ROC-RK3399-PC-PLUS / Station P1牛轧糖定制固件
Station P1 / ROC-RK3399-PC-PLUS-自定义Android牛轧糖固件v1.0
使用Google Gapps构建
Google GMS认证-无需手动注册GSF ID
默认情况下启用Wifi
预安装一些应用程序,例如Nova,Kodi,MiXplorer
在白名单中添加分数频率(23.976,29.97,59.94hz)
使用VP9编解码器修复Youtube(SmartYoutubeTV)冻结问题
启用墙纸服务
修复Amazon Prime Video无法正常工作
提高速度以更好地滚动和回复
修复主页按钮不适用于滑鼠
添加外部存储的写入模式
减少动画
修复10位h264视频播放
添加了Kodi帧速率切换(视频播放后仍然存在一些缩放错误,如果暂时不需要,请保持禁用状态)
强制某些应用需要横向定位
添加阻止(超过140000个站点添加了阻止)
删除根并添加Magisk根
添加Flac音频192000hz播放支持
最新应用程序的网格布局
-长按红外遥控器上的确定按钮以关闭当前窗口应用
-长按返回以关闭所有应用
音量步进增加到20,以实现更好的音频音量管理
将Busybox更新到最新版本
引导动画替换为库存工作站P1
设置-2个可用的应用程序+ Firefly设置
将RKTvLauncher设置为默认启动器,并将Lawnchair添加为辅助启动器
添加MediaCenter v3.5.4应用
添加了几种游戏手柄键盘布局
添加Widevine DRM L3支持
https://mega.nz/file/FigGHIYB#7AKsl58SRsSmJDBdNu_5b4B5t4m7kmxjIycIhNOSRKg
Station P1/ ROC-RK3399-PC-PLUS - Custom Android Nougat Firmware v1.0
Build with Google Gapps
Google GMS Certified - no need to manually register GSF ID
Wifi on by default
Preinstalles some apps like Nova, Kodi, MiXplorer
Add fractional frequencies in whitelist(23.976,29.97, 59.94hz)
Fix Youtube(SmartYoutubeTV) freezing problem with VP9 codec
Enable Wallpaperservice
Fix Amazon Prime Video not working
Improve velocity for better scrolling and repsonse
Fix home button not working on airmouses
Add write mode for external storage
Reduce animations
Fix 10-bit h264 video playback
Kodi frame-rate switching added(still has some zoom bug after video played, keep disabled if not needed for now)
Force landscape orientation needed for some apps
Add-block(140000+ sites adds blocked)
Remove root and added Magisk Root
Add Flac audio 192000hz playback support
Grid layout for recent apps
  • Long press OK button on ir remote to close current window app
  • Long press back to close all apps
    Volume steps increased to 20 for better audio volume management
    Update Busybox to latest version
    Bootanimation replaced with stock Station P1
    Settings - 2 apps available + Firefly Settings
    Set RKTvLauncher as default launcher and added Lawnchair as secondary launcher
    Add MediaCenter v3.5.4 app
    Added several gamepad keyboard layouts
    Add Widevine DRM L3 support
Download link:
Flash with AndroidTool v2.71 or higher(EraseFlash, Upgrade)
这个固件下载链接失败了,能不能再分享一下,另外有没有安卓10带谷歌框架的固件,也分享一下,感激不尽!
