PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=8.1.0
TARGET_PRODUCT=rk3399_firefly_mid
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=cortex-a53
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv7-a-neon
TARGET_2ND_CPU_VARIANT=cortex-a15
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.4.0-40-generic-x86_64-with-Ubuntu-20.04-focal
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=OPM6.171019.030.B1
OUT_DIR=out
ninja: no work to do.
wildcard(out/target/product/rk3399_firefly_mid/clean_steps.mk) was changed, regenerating…
[4/1057] including ./bootable/recovery/Android.mk …
./bootable/recovery/Android.mk:101: warning: *** Redirect log to UART
[491/1057] including ./hardware/rockchip/librga/Android.mk …
Generated version.h
[493/1057] including ./hardware/rockchip/omx_il/Android.mk …
[1057/1057] including ./vendor/rockchip/common/vpu/Android.mk …
PRODUCT_COPY_FILES device/rockchip/common/init.rk30board.usb.rc:root/init.rk30board.usb.rc ignored.
PRODUCT_COPY_FILES vendor/rockchip/common/nand/modules/arm/rk30xxnand_ko.ko.3.10.0:root/rk30xxnand_ko.ko ignored.
PRODUCT_COPY_FILES vendor/rockchip/common/nand/modules/arm/drmboot.ko:root/drmboot.ko ignored.
No private recovery resources for TARGET_DEVICE rk3399_firefly_mid
build/core/aapt2.mk:32: warning: overriding commands for target out/target/product/rk3399_firefly_mid/obj/APPS/Bluetooth_intermediates/flat-res/device/rockchip/common/overlay/packages/apps/Bluetooth/res/values_config.arsc.flat' build/core/aapt2.mk:32: warning: ignoring old commands for target out/target/product/rk3399_firefly_mid/obj/APPS/Bluetooth_intermediates/flat-res/device/rockchip/common/overlay/packages/apps/Bluetooth/res/values_config.arsc.flat’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399_firefly_mid/vendor/lib/libjpeghwenc.so' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399_firefly_mid/vendor/lib/libjpeghwenc.so’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399_firefly_mid/vendor/lib/libjpeghwdec.so' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399_firefly_mid/vendor/lib/libjpeghwdec.so’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399_firefly_mid/vendor/lib64/libjpeghwenc.so' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399_firefly_mid/vendor/lib64/libjpeghwenc.so’
[ 83% 5/6] glob art
[ 0% 419/79563] Ensuring Jack server is installed and started
FAILED: setup-jack-server
/bin/bash -c “(prebuilts/sdk/tools/jack-admin install-server prebuilts/sdk/tools/jack-launcher.jar prebuilts/sdk/tools/jack-server-4.11.ALPHA.jar 2>&1 || (exit 0) ) && (JACK_SERVER_VM_ARGUMENTS="-Dfile.encoding=UTF-8 -XX:+TieredCompilation" prebuilts/sdk/tools/jack-admin start-server 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update server prebuilts/sdk/tools/jack-server-4.11.ALPHA.jar 4.11.ALPHA 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-4.32.CANDIDATE.jar 4.32.CANDIDATE || exit 47 )”
Jack server already installed in “/home/chris/.jack-server”
Communication error with Jack server (6), try ‘jack-diagnose’ or see Jack server log
Communication error with Jack server 6. Try ‘jack-diagnose’
[ 0% 426/79563] target C++: libv8src <= external/v8/src/ast/scopes.cc
ninja: build stopped: subcommand failed.
11:27:15 ninja failed with: exit status 1
