rk3308插入sd卡,没有自动挂载手动挂载不成功
/ # mount /dev/mmcblk0p1 /sdcard
FUSE exfat 1.2.6
fuse: device not found, try ‘modprobe fuse’ first
/ # modprobe fuse
modprobe: can’t change directory to ‘/lib/modules’: No such file or directory
这是什么原因,大佬们快来献爱心
TF扩展卡挂载不成功
  1. 开发板型号是什么?
  2. FAT32文件系统的TF卡是否可以挂载?
firefly_zhongw 发表于 2020-4-8 18:54
  1. 开发板型号是什么?
开发板型号是rk3308;
sd卡是闪迪的128g的micro SD存储卡,
/ # fdisk -l
Found valid GPT with protective MBR; using GPT
Disk /dev/mmcblk1: 15269888 sectors, 3360M
Logical sector size: 512
Disk identifier (GUID): 992b0000-0000-4473-8000-2b880000574b
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 15269854
Number Start (sector) End (sector) Size Name
1 8192 12287 2048K uboot
2 12288 16383 2048K trust
3 16384 18431 1024K misc
4 18432 43007 12.0M recovery
5 43008 61439 9216K boot
6 61440 585727 256M rootfs
7 585728 716799 64.0M oem
8 716800 15269854 7105M userdata
Disk /dev/mmcblk1boot1: 4 MB, 4194304 bytes, 8192 sectors
128 cylinders, 4 heads, 16 sectors/track
Units: cylinders of 64 * 512 = 32768 bytes
Disk /dev/mmcblk1boot1 doesn’t contain a valid partition table
Disk /dev/mmcblk1boot0: 4 MB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0 doesn’t contain a valid partition table
Disk /dev/mmcblk0: 119 GB, 127865454592 bytes, 249737216 sectors
15545 cylinders, 255 heads, 63 sectors/track
Units: cylinders of 16065 * 512 = 8225280 bytes
Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type
/dev/mmcblk0p1 2,10,9 1023,254,63 32768 249737215 249704448 119G 7 HPFS/NTFS
/ # cat /proc/partitions
major minor #blocks name
179 32 7634944 mmcblk1
179 33 2048 mmcblk1p1
179 34 2048 mmcblk1p2
179 35 1024 mmcblk1p3
179 36 12288 mmcblk1p4
179 37 9216 mmcblk1p5
179 38 262144 mmcblk1p6
179 39 65536 mmcblk1p7
179 40 7276527 mmcblk1p8
179 128 512 mmcblk1rpmb
179 96 4096 mmcblk1boot1
179 64 4096 mmcblk1boot0
179 0 124868608 mmcblk0
179 1 124852224 mmcblk0p1
FUSE exfat 1.2.6
/ # mount -t vfat /dev/mmcblk0p1 /sdcard/
mount: /mnt/sdcard: wrong fs type, bad option, bad superblock on /dev/mmcblk0p1, missing codepage or helper program, or other error.
/ # mount -t ntfs /dev/mmcblk0p1 /sdcard/
NTFS signature is missing.
Failed to mount ‘/dev/mmcblk0p1’: Invalid argument
The device ‘/dev/mmcblk0p1’ doesn’t seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
  1. fat32文件系统的TF卡是否可以用,排除硬件问题?
  2. fuse exfat的文件系统的,尝试用mount.exfat-fuse相关命令
  2. fuse exfat的文件系统的,尝试用mount.exfat-fuse …
如何查看TF卡的文件系统格式?我现在就一张sd卡。
FUSE exfat 1.2.6
这是不是说明文件系统是ntfs的。
/ # mount.exfat-fuse /dev/mmcblk0p1 /sdcard/
FUSE exfat 1.2.6
/ # modprobe fuse
是这样嘛,还是不行,提示一个文件目录找不到,是不是这个命令会创建新的目录,而我的设备是只读权限所以挂载不成功?
  1. 如果不需要 HPFS/NTFS格式,可以在PC端格式化成FAT32,看能不能挂载?先确保硬件是好的
  2. 默认不支持NTFS文件系统
已解决,格式成fat32就可以,谢谢
  2. 默认不支持N …
谢谢{:4_108:}
