烧写的韦东山老师sdcard.img无法开机
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36
ChipType = 0x8, 228
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14928MB
FwPartOffset=2000 , 0
StorageInit ok = 36528
LOADER Check OK! 0x0, 94959
TOS    Check OK! 0x8400000, 170717
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-316-g7b4ec90 #59 Wed May 30 08:26:33 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x0
U-Boot 2017.09-gd80ac02 (Feb 25 2019 - 16:26:01 +0800)
Model: Firefly-RK3288
DRAM:  2 GiB
Relocation Offset is: 7de63000
MMC:   dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Boot from SDcard
get part misc fail -1
Net:
Warning: ethernet@ff290000 (eth0) using random MAC address - 2a:2f:53:51:f1:4e
eth0: ethernet@ff290000
Unknown command 'usb' - try 'help'
Hit any key to stop autoboot:  0
android_bootloader_boot_flow Could not find misc partition
ANDROID: reboot reason: "(none)"
android_bootloader_boot_flow Could not found bootable partition boot
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:1...
 ** fs_devread read error **
 ** fs_devread read error - block
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
** Can't read partition table on 1:0 **
** Invalid partition 1 **
ethernet@ff290000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@ff290000
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
ethernet@ff290000 Waiting for PHY auto negotiation to completeuser interrupt!
ethernet@ff290000 Waiting for PHY auto negotiation to complete....user interrupt!
ethernet@ff290000 Waiting for PHY auto negotiation to complete...user interrupt!
Retrieving file: pxelinux.cfg/default-arm-rockchip
ethernet@ff290000 Waiting for PHY auto negotiation to complete..user interrupt!
Config file not found
刚开始学,打击有点大,求教{:5_254:}
自己傻了,是无法连接网络,但是内核已经启动了
请问您解决这个问题了吗,是怎么解决的
