把Android7.1系统固件烧写进ROC-RK3328-PC 开发板芯片里不能正常启动
DDR version 1.08 20170628
DDR3
333MHz
ddrconfig:1
Boot1 Release Time: 2017-06-12, version: 2.44
ChipType = 0x11, 171
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 21031
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x582e4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):f947c7e
NOTICE: BL31: Built : 09:28:45, May 31 2017
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:336: Initializing (1.1.0-87-g80b20ce #1 Mon May 22 06:34:06 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:337: Release version: 1.3
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3328-06 (May 15 2020 - 12:49:27)
CPU: rk3328
cpu version = 1
CPU’s clock information:
arm pll = 600000000HZ
general pll = 800000000HZ
ddr pll = 664000000HZ
codec pll = 594000000HZ
new pll = 594000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(000000003fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
remotectl v0.1
pwm freq=0x11b3dc
pwm_freq_nstime=0x35d
Load FDT from resource image.
no power key node
rk816_set_regulator_init vdd_arm init uV:1225000
rk805 pre init: 0x19 = 0x08
rk805 pre init: new otp ver, skip operation
pmic:rk805
can’t find dts node for pwm0
arm pll = 1200000000HZ
#Boot ver: 2020-05-15#2.43
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
can’t find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
left = 0, right = 0, top = 0, bottom = 0, overscan = 0
panel->left = 100 , panel->right = 100 ,panel->top = 100, panel->bottom = 100, panel->overscan = 100
tve baseparamer 0x0@0-0
Hdmi Devices Not Exist.
can’t find dts node for rk312x-tve
can’t find dts node for rk322x-tve
SCREEN_TVOUT
rk3036_tve_init:use default config g_tve_pos = 1
no fuel gauge found
checkKey
vbus = 1
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x00e63908)
ramdisk @ 0x05bf0000 (0x0019d3e8)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000561d821 … OK
Add bank:0000000009400000, 0000000036c00000
