dumpsys.media.camera 的log 信息
^C
C:\Users\caoronggui>adb logcat > “C:\Users\caoronggui\Desktop\新建文本文档 (2).txt”
^C
C:\Users\caoronggui>adb shell
rk3399pro:/ $ su
su
255|rk3399pro:/ $ dumpsys media.camera
== Service global info: ==
Number of camera devices: 1
Number of normal camera devices: 1
Device 0 maps to “0”
Active Camera Clients:
Allowed user IDs: 0
== Camera service events log (most recent at top): ==
09-16 06:48:10 : DISCONNECT device 0 client for package com.android.camera2 (PID 1442)
09-16 06:48:10 : ADD device 0, reason: (Device status changed from 0 to 1)
09-16 06:48:10 : REMOVE device 0, reason: (Device status changed from -2 to 0)
09-16 06:48:09 : CONNECT device 0 client for package com.android.camera2 (PID 1442)
09-16 06:47:28 : USER_SWITCH previous allowed user IDs: , current allowed user IDs: 0
08-05 09:00:08 : ADD device 0, reason: (Device status changed from 0 to 1)
08-05 09:00:08 : ADD device 0, reason: (Device added)
== Camera Provider HAL external/0 (v2.4, remote) static info: 0 devices: ==
== Camera Provider HAL legacy/0 (v2.4, remote) static info: 1 devices: ==
== Camera HAL device device@3.3/legacy/0 (v3.3) static information: ==
Resource cost: 50
Conflicting devices: None
API1 info:
Has a flash unit: false
Facing: Back
Orientation: 180
API2 camera characteristics:
Dumping camera metadata array: 68 / 68 entries, 2080 / 2080 bytes of extra data.
Version: 1, Flags: 00000000
android.colorCorrection.availableAberrationModes (00004): byte[1]
[0 ]
android.control.aeAvailableAntibandingModes (10012): byte[4]
[0 1 2 3 ]
android.control.aeAvailableModes (10013): byte[2]
[1 0 ]
android.control.aeAvailableTargetFpsRanges (10014): int32[4]
[15 30 30 30 ]
android.control.aeCompensationRange (10015): int32[2]
[-6 6 ]
android.control.aeCompensationStep (10016): rational[1]
[(1 / 3) ]
android.control.afAvailableModes (10017): byte[6]
[0 1 2 3 4 5 ]
android.control.availableEffects (10018): byte[1]
[0 ]
android.control.availableSceneModes (10019): byte[1]
[0 ]
android.control.availableVideoStabilizationModes (1001a): byte[1]
[0 ]
android.control.awbAvailableModes (1001b): byte[5]
[1 2 3 5 6 ]
android.control.maxRegions (1001c): int32[3]
[1 0 1 ]
android.control.aeLockAvailable (10024): byte[1]
[FALSE ]
android.control.awbLockAvailable (10025): byte[1]
[FALSE ]
android.control.availableModes (10026): byte[1]
[1 ]
android.edge.availableEdgeModes (30002): byte[3]
[0 1 2 ]
android.flash.colorTemperature (40003): byte[1]
[0 ]
android.flash.maxEnergy (40004): byte[1]
[10 ]
[0 ]
android.flash.info.available (50000): byte[1]
[FALSE ]
android.flash.info.chargeDuration (50001): int64[1]
[1000000 ]
android.jpeg.availableThumbnailSizes (70007): int32[10]
[0 0 128 96 ]
[160 96 160 120 ]
[256 196 ]
android.jpeg.maxSize (70008): int32[1]
[19267584 ]
android.lens.facing (80005): byte[1]
[BACK ]
android.lens.info.availableApertures (90000): float[1]
[2.00000000 ]
android.lens.info.availableFocalLengths (90002): float[1]
[2.03999996 ]
android.lens.info.availableOpticalStabilization (90003): byte[1]
[0 ]
android.lens.info.hyperfocalDistance (90004): float[1]
[0.00000000 ]
android.lens.info.minimumFocusDistance (90005): float[1]
[0.10000000 ]
android.noiseReduction.availableNoiseReductionModes (a0002): byte[3]
[0 1 2 ]
android.request.maxNumOutputStreams (c0006): int32[3]
[1 2 1 ]
android.request.maxNumInputStreams (c0008): int32[1]
[0 ]
android.request.pipelineMaxDepth (c000a): byte[1]
[4 ]
android.request.partialResultCount (c000b): int32[1]
[1 ]
android.request.availableCapabilities (c000c): byte[1]
[BACKWARD_COMPATIBLE ]
android.request.availableRequestKeys (c000d): int32[36]
[1441792 3 2 1 ]
[65536 65537 65538 65539 ]
[65541 65542 65543 65540 ]
[65544 65545 65569 65546 ]
[65547 65549 65550 65551 ]
[65552 65553 196608 262146 ]
[458755 458756 458757 458758 ]
[524288 524290 524292 655360 ]
[851968 1114112 1114115 1114126 ]
android.request.availableResultKeys (c000e): int32[43]
[0 1 2 65536 ]
[65537 65538 65539 65541 ]
[65542 65543 65544 65545 ]
[65569 65546 65547 65549 ]
[65550 65551 65552 65553 ]
[65567 65568 65570 1507328 ]
[196608 262146 458755 458756 ]
[458757 458758 524290 524288 ]
[524292 786441 851968 917527 ]
[917528 917520 917530 1114112 ]
[1114115 655360 1114126 ]
android.request.availableCharacteristicsKeys (c000f): int32[68]
[4 65574 65554 65555 ]
[65572 65556 65557 65558 ]
[65559 65560 65563 65573 ]
[65561 65562 65564 458760 ]
[458759 589824 589826 589827 ]
[589828 589829 524293 786438 ]
[786442 786440 786443 786444 ]
[786445 786446 786447 851972 ]
[851977 851978 851979 851980 ]
[851981 983040 983041 983042 ]
[983043 983044 983045 983046 ]
[983047 983048 917515 917516 ]
[917517 917518 917519 917529 ]
[1376256 1179648 1179649 1179650 ]
[1179654 1179655 262147 262148 ]
[327680 327681 262148 1507329 ]
[1572865 196610 655362 983050 ]
android.scaler.availableMaxDigitalZoom (d0004): float[1]
[4.00000000 ]
android.scaler.availableInputOutputFormatsMap (d0009): int32[8]
[34 2 35 33 ]
[35 2 35 33 ]
android.scaler.availableStreamConfigurations (d000a): int32[84]
[33 1920 1080 OUTPUT ]
[33 1280 960 OUTPUT ]
[33 1280 720 OUTPUT ]
[33 640 480 OUTPUT ]
[33 352 288 OUTPUT ]
[33 320 240 OUTPUT ]
[33 176 144 OUTPUT ]
[35 1920 1080 OUTPUT ]
[35 1280 960 OUTPUT ]
[35 1280 720 OUTPUT ]
[35 640 480 OUTPUT ]
[35 352 288 OUTPUT ]
[35 320 240 OUTPUT ]
[35 176 144 OUTPUT ]
[34 1920 1080 OUTPUT ]
[34 1280 960 OUTPUT ]
[34 1280 720 OUTPUT ]
[34 640 480 OUTPUT ]
[34 352 288 OUTPUT ]
[34 320 240 OUTPUT ]
[34 176 144 OUTPUT ]
android.scaler.availableMinFrameDurations (d000b): int64[80]
[33 1920 ]
[1080 33333333 ]
[33 1280 ]
[960 33333333 ]
[33 1280 ]
[720 33333333 ]
[33 640 ]
[480 33333333 ]
[33 352 ]
[288 33333333 ]
[33 320 ]
[240 33333333 ]
[33 176 ]
[144 33333333 ]
[35 2112 ]
[1568 33333333 ]
[35 1920 ]
[1080 33333333 ]
[35 1280 ]
[960 33333333 ]
[35 1280 ]
[720 33333333 ]
[35 640 ]
[480 33333333 ]
[34 2112 ]
[1568 33333333 ]
[34 1920 ]
[1080 33333333 ]
[34 1280 ]
[960 33333333 ]
[34 1280 ]
[720 33333333 ]
[34 640 ]
[480 33333333 ]
[34 352 ]
[288 33333333 ]
[34 320 ]
[240 33333333 ]
[34 176 ]
[144 33333333 ]
android.scaler.availableStallDurations (d000c): int64[28]
[33 1920 ]
[1080 33333333 ]
[33 1280 ]
[960 33333333 ]
[33 1280 ]
[720 33333333 ]
[33 640 ]
[480 33333333 ]
[33 352 ]
[288 33333333 ]
[33 320 ]
[240 33333333 ]
[33 176 ]
[144 33333333 ]
android.scaler.croppingType (d000d): byte[1]
[CENTER_ONLY ]
android.sensor.baseGainFactor (e000b): rational[1]
[(0 / 1) ]
android.sensor.blackLevelPattern (e000c): int32[4]
[0 0 0 0 ]
android.sensor.maxAnalogSensitivity (e000d): int32[1]
[2400 ]
android.sensor.orientation (e000e): int32[1]
[180 ]
android.sensor.profileHueSatMapDimensions (e000f): int32[3]
[0 0 0 ]
android.sensor.availableTestPatternModes (e0019): int32[2]
[0 2 ]
android.sensor.info.activeArraySize (f0000): int32[4]
[0 0 1920 1080 ]
android.sensor.info.sensitivityRange (f0001): int32[2]
[32 2400 ]
android.sensor.info.colorFilterArrangement (f0002): byte[1]
[BGGR ]
android.sensor.info.exposureTimeRange (f0003): int64[2]
[100000 333333330 ]
android.sensor.info.maxFrameDuration (f0004): int64[1]
[66666666 ]
android.sensor.info.physicalSize (f0005): float[2]
[5.50000000 4.50000000 ]
android.sensor.info.pixelArraySize (f0006): int32[2]
[1920 1080 ]
android.sensor.info.whiteLevel (f0007): int32[1]
[0 ]
android.sensor.info.timestampSource (f0008): byte[1]
[UNKNOWN ]
android.statistics.info.availableFaceDetectModes (120000): byte[1]
[0 ]
android.statistics.info.histogramBucketCount (120001): int32[1]
[0 ]
android.statistics.info.maxFaceCount (120002): int32[1]
[0 ]
android.statistics.info.availableHotPixelMapModes (120006): byte[1]
[0 ]
android.statistics.info.availableLensShadingMapModes (120007): byte[1]
[0 ]
android.info.supportedHardwareLevel (150000): byte[1]
[LIMITED ]
android.sync.maxLatency (170001): int32[1]
[PER_FRAME_CONTROL ]
android.reprocess.maxCaptureStall (180001): int32[1]
[4 ]
android.sensor.info.preCorrectionActiveArraySize (f000a): int32[4]
[0 0 1920 1080 ]
== Camera HAL device device@3.3/legacy/0 (v3.3) dumpState: ==
