编译的源码下载后正常启动 5分钟就是会自动重启 一直这样循环下去 打印的信息没有发现异常 有大佬知道是怎么回事吗{:4_141:}{:4_141:}{:4_141:}
DDR Version 1.22 20190506
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 0, cs 1, advanced training done
channel 1, cs 0, advanced training done
channel 1, cs 1, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
CPUId = 0x0
ChipType = 0x10, 224
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67875
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x83eb4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):51f2096
NOTICE: BL31: Built : 16:24:31, May 6 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Feb 25 2020 - 10:44:50)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=33
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2020-02-25#1.15
empty serial no.
tribbi 0mactribbi read screen_type:-1 hdmi_mode:-1 lcd_mipi_param:-1 lcd_pri:-1 lcd_ext:-1
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
no fuel gauge found
Secure Boot state: 0
kernel @ 0x00280000 (0x0135d008)
ramdisk @ 0x04bf0000 (0x001e76d4)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616beb … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.126 (tribbi@ani) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #14 SMP PREEMPT Tue Feb 25 10:45:43 CST 2020
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef3000 s45528 r8192 d32296 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00008000@0x003C4000(metadata),0x00000040@0x003CC000(verity_mode),0x00002000@0x003CC040(reserved),0x00000400@0x003CE040(frp),-@0x003CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2020-02-25_10:44:50 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6eab000-0xf6eeb000] (0MB) mapped at [ffffffc0f6eab000-ffffffc0f6eeafff]
[ 0.000000] Memory: 3916696K/4030464K available (11646K kernel code, 1652K rwdata, 5664K rodata, 832K init, 2407K bss, 97384K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008be0000 ( 11648 KB)
[ 0.000000] .rodata : 0xffffff8008be0000 - 0xffffff8009170000 ( 5696 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093dd008 ( 1653 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.001857] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002844] pid_max: default: 32768 minimum: 301
[ 0.003347] Security Framework initialized
[ 0.003746] SELinux: Initializing.
[ 0.004190] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004835] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006363] Initializing cgroup subsys memory
[ 0.006806] Initializing cgroup subsys freezer
[ 0.008124] sched-energy: Sched-energy-costs installed from DT
[ 0.008686] CPU0: update cpu_capacity 401
[ 0.009151] ASID allocator initialised with 32768 entries
[ 0.025984] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027245] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039387] Detected VIPT I-cache on CPU1
[ 0.039418] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039458] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039500] CPU1: update cpu_capacity 401
[ 0.039504] CPU1: Booted secondary processor [410fd034]
[ 0.049368] Detected VIPT I-cache on CPU2
[ 0.049388] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049419] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049445] CPU2: update cpu_capacity 401
[ 0.049448] CPU2: Booted secondary processor [410fd034]
[ 0.059397] Detected VIPT I-cache on CPU3
[ 0.059416] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059448] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059473] CPU3: update cpu_capacity 401
[ 0.059476] CPU3: Booted secondary processor [410fd034]
[ 0.069445] Detected PIPT I-cache on CPU4
[ 0.069473] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069512] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069552] CPU4: update cpu_capacity 1024
[ 0.069555] CPU4: Booted secondary processor [410fd082]
[ 0.079470] Detected PIPT I-cache on CPU5
[ 0.079487] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079524] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079550] CPU5: update cpu_capacity 1024
[ 0.079553] CPU5: Booted secondary processor [410fd082]
[ 0.079638] Brought up 6 CPUs
[ 0.092037] SMP: Total of 6 processors activated.
[ 0.092491] CPU features: detected feature: GIC system register CPU interface
[ 0.093178] CPU: All CPU(s) started at EL2
[ 0.093613] alternatives: patching kernel code
[ 0.095981] devtmpfs: initialized
[ 0.115502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116437] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117741] pinctrl core: initialized pinctrl subsystem
[ 0.119698] Failed to find legacy iommu devices
[ 0.120481] NET: Registered protocol family 16
[ 0.121339] schedtune: init normalization constants…
[ 0.121817] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122426] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123046] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123652] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124258] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124868] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125472] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126076] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126712] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127320] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128025] schedtune: verify normalization constants…
[ 0.128522] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129037] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129557] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130081] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130592] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131109] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131623] schedtune: configured to support 5 boost groups
[ 0.140116] cpuidle: using governor ladder
[ 0.150119] cpuidle: using governor menu
[ 0.150499] Registered FIQ tty driver
[ 0.151244] vdso: 2 pages (1 code @ ffffff8008be6000, 1 data @ ffffff8009244000)
[ 0.151951] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.153626] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.165590] at24_parse_uboot_param:268 error not find screen_type !
[ 0.166193] at24_parse_uboot_param:268 error not find hdmi_mode !
[ 0.166777] at24_parse_uboot_param:268 error not find lcd_mipi_param !
[ 0.167401] at24_parse_uboot_param:268 error not find lcd_pri !
[ 0.167966] at24_parse_uboot_param:268 error not find lcd_ext !
[ 0.168519] uboot_param_init:
[ 0.168519] screen_type -1
[ 0.168519] hdmi_mode -1
[ 0.168519] lcd_mipi_param -1
[ 0.168519] lcd_pri -1
[ 0.179097] console [pstore-1] enabled
[ 0.179695] pstore: Registered ramoops as persistent store backend
[ 0.180273] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.181779] fiq debugger fiq mode enabled
[ [ 0.182421] console [ttyFIQ0] enabled
[ 0.183092] bootconsole [uart0] disabled
[ 0.183624] Registered fiq debugger ttyFIQ0
[ 0.217227] iommu: Adding device ff650000.vpu_service to group 0
[ 0.217308] iommu: Adding device ff660000.rkvdec to group 1
[ 0.217372] iommu: Adding device ff670000.iep to group 2
[ 0.217458] iommu: Adding device ff8f0000.vop to group 3
[ 0.217561] iommu: Adding device ff900000.vop to group 4
[ 0.218261] rk_iommu ff670800.iommu: can’t get aclk
[ 0.218278] rk_iommu ff670800.iommu: can’t get hclk
[ 0.218837] SCSI subsystem initialized
[ 0.219004] usbcore: registered new interface driver usbfs
[ 0.219047] usbcore: registered new interface driver hub
[ 0.219125] usbcore: registered new device driver usb
[ 0.219461] media: Linux media interface: v0.10
[ 0.219504] Linux video capture interface: v2.00
[ 0.219673] pps_core: LinuxPPS API ver. 1 registered
[ 0.219682] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.219704] PTP clock support registered
[ 0.221282] Advanced Linux Sound Architecture Driver Initialized.
[ 0.221823] Bluetooth: Core ver 2.21
[ 0.221855] NET: Registered protocol family 31
[ 0.221864] Bluetooth: HCI device and connection manager initialized
[ 0.221877] Bluetooth: HCI socket layer initialized
[ 0.221889] Bluetooth: L2CAP socket layer initialized
[ 0.221916] Bluetooth: SCO socket layer initialized
[ 0.222655] rockchip-cpuinfo cpuinfo: Serial : 5c7f4d0ee001de63
[ 0.223222] clocksource: Switched to clocksource arch_sys_counter
[ 0.266697] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.266939] NET: Registered protocol family 2
[ 0.267381] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.267646] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.268181] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.268263] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.268369] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.268602] NET: Registered protocol family 1
[ 0.269462] Trying to unpack rootfs image as initramfs…
[ 0.367043] Freeing initrd memory: 1948K
[ 0.367647] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.367745] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.370638] audit: initializing netlink subsys (disabled)
[ 0.370708] audit: type=2000 audit(0.366:1): initialized
[ 0.375894] VFS: Disk quotas dquot_6.6.0
[ 0.376017] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.377056] Registering sdcardfs 0.1
[ 0.377630] fuse init (API version 7.23)
[ 0.378707]
[ 0.378707] TEE Core Framework initialization (ver 1:0.1)
[ 0.378734] TEE armv7 Driver initialization
[ 0.379096] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.379112] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.379283] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.383233] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.383255] io scheduler noop registered
[ 0.383414] io scheduler cfq registered (default)
[ 0.384591] phy phy-ff770000.syscon:usb2-phy@e450.0: Failed to get VBUS supply regulator
[ 0.385711] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[ 0.385785] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.389563] backlight supply power not found, using dummy regulator
[ 0.389804] backlight1 supply power not found, using dummy regulator
[ 0.390201] iep: failed to find iep power down clock source.
[ 0.390549] IEP Power ON
[ 0.390710] IEP Power OFF
[ 0.390780] IEP Driver loaded succesfully
[ 0.390895] Module initialized.
[ 0.391152] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.391380] rk-vcodec ff650000.vpu_service: probe device
[ 0.391540] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.392027] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.392042] rk-vcodec ff650000.vpu_service: init success
[ 0.392224] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.392586] rk-vcodec ff660000.rkvdec: probe device
[ 0.392738] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.393116] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.393131] rk-vcodec ff660000.rkvdec: init success
[ 0.394712] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.394735] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.396089] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.396109] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.397966] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.398495] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.398972] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.399364] [drm] Initialized drm 1.1.0 20060810
[ 0.403021] [drm] Rockchip DRM driver version: v1.0.0
[ 0.403366] rockchip-drm display-subsystem: dmc is disabled
[ 0.403641] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.403891] rockchip-vop ff900000.vop: unable to request PWM
[ 0.403919] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.403960] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.404132] rockchip-vop ff8f0000.vop: unable to request PWM
[ 0.404147] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.404167] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 0.404415] rockchip-drm display-subsystem: master bind failed: -517
[ 0.405367] mali ff9a0000.gpu: Failed to get regulator
[ 0.405386] mali ff9a0000.gpu: Power control initialization failed
[ 0.405682] Unable to detect cache hierarchy for CPU 0
[ 0.423694] brd: module loaded
[ 0.445315] loop: module loaded
[ 0.449206] zram: Added device: zram0
[ 0.458397] get default mcu : 1
[ 0.463465] get default usb_3g : 1
[ 0.468523] get default usb_3g_wake : 1
[ 0.473598] get default usb_eth_led : 1
[ 0.478657] get default red_led : 0
[ 0.483715] get default func_io1 : 1
[ 0.488773] get default func_io2 : 1
[ 0.523802] misc_gpio_probe: Entering…
[ 0.524085] SCSI Media Changer driver v0.25
[ 0.524750] tun: Universal TUN/TAP device driver, 1.6
[ 0.524767] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.525738] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.525764] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.525775] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 0.525798] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.525956] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.525970] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.530985] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.531107] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.531121] Ring mode enabled
[ 0.531128] DMA HW capability register supported
[ 0.531135] Normal descriptors
[ 0.531144] RX Checksum Offload Engine supported (type 2)
[ 0.531150] TX Checksum insertion supported
[ 0.531157] Wake-Up On Lan supported
[ 0.531202] Enable RX Mitigation via HW Watchdog Timer
[ 0.599431] libphy: stmmac: probed
[ 0.599501] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.599513] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.600899] PPP generic driver version 2.4.2
[ 0.601191] PPP BSD Compression module registered
[ 0.601228] PPP Deflate Compression module registered
[ 0.601494] PPP MPPE Compression module registered
[ 0.601703] NET: Registered protocol family 24
[ 0.601952] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.602134] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.602371] Rockchip WiFi SYS interface (V1.00) …
[ 0.602660] usbcore: registered new interface driver catc
[ 0.602836] usbcore: registered new interface driver kaweth
[ 0.603028] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.603274] usbcore: registered new interface driver pegasus
[ 0.603507] usbcore: registered new interface driver rtl8150
[ 0.603722] usbcore: registered new interface driver r8152
[ 0.603914] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.604174] usbcore: registered new interface driver hso
[ 0.604389] usbcore: registered new interface driver asix
[ 0.604610] usbcore: registered new interface driver ax88179_178a
[ 0.604826] usbcore: registered new interface driver cdc_ether
[ 0.605046] usbcore: registered new interface driver cdc_eem
[ 0.605268] usbcore: registered new interface driver dm9601
[ 0.605498] usbcore: registered new interface driver smsc75xx
[ 0.605720] usbcore: registered new interface driver smsc95xx
[ 0.605931] usbcore: registered new interface driver gl620a
[ 0.606150] usbcore: registered new interface driver net1080
[ 0.606370] usbcore: registered new interface driver plusb
[ 0.606596] usbcore: registered new interface driver rndis_host
[ 0.606645] usbcore: registered new interface driver cdc_subset
[ 0.606690] usbcore: registered new interface driver zaurus
[ 0.606732] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.606794] usbcore: registered new interface driver int51x1
[ 0.606842] usbcore: registered new interface driver kalmia
[ 0.606883] usbcore: registered new interface driver ipheth
[ 0.606933] usbcore: registered new interface driver sierra_net
[ 0.606975] usbcore: registered new interface driver cx82310_eth
[ 0.607024] usbcore: registered new interface driver cdc_ncm
[ 0.607070] usbcore: registered new interface driver qmi_wwan
[ 0.607112] usbcore: registered new interface driver cdc_mbim
[ 0.611630] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 0.617041] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 0.618816] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.618847] ehci-pci: EHCI PCI platform driver
[ 0.618953] ehci-platform: EHCI generic platform driver
