RK3288 使用android MediaRecord长时间录制后卡死,几秒后重启,请大神们帮帮忙!感谢
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (root@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #504 SMP PREEMPT Tue Jan 14 15:33:07 CST 2020
<4>[ 0.000000] cpu_do_switch_mm is cpu_v7_btbinv_switch_mm
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
<6>[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<4>[ 0.000000] Boot mode: PANIC (7) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0d64880, node_mem_map c0e8d000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f04000 s13440 r8192 d15232 u36864
<7>[ 0.000000] pcpu-alloc: s13440 r8192 d15232 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console= androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console= init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),0x00008000@0x00192000(metadata),0x00020000@0x0039A000(radical_update),-@0x003BA000(userdata) storagemedia=emmc loader.timestamp=2019-05-31_18:42:25
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 2026548k/2026548k available, 70604k reserved, 1556480K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0bfd5b0 (12246 kB)
<5>[ 0.000000] .init : 0xc0bfe000 - 0xc0c57480 ( 358 kB)
<5>[ 0.000000] .data : 0xc0c58000 - 0xc0d6bf08 (1104 kB)
<5>[ 0.000000] .bss : 0xc0d6bf08 - 0xc0e8c8bc (1155 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 29
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 0
<6>[ 0.000000] channel:0, lkg:42
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:25
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.504121] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.504135] pid_max: default: 32768 minimum: 301
<6>[ 0.504245] Security Framework initialized
<6>[ 0.504257] SELinux: Initializing.
<7>[ 0.504289] SELinux: Starting in permissive mode
<6>[ 0.504324] Mount-cache hash table entries: 512
<6>[ 0.504912] Initializing cgroup subsys debug
<6>[ 0.504925] Initializing cgroup subsys memory
<6>[ 0.504949] Initializing cgroup subsys freezer
<6>[ 0.504976] CPU: Testing write buffer coherency: ok
<3>[ 0.505219] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.505231] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.505240] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.505249] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.505311] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.505356] Setting up static identity map for 0xc088af28 - 0xc088af80
<6>[ 0.506742] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x173d (version 3.1)
<4>[ 0.581643] CPU1: Booted secondary processor
<6>[ 0.581671] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.601323] CPU2: Booted secondary processor
<6>[ 0.601346] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.621030] CPU3: Booted secondary processor
<6>[ 0.621053] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.621153] Brought up 4 CPUs
<6>[ 0.621181] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.621190] CPU: All CPU(s) started in SVC mode.
<6>[ 0.621842] devtmpfs: initialized
<6>[ 0.625922] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.626905] pinctrl core: initialized pinctrl subsystem
<6>[ 0.627120] regulator-dummy: no parameters
<6>[ 0.645574] NET: Registered protocol family 16
<6>[ 0.647109] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.647394] ion_snapshot: 0x1e9e0000 map to 0xe0907000 and copy to 0xc0e67c54 (version 0.1)
<6>[ 0.647580] Registered FIQ tty driver
<3>[ 0.647898] fiq-debugger is disabled in device tree
<4>[ 0.648440] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.648460] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.648476] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.648492] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.648571] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.648635] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.648702] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.648764] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.648825] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.648886] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.648947] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.649008] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.649074] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.649138] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.649151] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.649162] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.649173] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.649240] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.649299] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.649356] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.649407] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.649464] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.649516] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.649567] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.649623] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.649676] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.649731] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.649753] rockchip_interrupts_register:bank_num=7
<4>[ 0.651661] rockchip_pinctrl_probe:init ok
<6>[ 0.658843] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.658907] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.658920] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.659089] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.659144] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.659156] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.659319] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.659374] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.659386] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.659562] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.659617] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.659628] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.659791] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.659850] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.659862] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.660026] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.660080] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.660092] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.660286] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.660344] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.660356] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.662212] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.662224] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.662869] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.662890] DDR DEBUG: version 1.00 20150126
<4>[ 0.662991] DDR DEBUG: Channel a:
<4>[ 0.663000] DDR DEBUG: DDR3 Device
<4>[ 0.663013] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.663021] DDR DEBUG: Channel b:
<4>[ 0.663028] DDR DEBUG: DDR3 Device
<4>[ 0.663040] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.663048] DDR DEBUG: addr=0xd75000
<4>[ 0.663058] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.663066] DDR DEBUG: socAddr[0]=0xd75000, socAddr[1]=0xd75100
<4>[ 0.663075] DDR DEBUG: chAddr[0]=0xd75000, chAddr[1]=0xd75000
<4>[ 0.663086] DDR DEBUG: dtar[0]=0x501ae000, dtar[1]=0x501ae000
<4>[ 0.663139] DDR DEBUG: init success!!! freq=396MHz
<4>[ 0.663147] DDR DEBUG: Channel a:
<4>[ 0.663159] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663172] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663184] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663196] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663207] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.663215] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.663224] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.663231] DDR DEBUG: Channel b:
<4>[ 0.663242] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663254] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663266] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663278] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270
<4>[ 0.663289] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.663297] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.663306] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.687759] bio: create slab at 0
<6>[ 0.688202] Rockchip hdmi driver version 2.0
<6>[ 0.688202] .
<5>[ 0.689354] SCSI subsystem initialized
<6>[ 0.689501] usbcore: registered new interface driver usbfs
<6>[ 0.689544] usbcore: registered new interface driver hub
<6>[ 0.689624] usbcore: registered new device driver usb
<7>[ 0.689893] of_get_named_gpio_flags: can’t parse gpios property
<3>[ 0.689907] rk3288-usb-control usb_control.33: invalid host gpio-2
<7>[ 0.689917] of_get_named_gpio_flags: can’t parse gpios property
<3>[ 0.689928] rk3288-usb-control usb_control.33: invalid otg gpio-2
<7>[ 0.690848] of_get_named_gpio_flags exited with status 15
<7>[ 0.690867] of_get_named_gpio_flags exited with status 16
<6>[ 0.691862] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.691959] of_get_named_gpio_flags exited with status 260
<7>[ 0.691977] of_get_named_gpio_flags exited with status 261
<6>[ 0.692287] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.692382] of_get_named_gpio_flags exited with status 201
<7>[ 0.692399] of_get_named_gpio_flags exited with status 202
<6>[ 0.692702] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.692792] of_get_named_gpio_flags exited with status 81
<7>[ 0.692809] of_get_named_gpio_flags exited with status 80
<6>[ 0.692938] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.693029] of_get_named_gpio_flags exited with status 241
<7>[ 0.693045] of_get_named_gpio_flags exited with status 242
<6>[ 0.693513] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.693623] media: Linux media interface: v0.10
<6>[ 0.693658] Linux video capture interface: v2.00
<6>[ 0.693772] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.693782] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.693802] PTP clock support registered
<4>[ 0.693854] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.693863] i2c-core: driver [bq24296] using legacy resume method
<6>[ 0.694182] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
<4>[ 0.694792] ion_drm_heap_create: 0@0
<6>[ 0.694902] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.695052] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.695411] Bluetooth: Core ver 2.16
<6>[ 0.695459] NET: Registered protocol family 31
<6>[ 0.695468] Bluetooth: HCI device and connection manager initialized
<6>[ 0.695482] Bluetooth: HCI socket layer initialized
<6>[ 0.695494] Bluetooth: L2CAP socket layer initialized
<6>[ 0.695518] Bluetooth: SCO socket layer initialized
<6>[ 0.695732] cfg80211: Calling CRDA to update world regulatory domain
<7>[ 0.696619] of_get_named_gpio_flags exited with status 227
<4>[ 0.697598] act8846_i2c_probe,line=880
<4>[ 0.699021] act8846 set 0xf4 error!
<4>[ 0.699098] act8846: probe of 0-005a failed with error -11
<4>[ 0.699908] The device is not syr82x fffffff5
<4>[ 0.699925] syr82x: probe of 0-0040 failed with error -11
<4>[ 0.700624] The device is not syr82x fffffff5
<4>[ 0.700639] syr82x: probe of 0-0041 failed with error -11
<4>[ 0.701064] rk808_i2c_probe,line=1355
<4>[ 0.701555] rk808_pre_init,line=1224
<7>[ 0.712173] of_get_named_gpio_flags exited with status 4
<7>[ 0.712187] of_get_named_gpio_flags exited with status 11
<6>[ 0.712211] rk808_i2c_probe: rk808_pmic_sleep=0
<6>[ 0.718496] vdd_arm: 712 ↔ 1500 mV at 900 mV
<6>[ 0.725275] vdd_gpu: 712 ↔ 1500 mV at 900 mV
<6>[ 0.731711] rk_dcdc3: 1200 mV
<6>[ 0.740448] vccio: 3300 mV
<6>[ 0.746883] rk_ldo1: 3300 mV
<6>[ 0.753316] rk_ldo2: 3300 mV
<6>[ 0.759723] rk_ldo3: 1000 mV
<6>[ 0.766128] rk_ldo4: 1800 mV
<6>[ 0.772544] rk_ldo5: 3300 mV
<6>[ 0.778973] rk_ldo6: 1000 mV
<6>[ 0.785384] rk_ldo7: 1800 mV
<6>[ 0.791789] rk_ldo8: 1800 mV
<6>[ 0.795058] rk_ldo9: at 3300 mV
<6>[ 0.798321] rk_ldo10: at 3300 mV
<6>[ 0.801041] rk808_irq_init: rk808_pmic_irq=1
<4>[ 0.801328] i2c-core: driver [rk816] using legacy suspend method
<4>[ 0.801339] i2c-core: driver [rk816] using legacy resume method
<4>[ 0.801380] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.801389] i2c-core: driver [rk818] using legacy resume method
<6>[ 0.802744] Switching to clocksource arch_sys_counter
<6>[ 0.823911] rga: Module initialized.
<6>[ 0.824416] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.824547] rga: Driver loaded succesfully
<6>[ 0.824718] fb disp policy is box
<7>[ 0.824728] uboot-logo-on:0
<6>[ 0.824756] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.824768] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.825346] rk-screen rk_screen.8: rockchip screen probe success
<6>[ 0.825567] rk32-lvds rk32-lvds: rk32 lvds driver probe success
<3>[ 0.825917] rk32-edp ff970000.edp: screen is not edp!
