-MMD -MP -MF ./.deps/bt-load.TPo ../../gcc/bt-load.c
Killed
Makefile:3049: recipe for target ‘doc/gccint.info’ failed
make[3]: *** [doc/gccint.info] Error 137
make[3]: *** Waiting for unfinished jobs…
/bin/bash ../../gcc/../move-if-change tmp-attrtab.c insn-attrtab.c
/bin/bash ../../gcc/../move-if-change tmp-dfatab.c insn-dfatab.c
/bin/bash ../../gcc/../move-if-change tmp-latencytab.c insn-latencytab.c
echo timestamp > s-attrtab
rm gcc.pod
Makefile:4113: recipe for target ‘all-gcc’ failed
make[2]: *** [all-gcc] Error 2
package/pkg-generic.mk:247: recipe for target ‘/home/book/work/rk3308/firefly/sdk/buildroot/output/firefly_rk3308_release/build/host-gcc-initial-6.4.0/.stamp_built’ failed
make[1]: *** [/home/book/work/rk3308/firefly/sdk/buildroot/output/firefly_rk3308_release/build/host-gcc-initial-6.4.0/.stamp_built] Error 2
/home/book/work/rk3308/firefly/sdk/buildroot/output/firefly_rk3308_release/Makefile:16: recipe for target ‘_all’ failed
make: *** [_all] Error 2
you take 6:48.11 to build builroot
====Build buildroot failed!====
- 编译步骤贴出来
- 编译环境搭建和编译步骤详细见维基教程
- 确保ubuntu编译环境一些软件都有安装
- 如果是虚拟机编译的,是不是分配的内存太小了,可以参考http://dev.t-firefly.com/thread-101545-1-1.html
编译步骤和wiki描述完全一样:
第一步解压并更新Firefly-RK3308_Linux_SDK_git_20190924.7z
第二步:安装环境
第三步:source buildroot/build/envsetup.sh 1
第四步:make
- ubuntu系统是装在虚拟机里还是真机里, 内存分配多少?
- 根据编译的错误信息,可以先从网上找答案或者找论坛相关的帖子
- 其他帖子有解决方案,http://dev.t-firefly.com/forum.php?mod=viewthread&tid=99605&highlight=docker
请问解决了吗?我更新了 common-linux-bundle后,也遇到通用的问题。
