升级固件HDMI没显示
[ 2.234376] sensor_register_slave:lsm330_gyro,id=50
[ 2.234393] sensor_register_slave:cm3217,id=52
[ 2.234410] sensor_register_slave:cm3218,id=53
[ 2.235383] i2c /dev entries driver
[ 2.237061] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.237173] fan53555-reg: supplied by vcc5v0_sys
[ 2.239066] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.239134] fan53555-reg: supplied by vcc5v0_sys
[ 2.241217] rk808 0-001b: Pmic Chip id: 0x0
[ 2.244755] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.244830] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.244934] DCDC_REG1: supplied by vcc3v3_sys
[ 2.245698] DCDC_REG2: supplied by vcc3v3_sys
[ 2.246294] DCDC_REG3: supplied by vcc3v3_sys
[ 2.246572] DCDC_REG4: supplied by vcc3v3_sys
[ 2.247029] LDO_REG1: supplied by vcc3v3_sys
[ 2.248179] LDO_REG2: supplied by vcc3v3_sys
[ 2.249176] LDO_REG3: supplied by vcc3v3_sys
[ 2.250191] LDO_REG4: supplied by vcc3v3_sys
[ 2.251211] LDO_REG5: supplied by vcc3v3_sys
[ 2.252239] LDO_REG6: supplied by vcc3v3_sys
[ 2.253275] LDO_REG7: supplied by vcc3v3_sys
[ 2.254338] LDO_REG8: supplied by vcc3v3_sys
[ 2.255365] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.255648] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.259422] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.259901] rk808 0-001b: Can not read property pmic,hold-gpio
[ 2.259926] rk808 0-001b: Can not read property pmic,stby-gpio
[ 2.259969] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009952000
[ 2.260760] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009954000
[ 2.261398] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009956000
[ 2.261519] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 2.261536] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 2.261552] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 2.261567] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 2.261975] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff8009958000
[ 2.262616] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800995a000
[ 2.263829] IR NEC protocol handler initialized
[ 2.263846] IR RC5(x/sz) protocol handler initialized
[ 2.263862] IR RC6 protocol handler initialized
[ 2.263876] IR JVC protocol handler initialized
[ 2.263890] IR Sony protocol handler initialized
[ 2.263905] IR SANYO protocol handler initialized
[ 2.263920] IR Sharp protocol handler initialized
[ 2.263935] IR MCE Keyboard/mouse protocol handler initialized
[ 2.263949] IR XMP protocol handler initialized
[ 2.264304] usbcore: registered new interface driver uvcvideo
[ 2.264315] USB Video Class driver (1.1.1)
[ 2.264336] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 2.270232] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.270406] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.270729] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.270856] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.274206] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.275343] device-mapper: uevent: version 1.0.3
[ 2.275767] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.276097] Bluetooth: HCI UART driver ver 2.3
[ 2.276112] Bluetooth: HCI UART protocol H4 registered
[ 2.276123] Bluetooth: HCI UART protocol LL registered
[ 2.276138] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.276148] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.276158] rtk_btusb: Register usb char device interface for BT driver
[ 2.276423] usbcore: registered new interface driver rtk_btusb
[ 2.276987] cpu cpu0: leakage=20
[ 2.294897] cpu cpu0: temp=75625, pvtm=144062 (141818 + 2244)
[ 2.295279] cpu cpu0: pvtm-sel=1
[ 2.295687] cpu cpu4: leakage=32
[ 2.307988] cpu cpu4: temp=75625, pvtm=149498 (148308 + 1190)
[ 2.308128] cpu cpu4: pvtm-sel=1
[ 2.310305] cpufreq_cooling_get_level: cpu:0 not part of any cooling device
[ 2.310347] thermal cooling_device0: Failed to convert 1512000KHz for cpu 0 into a cdev state
[ 2.313025] cpufreq_cooling_get_level: cpu:4 not part of any cooling device
[ 2.313061] thermal cooling_device1: Failed to convert 1800000KHz for cpu 4 into a cdev state
[ 2.313949] sdhci: Secure Digital Host Controller Interface driver
[ 2.313961] sdhci: Copyright(c) Pierre Ossman
[ 2.313977] Synopsys Designware Multimedia Card Interface Driver
[ 2.315233] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.315413] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.315434] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.315505] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.315550] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.315607] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.315620] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.316740] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.316834] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.316854] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.316906] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.316932] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.317061] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.317975] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.319970] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.319985] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.346262] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.350303] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.354117] usbcore: registered new interface driver usbhid
[ 2.354151] usbhid: USB HID core driver
[ 2.354295] inv_mpu_iio: inv_mpu_init:746
[ 2.355110] ashmem: initialized
[ 2.357359] ff100000.saradc supply vref not found, using dummy regulator
[ 2.359873] rknandbase v1.1 2016-11-08
[ 2.360677] usbcore: registered new interface driver snd-usb-audio
[ 2.362103] rt5640 1-001c: Can not read property hp-con-gpio
[ 2.362128] rt5640 1-001c: Can not read property: linein-mute.
