RK3399的PCIE问题
自己做的RK3399的主板,接的PCIE网卡,型号是RTL8111E, pcie枚举失败,显示[ 1.232119] pci 0000:01:00.0: BAR 0: no space for [io size 0x0100];以下是打印信息
U-Boot 2017.09 (May 06 2020 - 11:24:58 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbdb000, fdt: 7bdcf140
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
rockchip_get_boot_mode: Could not found misc partition
boot mode: None
Found DTB in boot part
DTB: rk-kernel.dtb
HASH: OK(c)
Android header version 0
I2c0 speed: 400000Hz
rk8xx_read: read reg 0x17 failed, ret=-121
Model: Rockchip RK3399 Excavator Board (Linux Opensource)
Using display timing dts
Detailed mode clock 200000 kHz, flags[a]
H: 1536 1548 1564 1612
V: 2048 2056 2060 2068
bus_format: 100e
AUX CH command reply failed!
failed to get Rx Max Link Rate
failed to init training
unable to do link train
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 200000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Could not find misc partition
Not AVB images, AVB skip
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000…
Sysmem Warn: kernel ‘reserved-memory’ “region@110000”(0x00110000 - 0x00200000) is overlap with [invisible] “SHM” (0x00100000 - 0x00200000)
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 17613 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c129
Total: 875.842 ms
[ 0.000000] Linux version 4.4.194 (root@localhost.localdomain) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #12 SMP Mon Aug 17 09:28:03 CST 2020
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee1000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=33c2200817418678 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory
[ 0.000000] software IO TLB: mapped [mem 0x7fe99000-0x7fed9000] (0MB)
[ 0.000000] Memory: 2006712K/2064384K available (10622K kernel code, 1676K rwdata, 4168K rodata, 1088K init, 1876K bss, 57672K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008f00000 - 0xffffff8009010000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ae0000 ( 10624 KB)
[ 0.000000] .rodata : 0xffffff8008ae0000 - 0xffffff8008f00000 ( 4224 KB)
[ 0.000000] .data : 0xffffff8009010000 - 0xffffff80091b3008 ( 1677 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
[ 0.010298] Console: colour dummy device 80x25
[ 0.015196] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.026476] pid_max: default: 32768 minimum: 301
[ 0.031685] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.039049] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.047586] Initializing cgroup subsys io
[ 0.052006] Initializing cgroup subsys memory
[ 0.056814] Initializing cgroup subsys devices
[ 0.061701] Initializing cgroup subsys freezer
[ 0.066585] Initializing cgroup subsys pids
[ 0.071197] ftrace: allocating 40484 entries in 159 pages
[ 0.181417] sched-energy: Sched-energy-costs installed from DT
[ 0.187839] CPU0: update cpu_capacity 401
[ 0.192303] ASID allocator initialised with 32768 entries
[ 0.201427] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.211616] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.223136] Detected VIPT I-cache on CPU1
[ 0.223169] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.223199] CPU1: using LPI pending table @0x000000007d090000
[ 0.223242] CPU1: update cpu_capacity 401
[ 0.223246] CPU1: Booted secondary processor [410fd034]
[ 0.223803] Detected VIPT I-cache on CPU2
[ 0.223824] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.223852] CPU2: using LPI pending table @0x000000007d0c0000
[ 0.223878] CPU2: update cpu_capacity 401
[ 0.223882] CPU2: Booted secondary processor [410fd034]
[ 0.224421] Detected VIPT I-cache on CPU3
[ 0.224441] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.224468] CPU3: using LPI pending table @0x000000007d120000
[ 0.224494] CPU3: update cpu_capacity 401
[ 0.224497] CPU3: Booted secondary processor [410fd034]
[ 0.225063] Detected PIPT I-cache on CPU4
[ 0.225090] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.225128] CPU4: using LPI pending table @0x000000007d150000
[ 0.225166] CPU4: update cpu_capacity 1024
[ 0.225169] CPU4: Booted secondary processor [410fd082]
[ 0.225729] Detected PIPT I-cache on CPU5
[ 0.225748] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.225785] CPU5: using LPI pending table @0x000000007d180000
[ 0.225812] CPU5: update cpu_capacity 1024
[ 0.225815] CPU5: Booted secondary processor [410fd082]
[ 0.225902] Brought up 6 CPUs
[ 0.368292] SMP: Total of 6 processors activated.
[ 0.373459] CPU features: detected feature: GIC system register CPU interface
[ 0.381296] CPU features: detected feature: 32-bit EL0 Support
[ 0.387707] CPU: All CPU(s) started at EL2
[ 0.392244] alternatives: patching kernel code
[ 0.398494] devtmpfs: initialized
[ 0.420103] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.430827] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.438164] pinctrl core: initialized pinctrl subsystem
[ 0.445656] Failed to find legacy iommu devices
[ 0.451017] NET: Registered protocol family 16
[ 0.462015] cpuidle: using governor ladder
[ 0.471548] cpuidle: using governor menu
[ 0.475888] Registered FIQ tty driver
[ 0.480283] vdso: 2 pages (1 code @ ffffff8008ae6000, 1 data @ ffffff8009014000)
[ 0.488425] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.496399] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.528138] console [pstore-1] enabled
[ 0.532260] pstore: Registered ramoops as persistent store backend
[ 0.539045] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.546213] console [ttyFIQ0] enabled
[ 0.553895] bootconsole [uart0] disabled
[ 0.562310] Registered fiq debugger ttyFIQ0
[ 0.595413] vcc_lcd: supplied by vcc5v0_sys
[ 0.621730] iommu: Adding device ff650000.vpu_service to group 0
[ 0.627819] iommu: Adding device ff660000.rkvdec to group 1
[ 0.633473] iommu: Adding device ff670000.iep to group 2
[ 0.638897] iommu: Adding device ff8f0000.vop to group 3
[ 0.644304] iommu: Adding device ff900000.vop to group 4
[ 0.649709] iommu: Adding device ff910000.rkisp1 to group 5
[ 0.655383] iommu: Adding device ff920000.rkisp1 to group 6
[ 0.661453] rk_iommu ff650800.iommu: can’t get sclk
[ 0.666588] rk_iommu ff660480.iommu: can’t get sclk
[ 0.671569] rk_iommu ff670800.iommu: can’t get aclk
[ 0.676460] rk_iommu ff670800.iommu: can’t get hclk
[ 0.681346] rk_iommu ff670800.iommu: can’t get sclk
[ 0.686404] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.691456] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.696513] rk_iommu ff914000.iommu: can’t get sclk
[ 0.701573] rk_iommu ff924000.iommu: can’t get sclk
[ 0.706833] SCSI subsystem initialized
[ 0.710767] usbcore: registered new interface driver usbfs
[ 0.716299] usbcore: registered new interface driver hub
[ 0.721708] usbcore: registered new device driver usb
[ 0.727043] media: Linux media interface: v0.10
[ 0.731610] Linux video capture interface: v2.00
[ 0.736324] pps_core: LinuxPPS API ver. 1 registered
[ 0.741295] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.750451] PTP clock support registered
[ 0.755528] Advanced Linux Sound Architecture Driver Initialized.
[ 0.762124] Bluetooth: Core ver 2.21
[ 0.765731] NET: Registered protocol family 31
[ 0.770182] Bluetooth: HCI device and connection manager initialized
[ 0.776543] Bluetooth: HCI socket layer initialized
[ 0.781430] Bluetooth: L2CAP socket layer initialized
[ 0.786504] Bluetooth: SCO socket layer initialized
[ 0.792020] rockchip-cpuinfo cpuinfo: Serial : 33c2200817418678
[ 0.798712] clocksource: Switched to clocksource arch_sys_counter
[ 0.854091] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.862322] NET: Registered protocol family 2
[ 0.867126] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.874492] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.881558] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.888171] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.894259] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.900957] NET: Registered protocol family 1
[ 0.905627] RPC: Registered named UNIX socket transport module.
[ 0.911569] RPC: Registered udp transport module.
[ 0.916292] RPC: Registered tcp transport module.
[ 0.921010] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.928912] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.937203] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.948557] Initialise system trusted keyring
[ 0.960935] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.967561] NFS: Registering the id_resolver key type
[ 0.972641] Key type id_resolver registered
[ 0.976830] Key type id_legacy registered
[ 0.980926] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.985520] fuse init (API version 7.23)
[ 0.989842] SGI XFS with security attributes, no debug enabled
[ 1.001332] NET: Registered protocol family 38
[ 1.005807] Key type asymmetric registered
[ 1.009915] Asymmetric key parser ‘x509’ registered
[ 1.014954] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.022358] io scheduler noop registered
[ 1.026296] io scheduler deadline registered
[ 1.030712] io scheduler cfq registered (default)
[ 1.037015] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 1.047342] rockchip-mipi-dphy-rx ff968000.mipi-dphy-tx1rx1: bad remote port parent
[ 1.055069] rockchip-mipi-dphy-rx: probe of ff968000.mipi-dphy-tx1rx1 failed with error -22
[ 1.067598] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.073990] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.080375] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.086734] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.093534] PCI host bridge /pcie@f8000000 ranges:
[ 1.098348] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.103501] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.163115] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 1.169751] pci_bus 0000:00: root bus resource [bus 00-1f]
[ 1.175244] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[ 1.182126] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[ 1.192087] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.200306] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 1.209782] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff]
[ 1.216592] pci 0000:01:00.0: BAR 4: assigned [mem 0xfa000000-0xfa003fff 64bit pref]
[ 1.224358] pci 0000:01:00.0: BAR 2: assigned [mem 0xfa004000-0xfa004fff 64bit pref]
[ 1.238394] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0100]
[ 1.245020] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.249995] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff]
[ 1.256838] pcieport 0000:00:00.0: enabling device (0000 → 0002)
[ 1.263171] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.270138] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.277492] backlight supply power not found, using dummy regulator
[ 1.284191] iep: failed to find iep power down clock source.
