rk3308连接bt一直报错,求各位大佬指点
使用的镜像版本ROC-RK3308-CC_Buildroot_normal_20181114
1、使用如下命令,可以扫描到,但是无法连接成功,连接通过hcitool dump出现如下错误:
Create Connection (0x01|0x0005) status 0x00 ncmd 1
HCI Event: Connect Complete (0x03) plen 11
status 0x04 handle 11 bdaddr 22:22:E3:6F:1C:F6 type ACL encrypt 0x00
Error: Page Timeout
bluetoothd[453]: src/adapter.c:connect_failed_callback() hci0 22:22:E3:6F:1C:F6 status 4
bluetoothd[453]: src/adapter.c:bonding_attempt_complete() hci0 bdaddr 22:22:E3:6F:1C:F6 type 0 status 0x4
bluetoothd[453]: src/adapter.c:resume_discovery()
命令:
hciconfig hci0 up #使能蓝牙
hciconfig -a #查看设备信息
hcitool scan #扫描蓝牙设备
hciconfig hci0 iscan #可见
hciconfig hci0 pscan #开启Inquiry Scan和Page Scan,使设备处于可被搜索和可连接状态
sdptool browse local #查看自己
sdptool add A2SNK #增加Sink服务
2、使用deviceio bluetooth进行蓝牙功能测试,第一步bt_server_open时出现如下错误:Which would you like: 01
--------------- BT BLUETOOTH INIT ----------------
++++++++++ RK_BT_STATE_TURNING_ON ++++++++++
hcd_file = /system/etc/firmware/BCM4345C0.hcd
start broadcom bluetooth server bsa_sever
killall: bsa_server: no process killed
e[30;47mBSA_trace 1@ 12/31 19h:56m:51s:853ms: BSA_MgtOpenInite[30;47m
e[30;47mBSA_trace 2@ 12/31 19h:56m:51s:854ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
Created thread with thread_id= b710f1c0
e[30;47mBSA_trace 3@ 12/31 19h:56m:51s:855ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 4@ 12/31 19h:56m:51s:855ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 5@ 12/31 19h:56m:51s:855ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 6@ 12/31 19h:56m:51s:855ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 7@ 12/31 19h:56m:51s:855ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 8@ 12/31 19h:56m:51s:855ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 9@ 12/31 19h:56m:52s:856ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 10@ 12/31 19h:56m:52s:856ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 11@ 12/31 19h:56m:52s:856ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 12@ 12/31 19h:56m:52s:856ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 13@ 12/31 19h:56m:52s:856ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 14@ 12/31 19h:56m:52s:856ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 15@ 12/31 19h:56m:52s:856ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
|----- bluetooth bsa server is open ------|
e[30;47mBSA_trace 16@ 12/31 19h:56m:53s:856ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 17@ 12/31 19h:56m:53s:856ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 18@ 12/31 19h:56m:53s:856ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 19@ 12/31 19h:56m:53s:856ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 20@ 12/31 19h:56m:53s:856ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 21@ 12/31 19h:56m:53s:857ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 22@ 12/31 19h:56m:53s:857ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 23@ 12/31 19h:56m:54s:857ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 24@ 12/31 19h:56m:54s:857ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 25@ 12/31 19h:56m:54s:857ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 26@ 12/31 19h:56m:54s:857ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 27@ 12/31 19h:56m:54s:857ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 28@ 12/31 19h:56m:54s:857ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 29@ 12/31 19h:56m:54s:857ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 30@ 12/31 19h:56m:55s:857ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 31@ 12/31 19h:56m:55s:857ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 32@ 12/31 19h:56m:55s:857ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 33@ 12/31 19h:56m:55s:857ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 34@ 12/31 19h:56m:55s:858ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 35@ 12/31 19h:56m:55s:858ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 36@ 12/31 19h:56m:55s:858ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 37@ 12/31 19h:56m:56s:858ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 38@ 12/31 19h:56m:56s:858ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 