[ 2.379977] rockchip-pinctrl pinctrl: pin gpio3-16 already requested by 1-001c; cannot claim for ff870000.spdif
[ 2.380050] rockchip-pinctrl pinctrl: pin-112 (ff870000.spdif) status -22
[ 2.380066] rockchip-pinctrl pinctrl: could not request pin 112 (gpio3-16) from group spdif-bus-1 on device rockchip-pinctrl
[ 2.380081] rockchip-spdif ff870000.spdif: Error applying setting, reverse things back
[ 2.385474] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.387103] mmc0: MAN_BKOPS_EN bit is not set
[ 2.389853] u32 classifier
[ 2.389909] Actions configured
[ 2.389984] Netfilter messages via NETLINK v0.30.
[ 2.390075] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.390531] ctnetlink v0.93: registering with nfnetlink.
[ 2.391353] xt_time: kernel timezone is -0000
[ 2.392733] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.392977] arp_tables: (C) 2002 David S. Miller
[ 2.393713] Initializing XFRM netlink socket
[ 2.394341] NET: Registered protocol family 10
[ 2.395880] mip6: Mobile IPv6
[ 2.395957] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.397361] sit: IPv6 over IPv4 tunneling driver
[ 2.397931] NET: Registered protocol family 17
[ 2.397992] NET: Registered protocol family 15
[ 2.398042] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.398148] Bridge firewalling registered
[ 2.398164] Ebtables v2.0 registered
[ 2.398467] Bluetooth: RFCOMM TTY layer initialized
[ 2.398485] Bluetooth: RFCOMM socket layer initialized
[ 2.398523] Bluetooth: RFCOMM ver 1.11
[ 2.398546] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.398554] Bluetooth: BNEP filters: protocol multicast
[ 2.398573] Bluetooth: BNEP socket layer initialized
[ 2.398588] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.398601] Bluetooth: HIDP socket layer initialized
[ 2.398670] l2tp_core: L2TP core driver, V2.0
[ 2.398692] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.398711] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.398972] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.399218] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.399404] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.399415] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.399424] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.399522] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.399532] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.399544] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.399624] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.399667] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.400073] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.400280] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.400327] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.400361] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.400396] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.400514] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.400974] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 2.401061] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.401098] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 2.401120] [BT_RFKILL]: ** disable irq
[ 2.401286] [BT_RFKILL]: bt_default device registered.
[ 2.401537] sensor_register_slave:mpu6880_gyro,id=49
[ 2.401623] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.401636] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.401646] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.401656] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.401667] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.401677] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.401687] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 2.401697] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 2.401706] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 2.401717] system: 0x016800000 – 0x076800000 (1536 MB)
[ 2.401727] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 2.401736] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 2.401775] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 2.401851] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 2.403020] Registered cp15_barrier emulation handler
[ 2.403107] Registered setend emulation handler
[ 2.404102] registered taskstats version 1
[ 2.404984] rockchip ion idev is NULL
[ 2.405004] rga2 ff680000.rga: rga ion client create success!