[ 0.622682] ehci-platform fe380000.usb: EHCI Host Controller
[ 0.622883] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 0.623070] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 0.629880] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 0.630018] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.630053] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.630064] usb usb1: Product: EHCI Host Controller
[ 0.630074] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 0.630083] usb usb1: SerialNumber: fe380000.usb
[ 0.630715] hub 1-0:1.0: USB hub found
[ 0.630770] hub 1-0:1.0: 1 port detected
[ 0.634877] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 0.635087] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 0.635246] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 0.643216] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 0.643344] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.643378] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.643389] usb usb2: Product: EHCI Host Controller
[ 0.643399] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 0.643408] usb usb2: SerialNumber: fe3c0000.usb
[ 0.643997] hub 2-0:1.0: USB hub found
[ 0.644065] hub 2-0:1.0: 1 port detected
[ 0.644917] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.645012] ohci-platform: OHCI generic platform driver
[ 0.645425] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 0.645665] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 0.645904] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 0.700682] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.700703] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.700713] usb usb3: Product: Generic Platform OHCI controller
[ 0.700722] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 0.700731] usb usb3: SerialNumber: fe3a0000.usb
[ 0.701356] hub 3-0:1.0: USB hub found
[ 0.701425] hub 3-0:1.0: 1 port detected
[ 0.702111] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 0.702341] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 0.702561] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 0.757397] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.757445] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.757460] usb usb4: Product: Generic Platform OHCI controller
[ 0.757474] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 0.757486] usb usb4: SerialNumber: fe3e0000.usb
[ 0.758063] hub 4-0:1.0: USB hub found
[ 0.758138] hub 4-0:1.0: 1 port detected
[ 0.759534] usbcore: registered new interface driver cdc_acm
[ 0.759547] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.759671] usbcore: registered new interface driver usblp
[ 0.759736] usbcore: registered new interface driver cdc_wdm
[ 0.759806] usbcore: registered new interface driver uas
[ 0.760003] usbcore: registered new interface driver usb-storage
[ 0.760095] usbcore: registered new interface driver ums-alauda
[ 0.760153] usbcore: registered new interface driver ums-cypress
[ 0.760214] usbcore: registered new interface driver ums-datafab
[ 0.760310] usbcore: registered new interface driver ums_eneub6250
[ 0.760367] usbcore: registered new interface driver ums-freecom
[ 0.760426] usbcore: registered new interface driver ums-isd200
[ 0.760489] usbcore: registered new interface driver ums-jumpshot
[ 0.760578] usbcore: registered new interface driver ums-karma
[ 0.760636] usbcore: registered new interface driver ums-onetouch
[ 0.760701] usbcore: registered new interface driver ums-sddr09
[ 0.760792] usbcore: registered new interface driver ums-sddr55
[ 0.760849] usbcore: registered new interface driver ums-usbat
[ 0.760961] usbcore: registered new interface driver usbserial
[ 0.761048] usbcore: registered new interface driver usbserial_generic
[ 0.761088] usbserial: USB Serial support registered for generic
[ 0.761151] usbcore: registered new interface driver option
[ 0.761220] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.761488] usbcore: registered new interface driver trancevibrator
[ 0.761539] usb20_otg: version 3.10a 21-DEC-2012
[ 0.761822] usb20_host: version 3.10a 21-DEC-2012
[ 0.762633] usbcore: registered new interface driver xpad
[ 0.762708] usbcore: registered new interface driver usb_acecad
[ 0.762772] usbcore: registered new interface driver aiptek
[ 0.762859] usbcore: registered new interface driver gtco
[ 0.762920] usbcore: registered new interface driver hanwang
[ 0.762979] usbcore: registered new interface driver kbtab
[ 0.763737] .. rk pwm remotectl v1.1 init
[ 0.764101] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.764704] sensor_register_slave:mma8452,id=17
[ 0.764743] sensor_register_slave:lis3dh,id=7
[ 0.764759] sensor_register_slave:mma7660,id=18
[ 0.764814] sensor_register_slave:lsm303d,id=22
[ 0.764829] sensor_register_slave:gs_mc3230,id=23
[ 0.764838] [Gsensor] gsensor_init
[ 0.764852] sensor_register_slave:mpu6880_acc,id=24
[ 0.764866] sensor_register_slave:mpu6500_acc,id=25
[ 0.764880] sensor_register_slave:lsm330_acc,id=26
[ 0.764895] sensor_register_slave:bma2xx_acc,id=27
[ 0.764909] sensor_register_slave:akm8975,id=30
[ 0.764923] sensor_register_slave:akm8963,id=31
[ 0.764938] sensor_register_slave:l3g4200d,id=45
[ 0.764952] sensor_register_slave:l3g20d,id=46
[ 0.764966] sensor_register_slave:ewtsa,id=47
[ 0.764982] sensor_register_slave:lsm330_gyro,id=51
[ 0.765032] sensor_register_slave:cm3217,id=53
[ 0.765046] sensor_register_slave:cm3218,id=54
[ 0.765061] sensor_register_slave:ls_stk3410,id=62
[ 0.765076] sensor_register_slave:ps_stk3410,id=67
[ 0.765988] i2c /dev entries driver
[ 0.768057] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.768258] fan53555-reg: supplied by vcc5v0_sys
[ 0.774925] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.775030] fan53555-reg: supplied by vcc5v0_sys
[ 0.780255] rk808 0-001b: Pmic Chip id: 0x0
[ 0.789753] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.789895] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.790060] DCDC_REG1: supplied by vcc3v3_sys
[ 0.791454] DCDC_REG2: supplied by vcc3v3_sys
[ 0.792725] DCDC_REG3: supplied by vcc3v3_sys
[ 0.793124] DCDC_REG4: supplied by vcc3v3_sys
[ 0.794012] LDO_REG1: supplied by vcc3v3_sys
[ 0.795927] LDO_REG2: supplied by vcc3v3_sys
[ 0.797367] LDO_REG3: supplied by vcc3v3_sys
[ 0.798803] LDO_REG4: supplied by vcc3v3_sys
[ 0.800218] LDO_REG5: supplied by vcc3v3_sys
[ 0.801667] LDO_REG6: supplied by vcc3v3_sys
[ 0.803112] LDO_REG7: supplied by vcc3v3_sys
[ 0.804550] LDO_REG8: supplied by vcc3v3_sys
[ 0.805994] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.806406] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.807113] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009a48000
[ 0.808052] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009a4a000
[ 0.808794] James DBG:>>>>>>pcf8563_probe
[ 0.808841] rtc-pcf8563 2-0051: chip found, driver version 0.4.3
[ 0.808850] James DBG:>>>>>>clear alarmtime
[ 0.810854] James DBG:>>>>>>disable getalarm
[ 0.811110] rtc-pcf8563 2-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 0.811290] @tribbi mcu_7502_probe:mcu_7502_probe
[ 0.811521] mcu_7502 initialized
[ 0.811579] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009a4c000
[ 0.812580] at24 6-0050: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 0.949881] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 0.953288] at24_parse_disp_param:225 error not find screen_type !
[ 0.953332] >>>drm screen_type = -1
[ 0.953377] at24_parse_disp_param:225 error not find lcd_vol_max !
[ 1.074920] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608
[ 1.074957] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.074967] usb 2-1: Product: USB2.0 Hub
[ 1.075665] hub 2-1:1.0: USB hub found
[ 1.076043] hub 2-1:1.0: 4 ports detected
[ 1.154086] Failed to i2c xrm117x_port_write <-6>
[ 1.154264] Failed to i2c xrm117x_port_write <-6>
[ 1.154438] Failed to i2c xrm117x_port_read <-6>
[ 1.154836] Failed to i2c xrm117x_port_read <-6>
[ 1.155003] Failed to i2c xrm117x_port_write <-6>
[ 1.155173] Failed to i2c xrm117x_port_write <-6>
[ 1.155342] Failed to i2c xrm117x_port_write <-6>
[ 1.155512] Failed to i2c xrm117x_port_read <-6>
[ 1.155868] Failed to i2c xrm117x_port_read <-6>
[ 1.156036] Failed to i2c xrm117x_port_write <-6>
[ 1.156218] xrm117x_probe~ devm_request_threaded_irq =133 result:0
[ 1.156381] goodix_ts_probe() start
[ 1.176650] <<-GTP-ERROR->> 2Failed to request GPIO:70, ERRNO:-16
[ 1.176686] <<-GTP-ERROR->> GTP request IO port failed.
[ 1.176761] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at ffffff8009a4e000
[ 1.177410] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009a50000
[ 1.178272] IR NEC protocol handler initialized
[ 1.178287] IR RC5(x/sz) protocol handler initialized
[ 1.178301] IR RC6 protocol handler initialized
[ 1.178342] IR JVC protocol handler initialized
[ 1.178354] IR Sony protocol handler initialized
[ 1.178367] IR SANYO protocol handler initialized
[ 1.178380] IR Sharp protocol handler initialized
[ 1.178394] IR MCE Keyboard/mouse protocol handler initialized
[ 1.178406] IR XMP protocol handler initialized
[ 1.178603] usbcore: registered new interface driver uvcvideo
[ 1.178629] USB Video Class driver (1.1.1)
[ 1.178646] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 1.179025] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.179174] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.179417] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.179541] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.181843] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.182487] device-mapper: uevent: version 1.0.3
[ 1.182817] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.182990] Bluetooth: HCI UART driver ver 2.3
[ 1.183007] Bluetooth: HCI UART protocol H4 registered
[ 1.183016] Bluetooth: HCI UART protocol LL registered
[ 1.183027] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.183035] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.183042] rtk_btusb: Register usb char device interface for BT driver
[ 1.183287] usbcore: registered new interface driver rtk_btusb
[ 1.183681] cpu cpu0: Failed to get leakage
[ 1.183781] cpu cpu0: Failed to get pvtm
[ 1.184026] cpu cpu4: Failed to get leakage
[ 1.184584] cpu cpu4: Failed to get pvtm
[ 1.191894] sdhci: Secure Digital Host Controller Interface driver
[ 1.191930] sdhci: Copyright(c) Pierre Ossman
[ 1.191941] Synopsys Designware Multimedia Card Interface Driver
[ 1.192739] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.192898] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.192916] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.192962] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.193001] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.193042] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.193051] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.193825] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.193875] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.193891] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.193937] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.193954] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.194038] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.194284] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 1.194305] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.194317] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.206699] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.221023] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.221321] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.223016] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.223051] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.249997] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.250563] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.254131] usbcore: registered new interface driver usbhid
[ 1.254150] usbhid: USB HID core driver
[ 1.254352] inv_mpu_iio: inv_mpu_init:746
[ 1.255369] ashmem: initialized
[ 1.260934] ff100000.saradc supply vref not found, using dummy regulator
[ 1.263017] rknandbase v1.1 2016-11-08
[ 1.263606] usbcore: registered new interface driver snd-usb-audio
[ 1.264623] es8316 1-0010: Can not read property hp_det_gpio
[ 1.268379] u32 classifier
[ 1.268409] Actions configured
[ 1.268456] Netfilter messages via NETLINK v0.30.
[ 1.268516] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.268932] ctnetlink v0.93: registering with nfnetlink.
[ 1.269608] xt_time: kernel timezone is -0000
[ 1.270732] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.270995] arp_tables: (C) 2002 David S. Miller
[ 1.271538] Initializing XFRM netlink socket
[ 1.271992] NET: Registered protocol family 10
[ 1.273379] mip6: Mobile IPv6
[ 1.273467] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.275017] sit: IPv6 over IPv4 tunneling driver
[ 1.275684] NET: Registered protocol family 17
[ 1.275752] NET: Registered protocol family 15
[ 1.275810] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.276474] Bridge firewalling registered
[ 1.276546] Ebtables v2.0 registered
[ 1.276982] Bluetooth: RFCOMM TTY layer initialized
[ 1.277009] Bluetooth: RFCOMM socket layer initialized
[ 1.277060] Bluetooth: RFCOMM ver 1.11
[ 1.277102] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.277112] Bluetooth: BNEP filters: protocol multicast
[ 1.277127] Bluetooth: BNEP socket layer initialized
[ 1.277143] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.277156] Bluetooth: HIDP socket layer initialized
[ 1.277203] l2tp_core: L2TP core driver, V2.0
[ 1.277232] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.277250] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.277772] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.277875] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 1.277918] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.277927] [WLAN_RFKILL]: >>>>James1
[ 1.278011] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.278085] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.278125] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.278171] [WLAN_RFKILL]: >>>>James3
[ 1.278181] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.278293] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.278898] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.278988] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.279058] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 91.
[ 1.279097] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.280033] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.280131] [BT_RFKILL]: ** disable irq
[ 1.280327] [BT_RFKILL]: bt_default device registered.
[ 1.280762] sensor_register_slave:mpu6500_gyro,id=49
[ 1.280787] sensor_register_slave:mpu6880_gyro,id=50
[ 1.282873] Registered cp15_barrier emulation handler
[ 1.282982] Registered setend emulation handler
[ 1.284411] registered taskstats version 1
[ 1.285457] rockchip ion idev is NULL
[ 1.285478] rga2 ff680000.rga: rga ion client create success!
[ 1.285842] rga2: Driver loaded successfully ver:3.02
[ 1.286130] rga2: Module initialized.
[ 1.286301] parse_disp_param:87 error not find screen_type !
[ 1.286376] parse_disp_param:87 error not find lvds_fmt !
[ 1.286419] parse_disp_param:87 error not find edp_cfg !
[ 1.286482] parse_disp_param:87 error not find lcd_cfg !
[ 1.286613] parse_disp_param:87 error not find lcd_face !
[ 1.286659] parse_disp_param:87 error not find lcd_map !
[ 1.286732] parse_disp_param:87 error not find hdmi_mode !
[ 1.286774] parse_disp_param:87 error not find lcd_rotate !
[ 1.286817] parse_disp_param:87 error not find dsi_lanes !
[ 1.286858] parse_disp_param:87 error not find pwm_max !
[ 1.286925] parse_disp_param:87 error not find pwm_min !
[ 1.286968] parse_disp_param:87 error not find pwm_pol !
[ 1.287009] parse_disp_param:87 error not find hid_vid !
[ 1.287051] parse_disp_param:87 error not find hid_pid !
[ 1.287093] parse_disp_param:87 error not find lcd_vol_max !
[ 1.287163] parse_disp_param:87 error not find lcd_bl_delay !
[ 1.287206] parse_disp_param:87 error not find hid_vid !