<4>[ 0.825935] rk32-edp: probe of ff970000.edp failed with error -22
<6>[ 0.826101] rk32-dsi
<4>[ 0.826218] dsi->host.irq =51
<4>[ 0.826234] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
<4>[ 0.826242] mipi_dsi v1.3 2014-04-17
<6>[ 0.826264] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
<6>[ 0.826275] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
<3>[ 0.826743] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
<6>[ 0.826942] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.827220] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.827381] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.827543] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.828539] rk3288-lcdc lcdc0: lcdc0: dclk:148000000>>fps:60
<6>[ 0.828560] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.857680] alloc_buffer:ion_phy_addr=0x10000000
<6>[ 0.869719] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
<6>[ 0.869742] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaca000
<6>[ 0.869756] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
<3>[ 0.869916] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.869927] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.870141] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.870442] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.870607] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.870771] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.871406] unknow screen type: 0
<6>[ 0.871474] rk3288-lcdc lcdc1: lcdc1: dclk:148000000>>fps:60
<6>[ 0.871486] rk3288-lcdc lcdc1: wakeup from standby!
<6>[ 0.874724] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
<6>[ 0.874737] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
<4>[ 0.875390] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.875517] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.875626] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.875744] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.875854] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.875961] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.876909] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.877053] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.877966] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.878105] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.879015] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.879158] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.880083] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.880224] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.881629] NET: Registered protocol family 2
<6>[ 0.882227] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.882301] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.882373] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.882416] TCP: reno registered
<6>[ 0.882430] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.882452] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.882621] NET: Registered protocol family 1
<6>[ 0.883320] Unpacking initramfs…
<6>[ 0.947766] Freeing initrd memory: 1252K (c5bf0000 - c5d29000)
<6>[ 0.948326] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.948843] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.948992] vcodec_service: No reset resource define
<6>[ 0.949124] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.949196] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.949210] vcodec_service: checking hw id 4831
<6>[ 0.949942] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.949981] vcodec_service: done
<6>[ 0.949989] vcodec_service: init success
<6>[ 0.950041] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.950354] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.950446] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.950460] vcodec_service: checking hw id 6867
<6>[ 0.950984] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.951022] vcodec_service: done
<6>[ 0.951030] vcodec_service: init success
<4>[ 0.951178] rknandbase v1.0 2014-03-31
<4>[ 0.951298] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.951407] rknand_driver:ret = 0
<6>[ 0.952511] audit: initializing netlink socket (disabled)
<5>[ 0.952551] type=2000 audit(0.450:1): initialized
<4>[ 0.953266] bounce pool size: 64 pages
<6>[ 0.957663] fuse init (API version 7.22)
<6>[ 0.958008] msgmni has been set to 952
<7>[ 0.958052] SELinux: Registering netfilter hooks
<6>[ 0.959761] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
<6>[ 0.959775] io scheduler noop registered
<6>[ 0.959784] io scheduler deadline registered
<6>[ 0.959875] io scheduler cfq registered (default)
<4>[ 0.960619] rockchip_gpio_request:GPIO7-13
<4>[ 0.960654] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 0.960668] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x1
<4>[ 0.960680] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb000,result=0xb000
<6>[ 0.960708] spi_backlight module init!
<7>[ 0.961180] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.962225] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.962864] IEP Power ON
<4>[ 0.962901] iep ion client create success!
<6>[ 0.963258] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eac5000
<4>[ 0.963268] IEP Power OFF
<4>[ 0.963284] IEP Driver loaded succesfully
<4>[ 0.963374] Module initialized.
<6>[ 0.964274] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.964292] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.965597] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.965613] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<6>[ 0.965921] vdd_logic: 925 ↔ 1400 mV at 1100 mV
<4>[ 0.966199] rk_serial.c v1.8 2014-03-04
<6>[ 0.966403] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.966573] serial ff180000.serial: membase e21b2000
<6>[ 0.966702] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
<6>[ 0.966875] serial ff190000.serial: membase e21c4000
<6>[ 0.967005] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 0.967161] serial ff690000.serial: membase fed60000
<6>[ 0.967294] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
<6>[ 0.967450] serial ff1b0000.serial: membase e21c6000
<6>[ 0.967583] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4
<6>[ 0.967741] serial ff1c0000.serial: membase e21ce000
<4>[ 0.967852] GPIO Driver Registered.
<6>[ 0.968019] [FMDSP] Probe
<3>[ 1.049415] [FMDSP] i2c_write: i2c_master_send error
<3>[ 1.051828] [FMDSP] i2c_write: i2c_master_send error
<3>[ 1.054236] [FMDSP] i2c_write: i2c_master_send error
<3>[ 1.056643] [FMDSP] i2c_write: i2c_master_send error
<3>[ 1.059053] [FMDSP] i2c_write: i2c_master_send error
<6>[ 1.187002] [FMDSP] probe done
<6>[ 1.187208] arm_release_ver of this mali_ko is ‘r12p0-04rel0’, rk_ko_ver is ‘13’, built at ‘14:08:51’, on ‘Jan 11 2020’.
<6>[ 1.187269] mali ffa30000.gpu: Continuing without Mali clock control
<6>[ 1.188246] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_dvfs.c; [Line] : 390; [Func] : kbase_platform_dvfs_init(); num_of_mali_dvfs_levels = 4, div_dvfs = 10.
<6>[ 1.188264] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_dvfs.c; [Line] : 593; [Func] : calculate_dvfs_max_min_threshold(); dvfs_level_table[0]: freq:198000, min_threshold:0, max_threshold:70
<6>[ 1.188279] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_dvfs.c; [Line] : 593; [Func] : calculate_dvfs_max_min_threshold(); dvfs_level_table[1]: freq:297000, min_threshold:70, max_threshold:80
<6>[ 1.188294] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_dvfs.c; [Line] : 593; [Func] : calculate_dvfs_max_min_threshold(); dvfs_level_table[2]: freq:417000, min_threshold:80, max_threshold:90
<6>[ 1.188307] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_dvfs.c; [Line] : 593; [Func] : calculate_dvfs_max_min_threshold(); dvfs_level_table[3]: freq:417000, min_threshold:97, max_threshold:100
<4>[ 1.210374] hrtimer: interrupt took 14875 ns
<6>[ 1.210521] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
<6>[ 1.230840] mali ffa30000.gpu: Probed as mali0
<6>[ 1.233523] loop: module loaded
<6>[ 1.233870] zram: Created 1 device(s) …
<4>[ 1.233934] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 1.233944] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 1.233957] mpu_init: Probe name mpu6050B1
<6>[ 1.234090] ak8963_mod_init: Probe name ak8963_mod
<6>[ 1.234750] SCSI Media Changer driver v0.25
<6>[ 1.235048] tun: Universal TUN/TAP device driver, 1.6
<6>[ 1.235058] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 1.235171] vmac_init.
<3>[ 1.235719] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 1.235731] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 1.235768] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 1.235777] stmmac_probe_config_dt: RX delay(0x10).
<7>[ 1.235788] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.235801] of_get_named_gpio_flags exited with status 136
<7>[ 1.235810] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 1.235820] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 1.235828] stmmc_pltfr_init:
<3>[ 1.235836] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<6>[ 1.235850] stmmc_pltfr_init: init for RMII
<6>[ 1.236297] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 1.236306] Normal descriptors
<6>[ 1.236313] Ring mode enabled
<6>[ 1.236321] DMA HW capability register supported
<6>[ 1.236330] RX Checksum Offload Engine supported (type 2)
<6>[ 1.236338] TX Checksum insertion supported
<6>[ 1.236345] Wake-Up On Lan supported
<6>[ 1.236377] Enable RX Mitigation via HW Watchdog Timer
<6>[ 1.236772] PPP generic driver version 2.4.2
<6>[ 1.236909] PPP BSD Compression module registered
<6>[ 1.236919] PPP Deflate Compression module registered
<6>[ 1.236935] PPP MPPE Compression module registered
<6>[ 1.236945] NET: Registered protocol family 24
<6>[ 1.236973] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 1.236982] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 1.236992] Rockchip WiFi SYS interface (V1.00) …
<4>[ 1.237020] esp_mem_init enter date Jan 11 2020 14:09:49
<4>[ 1.237029] esp_mem_init VERSION [V2.5]
<4>[ 1.237071] esp_mem_init complete
<6>[ 1.237141] usbcore: registered new interface driver catc
<6>[ 1.237177] usbcore: registered new interface driver kaweth
<6>[ 1.237187] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 1.237222] usbcore: registered new interface driver pegasus
<6>[ 1.237258] usbcore: registered new interface driver rtl8150
<6>[ 1.237267] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 1.237327] usbcore: registered new interface driver hso
<6>[ 1.237367] usbcore: registered new interface driver asix
<6>[ 1.237406] usbcore: registered new interface driver ax88179_178a
<6>[ 1.237442] usbcore: registered new interface driver cdc_ether
<6>[ 1.237477] usbcore: registered new interface driver cdc_eem
<6>[ 1.237512] usbcore: registered new interface driver dm9601
<6>[ 1.237546] usbcore: registered new interface driver dm9620
<6>[ 1.237589] usbcore: registered new interface driver smsc75xx
<6>[ 1.237634] usbcore: registered new interface driver smsc95xx
<6>[ 1.237671] usbcore: registered new interface driver gl620a
<6>[ 1.237706] usbcore: registered new interface driver net1080
<6>[ 1.237741] usbcore: registered new interface driver plusb
<6>[ 1.237777] usbcore: registered new interface driver rndis_host
<6>[ 1.237812] usbcore: registered new interface driver cdc_subset
<6>[ 1.237846] usbcore: registered new interface driver zaurus
<6>[ 1.237883] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 1.237938] usbcore: registered new interface driver int51x1
<6>[ 1.237976] usbcore: registered new interface driver kalmia
<6>[ 1.238012] usbcore: registered new interface driver ipheth
<6>[ 1.238050] usbcore: registered new interface driver sierra_net
<6>[ 1.238086] usbcore: registered new interface driver cx82310_eth
<6>[ 1.238129] usbcore: registered new interface driver cdc_ncm
<6>[ 1.238170] usbcore: registered new interface driver qmi_wwan
<6>[ 1.238207] usbcore: registered new interface driver cdc_mbim
<6>[ 1.631901] GobiNet: Quectel_WCDMA<E_Linux&Android_GobiNet_Driver_V1.3.0
<6>[ 1.631949] usbcore: registered new interface driver GobiNet
<6>[ 1.631959] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<7>[ 1.631970] ehci_hcd: block sizes: qh 64 qtd 96 itd 160 sitd 96
<6>[ 1.631992] ehci-platform: EHCI generic platform driver
<7>[ 1.632318] rockchip_ehci_host ff500000.usb: ehci_rk probe!
