firefly-RK3399 typec-dp显示没有反应
我用firefly-rk3399开发板,烧录的固件是Firefly-RK3399_Industry7.1.2_HDMI_191218.img,下面是log,显示器的规格参数和log如下
请大神帮忙看看
[ 33.422325] fusb302 4-0022: CC connected in CC2 as DFP
[ 33.439723] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 33.451840] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 33.453248] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 33.457457] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 33.457609] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe800000
[ 33.457962] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 33.457994] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 33.458083] usb usb4: Product: xHCI Host Controller
[ 33.458108] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 33.458132] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 33.464780] hub 4-0:1.0: USB hub found
[ 33.466390] hub 4-0:1.0: 1 port detected
[ 33.467347] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 33.470206] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8
[ 33.470516] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 33.470840] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 33.470901] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 33.470927] usb usb8: Product: xHCI Host Controller
[ 33.471004] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[ 33.471028] usb usb8: SerialNumber: xhci-hcd.11.auto
[ 33.475130] hub 8-0:1.0: USB hub found
[ 33.475295] hub 8-0:1.0: 1 port detected
[ 33.481962] rockchip-dwc3 usb@fe800000: USB HOST connected
[ 33.772571] usb 4-1: new high-speed USB device number 2 using xhci-hcd
[ 33.894654] usb 4-1: New USB device found, idVendor=0424, idProduct=2514
[ 33.894754] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 33.921275] hub 4-1:1.0: USB hub found
[ 33.921489] hub 4-1:1.0: 2 ports detected
[ 34.091234] fusb302 4-0022: PD connected as DFP, supporting 5V
[ 34.206626] fusb302 4-0022: DP config successful, pin_assignment 0x4
[ 34.216540] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 34.232555] usb 4-1.1: new full-speed USB device number 3 using xhci-hcd
[ 34.331292] usb 4-1.1: New USB device found, idVendor=0483, idProduct=5740
[ 34.331410] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 34.331438] usb 4-1.1: Product: STM32 Virtual ComPort
[ 34.331462] usb 4-1.1: Manufacturer: STMicroelectronics
[ 34.331485] usb 4-1.1: SerialNumber: 00000000001A
[ 34.382678] cdc_acm 4-1.1:1.0: ttyACM0: USB ACM device
[ 34.796804] fusb302 4-0022: attention, dp_status 82
[ 34.798851] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn
[ 35.021343] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p60, type: 10
[ 35.221154] cdn-dp fec00000.dp: [drm:cdn_dp_config_video] ERROR tu error, clk:54000, lanes:1, rate:162
[ 35.221245] cdn-dp fec00000.dp: [drm:cdn_dp_config_video] ERROR config video failed: -22
[ 35.221276] cdn-dp fec00000.dp: [drm:cdn_dp_encoder_enable] ERROR Failed to config video -22
[ 35.460610] [drm:vop_afbdc_atomic_check] ERROR not support afbdc
[ 45.473284] usb 4-1: USB disconnect, device number 2
[ 45.473397] usb 4-1.1: USB disconnect, device number 3
[ 45.486548] fusb302 4-0022: connection has disconnected
[ 45.501285] xhci-hcd xhci-hcd.11.auto: remove, state 4
[ 45.501427] usb usb8: USB disconnect, device number 1
[ 45.502138] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 45.512669] xhci-hcd xhci-hcd.11.auto: USB bus 8 deregistered
[ 45.516479] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 45.516550] usb usb4: USB disconnect, device number 1
[ 45.547352] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 45.549282] dwc3 fe800000.dwc3: dwc3 gadget stop timeout
[ 45.549478] rockchip-dwc3 usb@fe800000: USB unconnected
[ 45.549515] android_work: did not send uevent (0 0 (null))
[ 49.231958] fusb302 4-0022: CC connected in CC2 as DFP
[ 49.246092] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 49.257718] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 49.259876] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 49.264435] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 49.264588] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe800000
[ 49.264960] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 49.265051] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 49.265077] usb usb4: Product: xHCI Host Controller
[ 49.265101] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 49.265125] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 49.271606] hub 4-0:1.0: USB hub found
[ 49.273080] hub 4-0:1.0: 1 port detected
[ 49.273981] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 49.275817] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8
[ 49.276043] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 49.276346] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 49.276416] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 49.276442] usb usb8: Product: xHCI Host Controller
[ 49.276467] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[ 49.276530] usb usb8: SerialNumber: xhci-hcd.11.auto
[ 49.282393] hub 8-0:1.0: USB hub found
[ 49.282542] hub 8-0:1.0: 1 port detected
[ 49.284035] rockchip-dwc3 usb@fe800000: USB HOST connected
[ 49.582613] usb 4-1: new high-speed USB device number 2 using xhci-hcd
[ 49.704650] usb 4-1: New USB device found, idVendor=0424, idProduct=2514
[ 49.704713] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 49.726781] hub 4-1:1.0: USB hub found
[ 49.726980] hub 4-1:1.0: 2 ports detected
[ 49.886280] fusb302 4-0022: PD connected as DFP, supporting 5V
[ 50.001823] fusb302 4-0022: DP config successful, pin_assignment 0x4
[ 50.012391] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 50.039304] usb 4-1.1: new full-speed USB device number 3 using xhci-hcd
[ 50.140167] usb 4-1.1: New USB device found, idVendor=0483, idProduct=5740
[ 50.140308] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 50.140525] usb 4-1.1: Product: STM32 Virtual ComPort
[ 50.140746] usb 4-1.1: Manufacturer: STMicroelectronics
[ 50.140972] usb 4-1.1: SerialNumber: 00000000001A
[ 50.190195] cdc_acm 4-1.1:1.0: ttyACM0: USB ACM device
[ 50.596728] fusb302 4-0022: attention, dp_status 82
[ 50.598757] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn
[ 50.821832] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p60, type: 10
[ 51.021115] cdn-dp fec00000.dp: [drm:cdn_dp_config_video] ERROR tu error, clk:54000, lanes:1, rate:162
[ 51.021206] cdn-dp fec00000.dp: [drm:cdn_dp_config_video] ERROR config video failed: -22
[ 51.021236] cdn-dp fec00000.dp: [drm:cdn_dp_encoder_enable] ERROR Failed to config video -22
[ 51.034866] [drm:vop_afbdc_atomic_check] ERROR not support afbdc
1.我显示器的连接线,插入开发板的一端(公头)连的是b11,b10,a11,a10引脚,怀疑是和开发板的送出端(母头)没有对应上,我想确认把开发板送出端(母头)的A10,A11,B10,B11配置成信号的输出端口不知道怎么弄;
2..我的显示设备插手机正反插都是没有问题的,但是插我们的开发板却没有办法点亮,想请教软件如何自动适配
3.我通过添加打印发现设备插入时,调用到了drivers/gpu/drm/rockchip/cdn-dp-core.c 中的cdn_dp_get_port_lanes()函数,而里面读取到的lane=4,这是否说明开发板没有配置成2lane输出,如果是的,我应该如何配置?我有尝试直接在这个函数里修改成2lane,没有作用。