[ 1.287248] parse_disp_param:87 error not find hid_pid !
[ 1.287289] parse_disp_param:87 error not find lcd_dclk_freq !
[ 1.287330] parse_disp_param:87 error not find lcd_x !
[ 1.287398] parse_disp_param:87 error not find lcd_y !
[ 1.287441] parse_disp_param:87 error not find lcd_hsync !
[ 1.287483] parse_disp_param:87 error not find lcd_hbp !
[ 1.287525] parse_disp_param:87 error not find lcd_hfp !
[ 1.287587] parse_disp_param:87 error not find lcd_vsync !
[ 1.287630] parse_disp_param:87 error not find lcd_vbp !
[ 1.287672] parse_disp_param:87 error not find lcd_vfp !
[ 1.287687] lcd_x 0
[ 1.287687] lcd_y 0
[ 1.287687] lcd_dclk_freq -64
[ 1.287687] lcd_hsync 18763
[ 1.287687] lcd_hbp 1245926178
[ 1.287687] lcd_hfp 49472206
[ 1.287687] lcd_vsync 145285793
[ 1.287687] lcd_vbp 1855997168
[ 1.287687] lcd_vfp 1282303522
[ 1.289669] tribbi panel-init-sequence-1920x1080-map0
[ 1.289755] ff960000.dsi.0 supply power not found, using dummy regulator
[ 1.290818] [drm] Rockchip DRM driver version: v1.0.0
[ 1.291183] mmc1: MAN_BKOPS_EN bit is not set
[ 1.291288] rockchip-drm display-subsystem: dmc is disabled
[ 1.291812] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.292190] rockchip-vop ff900000.vop: unable to request PWM
[ 1.292225] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.292301] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.292546] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.292597] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.292697] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_dsi_ops)
[ 1.293376] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.293460] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.293599] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.296022] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.296053] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.296063] [drm] No driver support for vblank timestamp query.
[ 1.296508] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.304626] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.308881] mmcblk1: mmc1:0001 BJTD4R 29.1 GiB
[ 1.309138] mmcblk1boot0: mmc1:0001 BJTD4R partition 1 4.00 MiB
[ 1.310495] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.312998] mmcblk1boot1: mmc1:0001 BJTD4R partition 2 4.00 MiB
[ 1.313477] mmcblk1rpmb: mmc1:0001 BJTD4R partition 3 4.00 MiB
[ 1.314081] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.314106] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.314120] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.314134] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.314149] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.314160] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.314171] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 1.314183] backup: 0x009800000 – 0x010800000 (112 MB)
[ 1.314194] cache: 0x010800000 – 0x018800000 (128 MB)
[ 1.314205] system: 0x018800000 – 0x078800000 (1536 MB)
[ 1.314216] metadata: 0x078800000 – 0x079800000 (16 MB)
[ 1.314228] verity_mode: 0x079800000 – 0x079808000 (0 MB)
[ 1.314239] reserved: 0x079808000 – 0x079c08000 (4 MB)
[ 1.314250] frp: 0x079c08000 – 0x079c88000 (0 MB)
[ 1.314261] userdata: 0x079c88000 – 0x747800000 (27867 MB)
[ 1.314333] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 1.325011] mali ff9a0000.gpu: Failed to get leakage
[ 1.325087] mali ff9a0000.gpu: Failed to get pvtm
[ 1.326227] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.326667] mali ff9a0000.gpu: Protected mode not available
[ 1.327856] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.328047] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.328884] mali ff9a0000.gpu: Probed as mali0
[ 1.333082] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 1.333622] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 5
[ 1.334148] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.334251] xhci-hcd xhci-hcd.8.auto: irq 232, io mem 0xfe800000
[ 1.334496] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.334522] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.334562] usb usb5: Product: xHCI Host Controller
[ 1.334581] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.334599] usb usb5: SerialNumber: xhci-hcd.8.auto
[ 1.335449] hub 5-0:1.0: USB hub found
[ 1.335514] hub 5-0:1.0: 1 port detected
[ 1.336014] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 1.336308] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 6
[ 1.336430] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.336674] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.336703] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.336723] usb usb6: Product: xHCI Host Controller
[ 1.336741] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.336759] usb usb6: SerialNumber: xhci-hcd.8.auto
[ 1.337547] hub 6-0:1.0: USB hub found
[ 1.337645] hub 6-0:1.0: 1 port detected
[ 1.340675] xhci-hcd xhci-hcd.8.auto: remove, state 1
[ 1.340731] usb usb6: USB disconnect, device number 1
[ 1.365984] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microseconds.
[ 1.366007] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting reset.
[ 1.367358] xhci-hcd xhci-hcd.8.auto: USB bus 6 deregistered
[ 1.368145] xhci-hcd xhci-hcd.8.auto: remove, state 1
[ 1.368259] usb usb5: USB disconnect, device number 1
[ 1.369339] xhci-hcd xhci-hcd.8.auto: USB bus 5 deregistered
[ 1.370465] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.370821] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 1.371204] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.371265] xhci-hcd xhci-hcd.9.auto: irq 233, io mem 0xfe900000
[ 1.371559] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.371582] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.371601] usb usb5: Product: xHCI Host Controller
[ 1.371614] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.371627] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 1.372366] hub 5-0:1.0: USB hub found
[ 1.372464] hub 5-0:1.0: 1 port detected
[ 1.373018] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.373280] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[ 1.373532] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.373827] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.373848] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.373861] usb usb6: Product: xHCI Host Controller
[ 1.373874] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.373886] usb usb6: SerialNumber: xhci-hcd.9.auto
[ 1.374629] hub 6-0:1.0: USB hub found
[ 1.374718] hub 6-0:1.0: 1 port detected
[ 1.376460] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.376605] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.376630] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.376666] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.376691] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.376744] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.376756] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.377115] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.389968] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.403377] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.433181] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.434859] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.436471] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.439336] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.442824] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.456404] >>>>vol_max = 255
[ 1.528547] asoc-simple-card es8316-sound: ES8316 HiFi ↔ ff880000.i2s mapping ok
[ 1.528674] asoc-simple-card es8316-sound: ASoC: no source widget found for MICBIAS1
[ 1.528869] asoc-simple-card es8316-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.528916] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.529092] asoc-simple-card es8316-sound: ASoC: no sink widget found for IN1P
[ 1.529310] asoc-simple-card es8316-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.530125] es8316 1-0010: ASoC: Failed to create Left Hp mixer debugfs file
[ 1.530289] es8316 1-0010: ASoC: Failed to create Right Hp mixer debugfs file
[ 1.530534] es8316 1-0010: ASoC: Failed to create HPCP L debugfs file
[ 1.530736] es8316 1-0010: ASoC: Failed to create HPCP R debugfs file
[ 1.530981] es8316 1-0010: ASoC: Failed to create HPVOL L debugfs file
[ 1.531183] es8316 1-0010: ASoC: Failed to create HPVOL R debugfs file
[ 1.531564] mmc2: new high speed SDIO card at address 0001
[ 1.537472] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.540629] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 1.540701] ======== dhd_wlan_init_plat_data ========
[ 1.540719] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.540735] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.540752] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.540770] dhd_wlan_init_gpio: host_oob_irq: 67
[ 1.540824] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.540837] dhd_wifi_platform_load: Enter
[ 1.540882] Power-up adapter ‘DHD generic adapter’
[ 1.542990] rtc-pcf8563 2-0051: setting system clock to 2019-01-01 22:27:32 UTC (1546381652)
[ 1.543339] wifi_platform_set_power = 1
[ 1.543376] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.543395] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.543411] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.546416] It doesn’t contain Rogue gpu
[ 1.579631] rockchip_headset_probe() headset have hook adc mode
[ 1.580071] input: rk_headset as /devices/platform/rk_headset/input/input1
[ 1.590541] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-102ec6d’, rk_ko_ver is ‘5’, built at ‘10:45:27’, on ‘Feb 25 2020’.
[ 1.591099] Mali: Mali device driver loaded
[ 1.591707] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 1.592714] ALSA device list:
[ 1.592741] #0: rockchip,es8316-codec
[ 1.592749] #1: rk-hdmi-dp-sound
[ 1.593360] Freeing unused kernel memory: 832K
[ 1.596426] init: init first stage started!
[ 1.667831] audit: type=1403 audit(1546381652.623:2): policy loaded auid=4294967295 ses=4294967295
[ 1.668542] init: (Initializing SELinux non-enforcing took 0.07s.)
[ 1.672187] init: init second stage started!
[ 1.677108] init: Setting ro.rk.soc=rk3399
[ 1.677246] init: OK,EMMC DRIVERS INIT OK
[ 1.677280] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 1.677352] init: property_set(“ro.hardware”, “rk30board”) failed
[ 1.679693] init: Running restorecon…
[ 1.763801] init: waitpid failed: No child processes
[ 1.764272] init: (Loading properties from /default.prop took 0.00s.)
[ 1.766851] init: (Parsing /init.environ.rc took 0.00s.)
[ 1.767371] init: (Parsing /init.usb.rc took 0.00s.)
[ 1.768597] init: ignored duplicate definition of service 'ril-daemon’init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 1.769768] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 1.769983] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 1.770103] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.770375] init: (Parsing /init.logs.rc took 0.00s.)
[ 1.770538] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 1.770664] init: (Parsing /init.coredump.rc took 0.00s.)
[ 1.770744] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 1.770842] init: (Parsing /init.kernel.rc took 0.00s.)
[ 1.771008] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 1.771046] init: (Parsing /init.debug.rc took 0.00s.)
[ 1.771067] init: (Parsing init.rockchip.rc took 0.00s.)
[ 1.771591] init: (Parsing init.connectivity.rc took 0.00s.)
[ 1.771651] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.771870] init: (Parsing init.rk3399.rc took 0.00s.)
[ 1.772007] init: init.tablet.rc: 23: invalid keyword ‘ioprio’
[ 1.772065] init: (Parsing init.tablet.rc took 0.00s.)
[ 1.772113] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.772171] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.772193] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 1.773103] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 1.773252] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 1.773271] init: (Parsing /init.rc took 0.01s.)
[ 1.773813] init: Starting service ‘ueventd’…
[ 1.779893] audit: type=1400 audit(1546381652.733:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=3094 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 1.788871] ueventd: ueventd started!
[ 1.793753] ueventd: invalid gid ‘trace’
[ 1.799023] vendor storage:20160801 ret = 0
[ 1.831969] phy phy-ff770000.syscon:usb2-phy@e450.0: charger = USB_SDP_CHARGER
[ 1.846658] wifi_platform_bus_enumerate device present 1
[ 1.846681] ======== Card detection to detect SDIO card! ========
[ 1.846689] mmc2:mmc host rescan start!
[ 1.862856] bcmsdh_register: register client driver
[ 1.863277] bcmsdh_sdmmc_probe: Enter num=1
[ 1.863667] bcmsdh_sdmmc_probe: Enter num=2
[ 1.863674] bus num (host idx)=2, slot num (rca)=1
[ 1.863682] found adapter info ‘DHD generic adapter’
[ 1.864001] sdioh_attach: set sd_f2_blocksize 256
[ 1.864249] sdioh_attach: sd clock rate = 0
[ 1.865894] F1 signature read @0x18000000=0x1541a9a6
[ 1.869665] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 1.871090] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.871396] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 1.872288] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 1.873880] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 1.874556] wl_escan_attach: Enter
[ 1.874691] wl_escan_init: Enter
[ 1.875145] tsk Enter, tsk = 0xffffffc0efe301a0
[ 1.875350] wl_create_event_handler(): thread:wl_escan_handler:bc started
[ 1.875918] dhd_attach(): thread:dhd_watchdog_thread:bd started
[ 1.876506] dhd_attach(): thread:dhd_dpc:be started
[ 1.886619] dhd_attach(): thread:dhd_rxf:bf started
[ 1.886644] dhd_deferred_work_init: work queue initialized
[ 1.886671] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 1.887016] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.897413] Dongle Host Driver, version 1.579.77.41.2 (r)
[ 1.898827] Register interface [wlan0] MAC: 18:93:7f:91:13:b3
[ 1.898827]
[ 1.899228] dhd_wl_ioctl: returning as busstate=0
[ 1.899415] dhd_bus_devreset: == Power OFF ==
[ 1.900069] bcmsdh_oob_intr_unregister: Enter
[ 1.900161] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.900374] dhd_txglom_enable: enable 0
[ 1.900621] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 1.900840] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 1.901063] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[ 1.901284] sdioh_set_mode: set txglom_mode to copy
[ 1.901506] dhd_bus_devreset: WLAN OFF DONE
[ 1.901776] wifi_platform_set_power = 0
[ 1.901954] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.902177] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.902415] [WLAN_RFKILL]: wifi shut off power.
[ 1.902896] dhd_module_init: Exit err=0
[ 2.048167] ueventd: Coldboot took 0.25s.
[ 2.064546] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 2.064597] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 2.064629] init: Waiting for /dev/.coldboot_done…
[ 2.064687] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 2.064716] init: /dev/hw_random not found
[ 2.065260] keychord: using input dev ff420030.pwm for fevent
[ 2.065276] keychord: using input dev rk29-keypad for fevent
[ 2.074210] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 2.083134] Registered swp emulation handler
[ 2.083328] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 2.083946] fs_mgr: Warning: unknown flag resize
[ 2.084034] init: /dev/hw_random not found
[ 2.084113] init: write_file: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 2.085204] fs_mgr: Warning: unknown flag resize
[ 2.089798] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.089944] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 2.091300] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 2.092038] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 2.098242] random: e2fsck: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.131066] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.131066]
[ 2.131107] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 2.131107]
[ 2.131117] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 39/8192 files, 1772/32768 blocks (check in 5 mounts)
[ 2.131117]
[ 2.136278] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.136572] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 2.138535] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[ 2.140161] EXT4-fs (mmcblk1p11): warning: maximal mount count reached, running e2fsck is recommended
[ 2.140949] EXT4-fs (mmcblk1p11): recovery complete
[ 2.141002] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.141162] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 2.159758] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 2.160068] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 2.162259] random: e2fsck: uninitialized urandom read (40 bytes read, 48 bits of entropy available)
[ 2.174431] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.174431]
[ 2.174604] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata has been mounted 11 times without being checked, check forced.