<6>[ 1.634585] EHCI: ehci_rk_probe e2280000 e2280010
<6>[ 1.634599] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 1.634624] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<7>[ 1.634647] rockchip_ehci_host ff500000.usb: reset hcs_params 0x1111 dbg=0 cc=1 pcc=1 ordered ports=1
<7>[ 1.634661] rockchip_ehci_host ff500000.usb: reset hcc_params a026 thresh 2 uframes 256/512/1024 park
<7>[ 1.634942] rockchip_ehci_host ff500000.usb: park 0
<7>[ 1.634965] rockchip_ehci_host ff500000.usb: reset command 0080b02 park=3 ithresh=8 period=1024 Reset HALT
<6>[ 1.634992] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<7>[ 1.635011] rockchip_ehci_host ff500000.usb: init command 0010005 (park)=0 ithresh=1 period=512 RUN
<6>[ 1.649051] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<7>[ 1.649131] usb usb1: default language 0x0409
<7>[ 1.649159] usb usb1: udev 1, busnum 1, minor = 0
<6>[ 1.649172] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.649184] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.649195] usb usb1: Product: EHCI Host Controller
<6>[ 1.649206] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 1.649216] usb usb1: SerialNumber: ff500000.usb
<7>[ 1.649523] usb usb1: usb_probe_device
<7>[ 1.649538] usb usb1: configuration #1 chosen from 1 choice
<7>[ 1.649566] usb usb1: adding 1-0:1.0 (config #1, interface 0)
<7>[ 1.649652] hub 1-0:1.0: usb_probe_interface
<7>[ 1.649664] hub 1-0:1.0: usb_probe_interface - got id
<6>[ 1.649677] hub 1-0:1.0: USB hub found
<6>[ 1.649697] hub 1-0:1.0: 1 port detected
<7>[ 1.649707] hub 1-0:1.0: standalone hub
<7>[ 1.649717] hub 1-0:1.0: individual port power switching
<7>[ 1.649728] hub 1-0:1.0: individual port over-current protection
<7>[ 1.649739] hub 1-0:1.0: power on to power good time: 20ms
<7>[ 1.649757] hub 1-0:1.0: local power source is good
<7>[ 1.649806] hub 1-0:1.0: enabling power on all ports
<6>[ 1.649926] EHCI: ehci_rk_probe ok
<6>[ 1.650021] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<7>[ 1.650031] ohci_hcd: block sizes: ed 64 td 64
<7>[ 1.650184] ohci-rockchip ff520000.usb: ohci_hcd_rk_probe
<6>[ 1.650283] ohci-rockchip ff520000.usb: RK OHCI Host Controller
<6>[ 1.650306] ohci-rockchip ff520000.usb: new USB bus registered, assigned bus number 2
<7>[ 1.650324] ohci-rockchip ff520000.usb: starting OHCI controller
<7>[ 1.650378] ohci-rockchip ff520000.usb: created debug files
<6>[ 1.650405] ohci-rockchip ff520000.usb: irq 73, io mem 0xff520000
<7>[ 1.712035] ohci-rockchip ff520000.usb: OHCI controller state
<7>[ 1.712051] ohci-rockchip ff520000.usb: OHCI 1.0, NO legacy support registers, rh state running
<7>[ 1.712066] ohci-rockchip ff520000.usb: control 0x283 RWC HCFS=operational CBSR=3
<7>[ 1.712078] ohci-rockchip ff520000.usb: cmdstatus 0x00000 SOC=0
<7>[ 1.712091] ohci-rockchip ff520000.usb: intrstatus 0x00000004 SF
<7>[ 1.712105] ohci-rockchip ff520000.usb: intrenable 0x8000005a MIE RHSC UE RD WDH
<7>[ 1.712118] ohci-rockchip ff520000.usb: hcca frame #0005
<7>[ 1.712133] ohci-rockchip ff520000.usb: roothub.a 02001201 POTPGT=2 NOCP NPS NDP=1(1)
<7>[ 1.712145] ohci-rockchip ff520000.usb: roothub.b 00000000 PPCM=0000 DR=0000
<7>[ 1.712157] ohci-rockchip ff520000.usb: roothub.status 00008000 DRWE
<7>[ 1.712171] ohci-rockchip ff520000.usb: roothub.portstatus [0] 0x00000100 PPS
<7>[ 1.712211] usb usb2: default language 0x0409
<7>[ 1.712236] usb usb2: udev 1, busnum 2, minor = 128
<6>[ 1.712248] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
<6>[ 1.712260] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.712271] usb usb2: Product: RK OHCI Host Controller
<6>[ 1.712281] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
<6>[ 1.712291] usb usb2: SerialNumber: ff520000.usb
<7>[ 1.712580] usb usb2: usb_probe_device
<7>[ 1.712594] usb usb2: configuration #1 chosen from 1 choice
<7>[ 1.712619] usb usb2: adding 2-0:1.0 (config #1, interface 0)
<7>[ 1.712704] hub 2-0:1.0: usb_probe_interface
<7>[ 1.712715] hub 2-0:1.0: usb_probe_interface - got id
<6>[ 1.712727] hub 2-0:1.0: USB hub found
<6>[ 1.712746] hub 2-0:1.0: 1 port detected
<7>[ 1.712756] hub 2-0:1.0: standalone hub
<7>[ 1.712766] hub 2-0:1.0: no power switching (usb 1.0)
<7>[ 1.712776] hub 2-0:1.0: no over-current protection
<7>[ 1.712786] hub 2-0:1.0: power on to power good time: 4ms
<7>[ 1.712803] hub 2-0:1.0: local power source is good
<7>[ 1.712850] hub 2-0:1.0: trying to enable port power on non-switchable hub
<6>[ 1.713115] usbcore: registered new interface driver cdc_acm
<6>[ 1.713125] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 1.713177] usbcore: registered new interface driver usblp
<6>[ 1.713218] usbcore: registered new interface driver cdc_wdm
<6>[ 1.713285] usbcore: registered new interface driver usb-storage
<6>[ 1.713324] usbcore: registered new interface driver ums-alauda
<6>[ 1.713360] usbcore: registered new interface driver ums-cypress
<6>[ 1.713397] usbcore: registered new interface driver ums-datafab
<6>[ 1.713432] usbcore: registered new interface driver ums_eneub6250
<6>[ 1.713469] usbcore: registered new interface driver ums-freecom
<6>[ 1.713505] usbcore: registered new interface driver ums-isd200
<6>[ 1.713541] usbcore: registered new interface driver ums-jumpshot
<6>[ 1.713577] usbcore: registered new interface driver ums-karma
<6>[ 1.713616] usbcore: registered new interface driver ums-onetouch
<6>[ 1.713653] usbcore: registered new interface driver ums-sddr09
<6>[ 1.713690] usbcore: registered new interface driver ums-sddr55
<6>[ 1.713726] usbcore: registered new interface driver ums-usbat
<6>[ 1.713807] usbcore: registered new interface driver usbserial
<6>[ 1.713846] usbcore: registered new interface driver usbserial_generic
<6>[ 1.713875] usbserial: USB Serial support registered for generic
<6>[ 1.713914] usbcore: registered new interface driver ch341
<6>[ 1.713947] usbserial: USB Serial support registered for ch341-uart
<6>[ 1.713987] usbcore: registered new interface driver cp210x
<6>[ 1.714015] usbserial: USB Serial support registered for cp210x
<6>[ 1.714070] usbcore: registered new interface driver ftdi_sio
<6>[ 1.714099] usbserial: USB Serial support registered for FTDI USB Serial Device
<6>[ 1.714204] usbcore: registered new interface driver option
<6>[ 1.714233] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 1.714361] usbcore: registered new interface driver pl2303
<6>[ 1.714390] usbserial: USB Serial support registered for pl2303
<6>[ 1.714439] usbcore: registered new interface driver trancevibrator
<6>[ 1.714448] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 1.714823] e2300040
<4>[ 1.714834] Core Release: 3.10a
<4>[ 1.714843] Setting default values for core params
<4>[ 1.714954] Using Buffer DMA mode
<4>[ 1.714964] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.714972] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.714981] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.714990] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 1.715001] Dedicated Tx FIFOs mode
<4>[ 1.715016] pcd_init otg_dev = de000200
<6>[ 1.715320] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 1.715348] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
<6>[ 1.715374] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<7>[ 1.715411] usb usb3: default language 0x0409
<7>[ 1.715438] usb usb3: udev 1, busnum 3, minor = 256
<6>[ 1.715450] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.715462] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.715473] usb usb3: Product: DWC OTG Controller
<6>[ 1.715483] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.715493] usb usb3: SerialNumber: ff580000.usb
<7>[ 1.715814] usb usb3: usb_probe_device
<7>[ 1.715829] usb usb3: configuration #1 chosen from 1 choice
<7>[ 1.715860] usb usb3: adding 3-0:1.0 (config #1, interface 0)
<7>[ 1.715967] hub 3-0:1.0: usb_probe_interface
<7>[ 1.715979] hub 3-0:1.0: usb_probe_interface - got id
<6>[ 1.715992] hub 3-0:1.0: USB hub found
<6>[ 1.716010] hub 3-0:1.0: 1 port detected
<7>[ 1.716020] hub 3-0:1.0: standalone hub
<7>[ 1.716030] hub 3-0:1.0: ganged power switching
<7>[ 1.716040] hub 3-0:1.0: individual port over-current protection
<7>[ 1.716050] hub 3-0:1.0: Single TT
<7>[ 1.716060] hub 3-0:1.0: TT requires at most 8 FS bit times (666 ns)
<7>[ 1.716070] hub 3-0:1.0: power on to power good time: 2ms
<7>[ 1.716087] hub 3-0:1.0: local power source is good
<7>[ 1.716134] hub 3-0:1.0: enabling power on all ports
<6>[ 1.716386] usb20_host: version 3.10a 21-DEC-2012
<4>[ 1.718863] e2380040
<4>[ 1.718875] Core Release: 3.10a
<4>[ 1.718883] Setting default values for core params
<4>[ 1.718978] Using Buffer DMA mode
<4>[ 1.718988] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.718995] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.719004] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.719012] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 1.719032] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 1.719055] usb20_host ff540000.usb: new USB bus registered, assigned bus number 4
<6>[ 1.719079] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 1.719168] Init: Power Port (0)
<7>[ 1.719204] usb usb4: default language 0x0409
<7>[ 1.719229] usb usb4: udev 1, busnum 4, minor = 384
<6>[ 1.719241] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.719253] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.719264] usb usb4: Product: DWC OTG Controller
<6>[ 1.719274] usb usb4: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.719284] usb usb4: SerialNumber: ff540000.usb
<7>[ 1.719548] usb usb4: usb_probe_device
<7>[ 1.719563] usb usb4: configuration #1 chosen from 1 choice
<7>[ 1.719591] usb usb4: adding 4-0:1.0 (config #1, interface 0)
<7>[ 1.719675] hub 4-0:1.0: usb_probe_interface
<7>[ 1.719687] hub 4-0:1.0: usb_probe_interface - got id
<6>[ 1.719699] hub 4-0:1.0: USB hub found
<6>[ 1.719716] hub 4-0:1.0: 1 port detected
<7>[ 1.719727] hub 4-0:1.0: standalone hub
<7>[ 1.719736] hub 4-0:1.0: ganged power switching
<7>[ 1.719746] hub 4-0:1.0: individual port over-current protection
<7>[ 1.719756] hub 4-0:1.0: Single TT
<7>[ 1.719766] hub 4-0:1.0: TT requires at most 8 FS bit times (666 ns)
<7>[ 1.719776] hub 4-0:1.0: power on to power good time: 2ms
<7>[ 1.719793] hub 4-0:1.0: local power source is good
<7>[ 1.719838] hub 4-0:1.0: enabling power on all ports
<6>[ 1.720444] usbcore: registered new interface driver xpad
<6>[ 1.720495] usbcore: registered new interface driver usb_acecad
<6>[ 1.720538] usbcore: registered new interface driver aiptek
<6>[ 1.720580] usbcore: registered new interface driver gtco
<6>[ 1.720622] usbcore: registered new interface driver hanwang
<6>[ 1.720669] usbcore: registered new interface driver kbtab
<6>[ 1.720720] usbcore: registered new interface driver wacom
<4>[ 1.720850] goodix_ts_probe() start
<3>[ 1.720865] Goodix-TS 4-005d: no max-x defined
<7>[ 1.720881] of_get_named_gpio_flags exited with status 234
<7>[ 1.720892] of_get_named_gpio_flags exited with status 233
<7>[ 1.720901] of_get_named_gpio_flags: can’t parse gpios property
<3>[ 1.720911] Goodix-TS 4-005d: no max-x defined
<3>[ 1.720921] Goodix-TS 4-005d: no max-y defined
<7>[ 1.747490] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
<7>[ 1.806510] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
<7>[ 1.806528] hub 3-0:1.0: state 7 ports 1 chg 0000 evt 0000
<7>[ 1.816338] hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0000
<4>[ 1.850587] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -11! Process reset.
