RK3288主板烧写官网上的固件,不断重启!求助!
本人这周刚入手RK3288开发板,烧录官网版本后发现设备重启,我想知道是不是:1.本人下载操作是否有问题?
2.本人设备是否压根就不是3288型号?
[Pre准备工作]
1.烧录版本前设备版本:安卓(具体版本没查阅,当时开机一次后就开始如下烧录过程)
2.固件版本:Firefly-RK3288_Android5.1.1_VGA_HDMI_181010.img(来源于http://www.t-firefly.com/doc/download/page/id/4.html Android 5.1系统 百度云盘路径:public)
3.烧录工具版本:v2.35
[相关日志]
1.烧录工具日志如图所示:
图片目前不会上传…
总之下载没有报错,烧录是loader烧录
2.烧录后设备串口日志:
SRX
Channel a: LPDDR3 200MHz
MR0=0xFFFFFFD8
MR1=0xFFFFFFD8
MR2=0xFFFFFFD8
MR3=0xFFFFFFD8
MR4=0xFFFFFF01
MR5=0xFFFFFF06
MR6=0xFFFFFF04
MR7=0xFFFFFF00
MR8=0xFFFFFF1F
MR9=0xFFFFFF1F
MR10=0xFFFFFF1F
MR11=0xFFFFFF1F
MR12=0xFFFFFF1F
MR13=0xFFFFFF1F
MR14=0xFFFFFF1F
MR15=0xFFFFFF1F
MR16=0xFFFFFF1F
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB
Channel b: LPDDR3 200MHz
MR0=0xFFFFFFFF
MR1=0xFFFFFFFF
MR2=0xFFFFFFFF
MR3=0xFFFFFFFF
MR4=0xFFFFFFFF
MR5=0xFFFFFFFF
MR6=0xFFFFFFFF
MR7=0xFFFFFFFF
MR8=0xFFFFFFFF
MR9=0xFFFFFFFF
MR10=0xFFFFFFFF
MR11=0xFFFFFFFF
MR12=0xFFFFFFFF
MR13=0xFFFFFFFF
MR14=0xFFFFFFFF
MR15=0xFFFFFFFF
MR16=0xFFFFFFFF
U-Boot 2014.10-RK3288-10 (Oct 10 2018 - 17:23:17)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =1 vol=1100000,pwm_value=63
#Boot ver: 2018-10-10#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006ae930)
ramdisk @ 0x05bf0000 (0x002ad1d8)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c4d8 … OK
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #170 SMP PREEMPT Wed Oct 10 17:24:11 CST 2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f27000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-10-10_17:23:17
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1992184k/1992184k available, 104968k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bbbd80 (11984 kB)
[ 0.000000] .init : 0xc0bbc000 - 0xc0c15440 ( 358 kB)
[ 0.000000] .data : 0xc0c16000 - 0xc0da86c0 (1610 kB)
[ 0.000000] .bss : 0xc0da86c0 - 0xc0ecbdbc (1166 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:35
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:21
[ 0.492993] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.493008] pid_max: default: 32768 minimum: 301
[ 0.493126] Security Framework initialized
[ 0.493142] SELinux: Initializing.
[ 0.493214] Mount-cache hash table entries: 512
[ 0.493858] Initializing cgroup subsys debug
[ 0.493872] Initializing cgroup subsys memory
[ 0.493898] Initializing cgroup subsys freezer
[ 0.493927] CPU: Testing write buffer coherency: ok
[ 0.494242] /cpus/cpu@0 missing clock-frequency property
[ 0.494255] /cpus/cpu@1 missing clock-frequency property
[ 0.494264] /cpus/cpu@2 missing clock-frequency property
[ 0.494273] /cpus/cpu@3 missing clock-frequency property
[ 0.494325] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.494376] Setting up static identity map for 0xc0869720 - 0xc0869778
[ 0.497571] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x184a (version 3.1)
[ 0.571144] CPU1: Booted secondary processor
[ 0.571178] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.590815] CPU2: Booted secondary processor
[ 0.590838] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.610531] CPU3: Booted secondary processor
[ 0.610554] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.610655] Brought up 4 CPUs
[ 0.610684] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.610693] CPU: All CPU(s) started in SVC mode.
[ 0.611435] devtmpfs: initialized
[ 0.615829] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.616930] pinctrl core: initialized pinctrl subsystem
[ 0.617177] regulator-dummy: no parameters
[ 0.631471] NET: Registered protocol family 16
[ 0.633313] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.633627] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0ea704c (version 0.1)
[ 0.633895] Registered FIQ tty driver
[ 0.634284] fiq-debugger is disabled in device tree
[ 0.635007] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.635028] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.635046] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.635063] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.635155] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.635219] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.635280] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.635343] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.635404] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.635465] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.635527] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.635589] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.635657] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.635719] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.635732] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.635744] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.635755] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.636393] rockchip_interrupts_register:bank_num=7
[ 0.638289] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.638309] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.638375] rockchip_pinctrl_probe:init ok
[ 0.645494] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.645585] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.645598] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.645768] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.645837] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.645849] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.646017] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.646092] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646105] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.646273] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.646347] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646359] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.646528] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.646604] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646616] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.646786] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.646857] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646869] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.647037] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.647114] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647126] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.648912] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.648924] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.649501] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.649523] DDR DEBUG: version 1.00 20150126
[ 0.649550] DDR DEBUG: Channel a:
[ 0.649558] DDR DEBUG: LPDDR3 Device
[ 0.649605] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.649614] DDR DEBUG: Channel b:
[ 0.649622] DDR DEBUG: LPDDR3 Device
[ 0.649634] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.649643] DDR DEBUG: addr=0xdb2000
[ 0.649653] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.649662] DDR DEBUG: socAddr[0]=0xdb2000, socAddr[1]=0xdb2100
[ 0.649671] DDR DEBUG: chAddr[0]=0xdb2000, chAddr[1]=0xdb2000
[ 0.649682] DDR DEBUG: dtar[0]=0x201b6000, dtar[1]=0x201b6000
[ 0.649737] DDR DEBUG: init success!!! freq=200MHz
[ 0.649745] DDR DEBUG: Channel a:
[ 0.649757] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649770] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649782] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649795] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649806] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.649815] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.649824] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.649831] DDR DEBUG: Channel b:
[ 0.649842] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649855] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649867] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649879] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649890] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.649899] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.649907] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.674148] bio: create slab at 0
[ 0.674637] Rockchip hdmi driver version 2.0
[ 0.674637] .
