编译Android8.1,tf卡启动失败问题
4.3从gitlab取最新代码编译Android8.1,编译打包。RK固件烧录到eMMC启动正常,串口可以进入shell。
但是打包的SD卡固件“sd_ROC_RK3399_PC_Android8.1.0_DEFAULT_200403.img”烧录(通过Etcher)到tf卡,然后上电,启动中途卡死,串口不再输出,也不响应输入,卡死位置随机!
可以确认sd卡和烧录工具没有问题,因为烧录随盘固件“sd_ROC-RK3399-PC_Android8.1.0_DEFAULT_181016.img”能正常启动。是否gitlab上新代码问题?
附log:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.04.04 00:23:32 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version 1.12 20180518
Channel 0: LPDDR4,50MHz
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
Channel 1: LPDDR4,50MHz
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
change freq to 800MHz 1,0
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
Boot1: 2018-04-08, version: 1.12
CPUId = 0x0
ChipType = 0x10, 220
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60906MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 200060
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa912c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):65aa5ce
NOTICE: BL31: Built : 10:47:37, Jun 19 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Apr 03 2020 - 01:48:41)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Board:Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 0
SDCard Boot.
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 0000-00-00#0.00
empty serial no.
Writing env to storage…
done
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find phy node
failed to find panel driver
no fuel gauge found
rockchip_panel_deinit: failed to find panel deinit funcs
got recovery cmd from misc.
load fdt from resouce.
error init vendor storage.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0127d808)
ramdisk @ 0x04bf0000 (0x00865b40)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 00000000046156f2 … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.126 (user@host069-ubuntu-1804) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Thu Apr 2 15:26:15 UTC 2020
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef1000 s45528 r8192 d32296 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.veritymode=/dev/block/platform/ff0f0000.dwmmc/by-name/metadata androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00020000@0x00030000(recovery),0x00038000@0x00050000(backup),0x00002000@0x00088000(security),0x00100000@0x0008a000(cache),0x00500000@0x0018a000(system),0x00008000@0x0068a000(metadata),0x00100000@0x00692000(vendor),0x00100000@0x00794000(oem),0x00000400@0x00894000(frp),-@0x00894400(userdata) storagemedia=sd uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2020-04-03_01:48:41 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6ea9000-0xf6ee9000] (0MB) mapped at [ffffffc0f6ea9000-ffffffc0f6ee8fff]
[ 0.000000] Memory: 3911388K/4030464K available (11006K kernel code, 1654K rwdata, 5376K rodata, 832K init, 1133K bss, 102692K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009090000 - 0xffffff8009160000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009090000 ( 5440 KB)
[ 0.000000] .data : 0xffffff8009160000 - 0xffffff80092fd808 ( 1655 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.001859] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002825] pid_max: default: 32768 minimum: 301
[ 0.003316] Security Framework initialized
[ 0.003705] SELinux: Initializing.
[ 0.004135] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004764] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006270] Initializing cgroup subsys memory
[ 0.006703] Initializing cgroup subsys freezer
[ 0.008017] sched-energy: Sched-energy-costs installed from DT
[ 0.008567] CPU0: update cpu_capacity 401
[ 0.009018] ASID allocator initialised with 32768 entries
[ 0.025848] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027060] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039257] Detected VIPT I-cache on CPU1
[ 0.039289] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039328] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039371] CPU1: update cpu_capacity 401
[ 0.039375] CPU1: Booted secondary processor [410fd034]
[ 0.049241] Detected VIPT I-cache on CPU2
[ 0.049261] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049293] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049321] CPU2: update cpu_capacity 401
[ 0.049324] CPU2: Booted secondary processor [410fd034]
[ 0.059272] Detected VIPT I-cache on CPU3
[ 0.059291] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059322] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059349] CPU3: update cpu_capacity 401
[ 0.059352] CPU3: Booted secondary processor [410fd034]
[ 0.069319] Detected PIPT I-cache on CPU4
[ 0.069347] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069386] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069426] CPU4: update cpu_capacity 1024
[ 0.069430] CPU4: Booted secondary processor [410fd082]
[ 0.079345] Detected PIPT I-cache on CPU5
[ 0.079363] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079399] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079426] CPU5: update cpu_capacity 1024
[ 0.079429] CPU5: Booted secondary processor [410fd082]
[ 0.079514] Brought up 6 CPUs
[ 0.091619] SMP: Total of 6 processors activated.