No active camera device session instance
== Vendor tags: ==
Dumping vendor tag descriptors for vendor with id 3854507339
Dumping configured vendor tag descriptors: 38 entries
0x80000000 (privatedata_effective_driver_frame_id) with type 3 (int64) defined in section org.codeaurora.rkcamera3.privatedata
0x80000001 (privatedata_frame_sof_timestamp) with type 3 (int64) defined in section org.codeaurora.rkcamera3.privatedata
0x80000002 (privatedata_stillcap_sync_needed) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000003 (privatedata_stillcap_sync_cmd) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000004 (privatedata_isp_bls) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000005 (privatedata_isp_lsc_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000006 (privatedata_isp_ccm_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000007 (privatedata_isp_awb_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000008 (privatedata_isp_awb_wp) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000009 (privatedata_isp_awb_curv) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000a (privatedata_isp_awb_refgain) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000b (privatedata_isp_goc_normal) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000c (privatedata_isp_goc_night) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000d (privatedata_isp_cproc_preview) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000e (privatedata_isp_cproc_capture) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000f (privatedata_isp_cproc_video) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000010 (privatedata_isp_dpf_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000011 (privatedata_isp_flt_normal) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000012 (privatedata_isp_flt_night) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000013 (privatedata_isp_sensor_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000014 (privatedata_isp_module_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000015 (privatedata_isp_sensor_reg) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000016 (privatedata_isp_sensor_flip) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000017 (privatedata_isp_system_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000018 (privatedata_isp_bls_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000019 (privatedata_isp_lsc_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001a (privatedata_isp_ccm_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001b (privatedata_isp_awb_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001c (privatedata_isp_awb_wp_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001d (privatedata_isp_awb_curv_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001e (privatedata_isp_awb_refgain_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001f (privatedata_isp_goc_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000020 (privatedata_isp_cproc_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000021 (privatedata_isp_dpf_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000022 (privatedata_isp_flt_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000023 (privatedata_isp_restart) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000024 (privatedata_isp_protocol_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000025 (privatedata_tuning_flag) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
Dumping vendor tag descriptors for vendor with id 2592128789
Dumping configured vendor tag descriptors: None set
== Camera error traces (1): ==
----- pid 425 at 2020-09-16 06:48:10 -----
Cmd line: /system/bin/cameraserver
“cameraserver” sysTid=425
#00 pc 000d79b5 /system/lib/libcameraservice.so (android::camera3::CameraTraces::saveTrace()+100)
#01 pc 000bff03 /system/lib/libcameraservice.so (android::Camera3Device::setErrorStateLockedV(char const*, std::__va_list)+178)
#02 pc 000b6319 /system/lib/libcameraservice.so (android::Camera3Device::setErrorStateLocked(char const*, …)+32)
#03 pc 000bb163 /system/lib/libcameraservice.so (android::Camera3Device::configureStreamsLocked(int, android::CameraMetadata const&, bool)+738)
#04 pc 000ba3b9 /system/lib/libcameraservice.so (android::Camera3Device::filterParamsAndConfigureLocked(android::CameraMetadata const&, int)+132)
#05 pc 000bc355 /system/lib/libcameraservice.so (android::Camera3Device::configureStreams(android::CameraMetadata const&, int)+116)
#06 pc 000ac8bf /system/lib/libcameraservice.so (android::CameraDeviceClient::endConfigure(int, android::CameraMetadata const&)+262)
#07 pc 000acb55 /system/lib/libcameraservice.so (non-virtual thunk to android::CameraDeviceClient::endConfigure(int, android::CameraMetadata const&)+4)
#08 pc 00023859 /system/lib/libcamera_client.so (android::hardware::camera2::BnCameraDeviceUser::onTransact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+504)
#09 pc 00036151 /system/lib/libbinder.so (android::BBinder::transact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+72)
#10 pc 0003d995 /system/lib/libbinder.so (android::IPCThreadState::executeCommand(int)+408)
#11 pc 0003d723 /system/lib/libbinder.so (android::IPCThreadState::getAndExecuteCommand()+106)
#12 pc 0003dc4b /system/lib/libbinder.so (android::IPCThreadState::joinThreadPool(bool)+38)
#13 pc 00000b7f /system/bin/cameraserver (main+102)
#14 pc 0008c67d /system/lib/libc.so (__libc_init+48)
#15 pc 00000ad9 /system/bin/cameraserver (_start_main+40)
#16 pc 00000306 anonymous:e91aa000
“HwBinder:425_1” sysTid=492
#00 pc 0005424c /system/lib/libc.so (__ioctl+8)
#01 pc 00021b93 /system/lib/libc.so (ioctl+38)
#02 pc 00016a65 /system/lib/libhwbinder.so (android::hardware::IPCThreadState::talkWithDriver(bool)+192)
#03 pc 0000f3cb /system/lib/libhwbinder.so (android::hardware::IPCThreadState::getAndExecuteCommand()+10)
#04 pc 0000fcf7 /system/lib/libhwbinder.so (android::hardware::IPCThreadState::joinThreadPool(bool)+190)
#05 pc 000160e5 /system/lib/libhwbinder.so (android::hardware::PoolThread::threadLoop()+12)
#06 pc 0000c0bf /system/lib/libutils.so (android:
:_threadLoop(void*)+170)
#07 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#08 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“HwBinder:425_2” sysTid=493
#00 pc 00019d94 /system/lib/libc.so (syscall+28)
#01 pc 0001d13d /system/lib/libc.so (__futex_wait_ex(void volatile*, bool, int, bool, timespec const*)+88)
#02 pc 00064e99 /system/lib/libc.so (NonPI::MutexLockWithTimeout(pthread_mutex_internal_t*, bool, timespec const*)+156)
#03 pc 0008919b /system/lib/libcameraservice.so (android::Camera2ClientBaseandroid::CameraDeviceClientBase::disconnect()+54)
#04 pc 0007a313 /system/lib/libcameraservice.so (android::CameraService::onDeviceStatusChanged(android::String8 const&, android::hardware:
:common::V1_0::CameraDeviceStatus)+586)
#05 pc 0008c111 /system/lib/libcameraservice.so (android::CameraProviderManager::removeProvider(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator> const&)+452)
#06 pc 0008d889 /system/lib/libcameraservice.so (_ZTv0_n16_N7android21CameraProviderManager12ProviderInfo11serviceDiedEyRKNS_2wpINS_4hidl4base4V1_05IBaseEEE+12)
#07 pc 0001c371 /system/lib/libhidltransport.so (android::hardware::hidl_binder_death_recipient::binderDied(android::wpandroid::hardware::IBinder const&)+68)
#08 pc 0000dd3b /system/lib/libhwbinder.so (android::hardware::BpHwBinder::reportOneDeath(android::hardware::BpHwBinder::Obituary const&)+78)
#09 pc 0000dcd3 /system/lib/libhwbinder.so (android::hardware::BpHwBinder::sendObituary()+182)
#10 pc 0000f96d /system/lib/libhwbinder.so (android::hardware::IPCThreadState::executeCommand(int)+1060)
#11 pc 0000f43b /system/lib/libhwbinder.so (android::hardware::IPCThreadState::getAndExecuteCommand()+122)
#12 pc 0000fcf7 /system/lib/libhwbinder.so (android::hardware::IPCThreadState::joinThreadPool(bool)+190)
#13 pc 000160e5 /system/lib/libhwbinder.so (android::hardware::PoolThread::threadLoop()+12)