[ 2.174604]
[ 2.174651] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 2.174651]
[ 2.174776] e2fsck: Pass 2: Checking directory structure
[ 2.174776]
[ 2.174819] e2fsck: Pass 3: Checking directory connectivity
[ 2.174819]
[ 2.174859] e2fsck: Pass 4: Checking reference counts
[ 2.174859]
[ 2.174980] e2fsck: Pass 5: Checking group summary information
[ 2.174980]
[ 2.175024] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: 11/1024 files (0.0% non-contiguous), 1102/4096 blocks
[ 2.175024]
[ 2.179503] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.179770] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.182353] EXT4-fs (mmcblk1p15): Ignoring removed nomblk_io_submit option
[ 2.374845] EXT4-fs (mmcblk1p15): 1 orphan inode deleted
[ 2.374985] EXT4-fs (mmcblk1p15): recovery complete
[ 2.379926] EXT4-fs (mmcblk1p15): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.380357] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/userdata,/data,ext4)=0: Success
[ 2.407397] fs_mgr: check_fs(): unmount(/data) succeeded
[ 2.407622] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 2.411612] random: e2fsck: uninitialized urandom read (40 bytes read, 72 bits of entropy available)
[ 2.465776] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.465776]
[ 2.465905] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/userdata: clean, 1134/1785856 files, 230411/7134072 blocks (check after next mount)
[ 2.465905]
[ 2.473471] EXT4-fs (mmcblk1p15): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.473766] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=ext4)=0
[ 2.480250] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 2.480652] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 2.481222] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 2.482151] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 2.482833] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 2.483529] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 2.484280] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 2.485062] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 2.486172] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 2.486778] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 2.487506] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 2.488159] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 2.488905] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 2.489460] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 2.490697] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 2.491472] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 2.492015] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 2.492535] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 2.493048] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 2.493626] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 2.494216] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 2.494753] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 2.495286] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 2.495801] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 2.496322] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 2.497016] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 2.497665] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 2.498194] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 2.498806] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 2.499372] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 2.500000] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 2.504424] init: Starting service ‘logd’…
[ 2.513037] random: logd: uninitialized urandom read (40 bytes read, 75 bits of entropy available)
[ 2.520693] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directory
[ 2.547487] logd.auditd: start
[ 2.547564] logd.klogd: 2544371773
[ 2.594572] midgard_kbase: disagrees about version of symbol module_layout
[ 2.597278] init: finit_module for “/system/lib/modules/mali_kbase.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 2.601007] zram0: detected capacity change from 0 to 533413888
[ 2.604605] random: mkswap: uninitialized urandom read (40 bytes read, 82 bits of entropy available)
[ 2.625339] random: mkswap: uninitialized urandom read (16 bytes read, 82 bits of entropy available)
[ 2.627247] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.630500] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 2.631196] init: property_set(“ro.rk.screenoff_time”, “60000”) failed
[ 2.631513] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 2.631851] init: (Loading properties from /system/build.prop took 0.00s.)
[ 2.632014] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 2.632212] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 2.632513] fs_mgr: Warning: unknown flag resize
[ 2.632721] init: /recovery not specified in fstab
[ 2.633578] init: Starting service ‘debuggerd’…
[ 2.634684] init: Starting service ‘debuggerd64’…
[ 2.636214] init: Starting service ‘vold’…
[ 2.639488] random: debuggerd64: uninitialized urandom read (40 bytes read, 83 bits of entropy available)
[ 2.639804] init: Not bootcharting.
[ 2.641811] random: debuggerd: uninitialized urandom read (40 bytes read, 83 bits of entropy available)
[ 2.647509] random: vold: uninitialized urandom read (40 bytes read, 83 bits of entropy available)
[ 2.679783] random: vdc: uninitialized urandom read (40 bytes read, 87 bits of entropy available)
[ 2.746951] fs_mgr: Warning: unknown flag resize
[ 2.786404] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 2.801114] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 227) exited with status 0
[ 2.806137] type=1400 audit(1546381653.760:4): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk1p15” ino=770049 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 2.810303] EXT4-fs (mmcblk1p15): Unrecognized mount option “background_gc=on” or missing value
[ 2.814356] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 2.815178] init: (Loading properties from /data/local.prop took 0.00s.)
[ 2.874601] init: Starting service ‘logd-reinit’…
[ 2.877123] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 2.881648] init: Starting service ‘healthd’…
[ 2.883399] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 2.884864] init: Starting service ‘earlylogs’…
[ 2.886960] init: Starting service ‘lmkd’…
[ 2.889121] init: Starting service ‘servicemanager’…
[ 2.891244] init: Starting service ‘surfaceflinger’…
[ 2.891795] binder: 229:229 transaction failed 29189/-22, size 0-0 line 2948
[ 2.894897] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 2.901462] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 2.905183] init: Service ‘earlylogs’ (pid 230) exited with status 0
[ 2.912872] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.912931] init: write: cannot expand ‘${ro.serialno}’
[ 2.914372] file system registered
[ 2.919282] using random self ethernet address
[ 2.919360] using random host ethernet address
[ 2.919459] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 2.930908] init: Starting service ‘console’…
[ 2.931971] init: Starting service ‘adbd’…
[ 2.933442] type=1400 audit(1546381653.863:5): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=2941 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 2.933924] type=1400 audit(1546381653.863:6): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=2937 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[ 2.941472] init: Service ‘logd-reinit’ (pid 228) exited with status 0
[ 2.941898] init: Starting service ‘ap_log_srv’…
[ 2.941939] logd.daemon: reinit
[ 2.942808] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 2.942900] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 2.943049] type=1400 audit(1546381653.883:7): avc: denied { setattr } for pid=1 comm=“init” name=“mmcblk1p13” dev=“tmpfs” ino=2970 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 2.943230] type=1400 audit(1546381653.883:8): avc: denied { setattr } for pid=1 comm=“init” name=“mmcblk1p13” dev=“tmpfs” ino=2973 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=lnk_file permissive=1
[ 2.943511] init: Starting service ‘drmservice’…
[ 2.944246] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 2.944675] init: Starting service ‘up_eth0’…
[ 2.945301] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 2.945385] init: cannot find ‘/system/bin/ys_service’ (No such file or directory), disabling ‘ys_service’
[ 2.945643] init: Starting service ‘akmd’…
[ 2.946921] init: Starting service ‘zygote’…
[ 2.948137] init: Starting service ‘zygote_secondary’…
[ 2.949298] init: Starting service ‘audioserver’…
[ 2.950762] init: Starting service ‘cameraserver’…
[ 2.952375] init: Starting service ‘drm’…
[ 2.953633] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 30:1f:9a:65:19:5e
[ 2.953657] eth0: device MAC address 30:1f:9a:65:19:5e
[ 2.954976] init: Starting service ‘installd’…
[ 2.956746] init: Starting service ‘keystore’…
[ 2.958222] init: Starting service ‘mediacodec’…
[ 2.959430] type=1400 audit(1546381653.910:9): avc: denied { create } for pid=239 comm=“busybox” scontext=u:r
s0 tcontext=u:r
s0 tclass=udp_socket permissive=1
[ 2.959545] init: Starting service ‘mediadrm’…
[ 2.960856] init: Starting service ‘mediaextractor’…
[ 2.962061] init: Starting service ‘media’…
[ 2.963511] init: Starting service ‘netd’…
[ 2.964805] init: Starting service ‘crashlogd’…
[ 2.966308] init: Starting service ‘log-watch’…
[ 2.967195] init: couldn’t write 244 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 2.970280] init: Starting service ‘gatekeeperd’…
[ 2.970829] type=1400 audit(1546381653.910:10): avc: denied { net_raw } for pid=239 comm=“busybox” capability=13 scontext=u:r
s0 tcontext=u:r
s0 tclass=capability permissive=1
[ 2.973173] init: Starting service ‘perfprofd’…
[ 2.976165] type=1400 audit(1546381653.910:11): avc: denied { ioctl } for pid=239 comm=“busybox” path=“socket:[15380]” dev=“sockfs” ino=15380 ioctlcmd=8913 scontext=u:r
s0 tcontext=u:r
[ 2.976387] type=1400 audit(1546381653.910:12): avc: denied { net_admin } for pid=239 comm=“busybox” capability=12 scontext=u:r
s0 tcontext=u:r
[ 3.005155] ret = ffffffffffffffff
rk3399_firefly:/ $ [ 3.025926] init: Service ‘up_eth0’ (pid 239) exited with status 0
[ 3.026070] init: Service ‘akmd’ (pid 240) exited with status 254
[ 3.030372] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 3.030403] init: setprop: cannot expand ‘${sys.serialno}’
[ 3.040654] init: Service ‘drmservice’ (pid 238) exited with status 0
[ 3.075962] init: Starting service ‘apk_logfs’…
[ 3.078031] init: Service ‘ap_log_srv’ (pid 237) exited with status 0
[ 3.139774] read descriptors
[ 3.139834] read strings
[ 3.247960] type=1400 audit(1546381654.200:13): avc: denied { execute } for pid=300 comm=“audioserver” name=“sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.248550] type=1400 audit(1546381654.200:14): avc: denied { read open } for pid=300 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.248653] type=1400 audit(1546381654.203:15): avc: denied { execute_no_trans } for pid=300 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.249699] type=1400 audit(1546381654.203:16): avc: denied { getattr } for pid=300 comm=“sh” path=“/system/bin/sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.257787] type=1400 audit(1546381654.213:17): avc: denied { getattr } for pid=300 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.258097] type=1400 audit(1546381654.213:18): avc: denied { execute } for pid=300 comm=“sh” name=“vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.260667] type=1400 audit(1546381654.216:19): avc: denied { read open } for pid=312 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.261548] type=1400 audit(1546381654.216:20): avc: denied { execute_no_trans } for pid=312 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.323359] random: nonblocking pool is initialized
[ 3.560252] init: Starting service ‘bootanim’…
[ 3.563621] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 16
[ 3.564173] dw-mipi-dsi ff960000.dsi: final DSI-Link bandwidth: 992 x 4 Mbps
[ 3.894912] healthd: BatteryCurrentNowPath not found
[ 3.896150] healthd: BatteryCycleCountPath not found
[ 3.897212] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.897921] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.898684] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.899342] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.654468] capability: warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 6.710443] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 6.733221] >>>delay=2s
[ 8.197431] acc_open
[ 8.197593] acc_release
[ 8.739896] >>>delay=1s
[ 8.739993] parse_disp_param:105 error not find lcd_bl_delay !
[ 8.740000] >>>bl open
[ 9.029270] type=1400 audit(1546381659.983:21): avc: denied { search } for pid=253 comm=“Binder:253_1” name=“448” dev=“proc” ino=16096 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=dir permissive=1
[ 9.031306] type=1400 audit(1546381659.983:22): avc: denied { read } for pid=253 comm=“Binder:253_1” name=“cmdline” dev=“proc” ino=10919 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[ 9.031575] type=1400 audit(1546381659.983:23): avc: denied { open } for pid=253 comm=“Binder:253_1” path=“/proc/448/cmdline” dev=“proc” ino=10919 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[ 9.050429] sdcardfs version 2.0
[ 9.050457] sdcardfs: dev_name → /data/media
[ 9.050463] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=6,userid=0,gid=1015
[ 9.050469] sdcardfs: mnt → ffffffc0ced04c60
[ 9.050519] sdcardfs: mounted on top of /data/media type ext4
[ 9.051977] sdcardfs version 2.0
[ 9.051997] sdcardfs: dev_name → /data/media
[ 9.052002] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=23,userid=0,gid=9997
[ 9.052007] sdcardfs: mnt → ffffffc0cd450560
[ 9.052038] sdcardfs: mounted on top of /data/media type ext4
[ 9.053619] sdcardfs version 2.0
[ 9.053638] sdcardfs: dev_name → /data/media
[ 9.053644] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=7,userid=0,gid=9997
[ 9.053649] sdcardfs: mnt → ffffffc0cd451360
[ 9.054072] sdcardfs: mounted on top of /data/media type ext4
[ 10.494860] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 10.495356] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 10.511038] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 1043) exited with status 0
[ 10.511505] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 10.524373] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 1044) exited with status 0
[ 10.524644] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 10.540072] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1045) exited with status 0
[ 10.540367] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 10.558354] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1046) exited with status 0
[ 12.949548] type=1400 audit(1546381663.903:24): avc: granted { search } for pid=1248 comm=“.update.service” name=“recovery” dev=“mmcblk1p9” ino=12 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:cache_recovery_file:s0 tclass=dir
[ 13.364105] init: Service ‘bootanim’ is being killed…
[ 13.412467] init: Service ‘bootanim’ (pid 359) killed by signal 9
[ 13.429100] type=1400 audit(1546381664.383:25): avc: denied { getattr } for pid=1322 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.429683] type=1400 audit(1546381664.383:26): avc: denied { execute } for pid=1322 comm=“sh” name=“vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.435849] type=1400 audit(1546381664.386:27): avc: denied { read open } for pid=1324 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.436402] type=1400 audit(1546381664.390:28): avc: denied { execute_no_trans } for pid=1324 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.519605] init: avc: denied { set } for property=devicetest.bootcomplete pid=1230 uid=1000 gid=1000 scontext=u:r:system_app:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 63.895347] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 123.895063] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 183.895068] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 243.895062] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
DDR Version 1.22 20190506
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 0, cs 1, advanced training done
channel 1, cs 0, advanced training done
channel 1, cs 1, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
CPUId = 0x0
ChipType = 0x10, 225
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67875
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x83eb4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):51f2096
NOTICE: BL31: Built : 16:24:31, May 6 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Feb 25 2020 - 10:44:50)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=33
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2020-02-25#1.15
empty serial no.
tribbi 0mactribbi read screen_type:-1 hdmi_mode:-1 lcd_mipi_param:-1 lcd_pri:-1 lcd_ext:-1
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
no fuel gauge found
Secure Boot state: 0
kernel @ 0x00280000 (0x0135d008)
ramdisk @ 0x04bf0000 (0x001e76d4)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616beb … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.126 (tribbi@ani) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #14 SMP PREEMPT Tue Feb 25 10:45:43 CST 2020
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef3000 s45528 r8192 d32296 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00008000@0x003C4000(metadata),0x00000040@0x003CC000(verity_mode),0x00002000@0x003CC040(reserved),0x00000400@0x003CE040(frp),-@0x003CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2020-02-25_10:44:50 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6eab000-0xf6eeb000] (0MB) mapped at [ffffffc0f6eab000-ffffffc0f6eeafff]
[ 0.000000] Memory: 3916696K/4030464K available (11646K kernel code, 1652K rwdata, 5664K rodata, 832K init, 2407K bss, 97384K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008be0000 ( 11648 KB)
[ 0.000000] .rodata : 0xffffff8008be0000 - 0xffffff8009170000 ( 5696 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093dd008 ( 1653 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.001853] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002841] pid_max: default: 32768 minimum: 301
[ 0.003346] Security Framework initialized
[ 0.003745] SELinux: Initializing.
