefly kernel: CPU3: update cpu_capacity 430
Jan 01 12:06:50 firefly kernel: CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
Jan 01 12:06:50 firefly kernel: Brought up 4 CPUs
Jan 01 12:06:50 firefly kernel: SMP: Total of 4 processors activated (192.00 BogoMIPS).
Jan 01 12:06:50 firefly kernel: CPU: All CPU(s) started in SVC mode.
Jan 01 12:06:50 firefly kernel: devtmpfs: initialized
Jan 01 12:06:50 firefly kernel: VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
Jan 01 12:06:50 firefly kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jan 01 12:06:50 firefly kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
Jan 01 12:06:50 firefly kernel: pinctrl core: initialized pinctrl subsystem
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 16
Jan 01 12:06:50 firefly kernel: DMA: preallocated 256 KiB pool for atomic coherent allocations
Jan 01 12:06:50 firefly kernel: cpuidle: using governor ladder
Jan 01 12:06:50 firefly kernel: cpuidle: using governor menu
Jan 01 12:06:50 firefly kernel: Registered FIQ tty driver
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 0 to 23 on device: gpio0
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 24 to 55 on device: gpio1
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 56 to 87 on device: gpio2
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 88 to 119 on device: gpio3
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 120 to 151 on device: gpio4
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 152 to 183 on device: gpio5
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 184 to 215 on device: gpio6
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 216 to 247 on device: gpio7
Jan 01 12:06:50 firefly kernel: gpiochip_add_data: registered GPIOs 248 to 263 on device: gpio8
Jan 01 12:06:50 firefly kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Jan 01 12:06:50 firefly kernel: hw-breakpoint: maximum watchpoint size is 4 bytes.
Jan 01 12:06:50 firefly kernel: fiq debugger fiq mode enabled
Jan 01 12:06:50 firefly kernel: console [ttyFIQ0] enabled
Jan 01 12:06:50 firefly kernel: Registered fiq debugger ttyFIQ0
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vccadc-ref[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/usb-host-regulator[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/usb-otg-regulator[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vsys-regulator[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/flash-regulator[0]’
Jan 01 12:06:50 firefly kernel: vcc_flash: regulator get failed, ret=-517
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/sdmmc-regulator[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: vcc_sd: regulator get failed, ret=-517
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc28-dvp-regulator[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: vcc28_dvp: regulator get failed, ret=-517
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/dovdd-1v8-regulator[0]’
Jan 01 12:06:50 firefly kernel: dovdd_1v8: regulator get failed, ret=-517
Jan 01 12:06:50 firefly kernel: iommu: Adding device ff910000.isp to group 0
Jan 01 12:06:50 firefly kernel: iommu: Adding device ff930000.vop to group 1
Jan 01 12:06:50 firefly kernel: iommu: Adding device ff940000.vop to group 2
Jan 01 12:06:50 firefly kernel: iommu: Adding device ff9a0000.vpu-service to group 3
Jan 01 12:06:50 firefly kernel: iommu: Adding device ff9c0000.hevc-service to group 4
Jan 01 12:06:50 firefly kernel: SCSI subsystem initialized
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver usbfs
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver hub
Jan 01 12:06:50 firefly kernel: usbcore: registered new device driver usb
Jan 01 12:06:50 firefly kernel: media: Linux media interface: v0.10
Jan 01 12:06:50 firefly kernel: Linux video capture interface: v2.00
Jan 01 12:06:50 firefly kernel: pps_core: LinuxPPS API ver. 1 registered
Jan 01 12:06:50 firefly kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan 01 12:06:50 firefly kernel: PTP clock support registered
Jan 01 12:06:50 firefly kernel: Advanced Linux Sound Architecture Driver Initialized.
Jan 01 12:06:50 firefly kernel: Bluetooth: Core ver 2.21
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 31
Jan 01 12:06:50 firefly kernel: Bluetooth: HCI device and connection manager initialized
Jan 01 12:06:50 firefly kernel: Bluetooth: HCI socket layer initialized
Jan 01 12:06:50 firefly kernel: Bluetooth: L2CAP socket layer initialized
Jan 01 12:06:50 firefly kernel: Bluetooth: SCO socket layer initialized
Jan 01 12:06:50 firefly kernel: rockchip-cpuinfo cpuinfo: Serial : 754277dfa70f9fa8
Jan 01 12:06:50 firefly kernel: clocksource: Switched to clocksource arch_sys_counter
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 2
Jan 01 12:06:50 firefly kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Jan 01 12:06:50 firefly kernel: TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
Jan 01 12:06:50 firefly kernel: TCP: Hash tables configured (established 8192 bind 8192)
Jan 01 12:06:50 firefly kernel: UDP hash table entries: 512 (order: 2, 24576 bytes)
Jan 01 12:06:50 firefly kernel: UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
Jan 01 12:06:50 firefly kernel: RPC: Registered named UNIX socket transport module.
Jan 01 12:06:50 firefly kernel: RPC: Registered udp transport module.
Jan 01 12:06:50 firefly kernel: RPC: Registered tcp transport module.
Jan 01 12:06:50 firefly kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 01 12:06:50 firefly kernel: hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
Jan 01 12:06:50 firefly kernel: Initialise system trusted keyring
Jan 01 12:06:50 firefly kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 01 12:06:50 firefly kernel: NFS: Registering the id_resolver key type
Jan 01 12:06:50 firefly kernel: Key type id_resolver registered
Jan 01 12:06:50 firefly kernel: Key type id_legacy registered
Jan 01 12:06:50 firefly kernel: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Jan 01 12:06:50 firefly kernel: fuse init (API version 7.23)
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 38
Jan 01 12:06:50 firefly kernel: Key type asymmetric registered
Jan 01 12:06:50 firefly kernel: Asymmetric key parser ‘x509’ registered
Jan 01 12:06:50 firefly kernel: bounce: pool size: 64 pages
Jan 01 12:06:50 firefly kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Jan 01 12:06:50 firefly kernel: io scheduler noop registered
Jan 01 12:06:50 firefly kernel: io scheduler deadline registered
Jan 01 12:06:50 firefly kernel: io scheduler cfq registered (default)
Jan 01 12:06:50 firefly kernel: ###***rockchip_pwm_probe: ff680010.pwm
Jan 01 12:06:50 firefly kernel: ###***rockchip_pwm_probe: ff680020.pwm
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9a0000.vpu-service: probe device
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9a0000.vpu-service: could not find power_model node
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9a0000.vpu-service: init success
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9c0000.hevc-service: probe device
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9c0000.hevc-service: could not find power_model node
Jan 01 12:06:50 firefly kernel: rk-vcodec ff9c0000.hevc-service: init success
Jan 01 12:06:50 firefly kernel: dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
Jan 01 12:06:50 firefly kernel: dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
Jan 01 12:06:50 firefly kernel: dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
Jan 01 12:06:50 firefly kernel: dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
Jan 01 12:06:50 firefly kernel: Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
Jan 01 12:06:50 firefly kernel: ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
Jan 01 12:06:50 firefly kernel: ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 37, base_baud = 1500000) is a 16550A
Jan 01 12:06:50 firefly kernel: ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 38, base_baud = 1500000) is a 16550A
Jan 01 12:06:50 firefly kernel: ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 39, base_baud = 1500000) is a 16550A
Jan 01 12:06:50 firefly kernel: [drm] Initialized drm 1.1.0 20060810
Jan 01 12:06:50 firefly kernel: [drm] Rockchip DRM driver version: v1.0.1
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: devfreq is not set
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d6187c)
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d6187c)
Jan 01 12:06:50 firefly kernel: i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
Jan 01 12:06:50 firefly kernel: dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
Jan 01 12:06:50 firefly kernel: dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d5a340)
Jan 01 12:06:50 firefly kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Jan 01 12:06:50 firefly kernel: [drm] No driver support for vblank timestamp query.