[ 2.405207] rga: Driver loaded successfully ver:3.02
[ 2.406320] mali ff9a0000.gpu: leakage=26
[ 2.418798] mali ff9a0000.gpu: temp=74444, pvtm=120552 (120156 + 396)
[ 2.419038] vendor storage:20160801 ret = 0
[ 2.419416] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.420264] mali ff9a0000.gpu: pvtm-sel=0
[ 2.423149] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.424027] core: dev_pm_opp_get_voltage: Invalid parameters
[ 2.424044] mali ff9a0000.gpu: Failed to get voltage for frequency 0: -34
[ 2.425008] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.425696] mali ff9a0000.gpu: Probed as mali0
[ 2.430587] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.430632] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 2.430957] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.431013] xhci-hcd xhci-hcd.9.auto: irq 235, io mem 0xfe800000
[ 2.431173] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.431187] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.431199] usb usb5: Product: xHCI Host Controller
[ 2.431209] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.431219] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 2.431773] hub 5-0:1.0: USB hub found
[ 2.431810] hub 5-0:1.0: 1 port detected
[ 2.432095] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.432115] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[ 2.432181] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.432281] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.432294] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.432306] usb usb6: Product: xHCI Host Controller
[ 2.432316] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.432327] usb usb6: SerialNumber: xhci-hcd.9.auto
[ 2.432804] hub 6-0:1.0: USB hub found
[ 2.432836] hub 6-0:1.0: 1 port detected
[ 2.434500] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 2.434531] usb usb6: USB disconnect, device number 1
[ 2.458364] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[ 2.458388] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[ 2.458448] xhci-hcd xhci-hcd.9.auto: USB bus 6 deregistered
[ 2.458467] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 2.458490] usb usb5: USB disconnect, device number 1
[ 2.461212] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[ 2.466429] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.466465] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 2.466766] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.466817] xhci-hcd xhci-hcd.10.auto: irq 236, io mem 0xfe900000
[ 2.466959] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.466970] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.466980] usb usb5: Product: xHCI Host Controller
[ 2.466989] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.466998] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 2.467532] hub 5-0:1.0: USB hub found
[ 2.467564] hub 5-0:1.0: 1 port detected
[ 2.467807] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.467825] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[ 2.467880] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.467964] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.467976] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.467986] usb usb6: Product: xHCI Host Controller
[ 2.467994] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.468004] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 2.468371] hub 6-0:1.0: USB hub found
[ 2.468398] hub 6-0:1.0: 1 port detected
[ 2.469814] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.470002] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.470018] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.470053] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.470077] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.470124] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.470134] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.470464] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.482733] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.496080] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.497349] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.497497] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.497514] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.497549] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.497576] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.497681] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.499118] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 2.501290] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 2.501317] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.501329] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.513136] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.527361] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.537913] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.541943] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.542061] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 2.543777] otg_wakelock_init: No USB transceiver found
[ 2.543840] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.544029] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.544044] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.544057] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.544128] i2c i2c-2: sensor_probe: gs_mc3230,ffffffc0f0b3b000
[ 2.544237] sensors 2-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0xffffff80091ff090
[ 2.544905] hub 2-1:1.0: USB hub found
[ 2.545134] hub 2-1:1.0: 7 ports detected
[ 2.545664] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.548456] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.552082] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.603373] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 2.706639] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 71
[ 2.715408] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.716039] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 3.542977] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 4.542987] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 5.552994] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 6.552992] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 7.553000] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 8.563010] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 9.563002] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 10.573001] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 10.573099] [Gsensor] init_3230_ctl_data 445 : error: -110
[ 10.573130] sensors 2-004c: sensor_initial:fail to init sensor
[ 10.573158] sensors 2-004c: sensor_chip_init:fail to init sensor
[ 10.573185] i2c i2c-2: sensor_probe failed -2
[ 10.573185]
[ 10.573238] sensors: probe of 2-004c failed with error -2
[ 10.576052] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:00:15 UTC (1358499615)
[ 10.577503] It doesn’t contain Rogue gpu
[ 10.608196] ret 1024
[ 10.609067] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-Firefly-RK3399_Android7.1.1_170516_internal-2727-gdc7e889’, rk_ko_ver is ‘5’, built at ‘10:47:14’, on ‘Nov 6 2019’.
[ 10.610144] Mali: Mali device driver loaded
[ 10.611276] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 10.613344] ALSA device list:
[ 10.613443] #0: rk-hdmi-dp-sound
[ 10.613462] #1: rockchip,rt5640-codec
[ 10.614365] Freeing unused kernel memory: 832K
[ 10.619651] init: init first stage started!
[ 10.700564] audit: type=1403 audit(1358499615.623:2): policy loaded auid=4294967295 ses=4294967295
[ 10.701326] init: (Initializing SELinux non-enforcing took 0.08s.)
[ 10.706262] init: init second stage started!