39@ 12/31 19h:56m:56s:858ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 40@ 12/31 19h:56m:56s:858ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 41@ 12/31 19h:56m:56s:858ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 42@ 12/31 19h:56m:56s:858ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 43@ 12/31 19h:56m:56s:858ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 44@ 12/31 19h:56m:57s:858ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 45@ 12/31 19h:56m:57s:858ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 46@ 12/31 19h:56m:57s:858ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 47@ 12/31 19h:56m:57s:859ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 48@ 12/31 19h:56m:57s:859ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 49@ 12/31 19h:56m:57s:859ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 50@ 12/31 19h:56m:57s:859ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 51@ 12/31 19h:56m:58s:859ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 52@ 12/31 19h:56m:58s:859ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 53@ 12/31 19h:56m:58s:859ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 54@ 12/31 19h:56m:58s:859ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 55@ 12/31 19h:56m:58s:859ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 56@ 12/31 19h:56m:58s:859ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 57@ 12/31 19h:56m:58s:859ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 58@ 12/31 19h:56m:59s:860ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 59@ 12/31 19h:56m:59s:860ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 60@ 12/31 19h:56m:59s:860ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 61@ 12/31 19h:56m:59s:860ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 62@ 12/31 19h:56m:59s:860ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 63@ 12/31 19h:56m:59s:860ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 64@ 12/31 19h:56m:59s:860ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 65@ 12/31 19h:57m:00s:860ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 66@ 12/31 19h:57m:00s:860ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 67@ 12/31 19h:57m:00s:860ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 68@ 12/31 19h:57m:00s:860ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 69@ 12/31 19h:57m:00s:860ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 70@ 12/31 19h:57m:00s:860ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 71@ 12/31 19h:57m:00s:860ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
#### Please Input Your Test Command Index ####
开启bluetoothd,可以看到设备,连接显示连接失败,求大佬指点
bluetoothd[426]: profiles/audio/avrcp.c:avrcp_target_probe() path /org/bluez/hci0/dev_22_22_E3_6F_1C_F6
bluetoothd[426]: src/service.c:btd_service_ref() 0x2acd8d70: ref=2
bluetoothd[426]: src/service.c:change_state() 0x2acd8d70: device 22:22:E3:6F:1C:F6 profile audio-avrcp-target state changed: unavailable → disconnected (0)
bluetoothd[426]: profiles/audio/a2dp.c:a2dp_source_probe() path /org/bluez/hci0/dev_22_22_E3_6F_1C_F6
bluetoothd[426]: profiles/audio/source.c:source_init() /org/bluez/hci0/dev_22_22_E3_6F_1C_F6
bluetoothd[426]: src/service.c:btd_service_ref() 0x2acd38a0: ref=2
bluetoothd[426]: src/service.c:change_state() 0x2acd38a0: device 22:22:E3:6F:1C:F6 profile a2dp-source state changed: unavailable → disconnected (0)
bluetoothd[426]: src/device.c:device_svc_resolved() /org/bluez/hci0/dev_22_22_E3_6F_1C_F6 err 0
bluetoothd[426]: src/adapter.c:dev_disconnected() Device 22:22:E3:6F:1C:F6 disconnected, reason 2
bluetoothd[426]: src/adapter.c:adapter_remove_connection()
bluetoothd[426]: plugins/policy.c:disconnect_cb() reason 2
bluetoothd[426]: src/adapter.c:bonding_attempt_complete() hci0 bdaddr 22:22:E3:6F:1C:F6 type 0 status 0xe
bluetoothd[426]: src/device.c:device_bonding_complete() bonding (nil) status 0x0e
bluetoothd[426]: src/device.c:device_bonding_failed() status 14
bluetoothd[426]: src/adapter.c:resume_discovery()
top命令看一下是不是运行了brcm_patchram_plus1程序,如果有运行,kill掉它再使用deviceio
没有这个,确定还是不行,主要用他官方镜像也是一样问题,不是硬件问题吧?