[ 0.092061] CPU features: detected feature: GIC system register CPU interface
[ 0.092733] CPU: All CPU(s) started at EL2
[ 0.093157] alternatives: patching kernel code
[ 0.095463] devtmpfs: initialized
[ 0.115103] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116062] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117373] pinctrl core: initialized pinctrl subsystem
[ 0.119319] Failed to find legacy iommu devices
[ 0.120140] NET: Registered protocol family 16
[ 0.120966] schedtune: init normalization constants…
[ 0.121469] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122103] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.122737] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123378] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124012] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124645] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125277] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.125909] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126541] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127180] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.127919] schedtune: verify normalization constants…
[ 0.128435] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.128975] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129515] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130054] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130600] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131140] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131679] schedtune: configured to support 5 boost groups
[ 0.140638] cpuidle: using governor ladder
[ 0.150641] cpuidle: using governor menu
[ 0.151037] Registered FIQ tty driver
[ 0.151746] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009164000)
[ 0.152483] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154505] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.175152] console [pstore-1] enabled
[ 0.175757] pstore: Registered ramoops as persistent store backend
[ 0.176361] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.178899] fiq debugger fiq mode enabled
[ [ 0.179553] console [ttyFIQ0] enabled
[ 0.180244] bootconsole [uart0] disabled
[ 0.180813] Registered fiq debugger ttyFIQ0
[ 0.215179] iommu: Adding device ff650000.vpu_service to group 0
[ 0.215258] iommu: Adding device ff660000.rkvdec to group 1
[ 0.215336] iommu: Adding device ff670000.iep to group 2
[ 0.215423] iommu: Adding device ff8f0000.vop to group 3
[ 0.215491] iommu: Adding device ff900000.vop to group 4
[ 0.215593] iommu: Adding device ff910000.isp to group 5
[ 0.215662] iommu: Adding device ff920000.isp to group 6
[ 0.216357] rk_iommu ff670800.iommu: can’t get aclk
[ 0.216372] rk_iommu ff670800.iommu: can’t get hclk
[ 0.217206] SCSI subsystem initialized
[ 0.217548] usbcore: registered new interface driver usbfs
[ 0.217592] usbcore: registered new interface driver hub
[ 0.217659] usbcore: registered new device driver usb
[ 0.218012] media: Linux media interface: v0.10
[ 0.218045] Linux video capture interface: v2.00
[ 0.218207] pps_core: LinuxPPS API ver. 1 registered
[ 0.218216] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.218237] PTP clock support registered
[ 0.219803] Advanced Linux Sound Architecture Driver Initialized.
[ 0.220272] Bluetooth: Core ver 2.21
[ 0.220304] NET: Registered protocol family 31
[ 0.220312] Bluetooth: HCI device and connection manager initialized
[ 0.220325] Bluetooth: HCI socket layer initialized
[ 0.220337] Bluetooth: L2CAP socket layer initialized
[ 0.220367] Bluetooth: SCO socket layer initialized
[ 0.221049] rockchip-cpuinfo cpuinfo: Serial: 8aea507cca581cba
[ 0.221528] clocksource: Switched to clocksource arch_sys_counter
[ 0.263477] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.263709] NET: Registered protocol family 2
[ 0.264130] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.264357] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.264619] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.264697] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.264743] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.264965] NET: Registered protocol family 1
[ 0.265797] Trying to unpack rootfs image as initramfs…
[ 0.640452] Freeing initrd memory: 8596K
[ 0.641010] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.641096] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.643900] audit: initializing netlink subsys (disabled)
[ 0.643964] audit: type=2000 audit(0.640:1): initialized
[ 0.649060] VFS: Disk quotas dquot_6.6.0
[ 0.649183] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.650188] Registering sdcardfs 0.1
[ 0.650759] fuse init (API version 7.23)
[ 0.651850]
[ 0.651850] TEE Core Framework initialization (ver 1:0.1)
[ 0.651877] TEE armv7 Driver initialization
[ 0.652220] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.652236] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.652414] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.656286] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.656308] io scheduler noop registered
[ 0.656469] io scheduler cfq registered (default)
[ 0.661347] iep: failed to find iep power down clock source.
[ 0.661715] IEP Power ON
[ 0.661881] IEP Power OFF
[ 0.661913] IEP Driver loaded succesfully
[ 0.662006] Module initialized.