[ 1.290251] IEP Power ON
[ 1.292973] IEP Power OFF
[ 1.295629] IEP Driver loaded succesfully
[ 1.299882] Module initialized.
[ 1.303336] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.309852] rk-vcodec ff650000.vpu_service: probe device
[ 1.315377] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.322808] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.329780] rk-vcodec ff650000.vpu_service: init success
[ 1.335335] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.341581] rk-vcodec ff660000.rkvdec: probe device
[ 1.346671] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.353506] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.360045] rk-vcodec ff660000.rkvdec: init success
[ 1.366464] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.374049] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.384751] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.392334] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.402687] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.411375] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.418351] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.428408] [drm] Initialized drm 1.1.0 20060810
[ 1.437292] [drm] Rockchip DRM driver version: v1.0.1
[ 1.444956] mali ff9a0000.gpu: Failed to get regulator
[ 1.450111] mali ff9a0000.gpu: Power control initialization failed
[ 1.456672] Unable to detect cache hierarchy for CPU 0
[ 1.462636] brd: module loaded
[ 1.471060] loop: module loaded
[ 1.474805] zram: Added device: zram0
[ 1.478829] lkdtm: No crash points registered, enable through debugfs
[ 1.487203] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.494276] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.499948] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 1.505634] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.511980] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.518952] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.530061] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.535766] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.540821] Ring mode enabled
[ 1.543884] DMA HW capability register supported
[ 1.548417] Normal descriptors
[ 1.551758] RX Checksum Offload Engine supported (type 2)
[ 1.557244] TX Checksum insertion supported
[ 1.561524] Wake-Up On Lan supported
[ 1.565231] Enable RX Mitigation via HW Watchdog Timer
[ 1.635175] libphy: stmmac: probed
[ 1.638611] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.645067] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.653013] usbcore: registered new interface driver rtl8150
[ 1.658743] usbcore: registered new interface driver r8152
[ 1.664287] usbcore: registered new interface driver asix
[ 1.669737] usbcore: registered new interface driver ax88179_178a
[ 1.675876] usbcore: registered new interface driver cdc_ether
[ 1.681752] usbcore: registered new interface driver rndis_host
[ 1.687747] usbcore: registered new interface driver cdc_ncm
[ 1.693457] usbcore: registered new interface driver cdc_mbim
[ 1.700565] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.710346] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.716881] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.723453] ehci-pci: EHCI PCI platform driver
[ 1.727974] ehci-platform: EHCI generic platform driver
[ 1.737055] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.742902] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.750841] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.762732] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.769078] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.775879] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.783109] usb usb1: Product: EHCI Host Controller
[ 1.787996] usb usb1: Manufacturer: Linux 4.4.194 ehci_hcd
[ 1.793484] usb usb1: SerialNumber: fe3c0000.usb
[ 1.798565] hub 1-0:1.0: USB hub found
[ 1.802375] hub 1-0:1.0: 1 port detected
[ 1.806903] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.813110] ohci-platform: OHCI generic platform driver
[ 1.818841] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.825728] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.833646] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.894876] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.901674] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.908913] usb usb2: Product: Generic Platform OHCI controller
[ 1.914839] usb usb2: Manufacturer: Linux 4.4.194 ohci_hcd
[ 1.920328] usb usb2: SerialNumber: fe3e0000.usb
[ 1.925420] hub 2-0:1.0: USB hub found
[ 1.929214] hub 2-0:1.0: 1 port detected
[ 1.934156] usbcore: registered new interface driver cdc_acm
[ 1.939829] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.947880] usbcore: registered new interface driver cdc_wdm
[ 1.953585] usbcore: registered new interface driver uas
[ 1.958994] usbcore: registered new interface driver usb-storage
[ 1.965083] usbcore: registered new interface driver usbserial
[ 1.970956] usbcore: registered new interface driver usbserial_generic
[ 1.977519] usbserial: USB Serial support registered for generic
[ 1.983567] usbcore: registered new interface driver cp210x
[ 1.989181] usbserial: USB Serial support registered for cp210x
[ 1.995165] usbcore: registered new interface driver ftdi_sio
[ 2.000942] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.008400] usbcore: registered new interface driver keyspan
[ 2.014098] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.021957] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.029291] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.036636] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.043996] usbcore: registered new interface driver option
[ 2.049604] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.056678] usbcore: registered new interface driver oti6858
[ 2.062370] usbserial: USB Serial support registered for oti6858
[ 2.068418] usbcore: registered new interface driver pl2303
[ 2.074025] usbserial: USB Serial support registered for pl2303
[ 2.079991] usbcore: registered new interface driver qcserial
[ 2.085771] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.092783] usbcore: registered new interface driver sierra
[ 2.098390] usbserial: USB Serial support registered for Sierra USB modem
[ 2.105197] usb20_otg: version 3.10a 21-DEC-2012
[ 2.110055] usb20_host: version 3.10a 21-DEC-2012
[ 2.116037] usbcore: registered new interface driver usbtouchscreen
[ 2.123049] i2c /dev entries driver
[ 2.156950] fan53555-regulator 0-0040: Failed to get chip ID!
[ 2.192421] fan53555-regulator 0-0041: Failed to get chip ID!
[ 2.227842] rk808 0-001b: failed to read the chip id at 0x17
[ 2.233585] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095ca000
[ 2.242193] input: gsl3673 as /devices/platform/ff110000.i2c/i2c-1/1-0040/input/input0
[ 3.291739] rk3x-i2c ff110000.i2c: timeout, ipd: 0x00, state: 1
[ 4.299759] rk3x-i2c ff110000.i2c: timeout, ipd: 0x00, state: 1
[ 5.308770] rk3x-i2c ff110000.i2c: timeout, ipd: 0x00, state: 1
[ 5.314728] gsl3673 1-0040: GSL3673 test_i2c error!
[ 5.319624] gsl3673 1-0040: gsl_probe: init_chip failed
[ 5.329913] gsl3673: probe of 1-0040 failed with error -1
[ 5.335745] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80095cc000
[ 5.345169] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 5.356221] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 5.365332] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input1
[ 5.374401] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80095ce000
[ 5.383154] vm149c 1-000c: probing…
[ 5.386840] vm149c 1-000c: driver version: 00.01.00
[ 5.391739] vm149c 1-000c: could not get module rockchip,vcm-start-current from dts!
[ 5.399496] vm149c 1-000c: could not get module rockchip,vcm-rated-current from dts!
[ 5.407268] vm149c 1-000c: could not get module rockchip,vcm-step-mode from dts!
[ 5.414740] vm149c 1-000c: probing successful
[ 5.419658] IR NEC protocol handler initialized
[ 5.425078] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 5.431460] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 5.439230] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 5.445612] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 5.453265] usbcore: registered new interface driver npu_acm
[ 5.459015] usbcore: registered new interface driver uvcvideo
[ 5.464770] USB Video Class driver (1.1.1)
[ 5.470493] Boot mode: coldboot
[ 5.474681] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 5.483641] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 5.491137] dw_wdt ff848000.watchdog: Should better to setup a ‘resets’ property in dt, that must been named with reset
[ 5.502160] Bluetooth: Virtual HCI driver ver 1.5
[ 5.506996] Bluetooth: HCI UART driver ver 2.3
[ 5.511454] Bluetooth: HCI UART protocol H4 registered
[ 5.516604] Bluetooth: HCI UART protocol LL registered
[ 5.521752] Bluetooth: HCI UART protocol ATH3K registered
[ 5.527216] usbcore: registered new interface driver bfusb
[ 5.532765] usbcore: registered new interface driver btusb
[ 5.538711] cpu cpu0: bin=1
[ 5.541565] cpu cpu0: leakage=20
[ 5.544849] cpu cpu0: Failed to get reg
[ 5.548715] cpu cpu0: bin-scale=34
[ 5.552350] cpu cpu4: bin=1
[ 5.555200] cpu cpu4: leakage=36
[ 5.558472] cpu cpu4: Failed to get reg
[ 5.562328] cpu cpu4: bin-scale=17
[ 5.566680] sdhci: Secure Digital Host Controller Interface driver
[ 5.572873] sdhci: Copyright(c) Pierre Ossman
[ 5.577245] Synopsys Designware Multimedia Card Interface Driver
[ 5.584045] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.591304] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.598105] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.603895] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 5.613691] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.621851] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.628040] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.635180] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.642433] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 5.649234] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 5.655020] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 5.664771] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.673408] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.680771] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 5.686781] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 5.723121] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 5.731423] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.737332] usbcore: registered new interface driver usbhid
[ 5.742939] usbhid: USB HID core driver
[ 5.747526] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 5.756824] usbcore: registered new interface driver snd-usb-audio
[ 5.809025] mmc0: new HS400 MMC card at address 0001
[ 5.814628] mmcblk0: mmc0:0001 M8G1GC 7.28 GiB
[ 5.819625] mmcblk0boot0: mmc0:0001 M8G1GC partition 1 4.00 MiB
[ 5.826227] mmcblk0boot1: mmc0:0001 M8G1GC partition 2 4.00 MiB
[ 5.833238] mmcblk0rpmb: mmc0:0001 M8G1GC partition 3 512 KiB
[ 5.846569] mmcblk0: p1 p2 p3 p4 p5
[ 6.763950] rk3x-i2c ff110000.i2c: timeout, ipd: 0x00, state: 1
[ 6.769910] rt5651 1-001a: Device with ID register 0xffffffc0 is not rt5651
[ 6.781306] Netfilter messages via NETLINK v0.30.
