[ 2.651451] vcc_lcd: disabling
[ 2.651999] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘20:31:49’, on ‘Jun 18 2020’.
[ 2.654147] Mali: Mali device driver loaded
[ 2.656328] input: rk29-keypad as /devices/platform/rk_key0/input/input0
[ 2.659218] input: rk29-keypad as /devices/platform/rk_key1/input/input1
[ 2.661754] ALSA device list:
[ 2.662072] No soundcards found.
[ 2.663698] ttyS2 - failed to request DMA, use interrupt mode
[ 2.665602] Waiting for root device PARTUUID=b921b045-1d…
[ 5.058385] vendor storage:20190527 ret = -1
楼主,这个问题有进展么? 我也遇到同样的问题了。
楼主解决这个问题没?
什么情况了,我也遇到了
请问楼主怎么解决?我也碰到了。
请问楼主有进展了吗,我也遇到了同样的问题
Waiting for root device PARTUUID=b921b045-1d… 这个问题怎么解决的,我也卡在这好多天了
这是由于mmc设备树未使能
如添加:
&sdhci {
bus-width = <8>;
mmc-hs400-1_8v;
supports-emmc;
non-removable;
keep-power-in-suspend;
mmc-hs400-enhanced-strobe;
status = “okay”;
&emmc_phy {
status = “okay”;
wx__BY6Ua6 发表于 2023-8-25 14:03
这是由于mmc设备树未使能
如添加:
&sdhci {
牛!好人一生平安,谢谢。