<4>[ 1.963922] <<-GTP-ERROR->> GTP i2c test failed time 1.
<4>[ 1.988316] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -11! Process reset.
<4>[ 2.101682] <<-GTP-ERROR->> GTP i2c test failed time 2.
<4>[ 2.126076] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -11! Process reset.
<4>[ 2.239441] <<-GTP-ERROR->> GTP i2c test failed time 3.
<4>[ 2.263834] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -11! Process reset.
<4>[ 2.377201] <<-GTP-ERROR->> GTP i2c test failed time 4.
<4>[ 2.401596] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -11! Process reset.
<4>[ 2.514967] <<-GTP-ERROR->> GTP i2c test failed time 5.
<4>[ 2.534648] <goodix_ts_probe>_2698 I2C communication ERROR!
<4>[ 2.534660] <goodix_ts_probe>_2766 prob error !!!
<4>[ 2.534685] Goodix-TS: probe of 4-005d failed with error -11
<6>[ 2.534766] usbcore: registered new interface driver usbtouch
<4>[ 2.535121] sensor_register_slave:mma8452,id=17
<4>[ 2.535133] sensor_register_slave:gs_mc3230,id=23
<4>[ 2.535140] gsensor_init
<4>[ 2.535149] sensor_register_slave:mpu6880_acc,id=24
<4>[ 2.535157] sensor_register_slave:mpu6500_acc,id=25
<4>[ 2.535166] sensor_register_slave:cm3217,id=48
<4>[ 2.535174] sensor_register_slave:cm3218,id=49
<7>[ 2.535334] rtc-pcf8563 1-0051: pcf8563_probe
<6>[ 2.535346] rtc-pcf8563 1-0051: chip found, driver version 0.4.3
<4>[ 2.535420] rockchip_i2c ff140000.i2c: Warning: addr[0x0051] msg[0].scl_rate( = 0Khz) is too low!
<4>[ 2.535430] scl_rate = 100Khz
<7>[ 2.536940] rtc-pcf8563 1-0051: pcf8563_get_datetime: raw data is st1=08, st2=40, sec=54, min=06, hr=50, mday=46, wday=51, mon=47, year=20
<7>[ 2.536959] rtc-pcf8563 1-0051: pcf8563_get_datetime: tm is secs=54, mins=6, hours=10, mday=6, mon=6, year=120, wday=1
<4>[ 2.536992] rockchip_i2c ff140000.i2c: Warning: addr[0x0051] msg[0].scl_rate( = 0Khz) is too low!
<4>[ 2.537000] scl_rate = 100Khz
<7>[ 2.538505] rtc-pcf8563 1-0051: pcf8563_get_datetime: raw data is st1=08, st2=40, sec=54, min=06, hr=50, mday=46, wday=51, mon=47, year=20
<7>[ 2.538521] rtc-pcf8563 1-0051: pcf8563_get_datetime: tm is secs=54, mins=6, hours=10, mday=6, mon=6, year=120, wday=1
<7>[ 2.538684] rtc rtc0: rtc-pcf8563: dev (253:0)
<6>[ 2.538714] rtc-pcf8563 1-0051: rtc core: registered rtc-pcf8563 as rtc0
<6>[ 2.538751] i2c /dev entries driver
<6>[ 2.539408] IR NEC protocol handler initialized
<6>[ 2.539418] IR RC5(x) protocol handler initialized
<6>[ 2.539426] IR RC6 protocol handler initialized
<6>[ 2.539433] IR JVC protocol handler initialized
<6>[ 2.539441] IR Sony protocol handler initialized
<6>[ 2.539448] IR RC5 (streamzap) protocol handler initialized
<6>[ 2.539456] IR SANYO protocol handler initialized
<6>[ 2.539464] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 2.539600] usbcore: registered new interface driver uvcvideo
<6>[ 2.539609] USB Video Class driver (1.1.1)
<4>[ 2.539620] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<4>[ 2.540557] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 2.540557]
<4>[ 2.540614] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 2.540751] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21d8000 size: 0x4000)
<4>[ 2.541380] D1:camsys_platform_probe(1394): ff910000.isp memory:
<4>[ 2.541395] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe2260000 size: 0x10000)
<4>[ 2.541407] D1:camsys_platform_probe(1399): I2c memory (phy: 0x5889000 vir: 0xc5889000 size: 0x1000)
<4>[ 2.541417] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 2.541427] D1:camsys_platform_probe(1419): Probe ff910000.isp device success
<4>[ 2.542379] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 2.542390] i2c-core: driver [bq27320] using legacy resume method
<4>[ 2.542701] rockchip_temp_probe,line=362
<6>[ 2.593685] tsadc ff280000.tsadc: initialized
<6>[ 2.594101] device-mapper: uevent: version 1.0.3
<6>[ 2.594367] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 2.594628] Bluetooth: HCI UART driver ver 2.2
<6>[ 2.594640] Bluetooth: HCI H4 protocol initialized
<6>[ 2.594648] Bluetooth: HCILL protocol initialized
<6>[ 2.594657] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 2.594665] rtk_btusb: Register usb char device interface for BT driver
<6>[ 2.594839] usbcore: registered new interface driver rtk_btusb
<4>[ 2.594937] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(592000), use default, just enable dvfs
<4>[ 2.778912] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 2.782992] cpuidle: using governor ladder
<6>[ 2.783014] cpuidle: using governor menu
<6>[ 2.783076] Synopsys Designware Multimedia Card Interface Driver
<6>[ 2.783093] MHSC version = Ver 2.00 2015-06-10
<4>[ 2.783547] dw cru_regsbase addr 0x1d8.
<4>[ 2.783566] dw cru_reset_offset val 3.
<6>[ 2.783590] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 2.783647] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 2.784146] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 2.784412] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 2.784460] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 2.784618] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 2.800368] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 2.820089] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 2.820109] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 2.820129] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 2.820615] dw cru_regsbase addr 0x1d8.
<4>[ 2.820635] dw cru_reset_offset val 0.
<6>[ 2.820659] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 2.820710] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 2.821371] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 2.821646] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
<7>[ 2.821695] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 2.822510] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 2.822675] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 2.839725] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 2.852312] mmc0: BKOPS_EN bit is not set
<4>[ 2.854333] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<6>[ 2.856702] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
<4>[ 2.856737] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 2.856773] [mmc0] tuning regsbase addr 0x218.
<3>[ 2.858107] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 2.858128] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 2.858193] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
<3>[ 2.858235] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 2.858253] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 2.858316] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
<3>[ 2.858403] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-248 (23 len)
<3>[ 2.858429] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
<3>[ 2.858453] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-248 (23 len)
<3>[ 2.858474] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
<6>[ 2.858551] mmc0: new HS200 MMC card at address 0001
<6>[ 2.859171] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
<6>[ 2.859469] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 2.859496] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<6>[ 2.859857] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 2.859910] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 2.859932] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 2.859951] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 2.859970] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 2.859989] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 2.860008] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 2.860027] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 2.860046] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 2.860066] system: 0x012400000 – 0x032400000 (512 MB)
<6>[ 2.860085] metadata: 0x032400000 – 0x033400000 (16 MB)
<6>[ 2.860105] radical_update: 0x073400000 – 0x077400000 (64 MB)
<6>[ 2.860125] userdata: 0x077400000 – 0x1d1c00000 (5544 MB)
<4>[ 2.860168] dw cru_regsbase addr 0x1d8.
<4>[ 2.860191] dw cru_reset_offset val 1.