[ 6.786076] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.792633] ctnetlink v0.93: registering with nfnetlink.
[ 6.798095] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 6.804665] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.org>
[ 6.812341] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.817847] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 6.824273] arp_tables: (C) 2002 David S. Miller
[ 6.828939] Initializing XFRM netlink socket
[ 6.833902] NET: Registered protocol family 10
[ 6.839631] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.845255] NET: Registered protocol family 17
[ 6.849733] NET: Registered protocol family 15
[ 6.854217] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 6.866842] Bridge firewalling registered
[ 6.870873] Ebtables v2.0 registered
[ 6.875196] Bluetooth: RFCOMM socket layer initialized
[ 6.880395] Bluetooth: RFCOMM ver 1.11
[ 6.884173] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.890103] Bluetooth: HIDP socket layer initialized
[ 6.895135] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 6.900171] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 6.905017] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 6.911894] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 6.919034] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 6.926506] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 6.935560] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 6.942870] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 6.948105] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 6.952882] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.957631] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 6.965769] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 6.973718] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 6.981658] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 6.989848] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 6.996610] [BT_RFKILL]: Request irq for bt wakeup host
[ 7.001939] [BT_RFKILL]: ** disable irq
[ 7.005926] [BT_RFKILL]: bt_default device registered.
[ 7.011149] Key type dns_resolver registered
[ 7.016405] ov13850 1-0010: driver version: 00.01.03
[ 7.021239] vendor storage:20190527 ret = 0
[ 7.025823] 1-0010 supply avdd not found, using dummy regulator
[ 7.031814] 1-0010 supply dovdd not found, using dummy regulator
[ 7.037877] 1-0010 supply dvdd not found, using dummy regulator
[ 7.043908] ov13850 1-0010: could not get sleep pinstate
[ 8.050933] rk3x-i2c ff110000.i2c: timeout, ipd: 0x00, state: 1
[ 8.056891] ov13850 1-0010: Unexpected sensor id(000000), ret(-5)
[ 8.063985] Registered cp15_barrier emulation handler
[ 8.069207] Registered setend emulation handler
[ 8.074571] Loading compiled-in X.509 certificates
[ 8.079547] Bad mode in Error handler detected, code 0xbf000002 – SError
[ 8.086332] Internal error: Oops - bad mode: 0 [#1] SMP
[ 8.091557] Modules linked in:
[ 8.094643] CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.4.194 #12
[ 8.100736] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 8.108303] task: ffffffc00a378000 task.stack: ffffffc07d000000
[ 8.114221] PC is at rockchip_pcie_rd_conf+0x128/0x178
[ 8.119364] LR is at pci_bus_read_config_dword+0x6c/0xa4
[ 8.124675] pc : [] lr : [] pstate: 600000c5
[ 8.132060] sp : ffffffc07d003c30
[ 8.135379] x29: ffffffc07d003c30 x28: 0000000000000000
[ 8.140720] x27: ffffff8008fdd940 x26: ffffff8008f5cf88
[ 8.146069] x25: 0000000000000000 x24: 0000000000000000
[ 8.151418] x23: ffffffc07cfa6000 x22: 0000000000000000
[ 8.156767] x21: 0000000000000074 x20: ffffffc07d003cbc
[ 8.162116] x19: 0000000000000004 x18: 00000000ecc54dbf
[ 8.167465] x17: 0000000000000018 x16: 000000000000000e
[ 8.172813] x15: 0000000000000007 x14: 0ffffffffffffffe
[ 8.178162] x13: 0000000000000030 x12: 0000000000000000
[ 8.183511] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 8.188849] x9 : 66755e736e6e60ff x8 : 7f7f7fffffffffff
[ 8.194198] x7 : 636f75fefefefefe x6 : 8000000000000000
[ 8.199537] x5 : 0000000000100000 x4 : 0000000000000000
[ 8.204875] x3 : ffffffc07d32fa28 x2 : ffffff800c000000
[ 8.210223] x1 : 0000000000000000 x0 : 0000000000000000
[ 8.215573]
[ 8.215573] PC: 0xffffff8008438334:
[ 8.220534] 8334 b9400042 d5033d9f b9000282 52800000 17fffff5 71000a7f 54000081 79400042
[ 8.228869] 8354 12003c42 17fffff8 7100067f 54fffd81 39400042 12001c42 17fffff3 b9412c60
[ 8.237202] 8374 35fffe60 53111021 12002eb5 2a055025 53140ac1 2a150035 51000662 2a1500a1
[ 8.245535] 8394 6a01005f 54fffbc1 7100127f 540000e1 f9400062 8b010041 b9400021 d5033d9f
[ 8.253869] 83b4 b9000281 17ffffd8 71000a7f 540000c1 f9400062 8b010041 79400021 12003c21
[ 8.262201] 83d4 17fffff7 7100067f 54fff9a1 f9400062 8b010041 39400021 12001c21 17fffff0
[ 8.270535] 83f4 12800000 b9000280 528010c0 17ffffc6 a9be7bfd 910003fd a90153f3 aa0003f3
[ 8.278868] 8414 aa1e03e0 d503201f d5033e9f 52a00040 f9400661 b9000020 d5033e9f f9400660
[ 8.287203]
[ 8.287203] LR: 0xffffff800841aca0:
[ 8.292163] aca0 a94363f7 a8c57bfd d65f03c0 528010f4 17fffff9 a9bb7bfd 910003fd a90153f3
[ 8.300496] acc0 a9025bf5 a90363f7 2a0203f5 aa0003f4 2a0103f8 aa0303f7 aa1e03e0 d503201f
[ 8.308829] ace0 b9004fbf f24006bf 54000341 f0006413 9103c273 aa1303e0 941ad772 aa0003f6
[ 8.317162] ad00 f9405e80 2a1803e1 910133a4 52800083 2a1503e2 f9400405 aa1403e0 d63f00a0
[ 8.325494] ad20 2a0003f4 b9404fa0 aa1603e1 b90002e0 aa1303e0 941ad7b0 2a1403e0 a94153f3
[ 8.333827] ad40 a9425bf5 a94363f7 a8c57bfd d65f03c0 528010f4 17fffff9 a9bc7bfd 910003fd
[ 8.342149] ad60 a90153f3 a9025bf5 a90363f7 aa0003f4 12001c78 aa1e03e0 2a0103f6 2a0203f7
[ 8.350482] ad80 f0006413 d503201f 9103c273 aa1303e0 941ad74c aa0003f5 f9405e80 2a1803e4
[ 8.358816]
[ 8.358816] SP: 0xffffffc07d003bb0:
[ 8.363776] 3bb0 00000000 00000000 7cfa6000 ffffffc0 00000000 00000000 00000000 00000000
[ 8.372110] 3bd0 08f5cf88 ffffff80 08fdd940 ffffff80 00000000 00000000 7d003c30 ffffffc0
[ 8.380443] 3bf0 0841ad20 ffffff80 7d003c30 ffffffc0 084383b4 ffffff80 600000c5 00000000
[ 8.388776] 3c10 7c1e37f8 ffffffc0 09050000 ffffff80 ffffffff ffffffff 08ad0ae8 ffffff80
[ 8.397099] 3c30 7d003c70 ffffffc0 0841ad20 ffffff80 0909d0f0 ffffff80 7cfa6000 ffffffc0
[ 8.405432] 3c50 00000074 00000000 00000040 00000000 7d003d2c ffffffc0 7cfa6000 ffffffc0
[ 8.413765] 3c70 7d003cc0 ffffffc0 0841c07c ffffff80 00000004 00000000 7cfa6800 ffffffc0
[ 8.422098] 3c90 00000000 00000000 7d003d2c ffffffc0 0909d000 ffffff80 7cfa68a8 ffffffc0
[ 8.430423]
[ 8.430423] X2: 0xffffff800bffff80:
[ 8.435383] ff80 ******** ******** ******** ******** ******** ******** ******** ********
[ 8.443723] ffa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 8.452059] ffc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 8.460395] ffe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 8.468731] 0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.477066] 0020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.485401] 0040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.493736] 0060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.502073]
[ 8.502073] X3: 0xffffffc07d32f9a8:
[ 8.507032] f9a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.515365] f9c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.523687] f9e8 00000000 00000000 00000000 00000000 00000000 00000000 7d31e7c0 ffffffc0