[ 0.662260] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.662489] rk-vcodec ff650000.vpu_service: probe device
[ 0.662529] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1eda010
[ 0.662661] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.662713] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.663167] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.663182] rk-vcodec ff650000.vpu_service: init success
[ 0.663365] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.663742] rk-vcodec ff660000.rkvdec: probe device
[ 0.663789] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1eda810
[ 0.663922] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.663974] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.664300] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.664314] rk-vcodec ff660000.rkvdec: init success
[ 0.666009] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.666031] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chansk+Kk&k++sk&
[ 0.667382] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.667401] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.669158] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.670910] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.671216] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.671233] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.671244] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.671254] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.671631] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.672081] [drm] Initialized drm 1.1.0 20060810
[ 0.675528] [drm] Rockchip DRM driver version: v1.0.1
[ 0.677593] Unable to detect cache hierarchy for CPU 0
[ 0.685627] brd: module loaded
[ 0.690502] loop: module loaded
[ 0.691042] zram: Added device: zram0
[ 0.691895] SCSI Media Changer driver v0.25
[ 0.693151] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.693170] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.693692] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.694621] register spi return v = :0
[ 0.694660] register firefly_spi_init spi return v = :0
[ 0.694716] tun: Universal TUN/TAP device driver, 1.6
[ 0.694724] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.695721] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.695743] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.695754] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.695776] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.695932] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.695944] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.700959] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.701075] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.701085] Ring mode enabled
[ 0.701093] DMA HW capability register supported
[ 0.701100] Normal descriptors
[ 0.701109] RX Checksum Offload Engine supported (type 2)
[ 0.701116] TX Checksum insertion supported
[ 0.701122] Wake-Up On Lan supported
[ 0.701163] Enable RX Mitigation via HW Watchdog Timer
[ 0.767559] libphy: stmmac: probed
[ 0.767593] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.767603] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.768474] PPP generic driver version 2.4.2
[ 0.768671] PPP BSD Compression module registered
[ 0.768705] PPP Deflate Compression module registered
[ 0.768735] PPP MPPE Compression module registered
[ 0.768754] NET: Registered protocol family 24
[ 0.768815] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.768823] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.768840] Rockchip WiFi SYS interface (V1.00) …
[ 0.768920] usbcore: registered new interface driver catc
[ 0.768959] usbcore: registered new interface driver kaweth
[ 0.768974] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.769032] usbcore: registered new interface driver pegasus
[ 0.769072] usbcore: registered new interface driver rtl8150
[ 0.769114] usbcore: registered new interface driver r8152
[ 0.769127] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.769182] usbcore: registered new interface driver hso
[ 0.769228] usbcore: registered new interface driver asix
[ 0.769287] usbcore: registered new interface driver ax88179_178a
[ 0.769326] usbcore: registered new interface driver cdc_ether
[ 0.769369] usbcore: registered new interface driver cdc_eem
[ 0.769408] usbcore: registered new interface driver dm9601
[ 0.769458] usbcore: registered new interface driver smsc75xx
[ 0.769524] usbcore: registered new interface driver smsc95xx
[ 0.769567] usbcore: registered new interface driver gl620a
[ 0.769607] usbcore: registered new interface driver net1080
[ 0.769646] usbcore: registered new interface driver plusb
[ 0.769708] usbcore: registered new interface driver rndis_host
[ 0.769749] usbcore: registered new interface driver cdc_subset
[ 0.769788] usbcore: registered new interface driver zaurus