<6>[ 2.860215] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 2.860273] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 2.860753] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 2.860995] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 2.861043] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 2.861546] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 2.863717] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
<4>[ 2.879101] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 2.897783] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 2.897819] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc1]
<4>[ 2.897899] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc1]
<6>[ 2.897928] mmc1: new high speed SDHC card at address b368
<6>[ 2.898494] mmcblk1: mmc1:b368 NCard 14.8 GiB
<6>[ 2.898871] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 2.898898] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<6>[ 2.899287] usbcore: registered new interface driver ushc
<4>[ 2.899593] leds-gpio leds.24: pins are not configured from the driver
<7>[ 2.899623] of_get_named_gpio_flags exited with status 17
<7>[ 2.899646] of_get_named_gpio_flags exited with status 17
<6>[ 2.899791] mmcblk1: p1
<4>[ 2.899890] leds-gpio work-leds.25: pins are not configured from the driver
<7>[ 2.899920] of_get_named_gpio_flags exited with status 257
<7>[ 2.899942] of_get_named_gpio_flags exited with status 257
<6>[ 2.900446] hidraw: raw HID events driver (C) Jiri Kosina
<4>[ 2.900608] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 2.900965] usbcore: registered new interface driver usbhid
<6>[ 2.900984] usbhid: USB HID core driver
<6>[ 2.901203] ashmem: initialized
<6>[ 2.901481] logger: created 256K log ‘log_main’
<6>[ 2.901741] logger: created 256K log ‘log_events’
<6>[ 2.901987] logger: created 256K log ‘log_radio’
<6>[ 2.902252] logger: created 256K log ‘log_system’
<7>[ 2.903948] of_get_named_gpio_flags exited with status 5
<7>[ 2.903973] of_get_named_gpio_flags exited with status 5
<6>[ 2.904456] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input0
<4>[ 2.906158] --es8316_init–start–
<4>[ 2.906265] —es8316_i2c_probe—probe start
<7>[ 2.906293] of_get_named_gpio_flags exited with status 171
<7>[ 2.906327] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 2.906344] es8316_i2c_probe() Can not read property hp codec-en-gpio
<7>[ 2.906360] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 2.906375] es8316_i2c_probe() Can not read property hp_det gpio
<6>[ 2.908113] rockchip-spdif ff8b0000.rockchip-spdif: spdif ready.
<4>[ 2.909977] —es8316_probe–start–
<3>[ 2.917159] es8316_probe: 1177, retv=0
<4>[ 3.045992] es8316 2-0010: ASoC: Failed to create HPVOL R debugfs file
<4>[ 3.046027] es8316 2-0010: ASoC: Failed to create HPVOL L debugfs file
<4>[ 3.047038] es8316 2-0010: ASoC: Failed to create HPCP R debugfs file
<4>[ 3.047070] es8316 2-0010: ASoC: Failed to create HPCP L debugfs file
<4>[ 3.047634] es8316 2-0010: ASoC: Failed to create Right Hp mixer debugfs file
<4>[ 3.048133] es8316 2-0010: ASoC: Failed to create Left Hp mixer debugfs file
<4>[ 3.050891] Enter::rk29_es8316_init----118
<6>[ 3.058930] rockchip-es8316 rockchip-es8316.32: ES8316 HiFi ↔ ff890000.rockchip-i2s mapping ok
<6>[ 3.060558] u32 classifier
<6>[ 3.060579] Actions configured
<6>[ 3.060602] Netfilter messages via NETLINK v0.30.
<6>[ 3.060692] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 3.061465] ctnetlink v0.93: registering with nfnetlink.
<6>[ 3.061579] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 3.061596] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 3.062197] xt_time: kernel timezone is -0000
<6>[ 3.062713] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 3.063018] arp_tables: (C) 2002 David S. Miller
<6>[ 3.063101] TCP: cubic registered
<6>[ 3.063117] Initializing XFRM netlink socket
<6>[ 3.063744] NET: Registered protocol family 10
<6>[ 3.065012] mip6: Mobile IPv6
<6>[ 3.065073] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 3.065361] sit: IPv6 over IPv4 tunneling driver
<6>[ 3.066186] NET: Registered protocol family 17
<6>[ 3.066226] NET: Registered protocol family 15
<5>[ 3.066310] Bridge firewalling registered
<6>[ 3.066327] Ebtables v2.0 registered
<6>[ 3.066519] Bluetooth: RFCOMM TTY layer initialized
<6>[ 3.066556] Bluetooth: RFCOMM socket layer initialized
<6>[ 3.066568] Bluetooth: RFCOMM ver 1.11
<6>[ 3.066580] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 3.066591] Bluetooth: BNEP filters: protocol multicast
<6>[ 3.066610] Bluetooth: BNEP socket layer initialized
<6>[ 3.066622] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 3.066640] Bluetooth: HIDP socket layer initialized
<6>[ 3.066676] l2tp_core: L2TP core driver, V2.0
<6>[ 3.066698] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 3.066709] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 3.066959] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 3.066973] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 3.066986] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212a
<6>[ 3.066998] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 3.067010] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 3.067022] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 3.067041] of_get_named_gpio_flags exited with status 156
<6>[ 3.067053] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 3.067065] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 3.067078] of_get_named_gpio_flags exited with status 158
<6>[ 3.067091] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 3.067102] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 3.067133] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 3.3V
<6>[ 3.067145] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 3.067195] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 3.067415] of_get_named_gpio_flags exited with status 147
<6>[ 3.067429] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 3.067444] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 3.067458] of_get_named_gpio_flags exited with status 157
<6>[ 3.067470] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 3.067483] of_get_named_gpio_flags exited with status 154
<6>[ 3.067495] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 3.067508] of_get_named_gpio_flags exited with status 159
<6>[ 3.067520] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 3.067580] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 3.067696] [BT_RFKILL]: ** disable irq
<6>[ 3.067815] [BT_RFKILL]: ap6210 device registered.
<4>[ 3.069113] rk3288_init_suspend
<4>[ 3.069129] rk3288_suspend_init enter
<4>[ 3.069325] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 3.069370] gpio_get_dts_info suspend:4
<4>[ 3.069382] gpio_get_dts_info resume:4
<4>[ 3.069392] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 3.069445] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 3.069710] clks_gating_suspend_init:clkgt info ok
<5>[ 3.069858] Registering SWP/SWPB emulation handler
<6>[ 3.070397] ddrfreq: verion 1.2 20140526
<6>[ 3.070417] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 528MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
<6>[ 3.070428] ddrfreq: auto-freq=0
<6>[ 3.070439] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 3.070449] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 3.070459] ddrfreq: auto-freq-table[2] 456MHz
<6>[ 3.070469] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 3.082826] regulator-dummy: disabling
<4>[ 3.083005] =======================================================
<4>[ 3.083019] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 3.083028] =======================================================
<4>[ 3.083040] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 3.083147] dhd_module_init: in
<4>[ 3.083164] ======== bcm_wlan_set_plat_data ========
<6>[ 3.083176] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 3.083216] host_oob_irq: 195
<4>[ 3.083227] host_oob_irq_flags=4
<4>[ 3.083236] dhd_wifi_platform_load: Enter
<4>[ 3.083261] pcd_pullup, is_on 0
<4>[ 3.083280] Power-up adapter ‘DHD generic adapter’
<4>[ 3.083328] wifi_platform_set_power = 1
<4>[ 3.083340] ======== PULL WL_REG_ON HIGH! ========
<6>[ 3.083345] file system registered
<6>[ 3.083360] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 3.083371] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 3.083382] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 3.084578] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 3.084595] android_usb gadget: Number of LUNs=2
<6>[ 3.084609] lun0: LUN: removable file: (no medium)
<6>[ 3.084622] lun1: LUN: removable file: (no medium)
<6>[ 3.084985] android_usb gadget: android_usb ready
<6>[ 3.085331] sensor_init: Probe name sensors
<4>[ 3.085359] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<4>[ 3.085418] rockchip_i2c ff140000.i2c: Warning: addr[0x0051] msg[0].scl_rate( = 0Khz) is too low!
<4>[ 3.085429] scl_rate = 100Khz
<7>[ 3.086979] rtc-pcf8563 1-0051: pcf8563_get_datetime: raw data is st1=08, st2=40, sec=55, min=06, hr=50, mday=46, wday=51, mon=47, year=20
<7>[ 3.087007] rtc-pcf8563 1-0051: pcf8563_get_datetime: tm is secs=55, mins=6, hours=10, mday=6, mon=6, year=120, wday=1
<6>[ 3.087046] rtc-pcf8563 1-0051: setting system clock to 2020-07-06 10:06:55 UTC (1594030015)
<6>[ 3.099318] usbcore: registered new interface driver snd-usb-audio
<6>[ 3.099336] ALSA device list:
<6>[ 3.099347] #0: RK_ES8316
<3>[ 3.099448] Warning: unable to open an initial console.
<6>[ 3.099818] Freeing unused kernel memory: 356K (c0bfe000 - c0c57000)
<7>[ 3.131969] SELinux: 2048 avtab hash slots, 5456 rules.
<7>[ 3.133702] SELinux: 2048 avtab hash slots, 5456 rules.
<7>[ 3.133723] SELinux: 1 users, 2 roles, 449 types, 0 bools, 1 sens, 1024 cats
<7>[ 3.133731] SELinux: 86 classes, 5456 rules
<7>[ 3.134664] SELinux: Completing initialization.
<7>[ 3.134671] SELinux: Setting up existing superblocks.
<7>[ 3.134687] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 3.134704] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 3.134758] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 3.134770] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 3.134785] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.134801] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 3.135030] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 3.146973] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 3.146990] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 3.147000] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 3.147011] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 3.147030] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 3.147083] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 3.147092] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.147113] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<6>[ 3.184085] [WLAN_RFKILL]: wifi turn on power. 156
<5>[ 3.315364] type=1403 audit(1594030015.720:2): policy loaded auid=4294967295 ses=4294967295
<11>[ 3.342348] init: /init.rk30board.rc: 167: invalid option ‘net’
<11>[ 3.344905] init: invalid gid ‘trace’
<4>[ 3.390734] wifi_platform_bus_enumerate device present 1
<4>[ 3.390744] ======== Card detection to detect SDIO card! ========
<6>[ 3.390750] mmc2:mmc host rescan start!