试一下重启一遍直接用deviceio,如果不行试一下下面的代码然后用bluetoothctl工具连接一下手机看行不行
bt_load_broadcom_firmware
usr/libexec/bluetooth/bluetoothd --compat -n  &
sleep 1
sdptool add A2SNK
sleep 1
hciconfig hci0 up
sleep 1
hciconfig hci0 piscan
sleep 1
hciconfig hci0 name 'bt-test'
sleep 1
hciconfig hci0 down
sleep 1
hciconfig hci0 up
sleep 2
bluealsa --profile=a2dp-sink &
sleep 1
bluealsa-aplay --profile-a2dp 00:00:00:00:00:00 &
sleep 1
hciconfig hci0 class 0x240404
谢谢大佬,用的ap6236,就是firefly官方的cc开发板,我试试
建议你先看一下buildroot是否配置了ap6236,我看你的蓝牙固件好像不对
好的谢谢大佬
大佬,我这改了还是一样的错误,
hcd_file = /system/etc/firmware/BCM4343B0.hcd
e[30;47mBSA_trace 1@ 12/31 19h:00m:31s:836ms: BSA_MgtOpenInite[30;47m
e[30;47mBSA_trace 2@ 12/31 19h:00m:31s:837ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
Created thread with thread_id= a3f821c0
e[30;47mBSA_trace 3@ 12/31 19h:00m:31s:838ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 4@ 12/31 19h:00m:31s:839ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 5@ 12/31 19h:00m:31s:839ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 6@ 12/31 19h:00m:31s:839ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 7@ 12/31 19h:00m:31s:840ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 8@ 12/31 19h:00m:31s:840ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 9@ 12/31 19h:00m:32s:840ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 10@ 12/31 19h:00m:32s:840ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 11@ 12/31 19h:00m:32s:840ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 12@ 12/31 19h:00m:32s:840ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 13@ 12/31 19h:00m:32s:841ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 14@ 12/31 19h:00m:32s:841ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 15@ 12/31 19h:00m:32s:841ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 16@ 12/31 19h:00m:33s:841ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 17@ 12/31 19h:00m:33s:842ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 18@ 12/31 19h:00m:33s:842ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 19@ 12/31 19h:00m:33s:842ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 20@ 12/31 19h:00m:33s:842ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 21@ 12/31 19h:00m:33s:842ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 22@ 12/31 19h:00m:33s:842ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 23@ 12/31 19h:00m:34s:843ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 24@ 12/31 19h:00m:34s:843ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 25@ 12/31 19h:00m:34s:843ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 26@ 12/31 19h:00m:34s:843ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 27@ 12/31 19h:00m:34s:843ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 28@ 12/31 19h:00m:34s:843ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 29@ 12/31 19h:00m:34s:843ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 30@ 12/31 19h:00m:35s:844ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 31@ 12/31 19h:00m:35s:844ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 32@ 12/31 19h:00m:35s:844ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 33@ 12/31 19h:00m:35s:844ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 34@ 12/31 19h:00m:35s:844ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 35@ 12/31 19h:00m:35s:845ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 36@ 12/31 19h:00m:35s:845ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 37@ 12/31 19h:00m:36s:845ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 38@ 12/31 19h:00m:36s:845ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 39@ 12/31 19h:00m:36s:845ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 40@ 12/31 