自已打版,并用 ROC-RK3308-CC_Buildroot_normal_20181114.img 镜像, 有以下的 讯息, 之後一直就在这里,请帮忙…
pwm-regulator(vdd-core): init 1044000 uV
regulator(vdd-core) init 1044000 uV
MMC: dwmmc@ff490000: 0
In: serial@ff0c0000
Out: serial@ff0c0000
Err: serial@ff0c0000
Model: Rockchip RK3308 EVB
MMC Device 1 not found
no mmc device at slot 1
switch to partitions #0, OK
enter Recovery mode!
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98303 KHz
pclk_audio 98303 KHz
Net: Net Initialization Skipped
No ethernet found.
ANDROID: reboot reason: "recovery"
FDT load addr 0x10f00000 size 253 KiB
Booting kernel at 0x4080000 with fdt at 4acb000...
## Booting Android Image at 0x04080000 ...
Kernel load addr 0x02080000 size 4635 KiB
RAM disk load addr 0x11000000 size 5900 KiB
## Flattened Device Tree blob at 04acb000
Booting using the fdt blob at 0x4acb000
Uncompressing Kernel Image ... OK
Loading Ramdisk to 0ef51000, end 0f513eff ... OK
Loading Device Tree to 000000000ef3d000, end 000000000ef50205 ... OK
Adding bank: start=0x00200000, size=0x0fe00000
Starting kernel ...
[ 0.000000] Linux version 4.4.143 (guanzl@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Tue Nov 13 10:30:07 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0c0000 (options '')
[ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] PERCPU: Embedded 19 pages/cpu @ffffffc00ff54000 s40088 r8192 d29544 u77824
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64008
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rootwait earlycon=uart8250,mmio32,0xff0c0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=squashfs snd_aloop.index=7
[ 0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] software IO TLB [mem 0x0feb4000-0x0fef4000] (0MB) mapped at [ffffffc00feb4000-ffffffc00fef3fff]
[ 0.000000] Memory: 239396K/260096K available (5758K kernel code, 418K rwdata, 2112K rodata, 384K init, 502K bss, 20700K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008840000 - 0xffffff80088a0000 ( 384 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008620000 ( 5760 KB)
[ 0.000000] .rodata : 0xffffff8008620000 - 0xffffff8008840000 ( 2176 KB)
[ 0.000000] .data : 0xffffff80088a0000 - 0xffffff8008908808 ( 419 KB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc010000000 ( 254 MB)
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001756] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002706] pid_max: default: 32768 minimum: 301
[ 0.003258] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.003860] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.005289] sched-energy: CPU device node has no sched-energy-costs
[ 0.005907] Invalid sched_group_energy for CPU0
[ 0.006326] CPU0: update cpu_capacity 1024
[ 0.006750] ASID allocator initialised with 65536 entries
[ 0.016479] Detected VIPT I-cache on CPU1
[ 0.016534] Invalid sched_group_energy for CPU1
[ 0.016540] CPU1: update cpu_capacity 1024
[ 0.016544] CPU1: Booted secondary processor [410fd042]
[ 0.019500] Detected VIPT I-cache on CPU2
[ 0.019538] Invalid sched_group_energy for CPU2
[ 0.019542] CPU2: update cpu_capacity 1024
[ 0.019546] CPU2: Booted secondary processor [410fd042]
[ 0.022542] Detected VIPT I-cache on CPU3
[ 0.022577] Invalid sched_group_energy for CPU3
[ 0.022582] CPU3: update cpu_capacity 1024
[ 0.022586] CPU3: Booted secondary processor [410fd042]
[ 0.022654] Brought up 4 CPUs
[ 0.027858] SMP: Total of 4 processors activated.