#14 pc 0000c0bf /system/lib/libutils.so (android:
#15 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#16 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“HwBinder:425_3” sysTid=498
“Binder:425_1” sysTid=575
#02 pc 0003d573 /system/lib/libbinder.so (android::IPCThreadState::talkWithDriver(bool)+206)
#03 pc 0003d6c3 /system/lib/libbinder.so (android::IPCThreadState::getAndExecuteCommand()+10)
#04 pc 0003dc4b /system/lib/libbinder.so (android::IPCThreadState::joinThreadPool(bool)+38)
#05 pc 0005479d /system/lib/libbinder.so (android::PoolThread::threadLoop()+12)
“Binder:425_2” sysTid=688
“C3Dev-0-Status” sysTid=1539
#00 pc 00019d98 /system/lib/libc.so (syscall+32)
#02 pc 00063b27 /system/lib/libc.so (pthread_cond_timedwait+84)
#03 pc 000d0159 /system/lib/libcameraservice.so (android::camera3::StatusTracker::threadLoop()+656)
#04 pc 0000c139 /system/lib/libutils.so (android:
:_threadLoop(void*)+292)
#05 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#06 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“C3Dev-0-ReqQueu” sysTid=1540
#03 pc 000c45a1 /system/lib/libcameraservice.so (android::Camera3Device::RequestThread::waitIfPaused()+212)
#04 pc 000c425b /system/lib/libcameraservice.so (android::Camera3Device::RequestThread::threadLoop()+54)
#05 pc 0000c139 /system/lib/libutils.so (android:
#06 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#07 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“CDU-0-FrameProc” sysTid=1541
#03 pc 000bcbc3 /system/lib/libcameraservice.so (android::Camera3Device::waitForNextFrame(long long)+242)
#04 pc 00091e55 /system/lib/libcameraservice.so (android::camera2::FrameProcessorBase::threadLoop()+84)
----- end 425 -----
rk3399pro:/ $
如下log 是 在打开camera 相机应用时:log :
--------- beginning of main
08-05 09:00:03.106 234 234 W auditd : type=2000 audit(0.0:1): initialized
08-05 09:00:04.853 234 234 I auditd : type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
08-05 09:00:05.260 206 206 I init : type=1400 audit(0.0:3): avc: denied { setattr } for name=“system_status” dev=“sysfs” ino=24089 scontext=u:r:vendor_init:s0 tcontext=u:object_r:sysfs_dev:s0 tclass=lnk_file permissive=1
08-05 09:00:05.538 235 235 W SELinux : Multiple same specifications for drm_device_management.
08-05 09:00:05.540 235 235 I SELinux : SELinux: Loaded service_contexts from:
08-05 09:00:05.540 235 235 I SELinux : /system/etc/selinux/plat_service_contexts
08-05 09:00:05.555 237 237 I SELinux : SELinux: Loaded service_contexts from:
08-05 09:00:05.555 237 237 I SELinux : /vendor/etc/selinux/vndservice_contexts
08-05 09:00:05.582 236 236 I hwservicemanager: hwservicemanager is ready now.
--------- beginning of system
08-05 09:00:05.618 244 244 I vold : Vold 3.0 (the awakening) firing up
08-05 09:00:05.619 244 244 V vold : Detected support for: ext4 f2fs vfat
08-05 09:00:05.621 243 243 I android.hardware.keymaster@3.0-impl: Fetching keymaster device name default
08-05 09:00:05.622 243 243 I android.hardware.keymaster@3.0-impl: Could not find any keystore module, using software-only implementation.
08-05 09:00:05.622 243 243 I ServiceManagement: Removing namespace from process name android.hardware.keymaster@3.0-service to keymaster@3.0-service.
08-05 09:00:05.623 243 243 I android.hardware.keymaster@3.0-service: Registration complete for android.hardware.keymaster@3.0::IKeymasterDevice/default.
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop6: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop0: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop2: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop3: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop4: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop7: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop1: No such device or address
08-05 09:00:05.624 244 244 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop5: No such device or address
08-05 09:00:05.627 244 244 D vold : VoldNativeService::start() completed OK
08-05 09:00:05.631 244 250 D vold : e4crypt_init_user0
08-05 09:00:05.631 244 250 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
08-05 09:00:05.631 244 250 D vold : Preparing: /data/system/users/0
08-05 09:00:05.632 244 250 D vold : Preparing: /data/misc/profiles/cur/0
08-05 09:00:05.632 244 250 D vold : Preparing: /data/system_de/0
08-05 09:00:05.632 244 250 D vold : Preparing: /data/misc_de/0
08-05 09:00:05.632 244 250 D vold : Preparing: /data/vendor_de/0
08-05 09:00:05.632 244 250 D vold : Preparing: /data/user_de/0
08-05 09:00:05.632 244 250 V vold : /system/bin/vold_prepare_subdirs
08-05 09:00:05.632 244 250 V vold : prepare
08-05 09:00:05.632 244 250 V vold : 0
08-05 09:00:05.632 244 250 V vold : 1
08-05 09:00:05.656 244 250 I vold_prepare_subdirs: SELinux: Loaded file_contexts
08-05 09:00:05.659 251 251 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_de/0/vold
08-05 09:00:05.659 251 251 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_de/0/storaged
08-05 09:00:05.660 251 251 D vold_prepare_subdirs: Setting up mode 700 uid 1000 gid 1000 context u:object_r:fingerprint_vendor_data_file:s0 on path: /data/vendor_de/0/fpdata
08-05 09:00:05.661 244 250 D vold : e4crypt_unlock_user_key 0 serial=0 token_present=0
08-05 09:00:05.661 244 250 E vold : Failed to chmod /data/system_ce/0: No such file or directory
08-05 09:00:05.662 244 250 E vold : Failed to chmod /data/misc_ce/0: No such file or directory
08-05 09:00:05.662 244 250 E vold : Failed to chmod /data/media/0: No such file or directory
08-05 09:00:05.687 253 253 I /system/bin/tzdatacheck: timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
08-05 09:00:05.693 206 206 W init : type=1400 audit(0.0:4): avc: denied { setattr } for name=“bluetooth” dev=“tmpfs” ino=1147 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=
08-05 09:00:05.696 206 206 W init : type=1400 audit(0.0:5): avc: denied { setattr } for name=“nfc” dev=“tmpfs” ino=1209 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_data_file:s0 tclass=
08-05 09:00:05.742 255 255 I ServiceManagement: Removing namespace from process name android.hidl.allocator@1.0-service to allocator@1.0-service.
08-05 09:00:05.758 256 256 I health@2.0/: health@2.0/backup: Hal starting main loop…
08-05 09:00:05.758 256 256 I health@2.0/: health@2.0/backup Hal is starting up…
08-05 09:00:05.760 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.health@1.0::IHealth/default in either framework or device manifest.
08-05 09:00:05.762 256 256 I health@2.0/: health@2.0/backup: Hal init done
08-05 09:00:05.803 258 258 I ServiceManagement: Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
08-05 09:00:05.811 258 258 I android.hardware.bluetooth@1.0-service: Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
08-05 09:00:05.841 269 269 E light : light_open lights backlight failed: -38
08-05 09:00:05.841 269 269 E light : Light passthrough failed to load legacy HAL.
08-05 09:00:05.842 269 269 E light : light_open lights keyboard failed: -38
08-05 09:00:05.842 269 269 E light : Light passthrough failed to load legacy HAL.
08-05 09:00:05.842 269 269 E light : light_open lights buttons failed: -38
08-05 09:00:05.843 1 1 W init : type=1400 audit(0.0:6): avc: granted { read } for name=“ttyFIQ0” dev=“tmpfs” ino=11360 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
08-05 09:00:05.843 1 1 W init : type=1400 audit(0.0:7): avc: granted { read open } for path=“/dev/ttyFIQ0” dev=“tmpfs” ino=11360 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
08-05 09:00:05.843 269 269 E light : light_open lights battery failed: -38
08-05 09:00:05.843 269 269 E light : Light passthrough failed to load legacy HAL.
08-05 09:00:05.843 269 269 E light : light_open lights notifications failed: -38
08-05 09:00:05.844 269 269 E light : light_open lights attention failed: -38
08-05 09:00:05.844 269 269 E light : Light passthrough failed to load legacy HAL.
08-05 09:00:05.845 269 269 E light : light_open lights bluetooth failed: -38
08-05 09:00:05.845 269 269 E light : Light passthrough failed to load legacy HAL.