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: can’t not find any loader display
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: failed to show loader logo
Jan 01 12:06:50 firefly kernel: Freeing drm_logo memory: 616K
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: No connectors reported connected with modes
Jan 01 12:06:50 firefly kernel: [drm] Cannot find any crtc or sizes - going 1024x768
Jan 01 12:06:50 firefly kernel: rockchip-drm display-subsystem: fb0: frame buffer device
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver udl
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Failed to get regulator
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Power control initialization failed
Jan 01 12:06:50 firefly kernel: brd: module loaded
Jan 01 12:06:50 firefly kernel: loop: module loaded
Jan 01 12:06:50 firefly kernel: zram: Added device: zram0
Jan 01 12:06:50 firefly kernel: lkdtm: No crash points registered, enable through debugfs
Jan 01 12:06:50 firefly kernel: register spi return v = :0
Jan 01 12:06:50 firefly kernel: tun: Universal TUN/TAP device driver, 1.6
Jan 01 12:06:50 firefly kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jan 01 12:06:50 firefly kernel: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
Jan 01 12:06:50 firefly kernel: PPP generic driver version 2.4.2
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver rndis_wlan
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver rt2800usb
Jan 01 12:06:50 firefly kernel: Rockchip WiFi SYS interface (V1.00) …
Jan 01 12:06:50 firefly kernel: pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver pegasus
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver rtl8150
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver r8152
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver asix
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver ax88179_178a
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver cdc_ether
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver dm9601
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver smsc75xx
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver smsc95xx
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver net1080
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver rndis_host
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver MOSCHIP usb-ethernet driver
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver cdc_ncm
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver qmi_wwan
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver cdc_mbim
Jan 01 12:06:50 firefly kernel: ff540000.usb supply vusb_d not found, using dummy regulator
Jan 01 12:06:50 firefly kernel: ff540000.usb supply vusb_a not found, using dummy regulator
Jan 01 12:06:50 firefly kernel: dwc2 ff540000.usb: DWC OTG Controller
Jan 01 12:06:50 firefly kernel: dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
Jan 01 12:06:50 firefly kernel: dwc2 ff540000.usb: irq 45, io mem 0xff540000
Jan 01 12:06:50 firefly kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 01 12:06:50 firefly kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 01 12:06:50 firefly kernel: usb usb1: Product: DWC OTG Controller
Jan 01 12:06:50 firefly kernel: usb usb1: Manufacturer: Linux 4.4.154 dwc2_hsotg
Jan 01 12:06:50 firefly kernel: usb usb1: SerialNumber: ff540000.usb
Jan 01 12:06:50 firefly kernel: hub 1-0:1.0: USB hub found
Jan 01 12:06:50 firefly kernel: hub 1-0:1.0: 1 port detected
Jan 01 12:06:50 firefly kernel: ff580000.usb supply vusb_d not found, using dummy regulator
Jan 01 12:06:50 firefly kernel: ff580000.usb supply vusb_a not found, using dummy regulator
Jan 01 12:06:50 firefly kernel: dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
Jan 01 12:06:50 firefly kernel: dwc2 ff580000.usb: DWC OTG Controller
Jan 01 12:06:50 firefly kernel: dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
Jan 01 12:06:50 firefly kernel: dwc2 ff580000.usb: irq 46, io mem 0xff580000
Jan 01 12:06:50 firefly kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jan 01 12:06:50 firefly kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 01 12:06:50 firefly kernel: usb usb2: Product: DWC OTG Controller
Jan 01 12:06:50 firefly kernel: usb usb2: Manufacturer: Linux 4.4.154 dwc2_hsotg
Jan 01 12:06:50 firefly kernel: usb usb2: SerialNumber: ff580000.usb
Jan 01 12:06:50 firefly kernel: hub 2-0:1.0: USB hub found
Jan 01 12:06:50 firefly kernel: hub 2-0:1.0: 1 port detected
Jan 01 12:06:50 firefly kernel: ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Jan 01 12:06:50 firefly kernel: ehci-platform: EHCI generic platform driver
Jan 01 12:06:50 firefly kernel: ehci-platform ff500000.usb: EHCI Host Controller
Jan 01 12:06:50 firefly kernel: ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
Jan 01 12:06:50 firefly kernel: ehci-platform ff500000.usb: irq 43, io mem 0xff500000
Jan 01 12:06:50 firefly kernel: usb 1-1: new high-speed USB device number 2 using dwc2
Jan 01 12:06:50 firefly kernel: ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
Jan 01 12:06:50 firefly kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Jan 01 12:06:50 firefly kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 01 12:06:50 firefly kernel: usb usb3: Product: EHCI Host Controller
Jan 01 12:06:50 firefly kernel: usb usb3: Manufacturer: Linux 4.4.154 ehci_hcd
Jan 01 12:06:50 firefly kernel: usb usb3: SerialNumber: ff500000.usb
Jan 01 12:06:50 firefly kernel: hub 3-0:1.0: USB hub found
Jan 01 12:06:50 firefly kernel: hub 3-0:1.0: 1 port detected
Jan 01 12:06:50 firefly kernel: ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Jan 01 12:06:50 firefly kernel: ohci-platform: OHCI generic platform driver
Jan 01 12:06:50 firefly kernel: ohci-platform ff520000.usb: Generic Platform OHCI controller
Jan 01 12:06:50 firefly kernel: ohci-platform ff520000.usb: new USB bus registered, assigned bus number 4
Jan 01 12:06:50 firefly kernel: ohci-platform ff520000.usb: irq 44, io mem 0xff520000
Jan 01 12:06:50 firefly kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Jan 01 12:06:50 firefly kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 01 12:06:50 firefly kernel: usb usb4: Product: Generic Platform OHCI controller
Jan 01 12:06:50 firefly kernel: usb usb4: Manufacturer: Linux 4.4.154 ohci_hcd
Jan 01 12:06:50 firefly kernel: usb usb4: SerialNumber: ff520000.usb
Jan 01 12:06:50 firefly kernel: hub 4-0:1.0: USB hub found
Jan 01 12:06:50 firefly kernel: hub 4-0:1.0: 1 port detected
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver cdc_acm
Jan 01 12:06:50 firefly kernel: cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver cdc_wdm
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver usb-storage
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver usbserial
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver usbserial_generic
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for generic
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver cp210x
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for cp210x
Jan 01 12:06:50 firefly kernel: usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
Jan 01 12:06:50 firefly kernel: usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Jan 01 12:06:50 firefly kernel: usb 1-1: Product: USB 2.0 Hub [MTT]
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver ftdi_sio