[ 0.028297] CPU: All CPU(s) started at EL2
[ 0.028814] Invalid sched_group_energy for CPU3
[ 0.029236] Invalid sched_group_energy for Cluster3
[ 0.029698] Invalid sched_group_energy for CPU2
[ 0.030116] Invalid sched_group_energy for Cluster2
[ 0.030564] Invalid sched_group_energy for CPU1
[ 0.030991] Invalid sched_group_energy for Cluster1
[ 0.031440] Invalid sched_group_energy for CPU0
[ 0.031856] Invalid sched_group_energy for Cluster0
[ 0.032821] devtmpfs: initialized
[ 0.050982] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.051920] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.052884] pinctrl core: initialized pinctrl subsystem
[ 0.054474] NET: Registered protocol family 16
[ 0.059478] cpuidle: using governor menu
[ 0.059870] Registered FIQ tty driver
[ 0.060552] vdso: 2 pages (1 code @ ffffff8008626000, 1 data @ ffffff80088a4000)
[ 0.061260] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.062092] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.065561] console [pstore-1] enabled
[ 0.065913] pstore: Registered ramoops as persistent store backend
[ 0.066498] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.084998] fiq debugger fiq mode enabled
[[ 0.085747] console [ttyFIQ0] enabled
[ 0.086444] bootconsole [uart0] disabled
[ 0.087057] Registered fiq debugger ttyFIQ0
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.101845] vcc_1v8: regulator get failed, ret=-517
[ 0.102691] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.103481] vcc_1v8: supplied by vcc_io
[ 0.103571] vcc_1v8_codec: supplied by vcc_io
[ 0.105977] SCSI subsystem initialized
[ 0.106276] usbcore: registered new interface driver usbfs
[ 0.106353] usbcore: registered new interface driver hub
[ 0.106480] usbcore: registered new device driver usb
[ 0.106622] pps_core: LinuxPPS API ver. 1 registered
[ 0.106636] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.106672] PTP clock support registered
[ 0.107866] Advanced Linux Sound Architecture Driver Initialized.
[ 0.108534] Bluetooth: Core ver 2.21
[ 0.108596] NET: Registered protocol family 31
[ 0.108609] Bluetooth: HCI device and connection manager initialized
[ 0.108630] Bluetooth: HCI socket layer initialized
[ 0.108646] Bluetooth: L2CAP socket layer initialized
[ 0.108686] Bluetooth: SCO socket layer initialized
[ 0.109819] rockchip-cpuinfo cpuinfo: Serial : a32b06ea995d4011
[ 0.110487] clocksource: Switched to clocksource arch_sys_counter
[ 0.112960] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.113255] NET: Registered protocol family 2
[ 0.113957] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.114018] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.114079] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.114161] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114192] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114411] NET: Registered protocol family 1
[ 0.114738] Unpacking initramfs...
[ 0.558239] Freeing initrd memory: 5896K
[ 0.558926] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.570326] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.570643] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.573977] io scheduler noop registered (default)
[ 0.575124] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.579445] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.579504] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.581926] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.581964] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.582314] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.582462] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.584016] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.586313] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 6770833) is a 16550A
[ 0.588167] [drm] Initialized drm 1.1.0 20060810
[ 0.588334] random: nonblocking pool is initialized
[ 0.591082] Unable to detect cache hierarchy for CPU 0
[ 0.598094] loop: module loaded
[ 0.598463] SCSI Media Changer driver v0.25
[ 0.600412] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (input).
[ 0.600459] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 0.600504] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 0.600527] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 0.600543] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 0.600566] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 0.600807] rk_gmac-dwmac ff4e0000.ethernet: clock input from PHY
[ 0.605841] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 0.605980] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.605996] Ring mode enabled
[ 0.606008] DMA HW capability register supported
[ 0.606016] Normal descriptors
[ 0.606028] RX Checksum Offload Engine supported (type 2)
[ 0.606038] TX Checksum insertion supported
[ 0.606048] Wake-Up On Lan supported
[ 0.606108] Enable RX Mitigation via HW Watchdog Timer
[ 0.689773] libphy: stmmac: probed
[ 0.689815] eth%d: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active
[ 0.689832] eth%d: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01)
[ 0.689845] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 0.689858] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 0.689871] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 0.689884] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 0.689897] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 0.689910] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 0.689923] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 0.689937] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 0.689950] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 0.689963] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 0.689976] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 0.689989] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 0.690002] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 0.690015] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 0.690029] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 0.690047] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 0.690060] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 0.690073] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 0.690086] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 0.690099] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 0.690113] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 0.690126] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 0.690139] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 0.690152] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 0.690165] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 0.690178] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 0.690191] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 0.690204] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 0.690216] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 0.690229] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 0.691434] Rockchip WiFi SYS interface (V1.00) ...