[ 0.675821] SCSI subsystem initialized
[ 0.675968] usbcore: registered new interface driver usbfs
[ 0.676019] usbcore: registered new interface driver hub
[ 0.676104] usbcore: registered new device driver usb
[ 0.678370] host_en_gpio= -2
[ 0.680813] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.681267] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.681709] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.681954] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.682917] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.683038] media: Linux media interface: v0.10
[ 0.683081] Linux video capture interface: v2.00
[ 0.683137] pps_core: LinuxPPS API ver. 1 registered
[ 0.683147] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.683166] PTP clock support registered
[ 0.683231] i2c-core: driver [bq24296] using legacy suspend method
[ 0.683240] i2c-core: driver [bq24296] using legacy resume method
[ 0.683560] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.684228] ion_drm_heap_create: 0@0
[ 0.684353] Rockchip ion module is successfully loaded (v1.1)
[ 0.684511] Advanced Linux Sound Architecture Driver Initialized.
[ 0.684944] Bluetooth: Core ver 2.16
[ 0.685002] NET: Registered protocol family 31
[ 0.685012] Bluetooth: HCI device and connection manager initialized
[ 0.685029] Bluetooth: HCI socket layer initialized
[ 0.685042] Bluetooth: L2CAP socket layer initialized
[ 0.685068] Bluetooth: SCO socket layer initialized
[ 0.685292] cfg80211: Calling CRDA to update world regulatory domain
[ 0.685980] act8846_i2c_probe,line=898
[ 0.687421] act8846 set 0xf4 error!
[ 0.687502] act8846: probe of 0-005a failed with error -11
[ 0.688251] The device is not syr82x fffffff5
[ 0.688268] syr82x: probe of 0-0040 failed with error -11
[ 0.688970] The device is not syr82x fffffff5
[ 0.688985] syr82x: probe of 0-0041 failed with error -11
[ 0.689461] rk808_i2c_probe,line=1355
[ 0.689962] rk808_pre_init,line=1224
[ 0.700092] rk808_i2c_probe: rk808_pmic_sleep=0
[ 0.706391] vdd_arm: 712 ↔ 1500 mV at 937 mV
[ 0.713184] vdd_gpu: 712 ↔ 1500 mV at 900 mV
[ 0.719622] rk_dcdc3: 1200 mV
[ 0.726370] vccio: 1800 ↔ 3300 mV at 3300 mV
[ 0.732812] rk_ldo1: 3300 mV
[ 0.739252] rk_ldo2: 3300 mV
[ 0.745675] rk_ldo3: 1000 mV
[ 0.752105] rk_ldo4: 1800 mV
[ 0.758537] rk_ldo5: 3300 mV
[ 0.764982] rk_ldo6: 1800 mV
[ 0.770215] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.771501] rk_ldo7: 1800 mV
[ 0.777932] rk_ldo8: 3300 mV
[ 0.781218] rk_ldo9: at 3300 mV
[ 0.784492] rk_ldo10: at 3300 mV
[ 0.787229] rk808_irq_init: rk808_pmic_irq=1
[ 0.787579] i2c-core: driver [rk818] using legacy suspend method
[ 0.787590] i2c-core: driver [rk818] using legacy resume method
[ 0.787949] rk808_rtc_probe,line=540
[ 0.804826] rk808-rtc rk808-rtc: rtc core: registered rk808 as rtc0
[ 0.808314] rk808_rtc_probe:ok
[ 0.809848] Switching to clocksource arch_sys_counter
[ 0.833362] rga: Module initialized.
[ 0.834072] rga2 ff920000.rga: rga ion client create success!
[ 0.834246] rga: Driver loaded succesfully
[ 0.834438] fb disp policy is box
[ 0.834480] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.834492] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.834826] rk-screen rk_screen.8: rockchip screen probe success
[ 0.835078] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.835455] rk32-edp ff970000.edp: screen is not edp!
[ 0.835476] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.835950] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.836170] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.836472] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.836644] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.836818] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.837550] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 0.837566] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.868403] alloc_buffer:ion_phy_addr=0x10000000
[ 0.881107] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.894718] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa7000
[ 0.894764] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.894975] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.894988] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.895257] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.895587] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.895758] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.895930] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.896747] unknow screen type: 0
[ 0.896766] vop ver:a050a01,unsupport output color:1
[ 0.896827] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 0.896840] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.900734] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.900749] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.901641] rockchip_set_mux:warning ignore bank num 15
[ 0.901775] rockchip_set_mux:warning ignore bank num 15
[ 0.901895] rockchip_set_mux:warning ignore bank num 15
[ 0.902013] rockchip_set_mux:warning ignore bank num 15
[ 0.902143] rockchip_set_mux:warning ignore bank num 15
[ 0.902264] rockchip_set_mux:warning ignore bank num 15
[ 0.903232] rockchip_set_mux:warning ignore bank num 15
[ 0.903401] rockchip_set_mux:warning ignore bank num 15
[ 0.904349] rockchip_set_mux:warning ignore bank num 15
[ 0.904518] rockchip_set_mux:warning ignore bank num 15
[ 0.905433] rockchip_set_mux:warning ignore bank num 15
[ 0.905594] rockchip_set_mux:warning ignore bank num 15
[ 0.906510] rockchip_set_mux:warning ignore bank num 15
[ 0.906657] rockchip_set_mux:warning ignore bank num 15
[ 0.908163] NET: Registered protocol family 2
[ 0.908858] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.908956] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.909030] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.909087] TCP: reno registered
[ 0.909102] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.909126] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.909320] NET: Registered protocol family 1
[ 0.909919] Unpacking initramfs…
[ 1.044195] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[ 1.045031] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.045594] vcodec_service: probe device ff9a0000.vpu_service
[ 1.045802] vcodec_service: No reset resource define
[ 1.045974] vcodec_service: ff9a0000.vpu_service: power on
[ 1.046132] vcodec_service: probe device ff9a0000.vpu_service
[ 1.046149] vcodec_service: checking hw id 4831
[ 1.047110] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.047153] vcodec_service: done
[ 1.047178] vcodec_service: init success
[ 1.047240] vcodec_service: probe device ff9c0000.hevc_service
[ 1.047576] vcodec_service: ff9c0000.hevc_service: power on
[ 1.047653] vcodec_service: probe device ff9c0000.hevc_service
[ 1.047668] vcodec_service: checking hw id 6867
[ 1.048220] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.048262] vcodec_service: done
[ 1.048270] vcodec_service: init success
[ 1.048425] rknandbase v1.0 2014-03-31
[ 1.048559] rknand: probe of ff400000.nandc failed with error -1
[ 1.048667] rknand_driver:ret = 0
[ 1.050601] audit: initializing netlink socket (disabled)
[ 1.050645] type=2000 audit(0.560:1): initialized
[ 1.051436] bounce pool size: 64 pages
[ 1.056180] fuse init (API version 7.22)
[ 1.056589] msgmni has been set to 952
[ 1.058434] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.058448] io scheduler noop registered
[ 1.058457] io scheduler deadline registered
[ 1.058575] io scheduler cfq registered (default)
[ 1.059787] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.060477] IEP Driver loaded succesfully
[ 1.060566] Module initialized.