[ 0.769836] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.769892] usbcore: registered new interface driver int51x1
[ 0.769950] usbcore: registered new interface driver kalmia
[ 0.769990] usbcore: registered new interface driver ipheth
[ 0.770032] usbcore: registered new interface driver sierra_net
[ 0.770071] usbcore: registered new interface driver cx82310_eth
[ 0.770122] usbcore: registered new interface driver cdc_ncm
[ 0.770180] usbcore: registered new interface driver qmi_wwan
[ 0.770221] usbcore: registered new interface driver cdc_mbim
[ 0.771379] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 0.772232] rockchip-dwc3 usb@fe900000: failed to get drvdata dwc3
[ 0.773148] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.773189] ehci-pci: EHCI PCI platform driver
[ 0.773245] ehci-platform: EHCI generic platform driver
[ 0.773817] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.773862] ohci-platform: OHCI generic platform driver
[ 0.774666] usbcore: registered new interface driver cdc_acm
[ 0.774697] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.774749] usbcore: registered new interface driver usblp
[ 0.774818] usbcore: registered new interface driver cdc_wdm
[ 0.774884] usbcore: registered new interface driver uas
[ 0.774937] usbcore: registered new interface driver usb-storage
[ 0.774975] usbcore: registered new interface driver ums-alauda
[ 0.775034] usbcore: registered new interface driver ums-cypress
[ 0.775071] usbcore: registered new interface driver ums-datafab
[ 0.775108] usbcore: registered new interface driver ums_eneub6250
[ 0.775149] usbcore: registered new interface driver ums-freecom
[ 0.775187] usbcore: registered new interface driver ums-isd200
[ 0.775250] usbcore: registered new interface driver ums-jumpshot
[ 0.775287] usbcore: registered new interface driver ums-karma
[ 0.775325] usbcore: registered new interface driver ums-onetouch
[ 0.775362] usbcore: registered new interface driver ums-sddr09
[ 0.775399] usbcore: registered new interface driver ums-sddr55
[ 0.775437] usbcore: registered new interface driver ums-usbat
[ 0.775536] usbcore: registered new interface driver usbserial
[ 0.775569] usbcore: registered new interface driver usbserial_generic
[ 0.775595] usbserial: USB Serial support registered for generic
[ 0.775634] usbcore: registered new interface driver option
[ 0.775681] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.775724] usbcore: registered new interface driver trancevibrator
[ 0.775738] usb20_otg: version 3.10a 21-DEC-2012
[ 0.775915] usb20_host: version 3.10a 21-DEC-2012
[ 0.776483] usbcore: registered new interface driver xpad
[ 0.776533] usbcore: registered new interface driver usb_acecad
[ 0.776582] usbcore: registered new interface driver aiptek
[ 0.776629] usbcore: registered new interface driver gtco
[ 0.776671] usbcore: registered new interface driver hanwang
[ 0.776712] usbcore: registered new interface driver kbtab
[ 0.776726] ==gsl_ts_init==
[ 0.776753] ret=0
[ 0.777181] .. rk pwm remotectl v1.1 init
[ 0.777425] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.777816] sensor_register_slave:kxtj9,id=11
[ 0.777837] sensor_register_slave:mma8452,id=17
[ 0.777853] sensor_register_slave:lis3dh,id=7
[ 0.777868] sensor_register_slave:mma7660,id=18
[ 0.777882] sensor_register_slave:lsm303d,id=22
[ 0.777896] sensor_register_slave:gs_mc3230,id=23
[ 0.777903] [Gsensor] gsensor_init
[ 0.777917] sensor_register_slave:mpu6880_acc,id=24
[ 0.777932] sensor_register_slave:mpu6500_acc,id=25
[ 0.777945] sensor_register_slave:lsm330_acc,id=26
[ 0.777956] sensor_register_slave:bma2xx_acc,id=27
[ 0.777972] sensor_register_slave:akm8975,id=30
[ 0.777982] sensor_register_slave:akm8963,id=31
[ 0.777992] sensor_register_slave:l3g4200d,id=45
[ 0.778002] sensor_register_slave:l3g20d,id=46
[ 0.778013] sensor_register_slave:ewtsa,id=47
[ 0.778023] sensor_register_slave:lsm330_gyro,id=51
[ 0.778034] sensor_register_slave:cm3217,id=53
[ 0.778043] sensor_register_slave:cm3218,id=54
[ 0.778054] sensor_register_slave:ls_stk3410,id=62
[ 0.778064] sensor_register_slave:ps_stk3410,id=67
[ 0.778819] i2c /dev entries driver
[ 0.780047] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 0.788361] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.788412] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097fa000
[ 0.789385] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.789475] fan53555-reg: supplied by vcc5v0_sys
[ 0.791412] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.791482] fan53555-reg: supplied by vcc5v0_sys
[ 0.793561] rk808 0-001b: Pmic Chip id: 0x0
[ 0.797027] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.797111] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.797217] DCDC_REG1: supplied by vcc3v3_sys
[ 0.797952] DCDC_REG2: supplied by vcc3v3_sys
[ 0.798561] DCDC_REG3: supplied by vcc3v3_sys