[ 0.691940] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.692033] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.804558] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.805091] dwc2 ff400000.usb: DWC OTG Controller
[ 0.805142] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 0.805193] dwc2 ff400000.usb: irq 22, io mem 0xff400000
[ 0.806285] hub 1-0:1.0: USB hub found
[ 0.806355] hub 1-0:1.0: 1 port detected
[ 0.807279] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.807313] ehci-platform: EHCI generic platform driver
[ 0.811142] ehci-platform ff440000.usb: EHCI Host Controller
[ 0.811194] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 0.811341] ehci-platform ff440000.usb: irq 23, io mem 0xff440000
[ 0.816518] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 0.817557] hub 2-0:1.0: USB hub found
[ 0.817615] hub 2-0:1.0: 1 port detected
[ 0.818195] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.818246] ohci-platform: OHCI generic platform driver
[ 0.818667] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 0.818713] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 0.818894] ohci-platform ff450000.usb: irq 24, io mem 0xff450000
[ 0.874367] hub 3-0:1.0: USB hub found
[ 0.874424] hub 3-0:1.0: 1 port detected
[ 0.875090] usbcore: registered new interface driver uas
[ 0.875239] usbcore: registered new interface driver usb-storage
[ 0.875300] usbcore: registered new interface driver ums-alauda
[ 0.875366] usbcore: registered new interface driver ums-cypress
[ 0.875429] usbcore: registered new interface driver ums-datafab
[ 0.875516] usbcore: registered new interface driver ums_eneub6250
[ 0.875584] usbcore: registered new interface driver ums-freecom
[ 0.875650] usbcore: registered new interface driver ums-isd200
[ 0.875708] usbcore: registered new interface driver ums-jumpshot
[ 0.875769] usbcore: registered new interface driver ums-karma
[ 0.875838] usbcore: registered new interface driver ums-onetouch
[ 0.875900] usbcore: registered new interface driver ums-sddr09
[ 0.875961] usbcore: registered new interface driver ums-sddr55
[ 0.876027] usbcore: registered new interface driver ums-usbat
[ 0.876773] i2c /dev entries driver
[ 0.877913] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff80089be000
[ 0.880695] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.880941] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.881581] Bluetooth: HCI UART driver ver 2.3
[ 0.881607] Bluetooth: HCI UART protocol H4 registered
[ 0.881618] Bluetooth: HCI UART protocol LL registered
[ 0.881856] cpu cpu0: leakage=13
[ 0.882115] cpu cpu0: Failed to get pvtm
[ 0.884753] Synopsys Designware Multimedia Card Interface Driver
[ 0.886446] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.886626] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.886678] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 0.886702] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 0.886779] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.887590] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.887628] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.898582] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.909659] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.909694] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.909707] set vqmmc to 3.3v, ret=0
[ 0.910223] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 0.910459] dwmmc_rockchip ff490000.dwmmc: No default pinctrl state
[ 0.910518] dwmmc_rockchip ff490000.dwmmc: No off pinctrl state
[ 0.910646] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.910697] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 0.910722] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 0.910798] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 0.910877] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 0.910894] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 0.921658] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.932683] dwmmc_rockchip ff490000.dwmmc: 1 slots initialized
[ 0.933261] dwmmc_rockchip ff4a0000.dwmmc: No default pinctrl state
[ 0.933284] dwmmc_rockchip ff4a0000.dwmmc: No off pinctrl state
[ 0.933302] dwmmc_rockchip ff4a0000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.933398] dwmmc_rockchip ff4a0000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.933435] dwmmc_rockchip ff4a0000.dwmmc: Using internal DMA controller.