[ 0.004188] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004834] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006360] Initializing cgroup subsys memory
[ 0.006803] Initializing cgroup subsys freezer
[ 0.008127] sched-energy: Sched-energy-costs installed from DT
[ 0.008690] CPU0: update cpu_capacity 401
[ 0.009153] ASID allocator initialised with 32768 entries
[ 0.025984] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027246] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039390] Detected VIPT I-cache on CPU1
[ 0.039421] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039461] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039505] CPU1: update cpu_capacity 401
[ 0.039508] CPU1: Booted secondary processor [410fd034]
[ 0.049369] Detected VIPT I-cache on CPU2
[ 0.049388] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049420] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049447] CPU2: update cpu_capacity 401
[ 0.049450] CPU2: Booted secondary processor [410fd034]
[ 0.059401] Detected VIPT I-cache on CPU3
[ 0.059419] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059450] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059475] CPU3: update cpu_capacity 401
[ 0.059478] CPU3: Booted secondary processor [410fd034]
[ 0.069449] Detected PIPT I-cache on CPU4
[ 0.069477] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069516] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069556] CPU4: update cpu_capacity 1024
[ 0.069559] CPU4: Booted secondary processor [410fd082]
[ 0.079473] Detected PIPT I-cache on CPU5
[ 0.079490] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079526] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079552] CPU5: update cpu_capacity 1024
[ 0.079556] CPU5: Booted secondary processor [410fd082]
[ 0.079641] Brought up 6 CPUs
[ 0.092039] SMP: Total of 6 processors activated.
[ 0.092493] CPU features: detected feature: GIC system register CPU interface
[ 0.093180] CPU: All CPU(s) started at EL2
[ 0.093614] alternatives: patching kernel code
[ 0.095974] devtmpfs: initialized
[ 0.115470] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116398] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117701] pinctrl core: initialized pinctrl subsystem
[ 0.119654] Failed to find legacy iommu devices
[ 0.120443] NET: Registered protocol family 16
[ 0.121299] schedtune: init normalization constants…
[ 0.121782] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122396] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123020] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123627] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124237] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124837] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125443] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126051] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126692] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127301] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128009] schedtune: verify normalization constants…
[ 0.128502] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129020] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129539] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130063] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130574] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131087] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131604] schedtune: configured to support 5 boost groups
[ 0.140097] cpuidle: using governor ladder
[ 0.150100] cpuidle: using governor menu
[ 0.150478] Registered FIQ tty driver
[ 0.151228] vdso: 2 pages (1 code @ ffffff8008be6000, 1 data @ ffffff8009244000)
[ 0.151929] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.153615] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.165675] at24_parse_uboot_param:268 error not find screen_type !
[ 0.166282] at24_parse_uboot_param:268 error not find hdmi_mode !
[ 0.166868] at24_parse_uboot_param:268 error not find lcd_mipi_param !
[ 0.167487] at24_parse_uboot_param:268 error not find lcd_pri !
[ 0.168053] at24_parse_uboot_param:268 error not find lcd_ext !
[ 0.168610] uboot_param_init:
[ 0.168610] screen_type -1
[ 0.168610] hdmi_mode -1
[ 0.168610] lcd_mipi_param -1
[ 0.168610] lcd_pri -1
[ 0.181385] console [pstore-1] enabled
[ 0.181980] pstore: Registered ramoops as persistent store backend
[ 0.182561] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.184078] fiq debugger fiq mode enabled
[ [ 0.184728] console [ttyFIQ0] enabled
[ 0.185405] bootconsole [uart0] disabled
[ 0.185944] Registered fiq debugger ttyFIQ0
[ 0.216780] iommu: Adding device ff650000.vpu_service to group 0
[ 0.216861] iommu: Adding device ff660000.rkvdec to group 1
[ 0.216925] iommu: Adding device ff670000.iep to group 2
[ 0.217011] iommu: Adding device ff8f0000.vop to group 3
[ 0.217080] iommu: Adding device ff900000.vop to group 4
[ 0.217803] rk_iommu ff670800.iommu: can’t get aclk
[ 0.217818] rk_iommu ff670800.iommu: can’t get hclk
[ 0.218377] SCSI subsystem initialized
[ 0.218551] usbcore: registered new interface driver usbfs
[ 0.218593] usbcore: registered new interface driver hub
[ 0.218660] usbcore: registered new device driver usb
[ 0.218997] media: Linux media interface: v0.10
[ 0.219036] Linux video capture interface: v2.00
[ 0.219211] pps_core: LinuxPPS API ver. 1 registered
[ 0.219220] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.219241] PTP clock support registered
[ 0.220778] Advanced Linux Sound Architecture Driver Initialized.
[ 0.221240] Bluetooth: Core ver 2.21
[ 0.221279] NET: Registered protocol family 31
[ 0.221288] Bluetooth: HCI device and connection manager initialized
[ 0.221301] Bluetooth: HCI socket layer initialized
[ 0.221312] Bluetooth: L2CAP socket layer initialized
[ 0.221358] Bluetooth: SCO socket layer initialized
[ 0.222138] rockchip-cpuinfo cpuinfo: Serial : 5c7f4d0ee001de63
[ 0.222711] clocksource: Switched to clocksource arch_sys_counter
[ 0.266074] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.266325] NET: Registered protocol family 2
[ 0.266780] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.267047] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.267583] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.267669] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.267776] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.268024] NET: Registered protocol family 1
[ 0.268890] Trying to unpack rootfs image as initramfs…
[ 0.366805] Freeing initrd memory: 1948K
[ 0.367421] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.367519] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.370349] audit: initializing netlink subsys (disabled)
[ 0.370441] audit: type=2000 audit(0.366:1): initialized
[ 0.378878] VFS: Disk quotas dquot_6.6.0
[ 0.379002] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.380043] Registering sdcardfs 0.1
[ 0.383928] fuse init (API version 7.23)
[ 0.385010]
[ 0.385010] TEE Core Framework initialization (ver 1:0.1)
[ 0.385044] TEE armv7 Driver initialization
[ 0.385409] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.385427] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.385596] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.389402] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.389430] io scheduler noop registered
[ 0.389587] io scheduler cfq registered (default)
[ 0.390787] phy phy-ff770000.syscon:usb2-phy@e450.0: Failed to get VBUS supply regulator
[ 0.391884] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[ 0.391962] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.395761] backlight supply power not found, using dummy regulator
[ 0.396009] backlight1 supply power not found, using dummy regulator
[ 0.396410] iep: failed to find iep power down clock source.
[ 0.396765] IEP Power ON
[ 0.396931] IEP Power OFF
[ 0.396998] IEP Driver loaded succesfully
[ 0.397117] Module initialized.
[ 0.397377] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.397591] rk-vcodec ff650000.vpu_service: probe device
[ 0.397758] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.398222] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.398238] rk-vcodec ff650000.vpu_service: init success
[ 0.398409] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.398793] rk-vcodec ff660000.rkvdec: probe device
[ 0.398960] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.399299] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.399318] rk-vcodec ff660000.rkvdec: init success
[ 0.400945] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.400961] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.402332] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.402353] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.404186] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.404725] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.405199] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.405597] [drm] Initialized drm 1.1.0 20060810
[ 0.409275] [drm] Rockchip DRM driver version: v1.0.0
[ 0.409614] rockchip-drm display-subsystem: dmc is disabled
[ 0.409895] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.410143] rockchip-vop ff900000.vop: unable to request PWM
[ 0.410173] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.410218] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.410388] rockchip-vop ff8f0000.vop: unable to request PWM
[ 0.410403] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.410423] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 0.410668] rockchip-drm display-subsystem: master bind failed: -517
[ 0.411636] mali ff9a0000.gpu: Failed to get regulator
[ 0.411647] mali ff9a0000.gpu: Power control initialization failed
[ 0.411945] Unable to detect cache hierarchy for CPU 0
[ 0.443474] brd: module loaded
[ 0.454988] loop: module loaded
[ 0.458859] zram: Added device: zram0
[ 0.464742] get default mcu : 1
[ 0.469809] get default usb_3g : 1
[ 0.474869] get default usb_3g_wake : 1
[ 0.479931] get default usb_eth_led : 1
[ 0.484988] get default red_led : 0
[ 0.490047] get default func_io1 : 1
[ 0.495104] get default func_io2 : 1
[ 0.530133] misc_gpio_probe: Entering…
[ 0.530410] SCSI Media Changer driver v0.25
[ 0.531094] tun: Universal TUN/TAP device driver, 1.6
[ 0.531109] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.532089] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.532113] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.532124] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 0.532147] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.532299] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.532313] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.537328] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.537453] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.537467] Ring mode enabled
[ 0.537475] DMA HW capability register supported
[ 0.537481] Normal descriptors
[ 0.537490] RX Checksum Offload Engine supported (type 2)
[ 0.537497] TX Checksum insertion supported
[ 0.537504] Wake-Up On Lan supported
[ 0.537547] Enable RX Mitigation via HW Watchdog Timer
[ 0.605603] libphy: stmmac: probed
[ 0.605673] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.605685] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.607249] PPP generic driver version 2.4.2
[ 0.607470] PPP BSD Compression module registered
[ 0.607494] PPP Deflate Compression module registered
[ 0.607534] PPP MPPE Compression module registered
[ 0.607563] NET: Registered protocol family 24
[ 0.607619] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.607628] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.607649] Rockchip WiFi SYS interface (V1.00) …
[ 0.607774] usbcore: registered new interface driver catc
[ 0.607837] usbcore: registered new interface driver kaweth
[ 0.607855] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.607909] usbcore: registered new interface driver pegasus
[ 0.607970] usbcore: registered new interface driver rtl8150
[ 0.608026] usbcore: registered new interface driver r8152
[ 0.608049] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.608122] usbcore: registered new interface driver hso
[ 0.608186] usbcore: registered new interface driver asix
[ 0.608247] usbcore: registered new interface driver ax88179_178a
[ 0.608310] usbcore: registered new interface driver cdc_ether
[ 0.608365] usbcore: registered new interface driver cdc_eem
[ 0.608420] usbcore: registered new interface driver dm9601
[ 0.608503] usbcore: registered new interface driver smsc75xx
[ 0.608572] usbcore: registered new interface driver smsc95xx
[ 0.608628] usbcore: registered new interface driver gl620a
[ 0.608682] usbcore: registered new interface driver net1080
[ 0.608743] usbcore: registered new interface driver plusb
[ 0.608798] usbcore: registered new interface driver rndis_host
[ 0.608853] usbcore: registered new interface driver cdc_subset
[ 0.608911] usbcore: registered new interface driver zaurus
[ 0.608975] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.609053] usbcore: registered new interface driver int51x1
[ 0.609108] usbcore: registered new interface driver kalmia
[ 0.609173] usbcore: registered new interface driver ipheth
[ 0.609234] usbcore: registered new interface driver sierra_net
[ 0.609290] usbcore: registered new interface driver cx82310_eth
[ 0.609354] usbcore: registered new interface driver cdc_ncm
[ 0.609442] usbcore: registered new interface driver qmi_wwan
[ 0.609499] usbcore: registered new interface driver cdc_mbim
[ 0.614664] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 0.620211] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 0.621924] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.621952] ehci-pci: EHCI PCI platform driver
[ 0.622067] ehci-platform: EHCI generic platform driver
[ 0.625767] ehci-platform fe380000.usb: EHCI Host Controller
[ 0.625974] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 0.626166] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 0.636083] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 0.636242] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.636271] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.636283] usb usb1: Product: EHCI Host Controller
[ 0.636294] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 0.636304] usb usb1: SerialNumber: fe380000.usb
[ 0.636984] hub 1-0:1.0: USB hub found
[ 0.637050] hub 1-0:1.0: 1 port detected
[ 0.641214] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 0.641531] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 0.641821] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 0.649429] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 0.649649] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.649685] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.649698] usb usb2: Product: EHCI Host Controller
[ 0.649711] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 0.649749] usb usb2: SerialNumber: fe3c0000.usb
[ 0.650347] hub 2-0:1.0: USB hub found
[ 0.650407] hub 2-0:1.0: 1 port detected
