求助:rk3399 adb不能使用
我手头有块AIO-3399C(AI)板子,目前按照 http://wiki.t-firefly.com/AIO-3399C/buildroot_compile.html
Buildroot部分的指导,编译出的linux固件不能使用adb调试,请问各位大神是什么原因?
1.PC连接板子的typeC时,串口打印如下:
[root@rk3399:/]# [ 20.493897] phy phy-ff770000.syscon:usb2-phy@e450.7: charger = USB_SDP_CHARGER
2.PC使用公对公usb连接板子的usb3.0时,串口没有任何输出
PC端lsusb也是没有发现相关设备。
diff --git a/arch/arm64/boot/dts/rockchip/rk3399-firefly-aioc-ai.dts b/arch/arm64/boot/dts/rockchip/rk3399-firefly-aioc-ai.dts
index 5983c42..0c14469 100644
--- a/arch/arm64/boot/dts/rockchip/rk3399-firefly-aioc-ai.dts
+++ b/arch/arm64/boot/dts/rockchip/rk3399-firefly-aioc-ai.dts
@@ -42,7 +42,7 @@
 #include <dt-bindings/sensor-dev.h>
-       model = "AIO-3399C Board (Linux Opensource)";
+       model = "AIO-3399C-AI Board (Linux Opensource)";
        compatible = "rockchip,rk3399-firefly", "rockchip,rk3399";
        test-power {
@@ -84,6 +84,20 @@
                regulator-name = "dc_ctl";
                regulator-always-on;
+       vcc_otg_vbus: otg-vbus-regulator {
+               compatible = "regulator-fixed";
+                     gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>;
+                     pinctrl-names = "default";
+                     pinctrl-0 = <&otg_vbus_drv>;
+                     regulator-name = "vcc_otg_vbus";
+                     regulator-min-microvolt = <5000000>;
+                     regulator-max-microvolt = <5000000>;
+                     enable-active-high;
 &gmac {
@@ -212,6 +226,13 @@
+       vbus-usb {
+               otg_vbus_drv: otg-vbus-drv {
+                       rockchip,pins = <1 3 RK_FUNC_GPIO &pcfg_pull_none>;
 &fusb0 {
@@ -224,26 +245,27 @@
 &tcphy0 {
     /delete-property/ extcon;
-    status = "okay";
+    status = "disabled";
 &u2phy0 {
     status = "okay";
     u2phy0_otg: otg-port {
-        rockchip,vbus-always-on;
-        vbus-5v-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>;
-        status = "okay";
+        vbus-supply = <&vcc_otg_vbus>; /*配置Vbus regulator属性 */
+       status = "okay";
 &usbdrd3_0 {
     status = "okay";
-    /delete-property/ extcon;
+    extcon = <&u2phy0>;
 &usbdrd_dwc3_0 {
-    dr_mode = "host";
+    dr_mode = "otg";
+    phys = <&u2phy0_otg>;
+    maximum-speed = "high-speed";
+    phy-names = "usb2-phy";
感谢firefly, 我得到了firefly很好的支持。
打上以上这个patch → kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aioc-ai.dts
typec口就可以用作otg功能了,adb调试也就正常了
确保一下 device/rockchip/ .BoardConfig.mk 的 RK_KERNEL_DTS=rk3399-firefly-aioc-ai 是否正确 重新编译,升级
PS:数据线接typec