[ 0.933454] dwmmc_rockchip ff4a0000.dwmmc: Version ID is 270a
[ 0.933541] dwmmc_rockchip ff4a0000.dwmmc: DW MMC controller at irq 27,32 bit host data width,256 deep fifo
[ 0.933601] dwmmc_rockchip ff4a0000.dwmmc: No vmmc regulator found
[ 0.933615] dwmmc_rockchip ff4a0000.dwmmc: No vqmmc regulator found
[ 0.933911] dwmmc_rockchip ff4a0000.dwmmc: allocated mmc-pwrseq
[ 0.944624] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.955637] dwmmc_rockchip ff4a0000.dwmmc: 1 slots initialized
[ 0.957045] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.968375] mmc1: MAN_BKOPS_EN bit is not set
[ 0.971807] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 0.980598] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 0.988665] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_CDP_CHARGER
[ 1.017579] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 1.057701] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.058571] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 1.158682] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.259645] is31fl32xx_init_regs, write to shutdown register failed
[ 1.259770] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.348282] dwmmc_rockchip ff490000.dwmmc: Successfully tuned phase to 60
[ 1.348437] mmc1: new HS200 MMC card at address 0001
[ 1.349900] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 1.350688] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 1.352602] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 M[ 1.359059] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.360681] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.461771] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.563239] usbcore: registered new interface driver usbhid
[ 1.563286] usbhid: USB HID core driver
[ 1.563585] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 1.563993] rockchip-dmc dmc: Failed to get leakage
[ 1.564160] rockchip-dmc dmc: Failed to get pvtm
[ 1.564751] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ [ 1.568660] rknandc_base v1.1 2017-01-11
[ 1.569126] rksfc_base v1.1 2016-01-08
[ 1.577751] rk3308-acodec ff560000.acodec: Don't need pa-drv gpio
[ 1.577808] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 1.578946] 1-001a supply AVDD not found, using dummy regulator
[ 1.579092] 1-001a supply DVDD not found, using dummy regulator
[ 1.579206] 1-001a supply PVDD_A not found, using dummy regulator
[ 1.579318] 1-001a supply PVDD_001a supply PVDD_C not found, using dummy regulator
[ 1.5796ror requesting pdn_gpio: -16
[ 1.580683] tas571x: probe of 1-001a failed with error -16
[ 1.589346] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.589420] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.589965] rk-multicodecs vad-sound: ASoC: CPU DAI (null) not registered
[ 1.591439] NET: Registered protocol family 10
[ 1.592852] NET: Registered protocol family 17
[ 1.592922] NET: Registered protocol family 15
[ 1.593192] Bluetooth: RFCOMM TTY layer initialized
[ 1.593217] Bluetooth: RFCOMM socket layer initialized
[ 1.593255] Bluetooth: RFCOMM ver 1.11
[ 1.593280] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.593297] Bluetooth: HIDP socket layer initialized
[ 1.593312] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.593868] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.593897] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 1.593914] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.593923] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.594007] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 1.
[ 1.594023] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.594032] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.594044] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.594123] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.594594] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 1.594635] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 1.594685] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 1.594697] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.594766] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.594826] [BT_RFKILL]: ** disable irq
[ 1.595005] [BT_RFKILL]: bt_default device registered.
[ 1.595549] flash vendor_init_thread!
[ 1.595576] flash vendor storage:20170308 ret = -1
[ 1.596596] vendor storage:20160801 ret = 0
[ 1.597968] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 1.599212] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.599245] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.671208] rk-multicodecs vad-sound: multicodec <-> pdm-i2s-dais mapping ok
[ 1.674539] rk-multicodecs bluetooth-sound: dummy_codec <-> ff350000.i2s mapping ok
[ 1.676041] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 1.676070] ======== dhd_wlan_init_plat_data ========
[ 1.676081] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.676090] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.676101] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.676114] dhd_wlan_init_gpio: host_oob_irq: 36
[ 1.676123] dhd_wlan_init_gpio: host_oob_irq_flags=0x418
[ 1.676132] dhd_wifi_platform_load: Enter
[ 1.676163] Power-up adapter 'DHD generic adapter'
[ 1.676219] wifi_platform_set_power = 1
[ 1.676228] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.676238] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.676248] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.676311] hctosys: unable to open rtc device (rtc0)
[ 1.688011] vcc_sd: disabling
[ 1.688066] vccio_sd: disabling
u▒ 1.688696]
In: serial@ff0c0000
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
No ethernet found.
Starting kernel ...
[ 0.001746] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002696] pid_max: default: 32768 minimum: 301
[ 0.003247] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.003849] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.005268] sched-energy: CPU device node has no sched-energy-costs
[ 0.005885] Invalid sched_group_energy for CPU0
[ 0.006304] CPU0: update cpu_capacity 1024
[ 0.006727] ASID allocator initialised with 65536 entries
[ 0.016458] Detected VIPT I-cache on CPU1
[ 0.016514] Invalid sched_group_energy for CPU1
[ 0.016519] CPU1: update cpu_capacity 1024
[ 0.016524] CPU1: Booted secondary processor [410fd042]
[ 0.019479] Detected VIPT I-cache on CPU2
[ 0.019515] Invalid sched_group_energy for CPU2
[ 0.019519] CPU2: update cpu_capacity 1024
[ 0.019523] CPU2: Booted secondary processor [410fd042]
[ 0.022521] Detected VIPT I-cache on CPU3
[ 0.022555] Invalid sched_group_energy for CPU3
[ 0.022560] CPU3: update cpu_capacity 1024
[ 0.022564] CPU3: Booted secondary processor [410fd042]
[ 0.022634] Brought up 4 CPUs
[ 0.027837] SMP: Total of 4 processors activated.