[ 0.651328] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.651373] ohci-platform: OHCI generic platform driver
[ 0.651783] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 0.652004] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 0.652199] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 0.706927] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.707009] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.707227] usb usb3: Product: Generic Platform OHCI controller
[ 0.707448] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 0.707669] usb usb3: SerialNumber: fe3a0000.usb
[ 0.708569] hub 3-0:1.0: USB hub found
[ 0.708652] hub 3-0:1.0: 1 port detected
[ 0.709668] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 0.710089] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 0.710311] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 0.766914] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.766962] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.766977] usb usb4: Product: Generic Platform OHCI controller
[ 0.766990] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 0.767002] usb usb4: SerialNumber: fe3e0000.usb
[ 0.767569] hub 4-0:1.0: USB hub found
[ 0.767647] hub 4-0:1.0: 1 port detected
[ 0.769041] usbcore: registered new interface driver cdc_acm
[ 0.769055] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.769136] usbcore: registered new interface driver usblp
[ 0.769235] usbcore: registered new interface driver cdc_wdm
[ 0.769311] usbcore: registered new interface driver uas
[ 0.769499] usbcore: registered new interface driver usb-storage
[ 0.769561] usbcore: registered new interface driver ums-alauda
[ 0.769619] usbcore: registered new interface driver ums-cypress
[ 0.769677] usbcore: registered new interface driver ums-datafab
[ 0.769738] usbcore: registered new interface driver ums_eneub6250
[ 0.769832] usbcore: registered new interface driver ums-freecom
[ 0.769891] usbcore: registered new interface driver ums-isd200
[ 0.769957] usbcore: registered new interface driver ums-jumpshot
[ 0.770048] usbcore: registered new interface driver ums-karma
[ 0.770105] usbcore: registered new interface driver ums-onetouch
[ 0.770165] usbcore: registered new interface driver ums-sddr09
[ 0.770223] usbcore: registered new interface driver ums-sddr55
[ 0.770314] usbcore: registered new interface driver ums-usbat
[ 0.770424] usbcore: registered new interface driver usbserial
[ 0.770511] usbcore: registered new interface driver usbserial_generic
[ 0.770550] usbserial: USB Serial support registered for generic
[ 0.770614] usbcore: registered new interface driver option
[ 0.770688] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.770955] usbcore: registered new interface driver trancevibrator
[ 0.771004] usb20_otg: version 3.10a 21-DEC-2012
[ 0.771289] usb20_host: version 3.10a 21-DEC-2012
[ 0.772049] usbcore: registered new interface driver xpad
[ 0.772153] usbcore: registered new interface driver usb_acecad
[ 0.772246] usbcore: registered new interface driver aiptek
[ 0.772312] usbcore: registered new interface driver gtco
[ 0.772376] usbcore: registered new interface driver hanwang
[ 0.772467] usbcore: registered new interface driver kbtab
[ 0.773229] .. rk pwm remotectl v1.1 init
[ 0.773632] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.774268] sensor_register_slave:mma8452,id=17
[ 0.774316] sensor_register_slave:lis3dh,id=7
[ 0.774331] sensor_register_slave:mma7660,id=18
[ 0.774345] sensor_register_slave:lsm303d,id=22
[ 0.774359] sensor_register_slave:gs_mc3230,id=23
[ 0.774367] [Gsensor] gsensor_init
[ 0.774381] sensor_register_slave:mpu6880_acc,id=24
[ 0.774395] sensor_register_slave:mpu6500_acc,id=25
[ 0.774409] sensor_register_slave:lsm330_acc,id=26
[ 0.774423] sensor_register_slave:bma2xx_acc,id=27
[ 0.774438] sensor_register_slave:akm8975,id=30
[ 0.774454] sensor_register_slave:akm8963,id=31
[ 0.774505] sensor_register_slave:l3g4200d,id=45
[ 0.774519] sensor_register_slave:l3g20d,id=46
[ 0.774533] sensor_register_slave:ewtsa,id=47
[ 0.774547] sensor_register_slave:lsm330_gyro,id=51
[ 0.774562] sensor_register_slave:cm3217,id=53
[ 0.774576] sensor_register_slave:cm3218,id=54
[ 0.774590] sensor_register_slave:ls_stk3410,id=62
[ 0.774605] sensor_register_slave:ps_stk3410,id=67
[ 0.775554] i2c /dev entries driver
[ 0.777658] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.777863] fan53555-reg: supplied by vcc5v0_sys
[ 0.783970] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.784072] fan53555-reg: supplied by vcc5v0_sys
[ 0.788618] rk808 0-001b: Pmic Chip id: 0x0
[ 0.795685] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.795797] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.795936] DCDC_REG1: supplied by vcc3v3_sys
[ 0.797299] DCDC_REG2: supplied by vcc3v3_sys
[ 0.798483] DCDC_REG3: supplied by vcc3v3_sys
[ 0.798877] DCDC_REG4: supplied by vcc3v3_sys
[ 0.799754] LDO_REG1: supplied by vcc3v3_sys
[ 0.801598] LDO_REG2: supplied by vcc3v3_sys
[ 0.803054] LDO_REG3: supplied by vcc3v3_sys
[ 0.804476] LDO_REG4: supplied by vcc3v3_sys
[ 0.805860] LDO_REG5: supplied by vcc3v3_sys
[ 0.807279] LDO_REG6: supplied by vcc3v3_sys
[ 0.808703] LDO_REG7: supplied by vcc3v3_sys
[ 0.810107] LDO_REG8: supplied by vcc3v3_sys
[ 0.811535] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.811944] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.812638] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009a48000
[ 0.813588] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009a4a000
[ 0.814345] James DBG:>>>>>>pcf8563_probe
[ 0.814393] rtc-pcf8563 2-0051: chip found, driver version 0.4.3
[ 0.814403] James DBG:>>>>>>clear alarmtime
[ 0.816396] James DBG:>>>>>>disable getalarm
[ 0.816660] rtc-pcf8563 2-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 0.816851] @tribbi mcu_7502_probe:mcu_7502_probe
[ 0.817086] mcu_7502 initialized
[ 0.817145] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009a4c000
[ 0.818153] at24 6-0050: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 0.956062] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 0.959473] at24_parse_disp_param:225 error not find screen_type !
[ 0.959516] >>>drm screen_type = -1
[ 0.959560] at24_parse_disp_param:225 error not find lcd_vol_max !
[ 1.081013] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608
[ 1.081046] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.081057] usb 2-1: Product: USB2.0 Hub
[ 1.081757] hub 2-1:1.0: USB hub found
[ 1.082136] hub 2-1:1.0: 4 ports detected
[ 1.160077] Failed to i2c xrm117x_port_write <-6>
[ 1.160257] Failed to i2c xrm117x_port_write <-6>
[ 1.160431] Failed to i2c xrm117x_port_read <-6>
[ 1.160827] Failed to i2c xrm117x_port_read <-6>
[ 1.160993] Failed to i2c xrm117x_port_write <-6>
[ 1.161168] Failed to i2c xrm117x_port_write <-6>
[ 1.161337] Failed to i2c xrm117x_port_write <-6>
[ 1.161507] Failed to i2c xrm117x_port_read <-6>
[ 1.161859] Failed to i2c xrm117x_port_read <-6>
[ 1.162028] Failed to i2c xrm117x_port_write <-6>
[ 1.162241] xrm117x_probe~ devm_request_threaded_irq =133 result:0
[ 1.162405] goodix_ts_probe() start
[ 1.182825] <<-GTP-ERROR->> 2Failed to request GPIO:70, ERRNO:-16
[ 1.182862] <<-GTP-ERROR->> GTP request IO port failed.
[ 1.182938] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at ffffff8009a4e000
[ 1.183523] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009a50000
[ 1.184390] IR NEC protocol handler initialized
[ 1.184426] IR RC5(x/sz) protocol handler initialized
[ 1.184440] IR RC6 protocol handler initialized
[ 1.184453] IR JVC protocol handler initialized
[ 1.184489] IR Sony protocol handler initialized
[ 1.184502] IR SANYO protocol handler initialized
[ 1.184515] IR Sharp protocol handler initialized
[ 1.184530] IR MCE Keyboard/mouse protocol handler initialized
[ 1.184542] IR XMP protocol handler initialized
[ 1.184743] usbcore: registered new interface driver uvcvideo
[ 1.184770] USB Video Class driver (1.1.1)
[ 1.184786] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 1.185163] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.185292] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.185556] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.185693] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.187999] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.188630] device-mapper: uevent: version 1.0.3
[ 1.188972] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.189146] Bluetooth: HCI UART driver ver 2.3
[ 1.189163] Bluetooth: HCI UART protocol H4 registered
[ 1.189172] Bluetooth: HCI UART protocol LL registered
[ 1.189182] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.189190] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.189197] rtk_btusb: Register usb char device interface for BT driver
[ 1.189467] usbcore: registered new interface driver rtk_btusb
[ 1.189864] cpu cpu0: Failed to get leakage
[ 1.189964] cpu cpu0: Failed to get pvtm
[ 1.190207] cpu cpu4: Failed to get leakage
[ 1.190766] cpu cpu4: Failed to get pvtm
[ 1.197895] sdhci: Secure Digital Host Controller Interface driver
[ 1.197929] sdhci: Copyright(c) Pierre Ossman
[ 1.197940] Synopsys Designware Multimedia Card Interface Driver
[ 1.198733] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.198883] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.198902] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.198956] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.198996] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.199037] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.199046] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.199835] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.199892] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.199909] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.199948] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.199966] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.200049] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.200292] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 1.200313] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.200325] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.212846] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.227325] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.227670] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.229441] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.229475] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.256303] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.257016] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.259574] usbcore: registered new interface driver usbhid
[ 1.259592] usbhid: USB HID core driver
[ 1.259740] inv_mpu_iio: inv_mpu_init:746
[ 1.260305] ashmem: initialized
[ 1.263785] ff100000.saradc supply vref not found, using dummy regulator
[ 1.265287] rknandbase v1.1 2016-11-08
[ 1.265799] usbcore: registered new interface driver snd-usb-audio
[ 1.268854] es8316 1-0010: Can not read property hp_det_gpio
[ 1.273650] u32 classifier
[ 1.273685] Actions configured
[ 1.273731] Netfilter messages via NETLINK v0.30.
[ 1.273792] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.274216] ctnetlink v0.93: registering with nfnetlink.
[ 1.274992] xt_time: kernel timezone is -0000
[ 1.276592] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.277012] arp_tables: (C) 2002 David S. Miller
[ 1.277786] Initializing XFRM netlink socket
[ 1.278556] NET: Registered protocol family 10
[ 1.279992] mip6: Mobile IPv6
[ 1.280076] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.283100] sit: IPv6 over IPv4 tunneling driver
[ 1.283697] NET: Registered protocol family 17
[ 1.283793] NET: Registered protocol family 15
[ 1.283989] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.285375] Bridge firewalling registered
[ 1.285481] Ebtables v2.0 registered
[ 1.285956] Bluetooth: RFCOMM TTY layer initialized
[ 1.285972] Bluetooth: RFCOMM socket layer initialized
[ 1.286003] Bluetooth: RFCOMM ver 1.11
[ 1.286053] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.286062] Bluetooth: BNEP filters: protocol multicast
[ 1.286076] Bluetooth: BNEP socket layer initialized
[ 1.286089] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.286100] Bluetooth: HIDP socket layer initialized
[ 1.286136] l2tp_core: L2TP core driver, V2.0
[ 1.286156] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.286174] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.286504] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.286750] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 1.286926] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.287145] [WLAN_RFKILL]: >>>>James1
[ 1.287414] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.287644] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.287809] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.288052] [WLAN_RFKILL]: >>>>James3
[ 1.288252] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.288537] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.289052] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.289199] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.289439] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 91.
[ 1.289654] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.290590] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.290846] [BT_RFKILL]: ** disable irq
[ 1.291155] [BT_RFKILL]: bt_default device registered.
[ 1.291411] sensor_register_slave:mpu6500_gyro,id=49
[ 1.291430] sensor_register_slave:mpu6880_gyro,id=50
[ 1.293042] Registered cp15_barrier emulation handler
[ 1.293150] Registered setend emulation handler
[ 1.294057] registered taskstats version 1
[ 1.294776] rockchip ion idev is NULL
[ 1.294796] rga2 ff680000.rga: rga ion client create success!
[ 1.295008] rga2: Driver loaded successfully ver:3.02
[ 1.295158] rga2: Module initialized.
[ 1.295281] parse_disp_param:87 error not find screen_type !
[ 1.295308] parse_disp_param:87 error not find lvds_fmt !
[ 1.295333] parse_disp_param:87 error not find edp_cfg !
[ 1.295363] parse_disp_param:87 error not find lcd_cfg !
[ 1.295388] parse_disp_param:87 error not find lcd_face !
[ 1.295413] parse_disp_param:87 error not find lcd_map !
[ 1.295437] parse_disp_param:87 error not find hdmi_mode !
[ 1.295462] parse_disp_param:87 error not find lcd_rotate !
[ 1.295486] parse_disp_param:87 error not find dsi_lanes !
[ 1.295511] parse_disp_param:87 error not find pwm_max !
[ 1.295536] parse_disp_param:87 error not find pwm_min !
[ 1.295560] parse_disp_param:87 error not find pwm_pol !
[ 1.295589] parse_disp_param:87 error not find hid_vid !
[ 1.295613] parse_disp_param:87 error not find hid_pid !
[ 1.295638] parse_disp_param:87 error not find lcd_vol_max !
[ 1.295662] parse_disp_param:87 error not find lcd_bl_delay !
[ 1.295687] parse_disp_param:87 error not find hid_vid !
[ 1.295711] parse_disp_param:87 error not find hid_pid !
[ 1.295736] parse_disp_param:87 error not find lcd_dclk_freq !
[ 1.295758] parse_disp_param:87 error not find lcd_x !
[ 1.295780] parse_disp_param:87 error not find lcd_y !
