开发版:ROC-RK3328-CC
默认的串口波特率是1500000,换了几个工具都看不到打印,所以就该了下内核中波特率地方,修改的地方如下:
— a/arch/arm64/boot/dts/rockchip/rk3328-firefly-core.dtsi
+++ b/arch/arm64/boot/dts/rockchip/rk3328-firefly-core.dtsi
@@ -61,7 +61,7 @@
rockchip,wake-irq = <0>;
/* If enable uart uses irq instead of fiq */
rockchip,irq-mode-enable = <0>;
rockchip,baudrate = <1500000>; /* Only 115200 and 1500000 */
rockchip,baudrate = <115200>; /* Only 115200 and 1500000 */ interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_LOW>; status = "okay"; };
进不了命令行,桌面不显示时,串口最后的打印如下:
[ 9.072606] sdio: host isn’t initialization successfully.
[ 9.078097] failed to power up DHD generic adapter, max retry reached**
[ 9.084781] unregister wifi platform drivers
[ 9.089075] wifi_platform_bus_enumerate device present 0
[ 9.094389] ======== Card detection to remove SDIO card! ========
[ 9.100486] sdio: host isn’t initialization successfully.
[ 9.105978] ======== dhd_wlan_deinit_plat_data ========
[ 9.111213] dhd_module_init: Failed to load the driver, try cnt 0
[ 9.117341] dhd_module_init: Failed to load driver max retry reached**
[ 9.123870] dhd_module_init: Exit err=-19
麻烦了解的大神帮忙分析一下,谢谢