[ 0.028275] CPU: All CPU(s) started at EL2
[ 0.028791] Invalid sched_group_energy for CPU3
[ 0.029212] Invalid sched_group_energy for Cluster3
[ 0.029675] Invalid sched_group_energy for CPU2
[ 0.030093] Invalid sched_group_energy for Cluster2
[ 0.030542] Invalid sched_group_energy for CPU1
[ 0.030970] Invalid sched_group_energy for Cluster1
[ 0.031418] Invalid sched_group_energy for CPU0
[ 0.031834] Invalid sched_group_energy for Cluster0
[ 0.032801] devtmpfs: initialized
[ 0.050950] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.051887] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.052847] pinctrl core: initialized pinctrl subsystem
[ 0.054429] NET: Registered protocol family 16
[ 0.059435] cpuidle: using governor menu
[ 0.059830] Registered FIQ tty driver
[ 0.060507] vdso: 2 pages (1 code @ ffffff8008626000, 1 data @ ffffff80088a4000)
[ 0.061215] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.062048] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.065523] console [pstore-1] enabled
[ 0.065874] pstore: Registered ramoops as persistent store backend
[ 0.066458] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.084953] fiq debugger fiq mode enabled
[[ 0.085703] console [ttyFIQ0] enabled
[ 0.086398] bootconsole [uart0] disabled
[ 0.087011] Registered fiq debugger ttyFIQ0
[ 0.101795] vcc_1v8: regulator get failed, ret=-517
[ 0.102648] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.103441] vcc_1v8: supplied by vcc_io
[ 0.103532] vcc_1v8_codec: supplied by vcc_io
[ 0.105927] SCSI subsystem initialized
[ 0.106232] usbcore: registered new interface driver usbfs
[ 0.106307] usbcore: registered new interface driver hub
[ 0.106438] usbcore: registered new device driver usb
[ 0.106581] pps_core: LinuxPPS API ver. 1 registered
[ 0.106594] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.106630] PTP clock support registered
[ 0.107820] Advanced Linux Sound Architecture Driver Initialized.
[ 0.108491] Bluetooth: Core ver 2.21
[ 0.108553] NET: Registered protocol family 31
[ 0.108565] Bluetooth: HCI device and connection manager initialized
[ 0.108585] Bluetooth: HCI socket layer initialized
[ 0.108601] Bluetooth: L2CAP socket layer initialized
[ 0.108641] Bluetooth: SCO socket layer initialized
[ 0.109778] rockchip-cpuinfo cpuinfo: Serial : a32b06ea995d4011
[ 0.110453] clocksource: Switched to clocksource arch_sys_counter
[ 0.112907] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.113242] NET: Registered protocol family 2
[ 0.113946] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.114006] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.114062] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.114145] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114181] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114391] NET: Registered protocol family 1
[ 0.114747] Unpacking initramfs...
[ 0.558136] Freeing initrd memory: 5896K
[ 0.558812] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.570201] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.570512] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.573905] io scheduler noop registered (default)
[ 0.575083] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.579317] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.579366] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.581803] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.581843] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Cip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.582349] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.583854] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.586136] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 6770833) is a 16550A
[ 0.588004] [drm] Initialized drm 1.1.0 20060810
[ 0.588171] random: nonblocking pool is initialized
[ 0.590946] Unable to detect cache hierarchy for CPU 0
[ 0.598053] loop: module loaded
[ 0.598413] SCSI Media Changer driver v0.25
[ 0.600315] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (input).