08-05 09:00:05.845 269 269 E light : light_open lights wifi failed: -38
08-05 09:00:05.845 269 269 I light : Could not open any lights.
08-05 09:00:05.850 284 284 W init : type=1400 audit(0.0:8): avc: granted { read } for name=“ttyFIQ0” dev=“tmpfs” ino=11360 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
08-05 09:00:05.850 284 284 W init : type=1400 audit(0.0:9): avc: granted { read open } for path=“/dev/ttyFIQ0” dev=“tmpfs” ino=11360 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
08-05 09:00:05.850 281 281 W npu_upgrade: type=1400 audit(0.0:10): avc: denied { execute } for path=“/system/bin/sh” dev=“mmcblk1p14” ino=1416 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
08-05 09:00:05.850 269 269 I ServiceManagement: Removing namespace from process name android.hardware.light@2.0-service to light@2.0-service.
08-05 09:00:05.852 269 269 I android.hardware.light@2.0-service: Registration complete for android.hardware.light@2.0::ILight/default.
08-05 09:00:05.852 272 272 I ServiceManagement: Removing namespace from process name android.hardware.power@1.0-service to power@1.0-service.
08-05 09:00:05.853 277 277 I lowmemorykiller: Using in-kernel low memory killer interface
08-05 09:00:05.854 272 272 I android.hardware.power@1.0-service: Registration complete for android.hardware.power@1.0::IPower/default.
08-05 09:00:05.862 268 268 I health@2.0/: health@2.0/default: Hal starting main loop…
08-05 09:00:05.862 268 268 I health@2.0/: health@2.0/default Hal is starting up…
08-05 09:00:05.864 268 268 I ServiceManagement: Removing namespace from process name android.hardware.health@2.0-service to health@2.0-service.
08-05 09:00:05.867 268 268 I health@2.0/: health@2.0/default: Hal init done
08-05 09:00:05.868 259 259 I android.hardware.camera.provider@2.4-external-service: External camera provider service is starting.
08-05 09:00:05.876 263 263 D android.hardware.drm@1.0-service: android.hardware.drm@1.0-service starting…
08-05 09:00:05.899 275 275 D rockchip.hardware.outputmanager@1.0-service: ***************defaultPassthroughServiceImplementation IRkOutputManager ******
08-05 09:00:05.906 264 264 D android.hardware.drm@1.1-service.clearkey: android.hardware.drm@1.1-service.clearkey starting…
08-05 09:00:05.907 264 264 I ServiceManagement: Removing namespace from process name android.hardware.drm@1.1-service.clearkey to drm@1.1-service.clearkey.
08-05 09:00:05.907 275 275 E rockchip.hardware.outputmanager@1.0-service: Couldn’t set SCHED_FIFO: 1
08-05 09:00:05.909 264 264 I ServiceManagement: Removing namespace from process name android.hardware.drm@1.1-service.clearkey to drm@1.1-service.clearkey.
08-05 09:00:05.930 287 287 D NPU_POWER: version: V1.1
08-05 09:00:05.930 287 287 D NPU_POWER: init gpio: 4
08-05 09:00:05.932 287 287 D NPU_POWER: init gpio: 10
08-05 09:00:05.934 260 260 I android.hardware.camera.provider@2.4-service: Camera provider Service is starting.
08-05 09:00:05.936 280 280 W npu_transfer_pr: type=1400 audit(0.0:11): avc: denied { read } for name=“/” dev=“tmpfs” ino=10290 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:device:s0 tclass=
08-05 09:00:05.936 280 280 W npu_transfer_pr: type=1400 audit(0.0:12): avc: denied { open } for path=“/dev” dev=“tmpfs” ino=10290 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:device:s0 tclass=
08-05 09:00:05.939 261 261 D android.hardware.cas@1.0-service: android.hardware.cas@1.0-service starting…
08-05 09:00:05.939 261 261 I ServiceManagement: Removing namespace from process name android.hardware.cas@1.0-service to cas@1.0-service.
08-05 09:00:05.944 244 293 I Cryptfs : cryptfs_check_passwd
08-05 09:00:05.944 244 293 D Cryptfs : crypt_ftr->fs_size = 21521375
08-05 09:00:05.944 244 293 I Cryptfs : Using scrypt for cryptfs KDF
08-05 09:00:05.949 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.thermal@1.1::IThermal/default in either framework or device manifest.
08-05 09:00:05.950 279 279 W thermalserviced: Unable to get Thermal HAL V1.1, vendor thermal event notification not available
08-05 09:00:05.951 287 287 D NPU_POWER: init gpio: 11
08-05 09:00:05.953 280 280 I NPUTransfer: Starting NPU Transfer Proxy, Transfer version 2.0.0 (8f9ebbc@2020-04-03T09:13:46), devid = 0123456789ABCDEF, pid = 280:1
08-05 09:00:05.953 257 257 I ServiceManagement: Removing namespace from process name android.hardware.audio@2.0-service to audio@2.0-service.
08-05 09:00:05.953 265 265 D android.hardware.drm@1.0-service.widevine: android.hardware.drm@1.1-service.widevine starting…
08-05 09:00:05.954 265 265 I ServiceManagement: Removing namespace from process name android.hardware.drm@1.1-service.widevine to drm@1.1-service.widevine.
08-05 09:00:05.955 257 257 I audiohalservice: Registration complete for android.hardware.audio@4.0::IDevicesFactory/default.
08-05 09:00:05.957 265 265 I ServiceManagement: Removing namespace from process name android.hardware.drm@1.1-service.widevine to drm@1.1-service.widevine.
08-05 09:00:05.957 287 287 D NPU_POWER: init gpio: 54
08-05 09:00:05.957 287 287 D NPU_POWER: init gpio: 55
08-05 09:00:05.958 275 275 I ServiceManagement: Removing namespace from process name rockchip.hardware.outputmanager@1.0-service to outputmanager@1.0-service.
08-05 09:00:05.959 275 275 I rockchip.hardware.outputmanager@1.0-service: Registration complete for rockchip.hardware.outputmanager@1.0::IRkOutputManager/default.
08-05 09:00:05.965 287 287 D NPU_POWER: init gpio: 56
08-05 09:00:05.966 287 287 D NPU_POWER: init gpio: 32
08-05 09:00:05.968 287 287 D NPU_POWER: init gpio: 35
08-05 09:00:05.969 271 271 I ServiceManagement: Removing namespace from process name android.hardware.neuralnetworks@1.1-service-ovx to neuralnetworks@1.1-service-ovx.
08-05 09:00:05.969 287 287 D NPU_POWER: init gpio: 36
08-05 09:00:05.972 287 287 D NPU_POWER: gpio init
08-05 09:00:05.995 259 259 I ExtCamUtils@3.4: loadFromCfg: load external camera config succeed!
08-05 09:00:05.995 259 259 I ExtCamUtils@3.4: loadFromCfg: external camera cfg loaded: maxJpgBufSize 3145728, num video buffers 4, num still buffers 2
08-05 09:00:05.995 259 259 I ExtCamUtils@3.4: loadFromCfg: fpsLimitList: 640x480@30.000000
08-05 09:00:05.995 259 259 I ExtCamUtils@3.4: loadFromCfg: fpsLimitList: 1280x720@30.000000
08-05 09:00:05.995 259 259 I ExtCamUtils@3.4: loadFromCfg: fpsLimitList: 1920x1080@30.000000
08-05 09:00:05.995 257 257 I audiohalservice: Registration complete for android.hardware.audio.effect@4.0::IEffectsFactory/default.
08-05 09:00:05.996 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.soundtrigger@2.1::ISoundTriggerHw/default in either framework or device manifest.
08-05 09:00:05.997 259 259 I ServiceManagement: Removing namespace from process name android.hardware.camera.provider@2.4-external-service to provider@2.4-external-service.
08-05 09:00:05.998 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video3 does not support VIDEO_CAPTURE
08-05 09:00:05.999 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video6 does not support VIDEO_CAPTURE
08-05 09:00:05.999 259 259 I android.hardware.camera.provider@2.4-external-service: Registration complete for android.hardware.camera.provider@2.4::ICameraProvider/external/0.
08-05 09:00:05.999 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video7 does not support VIDEO_CAPTURE
08-05 09:00:06.000 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video5 does not support VIDEO_CAPTURE
08-05 09:00:06.000 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video4 does not support VIDEO_CAPTURE
08-05 09:00:06.000 257 257 E audiohalservice: Could not get passthrough implementation for android.hardware.soundtrigger@2.1::ISoundTriggerHw/default.
08-05 09:00:06.004 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video0 does not support VIDEO_CAPTURE
08-05 09:00:06.005 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video8 does not support VIDEO_CAPTURE
08-05 09:00:06.006 297 297 E NPU_POWER: set clk_en 0 to 1
08-05 09:00:06.006 263 263 I ServiceManagement: Removing namespace from process name android.hardware.drm@1.0-service to drm@1.0-service.