[ 0.798850] DCDC_REG4: supplied by vcc3v3_sys
[ 0.799304] LDO_REG1: supplied by vcc3v3_sys
[ 0.800436] LDO_REG2: supplied by vcc3v3_sys
[ 0.801428] LDO_REG3: supplied by vcc3v3_sys
[ 0.802421] LDO_REG4: supplied by vcc3v3_sys
[ 0.803400] LDO_REG5: supplied by vcc3v3_sys
[ 0.804373] LDO_REG6: supplied by vcc3v3_sys
[ 0.805363] LDO_REG7: supplied by vcc3v3_sys
[ 0.806344] LDO_REG8: supplied by vcc3v3_sys
[ 0.807335] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.807602] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.811139] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.811649] rk808 0-001b: Can not read property pmic,stby-gpio
[ 0.811688] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097fc000
[ 0.812175] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80097fe000
[ 0.812717] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80098ca000
[ 0.813822] fusb302 7-0022: Can’t get property of role, set role to default DRP
[ 0.813991] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 0.816638] fusb302 7-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.817912] mp8859 7-0066: set mp8859 out 12v ok
[ 0.817923] mp8859 7-0066: register ext0 dev0
[ 0.818057] mp8859 7-0066: mp8859 probe successful
[ 0.818084] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80098cc000
[ 0.818964] IR NEC protocol handler initialized
[ 0.818983] IR RC5(x/sz) protocol handler initialized
[ 0.818995] IR RC6 protocol handler initialized
[ 0.819007] IR JVC protocol handler initialized
[ 0.819019] IR Sony protocol handler initialized
[ 0.819031] IR SANYO protocol handler initialized
[ 0.819043] IR Sharp protocol handler initialized
[ 0.819055] IR MCE Keyboard/mouse protocol handler initialized
[ 0.819068] IR XMP protocol handler initialized
[ 0.819246] usbcore: registered new interface driver uvcvideo
[ 0.819256] USB Video Class driver (1.1.1)
[ 0.819273] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 0.823261] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 0.823394] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 0.823630] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.823734] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 0.824105] cw_bat_probe cw_init error
[ 0.826354] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 0.826945] device-mapper: uevent: version 1.0.3
[ 0.827210] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 0.827339] Bluetooth: HCI UART driver ver 2.3
[ 0.827352] Bluetooth: HCI UART protocol H4 registered
[ 0.827360] Bluetooth: HCI UART protocol LL registered
[ 0.827374] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 0.827382] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 0.827389] rtk_btusb: Register usb char device interface for BT driver
[ 0.827591] usbcore: registered new interface driver rtk_btusb
[ 0.827995] cpu cpu0: cpu_leakage=19
[ 0.828053] cpu cpu0: cpu_leakage=19
[ 0.840140] cpu cpu0: temp=20555, pvtm=150375 (152790 + -2415)
[ 0.840665] cpu cpu4: cpu_leakage=32
[ 0.840752] cpu cpu4: cpu_leakage=32
[ 0.853200] cpu cpu4: temp=20555, pvtm=156217 (157708 + -1491)
[ 0.857879] sdhci: Secure Digital Host Controller Interface driver
[ 0.857920] sdhci: Copyright(c) Pierre Ossman
[ 0.857931] Synopsys Designware Multimedia Card Interface Driver
[ 0.858830] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.859020] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 0.859041] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 0.859087] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.859115] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 0.859539] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 0.859582] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 0.859595] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 0.871701] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.886034] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 0.886380] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.890537] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 0.890571] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 0.918257] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 0.922019] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.925552] usbcore: registered new interface driver usbhid
[ 0.925597] usbhid: USB HID core driver
[ 0.925797] inv_mpu_iio: inv_mpu_init:746
[ 0.926876] ashmem: initialized
[ 0.929286] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 0.933322] ff100000.saradc supply vref not found, using dummy regulator
[ 0.935897] rknandbase v1.2 2018-05-08
[ 0.936708] usbcore: registered new interface driver snd-usb-audio
[ 0.944042] u32 classifier
[ 0.944073] Actions configured
[ 0.944120] Netfilter messages via NETLINK v0.30.
[ 0.944201] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.944680] ctnetlink v0.93: registering with nfnetlink.