[ 1.061377] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.061395] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.062697] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.062714] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.063001] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.063023] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.063046] pwm_regulator_probe:error
[ 1.063067] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.063271] rk_serial.c v1.8 2014-03-04
[ 1.063506] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.063704] serial ff180000.serial: membase e0972000
[ 1.063863] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.064034] serial ff190000.serial: membase e097e000
[ 1.064191] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.065879] console [ttyS2] enabled
[ 1.066109] serial ff690000.serial: membase fed60000
[ 1.066292] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.066490] serial ff1b0000.serial: membase e41be000
[ 1.069373] loop: module loaded
[ 1.069740] zram: Created 1 device(s) …
[ 1.069842] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.069855] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.069873] mpu_init: Probe name mpu6050B1
[ 1.070028] ak8963_mod_init: Probe name ak8963_mod
[ 1.070717] SCSI Media Changer driver v0.25
[ 1.071014] dws->regs: e41e2000
[ 1.072443] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 1.072710] tun: Universal TUN/TAP device driver, 1.6
[ 1.072723] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.072853] vmac_init.
[ 1.073417] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.073433] stmmac_probe_config_dt: clock input/output? (input).
[ 1.073447] stmmac_probe_config_dt: TX delay(0x1d).
[ 1.073459] stmmac_probe_config_dt: RX delay(0x16).
[ 1.073509] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.073520] stmmc_pltfr_init:
[ 1.073529] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.073552] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.073564] stmmc_pltfr_init: init for RGMII
[ 1.073574] tx delay=0x1d
[ 1.073574] rx delay=0x16
[ 1.073590] tx delay=0x1d
[ 1.073590] rx delay=0x16
[ 1.074059] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.074070] Normal descriptors
[ 1.074079] Ring mode enabled
[ 1.074090] DMA HW capability register supported
[ 1.074101] RX Checksum Offload Engine supported (type 2)
[ 1.074111] TX Checksum insertion supported
[ 1.074121] Wake-Up On Lan supported
[ 1.074156] Enable RX Mitigation via HW Watchdog Timer
[ 1.074596] PPP generic driver version 2.4.2
[ 1.074751] PPP BSD Compression module registered
[ 1.074763] PPP Deflate Compression module registered
[ 1.074788] PPP MPPE Compression module registered
[ 1.074801] NET: Registered protocol family 24
[ 1.074839] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.074853] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.074865] Rockchip WiFi SYS interface (V1.00) …
[ 1.074899] esp_mem_init enter date Apr 18 2018 10:10:02
[ 1.074910] esp_mem_init VERSION [V2.5]
[ 1.074953] esp_mem_init complete
[ 1.075037] usbcore: registered new interface driver catc
[ 1.075077] usbcore: registered new interface driver kaweth
[ 1.075090] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.075130] usbcore: registered new interface driver pegasus
[ 1.075170] usbcore: registered new interface driver rtl8150
[ 1.075210] usbcore: registered new interface driver r8152
[ 1.075221] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.075293] usbcore: registered new interface driver hso
[ 1.075339] usbcore: registered new interface driver asix
[ 1.075378] usbcore: registered new interface driver ax88179_178a
[ 1.075417] usbcore: registered new interface driver cdc_ether
[ 1.075455] usbcore: registered new interface driver cdc_eem
[ 1.075492] usbcore: registered new interface driver dm9601
[ 1.075530] usbcore: registered new interface driver dm9620
[ 1.075614] usbcore: registered new interface driver smsc75xx
[ 1.075665] usbcore: registered new interface driver smsc95xx
[ 1.075706] usbcore: registered new interface driver gl620a
[ 1.075751] usbcore: registered new interface driver net1080
[ 1.075791] usbcore: registered new interface driver plusb
[ 1.075832] usbcore: registered new interface driver rndis_host
[ 1.075878] usbcore: registered new interface driver cdc_subset
[ 1.075916] usbcore: registered new interface driver zaurus
[ 1.075958] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.076019] usbcore: registered new interface driver int51x1
[ 1.076060] usbcore: registered new interface driver kalmia
[ 1.076099] usbcore: registered new interface driver ipheth
[ 1.076142] usbcore: registered new interface driver sierra_net
[ 1.076188] usbcore: registered new interface driver cx82310_eth
[ 1.076235] usbcore: registered new interface driver cdc_ncm
[ 1.076276] usbcore: registered new interface driver qmi_wwan
[ 1.076316] usbcore: registered new interface driver cdc_mbim
[ 1.076329] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.078781] EHCI: ehci_rk_probe e4240000 e4240010
[ 1.078800] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.078830] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.079174] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.095289] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.095376] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.095392] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.095407] usb usb1: Product: EHCI Host Controller
[ 1.095420] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.095434] usb usb1: SerialNumber: ff500000.usb
[ 1.095884] hub 1-0:1.0: USB hub found
[ 1.095910] hub 1-0:1.0: 1 port detected
[ 1.096082] EHCI: ehci_rk_probe ok
[ 1.096192] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.096452] ohci-rockchip ff520000.usb: RK OHCI Host Controller
[ 1.096485] ohci-rockchip ff520000.usb: new USB bus registered, assigned bus number 2
[ 1.096527] ohci-rockchip ff520000.usb: irq 73, io mem 0xff520000
[ 1.158316] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.158334] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.158349] usb usb2: Product: RK OHCI Host Controller
[ 1.158362] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.158375] usb usb2: SerialNumber: ff520000.usb
[ 1.158764] hub 2-0:1.0: USB hub found
[ 1.158787] hub 2-0:1.0: 1 port detected
[ 1.159112] usbcore: registered new interface driver cdc_acm
[ 1.159125] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.159185] usbcore: registered new interface driver usblp
[ 1.159230] usbcore: registered new interface driver cdc_wdm
[ 1.159306] usbcore: registered new interface driver usb-storage
[ 1.159349] usbcore: registered new interface driver ums-alauda
[ 1.159390] usbcore: registered new interface driver ums-cypress
[ 1.159433] usbcore: registered new interface driver ums-datafab
[ 1.159473] usbcore: registered new interface driver ums_eneub6250