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for FTDI USB Serial Device
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver keyspan
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for Keyspan - (without firmware)
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for Keyspan 1 port adapter
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for Keyspan 2 port adapter
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for Keyspan 4 port adapter
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver option
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for GSM modem (1-port)
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver oti6858
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for oti6858
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver pl2303
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for pl2303
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver qcserial
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for Qualcomm USB modem
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver sierra
Jan 01 12:06:50 firefly kernel: usbserial: USB Serial support registered for Sierra USB modem
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver iforce
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver xpad
Jan 01 12:06:50 firefly kernel: ==gsl_ts_init==
Jan 01 12:06:50 firefly kernel: ret=0
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver usbtouchscreen
Jan 01 12:06:50 firefly kernel: .. rk pwm remotectl v1.1 init
Jan 01 12:06:50 firefly kernel: input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
Jan 01 12:06:50 firefly kernel: sensor_register_slave:mma8452,id=17
Jan 01 12:06:50 firefly kernel: sensor_register_slave:lis3dh,id=7
Jan 01 12:06:50 firefly kernel: sensor_register_slave:mma7660,id=18
Jan 01 12:06:50 firefly kernel: sensor_register_slave:lsm303d,id=22
Jan 01 12:06:50 firefly kernel: sensor_register_slave:gs_mc3230,id=23
Jan 01 12:06:50 firefly kernel: [Gsensor] gsensor_init
Jan 01 12:06:50 firefly kernel: sensor_register_slave:mpu6880_acc,id=24
Jan 01 12:06:50 firefly kernel: sensor_register_slave:mpu6500_acc,id=25
Jan 01 12:06:50 firefly kernel: sensor_register_slave:lsm330_acc,id=26
Jan 01 12:06:50 firefly kernel: sensor_register_slave:akm8975,id=30
Jan 01 12:06:50 firefly kernel: sensor_register_slave:akm8963,id=31
Jan 01 12:06:50 firefly kernel: sensor_register_slave:l3g4200d,id=45
Jan 01 12:06:50 firefly kernel: sensor_register_slave:l3g20d,id=46
Jan 01 12:06:50 firefly kernel: sensor_register_slave:ewtsa,id=47
Jan 01 12:06:50 firefly kernel: sensor_register_slave:lsm330_gyro,id=51
Jan 01 12:06:50 firefly kernel: sensor_register_slave:cm3217,id=53
Jan 01 12:06:50 firefly kernel: sensor_register_slave:cm3218,id=54
Jan 01 12:06:50 firefly kernel: i2c /dev entries driver
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0040: GPIO lookup for consumer vsel
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0040: using device tree for GPIO lookup
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff650000/syr827@40[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff650000/syr827@40[0]’
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0040: using lookup tables for GPIO lookup
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0040: lookup for GPIO vsel failed
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
Jan 01 12:06:50 firefly kernel: fan53555-reg: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0041: GPIO lookup for consumer vsel
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0041: using device tree for GPIO lookup
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff650000/syr828@41[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff650000/syr828@41[0]’
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0041: using lookup tables for GPIO lookup
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0041: lookup for GPIO vsel failed
Jan 01 12:06:50 firefly kernel: fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
Jan 01 12:06:50 firefly kernel: rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
Jan 01 12:06:50 firefly kernel: REG1: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG2: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: vcc_flash: supplied by vcc_io
Jan 01 12:06:50 firefly kernel: vcc_sd: supplied by vcc_io
Jan 01 12:06:50 firefly kernel: vcc28_dvp: supplied by vcc_io
Jan 01 12:06:50 firefly kernel: dovdd_1v8: supplied by vcc28_dvp
Jan 01 12:06:50 firefly kernel: REG3: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG4: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG5: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG6: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG7: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG8: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG9: supplied by vcc_sys
Jan 01 12:06:50 firefly kernel: REG10: supplied by vcc_20
Jan 01 12:06:50 firefly kernel: REG11: supplied by vcc_20
Jan 01 12:06:50 firefly kernel: REG12: supplied by vcc_20
Jan 01 12:06:50 firefly kernel: rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0c22000
Jan 01 12:06:50 firefly kernel: rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f0c24000
Jan 01 12:06:50 firefly kernel: rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0c26000
Jan 01 12:06:50 firefly kernel: rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0c28000
Jan 01 12:06:50 firefly kernel: rockchip-rga ff920000.rga: HW Version: 0x03.00
Jan 01 12:06:50 firefly kernel: rockchip-rga ff920000.rga: Registered rockchip-rga as /dev/video0
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver uvcvideo
Jan 01 12:06:50 firefly kernel: USB Video Class driver (1.1.1)
Jan 01 12:06:50 firefly kernel: rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
Jan 01 12:06:50 firefly kernel: rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
Jan 01 12:06:50 firefly kernel: rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
Jan 01 12:06:50 firefly kernel: softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
Jan 01 12:06:50 firefly kernel: device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
Jan 01 12:06:50 firefly kernel: Bluetooth: Virtual HCI driver ver 1.5
Jan 01 12:06:50 firefly kernel: Bluetooth: HCI UART driver ver 2.3
Jan 01 12:06:50 firefly kernel: Bluetooth: HCI UART protocol H4 registered
Jan 01 12:06:50 firefly kernel: Bluetooth: HCI UART protocol LL registered
Jan 01 12:06:50 firefly kernel: Bluetooth: HCI UART protocol ATH3K registered
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver bfusb
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver btusb
Jan 01 12:06:50 firefly kernel: cpu cpu0: bin=1
Jan 01 12:06:50 firefly kernel: cpu cpu0: leakage=12
Jan 01 12:06:50 firefly kernel: cpu cpu0: temp=35454, pvtm=16036 (16036 + 0)
Jan 01 12:06:50 firefly kernel: rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
Jan 01 12:06:50 firefly kernel: cpu cpu0: pvtm-volt-sel=3
Jan 01 12:06:50 firefly kernel: cpu cpu0: bin-scale=25
Jan 01 12:06:50 firefly kernel: cpu cpu0: avs=0, target-scale=25
Jan 01 12:06:50 firefly kernel: cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
Jan 01 12:06:50 firefly kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 01 12:06:50 firefly kernel: sdhci: Copyright(c) Pierre Ossman