[ 10.714865] init: Setting ro.rk.soc=rk3399
[ 10.715142] init: OK,EMMC DRIVERS INIT OK
[ 10.715199] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 10.715331] init: property_set(“ro.hardware”, “rk30board”) failed
[ 10.719297] init: Running restorecon…
[ 10.806310] init: waitpid failed: No child processes
[ 10.806741] init: (Loading properties from /default.prop took 0.00s.)
[ 10.808544] init: /init.rc: 588: invalid keyword ‘echo’
[ 10.809044] init: (Parsing /init.environ.rc took 0.00s.)
[ 10.809494] init: (Parsing /init.usb.rc took 0.00s.)
[ 10.810470] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 10.811237] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 10.811304] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 10.811402] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 10.811579] init: (Parsing /init.logs.rc took 0.00s.)
[ 10.811658] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 10.811735] init: (Parsing /init.coredump.rc took 0.00s.)
[ 10.811787] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 10.811842] init: (Parsing /init.kernel.rc took 0.00s.)
[ 10.811949] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 10.811967] init: (Parsing /init.debug.rc took 0.00s.)
[ 10.811983] init: (Parsing init.rockchip.rc took 0.00s.)
[ 10.812419] init: (Parsing init.connectivity.rc took 0.00s.)
[ 10.812507] init: (Parsing init.box.samba.rc took 0.00s.)
[ 10.812620] init: (Parsing init.rk3399.rc took 0.00s.)
[ 10.812770] init: init.box.rc: 25: invalid keyword ‘ioprio’
[ 10.812796] init: (Parsing init.box.rc took 0.00s.)
[ 10.812833] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 10.812863] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 10.812879] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 10.813592] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 10.813692] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 10.813708] init: (Parsing /init.rc took 0.01s.)
[ 10.814298] init: Starting service ‘ueventd’…
[ 10.816816] audit: type=1400 audit(1358499615.740:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=3128 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 10.820293] ueventd: ueventd started!
[ 10.821884] ueventd: invalid gid ‘trace’
[ 11.039503] ueventd: Coldboot took 0.21s.
[ 11.084866] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 11.084927] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 11.126165] init: Waiting for /dev/.coldboot_done…
[ 11.126262] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 11.126302] init: /dev/hw_random not found
[ 11.126794] keychord: using input dev ff420030.pwm for fevent
[ 11.126803] keychord: using input dev rk29-keypad for fevent
[ 11.132425] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 11.139504] Registered swp emulation handler
[ 11.139702] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 11.140232] init: /dev/hw_random not found
[ 11.141078] fs_mgr: Warning: unknown flag resize
[ 11.147962] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 11.148095] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 11.148875] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 11.149408] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 11.155718] random: e2fsck: uninitialized urandom read (40 bytes read, 77 bits of entropy available)
[ 11.190083] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 11.190083]
[ 11.190154] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 11.190154]
[ 11.190171] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 24/8192 files, 1609/32768 blocks
[ 11.190171]
[ 11.193422] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 11.193520] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 11.194599] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 11.195880] EXT4-fs (mmcblk0p11): recovery complete
[ 11.195892] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 11.195935] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 11.214667] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 11.214749] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 11.216335] random: e2fsck: uninitialized urandom read (40 bytes read, 79 bits of entropy available)
[ 11.224446] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 11.224446]
[ 11.224511] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 11.224511]
[ 11.226913] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 11.226999] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 11.227071] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 11.229880] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 11.229880]
[ 11.229906] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 11.229906]
[ 11.280414] F2FS-fs (mmcblk0p13): Mounted with checkpoint version = 23
[ 11.280795] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[ 11.285218] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 11.285448] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 11.285634] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 11.285853] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 11.286217] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 11.288674] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 11.289013] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 11.289235] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 11.289538] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 11.289738] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 11.289968] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 11.290161] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 11.290353] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 11.290547] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 11.290913] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 11.291127] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 11.291335] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 11.291542] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 11.291748] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 11.291956] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 11.292182] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 11.292397] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 11.292608] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 11.292839] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 11.293033] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 11.293236] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 11.293479] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 11.293673] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 11.293882] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 11.294086] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 11.294294] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 11.295310] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 11.295682] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 11.295841] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 11.295944] init: (Loading properties from /system/build.prop took 0.00s.)
