我板子上是ubuntu单系统 那为什么我把编译生成的resource.img烧到板子上后,系统就启动不了了?
http://wiki.t-firefly.com/index.php/Firefly-RK3288/UART 我按照这个教程将resource.img和boot.img烧到板子上,板子启动不了?
求大神们,指教!!!!
求大神们,指教!!!!
把log先附上来:)
zhansb 发表于 2015-6-4 11:00
把log先附上来
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-26#2.17
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x00608530)
ramdisk @ 0x04bf0000 (0x00275b8f)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480c000, end 04827184 … OK
一直重复打印这些log
parameter有更新吗?
zhansb 发表于 2015-6-4 11:58
parameter有更新吗?
没有。。。 哪里有lubuntu单系统的parameter
在SDK下面有个目录:/FFTools/parameter/
rk3288-3.10-uboot-android-data1G.parameter.txt rk3288-3.10-uboot-dual-data1G.parameter.txt rk3288-3.10-uboot-linux.parameter.txt
rk3288-3.10-uboot-android-data1G.parameter.txt rk3288-3.10- …
可以了,谢谢版主 我用的是2014的lubuntu固件,要烧写parameter, 2015的ubuntu固件就可以不用烧写parameter
在移植15.04?{:3_48:}
