首先贴出启动信息:
WARDDR Version V1.29 20190730
REG2C: 0x00000033, 0x00000033
451MHz
DDR2
Col=10 Bank=2 Row=13 Size=64MB
msch:0
Boot1 Release Time: Oct 28 2019 20:02:13, version: 1.19
chip_id:330800,0
ChipType = 0x13, 35790965
DPLL = 1300 MHz
sfc nor id: ff c2 12
DPLL = 1300 MHz
sfc_nand id: c2 12 c2
SFTL version: 5.0.50 20190215
SdmmcInit=0 NOT PRESENT
StorageInit ok = 35617883
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x104
Secure read PBA: 0x204
Secure read PBA: 0x304
Secure read PBA: 0x404
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x1000
GPT part: 1, name: trust, start:0x3000, size:0x1000
GPT part: 2, name: misc, start:0x4000, size:0x800
GPT part: 3, name: recovery, start:0x4800, size:0x6000
GPT part: 4, name: boot, start:0xa800, size:0x4800
GPT part: 5, name: rootfs, start:0xf000, size:0x16000
GPT part: 6, name: oem, start:0x25000, size:0xc000
GPT part: 7, name: userdata, start:0x31000, size:0x4ddf
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x3000.
LoadTrust Addr:0x3000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x600000, size=0xa63a0
RunBL31 0x40000 @ 35463163 us
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(release):30f1405
NOTICE: BL31: Built : 17:08:28, Sep 23 2019
INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe b
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: Entry point address = 0x600000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Sep 02 2020 - 11:47:23 +0800)
Model: Rockchip RK3308 EVB
PreSerial: 2
DRAM: 62 MiB
Sysmem: init
Relocation Offset is: 0390c000
ret -1
SFTL version: 5.0.51 20191028
Bootdev(atags): spinand 0
PartType: EFI
boot mode: recovery (misc)
init_resource_list: failed to get resource part, ret=-1
Failed to get kernel dtb, ret=-19
request for gpio0_a4 failed:-2
apll 816000 KHz
dpll 1300000 KHz
vpll0 1177823 KHz
vpll1 901583 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98151 KHz
pclk_audio 98151 KHz
Net: No ethernet found.
** Invalid Android Image header **
Android image load failed
=Booting Rockchip format image=
Could not found misc partition
MMC Device 1 not found
no mmc device at slot 1
no mmc device at slot 0
Device 0:…nandc_flash_init enter…
unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
自研板用的是RK3308H,flash用的是MX35LF1GE4AB,在支持列表中……
烧录器前有擦除操作。
