px30 启动后报告已系列错误
我自己编译的固件,使用的源码是 linux-sdk-px30-20200512.7z
当PX30启动后,报告一系列错误如下,而且debug串口输入没有任何反应。
U-Boot 2017.09-g0c15140-dirty (May 29 2020 - 14:39:57 +0800)
Model: Rockchip PX30 EVB
PreSerial: 2
DRAM: 992 MiB
Sysmem: init
Relocation Offset is: 3dbe5000
dwmmc@ff370000: 1, dwmmc@ff390000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 150Mhz
PartType: EFI
boot mode: None
init_resource_list: failed to get resource part, ret=-1
Read kernel dtb failed, ret=-19
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0 KHz)
apll 600000 KHz
dpll 664000 KHz
cpll 24000 KHz
npll 1188000 KHz
gpll 1200000 KHz
aclk_bus 200000 KHz
hclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_peri 200000 KHz
hclk_peri 150000 KHz
pclk_pmu 100000 KHz
Net: No ethernet found.
** Invalid Android Image header **
Android image load failed
=Booting Rockchip format image=
Could not found misc partition
mmc_init: -95, time 9
switch to partitions #0, OK
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
## Error: “rknand_boot” not defined
starting USB…
No controllers found
USB is stopped. Please issue ‘usb start’ first.
starting USB…
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB…
No ethernet found.
是由于配置脚本使用错误造成的。
tuf 发表于 2020-5-29 21:19
是由于配置脚本使用错误造成的。
你好 我现在也遇到了这个问题 能告诉一下怎么解决的吗 具体的解决方法