[ 8.532020] fa08 7d31e3c0 ffffffc0 08584dec ffffff80 08de741e ffffff80 00000130 00000000
[ 8.540353] fa28 0c000000 ffffff80 0a000000 ffffff80 7d217c00 ffffffc0 7d31ea40 ffffffc0
[ 8.548686] fa48 7d31eac0 ffffffc0 7d31eb40 ffffffc0 7d31ebc0 ffffffc0 7d31ec40 ffffffc0
[ 8.557018] fa68 7d31ed40 ffffffc0 7d31ecc0 ffffffc0 7d31ee40 ffffffc0 7d31eec0 ffffffc0
[ 8.565351] fa88 7d31ef40 ffffffc0 7d31efc0 ffffffc0 ffffffed ffffffff ffffffed ffffffff
[ 8.573691]
[ 8.573691] X20: 0xffffffc07d003c3c:
[ 8.578735] 3c3c ffffff80 0909d0f0 ffffff80 7cfa6000 ffffffc0 00000074 00000000 00000040
[ 8.587068] 3c5c 00000000 7d003d2c ffffffc0 7cfa6000 ffffffc0 7d003cc0 ffffffc0 0841c07c
[ 8.595401] 3c7c ffffff80 00000004 00000000 7cfa6800 ffffffc0 00000000 00000000 7d003d2c
[ 8.603733] 3c9c ffffffc0 0909d000 ffffff80 7cfa68a8 ffffffc0 00000004 00000000 7cfa6800
[ 8.612066] 3cbc 00000000 7d003cf0 ffffffc0 08424b2c ffffff80 7cfa6800 ffffffc0 00000001
[ 8.620399] 3cdc 00000000 ffffffe7 00000000 00000000 00000000 7d003d30 ffffffc0 08425058
[ 8.628732] 3cfc ffffff80 7cfa6800 ffffffc0 00000000 00000000 7c1ea680 ffffffc0 00000000
[ 8.637064] 3d1c 00000000 7c1ea680 ffffffc0 00000000 00000000 7d003d50 ffffffc0 08428388
[ 8.645399]
[ 8.645399] X23: 0xffffffc07cfa5f80:
[ 8.650444] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.658777] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.667109] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.675442] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.683775] 6000 7cfa5018 ffffffc0 7cfa5018 ffffffc0 7cfa5000 ffffffc0 7cfa6018 ffffffc0
[ 8.692108] 6020 7cfa6018 ffffffc0 7cfa6800 ffffffc0 7cfa6800 ffffffc0 7cfa5800 ffffffc0
[ 8.700440] 6040 7cfa6040 ffffffc0 7cfa6040 ffffffc0 7cfa5d58 ffffffc0 7cfa5d90 ffffffc0
[ 8.708774] 6060 7cfa5dc8 ffffffc0 7cfa5e00 ffffffc0 7cfa6070 ffffffc0 7cfa6070 ffffffc0
[ 8.717108]
[ 8.717108] X26: 0xffffff8008f5cf08:
[ 8.722153] cf08 00030003 dead4ead ffffffff 00000000 ffffffff ffffffff 08f5cf20 ffffff80
[ 8.730486] cf28 08f5cf20 ffffff80 00000001 00000000 00000000 00000000 08fdc040 ffffff80
[ 8.738808] cf48 08fdc070 ffffff80 08fdc1a0 ffffff80 08fdc270 ffffff80 08fdc2c8 ffffff80
[ 8.747130] cf68 08fdc578 ffffff80 08fdc6f0 ffffff80 08fdd8b0 ffffff80 08fdd9f8 ffffff80
[ 8.755463] cf88 08de7c64 ffffff80 08d778f4 ffffff80 08d6d39f ffffff80 08e40ee5 ffffff80
[ 8.763795] cfa8 08d6d3a8 ffffff80 08d898c0 ffffff80 08df410b ffffff80 08de7cca ffffff80
[ 8.772128] cfc8 726f7473 6d656761 61696465 6d6d6500 6e610063 696f7264 6f6f6264 74732e74
[ 8.780461] cfe8 6761726f 64656d65 65006169 00636d6d 72646e61 6264696f 2e746f6f 65646f6d
[ 8.788795]
[ 8.788795] X27: 0xffffff8008fdd8c0:
[ 8.793839] d8c0 0809b7bc ffffff80 08f083dc ffffff80 08f0a340 ffffff80 08f0a408 ffffff80
[ 8.802172] d8e0 08f0a520 ffffff80 08f0a970 ffffff80 08f0c7e8 ffffff80 08f0e0bc ffffff80
[ 8.810505] d900 08f10c70 ffffff80 08f13fd0 ffffff80 08f152d8 ffffff80 08f16020 ffffff80
[ 8.818838] d920 08f257b8 ffffff80 08f2a08c ffffff80 08f2c2f4 ffffff80 08f2c664 ffffff80
[ 8.827171] d940 08f2cc7c ffffff80 08f2d6e4 ffffff80 08580e70 ffffff80 08f31704 ffffff80
[ 8.835504] d960 08f3183c ffffff80 08f317c8 ffffff80 08f36650 ffffff80 08f3683c ffffff80
[ 8.843837] d980 08f38acc ffffff80 08f3c584 ffffff80 08f3e394 ffffff80 08f3fb28 ffffff80
[ 8.852170] d9a0 08f412e8 ffffff80 08f4300c ffffff80 08f4581c ffffff80 08f2dcac ffffff80
[ 8.860494]
[ 8.860494] X29: 0xffffffc07d003bb0:
[ 8.865539] 3bb0 00000000 00000000 7cfa6000 ffffffc0 00000000 00000000 00000000 00000000
[ 8.873871] 3bd0 08f5cf88 ffffff80 08fdd940 ffffff80 00000000 00000000 7d003c30 ffffffc0
[ 8.882204] 3bf0 0841ad20 ffffff80 7d003c30 ffffffc0 084383b4 ffffff80 600000c5 00000000
[ 8.890537] 3c10 7c1e37f8 ffffffc0 09050000 ffffff80 ffffffff ffffffff 08ad0ae8 ffffff80
[ 8.898870] 3c30 7d003c70 ffffffc0 0841ad20 ffffff80 0909d0f0 ffffff80 7cfa6000 ffffffc0
[ 8.907202] 3c50 00000074 00000000 00000040 00000000 7d003d2c ffffffc0 7cfa6000 ffffffc0
[ 8.915535] 3c70 7d003cc0 ffffffc0 0841c07c ffffff80 00000004 00000000 7cfa6800 ffffffc0
[ 8.923868] 3c90 00000000 00000000 7d003d2c ffffffc0 0909d000 ffffff80 7cfa68a8 ffffffc0
[ 8.932201]
[ 8.933702] Process swapper/0 (pid: 1, stack limit = 0xffffffc07d000000)
[ 8.940400] Stack: (0xffffffc07d003c30 to 0xffffffc07d004000)
[ 8.946145] 3c20: ffffffc07d003c70 ffffff800841ad20
[ 8.953967] 3c40: ffffff800909d0f0 ffffffc07cfa6000 0000000000000074 0000000000000040
[ 8.961788] 3c60: ffffffc07d003d2c ffffffc07cfa6000 ffffffc07d003cc0 ffffff800841c07c
[ 8.969611] 3c80: 0000000000000004 ffffffc07cfa6800 0000000000000000 ffffffc07d003d2c
[ 8.977431] 3ca0: ffffff800909d000 ffffffc07cfa68a8 0000000000000004 000000007cfa6800
[ 8.985253] 3cc0: ffffffc07d003cf0 ffffff8008424b2c ffffffc07cfa6800 0000000000000001
[ 8.993074] 3ce0: 00000000ffffffe7 0000000000000000 ffffffc07d003d30 ffffff8008425058
[ 9.000895] 3d00: ffffffc07cfa6800 0000000000000000 ffffffc07c1ea680 0000000000000000
[ 9.008716] 3d20: ffffffc07c1ea680 0000000000000000 ffffffc07d003d50 ffffff8008428388
[ 9.016537] 3d40: ffffffc07cfa6800 0000000000000000 ffffffc07d003da0 ffffff8008f2c6a4
[ 9.024359] 3d60: ffffffc07cfa6800 0000000000000000 ffffffc07c1ea680 ffffff8009027460
[ 9.032181] 3d80: 0000000000000000 ffffff8008f0047c ffffff80091b7000 ffffff80080830a8
[ 9.040002] 3da0: ffffffc07d003dc0 ffffff80080830b8 ffffff8008f2c664 ffffff8009027460
[ 9.047823] 3dc0: ffffffc07d003e40 ffffff8008f00e04 000000000000017e 0000000000000007
[ 9.055644] 3de0: ffffff8008f5cf80 ffffff80091b7000 ffffff8008eed850 ffffff8008f5cf88
[ 9.063466] 3e00: ffffff8008fdd800 0000000000000000 ffffff8008dc69e2 ffffff8008b3e0a8
[ 9.071287] 3e20: 0000000000000000 0000000700000007 ffffff8008ef1400 ffffffc07ff61f5c
[ 9.079108] 3e40: ffffffc07d003ea0 ffffff8008acc6d4 ffffff8008acc6bc 0000000000000000
[ 9.086928] 3e60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.094750] 3e80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.102571] 3ea0: 0000000000000000 ffffff8008082ef0 ffffff8008acc6bc 0000000000000000
[ 9.110391] 3ec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.118213] 3ee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.126034] 3f00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.133855] 3f20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.141676] 3f40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.149496] 3f60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.157319] 3f80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.165139] 3fa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.172959] 3fc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
[ 9.180781] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 9.188599] Call trace:
[ 9.191055] [] rockchip_pcie_rd_conf+0x128/0x178
[ 9.197236] [] pci_bus_read_config_dword+0x6c/0xa4
[ 9.203585] [] pcie_capability_read_dword+0x5c/0xb0
[ 9.210021] [] __pci_dev_reset+0x4c/0x274
[ 9.215597] [] pci_probe_reset_function+0x24/0x30
[ 9.221863] [] pci_create_sysfs_dev_files+0x20c/0x298
[ 9.228477] [] pci_sysfs_init+0x40/0x60
[ 9.233874] [] do_one_initcall+0x78/0x194
[ 9.239452] [] kernel_init_freeable+0x21c/0x220