[ 11.296007] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 11.296037] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 11.296134] fs_mgr: Warning: unknown flag resize
[ 11.296216] init: /recovery not specified in fstab
[ 11.296312] init: Starting service ‘healthd’…
[ 11.296729] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 11.297179] init: Starting service ‘earlylogs’…
[ 11.298697] init: Starting service ‘zygote’…
[ 11.299431] init: Starting service ‘zygote_secondary’…
[ 11.300177] binder: 196:196 transaction failed 29189/-22, size 0-0 line 2951
[ 11.300558] init: Starting service ‘lmkd’…
[ 11.303295] random: elogs.sh: uninitialized urandom read (40 bytes read, 84 bits of entropy available)
[ 11.303480] init: Starting service ‘servicemanager’…
[ 11.304288] init: Starting service ‘surfaceflinger’…
[ 11.304618] random: app_process64: uninitialized urandom read (40 bytes read, 84 bits of entropy available)
[ 11.306577] init: Starting service ‘vold’…
[ 11.311237] random: app_process32: uninitialized urandom read (40 bytes read, 85 bits of entropy available)
[ 11.312333] init: Service ‘earlylogs’ (pid 197) exited with status 0
[ 11.313210] random: surfaceflinger: uninitialized urandom read (40 bytes read, 85 bits of entropy available)
[ 11.314499] random: lmkd: uninitialized urandom read (40 bytes read, 85 bits of entropy available)
[ 11.314679] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directory
[ 11.316732] random: servicemanager: uninitialized urandom read (40 bytes read, 85 bits of entropy available)
[ 11.317188] init: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 11.319951] zram0: detected capacity change from 0 to 533413888
[ 11.322238] random: vold: uninitialized urandom read (40 bytes read, 86 bits of entropy available)
[ 11.326295] random: mkswap: uninitialized urandom read (40 bytes read, 86 bits of entropy available)
[ 11.363743] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 11.365309] init: Starting service ‘debuggerd’…
[ 11.366070] init: Starting service ‘debuggerd64’…
[ 11.368463] init: Not bootcharting.
[ 11.504909] fs_mgr: Warning: unknown flag resize
[ 11.601199] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 11.610725] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 225) exited with status 0
[ 11.615682] audit: type=1400 audit(1358499616.536:4): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk0p13” ino=86 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 11.619707] F2FS-fs (mmcblk0p13): acl options not supported
[ 11.619731] F2FS-fs (mmcblk0p13): Unrecognized mount option “errors=panic” or missing value
[ 11.624455] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 11.625060] init: (Loading properties from /data/local.prop took 0.00s.)
[ 11.653096] init: Starting service ‘logd’…
[ 11.653824] init: Starting service ‘logd-reinit’…
[ 11.655217] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 11.656876] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 11.657999] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 11.659746] audit: type=1400 audit(1358499616.583:5): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=14272 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 11.659966] audit: type=1400 audit(1358499616.583:6): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=14268 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[ 11.661258] audit: type=1400 audit(1358499616.583:7): avc: denied { getattr } for pid=1 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk0p10” ino=2792 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 11.661307] init: Starting service ‘fsud’…
[ 11.661902] init: Starting service ‘vm_daemon’…
[ 11.663375] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 11.663393] init: write: cannot expand ‘${ro.serialno}’
[ 11.665153] file system registered
[ 11.665685] audit: type=1400 audit(1358499616.586:8): avc: denied { execute } for pid=233 comm=“init” name=“fsu” dev=“mmcblk0p10” ino=2792 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 11.665770] audit: type=1400 audit(1358499616.586:10): avc: denied { transition } for pid=233 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk0p10” ino=2792 scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=process permissive=1
[ 11.665809] audit: type=1400 audit(1358499616.586:13): avc: denied { entrypoint } for pid=233 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk0p10” ino=2792 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 11.670575] using random self ethernet address
[ 11.670592] using random host ethernet address
[ 11.670643] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 11.678181] audit: type=1400 audit(1358499616.600:14): avc: denied { rlimitinh } for pid=233 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=process permissive=1
[ 11.684135] init: Starting service ‘console’…
[ 11.685051] init: Starting service ‘adbd’…
[ 11.687768] init: Starting service ‘ap_log_srv’…
[ 11.689179] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 11.689819] init: Starting service ‘ril-daemon’…
[ 11.690565] logd.auditd: start
[ 11.690611] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 11.690972] init: Starting service ‘drmservice’…
[ 11.691918] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 11.692355] init: Service up_eth0 does not have a SELinux domain defined.