[ 1.159513] usbcore: registered new interface driver ums-freecom
[ 1.159554] usbcore: registered new interface driver ums-isd200
[ 1.159595] usbcore: registered new interface driver ums-jumpshot
[ 1.159636] usbcore: registered new interface driver ums-karma
[ 1.159681] usbcore: registered new interface driver ums-onetouch
[ 1.159725] usbcore: registered new interface driver ums-sddr09
[ 1.159767] usbcore: registered new interface driver ums-sddr55
[ 1.159812] usbcore: registered new interface driver ums-usbat
[ 1.159904] usbcore: registered new interface driver usbserial
[ 1.159947] usbcore: registered new interface driver usbserial_generic
[ 1.159982] usbserial: USB Serial support registered for generic
[ 1.160026] usbcore: registered new interface driver ch341
[ 1.160064] usbserial: USB Serial support registered for ch341-uart
[ 1.160110] usbcore: registered new interface driver cp210x
[ 1.160142] usbserial: USB Serial support registered for cp210x
[ 1.160197] usbcore: registered new interface driver option
[ 1.160229] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.160364] usbcore: registered new interface driver pl2303
[ 1.160397] usbserial: USB Serial support registered for pl2303
[ 1.160448] usbcore: registered new interface driver trancevibrator
[ 1.160461] usb20_otg: version 3.10a 21-DEC-2012
[ 1.160902] e4300040
[ 1.160917] Core Release: 3.10a
[ 1.160933] Setting default values for core params
[ 1.161080] Using Buffer DMA mode
[ 1.161092] Periodic Transfer Interrupt Enhancement - disabled
[ 1.161103] Multiprocessor Interrupt Enhancement - disabled
[ 1.161115] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.161125] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.161144] Dedicated Tx FIFOs mode
[ 1.161164] pcd_init otg_dev = ddf0dec0
[ 1.161334] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.161363] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
[ 1.161398] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.161456] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.161473] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.161487] usb usb3: Product: DWC OTG Controller
[ 1.161501] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.161514] usb usb3: SerialNumber: ff580000.usb
[ 1.161933] hub 3-0:1.0: USB hub found
[ 1.161958] hub 3-0:1.0: 1 port detected
[ 1.162253] usb20_host: version 3.10a 21-DEC-2012
[ 1.164782] e4380040
[ 1.164796] Core Release: 3.10a
[ 1.164807] Setting default values for core params
[ 1.164908] Using Buffer DMA mode
[ 1.164919] Periodic Transfer Interrupt Enhancement - disabled
[ 1.164930] Multiprocessor Interrupt Enhancement - disabled
[ 1.164941] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.164951] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.164975] usb20_host ff540000.usb: DWC OTG Controller
[ 1.165019] usb20_host ff540000.usb: new USB bus registered, assigned bus number 4
[ 1.165050] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.165142] Init: Power Port (0)
[ 1.165197] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.165214] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.165228] usb usb4: Product: DWC OTG Controller
[ 1.165240] usb usb4: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.165253] usb usb4: SerialNumber: ff540000.usb
[ 1.165648] hub 4-0:1.0: USB hub found
[ 1.165675] hub 4-0:1.0: 1 port detected
[ 1.166379] usbcore: registered new interface driver xpad
[ 1.166439] usbcore: registered new interface driver usb_acecad
[ 1.166488] usbcore: registered new interface driver aiptek
[ 1.166540] usbcore: registered new interface driver gtco
[ 1.166592] usbcore: registered new interface driver hanwang
[ 1.166639] usbcore: registered new interface driver kbtab
[ 1.166694] usbcore: registered new interface driver wacom
[ 1.166705] ==gsl_ts_init==
[ 1.166775] ret=0
[ 1.167033] sensor_register_slave:mma8452,id=17
[ 1.167047] sensor_register_slave:gs_mc3230,id=23
[ 1.167057] gsensor_init
[ 1.167067] sensor_register_slave:mpu6880_acc,id=24
[ 1.167078] sensor_register_slave:mpu6500_acc,id=25
[ 1.167089] sensor_register_slave:cm3217,id=48
[ 1.167099] sensor_register_slave:cm3218,id=49
[ 1.167315] .. rk pwm remotectl v1.1 init
[ 1.167554] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.170927] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.181594] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc1
[ 1.183257] i2c /dev entries driver
[ 1.184011] IR NEC protocol handler initialized
[ 1.184025] IR RC5(x) protocol handler initialized
[ 1.184035] IR RC6 protocol handler initialized
[ 1.184046] IR JVC protocol handler initialized
[ 1.184055] IR Sony protocol handler initialized
[ 1.184065] IR RC5 (streamzap) protocol handler initialized
[ 1.184075] IR SANYO protocol handler initialized
[ 1.184084] IR MCE Keyboard/mouse protocol handler initialized
[ 1.184244] usbcore: registered new interface driver uvcvideo
[ 1.184263] USB Video Class driver (1.1.1)
[ 1.184289] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.185745] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.185769] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.185790] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.185812] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.185853] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.185853]
[ 1.185927] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.186077] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 1.186755] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.186773] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 1.186790] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1df8f000 vir: 0xddf8f000 size: 0x1000)
[ 1.186806] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.186818] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.187236] not find test_power_init dev node
[ 1.187293] i2c-core: driver [bq27320] using legacy suspend method
[ 1.187306] i2c-core: driver [bq27320] using legacy resume method
[ 1.187663] rockchip_temp_probe,line=364
[ 1.242880] tsadc ff280000.tsadc: initialized
[ 1.243277] device-mapper: uevent: version 1.0.3
[ 1.243525] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.243817] Bluetooth: HCI UART driver ver 2.2
[ 1.243833] Bluetooth: HCI H4 protocol initialized
[ 1.243844] Bluetooth: HCILL protocol initialized
[ 1.243856] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.243868] rtk_btusb: Register usb char device interface for BT driver
[ 1.244056] usbcore: registered new interface driver rtk_btusb
[ 1.244120] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.245106] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.253640] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.253845] cpuidle: using governor ladder
[ 1.253857] cpuidle: using governor menu
[ 1.253894] Synopsys Designware Multimedia Card Interface Driver
[ 1.253905] MHSC version = Ver 2.00 2015-06-10
[ 1.254213] dw cru_regsbase addr 0x1d8.