08-05 09:00:06.008 263 263 I android.hardware.drm@1.0-service: Registration complete for android.hardware.drm@1.0::IDrmFactory/default.
08-05 09:00:06.010 263 263 I ServiceManagement: Removing namespace from process name android.hardware.drm@1.0-service to drm@1.0-service.
08-05 09:00:06.010 263 263 I android.hardware.drm@1.0-service: Registration complete for android.hardware.drm@1.0::ICryptoFactory/default.
08-05 09:00:06.011 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video1 does not support VIDEO_CAPTURE
08-05 09:00:06.011 257 257 E SoundTriggerHalImpl: couldn’t load sound trigger module sound_trigger.primary (No such file or directory)
08-05 09:00:06.012 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video9 does not support VIDEO_CAPTURE
08-05 09:00:06.012 259 298 W CamPvdr@2.4-external: deviceAdded device /dev/video2 does not support VIDEO_CAPTURE
08-05 09:00:06.012 259 298 I CamPvdr@2.4-external: threadLoop start monitoring new V4L2 devices
08-05 09:00:06.020 257 257 I audiohalservice: Registration complete for android.hardware.soundtrigger@2.0::ISoundTriggerHw/default.
08-05 09:00:06.021 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default in either framework or device manifest.
08-05 09:00:06.021 257 257 E audiohalservice: Could not get passthrough implementation for android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default.
08-05 09:00:06.021 257 257 W audiohalservice: Could not register Bluetooth audio offload 1.0
08-05 09:00:06.035 274 274 I android.hardware.wifi@1.0-service: Wifi Hal is booting up…
08-05 09:00:06.035 274 274 I ServiceManagement: Removing namespace from process name android.hardware.wifi@1.0-service to wifi@1.0-service.
08-05 09:00:06.036 297 297 D NPU_POWER: powerup
08-05 09:00:06.037 266 266 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
08-05 09:00:06.038 266 266 I ServiceManagement: Removing namespace from process name android.hardware.graphics.allocator@2.0-service to allocator@2.0-service.
08-05 09:00:06.040 273 273 W linker : Warning: “/vendor/lib64/libmllite.so” unused DT entry: DT_RPATH (type 0xf arg 0x1669) (ignoring)
08-05 09:00:06.040 273 273 W linker : Warning: “/vendor/lib64/libmplmpu.so” unused DT entry: DT_RPATH (type 0xf arg 0x1e46) (ignoring)
08-05 09:00:06.041 266 266 I android.hardware.graphics.allocator@2.0-service: Registration complete for android.hardware.graphics.allocator@2.0::IAllocator/default.
08-05 09:00:06.042 273 273 D Sensors : int open_sensors(const struct hw_module_t *, const char *, struct hw_device_t **)
08-05 09:00:06.042 273 273 D Sensors : Sensor HAL version: 1.18
08-05 09:00:06.042 273 273 D Sensors : dev_name=(null), data_name=(null), data_fd=-1
08-05 09:00:06.044 273 273 E Sensors : couldn’t find ‘compass’ input device
08-05 09:00:06.044 273 273 D Sensors : dev_name=/dev/compass, data_name=compass, data_fd=-1
08-05 09:00:06.044 273 273 E Sensors : Couldn’t open /dev/compass (No such file or directory)
08-05 09:00:06.045 273 273 E Sensors : couldn’t find ‘lightsensor-level’ input device
08-05 09:00:06.047 262 262 W /vendor/bin/hw/android.hardware.configstore@1.1-service: libminijail[262]: allowing syscall: connect
08-05 09:00:06.047 262 262 W /vendor/bin/hw/android.hardware.configstore@1.1-service: libminijail[262]: allowing syscall: fcntl
08-05 09:00:06.047 262 262 W /vendor/bin/hw/android.hardware.configstore@1.1-service: libminijail[262]: allowing syscall: sendto
08-05 09:00:06.047 262 262 W /vendor/bin/hw/android.hardware.configstore@1.1-service: libminijail[262]: allowing syscall: socket
08-05 09:00:06.047 262 262 W /vendor/bin/hw/android.hardware.configstore@1.1-service: libminijail[262]: allowing syscall: writev
08-05 09:00:06.047 273 273 D Sensors : dev_name=/dev/lightsensor, data_name=lightsensor-level, data_fd=-1
08-05 09:00:06.048 285 300 I adbd : initializing functionfs
08-05 09:00:06.048 285 300 I adbd : opening control endpoint /dev/usb-ffs/adb/ep0
08-05 09:00:06.049 262 262 W /vendor/bin/hw/android.hardware.configstore@1.1-service: libminijail[262]: logging seccomp filter failures
08-05 09:00:06.050 262 262 I ServiceManagement: Removing namespace from process name android.hardware.configstore@1.1-service to configstore@1.1-service.
08-05 09:00:06.058 285 300 I adbd : functionfs successfully initialized
08-05 09:00:06.058 285 300 I adbd : registering usb transport
08-05 09:00:06.060 273 273 E Sensors : couldn’t find ‘proximity’ input device
08-05 09:00:06.060 273 273 D Sensors : dev_name=/dev/psensor, data_name=proximity, data_fd=-1
08-05 09:00:06.060 273 273 E Sensors : Couldn’t open /dev/psensor (No such file or directory)
08-05 09:00:06.060 273 273 D Sensors : dev_name=(null), data_name=(null), data_fd=-1
08-05 09:00:06.062 273 273 E Sensors : HAL:ERR- Failed to get chip ID
08-05 09:00:06.063 273 273 E Sensors : HAL:could not open timestamp enable
08-05 09:00:06.063 273 273 E Sensors : HAL:could not open buffer length
08-05 09:00:06.063 273 273 E Sensors : HAL:could not open iio device node
08-05 09:00:06.063 273 273 E Sensors : HAL:could not open dmp state
08-05 09:00:06.063 273 273 E Sensors : HAL:could not open temperature node
08-05 09:00:06.063 273 273 E Sensors : HAL:Error opening gyro FSR
08-05 09:00:06.063 273 273 E Sensors : HAL:Error opening accel FSR
08-05 09:00:06.063 273 273 E Sensors : HAL:could not open accel calibrated bias
08-05 09:00:06.063 273 273 E Sensors : HAL:ERR couldn’t open dmp_sign_motion node
08-05 09:00:06.063 273 273 E MPL-storeload: Cannot open file “/metadata/inv_cal_data.bin” for read, errno = 2, No such file or directory
08-05 09:00:06.063 273 273 E MPL-storeload: Could not load cal file - aborting
08-05 09:00:06.063 273 273 E Sensors : HAL:Could not open or load MPL calibration file (46)
08-05 09:00:06.063 273 273 E MPL :
08-05 09:00:06.063 273 273 E MPL : Critical error! Impossible mounting orientation given. Using Identity instead
08-05 09:00:06.063 273 273 I Sensors : newState = 0x0, what = 0x0, mEnabled = 0x0.
08-05 09:00:06.063 273 273 E Sensors : HAL:unknown gyro id – gyro params will be wrong.
08-05 09:00:06.063 273 273 E Sensors : HAL:default to use mpu3050 params
08-05 09:00:06.063 273 273 E Sensors : HAL:unknown accel id – params default to bma250 and might be wrong.
08-05 09:00:06.063 273 273 D Sensors : compass poll fd=-1
08-05 09:00:06.065 273 273 I ServiceManagement: Removing namespace from process name android.hardware.sensors@1.0-service to sensors@1.0-service.
08-05 09:00:06.074 273 273 I android.hardware.sensors@1.0-service: Registration complete for android.hardware.sensors@1.0::ISensors/default.
08-05 09:00:06.091 267 267 W hwc_rk : BP: baseparamter file cann’t be find.
08-05 09:00:06.120 260 260 I vpu_api : dlopen vpu lib /vendor/lib/librk_vpuapi.so success
08-05 09:00:06.126 260 260 D RkCamera: Debug log file is not enabled
08-05 09:00:06.126 260 260 I Camera3HALModule: @initCameraHAL: RockChip Camera Hal3 Release version v1.9.1
08-05 09:00:06.153 260 260 D RkCamera: Debug log file is not enabled
08-05 09:00:06.154 260 260 I CamProvider@2.4-impl: Loaded “Rockchip Camera3HAL Module” camera module
08-05 09:00:06.156 260 260 D RkCamera: Debug log file is not enabled
08-05 09:00:06.158 260 260 D RkCamera: Debug log file is not enabled
08-05 09:00:06.160 260 260 I ServiceManagement: Removing namespace from process name android.hardware.camera.provider@2.4-service to provider@2.4-service.
08-05 09:00:06.166 260 260 I android.hardware.camera.provider@2.4-service: Registration complete for android.hardware.camera.provider@2.4::ICameraProvider/legacy/0.
08-05 09:00:06.188 270 270 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
08-05 09:00:06.188 270 270 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
08-05 09:00:06.189 270 270 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
08-05 09:00:06.189 270 270 I mali_so : cmdline : /vendor/bin/hw/android.hardware.neuralnetworks@1.1-service-armnn, we should GO THROUGH patch_for_sf_memory_leak.