<5>[ 3.425734] type=1400 audit(1594030015.830:3): avc: denied { write } for pid=125 comm=“ueventd” name=“uevent” dev=“sysfs” ino=12552 scontext=u:r:ueventd:s0 tcontext=u:object_r:sysfs_hdmi:s0 tclass=file permissive=1
<5>[ 3.425766] type=1400 audit(1594030015.830:4): avc: denied { open } for pid=125 comm=“ueventd” path=“/sys/devices/virtual/display/HDMI/uevent” dev=“sysfs” ino=12552 scontext=u:r:ueventd:s0 tcontext=u:object_r:sysfs_hdmi:s0 tclass=file permissive=1
<11>[ 3.443512] init: /dev/hw_random not found
<6>[ 3.443566] keychord: using input dev rk29-keypad for fevent
<7>[ 3.443958] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 3.444240] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.444518] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 3.445779] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.445933] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.447148] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 3.448378] init: /dev/hw_random not found
<14>[ 3.449319] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 3.450209] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 131072 blocks long. Nothing to do!resize2fs:
<4>[ 3.452653] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 3.456228] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 3.456247] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 3.456308] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 3.457086] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 3.461918] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 3.461958] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/system: clean, 1892/32768 files, 115679/131072 blocks
<6>[ 3.465303] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 3.465320] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 3.465362] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 3.472091] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 3.472517] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 3.472531] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 3.472567] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 3.472884] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 3.476242] EXT4-fs (mmcblk0p11): recovery complete
<6>[ 3.476253] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 3.476264] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 3.476297] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 3.476987] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 3.483686] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 3.483714] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 3.487572] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 3.487589] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 3.487634] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 3.487671] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 3.490801] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 3.490832] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 3.491078] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 3.491345] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<4>[ 3.607199] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<6>[ 3.631809] EHCI: rk_ehci_hcd_enable, enable host controller
<4>[ 3.641962] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 3.643480] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 3.645002] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 3.647720] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<4>[ 3.651041] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
<6>[ 3.690409] EXT4-fs (mmcblk0p13): recovery complete
<6>[ 3.690853] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 3.690871] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 3.690934] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 3.695124] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<4>[ 3.695769] dwc_otg_hcd_enable, enable host controller
<14>[ 3.703129] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 3.703158] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 997/354816 files, 149053/1419264 blocks
<6>[ 3.707102] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 3.707119] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 3.707159] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 3.707175] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 3.707829] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<3>[ 3.725783] mali_kbase: exports duplicate symbol _mali_profiling_control (owned by kernel)
<6>[ 3.738386] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 3.738405] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 3.738474] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<6>[ 3.739707] mmc2: new high speed SDIO card at address 0001
<4>[ 3.755875] bcmsdh_register: register client driver
<4>[ 3.755948] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 3.756012] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 3.756020] bus num (host idx)=2, slot num (rca)=1
<4>[ 3.756025] found adapter info ‘DHD generic adapter’
<4>[ 3.756260] F1 signature read @0x18000000=0x1541a9a6
<4>[ 3.757848] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
<4>[ 3.758433] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
<4>[ 3.758512] wifi_platform_get_mac_addr
<4>[ 3.758517] ======== bcm_wlan_get_mac_address ========
<6>[ 3.758523] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 3.758531] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 3.758536] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 3.758544] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
<4>[ 3.758583] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 3.758887] wl_create_event_handler(): thread:wl_event_handler:94 started
<4>[ 3.758972] tsk Enter, tsk = 0xdd54149c
<4>[ 3.758993] dhd_attach(): thread:dhd_watchdog_thread:95 started
<4>[ 3.759043] dhd_attach(): thread:dhd_dpc:96 started
<4>[ 3.759055] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 3.759092] dhd_attach(): thread:dhd_rxf:97 started
<4>[ 3.759104] dhd_deferred_work_init: work queue initialized
<4>[ 3.759219] dhdsdio_probe_init: set use_rxchain 0 from config.txt
<4>[ 3.765322] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 3.765322] Compiled in drivers/net/wireless/bcmdhd on Jan 11 2020 at 14:09:55
<4>[ 3.765655] Register interface [wlan0] MAC: 8c:f7:10:38:55:36
<4>[ 3.765655]
<4>[ 3.765666] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 3.765693] bcmsdh_oob_intr_unregister: Enter
<4>[ 3.765699] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 3.765707] dhd_txglom_enable: enable 0
<4>[ 3.765713] dhd_bus_devreset: WLAN OFF DONE
<4>[ 3.765745] wifi_platform_set_power = 0
<4>[ 3.765750] ======== PULL WL_REG_ON LOW! ========
<6>[ 3.765756] [WLAN_RFKILL]: rockchip_wifi_power: 0
<4>[ 3.799547] Using Buffer DMA mode
<4>[ 3.799555] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.799560] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.799566] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.799571] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.843429] Init: Power Port (0)
<3>[ 3.844549] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 3.845119] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 3.845672] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 3.846464] zram0: detected capacity change from 0 to 533413888
<6>[ 3.872895] [WLAN_RFKILL]: wifi shut off power.
<6>[ 3.872907] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 3.872913] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 3.872969] dhd_module_init: Exit err=0
<6>[ 3.891494] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<3>[ 3.929928] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<14>[ 3.939298] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 3.939340] bat_cap: oldcap_path no exist
<6>[ 3.939497] binder: 154:154 transaction failed 29189, size 0-0
<11>[ 3.939996] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 3.944039] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 3.944057] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 3.944261] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 3.944751] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.944759] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 3.944773] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.944778] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 3.944795] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.944800] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 3.944811] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.944815] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<11>[ 3.969553] init: service ‘console’ requires console
<6>[ 3.986052] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
<7>[ 3.990979] hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0002
<7>[ 3.991005] hub 4-0:1.0: port 1, status 0101, change 0001, 12 Mb/s
<5>[ 3.991596] type=1400 audit(1594030016.410:5): avc: denied { write } for pid=1 comm=“init” name=“egl” dev=“mmcblk0p10” ino=361 scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
<5>[ 3.991622] type=1400 audit(1594030016.410:6): avc: denied { remove_name } for pid=1 comm=“init” name=“libGLES_mali.so” dev=“mmcblk0p10” ino=404 scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
<5>[ 3.991642] type=1400 audit(1594030016.410:7): avc: denied { unlink } for pid=1 comm=“init” name=“libGLES_mali.so” dev=“mmcblk0p10” ino=404 scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1
<5>[ 4.040666] type=1400 audit(1594030016.460:8): avc: denied { add_name } for pid=1 comm=“init” name=“libGLES_mali.so” scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
<5>[ 4.040696] type=1400 audit(1594030016.460:9): avc: denied { create } for pid=1 comm=“init” name=“libGLES_mali.so” scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=lnk_file permissive=1
<38>[ 4.042951] logd.auditd: start
<6>[ 4.047081] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
<11>[ 4.050770] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 4.052880] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 4.053787] init: Warning! Service rk_watchdog needs a SELinux domain defined; please fix!
<11>[ 4.054014] init: cannot find ‘/system/bin/hwaddr’, disabling ‘hwwwwwwaddr’
<11>[ 4.054205] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 4.054967] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
<11>[ 4.055168] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<7>[ 4.148430] hub 4-0:1.0: debounce: port 1: total 100ms stable 100ms status 0x101
<4>[ 4.148455] Indeed it is in host mode hprt0 = 00021501
<6>[ 4.325545] usb 4-1: new high-speed USB device number 2 using usb20_host
<4>[ 4.325623] Indeed it is in host mode hprt0 = 00001101
<6>[ 4.359897] warning: `daemonsu’ uses 32-bit capabilities (legacy support in use)
<7>[ 4.443919] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 4.444523] android_usb: already disabled
<6>[ 4.447072] read descriptors
<6>[ 4.447086] read strings
<6>[ 4.447103] mtp_bind_config
<4>[ 4.447128] pcd_pullup, is_on 1
<7>[ 4.485915] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<7>[ 4.522509] usb 4-1: udev 2, busnum 4, minor = 385
<6>[ 4.522521] usb 4-1: New USB device found, idVendor=0424, idProduct=2517
<6>[ 4.522529] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
<7>[ 4.522892] usb 4-1: usb_probe_device
<7>[ 4.522903] usb 4-1: configuration #1 chosen from 1 choice
<7>[ 4.523037] usb 4-1: adding 4-1:1.0 (config #1, interface 0)
<7>[ 4.523149] hub 4-1:1.0: usb_probe_interface
<7>[ 4.523159] hub 4-1:1.0: usb_probe_interface - got id
<6>[ 4.523169] hub 4-1:1.0: USB hub found
<6>[ 4.523238] hub 4-1:1.0: 7 ports detected
<7>[ 4.523248] hub 4-1:1.0: standalone hub
<7>[ 4.523255] hub 4-1:1.0: individual port power switching
<7>[ 4.523261] hub 4-1:1.0: individual port over-current protection
<7>[ 4.523346] hub 4-1:1.0: TT per port
<7>[ 4.523355] hub 4-1:1.0: TT requires at most 8 FS bit times (666 ns)
<7>[ 4.523361] hub 4-1:1.0: Port indicators are supported
<7>[ 4.523368] hub 4-1:1.0: power on to power good time: 100ms
<7>[ 4.523458] hub 4-1:1.0: local power source is good
<7>[ 4.523626] hub 4-1:1.0: enabling power on all ports
<7>[ 4.523905] hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0002
<7>[ 4.523922] hub 4-0:1.0: port 1 enable change, status 00000503
<7>[ 4.618611] _gpio_request: gpio-170 (sysfs) status -16
<7>[ 4.618621] export_store: status -16
<7>[ 4.620848] hub 4-1:1.0: port 2: status 0101 change 0001
<7>[ 4.620975] hub 4-1:1.0: port 4: status 0301 change 0001