[ 1.254226] dw cru_reset_offset val 3.
[ 1.254240] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.254284] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.254608] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.254765] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.254893] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.272402] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.292108] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.292145] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.292164] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.292459] dw cru_regsbase addr 0x1d8.
[ 1.292472] dw cru_reset_offset val 0.
[ 1.292486] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.292539] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.293255] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.293415] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.293533] mmc1: no vmmc regulator found
[ 1.293663] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.293770] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.311759] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.324229] mmc0: BKOPS_EN bit is not set
[ 1.326099] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.328377] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.328399] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.328418] [mmc0] tuning regsbase addr 0x218.
[ 1.329016] [mmc0] Data transmission error !!! MINTSTS: [0x00002004]
[ 1.329025] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.329046] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002004)
[ 1.329071] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.329095] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.329103] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.329131] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.329153] [mmc0] Data transmission error !!! MINTSTS: [0x00002046]
[ 1.329161] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.329190] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.329292] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-214 (20 len)
[ 1.329312] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 259-282 (3 len)
[ 1.329330] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-214 (20 len)
[ 1.329340] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 113
[ 1.329383] mmc0: new HS200 MMC card at address 0001
[ 1.329656] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 1.329760] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB
[ 1.330070] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.330082] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.330092] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.330100] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.330109] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.330117] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.330125] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.330133] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.330141] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.330150] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.330158] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.330166] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.330175] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.330183] userdata: 0x077800000 – 0x1d1c00000 (5540 MB)
[ 1.330212] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 1.331507] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.331521] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.331854] dw cru_regsbase addr 0x1d8.
[ 1.331863] dw cru_reset_offset val 1.
[ 1.331872] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.331910] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.332134] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.332262] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.332515] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.351120] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.370813] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.370824] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.370831] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.371097] leds-gpio leds.29: pins are not configured from the driver
[ 1.371315] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.372761] usbcore: registered new interface driver usbhid
[ 1.372770] usbhid: USB HID core driver
[ 1.372877] ashmem: initialized
[ 1.372998] logger: created 256K log ‘log_main’
[ 1.373094] logger: created 256K log ‘log_events’
[ 1.373185] logger: created 256K log ‘log_radio’
[ 1.373282] logger: created 256K log ‘log_system’
[ 1.374411] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
[ 1.375295] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.375312] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.375323] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.375335] ES8323 2-0010: Error applying setting, reverse things back
[ 1.375384] es8323_adc = 0
[ 1.375396] jp es8323_line_det_gpio:-1
[ 1.376074] es8323 probe error
[ 1.376091] ES8323: probe of 2-0010 failed with error -11
[ 1.376826] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.377361] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 1.377395] rockchip_es8323_audio_probe() register card failed:-517
[ 1.377410] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 1.377578] u32 classifier
[ 1.377586] Actions configured
[ 1.377598] Netfilter messages via NETLINK v0.30.
[ 1.377657] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.378000] ctnetlink v0.93: registering with nfnetlink.
[ 1.378089] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.378099] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.378378] xt_time: kernel timezone is -0000
[ 1.378606] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.378740] arp_tables: (C) 2002 David S. Miller
[ 1.378779] TCP: cubic registered
[ 1.378786] Initializing XFRM netlink socket
[ 1.379002] NET: Registered protocol family 10
[ 1.379577] mip6: Mobile IPv6
[ 1.379607] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.379725] sit: IPv6 over IPv4 tunneling driver
[ 1.380065] NET: Registered protocol family 17
[ 1.380091] NET: Registered protocol family 15
[ 1.380142] Bridge firewalling registered
[ 1.380155] Ebtables v2.0 registered
[ 1.380319] Bluetooth: RFCOMM TTY layer initialized
[ 1.380346] Bluetooth: RFCOMM socket layer initialized
[ 1.380354] Bluetooth: RFCOMM ver 1.11
[ 1.380362] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.380369] Bluetooth: BNEP filters: protocol multicast
[ 1.380381] Bluetooth: BNEP socket layer initialized
[ 1.380389] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.380401] Bluetooth: HIDP socket layer initialized
[ 1.380430] l2tp_core: L2TP core driver, V2.0
[ 1.380444] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.380452] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.380679] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.380691] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.380701] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.380711] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.380720] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.380730] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.380752] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.380775] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.380784] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.380810] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.380819] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.380862] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.381019] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.381038] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 1.381054] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.381069] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.381085] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.381133] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.381232] [BT_RFKILL]: ** disable irq
[ 1.381316] [BT_RFKILL]: ap6335 device registered.