08-05 09:00:06.189 270 270 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
08-05 09:00:06.189 270 270 D mali_so : current process is NOT sf, to bail out.
08-05 09:00:06.196 270 270 I ServiceManagement: Removing namespace from process name android.hardware.neuralnetworks@1.1-service-armnn to neuralnetworks@1.1-service-armnn.
08-05 09:00:06.248 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::startGraphicsAllocatorService retrieved: 0
08-05 09:00:06.251 278 278 I SurfaceFlinger: Using HWComposer service: ‘default’
08-05 09:00:06.251 278 278 I SurfaceFlinger: SurfaceFlinger is starting
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncEventPhaseOffsetNs retrieved: 1000000 (default)
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncSfEventPhaseOffsetNs retrieved: 1000000 (default)
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasSyncFramework retrieved: 1
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::presentTimeOffsetFromVSyncNs retrieved: 0
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useHwcForRGBtoYUV retrieved: 0
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxVirtualDisplaySize retrieved: 0 (default)
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useVrFlinger retrieved: 0 (default)
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3 (default)
08-05 09:00:06.253 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
08-05 09:00:06.255 278 278 I ConfigStore: android::hardware::configstore::V1_1::ISurfaceFlingerConfigs::primaryDisplayOrientation retrieved: ORIENTATION_0 (default)
08-05 09:00:06.255 278 278 I SurfaceFlinger: Disabling backpressure propagation
08-05 09:00:06.255 278 278 I SurfaceFlinger: Enabling HWC virtual displays
08-05 09:00:06.255 278 278 I SurfaceFlinger: Disabling Triple Buffering
08-05 09:00:06.255 278 278 I SurfaceFlinger: Treble testing override: ‘false’
08-05 09:00:06.255 278 278 I SurfaceFlinger: SurfaceFlinger’s main thread ready to run. Initializing graphics H/W…
08-05 09:00:06.255 278 278 I SurfaceFlinger: Phase offest NS: 1000000
08-05 09:00:06.286 278 278 D libEGL : loaded /vendor/lib64/egl/libGLES_mali.so
08-05 09:00:06.309 267 267 W hwc-drm-connector: DrmConnector init id=91,type=HDMI-A
08-05 09:00:06.313 278 278 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
08-05 09:00:06.313 278 278 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
08-05 09:00:06.313 278 278 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
08-05 09:00:06.313 278 278 I mali_so : cmdline : /system/bin/surfaceflinger, we should GO THROUGH patch_for_sf_memory_leak.
08-05 09:00:06.313 278 278 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 975; [Func] : base_context_deal_with_version_affairs_rk_ext;
08-05 09:00:06.313 278 278 I mali_so : arm_release_vers are match. to set the full mali_ver ‘r18p0-01rel0-x-16@0’ as value of ‘sys.gmali.version’.
08-05 09:00:06.320 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
08-05 09:00:06.320 278 278 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
08-05 09:00:06.320 278 278 I SurfaceFlinger: EGL information:
08-05 09:00:06.320 278 278 I SurfaceFlinger: vendor : Android
08-05 09:00:06.320 278 278 I SurfaceFlinger: version : 1.4 Android META-EGL
08-05 09:00:06.320 278 278 I SurfaceFlinger: extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_get_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_ANDROID_get_frame_timestamps EGL_EXT_surface_SMPTE2086_metadata EGL_EXT_surface_CTA861_3_metadata EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_colorspace EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_config_attribs EGL_KHR_surfaceless_context EGL_EXT_create_context_robustness EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_KHR_partial_update EGL_KHR_mutable_render_buffer EGL_IMG_context_priority
08-05 09:00:06.320 278 278 I SurfaceFlinger: Client API: OpenGL_ES
08-05 09:00:06.320 278 278 I SurfaceFlinger: EGLSurface: 8-8-8-8, config=0x7759529008
08-05 09:00:06.330 276 276 I FastMixerState: sMaxFastTracks = 8
08-05 09:00:06.332 278 278 I SurfaceFlinger: OpenGL ES informations:
08-05 09:00:06.332 278 278 I SurfaceFlinger: vendor : ARM
08-05 09:00:06.332 278 278 I SurfaceFlinger: renderer : Mali-T860
08-05 09:00:06.332 278 278 I SurfaceFlinger: version : OpenGL ES 3.2 v1.r18p0-01rel0.a9f1cb476cb31f09a55067fd0a0c2583
08-05 09:00:06.332 278 278 I SurfaceFlinger: extensions: GL_EXT_debug_marker GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth24 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_EXT_read_format_bgra GL_OES_compressed_paletted_texture GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_required_internalformat GL_OES_vertex_array_object GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_EXT_texture_type_2_10_10_10_REV GL_OES_fbo_render_mipmap GL_OES_element_index_uint GL_EXT_shadow_samplers GL_OES_texture_compression_astc GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_hdr GL_KHR_texture_compression_astc_sliced_3d GL_KHR_debug GL_EXT_occlusion_query_boolean GL_EXT_disjoint_timer_query GL_EXT_blend_minmax GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_OES_texture_3D GL_EXT_texture_storage GL_EXT_multisamp
08-05 09:00:06.332 278 278 I SurfaceFlinger: GL_MAX_TEXTURE_SIZE = 8192
08-05 09:00:06.332 278 278 I SurfaceFlinger: GL_MAX_VIEWPORT_DIMS = 8192
08-05 09:00:06.336 278 278 I ServiceManagement: getService: Trying again for android.hardware.graphics.composer@2.1::IComposer/default…
08-05 09:00:06.336 276 276 V MediaUtils: physMem: 1985019904
08-05 09:00:06.336 276 276 V MediaUtils: requested limit: 397003980
08-05 09:00:06.336 276 276 V MediaUtils: actual limit: 397003980
08-05 09:00:06.336 276 276 V MediaUtils: original limits: 4294967295/4294967295
08-05 09:00:06.336 276 276 V MediaUtils: new limits: 397003980/4294967295
08-05 09:00:06.337 276 276 I audioserver: ServiceManager: 0xf051c100
08-05 09:00:06.337 276 276 W BatteryNotifier: batterystats service unavailable!
08-05 09:00:06.340 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.audio@4.0::IDevicesFactory/msd in either framework or device manifest.
08-05 09:00:06.343 276 276 I AudioFlinger: Using default 3000 mSec as standby time.
08-05 09:00:06.347 276 276 E APM::Serializer: deserialize: Could not parse /odm/etc/audio_policy_configuration.xml document.