[ 1.295811] parse_disp_param:87 error not find lcd_hsync !
[ 1.295837] parse_disp_param:87 error not find lcd_hbp !
[ 1.295865] parse_disp_param:87 error not find lcd_hfp !
[ 1.295891] parse_disp_param:87 error not find lcd_vsync !
[ 1.295917] parse_disp_param:87 error not find lcd_vbp !
[ 1.295944] parse_disp_param:87 error not find lcd_vfp !
[ 1.295956] lcd_x 0
[ 1.295956] lcd_y 0
[ 1.295956] lcd_dclk_freq -64
[ 1.295956] lcd_hsync 0
[ 1.295956] lcd_hbp 0
[ 1.295956] lcd_hfp 0
[ 1.295956] lcd_vsync 0
[ 1.295956] lcd_vbp -248940432
[ 1.295956] lcd_vfp -64
[ 1.296904] mmc1: MAN_BKOPS_EN bit is not set
[ 1.297114] tribbi panel-init-sequence-1920x1080-map0
[ 1.297156] ff960000.dsi.0 supply power not found, using dummy regulator
[ 1.298019] [drm] Rockchip DRM driver version: v1.0.0
[ 1.298555] rockchip-drm display-subsystem: dmc is disabled
[ 1.299013] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.299352] rockchip-vop ff900000.vop: unable to request PWM
[ 1.299430] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.299492] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.299702] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.299729] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.299825] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_dsi_ops)
[ 1.300489] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.300549] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.300689] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.302925] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.302955] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.302966] [drm] No driver support for vblank timestamp query.
[ 1.303362] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.308767] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.312571] mmcblk1: mmc1:0001 BJTD4R 29.1 GiB
[ 1.313228] mmcblk1boot0: mmc1:0001 BJTD4R partition 1 4.00 MiB
[ 1.316195] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.317192] mmcblk1boot1: mmc1:0001 BJTD4R partition 2 4.00 MiB
[ 1.317599] mmcblk1rpmb: mmc1:0001 BJTD4R partition 3 4.00 MiB
[ 1.318167] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.318189] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.318200] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.318210] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.318219] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.318228] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.318237] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 1.318245] backup: 0x009800000 – 0x010800000 (112 MB)
[ 1.318254] cache: 0x010800000 – 0x018800000 (128 MB)
[ 1.318263] system: 0x018800000 – 0x078800000 (1536 MB)
[ 1.318271] metadata: 0x078800000 – 0x079800000 (16 MB)
[ 1.318279] verity_mode: 0x079800000 – 0x079808000 (0 MB)
[ 1.318299] reserved: 0x079808000 – 0x079c08000 (4 MB)
[ 1.318308] frp: 0x079c08000 – 0x079c88000 (0 MB)
[ 1.318317] userdata: 0x079c88000 – 0x747800000 (27867 MB)
[ 1.318370] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 1.338319] mali ff9a0000.gpu: Failed to get leakage
[ 1.338406] mali ff9a0000.gpu: Failed to get pvtm
[ 1.339591] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.339896] mali ff9a0000.gpu: Protected mode not available
[ 1.340928] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.341108] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.341856] mali ff9a0000.gpu: Probed as mali0
[ 1.345977] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 1.346479] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 5
[ 1.346825] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.346899] xhci-hcd xhci-hcd.8.auto: irq 232, io mem 0xfe800000
[ 1.347091] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.347115] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.347128] usb usb5: Product: xHCI Host Controller
[ 1.347140] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.347152] usb usb5: SerialNumber: xhci-hcd.8.auto
[ 1.347853] hub 5-0:1.0: USB hub found
[ 1.347910] hub 5-0:1.0: 1 port detected
[ 1.348274] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 1.348580] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 6
[ 1.348673] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.348801] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.348824] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.348836] usb usb6: Product: xHCI Host Controller
[ 1.348849] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.348860] usb usb6: SerialNumber: xhci-hcd.8.auto
[ 1.349515] hub 6-0:1.0: USB hub found
[ 1.349563] hub 6-0:1.0: 1 port detected
[ 1.351905] xhci-hcd xhci-hcd.8.auto: remove, state 1
[ 1.351957] usb usb6: USB disconnect, device number 1
[ 1.356524] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.356999] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 7
[ 1.357349] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.357426] xhci-hcd xhci-hcd.9.auto: irq 233, io mem 0xfe900000
[ 1.357628] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.357644] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.357665] usb usb7: Product: xHCI Host Controller
[ 1.357677] usb usb7: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.357689] usb usb7: SerialNumber: xhci-hcd.9.auto
[ 1.358323] hub 7-0:1.0: USB hub found
[ 1.358369] hub 7-0:1.0: 1 port detected
[ 1.358726] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.358958] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 8
[ 1.359055] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.359184] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.359199] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.359212] usb usb8: Product: xHCI Host Controller
[ 1.359224] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.359236] usb usb8: SerialNumber: xhci-hcd.9.auto
[ 1.360280] hub 8-0:1.0: USB hub found
[ 1.360535] hub 8-0:1.0: 1 port detected
[ 1.363418] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.363737] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.363828] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.364076] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.364288] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.364549] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.364719] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.365566] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.373441] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microseconds.
[ 1.373473] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting reset.
[ 1.373550] xhci-hcd xhci-hcd.8.auto: USB bus 6 deregistered
[ 1.373852] xhci-hcd xhci-hcd.8.auto: remove, state 1
[ 1.373891] usb usb5: USB disconnect, device number 1
[ 1.374593] xhci-hcd xhci-hcd.8.auto: USB bus 5 deregistered
[ 1.379666] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.393026] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.424993] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.426951] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.428633] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.431589] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.435181] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.451113] >>>>vol_max = 255
[ 1.525700] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.526775] asoc-simple-card es8316-sound: ES8316 HiFi ↔ ff880000.i2s mapping ok
[ 1.526933] asoc-simple-card es8316-sound: ASoC: no source widget found for MICBIAS1
[ 1.526961] asoc-simple-card es8316-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.527074] asoc-simple-card es8316-sound: ASoC: no sink widget found for IN1P
[ 1.527100] asoc-simple-card es8316-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.527599] es8316 1-0010: ASoC: Failed to create Left Hp mixer debugfs file
[ 1.527727] es8316 1-0010: ASoC: Failed to create Right Hp mixer debugfs file
[ 1.527788] es8316 1-0010: ASoC: Failed to create HPCP L debugfs file
[ 1.528013] es8316 1-0010: ASoC: Failed to create HPCP R debugfs file
[ 1.528258] es8316 1-0010: ASoC: Failed to create HPVOL L debugfs file
[ 1.528460] es8316 1-0010: ASoC: Failed to create HPVOL R debugfs file
[ 1.531587] mmc2: new high speed SDIO card at address 0001
[ 1.534766] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.538261] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 1.538298] ======== dhd_wlan_init_plat_data ========
[ 1.538315] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.538330] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.538346] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.538364] dhd_wlan_init_gpio: host_oob_irq: 67
[ 1.538379] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.538392] dhd_wifi_platform_load: Enter
[ 1.538432] Power-up adapter ‘DHD generic adapter’
[ 1.538912] wifi_platform_set_power = 1
[ 1.538949] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.538965] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.538980] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.540005] rtc-pcf8563 2-0051: setting system clock to 2019-01-01 22:31:53 UTC (1546381913)
[ 1.541328] It doesn’t contain Rogue gpu
[ 1.587478] rockchip_headset_probe() headset have hook adc mode
[ 1.587779] input: rk_headset as /devices/platform/rk_headset/input/input1
[ 1.588701] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-102ec6d’, rk_ko_ver is ‘5’, built at ‘10:45:27’, on ‘Feb 25 2020’.
[ 1.589087] Mali: Mali device driver loaded
[ 1.589905] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 1.590732] ALSA device list:
[ 1.590905] #0: rockchip,es8316-codec
[ 1.591126] #1: rk-hdmi-dp-sound
[ 1.591982] Freeing unused kernel memory: 832K
[ 1.599764] init: init first stage started!
[ 1.659541] audit: type=1403 audit(1546381913.616:2): policy loaded auid=4294967295 ses=4294967295
[ 1.660923] init: (Initializing SELinux non-enforcing took 0.06s.)
[ 1.669273] init: init second stage started!
[ 1.677127] init: Setting ro.rk.soc=rk3399
[ 1.677295] init: OK,EMMC DRIVERS INIT OK
[ 1.677363] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 1.677444] init: property_set(“ro.hardware”, “rk30board”) failed
[ 1.680116] init: Running restorecon…
[ 1.764924] init: waitpid failed: No child processes
[ 1.765794] init: (Loading properties from /default.prop took 0.00s.)
[ 1.770695] init: (Parsing /init.environ.rc took 0.00s.)
[ 1.771720] init: (Parsing /init.usb.rc took 0.00s.)
[ 1.774118] init: ignored duplicate definition of service 'ril-daemon’init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 1.776529] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 1.776736] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 1.777019] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.777547] init: (Parsing /init.logs.rc took 0.00s.)
[ 1.777812] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 1.778071] init: (Parsing /init.coredump.rc took 0.00s.)
[ 1.778268] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 1.778470] init: (Parsing /init.kernel.rc took 0.00s.)
[ 1.778771] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 1.778855] init: (Parsing /init.debug.rc took 0.00s.)
[ 1.778930] init: (Parsing init.rockchip.rc took 0.00s.)
[ 1.779992] init: (Parsing init.connectivity.rc took 0.00s.)
[ 1.780135] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.780494] init: (Parsing init.rk3399.rc took 0.00s.)
[ 1.780760] init: init.tablet.rc: 23: invalid keyword ‘ioprio’
[ 1.780903] init: (Parsing init.tablet.rc took 0.00s.)
[ 1.781025] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.781111] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.781183] init: (Parsing /init.rk30board.rc took 0.01s.)
[ 1.782614] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 1.782788] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 1.782828] init: (Parsing /init.rc took 0.02s.)
[ 1.783440] init: Starting service ‘ueventd’…
[ 1.790831] audit: type=1400 audit(1546381913.746:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=4108 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 1.799568] ueventd: ueventd started!
[ 1.810405] ueventd: invalid gid ‘trace’
[ 1.814854] vendor storage:20160801 ret = 0
[ 1.838578] phy phy-ff770000.syscon:usb2-phy@e450.0: charger = USB_SDP_CHARGER
[ 1.869394] wifi_platform_bus_enumerate device present 1
[ 1.869421] ======== Card detection to detect SDIO card! ========
[ 1.869429] mmc2:mmc host rescan start!
[ 1.885503] bcmsdh_register: register client driver
[ 1.885755] bcmsdh_sdmmc_probe: Enter num=1
[ 1.886031] bcmsdh_sdmmc_probe: Enter num=2
[ 1.886104] bus num (host idx)=2, slot num (rca)=1
[ 1.886122] found adapter info ‘DHD generic adapter’
[ 1.886187] sdioh_attach: set sd_f2_blocksize 256
[ 1.886246] sdioh_attach: sd clock rate = 0
[ 1.886594] F1 signature read @0x18000000=0x1541a9a6
[ 1.889855] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 1.890959] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.891137] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 1.891607] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 1.896427] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 1.896805] wl_escan_attach: Enter
[ 1.896857] wl_escan_init: Enter
[ 1.897170] wl_create_event_handler(): thread:wl_escan_handler:bb started
[ 1.897271] tsk Enter, tsk = 0xffffffc0f02901a0
[ 1.897496] dhd_attach(): thread:dhd_watchdog_thread:bc started
[ 1.897552] dhd_attach(): thread:dhd_dpc:bd started
[ 1.897734] dhd_attach(): thread:dhd_rxf:be started
[ 1.897750] dhd_deferred_work_init: work queue initialized
[ 1.897775] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 1.898677] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.923868] Dongle Host Driver, version 1.579.77.41.2 (r)
[ 1.924658] Register interface [wlan0] MAC: 18:93:7f:91:13:b3
[ 1.924658]
[ 1.924817] dhd_wl_ioctl: returning as busstate=0
[ 1.924852] dhd_bus_devreset: == Power OFF ==
[ 1.925215] bcmsdh_oob_intr_unregister: Enter
[ 1.925248] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.925262] dhd_txglom_enable: enable 0
[ 1.925272] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 1.925280] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 1.925288] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[ 1.925295] sdioh_set_mode: set txglom_mode to copy
[ 1.925303] dhd_bus_devreset: WLAN OFF DONE
[ 1.925385] wifi_platform_set_power = 0
[ 1.925393] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.925402] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.925422] [WLAN_RFKILL]: wifi shut off power.
[ 1.925573] dhd_module_init: Exit err=0
[ 2.057720] ueventd: Coldboot took 0.24s.
[ 2.136769] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 2.136820] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 2.136852] init: Waiting for /dev/.coldboot_done…
[ 2.136913] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 2.136947] init: /dev/hw_random not found
[ 2.137467] keychord: using input dev ff420030.pwm for fevent
[ 2.137482] keychord: using input dev rk29-keypad for fevent
[ 2.146466] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 2.155805] Registered swp emulation handler
[ 2.156005] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 2.156684] fs_mgr: Warning: unknown flag resize
[ 2.156775] init: /dev/hw_random not found
[ 2.156854] init: write_file: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 2.157947] fs_mgr: Warning: unknown flag resize
[ 2.162641] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.162846] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 2.164402] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 2.165304] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 2.171450] random: e2fsck: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 2.209559] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.209559]
[ 2.209647] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 2.209647]
[ 2.209831] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 39/8192 files, 1772/32768 blocks (check in 4 mounts)
[ 2.209831]
[ 2.214459] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.214550] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 2.216226] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[ 2.217332] EXT4-fs (mmcblk1p11): recovery complete
[ 2.217349] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.217399] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 2.234419] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 2.234575] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 2.236788] random: e2fsck: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[ 2.248574] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.248574]
[ 2.248746] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.248746]
[ 2.253642] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.253925] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.256000] EXT4-fs (mmcblk1p15): Ignoring removed nomblk_io_submit option
[ 2.362333] EXT4-fs (mmcblk1p15): warning: maximal mount count reached, running e2fsck is recommended
[ 2.365420] EXT4-fs (mmcblk1p15): recovery complete
[ 2.366925] EXT4-fs (mmcblk1p15): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.367319] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/userdata,/data,ext4)=0: Success
[ 2.389745] fs_mgr: check_fs(): unmount(/data) succeeded
[ 2.389955] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 2.392105] random: e2fsck: uninitialized urandom read (40 bytes read, 67 bits of entropy available)
[ 2.966513] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.966513]
[ 2.966599] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/userdata has been mounted 11 times without being checked, check forced.
