RK3399在Android9中屏幕黑屏
现象:rk3399可以正常开机进入系统,并且除开视频播放的其他运用都是正常的,
但是但是:只要一打开视频播放app,屏幕立马黑屏,从logcat上看,
09-15 09:50:36.672 1381 1398 D : set stream to NULL
09-15 09:50:36.699 1381 1398 I chatty : uid=10035(com.android.gallery3d) RenderThread identical 4 lines
09-15 09:50:36.706 1381 1398 D : set stream to NULL
09-15 09:50:36.742 254 254 E hwc_rk : hwc_get_handle_layername:cann’t get value from gralloc
09-15 09:50:36.746 450 464 I ActivityManager: Displayed com.android.packageinstaller/.permission.ui.GrantPermissionsActivity: +468ms
09-15 09:50:36.759 254 254 E hwc_rk : hwc_get_handle_layername:cann’t get value from gralloc
09-15 09:50:36.879 254 254 I chatty : uid=1000(system) composer@2.1-se identical 7 lines
09-15 09:50:36.896 254 254 E hwc_rk : hwc_get_handle_layername:cann’t get value from gralloc
是gralloc无法分配内存。请教一下这个问题有修复吗??