08-05 09:00:06.361 257 338 D AudioHardwareTiny: ALSA Audio Version: V1.1.0
08-05 09:00:06.362 257 338 D AudioHardwareTiny: adev_open: buf = 0 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
08-05 09:00:06.362 257 338 D AudioHardwareTiny: get_card_number: number =0,card_name = 0 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
08-05 09:00:06.386 257 338 D alsa_route: Get route table for sound card0 rockchiprk809co
08-05 09:00:06.386 257 338 D alsa_route: mMixerCard=0(rockchiprk809co)
08-05 09:00:06.386 257 338 D AudioHardwareTiny: adev_open: buf = rockchip,rk809-codec
08-05 09:00:06.386 257 338 D AudioHardwareTiny: adev_open: buf = 1 [rockchiphdmi ]: rockchip_hdmi - rockchip,hdmi
08-05 09:00:06.386 257 338 D AudioHardwareTiny: get_card_number: number =1,card_name = 1 [rockchiphdmi ]: rockchip_hdmi - rockchip,hdmi
08-05 09:00:06.408 257 338 D AudioHardwareTiny: adev_open: buf = rockchip,hdmi
08-05 09:00:06.408 257 338 D AudioHardwareTiny: adev_open: buf = 2 [rockchipcdndpso]: rockchip-cdndp- - rockchip-cdndp-sound
08-05 09:00:06.408 257 338 D AudioHardwareTiny: get_card_number: number =2,card_name = 2 [rockchipcdndpso]: rockchip-cdndp- - rockchip-cdndp-sound
08-05 09:00:06.428 257 338 D AudioHardwareTiny: adev_open: buf = rockchip-cdndp-sound
08-05 09:00:06.428 257 338 D AudioHardwareTiny: adev_open_init
08-05 09:00:06.429 257 338 W DeviceHAL: Error from HAL Device in function set_master_volume: Function not implemented
08-05 09:00:06.429 276 276 I AudioFlinger: loadHwModule() Loaded primary audio interface, handle 10
08-05 09:00:06.429 276 276 I AudioFlinger: openOutput() this 0xf053e000, module 10 Device 0x2, SamplingRate 48000, Format 0x000001, Channels 0x3, flags 0x2
08-05 09:00:06.429 257 338 D AudioHardwareTiny: audio hal adev_open_output_stream devices = 0x2, flags = 2, samplerate = 48000,format = 0x1
08-05 09:00:06.429 257 338 D AudioHardwareTiny: out->config.rate = 44100, out->config.channels = 2 out->config.format = 0,out->config.flag = 0
08-05 09:00:06.430 276 276 I AudioFlinger: HAL output buffer size 512 frames, normal sink buffer size 1024 frames
08-05 09:00:06.439 276 276 I BufferProvider: found effect “Multichannel Downmix To Stereo” from The Android Open Source Project
08-05 09:00:06.439 276 276 I AudioFlinger: Using module 10 as the primary audio interface
08-05 09:00:06.439 257 257 D AudioHardwareTiny: adev_set_mode: set_mode = 0
08-05 09:00:06.440 276 355 I AudioFlinger: AudioFlinger’s thread 0xefa83240 tid=355 ready to run
08-05 09:00:06.440 276 355 W AudioFlinger: no wake lock to update, system not ready yet
08-05 09:00:06.440 257 257 D AudioHardwareTiny: do_out_standby,out = 0xe74a9000,device = 0x2
08-05 09:00:06.441 276 276 W AudioFlinger: moveEffects() bad srcOutput 0
08-05 09:00:06.441 257 257 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=2
08-05 09:00:06.442 257 257 D AudioHardwareTiny: audio hal adev_open_input_stream devices = 0x80000004, flags = 0, config->samplerate = 48000,config->channel_mask = c
08-05 09:00:06.442 257 257 D AudioHardwareTiny: pcm_config->rate:44100,in->requested_rate:48000,in->channel_mask:2
08-05 09:00:06.443 257 257 D AudioHardwareTiny: in->mSpeexFrameSize:1120 in->requested_rate:48000
08-05 09:00:06.445 276 356 I AudioFlinger: AudioFlinger’s thread 0xef783040 tid=356 ready to run
08-05 09:00:06.445 257 257 D AudioHardwareTiny: adev_close_input_stream
08-05 09:00:06.456 276 276 I bt_a2dp_hw: adev_open: adev_open in A2dp_hw module
08-05 09:00:06.456 276 276 I AudioFlinger: loadHwModule() Loaded a2dp audio interface, handle 18
08-05 09:00:06.458 276 276 I AudioFlinger: loadHwModule() Loaded usb audio interface, handle 26
08-05 09:00:06.460 257 257 I r_submix: adev_open(name=audio_hw_if)
08-05 09:00:06.461 257 257 I r_submix: adev_init_check()
08-05 09:00:06.461 257 257 W DeviceHAL: Error from HAL Device in function set_master_mute: Function not implemented
08-05 09:00:06.461 276 276 I AudioFlinger: loadHwModule() Loaded r_submix audio interface, handle 34
08-05 09:00:06.461 257 257 D r_submix: adev_open_input_stream(addr=0)
08-05 09:00:06.461 257 257 D r_submix: submix_audio_device_create_pipe_l(addr=0, idx=9)
08-05 09:00:06.461 257 257 D r_submix: now using address 0 for route 9
08-05 09:00:06.462 276 357 I AudioFlinger: AudioFlinger’s thread 0xef783840 tid=357 ready to run
08-05 09:00:06.462 257 257 D r_submix: adev_close_input_stream()
08-05 09:00:06.462 257 257 D r_submix: submix_audio_device_destroy_pipe_l: shutting down MonoPipe
08-05 09:00:06.462 257 257 D r_submix: submix_audio_device_release_pipe_l(idx=9) addr=0
08-05 09:00:06.462 257 257 D r_submix: submix_audio_device_destroy_pipe_l(): pipe destroyed
08-05 09:00:06.463 276 276 I : Waiting for activity service
08-05 09:00:06.521 267 267 W hwc-drm-connector: DrmConnector init id=99,type=DP
08-05 09:00:06.522 267 267 W hwc-drm-connector: Could not get hdr source metadata property
08-05 09:00:06.522 267 267 W hwc-drm-connector: Could not get hdr panel metadata property
08-05 09:00:06.522 267 267 W hwc-drm-connector: Could not get hdmi_output_colorimetry property
08-05 09:00:06.522 267 267 W hwc-drm-connector: Could not get hdmi_output_format property
08-05 09:00:06.522 267 267 W hwc-drm-connector: Could not get hdmi_output_depth property
08-05 09:00:06.522 267 267 W hwc_rk : BP: DEVICE baseparameter is not ready,can’t use it !
08-05 09:00:06.522 267 267 E hwc-drm-resources: BP: hwc get baseparameter err
08-05 09:00:06.525 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.530 267 267 I chatty : uid=1000(system) composer@2.1-se identical 2 lines
08-05 09:00:06.533 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.534 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.534 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.535 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.537 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.537 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.538 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.539 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.539 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.540 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.542 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.542 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.543 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.545 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.545 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.546 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.547 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.547 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.548 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.551 267 267 I chatty : uid=1000(system) composer@2.1-se identical 1 line
08-05 09:00:06.553 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.555 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.555 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.556 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.557 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.558 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.558 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.560 267 267 E hwc-drm-plane: Could not get rotation property
08-05 09:00:06.560 267 267 I hwc-drm-plane: Could not get alpha property
08-05 09:00:06.561 267 267 E hwc-drm-plane: Could not get AREA_ID property
08-05 09:00:06.563 267 267 E hwc-drm-display-compositor: vop_bw: Error opening /sys/class/devfreq/dmc/vop_bandwidth: No such file or directory
08-05 09:00:06.564 267 267 E hwc-drm-display-compositor: vop_bw: Error opening /sys/class/devfreq/dmc/vop_bandwidth: No such file or directory
08-05 09:00:06.567 267 267 D hwc_rk : RK_GRAPHICS_VER=commit-id:538bfe4
08-05 09:00:06.567 267 267 I HWC2On1Adapter: Found support for HWC virtual displays
08-05 09:00:06.604 244 293 I Cryptfs : Extra parameters for dm_crypt: 1 allow_discards
08-05 09:00:06.607 244 249 D vold : Disk at 252:0 changed
08-05 09:00:06.778 267 267 I ServiceManagement: Removing namespace from process name android.hardware.graphics.composer@2.1-service to composer@2.1-service.
08-05 09:00:06.781 267 267 I android.hardware.graphics.composer@2.1-service: Registration complete for android.hardware.graphics.composer@2.1::IComposer/default.
08-05 09:00:06.788 278 278 E HWComposer: getSupportedPerFrameMetadata: getSupportedPerFrameMetadata failed for display 0: Unsupported (8)
08-05 09:00:06.789 278 278 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format , EGLBoolean) returns 0x3000
08-05 09:00:06.806 278 278 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
08-05 09:00:06.826 278 278 D : set stream to NULL
08-05 09:00:07.047 278 278 I chatty : uid=1000(system) /system/bin/surfaceflinger identical 70 lines
08-05 09:00:07.053 278 278 D : set stream to NULL
08-05 09:00:07.053 278 278 D SurfaceFlinger: shader cache generated - 24 shaders in 236.946243 ms
08-05 09:00:07.056 278 278 D SurfaceFlinger: Set power mode=2, type=0 flinger=0x7759458000
08-05 09:00:07.076 281 281 W npu_upgrade: type=1400 audit(0.0:201): avc: denied { write } for name=“/” dev=“tmpfs” ino=1111 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=
08-05 09:00:07.076 281 281 W npu_upgrade: type=1400 audit(0.0:202): avc: denied { add_name } for name=“npu.log” scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=
08-05 09:00:07.076 281 281 W npu_upgrade: type=1400 audit(0.0:203): avc: denied { create } for name=“npu.log” scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
08-05 09:00:07.076 281 281 W npu_upgrade: type=1400 audit(0.0:204): avc: denied { write open } for path=“/data/npu.log” dev=“tmpfs” ino=3009 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
08-05 09:00:07.093 386 386 W upgrade_tool: type=1400 audit(0.0:205): avc: denied { read } for name=“busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:07.180 278 278 D SurfaceFlinger: Finished set power mode=2, type=0
08-05 09:00:07.276 244 293 I Cryptfs : Password matches
08-05 09:00:07.277 244 293 D Cryptfs : test_mount_encrypted_fs(): Master key saved
08-05 09:00:07.279 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
08-05 09:00:07.281 244 293 I vold : List of Keymaster HALs found:
08-05 09:00:07.281 244 293 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
08-05 09:00:07.281 244 293 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
08-05 09:00:07.281 244 293 D Cryptfs : Password is default - restarting filesystem
08-05 09:00:07.297 244 293 D Cryptfs : unmounting /data succeeded
08-05 09:00:07.297 244 293 I vold : [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/dm-0
08-05 09:00:07.491 385 397 D libEGL : loaded /vendor/lib64/egl/libGLES_mali.so
08-05 09:00:07.522 385 397 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
08-05 09:00:07.522 385 397 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
08-05 09:00:07.522 385 397 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
08-05 09:00:07.522 385 397 I mali_so : cmdline : /system/bin/bootanimation, we should GO THROUGH patch_for_sf_memory_leak.