Jan 01 12:06:50 firefly kernel: Synopsys Designware Multimedia Card Interface Driver
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer cd
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@ff0c0000[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@ff0c0000[0]’
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO lookup
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO cd failed
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer wp
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff0c0000[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff0c0000[0]’
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO wp failed
Jan 01 12:06:50 firefly kernel: rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
Jan 01 12:06:50 firefly kernel: mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: GPIO lookup for consumer wp
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: using device tree for GPIO lookup
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff0d0000[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff0d0000[0]’
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: using lookup tables for GPIO lookup
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: lookup for GPIO wp failed
Jan 01 12:06:50 firefly kernel: platform sdio-pwrseq: GPIO lookup for consumer reset
Jan 01 12:06:50 firefly kernel: platform sdio-pwrseq: using device tree for GPIO lookup
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/sdio-pwrseq[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
Jan 01 12:06:50 firefly kernel: mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: No vmmc regulator found
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: No vqmmc regulator found
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: GPIO lookup for consumer wp
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: using device tree for GPIO lookup
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff0f0000[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff0f0000[0]’
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: using lookup tables for GPIO lookup
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: lookup for GPIO wp failed
Jan 01 12:06:50 firefly kernel: mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Jan 01 12:06:50 firefly kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Jan 01 12:06:50 firefly kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jan 01 12:06:50 firefly kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Jan 01 12:06:50 firefly kernel: mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
Jan 01 12:06:50 firefly kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/work[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/user[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: hidraw: raw HID events driver (C) Jiri Kosina
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver usbhid
Jan 01 12:06:50 firefly kernel: usbhid: USB HID core driver
Jan 01 12:06:50 firefly kernel: ashmem: initialized
Jan 01 12:06:50 firefly kernel: rockchip-dmc dmc: unable to get devfreq-event device : dfi
Jan 01 12:06:50 firefly kernel: rknandbase v1.2 2018-05-08
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver snd-usb-audio
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘spk-ctl-gpio’ property of node ‘/i2c@ff660000/es8323@10[0]’
Jan 01 12:06:50 firefly kernel: ES8323 2-0010: Can not read property spk_ctl_gpio
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘hp-ctl-gpio’ property of node ‘/i2c@ff660000/es8323@10[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘hp-det-gpio’ property of node ‘/i2c@ff660000/es8323@10[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘aux-det-gpio’ property of node ‘/i2c@ff660000/es8323@10[0]’
Jan 01 12:06:50 firefly kernel: ES8323 2-0010: Can not read property aux_det_gpio
Jan 01 12:06:50 firefly kernel: u32 classifier
Jan 01 12:06:50 firefly kernel: Netfilter messages via NETLINK v0.30.
Jan 01 12:06:50 firefly kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Jan 01 12:06:50 firefly kernel: ctnetlink v0.93: registering with nfnetlink.
Jan 01 12:06:50 firefly kernel: ip_set: protocol 6
Jan 01 12:06:50 firefly kernel: IPVS: Registered protocols ()
Jan 01 12:06:50 firefly kernel: IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
Jan 01 12:06:50 firefly kernel: IPVS: Creating netns size=1104 id=0
Jan 01 12:06:50 firefly kernel: IPVS: ipvs loaded.
Jan 01 12:06:50 firefly kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 01 12:06:50 firefly kernel: Initializing XFRM netlink socket
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 10
Jan 01 12:06:50 firefly kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 01 12:06:50 firefly kernel: sit: IPv6 over IPv4 tunneling driver
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 17
Jan 01 12:06:50 firefly kernel: NET: Registered protocol family 15
Jan 01 12:06:50 firefly kernel: bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
Jan 01 12:06:50 firefly kernel: Bridge firewalling registered
Jan 01 12:06:50 firefly kernel: Bluetooth: RFCOMM socket layer initialized
Jan 01 12:06:50 firefly kernel: Bluetooth: RFCOMM ver 1.11
Jan 01 12:06:50 firefly kernel: Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Jan 01 12:06:50 firefly kernel: Bluetooth: HIDP socket layer initialized
Jan 01 12:06:50 firefly kernel: 8021q: 802.1Q VLAN Support v1.8
Jan 01 12:06:50 firefly kernel: lib80211: common routines for IEEE802.11 drivers
Jan 01 12:06:50 firefly kernel: lib80211_crypt: registered algorithm ‘NULL’
Jan 01 12:06:50 firefly kernel: lib80211_crypt: registered algorithm ‘WEP’
Jan 01 12:06:50 firefly kernel: lib80211_crypt: registered algorithm ‘CCMP’
Jan 01 12:06:50 firefly kernel: lib80211_crypt: registered algorithm ‘TKIP’
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: Enter rfkill_wlan_init
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: Enter rfkill_wlan_probe
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘WIFI,poweren_gpio’ property of node ‘/wireless-wlan[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘WIFI,vbat_gpio’ property of node ‘/wireless-wlan[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘WIFI,reset_gpio’ property of node ‘/wireless-wlan[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘WIFI,host_wake_irq’ property of node ‘/wireless-wlan[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: Exit rfkill_wlan_probe
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: Enter rfkill_rk_init
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘uart_rts_gpios’ property of node ‘/wireless-bluetooth[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘BT,power_gpio’ property of node ‘/wireless-bluetooth[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘BT,reset_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘BT,wake_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘BT,wake_host_irq’ property of node ‘/wireless-bluetooth[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: Request irq for bt wakeup host
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: ** disable irq
Jan 01 12:06:50 firefly kernel: [BT_RFKILL]: bt_default device registered.
Jan 01 12:06:50 firefly kernel: Key type dns_resolver registered
Jan 01 12:06:50 firefly kernel: sensor_register_slave:mpu6880_gyro,id=50
Jan 01 12:06:50 firefly kernel: ThumbEE CPU extension supported.