[ 9.245545] [] kernel_init+0x18/0x100
[ 9.250771] [] ret_from_fork+0x10/0x20
[ 9.256084] Code: f9400062 8b010041 b9400021 d5033d9f (b9000281)
[ 9.262178] —[ end trace d7779e2eb2aae601 ]—
[ 9.269163] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 9.269163]
[ 9.278352] CPU4: stopping
[ 9.281066] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G D 4.4.194 #12
[ 9.288369] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 9.295935] Call trace:
[ 9.298394] [] dump_backtrace+0x0/0x220
[ 9.303792] [] show_stack+0x24/0x30
[ 9.308840] [] dump_stack+0x94/0xbc
[ 9.313887] [] handle_IPI+0x1e0/0x260
[ 9.319113] [] gic_handle_irq+0x12c/0x184
[ 9.324688] Exception stack(0xffffffc07d05fd90 to 0xffffffc07d05fec0)
[ 9.331120] fd80: 0000000000000000 0000000000000004
[ 9.338942] fda0: 0000004076f57000 0000000000000020 00ffffffffffffff 000000000f959973
[ 9.346765] fdc0: 0000000000000cac 0000000000000004 00000034b5593519 ffffff8008081800
[ 9.354586] fde0: 0000000000001000 0000000000000000 0000000034d5d91d 0000004076f57000
[ 9.362408] fe00: ffffffc07d043600 0000000000000000 0000000000000000 0000000000000000
[ 9.370230] fe20: 0000000030d00800 00000002168371b6 0000000000000002 ffffffc07c070a00
[ 9.378051] fe40: ffffff8009176860 0000000000000001 00000002167b65d1 ffffff800911cb68
[ 9.385872] fe60: 000000000158c000 0000000000cd3244 0000000000000000 ffffffc07d05fec0
[ 9.393693] fe80: ffffff80087a9de8 ffffffc07d05fec0 ffffff80087a9dec 0000000060000045
[ 9.401514] fea0: ffffffc07d05fec0 ffffff80087a9de8 ffffffffffffffff 0000000000000002
[ 9.409336] [] el1_irq+0xb4/0x140
[ 9.414217] [] cpuidle_enter_state+0x1cc/0x25c
[ 9.420226] [] cpuidle_enter+0x34/0x44
[ 9.425538] [] call_cpuidle+0x6c/0x74
[ 9.430763] [] cpu_startup_entry+0x2ac/0x2bc
[ 9.436593] [] secondary_start_kernel+0x190/0x1bc
[ 9.442856] [<0000000000cd3188>] 0xcd3188
[ 9.446873] CPU0: stopping
[ 9.449600] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.194 #12
[ 9.456907] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 9.464468] Call trace:
[ 9.466932] [] dump_backtrace+0x0/0x220
[ 9.472330] [] show_stack+0x24/0x30
[ 9.477391] [] dump_stack+0x94/0xbc
[ 9.482450] [] handle_IPI+0x1e0/0x260
[ 9.487677] [] gic_handle_irq+0x12c/0x184
[ 9.493252] Exception stack(0xffffff8009013d60 to 0xffffff8009013e90)
[ 9.499695] 3d60: 0000000000000000 0000000000000000 0000004076f03000 0000000000000020
[ 9.507523] 3d80: 00ffffffffffffff 000000000f959973 0000000000000cac 0000000000000000
[ 9.515350] 3da0: 00000032b5593519 ffffff8008081800 0000000000001000 0000000000000000
[ 9.523178] 3dc0: 0000000034d5d91d 0000004076f03000 ffffff8009027690 0000000000000000
[ 9.531005] 3de0: 0000000000000000 0000000000000000 0000000030d00800 000000021684045c
[ 9.538832] 3e00: 0000000000000002 ffffffc07c070200 ffffff8009176860 0000000000000001
[ 9.546660] 3e20: 0000000206c2152f ffffff800911cb68 000000000158c000 0000000000cd323c
[ 9.554487] 3e40: 000000000110001c ffffff8009013e90 ffffff80087a9de8 ffffff8009013e90
[ 9.562315] 3e60: ffffff80087a9dec 0000000060000045 ffffff8009013e90 ffffff80087a9de8
[ 9.570140] 3e80: ffffffffffffffff 0000000000000002
[ 9.575018] [] el1_irq+0xb4/0x140
[ 9.579898] [] cpuidle_enter_state+0x1cc/0x25c
[ 9.585908] [] cpuidle_enter+0x34/0x44
[ 9.591221] [] call_cpuidle+0x6c/0x74
[ 9.596437] [] cpu_startup_entry+0x2ac/0x2bc
[ 9.602267] [] rest_init+0x74/0x7c
[ 9.607232] [] start_kernel+0x3c4/0x3e8
[ 9.612629] [] __primary_switched+0x30/0x6c
[ 9.618372] CPU3: stopping
[ 9.621085] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.194 #12
[ 9.628391] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 9.635951] Call trace:
[ 9.638408] [] dump_backtrace+0x0/0x220
[ 9.643805] [] show_stack+0x24/0x30
[ 9.648863] [] dump_stack+0x94/0xbc
[ 9.653920] [] handle_IPI+0x1e0/0x260
[ 9.659146] [] gic_handle_irq+0x12c/0x184
[ 9.664720] Exception stack(0xffffffc07d05bd90 to 0xffffffc07d05bec0)
[ 9.671161] bd80: 0000000000000000 0000000000000003
[ 9.678989] bda0: 0000004076f42000 0000000000000020 00ffffffffffffff 000000000f959973
[ 9.686816] bdc0: 0000000000000cac 0000000000000003 00000032b5593519 ffffff8008081800
[ 9.694643] bde0: 0000000000001000 0000000000000000 0000000034d5d91d 0000004076f42000
[ 9.702471] be00: ffffffc07d042880 0000000000000000 0000000000000000 0000000000000000
[ 9.710298] be20: 0000000030d00800 000000021684c976 0000000000000002 ffffffc07c070800
[ 9.718126] be40: ffffff8009176860 0000000000000001 00000001e0308435 ffffff800911cb68
[ 9.725954] be60: 000000000158c000 0000000000cd3244 0000000000000000 ffffffc07d05bec0
[ 9.733781] be80: ffffff80087a9de8 ffffffc07d05bec0 ffffff80087a9dec 0000000060000045
[ 9.741609] bea0: ffffffc07d05bec0 ffffff80087a9de8 ffffffffffffffff 0000000000000002
[ 9.749436] [] el1_irq+0xb4/0x140
[ 9.754314] [] cpuidle_enter_state+0x1cc/0x25c
[ 9.760324] [] cpuidle_enter+0x34/0x44
[ 9.765635] [] call_cpuidle+0x6c/0x74
[ 9.770862] [] cpu_startup_entry+0x2ac/0x2bc
[ 9.776691] [] secondary_start_kernel+0x190/0x1bc
[ 9.782952] [<0000000000cd3188>] 0xcd3188
[ 9.786961] CPU2: stopping
[ 9.789673] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.194 #12
[ 9.796980] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 9.804539] Call trace:
[ 9.806996] [] dump_backtrace+0x0/0x220
[ 9.812393] [] show_stack+0x24/0x30
[ 9.817451] [] dump_stack+0x94/0xbc
[ 9.822508] [] handle_IPI+0x1e0/0x260
[ 9.827734] [] gic_handle_irq+0x12c/0x184
[ 9.833308] Exception stack(0xffffffc07d057d90 to 0xffffffc07d057ec0)
[ 9.839750] 7d80: 0000000000000000 0000000000000002
[ 9.847577] 7da0: 0000004076f2d000 0000000000000020 00ffffffffffffff 000000000f959973
[ 9.855405] 7dc0: 0000000000000cac 0000000000000002 00000032b5593519 ffffff8008081800
[ 9.863232] 7de0: 0000000000001000 0000000000000000 0000000034d5d91d 0000004076f2d000
[ 9.871060] 7e00: ffffffc07d041b00 0000000000000000 0000000000000000 0000000000000000
[ 9.878887] 7e20: 0000000030d00800 00000002168428d1 0000000000000002 ffffffc07c070600
[ 9.886714] 7e40: ffffff8009176860 0000000000000001 00000001e03081ee ffffff800911cb68
[ 9.894542] 7e60: 000000000158c000 0000000000cd3244 0000000000000000 ffffffc07d057ec0
[ 9.902369] 7e80: ffffff80087a9de8 ffffffc07d057ec0 ffffff80087a9dec 0000000060000045
[ 9.910197] 7ea0: ffffffc07d057ec0 ffffff80087a9de8 ffffffffffffffff 0000000000000002
[ 9.918023] [] el1_irq+0xb4/0x140
[ 9.922902] [] cpuidle_enter_state+0x1cc/0x25c
[ 9.928912] [] cpuidle_enter+0x34/0x44
[ 9.934223] [] call_cpuidle+0x6c/0x74
[ 9.939449] [] cpu_startup_entry+0x2ac/0x2bc
[ 9.945278] [] secondary_start_kernel+0x190/0x1bc
[ 9.951539] [<0000000000cd3188>] 0xcd3188
[ 9.955548] CPU1: stopping
[ 9.958261] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.194 #12
[ 9.965568] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 9.973127] Call trace:
[ 9.975584] [] dump_backtrace+0x0/0x220
[ 9.980981] [] show_stack+0x24/0x30
[ 9.986039] [] dump_stack+0x94/0xbc
[ 9.991097] [] handle_IPI+0x1e0/0x260
[ 9.996323] [] gic_handle_irq+0x12c/0x184
[ 10.001897] Exception stack(0xffffffc07d053d90 to 0xffffffc07d053ec0)
[ 10.008338] 3d80: 0000000000000000 0000000000000001
[ 10.016166] 3da0: 0000004076f18000 0000000000000020 00ffffffffffffff 000000000f959973
[ 10.023993] 3dc0: 0000000000000cac 0000000000000001 00000032b5593519 ffffff8008081800
