DDR version 1.16 20190528
DDR3
333MHz
ddrconfig:1
Boot1 Release Time: Feb 2 2018 15:41:39, version: 2.46
ChipType = 0x11, 193
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 19049
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa515c
RunBL31 0x10000
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #14 Wed May 30 08:34:20 UTC 2018 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
U-Boot 2014.10-RK3328-06 (Aug 01 2019 - 10:50:15)
CPU: rk3328
cpu version = 1
CPU’s clock information:
arm pll = 600000000HZ
general pll = 1200000000HZ
ddr pll = 664000000HZ
codec pll = 1200000000HZ
new pll = 594000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(000000003fe00000)
Reserve memory for trust os.
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
remotectl v0.1
pwm freq=0x23c346
pwm_freq_nstime=0x1aa
Load FDT from resource image.
no key node
can’t find dts node for fixed
rk816_set_regulator_init vdd_arm init uV:1225000
pmic:rk805
can’t find dts node for pwm0
arm pll = 1200000000HZ
invalide header tag
ca head not found
#Boot ver: 2019-08-01#2.46
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
use default hdmi phy table
failed to find panel driver
no fuel gauge found
inno_hdmi_phy_clk_set_rate rate 27000000 tmdsclk 27000000
rockchip_panel_deinit: failed to find panel deinit funcs
can’t find dts node for rk312x-tve
can’t find dts node for rk322x-tve
Warn: vop clk request 13500000hz, but real clock is 594000000hz
rockchip_panel_prepare: failed to find panel prepare funcs
rockchip_panel_enable: failed to find panel prepare funcs
checkKey
vbus = 1
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01217808)
ramdisk @ 0x04bf0000 (0x0016c51c)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004612160 … OK
Add bank:000000000a200000, 0000000035e00000