Jan 01 12:06:50 firefly kernel: Registering SWP/SWPB emulation handler
Jan 01 12:06:50 firefly kernel: Loading compiled-in X.509 certificates
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Failed to get leakage
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Failed to get pvtm
Jan 01 12:06:50 firefly kernel: W : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 113; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Protected mode not available
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
Jan 01 12:06:50 firefly kernel: I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
Jan 01 12:06:50 firefly kernel: mali ffa30000.gpu: Probed as mali0
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: TX delay(0x1d).
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: RX delay(0x16).
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: clock input from PHY
Jan 01 12:06:50 firefly kernel: rk_gmac-dwmac ff290000.ethernet: init for RGMII
Jan 01 12:06:50 firefly kernel: stmmac - user ID: 0x10, Synopsys ID: 0x35
Jan 01 12:06:50 firefly kernel: Ring mode enabled
Jan 01 12:06:50 firefly kernel: DMA HW capability register supported
Jan 01 12:06:50 firefly kernel: Normal descriptors
Jan 01 12:06:50 firefly kernel: RX Checksum Offload Engine supported (type 2)
Jan 01 12:06:50 firefly kernel: Wake-Up On Lan supported
Jan 01 12:06:50 firefly kernel: Enable RX Mitigation via HW Watchdog Timer
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/ethernet@ff290000[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: devfreq ffa30000.gpu: Couldn’t update frequency transition information.
Jan 01 12:06:50 firefly kernel: mmc2: MAN_BKOPS_EN bit is not set
Jan 01 12:06:50 firefly kernel: mmc_host mmc2: Bus speed (slot 0) = 99000000Hz (slot req 100000000Hz, actual 99000000HZ div = 0)
Jan 01 12:06:50 firefly kernel: mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0f0000.dwmmc: Successfully tuned phase to 171
Jan 01 12:06:50 firefly kernel: mmc2: new HS200 MMC card at address 0001
Jan 01 12:06:50 firefly kernel: mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
Jan 01 12:06:50 firefly kernel: mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
Jan 01 12:06:50 firefly kernel: mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
Jan 01 12:06:50 firefly kernel: mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB
Jan 01 12:06:50 firefly kernel: mmcblk2: p1 p2 p3 p4 p5
Jan 01 12:06:50 firefly kernel: vendor storage:20160801 ret = 0
Jan 01 12:06:50 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 137
Jan 01 12:06:50 firefly kernel: mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
Jan 01 12:06:50 firefly kernel: mmc1: new ultra high speed SDR104 SDIO card at address 0001
Jan 01 12:06:50 firefly kernel: hub 1-1:1.0: USB hub found
Jan 01 12:06:50 firefly kernel: hub 1-1:1.0: 4 ports detected
Jan 01 12:06:50 firefly kernel: libphy: stmmac: probed
Jan 01 12:06:50 firefly kernel: eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
Jan 01 12:06:50 firefly kernel: eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
Jan 01 12:06:50 firefly kernel: input: adc-keys as /devices/platform/adc-keys/input/input1
Jan 01 12:06:50 firefly kernel: rockchip-dmc dmc: Failed to get leakage
Jan 01 12:06:50 firefly kernel: rockchip-dmc dmc: Failed to get pvtm
Jan 01 12:06:50 firefly kernel: rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
Jan 01 12:06:50 firefly kernel: rockchip-dmc dmc: could not find power_model node
Jan 01 12:06:50 firefly kernel: devfreq dmc: Couldn’t update frequency transition information.
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/sound[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/sound[0]’
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ES8323 HiFi ↔ ff890000.i2s mapping ok
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: i2s-hifi ↔ ff890000.i2s mapping ok
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: no sink widget found for MIC1
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC1
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: no sink widget found for MIC2
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC2
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: no source widget found for micbias1
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: Failed to add route micbias1 → direct → Microphone Jack
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: no source widget found for HPOL
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: no source widget found for HPOR
Jan 01 12:06:50 firefly kernel: asoc-simple-card sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
Jan 01 12:06:50 firefly kernel: input: rockchip,firefly-codec Headphone Jack as /devices/platform/sound/sound/card0/input2
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/spdif-sound[0]’
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/spdif-sound[0]’
Jan 01 12:06:50 firefly kernel: asoc-simple-card spdif-sound: dit-hifi ↔ ff8b0000.sound mapping ok
Jan 01 12:06:50 firefly kernel: =======================================================
Jan 01 12:06:50 firefly kernel: ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
Jan 01 12:06:50 firefly kernel: dhd_module_init: in Dongle Host Driver, version 1.579.77.41.9 (r)
Jan 01 12:06:50 firefly kernel: ======== dhd_wlan_init_plat_data ========
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
Jan 01 12:06:50 firefly kernel: dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
Jan 01 12:06:50 firefly kernel: dhd_wlan_init_gpio: oob_irq=234, oob_irq_flags=0x414
Jan 01 12:06:50 firefly kernel: dhd_wifi_platform_load: Enter
Jan 01 12:06:50 firefly kernel: Power-up adapter ‘DHD generic adapter’
Jan 01 12:06:50 firefly kernel: wifi_platform_set_power = 1
Jan 01 12:06:50 firefly kernel: ======== PULL WL_REG_ON(-1) HIGH! ========
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: rockchip_wifi_power: 1
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wifi turn on power. -1
Jan 01 12:06:50 firefly kernel: Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
Jan 01 12:06:50 firefly kernel: RTW: module init start
Jan 01 12:06:50 firefly kernel: RTW: rtl8188eu v5.2.2.3_24783.20171030
Jan 01 12:06:50 firefly kernel: usbcore: registered new interface driver rtl8188eu
Jan 01 12:06:50 firefly kernel: RTW: module init ret=0
Jan 01 12:06:50 firefly kernel: of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/gpio-keys/button@0[0]’ - status (0)
Jan 01 12:06:50 firefly kernel: gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
Jan 01 12:06:50 firefly kernel: input: gpio-keys as /devices/platform/gpio-keys/input/input3
Jan 01 12:06:50 firefly kernel: rtc-hym8563 0-0051: setting system clock to 2017-01-01 12:06:49 UTC (1483272409)
Jan 01 12:06:50 firefly kernel: vcc_sd: disabling
Jan 01 12:06:50 firefly kernel: I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘18:26:37’, on ‘Dec 24 2019’.
