libtool: link: rm -fr .libs/libasan.lax
libtool: link: ( cd “.libs” && rm -f “libasan.la” && ln -s “../libasan.la” “libasan.la” )
make[6]: write error: stdout
Makefile:466: recipe for target ‘all-recursive’ failed
make[5]: *** [all-recursive] Error 1
Makefile:336: recipe for target ‘all’ failed
make[4]: *** [all] Error 2
Makefile:10757: recipe for target ‘all-target-libsanitizer’ failed
make[3]: *** [all-target-libsanitizer] Error 2
Makefile:878: recipe for target ‘all’ failed
make[2]: *** [all] Error 2
package/pkg-generic.mk:247: recipe for target ‘/home/lee/prj/Firefly-RK3308/buildroot/output/firefly_rk3308_qt_release/build/host-gcc-final-6.4.0/.stamp_built’ failed
make[1]: *** [/home/lee/prj/Firefly-RK3308/buildroot/output/firefly_rk3308_qt_release/build/host-gcc-final-6.4.0/.stamp_built] Error 2
/home/lee/prj/Firefly-RK3308/buildroot/output/firefly_rk3308_qt_release/Makefile:16: recipe for target ‘_all’ failed
make: *** [_all] Error 2
you take 1:08.63 to build builroot
====Build buildroot failed!====
lee@lee:~/prj/Firefly-RK3308$
请问哪位大神指点指点
{:4_89:}
维基教程上的编译环境是Ubuntu16.04 64bits上开发测试的,其他版本没有具体测试,可能需要对软件包做相应的调整。
1.首先切换到root用户,再解压7z文件
2.调整虚拟机内存到3GB,然后swap分区调整到3G以上
3.下载好相应的依赖包,root用户下执行试试看