[ 1.382172] rk3288_init_suspend
[ 1.382185] rk3288_suspend_init enter
[ 1.382391] rk3288_suspend_init: pm_ctrbits =200007
[ 1.382422] gpio_get_dts_info suspend:4
[ 1.382431] gpio_get_dts_info resume:4
[ 1.382437] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.382470] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.382627] clks_gating_suspend_init:clkgt info ok
[ 1.382724] Registering SWP/SWPB emulation handler
[ 1.382737] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.385573] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.386018] ddrfreq: verion 1.2 20140526
[ 1.386034] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.386043] ddrfreq: auto-freq=0
[ 1.386050] ddrfreq: auto-freq-table[0] 240MHz
[ 1.386057] ddrfreq: auto-freq-table[1] 324MHz
[ 1.386064] ddrfreq: auto-freq-table[2] 456MHz
[ 1.386071] ddrfreq: auto-freq-table[3] 528MHz
[ 1.386702] Unable to handle kernel paging request at virtual address fffffe2b
[ 5.130191] EHCI: rk_ehci_hcd_enable, disable host controller
[ 5.135873] pgd = c0004000
[ 5.138499] [fffffe2b] *pgd=1eff6821, *pte=00000000, *ppte=00000000
[ 5.144631] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 5.149913] Modules linked in:
[ 5.152902] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #170
[ 5.158868] task: de890000 ti: de872000 task.ti: de872000
[ 5.164169] PC is at regulator_set_voltage+0x8/0xe0
[ 5.168937] LR is at vga_edid_probe+0x4c/0x380
[ 5.173282] pc : [] lr : [] psr: a0000113
[ 5.173282] sp : de873e38 ip : 00000000 fp : 00000000
[ 5.184535] r10: c0bbc5f0 r9 : c0c1119c r8 : c02dfb68
[ 5.189653] r7 : c1f17c88 r6 : de004e00 r5 : 00000000 r4 : fffffdfb
[ 5.196049] r3 : 00000000 r2 : 001b7740 r1 : 001b7740 r0 : fffffdfb
[ 5.202447] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 5.209609] Control: 10c5387d Table: 0000406a DAC: 00000015
[ 5.215236]
[ 5.215236] PC: 0xc02eb8b4:
[ 5.219412] b8b4 e3530000 1a000002 e5962018 e3520000 0a000013 e58d3000 e1a00004 e5963018
[ 5.227429] b8d4 e1a0100d e28d2004 e58d3004 ebfffa2a e2506000 ba00000b e1a00004 e1a0100d
[ 5.235445] b8f4 e28d2004 ebffffb9 e2506000 ba000005 e1a00004 e89d0006 ebfffc02 e1a06000
[ 5.243461] b914 ea000000 e3e06015 e1a00005 eb15edc4 e1a00006 e8bd807c e92d45f7 e1a04000
[ 5.251477] b934 e5905030 e58d2000 e2856038 e58d1004 e1a00006 eb15ee51 e5942014 e59d3004
[ 5.259494] b954 e1520003 1a000004 e5942018 e59d3000 e1520003 03a0a000 0a000022 e5953000
[ 5.267510] b974 e5933014 e5932004 e3520000 1a000003 e593300c e3530000 03e0a015 0a000019
[ 5.275526] b994 e1a00005 e28d1004 e1a0200d ebfff9fa e250a000 ba000013 e59d3004 e1a00005
[ 5.283544]
[ 5.283544] LR: 0xc02dfb34:
[ 5.287721] fb34 e1a01005 e1a03000 e3a00004 ebf5c1d4 ea000001 e59f0014 eb15b419 e1a00004
[ 5.295738] fb54 e8bd81f0 c0e83fac c02dff78 c004f938 c0a966c4 e92d41ff e1a06000 e590715c
[ 5.303754] fb74 e5900018 e5903008 e5933008 e12fff33 e3100001 03e05012 0a0000b0 e3a00000
[ 5.311770] fb94 e59f12c4 eb002da4 e2504000 059f02bc 0a000007 e59f12b8 e1a02001 eb002f5d
[ 5.319787] fbb4 e1a00004 eb003058 e3500000 159f02a4 059f02a4 e59f12a4 eb15b3f9 e3a00000
[ 5.327803] fbd4 e59f129c eb002d94 e2504000 059f0294 0a000007 e59f1290 e1a02001 eb002f4d
[ 5.335819] fbf4 e1a00004 eb003048 e3500000 159f027c 059f027c e59f1264 eb15b3e9 e3a00000
[ 5.343836] fc14 e59f1270 eb002d84 e2504000 059f0268 0a000007 e59f1264 e1a02001 eb002f3d
[ 5.351853]
[ 5.351853] SP: 0xde873db8:
[ 5.356031] 3db8 c0285044 c0e8bc4c 00000000 00000001 c0e8bc64 00000000 000003e0 00000000
[ 5.364047] 3dd8 00000020 c02eb934 a0000113 ffffffff de873e24 c000d598 fffffdfb 001b7740
[ 5.372064] 3df8 001b7740 00000000 fffffdfb 00000000 de004e00 c1f17c88 c02dfb68 c0c1119c
[ 5.380080] 3e18 c0bbc5f0 00000000 00000000 de873e38 c02dfbb4 c02eb934 a0000113 ffffffff
[ 5.388096] 3e38 fffffdfb 001b7740 001b7740 fffffdfb 00000000 de004e00 c1f17c88 c02dfb68
[ 5.396112] 3e58 c0bbc5f0 c02dfbb4 de004e00 00000000 00000065 00000000 de004e20 00000000
[ 5.404129] 3e78 de004e04 de004e00 c02dfb68 c0534128 00000000 de004e20 00000000 c0c53dc0
[ 5.412145] 3e98 c0da9000 c030ae80 de004e20 c0c53dc0 c0c53dc0 00000000 c0da9000 c030b0dc
[ 5.420162]
[ 5.420162] R0: 0xfffffd7b:
[ 5.424340] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.432356] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.440373] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.448389] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.456405] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.464422] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.472438] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.480454] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.488470] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.496488]
[ 5.496488] R4: 0xfffffd7b:
[ 5.500666] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.508682] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.516698] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.524715] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.532731] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.540747] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.548763] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.556780] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.564796] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.572814]
[ 5.572814] R6: 0xde004d80:
[ 5.576991] 4d80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.585007] 4da0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.593024] 4dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.601040] 4de0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.609057] 4e00 00500000 5f616776 00636464 00000000 00000000 00000000 de010858 c0c53d9c