Jan 01 12:06:50 firefly kernel: Mali: Mali device driver loaded
Jan 01 12:06:50 firefly kernel: ALSA device list:
Jan 01 12:06:50 firefly kernel: #0: rockchip,firefly-codec
Jan 01 12:06:50 firefly kernel: #1: ROCKCHIP,SPDIF
Jan 01 12:06:50 firefly kernel: EXT4-fs (mmcblk2p5): recovery complete
Jan 01 12:06:50 firefly kernel: EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Opts: (null)
Jan 01 12:06:50 firefly kernel: VFS: Mounted root (ext4 filesystem) on device 179:5.
Jan 01 12:06:50 firefly kernel: devtmpfs: mounted
Jan 01 12:06:50 firefly kernel: Freeing unused kernel memory: 1024K
Jan 01 12:06:50 firefly kernel: wifi_platform_bus_enumerate device present 1
Jan 01 12:06:50 firefly kernel: ======== Card detection to detect SDIO card! ========
Jan 01 12:06:50 firefly kernel: mmc1:mmc host rescan start!
Jan 01 12:06:50 firefly kernel: random: systemd: uninitialized urandom read (16 bytes read, 57 bits of entropy available)
Jan 01 12:06:50 firefly kernel: bcmsdh_register: register client driver
Jan 01 12:06:50 firefly kernel: bcmsdh_sdmmc_probe: Enter num=1
Jan 01 12:06:50 firefly kernel: bcmsdh_sdmmc_probe: Enter num=2
Jan 01 12:06:50 firefly kernel: bus num (host idx)=1, slot num (rca)=1
Jan 01 12:06:50 firefly kernel: found adapter info ‘DHD generic adapter’
Jan 01 12:06:50 firefly kernel: sdioh_attach: set sd_f2_blocksize 256
Jan 01 12:06:50 firefly kernel: sdioh_attach: sd clock rate = 0
Jan 01 12:06:50 firefly kernel: dhdsdio_probe : no mutex held. set lock
Jan 01 12:06:50 firefly kernel: F1 signature read @0x18000000=0x15264345
Jan 01 12:06:50 firefly kernel: F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
Jan 01 12:06:50 firefly kernel: DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
Jan 01 12:06:50 firefly kernel: dhd_conf_set_chiprev: chip=0x4345, chiprev=6
Jan 01 12:06:50 firefly kernel: CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
Jan 01 12:06:50 firefly kernel: CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
Jan 01 12:06:50 firefly kernel: wl_escan_attach: Enter
Jan 01 12:06:50 firefly kernel: wl_escan_init: Enter
Jan 01 12:06:50 firefly kernel: wl_create_event_handler(): thread:wl_escan_handler:83 started
Jan 01 12:06:50 firefly kernel: tsk Enter, tsk = 0xeda10170
Jan 01 12:06:50 firefly kernel: dhd_init_logstrs_array: Failed to open the file /installmedia/logstrs.bin
Jan 01 12:06:50 firefly kernel: dhd_attach(): thread:dhd_watchdog_thread:84 started
Jan 01 12:06:50 firefly kernel: dhd_attach(): thread:dhd_dpc:85 started
Jan 01 12:06:50 firefly kernel: dhd_attach(): thread:dhd_rxf:86 started
Jan 01 12:06:50 firefly kernel: dhd_deferred_work_init: work queue initialized
Jan 01 12:06:50 firefly kernel: dhd_bus_set_default_min_res_mask: Unhandled chip id
Jan 01 12:06:50 firefly kernel: sdioh_cis_read: func_cis_ptr[0]=0x10ac
Jan 01 12:06:50 firefly kernel: Dongle Host Driver, version 1.579.77.41.9 (r)
Jan 01 12:06:50 firefly kernel: wl_ext_iapsta_attach_netdev: bssidx=0
Jan 01 12:06:50 firefly kernel: Register interface [wlan0] MAC: cc:4b:73:76:fc:a2
Jan 01 12:06:50 firefly kernel: dhd_wl_ioctl: returning as busstate=0
Jan 01 12:06:50 firefly kernel: dhd_dbg_detach_pkt_monitor, 2204
Jan 01 12:06:50 firefly kernel: dhd_bus_devreset: == Power OFF ==
Jan 01 12:06:50 firefly kernel: bcmsdh_oob_intr_unregister: Enter
Jan 01 12:06:50 firefly kernel: bcmsdh_oob_intr_unregister: irq is not registered
Jan 01 12:06:50 firefly kernel: dhd_txglom_enable: enable 0
Jan 01 12:06:50 firefly kernel: dhd_conf_set_txglom_params: txglom_mode=copy
Jan 01 12:06:50 firefly kernel: dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
Jan 01 12:06:50 firefly kernel: dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
Jan 01 12:06:50 firefly kernel: dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
Jan 01 12:06:50 firefly kernel: dhd_bus_devreset: WLAN OFF DONE
Jan 01 12:06:50 firefly kernel: wifi_platform_set_power = 0
Jan 01 12:06:50 firefly kernel: ======== PULL WL_REG_ON(-1) LOW! ========
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: rockchip_wifi_power: 0
Jan 01 12:06:50 firefly kernel: [WLAN_RFKILL]: wifi shut off power.
Jan 01 12:06:50 firefly kernel: dhdsdio_probe : the lock is released.
Jan 01 12:06:50 firefly kernel: dhd_module_init: Exit err=0
Jan 01 12:06:50 firefly systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
Jan 01 12:06:50 firefly systemd[1]: Detected architecture arm.
Jan 01 12:06:50 firefly systemd[1]: Set hostname to .
Jan 01 12:06:50 firefly kernel: random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
Jan 01 12:06:50 firefly kernel: random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
Jan 01 12:06:50 firefly kernel: random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
Jan 01 12:06:50 firefly kernel: random: systemd-cryptse: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
Jan 01 12:06:50 firefly kernel: random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
Jan 01 12:06:50 firefly kernel: random: systemd: uninitialized urandom read (16 bytes read, 78 bits of entropy available)
Jan 01 12:06:50 firefly kernel: random: systemd: uninitialized urandom read (16 bytes read, 79 bits of entropy available)
Jan 01 12:06:50 firefly systemd[1]: Configuration file /lib/systemd/system/qcl-proxy.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Jan 01 12:06:50 firefly systemd[1]: Reached target Swap.
Jan 01 12:06:50 firefly systemd[1]: Reached target User and Group Name Lookups.
Jan 01 12:06:50 firefly systemd[1]: Listening on Journal Socket (/dev/log).
Jan 01 12:06:50 firefly systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jan 01 12:06:50 firefly systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Jan 01 12:06:50 firefly systemd[1]: Reached target Encrypted Volumes.
Jan 01 12:06:50 firefly systemd[1]: Listening on udev Control Socket.
Jan 01 12:06:50 firefly systemd[1]: Listening on Syslog Socket.