[ 11.692422] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 11.692620] init: Starting service ‘akmd’…
[ 11.693610] logd.klogd: 11690920942
[ 11.694329] init: Starting service ‘audioserver’…
[ 11.695740] init: Starting service ‘cameraserver’…
[ 11.696460] init: couldn’t write 248 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 11.697406] init: Starting service ‘drm’…
[ 11.698659] init: Starting service ‘installd’…
[ 11.699785] init: Starting service ‘keystore’…
[ 11.701225] init: Starting service ‘mediacodec’…
[ 11.703198] init: Starting service ‘mediadrm’…
[ 11.705830] init: Starting service ‘mediaextractor’…
[ 11.707253] init: Starting service ‘media’…
[ 11.708649] init: Starting service ‘netd’…
[ 11.716371] init: Service ‘logd-reinit’ (pid 232) exited with status 145
[ 11.722875] init: Starting service ‘crashlogd’…
[ 11.726461] init: Starting service ‘log-watch’…
[ 11.727933] init: Starting service ‘gatekeeperd’…
[ 11.729077] init: Starting service ‘perfprofd’…
rk3399_firefly_aiojd4_box:/ $ [ 11.769615] init: Service ‘akmd’ (pid 246) exited with status 254
[ 11.786397] ret = ffffffffffffffff
[ 11.806438] init: avc: denied { set } for property=telephony.lteOnCdmaDevice pid=241 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 11.806949] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 11.806971] init: setprop: cannot expand ‘${sys.serialno}’
[ 11.818364] init: Starting service ‘apk_logfs’…
[ 11.820012] init: Service ‘ap_log_srv’ (pid 238) exited with status 0
[ 11.820854] init: Service ‘drmservice’ (pid 245) exited with status 0
[ 11.899517] read descriptors
[ 11.899562] read strings
[ 11.976229] type=1400 audit(1358499616.880:35): avc: denied { execute } for pid=291 comm=“audioserver” name=“sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.983271] type=1400 audit(1358499616.880:36): avc: denied { read open } for pid=291 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.985817] type=1400 audit(1358499616.880:37): avc: denied { execute_no_trans } for pid=291 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.988276] type=1400 audit(1358499616.883:38): avc: denied { getattr } for pid=291 comm=“sh” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 11.988385] type=1400 audit(1358499616.890:39): avc: denied { getattr } for pid=291 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.988460] type=1400 audit(1358499616.890:40): avc: denied { execute } for pid=291 comm=“sh” name=“toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.988531] type=1400 audit(1358499616.890:41): avc: denied { read open } for pid=291 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 11.988602] type=1400 audit(1358499616.890:42): avc: denied { execute_no_trans } for pid=291 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.117090] init: Untracked pid 300 exited with status 0
[ 12.236549] init: Untracked pid 322 exited with status 0
[ 12.261113] random: nonblocking pool is initialized
[ 12.303209] healthd: BatteryCurrentNowPath not found
[ 12.303259] healthd: BatteryCycleCountPath not found
[ 12.833267] init: Starting service ‘bootanim’…
[ 12.991124] Freeing drm_logo memory: 488K
[ 13.062650] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 13.062945] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 13.075352] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 13.075401] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 13.075412] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 13.075425] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 13.075434] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 13.086424] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 13.086628] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 13.117398] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 13.117684] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 13.128722] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 13.128743] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 13.128753] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 13.128765] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 13.128774] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 13.139737] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 13.139991] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 13.169916] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 13.170114] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 13.181135] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 13.181159] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 13.181170] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 13.181180] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 13.181187] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 13.193097] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 13.193292] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 14.059524] init: Untracked pid 325 exited with status 1
[ 14.081584] init: Untracked pid 304 exited with status 1
[ 14.376293] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 15.413215] type=1400 audit(1358499620.336:109): avc: denied { read } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 16.995002] acc_open
[ 16.995042] acc_release
[ 17.789767] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 56:ff:e0:18:8d:9b
[ 17.789803] eth0: device MAC address 56:ff:e0:18:8d:9b
[ 17.789850] phy_rtl8211f_led_fixup in
[ 18.028784] type=1400 audit(1358499622.950:110): avc: denied { search } for pid=257 comm=“Binder:257_1” name=“592” dev=“proc” ino=16719 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=
[ 18.032443] type=1400 audit(1358499622.950:111): avc: denied { read } for pid=257 comm=“Binder:257_1” name=“cmdline” dev=“proc” ino=16725 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=f
[ 18.032588] type=1400 audit(1358499622.950:112): avc: denied { open } for pid=257 comm=“Binder:257_1” path=“/proc/592/cmdline” dev=“proc” ino=16725 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=f
