Git log:date 2020.4.17 16:43:55 author:zhongw
执行如下步骤,再统一编译生成img过程中报错:
1、修改kernel/arch/arm64/boot/dts/rockchip/rk3308b-roc-cc-plus-amic_emmc.dts文件将dts文件中的chosen中的bootargs改为bootargs=“earlycon=uart8250,mmio32,0xff0c0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext2 rootwait”;
2、修改 device/rockchip/rk3308/roc-rk3308b-cc-plus_release_BoardConfig.mk中的ROOTFS_TYPE=ext2
3、在SDK根目录下执行./build.sh roc-rk3308b-cc-plus_release_BoardConfig.mk
4、./build.sh
在执行第4步骤过程中,编译报错,如下:
make[3]:write error: stdout
Makefile:4113: recipe for target ‘all-gcc’ failed
make[2]: *** [all-gcc] Error 1
package/pkg-generic.mk:247: recipe for target ‘/home/buildroot/output/firefly_rk3308_release/build/host-gcc-initial-6.4.0/.stamp_build’ failed
make[1]: *** [/home/buildroot/output/firefly_rk3308_release/build/host-gcc-initial-6.4.0/.stamp_build] Error2
/home/buildroot/output/firefly_rk3308_release/Makefile:16:recipe for targe ‘_all’ failed
make: *** [_all] Error 2
you take 16:14.09 to build builroot
====Build buildroot failed!====
请大神帮忙分析和解决,谢谢!
- 尝试增大编译环境的Ubuntu 内存或者swap分区大小
- 参考维基教程安装编译需要依赖的软件包
已将ubuntu内存从2G改为4G,重新./bulid.sh后,仍然出现同样的ERR问题。
libtool: link: /home/buildroot/output/firefly_rk3308_release/host/aarch64-rockchip-linux-gnu/bin/ranlib .libs/libsanitizer_common.a
libtool: link: ( cd “.libs” && rm -f “libsanitizer_common.la” && ln -s “../libsanitizer_common.la” “libsanitizer_common.la” )
make[6]: write error: stdout
Makefile:466: recipe for target ‘all-recursive’ failed
make[5]: *** [all-recursive] Error 1
Makefile:336: recipe for target ‘all’ failed
make[4]: *** [all] Error 2
Makefile:10757: recipe for target ‘all-target-libsanitizer’ failed
make[3]: *** [all-target-libsanitizer] Error 2
Makefile:878: recipe for target ‘all’ failed
make[2]: *** [all] Error 2
package/pkg-generic.mk:247: recipe for target ‘/home/buildroot/output/firefly_rk3308_release/build/host-gcc-final-6.4.0/.stamp_built’ failed
make[1]: *** [/home/buildroot/output/firefly_rk3308_release/build/host-gcc-final-6.4.0/.stamp_built] Error 2
/home/buildroot/output/firefly_rk3308_release/Makefile:16: recipe for target ‘_all’ failed
- 推荐使用Ubuntu 16.04 的系统进行编译。其他版本没有具体测试,可能需要对软件包做相应调整。
- 编译若遇到报错,可以视报错信息,安装对应的软件包。
尝试安装如下软件包:
sudo apt-get install libncurses5-dev