[ 10.031821] 3de0: 0000000000001000 0000000000000000 0000000034d5d91d 0000004076f18000
[ 10.039649] 3e00: ffffffc07d040d80 0000000000000000 0000000000000000 0000000000000000
[ 10.047476] 3e20: 0000000030d00800 000000021684776e 0000000000000002 ffffffc07c070400
[ 10.055304] 3e40: ffffff8009176860 0000000000000001 00000001e0213a4f ffffff800911cb68
[ 10.063132] 3e60: 000000000158c000 0000000000cd3244 0000000000000000 ffffffc07d053ec0
[ 10.070959] 3e80: ffffff80087a9de8 ffffffc07d053ec0 ffffff80087a9dec 0000000060000045
[ 10.078787] 3ea0: ffffffc07d053ec0 ffffff80087a9de8 ffffffffffffffff 0000000000000002
[ 10.086613] [] el1_irq+0xb4/0x140
[ 10.091492] [] cpuidle_enter_state+0x1cc/0x25c
[ 10.097502] [] cpuidle_enter+0x34/0x44
[ 10.102813] [] call_cpuidle+0x6c/0x74
[ 10.108040] [] cpu_startup_entry+0x2ac/0x2bc
[ 10.113870] [] secondary_start_kernel+0x190/0x1bc
[ 10.120131] [<0000000000cd3188>] 0xcd3188
[ 10.124140] CRU:
[ 10.125989] 00000000: 00000044 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 10.134515] 00000020: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 10.143043] 00000040: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 10.151569] 00000060: 000000c0 00001302 8000031f 00000008 00000007 00007f00 00000000 00000000
[ 10.160086] 00000080: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 10.168602] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
[ 10.177118] 000000c0: 00000064 00001403 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 10.185644] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.194160] 00000100: 00000100 00000701 00000140 00006404 00000083 00008581 00008320 00000141
[ 10.202686] 00000120: 00000181 00008181 00000141 00000141 00004141 00008343 00003185 0000010f
[ 10.211212] 00000140: 00000203 00000300 00004a87 0000033f 00009381 00008387 00001103 00005282
[ 10.219738] 00000160: 00008247 00000187 00001743 0000001f 00000380 00000300 00000380 00000000
[ 10.228263] 00000180: 0000e380 00001200 00000200 00000200 00000200 00000200 00003f3f 00000081
[ 10.236780] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000005 00000381
[ 10.245306] 000001c0: 00000381 00000101 00000000 00000087 00000087 00000141 00000141 00008181
[ 10.253831] 000001e0: 00008320 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
[ 10.262357] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.270882] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.279398] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.287914] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.296440] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[ 10.304965] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[ 10.313491] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.322016] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.330541] 00000300: 00000000 00000000 00000202 00000000 00000030 00000000 00000003 00000000
[ 10.339056] 00000320: 00008000 00000000 00000001 00000000 0000001e 000000f1 00000000 00000000
[ 10.347572] 00000340: 00000005 00000000 00000000 00000000 00000000 00000000 00004041 00000000
[ 10.356097] 00000360: 00000000 00000020 00000000 00000000 00000000 00000000 00000116 00000038
[ 10.364613] 00000380: 00000000 00000100 00000018 00000000 00000000 00000000 00000000 00000000
[ 10.373128] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.381643] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.390168] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.398683] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.407209] 00000420: 00000000 00007070 00000000 00000014 00000000 00000000 00000000 00000000
[ 10.415724] 00000440: 00000000 00000000 00000000 00000000 00003000 00000000 00000000 00000000
[ 10.424240] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.432755] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.441280] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.449804] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.458330] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.466855] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000
[ 10.475380] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.483905] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.492430] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.500944] 00000580: 00000004 00000000 00000004 00000000 00000004
[ 10.507119] PMU CRU:
[ 10.509314] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[ 10.517842] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.526369] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.534886] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.543414] 00000080: 0000060d 00001986 00000303 00000003 000002dc 00000200 0bb8ea60 00040050
[ 10.551940] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.560466] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.568984] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.577510] 00000100: 00000700 00000188 0000000f 00000000 00000024 00000000 00000000 00000000
[ 10.586034] 00000120: 00000000 00000000 00000000 00000000 00000003
[ 10.592212] PMU:
[ 10.594058] 00000000: 00000000 00000000 00000000 00000000 00000000 c8088300 c8088300 00000000
[ 10.602585] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.611112] 00000040: 00000000 00000000 00000000 00000000 00000000 c808833f 00000000 00000000
[ 10.619639] 00000060: 30001041 30001041 30001041 00000010 00000000 00007e00 00000000 28800000
[ 10.628167] 00000080: 000003c0 00011940 00005dc0 000003c0 00005dc0 00000060 0000000f 00000018
[ 10.636695] 000000a0: 00000018 00000018 00000018 00000006 00000006 00005dc0 00005dc0 00005dc0
[ 10.645212] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 3fffffff 00000000
[ 10.653739] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.662258] Kernel Offset: disabled
[ 10.665747] Memory Limit: none
[ 10.668820] rockchip-thermal ff260000.tsadc: channal 0: temperature(55 C)
[ 10.675601] THERMAL REGS:
[ 10.678230] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000
[ 10.686756] 00000020: 00000238 00000233 00000000 00000000 0000024e 00000000 00000000 00000000
[ 10.695283] 00000040: 000002a5 000002a5 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.703809] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
[ 10.712330] 00000080: 00000000 00000000
[ 10.730145] —[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 10.730145]
[ 36.368700] Watchdog detected hard LOCKUP on cpu 0
[ 36.373319] ------------[ cut here ]------------
[ 36.378124] WARNING: at kernel/watchdog.c:352
[ 36.382480] Modules linked in:
[ 36.385559]
[ 36.387062] CPU: 5 PID: 1 Comm: swapper/0 Tainted: G D 4.4.194 #12
[ 36.394363] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
[ 36.401928] task: ffffffc00a378000 task.stack: ffffffc07d000000
[ 36.407851] PC is at watchdog_timer_fn+0x170/0x2e0
[ 36.412645] LR is at watchdog_timer_fn+0x170/0x2e0
[ 36.417436] pc : [] lr : [] pstate: 600001c5
[ 36.424821] sp : ffffffc07ff4ddf0
[ 36.428141] x29: ffffffc07ff4ddf0 x28: 0000000000000000
[ 36.433492] x27: ffffff800901d760 x26: ffffff8008fe4238
[ 36.438841] x25: ffffffc07ff50250 x24: ffffffc07d0037e0
[ 36.444190] x23: 0000000000000000 x22: 0000000000000000
[ 36.449539] x21: ffffff800901c000 x20: ffffff8008fe42b0