[ 0.600360] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 0.600377] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 0.600397] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 0.600414] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 0.600437] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 0.600723] rk_gmac-dwmac ff4e0000.ethernet: clock input from PHY
[ 0.605758] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 0.605895] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.605911] Ring mode enabled
[ 0.605922] DMA HW capability register supported
[ 0.605931] Normal descriptors
[ 0.605942] RX Checksum Offload Engine supported (type 2)
[ 0.605952] TX Checksum insertion supported
[ 0.605963] Wake-Up On Lan supported
[ 0.606028] Enable RX Mitigation via HW Watchdog Timer
[ 0.689535] libphy: stmmac: probed
[ 0.689577] eth%d: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active
[ 0.689594] eth%d: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01)
[ 0.689608] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 0.689621] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 0.689634] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 0.689647] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 0.689660] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 0.689673] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 0.689686] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 0.689699] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 0.689712] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 0.689725] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 0.689739] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 0.689752] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 0.689765] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 0.689778] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 0.689799] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 0.689812] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 0.689826] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 0.689839] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 0.689852] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 0.689865] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 0.689878] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 0.689891] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 0.689904] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 0.689917] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 0.689931] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 0.689943] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 0.689957] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 0.689970] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 0.689982] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 0.689996] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 0.691196] Rockchip WiFi SYS interface (V1.00) ...
[ 0.691672] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.691801] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.804524] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.805048] dwc2 ff400000.usb: DWC OTG Controller
[ 0.805096] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 0.805144] dwc2 ff400000.usb: irq 22, io mem 0xff400000
[ 0.806062] hub 1-0:1.0: USB hub found
[ 0.806117] hub 1-0:1.0: 1 port detected
[ 1.029939] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 1.030190] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.030223] ehci-platform: EHCI generic platform driver
[ 1.034078] ehci-platform ff440000.usb: EHCI Host Controller
[ 1.034130] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 1.034274] ehci-platform ff440000.usb: irq 23, io mem 0xff440000
[ 1.039487] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 1.040373] hub 2-0:1.0: USB hub found
[ 1.040426] hub 2-0:1.0: 1 port detected
[ 1.041053] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.041102] ohci-platform: OHCI generic platform driver
[ 1.041529] ohci-platform ff450000.usb: Generic Platform OHCI contq 24, io mem 0xff450000
[ 1.097336] hub 3-0:1.0: USB hub found
[ 1.097392] hub 3-0:1.0: 1 port detected
[ 1.098047] usbcore: registered new interface driver uas
[ 1.098201] usbcore: registered new interface driver usb-storage
[ 1.098264] usbcore: registered new interface driver ums-alauda
[ 1.098324] usbcore: registered new interface driver ums-cypress
[ 1.098391] usbcore: registered new interface driver ums-datafab
[ 1.098473] usbcore: registered new interface driver ums_eneub6250
[ 1.098537] usbcore: registered new interface driver ums-freecom
[ 1.098610] usbcore: registered new interface driver ums-isd200
[ 1.098670] usbcore: registered new interface driver ums-jumpshot
[ 1.098730] usbcore: registered new interface driver ums-karma
[ 1.098798] usbcore: registered new interface driver ums-onetouch
[ 1.098861] usbcore: registered new interface driver ums-sddr09
[ 1.098922] usbcore: registered new interface driver ums-sddr55
[ 1.098988] usbcore: registered new interface driver ums-usbat
[ 1.099726] i2c /dev entries driver
[ 1.100885] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff80089be000
[ 1.103735] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 1.103965] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 1.104600] Bluetooth: HCI UART driver ver 2.3
[ 1.104626] Bluetooth: HCI UART protocol H4 registered
[ 1.104637] Bluetooth: HCI UART protocol LL registered
[ 1.104874] cpu cpu0: leakage=13
[ 1.105103] cpu cpu0: Failed to get pvtm
[ 1.107674] Synopsys Designware Multimedia Card Interface Driver
[ 1.109383] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 1.109564] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.109609] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 1.109639] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 1.109716] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.110549] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 1.110589] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 1.121553] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.132626] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 1.132659] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 1.132674] set vqmmc to 3.3v, ret=0
[ 1.133187] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 1.133425] dwmmc_rockchip ff490000.dwmmc: No default pinctrl state
[ 1.133484] dwmmc_rockchip ff490000.dwmmc: No off pinctrl state
[ 1.133613] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.133662] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 1.133684] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 1.133763] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.133842] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 1.133859] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 1.144628] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.155613] dwmmc_rockchip ff490000.dwmmc: 1 slots initialized
[ 1.156189] dwmmc_rockchip ff4a0000.dwmmc: No default pinctrl state
[ 1.156213] dwmmc_rockchip ff4a0000.dwmmc: No off pinctrl state
[ 1.156229] dwmmc_rockchip ff4a0000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 1.156325] dwmmc_rockchip ff4a0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.156371] dwmmc_rockchip ff4a0000.dwmmc: Using internal DMA controller.