<38>[ 4.638383] type=1400 audit(1594030017.060:10): avc: denied { getattr } for pid=225 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=16443 scontext=u:r:rild:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 4.638603] type=1400 audit(1594030017.060:11): avc: denied { execute } for pid=225 comm=“sh” name=“logcat” dev=“mmcblk0p10” ino=16443 scontext=u:r:rild:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 4.638690] type=1400 audit(1594030017.060:12): avc: denied { read open } for pid=225 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=16443 scontext=u:r:rild:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 4.638767] type=1400 audit(1594030017.060:13): avc: denied { execute_no_trans } for pid=225 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=16443 scontext=u:r:rild:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<12>[ 4.641581] avc: denied { set } for property=telephony.lteOnCdmaDevice scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service
<6>[ 4.692943] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
<6>[ 4.699659] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
<38>[ 4.706413] type=1400 audit(1594030017.130:14): avc: denied { setattr } for pid=215 comm=“daemonsu” name=“daemonsu” dev=“mmcblk0p10” ino=373 scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
<38>[ 4.717985] type=1400 audit(1594030017.140:15): avc: denied { relabelfrom } for pid=233 comm=“toolbox” name=“daemonsu” dev=“mmcblk0p10” ino=373 scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
<38>[ 4.718197] type=1400 audit(1594030017.140:16): avc: denied { relabelto } for pid=233 comm=“toolbox” name=“daemonsu” dev=“mmcblk0p10” ino=373 scontext=u:r:init:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
<7>[ 4.719172] hub 4-1:1.0: state 7 ports 7 chg 0014 evt 0000
<7>[ 4.719265] hub 4-1:1.0: port 2, status 0101, change 0000, 12 Mb/s
<38>[ 4.731614] type=1400 audit(1594030017.160:17): avc: denied { append } for pid=227 comm=“logcat” path=“/data/quectel_debug_log/0706_180657_radio.txt” dev=“mmcblk0p13” ino=129035 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
<38>[ 4.731860] type=1400 audit(1594030017.160:18): avc: denied { write } for pid=227 comm=“logcat” name=“logdr” dev=“tmpfs” ino=1322 scontext=u:r:rild:s0 tcontext=u:object_r:logdr_socket:s0 tclass=sock_file permissive=1
<38>[ 4.731949] type=1400 audit(1594030017.160:19): avc: denied { connectto } for pid=227 comm=“logcat” path=“/dev/socket/logdr” scontext=u:r:rild:s0 tcontext=u:r:logd:s0 tclass=unix_stream_socket permissive=1
<6>[ 4.797995] usb 4-1.2: new high-speed USB device number 3 using usb20_host
<6>[ 4.868436] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
<12>[ 4.925222] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<12>[ 4.925525] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<12>[ 4.925836] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<6>[ 4.943317] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null)
<38>[ 4.962205] type=1400 audit(1594030017.390:20): avc: denied { relabelto } for pid=294 comm=“toolbox” name=“tmp-mksh” dev=“rootfs” ino=6318 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
<38>[ 4.968690] type=1400 audit(1594030017.400:21): avc: denied { create } for pid=296 comm=“toolbox” name=“tmp-mksh” scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
<38>[ 4.968964] type=1400 audit(1594030017.400:22): avc: denied { write } for pid=296 comm=“toolbox” path=“/tmp-mksh/tmp-mksh” dev=“rootfs” ino=1416 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
<38>[ 4.975405] type=1400 audit(1594030017.410:23): avc: denied { setattr } for pid=299 comm=“toolbox” name=“tmp-mksh” dev=“rootfs” ino=1416 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
<38>[ 4.981798] type=1400 audit(1594030017.410:24): avc: denied { relabelto } for pid=302 comm=“toolbox” name=“tmp-mksh” dev=“rootfs” ino=1416 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
<7>[ 4.982076] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<11>[ 5.004172] init: untracked pid 310 exited with status 0
<7>[ 5.008451] usb 4-1.2: skipped 1 descriptor after configuration
<7>[ 5.008466] usb 4-1.2: skipped 5 descriptors after interface
<7>[ 5.008476] usb 4-1.2: skipped 1 descriptor after endpoint
<7>[ 5.008485] usb 4-1.2: skipped 23 descriptors after interface
<7>[ 5.008495] usb 4-1.2: skipped 1 descriptor after endpoint
<7>[ 5.008502] usb 4-1.2: skipped 4 descriptors after interface
<7>[ 5.008508] usb 4-1.2: skipped 2 descriptors after interface
<7>[ 5.008515] usb 4-1.2: skipped 1 descriptor after endpoint
<7>[ 5.008988] usb 4-1.2: default language 0x0409
<7>[ 5.014037] usb 4-1.2: udev 3, busnum 4, minor = 386
<6>[ 5.014049] usb 4-1.2: New USB device found, idVendor=058f, idProduct=2657
<6>[ 5.014057] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 5.014063] usb 4-1.2: Product: PC Camera
<6>[ 5.014069] usb 4-1.2: Manufacturer: Alcor Micro, Corp.
<7>[ 5.014937] usb 4-1.2: usb_probe_device
<7>[ 5.014949] usb 4-1.2: configuration #1 chosen from 1 choice
<7>[ 5.015373] usb 4-1.2: adding 4-1.2:1.0 (config #1, interface 0)
<7>[ 5.019439] uvcvideo 4-1.2:1.0: usb_probe_interface
<7>[ 5.019453] uvcvideo 4-1.2:1.0: usb_probe_interface - got id
<6>[ 5.019481] uvcvideo: Found UVC 1.00 device PC Camera (058f:2657)
<6>[ 5.022948] input: PC Camera as /devices/ff540000.usb/usb4/4-1/4-1.2/4-1.2:1.0/input/input1
<7>[ 5.023727] usb 4-1.2: adding 4-1.2:1.1 (config #1, interface 1)
<7>[ 5.027287] usb 4-1.2: adding 4-1.2:1.2 (config #1, interface 2)
<7>[ 5.028439] snd-usb-audio 4-1.2:1.2: usb_probe_interface
<7>[ 5.028455] snd-usb-audio 4-1.2:1.2: usb_probe_interface - got id
<7>[ 5.049248] usb 4-1.2: adding 4-1.2:1.3 (config #1, interface 3)
<7>[ 5.050459] hub 4-1:1.0: port 4, status 0301, change 0000, 1.5 Mb/s
<7>[ 5.063624] hub 4-1:1.0: port 4 not reset yet, waiting 10ms
<6>[ 5.142360] usb 4-1.4: new low-speed USB device number 4 using usb20_host
<7>[ 5.242731] usb 4-1.4: skipped 1 descriptor after interface
<7>[ 5.250517] usb 4-1.4: default language 0x0409
<7>[ 5.251521] usb 4-1.4: udev 4, busnum 4, minor = 387
<6>[ 5.251535] usb 4-1.4: New USB device found, idVendor=0000, idProduct=3825
<6>[ 5.251542] usb 4-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 5.251548] usb 4-1.4: Product: USB OPTICAL MOUSE
<7>[ 5.251852] usb 4-1.4: usb_probe_device
<7>[ 5.251863] usb 4-1.4: configuration #1 chosen from 1 choice
<7>[ 5.253141] usb 4-1.4: adding 4-1.4:1.0 (config #1, interface 0)
<7>[ 5.253408] usbhid 4-1.4:1.0: usb_probe_interface
<7>[ 5.253417] usbhid 4-1.4:1.0: usb_probe_interface - got id
<6>[ 5.256985] input: USB OPTICAL MOUSE as /devices/ff540000.usb/usb4/4-1/4-1.4/4-1.4:1.0/input/input2
<6>[ 5.257530] hid-generic 0003:0000:3825.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-ff540000.usb-1.4/input0
<6>[ 5.284857] rk3288-lcdc lcdc0: blank mode:0
<7>[ 5.603989] unexport_store: status -22
<7>[ 6.182047] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<38>[ 8.520613] type=1400 audit(1594030021.010:25): avc: denied { execute } for pid=550 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=16490 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.520827] type=1400 audit(1594030021.010:26): avc: denied { read open } for pid=550 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=16490 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.520967] type=1400 audit(1594030021.010:27): avc: denied { execute_no_trans } for pid=550 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=16490 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.523118] type=1400 audit(1594030021.010:28): avc: denied { getattr } for pid=550 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=16497 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.523243] type=1400 audit(1594030021.010:29): avc: denied { execute } for pid=550 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=16497 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.523404] type=1400 audit(1594030021.010:30): avc: denied { read open } for pid=550 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=16497 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.523503] type=1400 audit(1594030021.010:31): avc: denied { execute_no_trans } for pid=550 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=16497 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<6>[ 9.599787] [otg id chg] last id -1 current id 1
<4>[ 9.599804] PortPower off
<4>[ 9.599811] rk_battery_charger_detect_cb , battery_charger_detect 6
<7>[ 9.648983] hub 3-0:1.0: state 7 ports 1 chg 0000 evt 0002
<7>[ 9.649011] hub 3-0:1.0: port 1, status 0000, change 0001, 12 Mb/s
<4>[ 9.699232] Using Buffer DMA mode
<4>[ 9.699244] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 9.699250] Multiprocessor Interrupt Enhancement - disabled
<4>[ 9.699257] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 9.699263] ^^^^^^^^^^^^^^^^^Device Mode
<7>[ 9.806442] hub 3-0:1.0: debounce: port 1: total 100ms stable 100ms status 0x0
<4>[ 10.190342] rk_battery_charger_detect_cb , battery_charger_detect 0
<7>[ 11.522583] hub 4-1:1.0: state 7 ports 7 chg 0000 evt 0040
<7>[ 11.522831] hub 4-1:1.0: port 6, status 0101, change 0001, 12 Mb/s
<12>[ 11.670678] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<7>[ 11.676157] hub 4-1:1.0: debounce: port 6: total 100ms stable 100ms status 0x101
<6>[ 11.754886] usb 4-1.6: new high-speed USB device number 5 using usb20_host
<6>[ 11.817000] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 11.817012] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 11.817017] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 11.817023] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 11.817027] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 11.817032] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 11.817037] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<7>[ 11.857290] usb 4-1.6: skipped 4 descriptors after interface
<7>[ 11.857303] usb 4-1.6: skipped 4 descriptors after interface
<7>[ 11.857310] usb 4-1.6: skipped 4 descriptors after interface
<7>[ 11.859225] usb 4-1.6: default language 0x0409
<7>[ 11.863171] usb 4-1.6: udev 5, busnum 4, minor = 388
<6>[ 11.863184] usb 4-1.6: New USB device found, idVendor=2c7c, idProduct=0125
<6>[ 11.863192] usb 4-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 11.863198] usb 4-1.6: Product: Android
<6>[ 11.863205] usb 4-1.6: Manufacturer: Android
<7>[ 11.863566] usb 4-1.6: usb_probe_device
<7>[ 11.863578] usb 4-1.6: configuration #1 chosen from 1 choice
<7>[ 11.864361] usb 4-1.6: adding 4-1.6:1.0 (config #1, interface 0)
<7>[ 11.864563] GobiNet 4-1.6:1.0: usb_probe_interface
<7>[ 11.864573] GobiNet 4-1.6:1.0: usb_probe_interface - got id
<7>[ 11.864671] option 4-1.6:1.0: usb_probe_interface
<7>[ 11.864680] option 4-1.6:1.0: usb_probe_interface - got id
<6>[ 11.864693] option 4-1.6:1.0: GSM modem (1-port) converter detected
<6>[ 11.865307] usb 4-1.6: GSM modem (1-port) converter now attached to ttyUSB0
<7>[ 11.865405] usb 4-1.6: adding 4-1.6:1.1 (config #1, interface 1)
<7>[ 11.865588] GobiNet 4-1.6:1.1: usb_probe_interface
<7>[ 11.865598] GobiNet 4-1.6:1.1: usb_probe_interface - got id
<7>[ 11.865689] option 4-1.6:1.1: usb_probe_interface
<7>[ 11.865697] option 4-1.6:1.1: usb_probe_interface - got id
<6>[ 11.865709] option 4-1.6:1.1: GSM modem (1-port) converter detected
<6>[ 11.866864] usb 4-1.6: GSM modem (1-port) converter now attached to ttyUSB1
<7>[ 11.867000] usb 4-1.6: adding 4-1.6:1.2 (config #1, interface 2)
<7>[ 11.867184] GobiNet 4-1.6:1.2: usb_probe_interface
<7>[ 11.867195] GobiNet 4-1.6:1.2: usb_probe_interface - got id
<7>[ 11.867303] option 4-1.6:1.2: usb_probe_interface
<7>[ 11.867312] option 4-1.6:1.2: usb_probe_interface - got id
<6>[ 11.867324] option 4-1.6:1.2: GSM modem (1-port) converter detected
<6>[ 11.868545] usb 4-1.6: GSM modem (1-port) converter now attached to ttyUSB2
<7>[ 11.868706] usb 4-1.6: adding 4-1.6:1.3 (config #1, interface 3)
<7>[ 11.869145] GobiNet 4-1.6:1.3: usb_probe_interface
<7>[ 11.869158] GobiNet 4-1.6:1.3: usb_probe_interface - got id
<7>[ 11.869261] option 4-1.6:1.3: usb_probe_interface
<7>[ 11.869271] option 4-1.6:1.3: usb_probe_interface - got id
<6>[ 11.869282] option 4-1.6:1.3: GSM modem (1-port) converter detected
<6>[ 11.870029] usb 4-1.6: GSM modem (1-port) converter now attached to ttyUSB3
<7>[ 11.870185] usb 4-1.6: adding 4-1.6:1.4 (config #1, interface 4)
<7>[ 11.870655] GobiNet 4-1.6:1.4: usb_probe_interface
<7>[ 11.870668] GobiNet 4-1.6:1.4: usb_probe_interface - got id
<6>[ 11.872022] GobiNet 4-1.6:1.4 usb0: register ‘GobiNet’ at usb-ff540000.usb-1.6, GobiNet Ethernet Device, 8a:93:cc:13:f8:91
<6>[ 11.873889] creating qcqmi0
<7>[ 11.874287] hub 4-1:1.0: state 7 ports 7 chg 0000 evt 0040
<6>[ 12.206622] acc_open
<6>[ 12.206643] acc_release
<4>[ 12.349605] phy_power_on: enable = 1
<4>[ 12.389004] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 12.389038] eth0: device MAC address c2:b4:b2:75:68:c4
<6>[ 12.391323] libphy: stmmac: probed
<6>[ 12.391333] eth0: PHY ID 02430c54 at 1 IRQ 0 (stmmac-0:01) active
<4>[ 12.914699] Current WiFi chip is AP6212A.
