立即输出模式如何使用?
在rk3328的control设置立即输出模式MPP_DEC_SET_IMMEDIATE_OUT时失败。
mpp[829]: mpi_dec_test: mpi_dec_test start
mpp[829]: mpi_dec_test: mpi_dec_test decoder test start w 1920 h 1080 type 7
mpp[829]: mpp_info: mpp version: unknown mpp version for missing VCS info
mpp[829]: mpp_dec: mpp_dec_control found NULL input dec (nil)
mpp[829]: mpp: command 31000c param 0x7fc08c7c9c ret -3
mpp[829]: mpi_dec_test: mpi->control failed
mpp[829]: mpp_packet: check_is_mpp_packet pointer (nil) failed on check
mpp[829]: mpp_packet: mpp_packet_deinit found NULL input
mpp[829]: mpp_frame: check_is_mpp_frame pointer (nil) failed on check
mpp[829]: mpp_frame: mpp_frame_deinit invalid NULL pointer input
mpp[829]: mpi: mpi_control found invalid context 0x24778260
mpp[829]: mpi: mpp_destroy found invalid context 0x24778260
mpp[829]: mpi: mpp_init found invalid context 0x24778260
mpp[829]: mpi_dec_test: mpp_init failed
已经解决了 初始化要MPP_DEC_SET_IMMEDIATE_OUT前面