[ 18.420009] type=1400 audit(1358499623.343:113): avc: denied { read } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 19.165280] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 19.166137] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 19.178413] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 19.178436] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 19.178446] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 19.178458] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 19.178465] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 19.189487] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 19.189722] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 19.228296] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 19.228618] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 19.239392] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 19.239419] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 19.239434] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 19.239450] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 19.239462] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 19.251019] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 19.251256] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 19.292042] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 19.292256] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 19.303635] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 19.304207] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 19.304235] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 19.304253] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 19.304267] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 19.316058] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 19.316389] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 19.380646] type=1400 audit(1358499624.303:114): avc: denied { read } for pid=247 comm=“AudioOut_D” name=“audioformat” dev=“sysfs” ino=12564 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 19.384461] type=1400 audit(1358499624.303:115): avc: denied { open } for pid=247 comm=“AudioOut_D” path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=12564 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 19.387161] type=1400 audit(1358499624.303:116): avc: denied { getattr } for pid=247 comm=“AudioOut_D” path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=12564 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 19.784918] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 19.785439] init: Starting service ‘mode_switch’…
[ 19.788445] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 19.789442] type=1400 audit(1358499624.710:117): avc: denied { entrypoint } for pid=1023 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p10” ino=463 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 19.809081] type=1400 audit(1358499624.723:118): avc: denied { getattr } for pid=1023 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 19.816887] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 1025) exited with status 0
[ 19.817741] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 19.819602] type=1400 audit(1358499624.723:119): avc: denied { getattr } for pid=1023 comm=“usb_mode_switch” path=“/vendor” dev=“rootfs” ino=8816 scontext=u:r:mode_switch:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_f
[ 19.824068] type=1400 audit(1358499624.726:120): avc: denied { read } for pid=1023 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 19.826898] type=1400 audit(1358499624.736:121): avc: denied { read } for pid=1023 comm=“usb_mode_switch” name=“usb_mode_switch.sh” dev=“mmcblk0p10” ino=463 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 19.831446] type=1400 audit(1358499624.740:122): avc: denied { open } for pid=1023 comm=“usb_mode_switch” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p10” ino=463 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 19.834240] type=1400 audit(1358499624.743:123): avc: denied { getattr } for pid=1035 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 19.837549] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 1034) exited with status 0
[ 19.837964] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 19.838708] type=1400 audit(1358499624.743:124): avc: denied { execute } for pid=1035 comm=“usb_mode_switch” name=“toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 19.841721] type=1400 audit(1358499624.750:125): avc: denied { read open } for pid=1035 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 19.844346] type=1400 audit(1358499624.753:126): avc: denied { execute_no_trans } for pid=1035 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 19.848124] type=1400 audit(1358499624.760:127): avc: denied { getattr } for pid=1035 comm=“getprop” path=“/vendor” dev=“rootfs” ino=8816 scontext=u:r:mode_switch:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_f
[ 19.856735] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1036) exited with status 0
[ 19.857111] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 19.865467] type=1400 audit(1358499624.786:128): avc: denied { getattr } for pid=1023 comm=“usb_mode_switch” path=“/sys/kernel/debug/usb@fe800000/rk_usb_force_mode” dev=“debugfs” ino=2200 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 19.865652] type=1400 audit(1358499624.786:129): avc: denied { dac_override } for pid=1023 comm=“usb_mode_switch” capability=1 scontext=u:r:mode_switch:s0 tcontext=u:r:mode_switch:s0 tclass=capabil
[ 19.865735] type=1400 audit(1358499624.786:130): avc: denied { write } for pid=1023 comm=“usb_mode_switch” name=“rk_usb_force_mode” dev=“debugfs” ino=2200 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 19.865811] type=1400 audit(1358499624.786:131): avc: denied { open } for pid=1023 comm=“usb_mode_switch” path=“/sys/kernel/debug/usb@fe800000/rk_usb_force_mode” dev=“debugfs” ino=2200 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[ 19.877005] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1037) exited with status 0