[ 5.617073] 4e20 de010880 deb5ef00 deb65140 de00500c de004c2c de010888 de981340 c0cd8ac8
[ 5.625089] 4e40 deb65100 00000003 00000007 00000000 c0d2f868 00000000 00000000 de004e5c
[ 5.633106] 4e60 de004e5c de890000 00000000 c0d2f8b0 c0c53dc0 00000000 00000000 00000020
[ 5.641123]
[ 5.641123] R7: 0xc1f17c08:
[ 5.645300] 7c08 00000000 00000000 c5618865 00000004 c561408c c1f17c44 00000000 00000000
[ 5.653317] 7c28 c5618865 00000124 00000004 00000000 c0609d78 00000000 00000000 c0aef59b
[ 5.661333] 7c48 0000000d c1f17c78 00000000 00000000 00000000 c0aef59b 00000124 0000000d
[ 5.669350] 7c68 00000000 c0609d78 00000000 00000000 30316b72 635f3030 6365646f 00000000
[ 5.677366] 7c88 c1f17e68 c0afb97a 00000000 c1f17ce0 c1f17cfc 00000000 c1f1740c 00000000
[ 5.685382] 7ca8 00000000 00000000 c1f17e70 dea74b80 c1f17ea0 c1f17a90 c1f17438 dea1b840
[ 5.693398] 7cc8 c0d7f44c dea74c00 00000001 00000003 00000008 00000000 6332692f 31666640
[ 5.701415] 7ce8 30303036 67762f30 64645f61 30354063 00000000 c561874b 00000010 c56140b0
[ 5.709432]
[ 5.709432] R8: 0xc02dfae8:
[ 5.713610] fae8 e3a02000 e5843004 e2840010 e5843008 e3a01002 e59f3058 e584300c e1a03002
[ 5.721626] fb08 ebf59242 e59f304c e5844024 e1a00008 e584504c e5843020 e5847050 e5846054
[ 5.729642] fb28 e5955030 ebf57506 e1a02004 e1a01005 e1a03000 e3a00004 ebf5c1d4 ea000001
[ 5.737659] fb48 e59f0014 eb15b419 e1a00004 e8bd81f0 c0e83fac c02dff78 c004f938 c0a966c4
[ 5.745675] fb68 e92d41ff e1a06000 e590715c e5900018 e5903008 e5933008 e12fff33 e3100001
[ 5.753691] fb88 03e05012 0a0000b0 e3a00000 e59f12c4 eb002da4 e2504000 059f02bc 0a000007
[ 5.761708] fba8 e59f12b8 e1a02001 eb002f5d e1a00004 eb003058 e3500000 159f02a4 059f02a4
[ 5.769724] fbc8 e59f12a4 eb15b3f9 e3a00000 e59f129c eb002d94 e2504000 059f0294 0a000007
[ 5.777741]
[ 5.777741] R9: 0xc0c1111c:
[ 5.781919] 111c c0be8958 c0be8968 c0be8978 c0be8988 c0be8998 c0be89a8 c0be89b8 c0be89c8
[ 5.789935] 113c c0be89d8 c0be89e8 c0be89f8 c0be8a08 c0be8a18 c0be8a28 c0bbe764 c0bbfee0
[ 5.797951] 115c c0bc32ac c0bc3498 c0029198 c0bc57f0 c00367c4 c0bc5ffc c0bc80f0 c0bc972c
[ 5.805968] 117c c0bc978c c0bc98b0 c0bc9914 c0bcb9f4 c0bcdd78 c0bd18a0 c0be16d4 c0be2644
[ 5.813984] 119c c0be2654 c0be2888 c030ac04 c0be5d1c c03b04cc c0409b00 c0466630 c0be767c
[ 5.822001] 11bc c0be7b5c c0be7c08 c0bec6d8 c0bec8d8 c0bee638 c0befe94 c0bf31d4 c0bf3258
[ 5.830017] 11dc c0bf5940 c0be3a20 c061b580 c0bef42c c0befeb8 c0bf0138 c0bddba4 37303730
[ 5.838033] 11fc 30303130 32303030 30303144 31343030 30304445 30303030 30303030 30303030
[ 5.846050]
[ 5.846050] R10: 0xc0bbc570:
[ 5.850313] c570 e5941000 ebd25fb5 e3500000 1a000009 e1a00005 e59f1058 ebdb11cd e3500000
[ 5.858330] c590 1a00000c e5940000 e59f1048 ebdb11c8 e3500000 1a000007 e5943004 e1a00007
[ 5.866346] c5b0 e12fff33 e3500000 0a000002 e59f0028 e1a01005 ebf2417b e284400c e1540006
[ 5.874363] c5d0 3affffe2 e3a00000 e8bd80f8 c0c0fe80 c0c10390 c0a5f2f0 c0a5f173 c0a5f17c
[ 5.882379] c5f0 e92d4038 e2515000 e1a04000 0a000014 ebdb11ec e2803001 e0843003 e1550003
[ 5.890395] c610 03a0303d 05453001 0a00000d e2800002 e0844000 e1550004 1a000008 e3a0303d
[ 5.898411] c630 e1a00005 e5453002 ebdb11de e1a01005 e2802001 e2450001 ebdaf0c0 ea000000
[ 5.906428] c650 e7f001f2 e3a00000 e8bd8038 e92d45f8 e1a04000 e1a06001 ebffffe0 e1a00004
[ 5.914448] Process swapper/0 (pid: 1, stack limit = 0xde872238)
[ 5.920332] Stack: (0xde873e38 to 0xde874000)
[ 5.924597] 3e20: fffffdfb 001b7740
[ 5.932617] 3e40: 001b7740 fffffdfb 00000000 de004e00 c1f17c88 c02dfb68 c0bbc5f0 c02dfbb4
[ 5.940633] 3e60: de004e00 00000000 00000065 00000000 de004e20 00000000 de004e04 de004e00
[ 5.948649] 3e80: c02dfb68 c0534128 00000000 de004e20 00000000 c0c53dc0 c0da9000 c030ae80
[ 5.956666] 3ea0: de004e20 c0c53dc0 c0c53dc0 00000000 c0da9000 c030b0dc 00000000 de004e20
[ 5.964682] 3ec0: de004e54 c030b154 c0c53dc0 de873ed8 c030b0f4 c030991c de9d755c deb5ef34
[ 5.972699] 3ee0: c0c53dc0 c0c53dc0 c580d380 c0d2f8b0 00000000 c030a6d0 c0a9684e c0a9684f
[ 5.980715] 3f00: c0c53dc0 c0be2644 de872000 00000000 c0da9000 c030b640 c0d2f8b0 c0c53d9c
[ 5.988731] 3f20: c0be2644 de872000 00000000 c0da9000 c0bbc5f0 c0535e64 00000000 00000007
[ 5.996747] 3f40: c0be2644 c00086a4 c0be2644 00000004 00000007 c0c09e94 c0c09e74 c0da9000
[ 6.004763] 3f60: 00000202 c0bbcb28 00000007 00000007 c0bbc5f0 00000000 c0c103dc c0c103dc
[ 6.012779] 3f80: 00000000 00000000 00000000 00000000 00000000 c0bbcbe8 de872000 00000000
[ 6.020795] 3fa0: c0846818 c0846820 00000000 c000da98 00000000 00000000 00000000 00000000
[ 6.028811] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.036828] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
[ 6.044866] [] (regulator_set_voltage+0x8/0xe0) from [] (vga_edid_probe+0x4c/0x380)
[ 6.054067] [] (vga_edid_probe+0x4c/0x380) from [] (i2c_device_probe+0xa8/0xd4)
[ 6.062935] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c)
[ 6.071629] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 6.080580] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 6.089706] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 6.098576] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 6.107444] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 6.116314] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac)
[ 6.125528] [] (i2c_register_driver+0x40/0xac) from [] (do_one_initcall+0x34/0xc8)
[ 6.134654] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 6.143178] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 6.152221] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 6.161090] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 6.169269] Code: e1a00006 e8bd807c e92d45f7 e1a04000 (e5905030)
