ROC-RK3399-PC-PLUS烧录固件无法进入系统
卡在kernel:log如下
[ 1.393542] It doesn’t contain Rogue gpu
[ 1.394256] rockchip_headset rk-headset: Can not read property hook_gpio
[ 1.394314] rockchip_headset rk-headset: headset have hook adc mode
[ 1.394644] input: rk-headset as /devices/platform/rk-headset/input/input2
[ 1.395705] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.399934] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.400279] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.400327] cfg80211: failed to load regulatory.db
[ 1.401479] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘09:15:36’, on ‘Aug 11 2020’.
[ 1.402391] Mali:
[ 1.402396] Mali device driver loaded
[ 1.403149] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[ 1.403878] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 1.404557] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.404605] rkisp1: update sensor failed
[ 1.404644] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 1.405279] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.405324] rkisp1: update sensor failed
[ 1.405871] (NULL device *): spi_new_device() returned NULL
u▒ 1.407353]
固件是Android10.0,在官方下载的,使用emmc
我也是这个问题,请问你解决啦吗?