Jan 01 12:06:50 firefly systemd[1]: Created slice System Slice.
Jan 01 12:06:50 firefly systemd[1]: Created slice system-serial\x2dgetty.slice.
Jan 01 12:06:50 firefly systemd[1]: Created slice User and Session Slice.
Jan 01 12:06:50 firefly systemd[1]: Reached target Remote File Systems (Pre).
Jan 01 12:06:50 firefly systemd[1]: Reached target Remote File Systems.
Jan 01 12:06:50 firefly systemd[1]: Reached target Slices.
Jan 01 12:06:50 firefly systemd[1]: Listening on udev Kernel Socket.
Jan 01 12:06:50 firefly systemd[1]: Listening on Journal Socket.
Jan 01 12:06:50 firefly systemd[1]: Starting Load Kernel Modules…
Jan 01 12:06:50 firefly systemd[1]: Starting Journal Service…
Jan 01 12:06:50 firefly systemd[1]: Started Braille Device Support.
Jan 01 12:06:50 firefly systemd[1]: Starting Set console keymap…
Jan 01 12:06:50 firefly systemd[1]: Mounting Debug File System…
Jan 01 12:06:50 firefly systemd[1]: Starting Create Static Device Nodes in /dev…
Jan 01 12:06:50 firefly systemd[1]: Starting Remount Root and Kernel File Systems…
Jan 01 12:06:50 firefly systemd[1]: Mounted Debug File System.
Jan 01 12:06:50 firefly systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Jan 01 12:06:50 firefly systemd[1]: Failed to start Load Kernel Modules.
Jan 01 12:06:50 firefly systemd[1]: systemd-modules-load.service: Unit entered failed state.
Jan 01 12:06:50 firefly systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
Jan 01 12:06:50 firefly systemd[1]: Started Set console keymap.
Jan 01 12:06:50 firefly systemd[1]: Started Create Static Device Nodes in /dev.
Jan 01 12:06:50 firefly systemd[1]: Started Remount Root and Kernel File Systems.
Jan 01 12:06:50 firefly systemd[1]: Started Journal Service.
Jan 01 12:06:51 firefly kernel: random: nonblocking pool is initialized
Jan 01 12:06:51 firefly kernel: rk_gmac-dwmac ff290000.ethernet: rk_get_eth_addr: mac address: ce:d6:24:68:3b:6b
Jan 01 12:06:51 firefly kernel: eth0: device MAC address ce:d6:24:68:3b:6b
Jan 01 12:06:51 firefly kernel: [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin output high!
Jan 01 12:06:51 firefly kernel: [BT_RFKILL]: ENABLE UART_RTS
Jan 14 08:09:20 firefly kernel: [BT_RFKILL]: DISABLE UART_RTS
Jan 14 08:09:20 firefly kernel: [BT_RFKILL]: bt turn on power
Jan 14 08:09:20 firefly kernel: cfg80211: World regulatory domain updated:
Jan 14 08:09:20 firefly kernel: cfg80211: DFS Master region: unset
Jan 14 08:09:20 firefly kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jan 14 08:09:20 firefly kernel: cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Jan 14 08:09:20 firefly kernel: cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Jan 14 08:09:20 firefly kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Jan 14 08:09:20 firefly kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Jan 14 08:09:20 firefly kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Jan 14 08:09:20 firefly kernel: cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Jan 14 08:09:20 firefly kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Jan 14 08:09:20 firefly kernel: cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Jan 14 08:09:21 firefly kernel: IPVS: Creating netns size=1104 id=1
Jan 14 08:09:21 firefly kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 14 08:09:21 firefly kernel: dhd_open: Enter ee1fe800
Jan 14 08:09:21 firefly kernel: dhd_open : no mutex held. set lock
Jan 14 08:09:21 firefly kernel: dhd_init_logstrs_array: Failed to open the file /installmedia/logstrs.bin
Jan 14 08:09:21 firefly kernel: wl_ext_iapsta_attach_netdev: bssidx=0
Jan 14 08:09:21 firefly kernel: wl_android_wifi_on in 1
Jan 14 08:09:21 firefly kernel: wl_android_wifi_on in 2: g_wifi_on=0
Jan 14 08:09:21 firefly kernel: wifi_platform_set_power = 1
Jan 14 08:09:21 firefly kernel: ======== PULL WL_REG_ON(-1) HIGH! ========
Jan 14 08:09:21 firefly kernel: [WLAN_RFKILL]: rockchip_wifi_power: 1
Jan 14 08:09:21 firefly kernel: [WLAN_RFKILL]: wifi turn on power. -1
Jan 14 08:09:21 firefly kernel: sdio_reset_comm():
Jan 14 08:09:21 firefly kernel: mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Jan 14 08:09:21 firefly kernel: mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
Jan 14 08:09:21 firefly kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Jan 14 08:09:21 firefly kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jan 14 08:09:21 firefly kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Jan 14 08:09:21 firefly kernel: mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
Jan 14 08:09:22 firefly kernel: mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
Jan 14 08:09:22 firefly kernel: dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 137
Jan 14 08:09:22 firefly kernel: sdioh_start: set sd_f2_blocksize 256
dhd_bus_devreset: == WLAN ON ==
Jan 14 08:09:22 firefly kernel: F1 signature read @0x18000000=0x15264345
Jan 14 08:09:22 firefly kernel: F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
Jan 14 08:09:22 firefly kernel: DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
Jan 14 08:09:22 firefly kernel: dhd_bus_set_default_min_res_mask: Unhandled chip id
Jan 14 08:09:22 firefly kernel: dhd_os_open_image: /system/etc/firmware/config.txt (204 bytes) open success
Jan 14 08:09:22 firefly kernel: dhd_conf_read_others: ccode = ALL
Jan 14 08:09:22 firefly kernel: dhd_conf_read_others: regrev = 0
Jan 14 08:09:22 firefly kernel: dhd_conf_read_sdio_params: dhd_doflow = 1
Jan 14 08:09:22 firefly kernel: dhd_conf_read_others: srl = 15
Jan 14 08:09:22 firefly kernel: dhd_conf_read_others: lrl = 15
Jan 14 08:09:22 firefly kernel: Final fw_path=/system/etc/firmware/fw_bcm43455c0_ag.bin
Jan 14 08:09:22 firefly kernel: Final nv_path=/system/etc/firmware/nvram_ap6255.txt