[ 14a0000.dwmmc: DW MMC controller at irq 27,32 bit host data width,256 deep fifo
[ 1.156552] dwmmc_rockchip ff4a0000.dwmmc: No vmmc regulator found
[ 1.156570] dwmmc_rockchip ff4a0000.dwmmc: No vqmmc regulator found
[ 1.156878] dwmmc_rockchip ff4a0000.dwmmc: allocated mmc-pwrseq
[ 1.167589] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.178617] dwmmc_rockchip ff4a0000.dwmmc: 1 slots initialized
[ 1.180007] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.191360] mmc1: MAN_BKOPS_EN bit is not set
[ 1.194793] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 1.203568] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 1.240545] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 1.280620] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.281527] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 1.381616] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.482611] is31fl32xx_init_regs, write to shutdown register failed
[ 1.482735] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.571286] dwmmc_rockchip ff490000.dwmmc: Successfully tuned phase to 60
[ 1.571443] mmc1: new HS200 MMC card at address 0001
[ 1.572991] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 1.574856] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 1.576776] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 1.577781] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[ 1.583644] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.583826] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.684743] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.786182] usbcore: registered new interface driver usbhid
[ 1.786228] usbhid: USB HID core driver
[ 1.786515] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 1.786943] rockchip-dmc dmc: Failed to get leakage
[ 1.787100] rockchip-dmc dmc: Failed to get pvtm
[ 1.787695] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ [ 1.791487] rknandc_base v1.1 2017-01-11
[ 1.791948] rksfc_base v1.1 2016-01-08
[ 1.800413] rk3308-acodec ff560000.acodec: Don't need pa-drv gpio
[ 1.800516] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 1.801729] 1-001a supply AVDD not found, using dummy regulator
[ 1.801878] 1-001a supply DVDD not found, using dummy regulator
[ 1.801988] 1-001a supply PVDD_A not found, using dummy regulator
[ 1.802091] 1-001a supply PVDD_B not found, using dummy regulator
[ 1.802202] 1-001a supply PVDD_C not found, using dummy regulator
[ 1.802316] 1-001a supply PVDD_D not found, using dting pdn_gpio: -16
[ 1.80334[ 1.808898] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.808943] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.809194] rk-multicodecs vad-sound: ASoC: CPU DAI (null) not registered
[ 1.810136] NET: Registered protocol family 10
[ 1.811386] NET: Registered protocol family 17
[ 1.811492] NET: Registered protocol family 15
[ 1.811766] Bluetooth: RFCOMM TTY layer initialized
[ 1.811793] Bluetooth: RFCOMM socket layer initialized
[ 1.811827] Bluetooth: RFCOMM ver 1.11
[ 1.811851] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.811867] Bluetooth: HIDP socket layer initialized
[ 1.811882] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.812391] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.812423] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 1.812433] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.812477] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.812564] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 1.
[ 1.812580] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.812589] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.812610] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.812689] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.813134] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 1.813175] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 1.813226] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 1.813238] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.813305] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.813371] [BT_RFKILL]: ** disable irq
[ 1.813568] [BT_RFKILL]: bt_default device registered.
[ 1.814110] flash vendor_init_thread!
[ 1.814151] flash vendor storage:20170308 ret = -1
[ 1.814813] vendor storage:20160801 ret = 0
[ 1.816134] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 1.817331] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.817356] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.890144] rk-multicodecs vad-sound: multicodec <-> pdm-i2s-dais mapping ok
[ 1.896249] rk-multicodecs bluetooth-sound: dummy_codec <-> ff350000.i2s mapping ok
[ 1.899553] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 1.899614] ======== dhd_wlan_init_plat_data ========
[ 1.899637] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.899658] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.899679] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.899704] dhd_wlan_init_gpio: host_oob_irq: 36
[ 1.899742] dhd_wlan_init_gpio: host_oob_irq_flags=0x418
[ 1.899761] dhd_wifi_platform_load: Enter
[ 1.899855] Power-up adapter 'DHD generic adapter'
[ 1.899965] wifi_platform_set_power = 1
[ 1.899986] hctosys: unable to open rtc device (rtc0)
[ 1.900012] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.900034] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.900055] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.925158] vcc_sd: disabling
[ 1.925243] vccio_sd: disabling
u▒ 1.925960]