19h:00m:36s:845ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 41@ 12/31 19h:00m:36s:845ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 42@ 12/31 19h:00m:36s:846ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 43@ 12/31 19h:00m:36s:846ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 44@ 12/31 19h:00m:37s:846ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 45@ 12/31 19h:00m:37s:846ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 46@ 12/31 19h:00m:37s:846ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 47@ 12/31 19h:00m:37s:846ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 48@ 12/31 19h:00m:37s:847ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 49@ 12/31 19h:00m:37s:847ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 50@ 12/31 19h:00m:37s:847ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 51@ 12/31 19h:00m:38s:847ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 52@ 12/31 19h:00m:38s:848ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 53@ 12/31 19h:00m:38s:848ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 54@ 12/31 19h:00m:38s:848ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 55@ 12/31 19h:00m:38s:848ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 56@ 12/31 19h:00m:38s:848ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 57@ 12/31 19h:00m:38s:848ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 58@ 12/31 19h:00m:39s:849ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 59@ 12/31 19h:00m:39s:849ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 60@ 12/31 19h:00m:39s:849ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 61@ 12/31 19h:00m:39s:849ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 62@ 12/31 19h:00m:39s:849ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 63@ 12/31 19h:00m:39s:849ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 64@ 12/31 19h:00m:39s:849ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
e[30;47mBSA_trace 65@ 12/31 19h:00m:40s:850ms: BSA_MgtOpen (/data/bsa/config/)e[30;47m
e[30;47mBSA_trace 66@ 12/31 19h:00m:40s:850ms: bsa_cl_mgt_inite[30;47m
e[30;47mBSA_trace 67@ 12/31 19h:00m:40s:850ms: UIPC_Inite[30;47m
e[30;47mBSA_trace 68@ 12/31 19h:00m:40s:850ms: UIPC_Open ChId:3e[30;47m
e[31;47mBSA_trace 69@ 12/31 19h:00m:40s:850ms: uipc_cl_socket_connect: connect(/data/bsa/config/./bt-daemon-socket) failed(No such file or directory)e[30;47m
e[31;47mBSA_trace 70@ 12/31 19h:00m:40s:850ms: uipc_cl_control_open fails to connect control sockete[30;47m
e[31;47mBSA_trace 71@ 12/31 19h:00m:40s:850ms: BSA_MgtOpen UIPC_open fails (cannot connect to server)e[30;47m
ps结果如下
1 root 2400 S init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [kworker/0:0]
5 root 0 SW< [kworker/0:0H]
6 root 0 SW [kworker/u8:0]
7 root 0 SW [rcu_preempt]
8 root 0 SW [rcu_sched]
9 root 0 SW [rcu_bh]
10 root 0 SW [migration/0]
11 root 0 SW [watchdog/0]
12 root 0 SW [watchdog/1]
13 root 0 SW [migration/1]
14 root 0 SW [ksoftirqd/1]
15 root 0 SW [kworker/1:0]
16 root 0 SW< [kworker/1:0H]
17 root 0 SW [watchdog/2]
18 root 0 SW [migration/2]
19 root 0 SW [ksoftirqd/2]
20 root 0 SW [kworker/2:0]
21 root 0 SW< [kworker/2:0H]
22 root 0 SW [watchdog/3]
23 root 0 SW [migration/3]
24 root 0 SW [ksoftirqd/3]
25 root 0 SW [kworker/3:0]
26 root 0 SW< [kworker/3:0H]
27 root 0 SW [kdevtmpfs]
28 root 0 SW< [perf]
29 root 0 SW [kconsole]
30 root 0 SW [khungtaskd]
31 root 0 SW< [writeback]
32 root 0 SW< [crypto]
33 root 0 SW< [bioset]
34 root 0 SW< [kblockd]
35 root 0 SW< [devfreq_wq]
36 root 0 SW [kworker/0:1]
37 root 0 SW< [cfg80211]
38 root 0 SW [cfinteractive]
39 root 0 SW [kworker/u8:1]
65 root 0 SW [kswapd0]
66 root 0 SW< [vmstat]
67 root 0 SW [fsnotify_mark]
68 root 0 SW< [SquashFS read w]
89 root 0 SW [irq/197-rockchi]