[ 2.966599]
[ 2.966614] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 2.966614]
[ 2.966627] e2fsck: Pass 2: Checking directory structure
[ 2.966627]
[ 2.966639] e2fsck: Pass 3: Checking directory connectivity
[ 2.966639]
[ 2.966691] e2fsck: Pass 4: Checking reference counts
[ 2.966691]
[ 2.966704] e2fsck: Pass 5: Checking group summary information
[ 2.966704]
[ 2.966718] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/userdata: 1141/1785856 files (12.2% non-contiguous), 230590/7134072 blocks
[ 2.966718]
[ 2.971603] EXT4-fs (mmcblk1p15): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.971797] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=ext4)=0
[ 2.981092] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 2.981742] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 2.982079] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 2.982473] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 2.982828] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 2.983141] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 2.983420] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 2.983737] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 2.984125] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 2.984431] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 2.984778] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 2.985058] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 2.985329] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 2.985613] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 2.986124] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 2.986456] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 2.986731] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 2.987003] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 2.987291] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 2.987582] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 2.987898] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 2.988169] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 2.988450] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 2.988732] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 2.989021] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 2.989330] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 2.989750] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 2.990063] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 2.990410] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 2.990720] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 2.991066] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 2.992948] init: Starting service ‘logd’…
[ 3.000304] random: logd: uninitialized urandom read (40 bytes read, 92 bits of entropy available)
[ 3.005461] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directory
[ 3.027702] logd.auditd: start
[ 3.027774] logd.klogd: 3025060655
[ 3.081562] midgard_kbase: disagrees about version of symbol module_layout
[ 3.084964] init: finit_module for “/system/lib/modules/mali_kbase.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 3.089176] zram0: detected capacity change from 0 to 533413888
[ 3.093220] random: mkswap: uninitialized urandom read (40 bytes read, 98 bits of entropy available)
[ 3.114473] random: mkswap: uninitialized urandom read (16 bytes read, 99 bits of entropy available)
[ 3.116349] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.119723] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 3.120408] init: property_set(“ro.rk.screenoff_time”, “60000”) failed
[ 3.120729] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 3.121075] init: (Loading properties from /system/build.prop took 0.00s.)
[ 3.121243] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.121436] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.121741] fs_mgr: Warning: unknown flag resize
[ 3.121947] init: /recovery not specified in fstab
[ 3.122861] init: Starting service ‘debuggerd’…
[ 3.124070] init: Starting service ‘debuggerd64’…
[ 3.125346] init: Starting service ‘vold’…
[ 3.127387] random: debuggerd64: uninitialized urandom read (40 bytes read, 99 bits of entropy available)
[ 3.128223] init: Not bootcharting.
[ 3.132002] random: debuggerd: uninitialized urandom read (40 bytes read, 99 bits of entropy available)
[ 3.134834] random: vold: uninitialized urandom read (40 bytes read, 100 bits of entropy available)
[ 3.172078] random: vdc: uninitialized urandom read (40 bytes read, 103 bits of entropy available)
[ 3.234739] fs_mgr: Warning: unknown flag resize
[ 3.277861] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 3.291211] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 227) exited with status 0
[ 3.296302] type=1400 audit(1546381915.253:4): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk1p15” ino=770049 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 3.300639] EXT4-fs (mmcblk1p15): Unrecognized mount option “background_gc=on” or missing value
[ 3.304611] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 3.305420] init: (Loading properties from /data/local.prop took 0.00s.)
[ 3.377859] init: Starting service ‘logd-reinit’…
[ 3.380767] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 3.385680] init: Starting service ‘healthd’…
[ 3.386767] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 3.387895] init: Starting service ‘earlylogs’…
[ 3.390189] init: Starting service ‘lmkd’…
[ 3.392117] init: Starting service ‘servicemanager’…
[ 3.392886] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[ 3.394217] init: Starting service ‘surfaceflinger’…
[ 3.397679] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 3.401242] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 3.410686] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.410785] init: write: cannot expand ‘${ro.serialno}’
[ 3.415003] file system registered
[ 3.418571] using random self ethernet address
[ 3.419065] using random host ethernet address
[ 3.421049] init: Service ‘earlylogs’ (pid 231) exited with status 0
[ 3.422854] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 3.428327] type=1400 audit(1546381915.363:5): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=15816 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 3.428518] type=1400 audit(1546381915.363:6): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=15812 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[ 3.442284] init: Service ‘logd-reinit’ (pid 229) exited with status 0
[ 3.446563] logd.daemon: reinit
[ 3.450845] type=1400 audit(1546381915.406:7): avc: denied { setattr } for pid=1 comm=“init” name=“mmcblk1p13” dev=“tmpfs” ino=15845 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 3.450980] type=1400 audit(1546381915.406:8): avc: denied { setattr } for pid=1 comm=“init” name=“mmcblk1p13” dev=“tmpfs” ino=15848 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=lnk_file permissive=1
[ 3.456870] init: Starting service ‘console’…
[ 3.460376] init: Starting service ‘adbd’…
[ 3.468791] init: Starting service ‘ap_log_srv’…
[ 3.469698] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 3.469777] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 3.470186] init: Starting service ‘drmservice’…
[ 3.470873] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 3.471258] init: Starting service ‘up_eth0’…
[ 3.471892] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 3.471985] init: cannot find ‘/system/bin/ys_service’ (No such file or directory), disabling ‘ys_service’
[ 3.472209] init: Starting service ‘akmd’…
[ 3.473284] init: Starting service ‘zygote’…
[ 3.474239] init: Starting service ‘zygote_secondary’…
[ 3.475651] init: Starting service ‘audioserver’…
[ 3.477085] init: Starting service ‘cameraserver’…
[ 3.478314] init: Starting service ‘drm’…
[ 3.479504] init: Starting service ‘installd’…
[ 3.479915] type=1400 audit(1546381915.436:9): avc: denied { create } for pid=240 comm=“busybox” scontext=u:r
s0 tcontext=u:r
s0 tclass=udp_socket permissive=1
[ 3.480370] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 30:1f:9a:65:19:5e
[ 3.480397] eth0: device MAC address 30:1f:9a:65:19:5e
[ 3.481487] init: Starting service ‘keystore’…
[ 3.482792] init: Starting service ‘mediacodec’…
[ 3.483842] init: Starting service ‘mediadrm’…
[ 3.485088] init: couldn’t write 245 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 3.485297] type=1400 audit(1546381915.436:10): avc: denied { net_raw } for pid=240 comm=“busybox” capability=13 scontext=u:r
s0 tcontext=u:r
s0 tclass=capability permissive=1
[ 3.485460] type=1400 audit(1546381915.436:11): avc: denied { ioctl } for pid=240 comm=“busybox” path=“socket:[592]” dev=“sockfs” ino=592 ioctlcmd=8913 scontext=u:r
s0 tcontext=u:r
[ 3.485560] type=1400 audit(1546381915.436:12): avc: denied { net_admin } for pid=240 comm=“busybox” capability=12 scontext=u:r
s0 tcontext=u:r
[ 3.486459] init: Starting service ‘mediaextractor’…
[ 3.488094] init: Starting service ‘media’…
[ 3.489309] init: Starting service ‘netd’…
[ 3.490408] init: Starting service ‘crashlogd’…
[ 3.491254] init: Starting service ‘log-watch’…
[ 3.492289] init: Starting service ‘gatekeeperd’…
[ 3.506870] init: Starting service ‘perfprofd’…
[ 3.507906] init: Service ‘up_eth0’ (pid 240) exited with status 0
[ 3.525042] init: Service ‘akmd’ (pid 241) exited with status 254
rk3399_firefly:/ $ [ 3.549305] random: nonblocking pool is initialized
[ 3.609457] ret = ffffffffffffffff
[ 3.610298] init: Starting service ‘apk_logfs’…
[ 3.616132] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 3.616181] init: setprop: cannot expand ‘${sys.serialno}’
[ 3.626427] init: Service ‘ap_log_srv’ (pid 238) exited with status 0
[ 3.633769] init: Service ‘drmservice’ (pid 239) exited with status 0
[ 3.678372] read descriptors
[ 3.678420] read strings
[ 3.716257] type=1400 audit(1546381915.656:13): avc: denied { execute } for pid=281 comm=“audioserver” name=“sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.716806] type=1400 audit(1546381915.656:14): avc: denied { read open } for pid=281 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.716898] type=1400 audit(1546381915.656:15): avc: denied { execute_no_trans } for pid=281 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.716982] type=1400 audit(1546381915.656:16): avc: denied { getattr } for pid=281 comm=“sh” path=“/system/bin/sh” dev=“mmcblk1p10” ino=403 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 3.717069] type=1400 audit(1546381915.663:17): avc: denied { getattr } for pid=281 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.717147] type=1400 audit(1546381915.663:18): avc: denied { execute } for pid=281 comm=“sh” name=“vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.717219] type=1400 audit(1546381915.663:19): avc: denied { read open } for pid=282 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.717516] type=1400 audit(1546381915.663:20): avc: denied { execute_no_trans } for pid=282 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.720252] type=1400 audit(1546381915.673:21): avc: denied { read } for pid=282 comm=“sh” name=“vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.720533] type=1400 audit(1546381915.676:22): avc: denied { execute } for pid=282 comm=“vm” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.740958] type=1400 audit(1546381915.696:23): avc: denied { getattr } for pid=285 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.747802] type=1400 audit(1546381915.703:24): avc: denied { open } for pid=299 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 3.753532] type=1400 audit(1546381915.703:25): avc: denied { execute_no_trans } for pid=299 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 4.108940] init: Starting service ‘bootanim’…
[ 4.111869] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 16
[ 4.112535] dw-mipi-dsi ff960000.dsi: final DSI-Link bandwidth: 992 x 4 Mbps
[ 4.395868] healthd: BatteryCurrentNowPath not found
[ 4.395925] healthd: BatteryCycleCountPath not found
[ 4.396777] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.397394] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.397972] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.398593] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 5.075983] capability: warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 7.289406] >>>delay=2s
[ 7.469662] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.595456] acc_open
[ 8.595624] acc_release
[ 9.002375] type=1400 audit(1546381920.956:26): avc: denied { search } for pid=254 comm=“Binder:254_1” name=“440” dev=“proc” ino=16614 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=dir permissive=1
[ 9.002658] type=1400 audit(1546381920.956:27): avc: denied { read } for pid=254 comm=“Binder:254_1” name=“cmdline” dev=“proc” ino=17631 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[ 9.003244] type=1400 audit(1546381920.956:28): avc: denied { open } for pid=254 comm=“Binder:254_1” path=“/proc/440/cmdline” dev=“proc” ino=17631 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[ 9.052214] sdcardfs version 2.0
[ 9.052257] sdcardfs: dev_name → /data/media
[ 9.052264] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=6,userid=0,gid=1015
[ 9.052272] sdcardfs: mnt → ffffffc0cdd76020
[ 9.052359] sdcardfs: mounted on top of /data/media type ext4
[ 9.053684] sdcardfs version 2.0
[ 9.053722] sdcardfs: dev_name → /data/media
[ 9.053728] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=23,userid=0,gid=9997
[ 9.053737] sdcardfs: mnt → ffffffc0cdd778a0
[ 9.053785] sdcardfs: mounted on top of /data/media type ext4
[ 9.054375] sdcardfs version 2.0
[ 9.054408] sdcardfs: dev_name → /data/media
[ 9.054413] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=7,userid=0,gid=9997
[ 9.054421] sdcardfs: mnt → ffffffc0cdd80720
[ 9.054463] sdcardfs: mounted on top of /data/media type ext4
[ 9.292751] >>>delay=1s
[ 9.292825] parse_disp_param:105 error not find lcd_bl_delay !
[ 9.292839] >>>bl open
[ 10.527822] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 10.528923] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 10.545709] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 1044) exited with status 0
[ 10.546185] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 10.557363] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 1047) exited with status 0
[ 10.558076] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 10.573217] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1048) exited with status 0
[ 10.573464] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 10.595145] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1049) exited with status 0
[ 13.006582] type=1400 audit(1546381924.963:29): avc: granted { search } for pid=1249 comm=“.update.service” name=“recovery” dev=“mmcblk1p9” ino=12 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:cache_recovery_file:s0 tclass=dir
[ 13.438031] init: Service ‘bootanim’ is being killed…
[ 13.452346] type=1400 audit(1546381925.406:30): avc: denied { getattr } for pid=1322 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.453223] type=1400 audit(1546381925.406:31): avc: denied { execute } for pid=1322 comm=“sh” name=“vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.454163] type=1400 audit(1546381925.410:32): avc: denied { read open } for pid=1325 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.454887] type=1400 audit(1546381925.410:33): avc: denied { execute_no_trans } for pid=1325 comm=“sh” path=“/system/xbin/vm” dev=“mmcblk1p10” ino=2830 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 13.477219] init: Service ‘bootanim’ (pid 361) killed by signal 9
[ 13.562924] init: avc: denied { set } for property=devicetest.bootcomplete pid=1230 uid=1000 gid=1000 scontext=u:r:system_app:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