Jan 14 08:09:22 firefly kernel: Final clm_path=/system/etc/firmware/clm.blob
Jan 14 08:09:22 firefly kernel: Final conf_path=/system/etc/firmware/config.txt
Jan 14 08:09:22 firefly kernel: dhd_os_open_image: /system/etc/firmware/fw_bcm43455c0_ag.bin (483181 bytes) open success
Jan 14 08:09:22 firefly kernel: dhd_os_open_image: /system/etc/firmware/nvram_ap6255.txt (1644 bytes) open success
Jan 14 08:09:22 firefly kernel: NVRAM version: AP6255_NVRAM_V1.0_29052015
Jan 14 08:09:22 firefly kernel: dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
Jan 14 08:09:22 firefly kernel: dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
Jan 14 08:09:22 firefly kernel: bcmsdh_oob_intr_register: HW_OOB irq=234 flags=0x4
Jan 14 08:09:22 firefly kernel: dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn’t exist
Jan 14 08:09:22 firefly kernel: dhd_get_memdump_info: MEMDUMP ENABLED = 2
Jan 14 08:09:22 firefly kernel: Disable tdls_auto_op failed. -1
Jan 14 08:09:22 firefly kernel: dhd_preinit_ioctls: Set tcpack_sup_mode 0
Jan 14 08:09:22 firefly kernel: dhd_tcpack_suppress_set 362: already set to 0
Jan 14 08:09:22 firefly kernel: dhd_apply_default_clm: Ignore clm file /system/etc/firmware/clm.blob
Jan 14 08:09:22 firefly kernel: Firmware up: op_mode=0x0005, MAC=cc:4b:73:76:fc:a2
Jan 14 08:09:22 firefly kernel: dhd_preinit_ioctls Set scancache failed -23
Jan 14 08:09:22 firefly kernel: Driver: 1.579.77.41.9 (r)
Firmware: wl0: Aug 25 2015 18:58:57 version 7.45.69 (r581703) FWID 01-24037f6e
CLM: 7.14.8
Jan 14 08:09:22 firefly kernel: dhd_txglom_enable: enable 1
Jan 14 08:09:22 firefly kernel: dhd_conf_set_txglom_params: txglom_mode=copy
Jan 14 08:09:22 firefly kernel: dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=0
Jan 14 08:09:22 firefly kernel: dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
Jan 14 08:09:22 firefly kernel: dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
Jan 14 08:09:22 firefly kernel: dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
Jan 14 08:09:22 firefly kernel: dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
Jan 14 08:09:22 firefly kernel: CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
Jan 14 08:09:22 firefly kernel: rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
Jan 14 08:09:22 firefly kernel: dhd_rtt_init : FTM is not supported
Jan 14 08:09:22 firefly kernel: dhd_preinit_ioctls: SensorHub diabled 0
Jan 14 08:09:22 firefly kernel: dhd_preinit_ioctls failed to set ShubHub disable
Jan 14 08:09:22 firefly kernel: dhd_ndo_get_version: failed, retcode = -23
Jan 14 08:09:22 firefly kernel: dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
Jan 14 08:09:22 firefly kernel: failed to get wnm_bsstrans_resp
Jan 14 08:09:22 firefly kernel: failed to set WNM capabilities
Jan 14 08:09:22 firefly kernel: dhd_conf_set_country: set country ALL, revision 0
Jan 14 08:09:22 firefly kernel: CONFIG-ERROR) dhd_conf_set_bufiovar: country setting failed -2
Jan 14 08:09:22 firefly kernel: Country code: US (US/0)
Jan 14 08:09:22 firefly kernel: wl_android_wifi_on: Success
Jan 14 08:09:22 firefly kernel: CFG80211-ERROR) __wl_update_wiphybands : error reading txbf_bfe_cap (-23)
Jan 14 08:09:22 firefly kernel: CFG80211-ERROR) __wl_update_wiphybands : error reading txbf_bfr_cap (-23)
Jan 14 08:09:22 firefly kernel: dhd_open : the lock is released.
Jan 14 08:09:22 firefly kernel: dhd_open: Exit ret=0
Jan 14 08:09:22 firefly kernel: P2P interface registered
Jan 14 08:09:22 firefly kernel: wl_cfgp2p_add_p2p_disc_if: wdev: ecf28000, wdev->net: (null)
Jan 14 08:09:22 firefly kernel: [35B blob data]
Jan 14 08:09:22 firefly kernel: P2P interface started
Jan 14 08:09:24 firefly kernel: tty_port_close_start: tty->count = 1 port count = 2.
Jan 14 08:09:24 firefly kernel: [BT_RFKILL]: bt shut off power
Jan 14 08:09:24 firefly kernel: [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin output high!
Jan 14 08:09:24 firefly kernel: [BT_RFKILL]: ENABLE UART_RTS
Jan 14 08:09:24 firefly kernel: [BT_RFKILL]: DISABLE UART_RTS
Jan 14 08:09:24 firefly kernel: [BT_RFKILL]: bt turn on power
Jan 14 08:09:25 firefly kernel: ttyS0 - failed to request DMA, use interrupt mode
Jan 14 08:09:27 firefly kernel: IPVS: Creating netns size=1104 id=2
Jan 14 08:09:30 firefly kernel: Connecting with 78:11:dc:35:fb:55 ssid “LOVE-MI”, len (7) channel=4
Jan 14 08:09:30 firefly kernel: dhd_dbg_start_pkt_monitor, 1724
Jan 14 08:09:30 firefly kernel: wl_iw_event: Link UP with 78:11:00:00:fb:55
Jan 14 08:09:30 firefly kernel: wl_bss_connect_done succeeded with 78:11:dc:35:fb:55
Jan 14 08:09:30 firefly kernel: cfg80211: Regulatory domain changed to country: CN
Jan 14 08:09:30 firefly kernel: cfg80211: DFS Master region: FCC
Jan 14 08:09:30 firefly kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jan 14 08:09:30 firefly kernel: cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Jan 14 08:09:30 firefly kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
Jan 14 08:09:30 firefly kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
Jan 14 08:09:30 firefly kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
Jan 14 08:09:30 firefly kernel: cfg80211: (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
Jan 14 08:09:30 firefly kernel: cfg80211: (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
Jan 14 08:09:30 firefly kernel: cfg80211: (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
Jan 14 08:09:30 firefly kernel: wl_bss_connect_done succeeded with 78:11:dc:35:fb:55 vndr_oui: 00-90-4C 00-0C-43 8C-BE-BE
Jan 14 08:09:33 firefly kernel: [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin output high!
Jan 14 08:09:33 firefly kernel: [BT_RFKILL]: ENABLE UART_RTS
Jan 14 08:09:33 firefly kernel: [BT_RFKILL]: DISABLE UART_RTS
Jan 14 08:09:33 firefly kernel: [BT_RFKILL]: bt turn on power
dts.zip (19.9 KB)
