Firefly-rk3288 buildroot wifi配置AP模式时用户接入热点失败
板子上的wifi模组为AP6181,可以连到办公室wifi路由器上外网。参照[u]https://blog.csdn.net/gilzhy/article/details/9098031[/u]使用hostapd+dnsmasq进行配置,如下:
1、配置hostapd
[root@rk3288:/]# cat /etc/hostapd.conf
interface=wlan0
driver=nl80211
ssid=wt
hw_mode=g
channel=11
dtim_period=1
rts_threshold=2347
fragm_threshold=2346
macaddr_acl=0
auth_algs=3
ieee80211n=0
wpa=3
wpa_passphrase=qwert8642
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
2、配置dnsmasq
[root@rk3288:/]# cat /etc/dnsmasq.conf
interface=wlan0
bind-interfaces
except-interface=lo
dhcp-range=192.168.2.10,192.168.2.20,12h
dhcp-option=3,192.168.2.1
dhcp-option=6,223.5.5.5
3、路由规则脚本
[root@rk3288:/]# cat home/wtap
#!/bin/sh
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
iptables -t nat -A POSTROUTING -s 192.168.2.0/24 -o eth0 -j MASQUERADE
iptables -A FORWARD -s 192.168.2.0/24 -o eth0 -j ACCEPT
iptables -A FORWARD -d 192.168.2.0/24 -m conntrack --ctstate ESTABLISHED,RELATED -i eth0 -j ACCEPT
4、打开路由转发
[root@rk3288:/]# cat /etc/sysctl.conf
# /etc/sysctl.conf - Configuration file for setting system variables
# See /etc/sysctl.d/ for additional system variables.
# See sysctl.conf (5) for information.
# Uncomment the next line to enable packet forwarding for IPv4
net.ipv4.ip_forward=1
5、启动AP
[root@rk3288:/]# killall named
killall: named: no process killed
[root@rk3288:/]# killall hostapd
killall: hostapd: no process killed
[root@rk3288:/]# ifconfig wlan0 192.168.2.1
[root@rk3288:/]#
[root@rk3288:/]# hostapd -B /etc/hostapd.conf
Configuration file: /etc/hostapd.conf
[ 493.643371] wl_cfg80211_del_station: Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
Using interface wlan0 with hwaddr 94:a1:a2:1b:44:f2 and ssid “wt”
[ 493.729952] dhd_wl_ioctl_set_intiovar: set int iovar ndoe failed, ERR -23
[ 493.736741] dhd_ndo_enable: failed to enabe ndo to 0, retcode = -23
[ 493.743036] CFG80211-ERROR) wl_cfg80211_start_ap : wl_cfg80211_start_ap: Disabling NDO Failed -23
[ 493.752771] wl_cfg80211_set_channel: netdev_ifidx(4), chan_type(1) target channel(11)
[ 493.837268] wl_iw_event: Link UP with 94:a1:a2:1b:44:f2
[ 493.843432] wl_notify_connect_status_ap: ** AP/GO Link up event **
[ 493.851862] CFG80211-ERROR) wl_cfg80211_set_scb_timings : set ‘scb_probe’ failed, error = -23
[ 493.860683] CFG80211-ERROR) wl_cfg80211_start_ap : scb setting failed
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
[root@rk3288:/]# /etc/init.d/dnsmasq restart
Terminated
[root@rk3288:/]# echo 1 >/proc/sys/net/ipv4/ip_forward
[root@rk3288:/]# ./home/wtap
[root@rk3288:/]#
[root@rk3288:/]#
eth0 Link encap:Ethernet HWaddr 9E:40:B6:56:5B:3A
      inet addr:192.168.1.32  Bcast:192.168.1.255  Mask:255.255.255.0
      inet6 addr: 240e:390:8bc:bd30::3/128 Scope:Global
      inet6 addr: fe80::7f55:611f:b93:9e4b/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:104 errors:0 dropped:0 overruns:0 frame:0
      TX packets:121 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:10476 (10.2 KiB)  TX bytes:10998 (10.7 KiB)
      Interrupt:40
lo Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:72 errors:0 dropped:0 overruns:0 frame:0
      TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:5328 (5.2 KiB)  TX bytes:5328 (5.2 KiB)
wlan0 Link encap:Ethernet HWaddr 94:A1:A2:1B:44:F2
      inet addr:192.168.2.1  Bcast:192.168.2.255  Mask:255.255.255.0
      inet6 addr: fe80::b4fd:dbfd:d93d:2769/64 Scope:Link
      RX packets:0 errors:0 dropped:0 overruns:0 frame:0
      TX packets:29 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:0 (0.0 B)  TX bytes:6152 (6.0 KiB)
6、打开手机WLAN可以看到热点“wt”,连接该热点
板子上log如下:
[root@rk3288:/]# [ 658.538293] wl_notify_connect_status_ap: connected device b0:e1:7e:3c:23:38
[ 658.548514] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 658.598070] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 1
[ 658.615240] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 1
[ 658.622077] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 2
[ 658.636723] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 2
[ 658.645011] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 3
[ 658.667957] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 3
[ 694.854661] wl_notify_connect_status_ap: event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 694.863136] wl_notify_connect_status_ap: disassociated device b0:e1:7e:3c:23:38
[ 694.882671] wl_cfg80211_del_station: Disconnect STA : b0:e1:7e:3c:23:38 scb_val.val 3
[ 696.064659] wl_notify_connect_status_ap: connected device b0:e1:7e:3c:23:38
[ 696.074309] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 696.101601] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 1
[ 696.115376] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 1
[ 696.124163] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 2
[ 696.139159] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 2
[ 696.152020] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 3
[ 696.169684] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 3
[ 732.283022] wl_notify_connect_status_ap: event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 732.291757] wl_notify_connect_status_ap: disassociated device b0:e1:7e:3c:23:38
[ 732.310281] wl_cfg80211_del_station: Disconnect STA : b0:e1:7e:3c:23:38 scb_val.val 3
[ 733.386774] wl_notify_connect_status_ap: connected device b0:e1:7e:3c:23:38
[ 733.396069] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 733.424180] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 1
[ 733.438731] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 1
[ 733.447405] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 2
[ 733.462306] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 2
[ 733.474936] ETHER_TYPE_802_1X[wlan0] [TX]: ver 2, type 3, replay 3
[ 733.497181] ETHER_TYPE_802_1X[wlan0] [RX]: ver 1, type 3, replay 3
手机端一直处于提示“正在连接‘wt’”,最后提示超时,连接失败。请问,如何解决?非常感谢!
楼主您好,我遇到了和您同样的问题,请问当时怎么解决的?
请问楼上两位大神解决这个问题了么?我也遇到了
这个问题解决了吗 ?