[ 0.945740] xt_time: kernel timezone is -0000
[ 0.947070] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.947348] arp_tables: (C) 2002 David S. Miller
[ 0.947928] Initializing XFRM netlink socket
[ 0.948520] NET: Registered protocol family 10
[ 0.949853] mip6: Mobile IPv6
[ 0.949914] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.951059] sit: IPv6 over IPv4 tunneling driver
[ 0.951627] NET: Registered protocol family 17
[ 0.951668] NET: Registered protocol family 15
[ 0.951717] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.952403] Bridge firewalling registered
[ 0.952442] Ebtables v2.0 registered
[ 0.952645] Bluetooth: RFCOMM TTY layer initialized
[ 0.952672] Bluetooth: RFCOMM socket layer initialized
[ 0.952715] Bluetooth: RFCOMM ver 1.11
[ 0.952734] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 0.952742] Bluetooth: BNEP filters: protocol multicast
[ 0.952755] Bluetooth: BNEP socket layer initialized
[ 0.952766] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.952777] Bluetooth: HIDP socket layer initialized
[ 0.952817] l2tp_core: L2TP core driver, V2.0
[ 0.952836] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 0.952849] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.953379] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.953757] sensor_register_slave:mpu6500_gyro,id=49
[ 0.953779] sensor_register_slave:mpu6880_gyro,id=50
[ 0.955567] Registered cp15_barrier emulation handler
[ 0.955623] Registered setend emulation handler
[ 0.957136] registered taskstats version 1
[ 0.958006] fusb302 7-0022: CC connected in CC2 as UFP
[ 0.958345] rockchip ion idev is NULL
[ 0.958385] rga2 ff680000.rga: rga ion client create success!
[ 0.958730] mmc1: MAN_BKOPS_EN bit is not set
[ 0.958763] rga: Driver loaded successfully ver:3.02
[ 0.960463] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 0.960495] phy phy-ff770000.syscon:usb2-phy@e450.2: Failed to get VBUS supply regulator
[ 0.962437] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.962487] phy phy-ff770000.syscon:usb2-phy@e460.4: Failed to get VBUS supply regulator
[ 0.965060] rockchip-drm display-subsystem: defer getting devfreq
[ 0.965422] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.965726] rockchip-vop ff900000.vop: unable to request PWM
[ 0.965756] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.965817] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.966002] rockchip-vop ff8f0000.vop: unable to request PWM
[ 0.966024] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.966622] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.966673] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.966800] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.968938] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.969597] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 0.970004] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 0.970021] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.970029] [drm] No driver support for vblank timestamp query.
[ 0.970474] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.970500] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.970516] rockchip-drm display-subsystem: failed to show loader logo
[ 0.970524] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 0.970687] Freeing drm_logo memory: 820K
[ 0.970709] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 0.970724] [drm] Cannot find any crtc or sizes - going 1024x768
[ 0.971120] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 0.971382] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 0.971793] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 0.972035] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 0.975085] rockchip-drm display-subsystem: fb0: frame buffer device
[ 0.975268] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 0.995857] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 0.996203] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
[ 0.996650] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 0.996776] xhci-hcd xhci-hcd.11.auto: irq 228, io mem 0xfe800000
[ 0.997055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.997108] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.997128] usb usb1: Product: xHCI Host Controller
[ 0.997146] usb usb1: Manufacturer: Linux 4.4.126 xhci-hcd
[ 0.997163] usb usb1: SerialNumber: xhci-hcd.11.auto
[ 0.997977] hub 1-0:1.0: USB hub found
[ 0.998073] hub 1-0:1.0: 1 port detected
[ 0.998710] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 0.999005] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
[ 0.999197] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.999410] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.999457] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.999476] usb usb2: Product: xHCI Host Controller
[ 0.999494] usb usb2: Manufacturer: Linux 4.4.126 xhci-hcd
[ 0.999512] usb usb2: SerialNumber: xhci-hcd.11.auto
[ 1.000363] hub 2-0:1.0: USB hub found
[ 1.000461] hub 2-0:1.0: 1 port detected
[ 1.003151] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.003195] usb usb2: USB disconnect, device number 1
[ 1.032076] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 1.032141] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 1.032253] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
[ 1.032525] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.032590] usb usb1: USB disconnect, device number 1
