各位大神好,我现在用rk3399pro开发板,用的是mipi0接口接lt8912(mipi转hdmi芯片),我现在配置dts文件,让mipi0 接口输出mipi信号,我的dts配置如下:
修改rk3399.dtsi文件,
把 vopl节点的 status 设为"okay"
dsi: dsi@ff960000 {
compatible = “rockchip,rk3399-mipi-dsi”;
reg = <0x0 0xff960000 0x0 0x8000>;
interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI0>,
<&cru SCLK_DPHY_TX0_CFG>;
clock-names = “ref”, “pclk”, “phy_cfg”;
power-domains = <&power RK3399_PD_VIO>;
resets = <&cru SRST_P_MIPI_DSI0>;
reset-names = “apb”;
rockchip,grf = <&grf>;
status = “okay”;
#address-cells = <1>;
#size-cells = <0>;
把dsi节点的status设为"okay"
编译内核:
用的命令为:
make ARCH=arm64 firefly_defconfig
make -j8 ARCH=arm64 rk3399pro-firefly-aiojd4.img(用的是rk3399pro-firefly-aiojd4.dts )
内核运行,LOG打印出的错误如下所示:
请问:
(1)这种情况是mipi的dts配置不正确,rk3399pro mipi输出正确的dts配置是怎样的呢?
(2)rk3399pro 官方源码中,有一个rk3399pro-evb-mipi.dts文件,这个文件是否是正确的mipi dts配置。
(3)有大神做的rk3399pro mipi接口接lt8912(mipi转hdmi芯片)的项目吗,这种情况怎样配置mipi输出呢(是否把lt8912看做一个LCD屏)。
谢谢大家的不瑟吝教。
[ 355.941236] [drm] Rockchip DRM driver version: v1.0.1
[ 355.941885] rockchip-drm display-subsystem: devfreq is ready
[ 355.942205] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.942391] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 355.942425] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 355.942510] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 355.942526] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 355.942706] rockchip-drm display-subsystem: master bind failed: -517
[ 355.942941] ff960000.dsi.0 supply power not found, using dummy regulator
[ 355.943512] [drm] Rockchip DRM driver version: v1.0.1
[ 355.944150] rockchip-drm display-subsystem: devfreq is ready
[ 355.944586] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.944779] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 355.945940] [drm] Rockchip DRM driver version: v1.0.1
[ 355.948873] rockchip-drm display-subsystem: devfreq is ready
[ 355.949182] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.949363] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 355.949395] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 355.949484] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 355.949500] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 355.949680] rockchip-drm display-subsystem: master bind failed: -517
[ 355.949903] ff960000.dsi.0 supply power not found, using dummy regulator
[ 355.950476] [drm] Rockchip DRM driver version: v1.0.1
[ 355.951153] rockchip-drm display-subsystem: devfreq is ready
[ 355.951472] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.951650] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 355.951684] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 355.956565] rockchip-drm display-subsystem: master bind failed: -517
[ 355.956805] ff960000.dsi.0 supply power not found, using dummy regulator
[ 355.957364] [drm] Rockchip DRM driver version: v1.0.1
[ 355.958063] rockchip-drm display-subsystem: devfreq is ready
[ 355.958380] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.958566] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 355.958598] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 355.958689] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 355.958706] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 355.958883] rockchip-drm display-subsystem: master bind failed: -517
[ 355.959116] ff960000.dsi.0 supply power not found, using dummy regulator
[ 355.959689] [drm] Rockchip DRM driver version: v1.0.1
[ 355.960336] rockchip-drm display-subsystem: devfreq is ready
[ 355.960637] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.964986] rockchip-drm display-subsystem: devfreq is ready
[ 355.965316] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 355.965491] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 355.965523] rockchip-vop ff8f0000.vop: missing rockchip,grf property
这是LOG数据。
shushen
3
你的问题解决的了吗? 我的qq1260099535
楼主你好,我也遇到了类似的问题,我想配置两个gpio做中断接收和使能,用的pro aiojd4的开发板,我是修改的rk3399-firefly-dts文件,编译内核命令和楼主一样,但是结果配置失败,
请问楼主解决问题了吗,可以分享下吗