[ 36.454887] x19: ffffff8008fe4000 x18: ffffff80891ba8d7
[ 36.460226] x17: 000000000000000a x16: 00000000000001fd
[ 36.465574] x15: 0000000000000000 x14: 000000000005a03c
[ 36.470912] x13: 000000000000000a x12: 0000000000000030
[ 36.476261] x11: 00000000fffffffe x10: ffffff80091ba8df
[ 36.481610] x9 : 0000000005f5e0ff x8 : ffffff8008367914
[ 36.486948] x7 : ffffff8009088f38 x6 : 0000000000000035
[ 36.492297] x5 : 0000000000000000 x4 : 0000000000000000
[ 36.497645] x3 : 0000004076f6c000 x2 : 0000004076f6c000
[ 36.502984] x1 : 0000000000000005 x0 : 0000000000000026
[ 36.508334]
[ 36.508334] PC: 0xffffff800812d548:
[ 36.513294] d548 f9401000 d63f0000 aa0003e1 aa1b03e2 aa1903e0 97ff55ed b50003f6 91022694
[ 36.521629] d568 d538d080 38606a81 34000041 38206a9f 97ffff7b a94153f3 52800020 a9425bf5
[ 36.529962] d588 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020283 f87a6840 f8636845
[ 36.538295] d5a8 91022294 eb05001f 54000b60 f8236840 f87c7b60 3834681f 17ffffda 9400d45a
[ 36.546628] d5c8 d4210000 f87c7b60 52800021 38346801 17ffffd4 97fe747e f943aaa1 36080921
[ 36.554962] d5e8 b9401341 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841 6b160016
[ 36.563295] d608 54000800 91022a99 d538d080 38796801 34000101 91024294 f8746802 d5384101
[ 36.571628] d628 eb01005f 54fffa80 3839681f 17ffffd1 34000157 900087a1 52800000 910f0021
[ 36.579963]
[ 36.579963] LR: 0xffffff800812d548:
[ 36.584923] d548 f9401000 d63f0000 aa0003e1 aa1b03e2 aa1903e0 97ff55ed b50003f6 91022694
[ 36.593256] d568 d538d080 38606a81 34000041 38206a9f 97ffff7b a94153f3 52800020 a9425bf5
[ 36.601579] d588 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020283 f87a6840 f8636845
[ 36.609901] d5a8 91022294 eb05001f 54000b60 f8236840 f87c7b60 3834681f 17ffffda 9400d45a
[ 36.618234] d5c8 d4210000 f87c7b60 52800021 38346801 17ffffd4 97fe747e f943aaa1 36080921
[ 36.626567] d5e8 b9401341 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841 6b160016
[ 36.634900] d608 54000800 91022a99 d538d080 38796801 34000101 91024294 f8746802 d5384101
[ 36.643233] d628 eb01005f 54fffa80 3839681f 17ffffd1 34000157 900087a1 52800000 910f0021
[ 36.651566]
[ 36.651566] SP: 0xffffffc07ff4dd70:
[ 36.656527] dd70 00000000 00000000 00000000 00000000 7d0037e0 ffffffc0 7ff50250 ffffffc0
[ 36.664859] dd90 08fe4238 ffffff80 0901d760 ffffff80 00000000 00000000 7ff4ddf0 ffffffc0
[ 36.673193] ddb0 0812d5c8 ffffff80 7ff4ddf0 ffffffc0 0812d5c8 ffffff80 600001c5 00000000
[ 36.681526] ddd0 0901c750 ffffff80 00000002 00000000 00000000 00000080 7d400028 ffffffc0
[ 36.689859] ddf0 7ff4de60 ffffffc0 0810356c ffffff80 7ff50250 ffffffc0 7ff4fc00 ffffffc0
[ 36.698193] de10 7ff4fc80 ffffffc0 08fde000 ffffff80 00000001 00000000 09176338 ffffff80
[ 36.706526] de30 08fde000 ffffff80 0812d458 ffffff80 65396dfb 00000008 0a378000 ffffffc0
[ 36.714858] de50 7ff50250 ffffffc0 0901c750 ffffff80 7ff4ded0 ffffffc0 08103b88 ffffff80
[ 36.723195]
[ 36.723195] X7: 0xffffff8009088eb8:
[ 36.728155] 8eb8 7cd36300 ffffffc0 00000000 00000000 00000000 00000000 00110000 00000000
[ 36.736489] 8ed8 000f0000 00000000 00000000 00000000 00040000 00000000 00080000 00000000
[ 36.744822] 8ef8 00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000
[ 36.753143] 8f18 00000000 00000001 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.761476] 8f38 00000000 00000000 08d9bb8d ffffff80 08590859 dead4ead ffffffff 00000000
[ 36.769809] 8f58 ffffffff ffffffff 7cd80000 ffffffc0 00040000 00000000 00000001 00000000
[ 36.778142] 8f78 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 09088f90 ffffff80
[ 36.786475] 8f98 09088f90 ffffff80 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.794798]
[ 36.794798] X8: 0xffffff8008367894:
[ 36.799758] 7894 9400054a aa1303e0 94000554 52800000 a94153f3 f94013f5 a8c37bfd d65f03c0
[ 36.808091] 78b4 f9400413 17fffff6 f9400813 17fffff4 f9400c13 17fffff2 128002a0 17fffff5
[ 36.816425] 78d4 71001c1f 54000161 f9405ce0 f9400c00 b4000140 a9bf7bfd aa0603e2 aa0403e1
[ 36.824757] 78f4 910003fd 940004ce a8c17bfd d65f03c0 128002a0 d65f03c0 12800160 d65f03c0
[ 36.833090] 7914 a9bb7bfd 7100081f 910003fd a9025bf5 aa0403f6 a90153f3 aa0603f5 a90363f7
[ 36.841422] 7934 f9405cf3 54000181 f9400660 b4000a20 2a1503e2 aa1603e1 9400047d 52800000
[ 36.849755] 7954 a94153f3 a9425bf5 a94363f7 a8c57bfd d65f03c0 71000c1f 54000061 f9400a60
[ 36.858088] 7974 17fffff3 71001c1f 54000061 f9400e60 17ffffef 35000820 51000420 7100041f
[ 36.866423]
[ 36.866423] X10: 0xffffff80091ba85f:
[ 36.871467] a85c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.879800] a87c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.888132] a89c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.896465] a8bc 00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[ 36.904798] a8dc 392e3633 39373433 61205d38 20636438 382e3633 32343636 58205d33 203a3031
[ 36.913130] a8fc 66667830 66666666 39303038 38616231 0a3a6635 32313830 38633564 70205d3e
[ 36.921463] a91c 74617473 36203a65 30303030 0a356331 30780a29 30303030 0a623030 2020205b
[ 36.929796] a93c 372e3031 34313033 0a205d35 73757461 29302820 65740a0a 66692072 756f7920
[ 36.938129] a95c 65656e20 68742064 0a2e7369 6f702f30 2d726577 746e6f63 6c6c6f72 66207265
[ 36.946466]
[ 36.946466] X18: 0xffffff80891ba857:
[ 36.951510] a854 ******** ******** ******** ******** ******** ******** ******** ********
[ 36.959848] a874 ******** ******** ******** ******** ******** ******** ******** ********
[ 36.968184] a894 ******** ******** ******** ******** ******** ******** ******** ********
[ 36.976520] a8b4 ******** ******** ******** ******** ******** ******** ******** ********
[ 36.984855] a8d4 ******** ******** ******** ******** ******** ******** ******** ********
[ 36.993191] a8f4 ******** ******** ******** ******** ******** ******** ******** ********
[ 37.001527] a914 ******** ******** ******** ******** ******** ******** ******** ********
[ 37.009863] a934 ******** ******** ******** ******** ******** ******** ******** ********
[ 37.018199] a954 ******** ******** ******** ******** ******** ******** ******** ********
[ 37.026536]
[ 37.026536] X19: 0xffffff8008fe3f80:
[ 37.031581] 3f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.039914] 3fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.048247] 3fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.056580] 3fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.064912] 4000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.073245] 4020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.081578] 4040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.089911] 4060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.098245]
[ 37.098245] X20: 0xffffff8008fe4230:
[ 37.103289] 4230 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.111622] 4250 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.119955] 4270 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.128287] 4290 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.136620] 42b0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.144952] 42d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.153285] 42f0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.161618] 4310 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.169951]
