不能运行快手的问题
拿到了板子rk3399-J,发现启动快手时没有响应,从网上下了快手的apk,找了一台旧的魅族android 5.1的系统做对比测试,还是发现魅族安装的apk可以运行,而开发板上则死在的启动画面,没有修改过板载固件,其他的斗鱼什么的app则可以在开发板上运行。运行快手抓到的错误信息如下:谁能帮忙解决下或者给点提示:
2020-05-11 12:58:14.000 285-375/? E/AudioHardwareTiny: 1212121 start_output_stream,dev=0x40a
2020-05-11 12:58:14.000 285-375/? E/AudioHardwareTiny: vicent r 44100 c 2 ps 512 pc 3
2020-05-11 12:58:14.001 285-375/? E/AudioHardwareTiny: start_output_stream() >>>> PCM_CARD_HDMI:0, PCM_CARD:1, HdmiIn_snd_config.config:4<
2020-05-11 12:58:14.231 236-241/? E/BufferQueueProducer: [NavigationBar] connect: already connected (cur=1 req=1)
2020-05-11 12:58:14.336 236-672/? E/BufferQueueProducer: [com.android.systemui.ImageWallpaper] connect: already connected (cur=1 req=1)
2020-05-11 12:58:14.548 3776-3776/com.smile.gifmaker A/libc: stack corruption detected
2020-05-11 12:58:14.639 236-672/? E/BufferQueueProducer: [StatusBar] connect: already connected (cur=1 req=1)
2020-05-11 12:58:14.643 1216-1216/com.sohu.inputmethod.sogou E/BitmapFactory: Unable to decode stream: java.io.FileNotFoundException: /data/user/0/com.sohu.inputmethod.sogou/files/.theme/sogou/res/composing_bg.png (No such file or directory)
等待几秒
2020-05-11 12:58:36.339 624-638/system_process E/ActivityManager: ANR in com.smile.gifmaker
PID: 3776
Reason: executing service com.smile.gifmaker/com.yxcorp.gifshow.log.service.LogService
Load: 0.88 / 0.41 / 0.4
官网最新固件191224,快手官网下载最新APP,连接wifi,打开快手一切正常
多谢,亲测有效
