更新最新的代码,
编译uboot 出错
Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error
FATAL ERROR: Unable to parse input tree
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3036-sdk.dtb] Error 1
make[2]: *** Waiting for unfinished jobs…
Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3188-radxarock.dtb] Error 1
make[1]: *** [dts/Makefile:72: arch-dtbs] Error 2
make: *** [Makefile:880: dts/dt.dtb] Error 2
查看
发现 最后一行 #include “rk3036-sdk-u-boot.dtsi”
怎么会多出 \
Liu.wj
3
时间的蝴蝶 发表于 2020-5-12 15:18
有按照WIKI步骤操作吗?http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/linux_compile.html
同步一下所 …
同步了,编译rootfs 也出现好几个文件有“ #include”,我怀疑git同步出现问题,其他的我把那个\删掉就可以了,但是这个uboot,删了,还是会出现
Error: arch/arm/dts/.rk3368-geekbox.dtb.pre.tmp:320.1-10 Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error
syntax errormake[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3188-radxarock.dtb] Error 1
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-geekbox.dtb] Error 1
Error: arch/arm/dts/.rk3368-lion.dtb.pre.tmp:196.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-lion.dtb] Error 1
Error: arch/arm/dts/.rk3368-sheep.dtb.pre.tmp:288.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-sheep.dtb] Error 1
Error: arch/arm/dts/.rk3328-evb.dtb.pre.tmp:271.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3328-evb.dtb] Error 1
Error: arch/arm/dts/.rk3368-px5-evb.dtb.pre.tmp:324.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-px5-evb.dtb] Error 1
====Build uboot failed!====
amjeg
6
