AIO-3288C烧写buildroot固件提示Download Firmware Fail
[ 本帖最后由 xhzhou1234 于 2020-8-3 17:13 编辑 ]\n\n[ 本帖最后由 xhzhou1234 于 2020-8-3 17:06 编辑 ]\n\n[ 本帖最后由 xhzhou1234 于 2020-8-3 17:01 编辑 ]\n\nAIO-3288C原本烧写的是Android5.1,改烧buildroot。
1、根据http://wiki.t-firefly.com/zh_CN/AIO-3288C/upgrade_firmware-linux.html#的要求,先用v1.24先擦除然后用v1.34烧写,烧写步骤如下:
$ sudo upgrade_tool_v124 ef rockdev/pack/AIO-3288C-BUILDROOT-GPT-20200803-1521.img[sudo] xh 的密码:Loading loader…Erase flash ok.xh@xh-dell:~/wisdtour/aio-firefly-sdk$ sudo upgrade_tool_v134 uf rockdev/pack/AIO-3288C-BUILDROOT-GPT-20200803-1521.imgLoading firmware…Support Type:RK320A FW Ver:8.1.276 FW Time:2020-08-03 15:22:11Loader ver:2.58 Loader Time:2020-08-03 11:56:09Download Firmware Fail
2、upgrade_tool log如下:
15:49:30 Upgrade Tool v1.34 2 3 15:49:30 Download Boot Start 4 15:49:31 Download Boot Success 5 15:49:31 Wait For Maskrom Start 6 15:49:32 Wait For Maskrom Success 7 15:49:32 Test Device Start 8 15:49:32 Test Device Success 9 15:49:32 Check Chip Start 10 15:49:32 Check Chip Success 11 15:49:32 Get FlashInfo Start 12 15:49:32 <LAYER 1-2> INFO:FlashInfo: 0 0 E9 0 0 4 4 0 28 0 1 13 15:49:32 Get FlashInfo Success 14 15:49:32 Prepare IDB Start 15 15:49:32 <LAYER 1-2> INFO:CS(1) (7456MB) (SAMSUNG) 16 15:49:32 INFO:FindBackupSector3–>No Found 17 15:49:32 Prepare IDB Success 18 15:49:32 Download IDB Start 19 15:49:32 Download IDB Success 20 15:49:32 Download Firmware Start 21 15:49:32 <LAYER 1-2> INFO:FlashInfo: 0 0 E9 0 0 4 4 0 28 0 1 22 15:49:32 <LAYER 1-2> INFO:Start download image,total=535141888,band=64,DirectLBA=1,First4Access=1,Gpt=1 23 15:49:32 <LAYER 1-2> INFO:Start to download trust,offset=0x6000,size=4194304 24 15:49:32 <LAYER 1-2> INFO:Start to download uboot,offset=0x4000,size=4194304 25 15:49:32 <LAYER 1-2> INFO:Start to download misc,offset=0x8000,size=49152 26 15:49:32 <LAYER 1-2> INFO:Start to download boot,offset=0xa000,size=17588224 27 15:49:33 <LAYER 1-2> INFO:Start to download recovery,offset=0x1a000,size=15394816 28 15:49:34 <LAYER 1-2> INFO:Start to download rootfs,offset=0x5a000,size=477958144 29 15:49:57 <LAYER 1-2> INFO:Start to download oem,offset=0x3a000,size=10485760 30 15:49:57 <LAYER 1-2> INFO:Start to download userdata:grow,offset=0x157000,size=5242880 31 15:49:57 <LAYER 1-2> ERROR:RKA_Gpt_Download–>compare gpt backup failed 32 15:49:57 <LAYER 1-2> ERROR:DownloadImage–>RKA_Gpt_Check failed 33 15:49:57 Download Firmware Fail 34 15:51:08 Upgrade Tool v1.34
3、tools/linux/Linux_Pack_Firmware/rockdev/rk3288-package-file
1 # NAME Relative path 2 # 3 #HWDEF HWDEF 4 package-file package-file 5 bootloader Image/MiniLoaderAll.bin 6 parameter Image/parameter.txt 7 trust Image/trust.img 8 uboot Image/uboot.img 9 misc Image/misc.img 10 #resource Image/resource.img 11 #kernel Image/kernel.img 12 boot Image/boot.img 13 recovery Image/recovery.img 14 rootfs Image/rootfs.img 15 oem Image/oem.img 16 userdata:grow Image/userdata.img 17 # 要写入backup分区的文件就是自身(update.img) 18 # SELF 是关键字,表示升级文件(update.img)自身 19 # 在生成升级文件时,不加入SELF文件的内容,但在头部信息中有记录 20 # 在解包升级文件时,不解包SELF文件的内容。 21 backup RESERVED 22 #update-script update-script 23 #recover-script recover-script
4、device/rockchip/rk3288/parameter-buildroot.txt
1 FIRMWARE_VER: 8.1 2 MACHINE_MODEL:RK3288 3 MACHINE_ID:007 4 MANUFACTURER:RK3288 5 MAGIC: 0x5041524B 6 ATAG: 0x00200800 7 MACHINE: 3288 8 CHECK_MASK: 0x80 9 PWR_HLD: 0,0,A,0,1 10 TYPE: GPT 11 CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x0 0010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x00020000@0x0003a000(oem),0x00100000@0x0005a000(rootfs),-@0x0015a000(userdata:grow) 12 uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9
还尝试用1.34擦除再烧写,还是提示“Download Firmware Fail”请问如何解决?谢谢!