[ 1.033469] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
[ 1.038791] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 1.040542] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.041102] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1
[ 1.042084] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.042311] xhci-hcd xhci-hcd.12.auto: irq 229, io mem 0xfe900000
[ 1.042842] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.042988] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.043212] usb usb1: Product: xHCI Host Controller
[ 1.043443] usb usb1: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.043669] usb usb1: SerialNumber: xhci-hcd.12.auto
[ 1.045495] hub 1-0:1.0: USB hub found
[ 1.045650] hub 1-0:1.0: 1 port detected
[ 1.046597] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.047258] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2
[ 1.047607] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.047994] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.048303] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.048525] usb usb2: Product: xHCI Host Controller
[ 1.048753] usb usb2: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.048980] usb usb2: SerialNumber: xhci-hcd.12.auto
[ 1.050681] hub 2-0:1.0: USB hub found
[ 1.050924] hub 2-0:1.0: 1 port detected
[ 1.052269] xhci-hcd xhci-hcd.12.auto: remove, state 1
[ 1.052401] usb usb2: USB disconnect, device number 1
[ 1.053935] xhci-hcd xhci-hcd.12.auto: USB bus 2 deregistered
[ 1.054377] xhci-hcd xhci-hcd.12.auto: remove, state 1
[ 1.054569] usb usb1: USB disconnect, device number 1
[ 1.056096] xhci-hcd xhci-hcd.12.auto: USB bus 1 deregistered
[ 1.060021] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.060632] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.060878] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.061239] rockchip-iodomain ff770000.syscon:io-domains: Setting to 1800000 done
[ 1.061801] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 1.062319] mp8859 7-0066: mp8859 get notify
[ 1.062351] mp8859 7-0066: mp8859 get ufp 1 dp 0
[ 1.064548] mp8859 7-0066: set mp8859 out 12v ok
[ 1.071847] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.072226] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.072257] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.072282] usb usb1: Product: EHCI Host Controller
[ 1.072304] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.072326] usb usb1: SerialNumber: fe380000.usb
[ 1.073456] hub 1-0:1.0: USB hub found
[ 1.073578] hub 1-0:1.0: 1 port detected
[ 1.078455] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.078928] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.079448] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[ 1.086978] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 1.088505] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.089004] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.089054] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.089158] usb usb2: Product: EHCI Host Controller
[ 1.089182] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.089204] usb usb2: SerialNumber: fe3c0000.usb
[ 1.090380] hub 2-0:1.0: USB hub found
[ 1.090507] hub 2-0:1.0: 1 port detected
[ 1.092380] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.092856] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.093314] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 1.128097] fusb302 7-0022: 0000 max vol cur 0 0
[ 1.128259] fusb302 7-0022: max vol cur 15000 3000
[ 1.149455] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.149512] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.149540] usb usb3: Product: Generic Platform OHCI controller
[ 1.149564] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.149586] usb usb3: SerialNumber: fe3a0000.usb
[ 1.150688] hub 3-0:1.0: USB hub found
[ 1.150769] hub 3-0:1.0: 1 port detected
[ 1.152632] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.153115] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.153587] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[ 1.209310] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.209424] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.209451] usb usb4: Product: Generic Platform OHCI controller
[ 1.209474] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.209496] usb usb4: SerialNumber: fe3e0000.usb
[ 1.210736] hub 4-0:1.0: USB hub found
[ 1.210903] hub 4-0:1.0: 1 port detected
[ 1.214032] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 1.214486] rockchip-dmc dmc: could not find power_model node
[ 1.216125] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 1.216257] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to add ELD: -16
[ 1.217669] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 1.217900] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 1.222422] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:05 UTC (1358499005)
[ 1.223724] It doesn’t contain Rogue gpu
[ 1.254168] u
[ 1.265599] fusb302 7-0022: PD connected as UFP, fetching 5V
[ 1.266689] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
4月3日 从git@gitlab.com:TeeFirefly/firenow-oreo-rk3399.git 上取代码编译生成的固件“sd_ROC_RK3399_PC_Android8.1.0_DEFAULT_200403.img”烧写tf卡启动,kernel初始化失败。附第一次和第二次上电的启动log。faillog.zip (24.2 KB)
发货u盘中带的固件“sd_ROC-RK3399-PC_Android8.1.0_DEFAULT_181025.img”用同样方法烧写可以启动。附正常image第一次和第二次上电启动的两个log。OKlog.zip (35.4 KB)
建议用7.1行业版本,8.1已经不做维护
能分析出大致原因吗