[ 37.169951] X21: 0xffffff800901bf80:
[ 37.174996] bf80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.183328] bfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.191661] bfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.199994] bfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.208326] c000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.216659] c020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.224992] c040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.233324] c060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.241659]
[ 37.241659] X24: 0xffffffc07d003760:
[ 37.246703] 3760 00000005 00000000 09036000 ffffff80 00000000 00000000 00000000 00000000
[ 37.255036] 3780 00000051 00000000 00000000 00000000 091bb13a ffffff80 00000006 00000000
[ 37.263369] 37a0 7d0037c0 ffffffc0 00016b50 00000006 00000000 00000000 00000000 00000001
[ 37.271702] 37c0 7d003860 ffffffc0 080ee550 ffffff80 7d0038c0 ffffffc0 08d71ed7 ffffff80
[ 37.280035] 37e0 0000214e 00000000 36567d65 00000000 000003e8 00000000 76f6c000 00000040
[ 37.288368] 3800 00000000 00000000 00000000 00000000 00000070 00000000 09088f38 ffffff80
[ 37.296701] 3820 08367914 ffffff80 05f5e0ff 00000000 091ba93f ffffff80 fffffffe 00000000
[ 37.305035] 3840 00000030 00000000 0000000a 00000000 000b2421 00000000 00000000 00000000
[ 37.313369]
[ 37.313369] X25: 0xffffffc07ff501d0:
[ 37.318413] 01d0 ffffffff 00000000 ffffffff ffffffff 00000001 00000000 7ff501e8 ffffffc0
[ 37.326746] 01f0 7ff501e8 ffffffc0 7ff501f8 ffffffc0 7ff501f8 ffffffc0 0812c070 ffffff80
[ 37.335080] 0210 7d003cf8 ffffffc0 7d003c50 ffffffc0 00020002 00000000 00000000 00000000
[ 37.343413] 0230 00000001 00000000 00000009 00000000 00000002 00000000 7d0dec00 ffffffc0
[ 37.351746] 0250 7ff50250 ffffffc0 7ff500c0 ffffffc0 00000000 00000000 65396a80 00000008
[ 37.360079] 0270 65396a80 00000008 0812d458 ffffff80 7ff4fc80 ffffffc0 00000000 0000001f
[ 37.368401] 0290 0812d42c ffffff80 63746177 676f6468 0000352f 00000000 00000000 00000000
[ 37.376724] 02b0 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 37.385057]
[ 37.385057] X26: 0xffffff8008fe41b8:
[ 37.390102] 41b8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.398435] 41d8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.406768] 41f8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.415100] 4218 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.423433] 4238 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.431765] 4258 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.440098] 4278 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.448430] 4298 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.456764]
[ 37.456764] X27: 0xffffff800901d6e0:
[ 37.461808] d6e0 00000001 00000000 00000001 00000000 000003e8 00000000 7ff5fbc0 ffffffc0
[ 37.470141] d700 00000015 00000000 7ff5fb80 ffffffc0 00000001 00000000 00000060 00000000
[ 37.478474] d720 00015000 00001000 00000001 00000000 7ff5fc00 ffffffc0 7ff5fc40 ffffffc0
[ 37.486807] d740 00000006 00000000 00000005 00000010 7ff5fa80 ffffffc0 7fee1000 ffffffc0
[ 37.495139] d760 76f03000 00000040 76f18000 00000040 76f2d000 00000040 76f42000 00000040
[ 37.503472] d780 76f57000 00000040 76f6c000 00000040 00000000 00000000 00000000 00000000
[ 37.511805] d7a0 00000002 00000000 000013b6 00000000 00010000 00000000 0007ffff 00000000
[ 37.520138] d7c0 0000f3c2 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[ 37.528472]
[ 37.528472] X29: 0xffffffc07ff4dd70:
[ 37.533516] dd70 00000000 00000000 00000000 00000000 7d0037e0 ffffffc0 7ff50250 ffffffc0
[ 37.541849] dd90 08fe4238 ffffff80 0901d760 ffffff80 00000000 00000000 7ff4ddf0 ffffffc0
[ 37.550183] ddb0 0812d5c8 ffffff80 7ff4ddf0 ffffffc0 0812d5c8 ffffff80 600001c5 00000000
[ 37.558517] ddd0 0901c750 ffffff80 00000002 00000000 00000000 00000080 7d400028 ffffffc0
[ 37.566850] ddf0 7ff4de60 ffffffc0 0810356c ffffff80 7ff50250 ffffffc0 7ff4fc00 ffffffc0
[ 37.575172] de10 7ff4fc80 ffffffc0 08fde000 ffffff80 00000001 00000000 09176338 ffffff80
[ 37.583506] de30 08fde000 ffffff80 0812d458 ffffff80 65396dfb 00000008 0a378000 ffffffc0
[ 37.591839] de50 7ff50250 ffffffc0 0901c750 ffffff80 7ff4ded0 ffffffc0 08103b88 ffffff80
[ 37.600171]
[ 37.601671] —[ end trace d7779e2eb2aae602 ]—
[ 37.606281] Call trace:
[ 37.608734] Exception stack(0xffffffc07ff4dc10 to 0xffffffc07ff4dd40)
[ 37.615167] dc00: ffffff8008fe4000 0000008000000000
[ 37.622991] dc20: ffffffc07ff4ddf0 ffffff800812d5c8 00000000600001c5 0000000000000000
[ 37.630813] dc40: ffffff80091bb138 0000000000000000 ffffffc07ff4dc70 ffffff80080ee2e8
[ 37.638634] dc60: 0000000000000026 0000000000000000 ffffffc07ff4dd10 ffffff80080ee550
[ 37.646457] dc80: ffffffc07ff4dd70 ffffff8008d79bae ffffff800901c000 0000000000000000
[ 37.654278] dca0: 0000000000000000 ffffffc07d0037e0 ffffffc07ff50250 ffffff8008fe4238
[ 37.662099] dcc0: 0000000000000026 0000000000000005 0000004076f6c000 0000004076f6c000
[ 37.669920] dce0: 0000000000000000 0000000000000000 0000000000000035 ffffff8009088f38
[ 37.677743] dd00: ffffff8008367914 0000000005f5e0ff ffffff80091ba8df 00000000fffffffe
[ 37.685566] dd20: 0000000000000030 000000000000000a 000000000005a03c 0000000000000000
[ 37.693391] [] watchdog_timer_fn+0x170/0x2e0
[ 37.699223] [] __hrtimer_run_queues+0x190/0x290
[ 37.705318] [] hrtimer_interrupt+0xac/0x1bc
[ 37.711066] [] arch_timer_handler_phys+0x38/0x50
[ 37.717247] [] handle_percpu_devid_irq+0xcc/0x17c
[ 37.723511] [] generic_handle_irq+0x2c/0x44
[ 37.729256] [] __handle_domain_irq+0xb4/0xb8
[ 37.735084] [] gic_handle_irq+0xb8/0x184
[ 37.740563] Exception stack(0xffffffc07d0037e0 to 0xffffffc07d003910)
[ 37.746997] 37e0: 000000000000214e 0000000036567d65 00000000000003e8 0000004076f6c000
[ 37.754818] 3800: 0000000000000000 0000000000000000 0000000000000070 ffffff8009088f38
[ 37.762641] 3820: ffffff8008367914 0000000005f5e0ff ffffff80091ba93f 00000000fffffffe
[ 37.770462] 3840: 0000000000000030 000000000000000a 00000000000b2421 0000000000000000
[ 37.778283] 3860: 00000000000001fd 000000000000000a ffffff80891ba937 0000000000005dc0
[ 37.786106] 3880: 0000000000000001 0000000000006400 00000000000064c8 000000000000004b
[ 37.793928] 38a0: 0000000000418958 ffffff8009015000 0000000000000000 ffffff8008fdd940
[ 37.801750] 38c0: ffffffc00a378000 ffffffc07d003910 ffffff80083c8e88 ffffffc07d003910
[ 37.809571] 38e0: ffffff80083c8e5c 0000000080000345 ffffffc00a378000 ffffffc07d003940
[ 37.817392] 3900: 0000008000000000 ffffffc07d003940
[ 37.822268] [] el1_irq+0xb4/0x140
[ 37.827146] [] __delay+0x40/0x48
[ 37.831939] [] __const_udelay+0x24/0x2c
[ 37.837336] [] panic+0x234/0x238
[ 37.842131] [] do_exit+0x584/0x894
[ 37.847093] [] die+0x1a0/0x1b4
[ 37.851706] [] bad_mode+0x78/0x88
[ 37.856584] [] pci_bus_read_config_dword+0x6c/0xa4
[ 37.862932] [] pci_bus_read_config_dword+0x6c/0xa4
[ 37.869281] [] pcie_capability_read_dword+0x5c/0xb0
[ 37.875716] [] __pci_dev_reset+0x4c/0x274
[ 37.881291] [] pci_probe_reset_function+0x24/0x30
[ 37.887556] [] pci_create_sysfs_dev_files+0x20c/0x298
[ 37.894172] [] pci_sysfs_init+0x40/0x60
[ 37.899567] [] do_one_initcall+0x78/0x194
[ 37.905145] [] kernel_init_freeable+0x21c/0x220
[ 37.911238] [] kernel_init+0x18/0x100
[ 37.916464] [] ret_from_fork+0x10/0x20
请问你的问题解决了吗