[ 6.175316] —[ end trace 9dc5b16a85c82e8a ]—
[ 6.179806] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 6.179806]
[ 6.188730] CPU0: stopping
[ 6.191374] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 3.10.0 #170
[ 6.198293] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 6.206643] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 6.214743] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 6.223186] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 6.231367] Exception stack(0xc0c17f08 to 0xc0c17f50)
[ 6.236316] 7f00: c0c17f50 00000005 58e3eaf7 00000001 c1f292e0 00000000
[ 6.244333] 7f20: 58d8f717 00000001 c0c28fd8 c0c16000 c0c28fe8 00000000 00000000 c0c17f50
[ 6.252347] 7f40: c00798fc c05c4d78 60000113 ffffffff
[ 6.257305] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 6.265914] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 6.275379] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 6.284251] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 6.292777] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 6.301728] [] (freezing_slow_path+0x0/0x80) from [] (0xffffffff)
[ 6.309399] CPU1: stopping
[ 6.312045] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 3.10.0 #170
[ 6.318959] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 6.327313] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 6.335414] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 6.343857] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 6.352038] Exception stack(0xde8bdf30 to 0xde8bdf78)
[ 6.356987] df20: de8bdf78 00000005 58e3eaf7 00000001
[ 6.365005] df40: c1f322e0 00000000 5459904d 00000001 c0c28fd8 de8bc000 c0c28fe8 00000000
[ 6.373020] df60: 00000000 de8bdf78 c00798fc c05c4d78 60000113 ffffffff
[ 6.379506] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 6.388119] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 6.397585] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 6.406454] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 6.414981] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 6.423930] CPU3: stopping
[ 6.426576] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 3.10.0 #170
[ 6.433491] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 6.441844] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 6.449945] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 6.458388] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 6.466569] Exception stack(0xde8c1f30 to 0xde8c1f78)
[ 6.471518] 1f20: de8c1f78 00000005 58e3ec1b 00000001
[ 6.479536] 1f40: c1f442e0 00000000 587d8449 00000001 c0c28fd8 de8c0000 c0c28fe8 00000000
[ 6.487551] 1f60: 00000000 de8c1f78 c00798fc c05c4d78 60000113 ffffffff
[ 6.494037] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 6.502650] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 6.512116] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 6.520985] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 6.529512] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 6.538461] CRU:
[ 6.540259] 00000000: 00000001 9fff0043 0fff0022 00000008 00000005 9fff0031 0fff0018 00000008
[ 6.548615] 00000020: 00000103 9fff007f 0fff0040 00000008 00000007 9fff00c5 0fff0014 00000008
[ 6.556972] 00000040: 00000b00 1fff0270 0fff0138 0000000a 00001111 00000000 00000000 00000000
[ 6.565329] 00000060: 00004031 0000b108 00000003 00000200 00008100 00008100 00008585 00010014
[ 6.573687] 00000080: 01885091 01885091 0000a101 00002745 00004345 00008a00 00000200 00000200
[ 6.582044] 000000a0: 00000200 0bb8ea60 00010014 00010014 00010014 00000910 00000900 001f05dc
[ 6.590401] 000000c0: 00001703 0000078c 00000e40 00000101 00000542 00000342 00004141 00004040
[ 6.598758] 000000e0: 00004141 00000505 00008042 00008f8f 00000000 00000631 00001ee5 00008307
[ 6.607116] 00000100: 00001200 00010014 00004141 00000000 00000000 00000000 00000000 00000000
[ 6.615472] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.623830] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.632188] 00000160: 00000000 00000000 00000100 00000800 00000000 00000000 0000eb00 00000092
[ 6.640545] 00000180: 00000000 00000000 0000000c 00000000 00000000 0000e010 00000000 00000000
[ 6.648902] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.657260] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.665617] 000001e0: 00000000 00000000 00000000 00640064 00000004 00000000 00000002 00000000
[ 6.673975] 00000200: 00000002 00000000 00000002 00000000 00000002 00000000 00000004 0000041d
[ 6.682332] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.690689] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.699047] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.707404] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.715762] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.724119] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.732477] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.740834] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.749191] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.757549] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.765907] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.774264] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.782621] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.790979] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.799336] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.807695] 00000400: 00000001 9fff0043 0fff0022 00000008 00000005 9fff0031 0fff0018 00000008
[ 6.816047] Rebooting in 5 seconds..DDR Version 1.00 20160530
!(file:///C:/Users/osan/Desktop/1.png)
路过,参考下
遇到同样的问题,楼主最后有解决掉吗?求分享