90 root 0 SW [irq/198-rockchi]
91 root 0 SW [irq/199-rockchi]
92 root 0 SW [irq/200-rockchi]
93 root 0 SW [kworker/2:1]
94 root 0 SW [hwrng]
95 root 0 SW [kworker/1:1]
96 root 0 SW< [bioset]
97 root 0 SW< [bioset]
98 root 0 SW< [bioset]
99 root 0 SW< [bioset]
100 root 0 SW< [bioset]
101 root 0 SW< [bioset]
102 root 0 SW< [bioset]
103 root 0 SW< [bioset]
106 root 0 SW< [dwc2]
107 root 0 SW [kworker/3:1]
108 root 0 SW [irq/14-rockchip]
109 root 0 SW [kworker/0:2]
110 root 0 SW< [ipv6_addrconf]
111 root 0 SW< [krfcommd]
112 root 0 SW< [bioset]
113 root 0 SW [mmcqd/1]
114 root 0 SW< [bioset]
115 root 0 SW [mmcqd/1boot0]
116 root 0 SW< [bioset]
119 root 0 SW [mmcqd/1boot1]
120 root 0 SW< [bioset]
121 root 0 SW [mmcqd/1rpmb]
122 root 0 SW< [deferwq]
123 root 0 SW [kworker/u8:2]
124 root 0 SW [kworker/u8:3]
126 root 0 SW [kworker/1:2]
127 root 0 SW [kworker/3:2]
128 root 0 SW [kworker/2:2]
129 root 0 SW< [kworker/3:1H]
131 root 0 SW< [kworker/2:1H]
134 root 0 SW< [kworker/1:1H]
135 root 0 SW< [kworker/0:1H]
136 root 0 SW [kworker/1:3]
145 root 2400 S /sbin/syslogd -n
148 root 2400 S /sbin/klogd -n
152 root 0 SW [wl_escan_handle]
153 root 0 SW [dhd_watchdog_th]
154 root 0 SW [dhd_dpc]
155 root 0 SW [dhd_rxf]
156 root 3260 S /sbin/udevd -d
256 dbus 2716 S dbus-daemon --system
283 root 2776 S /sbin/dhcpcd -f /etc/dhcpcd.conf
287 root 72200 S /usr/sbin/ntpd -g
294 root 0 SW< [dhd_eventd]
295 root 2328 S /usr/sbin/dropbear -R
321 root 236m R adbd
352 root 2592 S /usr/sbin/dnsmasq
354 root 5616 S /usr/bin/eq_drc_process
377 root 4440 S wpa_supplicant -B -i wlan0 -c /data/cfg/wpa_supplica
386 root 2400 S -/bin/sh
392 root 2400 S /bin/sh -
398 root 15968 S deviceio_test bluetooth
433 root 0 SW [kworker/2:3]
444 root 2400 S /bin/sh -
446 root 2400 R ps
whopawho 发表于 2020-7-30 16:52
大佬,我这改了还是一样的错误,
有可能是你的配置未生效,我这边是可以的,你试一下以下操作:
在buildroot/output/firefly_rk3308_release中make menuconfig搜索broadcom,选择broadcom(ampak)服务,支持的芯片选择AP6236保存后make savedefconfig
回到sdk的根目录rk3308/linux/或prj/Firefly-RK3308执行
make broadcom_bsa-dirclean && make broadcom_bsa-rebuild
make deviceio-dirclean && make deviceio-rebuild
./build.sh
将固件烧进开发板后测试
在buildroot/output/firefly_rk3308_re …
好的我试试,大佬,bluealsa a2dp调节source音量怎么用,bluealsa和bluealsa-aplay关系是啥,这个资料太少了,去github看的满头雾水
whopawho 发表于 2020-7-31 10:38
好的我试试,大佬,bluealsa a2dp调节source音量怎么用,bluealsa和bluealsa-aplay关系是啥,这个资料太 …
其他的用法和应用之类的要自己网上搜一下或参考external/broadcom_bsa里面的应用
好的谢谢大佬{:4_123:}
可以了谢谢大佬,firefly自己代码bsa目录没修改,手动修改就可以了,firefly这个理论上应该验证过的呀
如何手动修改?
diff --git a/buildroot/package/rockchip/broadcom_bsa/Config.in b/buildroot/package/rockchip/broadcom_bsa/Config.in
    index d69fd18..8395ecf 100644
    --- a/buildroot/package/rockchip/broadcom_bsa/Config.in
    +++ b/buildroot/package/rockchip/broadcom_bsa/Config.in
    @@ -7,6 +7,8 @@ choice
            default BR2_PACKAGE_BROADCOM_BSA_AP6255
        prompt "wifi/bt chip support"
    +       config BR2_PACKAGE_BROADCOM_BSA_AP6236
    +                bool "AP6236"
            config BR2_PACKAGE_BROADCOM_BSA_AP6255
                    bool "AP6255"
diff --git a/buildroot/package/rockchip/broadcom_bsa/broadcom_bsa.mk b/buildroot/package/rockchip/broadcom_bsa/broadcom_bsa.mk
    index 44122ac..6e44a82 100644
    --- a/buildroot/package/rockchip/broadcom_bsa/broadcom_bsa.mk
    +++ b/buildroot/package/rockchip/broadcom_bsa/broadcom_bsa.mk
    @@ -23,6 +23,12 @@ ifeq ($(BR2_PACKAGE_BROADCOM_BSA_AP6255),y)
            BTFIRMWARE = BCM4345C0.hcd
    endif
    +ifeq ($(BR2_PACKAGE_BROADCOM_BSA_AP6236),y)
    +        BTFIRMWARE = BCM4343B0.hcd
    +endif
    ifeq ($(BR2_PACKAGE_BROADCOM_BSA_AP6212A1),y)
            BTFIRMWARE = bcm43438a1.hcd
    endif
你好,楼主,你的问题解决了吗?我目前也是遇到跟你一样的问题,还请帮忙回复下
你好,请问一下是怎么解决的,我也遇到了这个问题
请问楼主问题解决了吗?我在其他平台上也遇到了同样的问题,bluetoothd抓到的日志和你的一致