【注】编辑了好几次,一提交,换行符就没了,故此为方便查看,放到附件文件了,谢谢!
AIO-3288C-Download_Firmware_Fail.pdf (105 KB)
[ 本帖最后由 xhzhou1234 于 2020-8-3 19:50 编辑 ]\n\n你好!
我继续研究了一下这个问题。烧写到板子的分区表中rootfs的大小是0x0005a000:$ sudo upgrade_tool_v134 plPartition Info(gpt):NO LBA Size Name01 0x00004000 0x00002000 uboot02 0x00006000 0x00002000 trust03 0x00008000 0x00002000 misc04 0x0000a000 0x00010000 boot05 0x0001a000 0x00010000 recovery06 0x0002a000 0x00010000 backup07 0x0003a000 0x00020000 oem08 0x0005a000 0x000fd000 rootfs09 0x00157000 0x00d38fdf userdata
分区表中是0x00100000:$ cat rockdev/parameter.txtFIRMWARE_VER: 8.1MACHINE_MODEL:RK3288MACHINE_ID:007MANUFACTURER:RK3288MAGIC: 0x5041524BATAG: 0x00200800MACHINE: 3288CHECK_MASK: 0x80PWR_HLD: 0,0,A,0,1TYPE: GPTCMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0rust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000(recovery),0x00010000@0x0002a000(backup),0x00020000@0x0003a000(oem),0x0005a000(rootfs),-@0x0015a000(userdata:grow)uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9xh@xh-dell:~/wisdtour/aio-firefly-sdk$xh@xh-dell:~/wisdtour/aio-firefly-sdk$ cat rockdev/parameter.txtFIRMWARE_VER: 8.1MACHINE_MODEL:RK3288MACHINE_ID:007MANUFACTURER:RK3288MAGIC: 0x5041524BATAG: 0x00200800MACHINE: 3288CHECK_MASK: 0x80PWR_HLD: 0,0,A,0,1TYPE: GPTCMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x00020000@0x0003a000(oem),0x00100000@0x0005a000(rootfs),-@0x0015a000(userdata:grow)uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9
板子上的烧写程序检查出了这个差异,所以报错。若这是直接问题点,如何解决?顺便说一下,我猜贵公司网站对用户提交的表单的处理出了问题,换行符全被忽略。
  • 这里其实是校验错误,固件已经正常烧写,可以忽略。
  • 可以按照如下配置,略过校验:在家目录添加配置文件, ~/.config/upgrade_tool/config.ini ,添加一行 rb_check_off=true
  • 分区大小在打包固件时,会根据 rootfs 大小调整 roofs 分区,所以会和配置文件不一致。
[ 本帖最后由 xhzhou1234 于 2020-8-6 16:45 编辑 ]\n\n1、取消校验这个配置我在使用文档里看到了,这个不是大问题。
2、关键是要保证使用upgrade_tool从下面读上来的信息与源代码目录树下paramter.txt中两个信息不一致,对程序的运行是否有影响?
3、按理,从打包脚本看,update.img中的分区信息就是从paramter.txt来的,结果两者不一致,这总是个问题吧!
- 分区大小在打包固件时,会根据 rootfs 大小调整 roofs 分区,所以会和配置文件不一致。
这里是打包了 修改后 的 paramter.txt 的文件,嗯~,确实不一致。{:4_213:}
具体你可以看下打包脚本 tools/linux/Linux_Pack_Firmware/rockdev/rk3288-mkupdate.sh