<4>[ 12.914798] Current WiFi chip is AP6212A.
<4>[ 12.945261] Current WiFi chip is AP6212A.
<3>[ 13.104912] [mmc1] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 13.104924] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.105025] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.105036] mmcblk1: error -84 transferring data, sector 16480, nr 256, cmd response 0x900, card status 0xb00
<4>[ 13.105115] mmcblk1: retrying using single block read
<3>[ 13.147755] [mmc1] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 13.147766] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.147807] mmcblk1: error -110 sending status command, retrying
<3>[ 13.147826] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.147833] mmcblk1: error -84 transferring data, sector 16585, nr 151, cmd response 0x900, card status 0x0
<3>[ 13.147842] end_request: I/O error, dev mmcblk1, sector 16585
<3>[ 13.150319] Buffer I/O error on device mmcblk1p1, logical block 1049
<3>[ 13.153988] [mmc1] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 13.153997] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.154042] mmcblk1: error -110 sending status command, retrying
<3>[ 13.154064] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.154071] mmcblk1: error -84 transferring data, sector 16600, nr 136, cmd response 0x900, card status 0x0
<3>[ 13.154081] end_request: I/O error, dev mmcblk1, sector 16600
<3>[ 13.154875] [mmc1] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 13.154883] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.155133] mmcblk1: error -110 sending status command, retrying
<3>[ 13.155157] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.155164] mmcblk1: error -84 transferring data, sector 16602, nr 134, cmd response 0x900, card status 0x0
<3>[ 13.155176] end_request: I/O error, dev mmcblk1, sector 16602
<3>[ 13.157329] Buffer I/O error on device mmcblk1p1, logical block 1051
<3>[ 13.159846] [mmc1] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 13.159857] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.159909] mmcblk1: error -110 sending status command, retrying
<3>[ 13.159933] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.159940] mmcblk1: error -84 transferring data, sector 16611, nr 125, cmd response 0x900, card status 0x0
<3>[ 13.159950] end_request: I/O error, dev mmcblk1, sector 16611
<3>[ 13.161506] Buffer I/O error on device mmcblk1p1, logical block 1052
<3>[ 13.174372] [mmc1] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 13.174383] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.174639] mmcblk1: error -110 sending status command, retrying
<3>[ 13.174663] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.174671] mmcblk1: error -84 transferring data, sector 16644, nr 92, cmd response 0x900, card status 0x0
<3>[ 13.174681] end_request: I/O error, dev mmcblk1, sector 16644
<3>[ 13.175762] Buffer I/O error on device mmcblk1p1, logical block 1056
<3>[ 13.185906] [mmc1] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 13.185917] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.185979] mmcblk1: error -110 sending status command, retrying
<3>[ 13.186003] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.186012] mmcblk1: error -84 transferring data, sector 16675, nr 61, cmd response 0x900, card status 0x0
<3>[ 13.186023] end_request: I/O error, dev mmcblk1, sector 16675
<3>[ 13.188012] Buffer I/O error on device mmcblk1p1, logical block 1060
<3>[ 13.203803] [mmc1] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 13.203815] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.203867] mmcblk1: error -110 sending status command, retrying
<3>[ 13.203887] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.203894] mmcblk1: error -84 transferring data, sector 16720, nr 16, cmd response 0x900, card status 0x0
<3>[ 13.203904] end_request: I/O error, dev mmcblk1, sector 16720
<3>[ 13.204593] [mmc1] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 13.204602] [mmc1] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 13.204639] mmcblk1: error -110 sending status command, retrying
<3>[ 13.204659] need_retune:0,brq->retune_retry_done:0.
<3>[ 13.204666] mmcblk1: error -84 transferring data, sector 16722, nr 14, cmd response 0x900, card status 0x0
<3>[ 13.204674] end_request: I/O error, dev mmcblk1, sector 16722
<3>[ 13.206386] Buffer I/O error on device mmcblk1p1, logical block 1066
<4>[ 13.302588] dhd_open: Enter dd462000
<4>[ 13.302601]
<4>[ 13.302601] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 13.302601] Compiled in drivers/net/wireless/bcmdhd on Jan 11 2020 at 14:09:55
<4>[ 13.302611] wl_android_wifi_on in 1
<4>[ 13.302616] wl_android_wifi_on in 2: g_wifi_on=0
<4>[ 13.302621] wifi_platform_set_power = 1
<4>[ 13.302625] ======== PULL WL_REG_ON HIGH! ========
<6>[ 13.302630] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 13.302635] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 13.302639] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 13.407857] [WLAN_RFKILL]: wifi turn on power. 156
<6>[ 13.513899] pm policy 0 → 1
<4>[ 13.614494] sdio_reset_comm():
<6>[ 13.617488] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
<4>[ 13.617502] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
<4>[ 13.638437] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 13.641460] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 13.644498] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 13.650312] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<4>[ 13.657600] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
<6>[ 13.859835] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 13.859870] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 13.860224]
<4>[ 13.860224]
<4>[ 13.860224] dhd_bus_devreset: == WLAN ON ==
<4>[ 13.860354] F1 signature read @0x18000000=0x1541a9a6
<4>[ 13.862131] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
<4>[ 13.862672] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
<4>[ 13.862817] dhdsdio_probe_init: set use_rxchain 0 from config.txt
<4>[ 13.862986] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
<4>[ 13.862997] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm43438a1.bin
<4>[ 13.863002] Final fw_path=/system/etc/firmware/fw_bcm43438a1.bin
<4>[ 13.863007] Final nv_path=/system/etc/firmware/nvram_ap6212.txt
<4>[ 13.863011] Final conf_path=/system/etc/firmware/config.txt
<4>[ 14.026215] NVRAM version: AP6212_NVRAM_V1.0.1_20160606
<4>[ 14.026763] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
<4>[ 14.086882] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
<4>[ 14.086974] bcmsdh_oob_intr_register: Enter
<4>[ 14.086980] bcmsdh_oob_intr_register: HW_OOB enabled
<4>[ 14.086986] bcmsdh_oob_intr_register OOB irq=195 flags=4
<4>[ 14.087050] bcmsdh_oob_intr_register: enable_irq_wake
<4>[ 14.087858] dhd_conf_set_band: Set band 0
<4>[ 14.088046] dhd_preinit_ioctls: Set tcpack_sup_mode 0
<4>[ 14.088062] wifi_platform_get_mac_addr
<4>[ 14.088067] ======== bcm_wlan_get_mac_address ========
<6>[ 14.088072] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 14.088079] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 14.088083] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 14.090949] Firmware up: op_mode=0x0005, MAC=8c:f7:10:38:55:36
<4>[ 14.090961] dhd_conf_set_country: Set country CN, revision 0
<4>[ 14.119121] Country code: CN (CN/0)
<4>[ 14.119644] dhd_conf_set_roam: Set roam_off 1
<4>[ 14.130701] Firmware version = wl0: Nov 25 2016 15:06:56 version 7.46.57.5.apsta.r4.o12 (Station/Softap) FWID 01-64fb9fe8 es6.c5.n4.a3
<4>[ 14.130714] Driver: 1.201.59.5 (r506368)
<4>[ 14.130714] Firmware: wl0: Nov 25 2016 15:06:56 version 7.46.57.5.apsta.r4.o12 (Station/Softap) FWID 01-64fb9fe8 es6.c5.n4.a3
<4>[ 14.130724] dhd_txglom_enable: enable 0
<4>[ 14.130754] dhd_conf_set_disable_proptx: set disable_proptx 0
<4>[ 14.132662] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
<4>[ 14.133301] wl_android_wifi_on: Success
<4>[ 14.171185] dhd_open: Exit ret=0
<4>[ 14.283770] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 14.283827] SELinux: initialized (dev mmcblk1p1, type vfat), uses genfs_contexts
<4>[ 14.288503] WLC_E_IF: NO_IF set, event Ignored
<4>[ 14.336822] Current WiFi chip is AP6212A.
<4>[ 14.342082] dhd_pktfilter_offload_set: failed to add pktfilter 102 0 0 0 0xFFFFFF 0x01005E, retcode = -2
<4>[ 14.368845] dhd_set_suspend: Remove extra suspend setting