08-05 09:00:07.522 385 397 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
08-05 09:00:07.522 385 397 D mali_so : current process is NOT sf, to bail out.
08-05 09:00:07.530 385 397 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
08-05 09:00:07.530 385 397 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
08-05 09:00:07.531 385 397 D mali_winsys: EGLint new_window_surface(egl_winsys_display , void , EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
08-05 09:00:07.534 385 397 D BootAnimation: mVideoAnimation 11111= true
08-05 09:00:07.534 385 397 D BootAnimation: bootvideo:No boot video animation,EXIT_VIDEO_NAME:false,bootvideo.showtime:-1
08-05 09:00:07.535 385 397 D BootAnimation: BootAnimationShownTiming start time: 4708ms
08-05 09:00:07.581 385 397 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
08-05 09:00:07.597 278 278 I SurfaceFlinger: Enter boot animation
08-05 09:00:07.599 267 389 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
08-05 09:00:07.682 267 389 I rockchiprga: Rga built version:version:1.00
08-05 09:00:07.916 244 293 I vold : [libfs_mgr]__mount(source=/dev/block/dm-0,target=/data,type=f2fs)=0: Success
08-05 09:00:07.917 244 293 D Cryptfs : Just triggered post_fs_data
08-05 09:00:07.967 244 250 D vold : e4crypt_init_user0
08-05 09:00:07.967 244 250 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
08-05 09:00:07.967 244 250 D vold : Preparing: /data/system/users/0
08-05 09:00:07.968 244 250 D vold : Preparing: /data/misc/profiles/cur/0
08-05 09:00:07.968 244 250 D vold : Preparing: /data/system_de/0
08-05 09:00:07.968 244 250 D vold : Preparing: /data/misc_de/0
08-05 09:00:07.969 244 250 D vold : Preparing: /data/vendor_de/0
08-05 09:00:07.969 244 250 D vold : Preparing: /data/user_de/0
08-05 09:00:07.969 244 250 V vold : /system/bin/vold_prepare_subdirs
08-05 09:00:07.969 244 250 V vold : prepare
08-05 09:00:07.969 244 250 V vold : 0
08-05 09:00:07.969 244 250 V vold : 1
08-05 09:00:07.984 244 250 I vold_prepare_subdirs: SELinux: Loaded file_contexts
08-05 09:00:07.985 417 417 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_de/0/vold
08-05 09:00:07.986 417 417 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_de/0/storaged
08-05 09:00:07.987 417 417 D vold_prepare_subdirs: Setting up mode 700 uid 1000 gid 1000 context u:object_r:fingerprint_vendor_data_file:s0 on path: /data/vendor_de/0/fpdata
08-05 09:00:07.988 244 250 D vold : e4crypt_unlock_user_key 0 serial=0 token_present=0
08-05 09:00:08.000 418 418 I /system/bin/tzdatacheck: timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
08-05 09:00:08.005 244 293 D Cryptfs : post_fs_data done
08-05 09:00:08.006 244 293 D Cryptfs : Just triggered restart_framework
08-05 09:00:08.028 419 419 I bootstat: Service started: /system/bin/bootstat -r post_decrypt_time_elapsed
08-05 09:00:08.063 421 421 I AKMD2 : start in akmd
08-05 09:00:08.064 421 421 I AKMD2 : AKMD PG and DOEPlus v20140729 (Library for AK9911: v7.2.0.729.314) started.
08-05 09:00:08.064 421 421 I AKMD2 : Debug: ON
08-05 09:00:08.064 421 421 E AKMD2 : AKD_InitDevice:99 open Error (No such file or directory).
08-05 09:00:08.064 421 421 I AKMD2 : AKMD end (-2).
08-05 09:00:08.224 430 430 I mediaserver: ServiceManager: 0xea91c120
08-05 09:00:08.224 439 439 D DrmService: ----------------running drmservice---------------
08-05 09:00:08.224 439 439 E DrmService: rknand_sys_storage open fail
08-05 09:00:08.224 439 439 D DrmService: Get HID data:
08-05 09:00:08.246 422 422 W rild : type=1400 audit(0.0:214): avc: denied { read } for name=“u:object_r:default_prop:s0” dev=“tmpfs” ino=10111 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=f
08-05 09:00:08.246 422 422 W rild : type=1400 audit(0.0:215): avc: denied { open } for path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=10111 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=f
08-05 09:00:08.246 422 422 W rild : type=1400 audit(0.0:216): avc: denied { getattr } for path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=10111 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=f
08-05 09:00:08.252 428 428 I installd: installd firing up
08-05 09:00:08.257 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
08-05 09:00:08.260 429 429 I keystore: found android.hardware.keymaster@3.0::IKeymasterDevice with interface name default and seclevel SOFTWARE
08-05 09:00:08.260 429 429 W keystore: No secure Keymaster implementation found, but device offers insecure Keymaster HAL. Using as default.
08-05 09:00:08.280 440 440 W npu_monitor: type=1400 audit(0.0:217): avc: denied { read } for name=“temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
08-05 09:00:08.280 440 440 W npu_monitor: type=1400 audit(0.0:218): avc: denied { open } for path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
08-05 09:00:08.281 440 440 D RKNpuMonitor: ==== NPU Monitor start ====
08-05 09:00:08.281 440 440 D RKNpuMonitor: ==== gpu node = [coarse_demand] always_on ====
08-05 09:00:08.299 435 435 W statsd : statscompanion service unavailable!
08-05 09:00:08.300 435 435 I statsd : using statsd socket
08-05 09:00:08.304 439 439 E DrmService: vendor read:
08-05 09:00:08.304 439 439 E DrmService: 374d3053 52425a39 4547 0
08-05 09:00:08.304 439 439 E DrmService: 0 0 0 0
08-05 09:00:08.304 439 439 E DrmService: 0 e94bea60 e94bf380 e94bea90
08-05 09:00:08.304 439 439 E DrmService: e94bea64 15 e9200100 e9193208
08-05 09:00:08.305 439 439 E DrmService: 0 0 0 e95eda28
08-05 09:00:08.305 439 439 E DrmService: 0 e91562d3 e9183068 20
08-05 09:00:08.305 439 439 E DrmService: 0 e919c000 e9183068 0
08-05 09:00:08.305 439 439 E DrmService: e9159e14 e94995c1 6cee6c92 3
08-05 09:00:08.305 439 439 E DrmService: 6cef041a 3 e91a0000 e947b489
08-05 09:00:08.305 439 439 E DrmService: 7e489d47 e918400c 1000 0
08-05 09:00:08.305 439 439 E DrmService: ac964058 ffdcb254 7e489d47 ffdcb24c
08-05 09:00:08.305 439 439 E DrmService: ffdcb1b8 1 ffdcb48c ac9629d7
08-05 09:00:08.305 439 439 E DrmService: ac964058 0 0 e9436cf7
08-05 09:00:08.305 439 439 E DrmService: 642f0001 732f7665 656b636f 72702f74
08-05 09:00:08.305 439 439 E DrmService: 7265706f 735f7974 69767265 6563
08-05 09:00:08.305 439 439 E DrmService: 0 0 0 0
08-05 09:00:08.305 439 439 I chatty : uid=0(root) /vendor/bin/rockchip.drmservice identical 2 lines
08-05 09:00:08.305 439 439 E DrmService: 0 0 0 100
08-05 09:00:08.305 439 439 E DrmService: ffdcb254 ffdcb2d4 0 0
08-05 09:00:08.305 439 439 E DrmService: 0 e9436bd5 100 0
08-05 09:00:08.305 439 439 E DrmService: 0 5 0 ffdcb24c
08-05 09:00:08.305 439 439 E DrmService: ffdcb29c 4 ffdcb2a0 4
08-05 09:00:08.305 439 439 E DrmService: ac9629d7 f ffdcb2a4 4
08-05 09:00:08.305 439 439 E DrmService: ac964058 a ac964058 ac9624bf
08-05 09:00:08.305 439 439 E DrmService: e9193200 e9193208 ffdcb48c 0
08-05 09:00:08.305 439 439 E DrmService: 0 20001 f a
08-05 09:00:08.305 439 439 E DrmService: 7e489d47 ac964058 5 ac9620f8
08-05 09:00:08.305 439 439 E DrmService: ac9625f8 0 a ac964058
08-05 09:00:08.305 439 439 E DrmService: 7e489d47 ac964058 e988b4ec ac9620f8
08-05 09:00:08.305 439 439 E DrmService: ac964058 ac961733 ac9626f0 e94a3e1b
08-05 09:00:08.305 439 439 E DrmService: cafd74e b59c00f8 b59c043a b59c043a
08-05 09:00:08.305 439 439 D DrmService: vendor read sn_buf_idb:S0M79ZBRGE
08-05 09:00:08.321 442 442 I gatekeeperd: Starting gatekeeperd…
08-05 09:00:08.325 442 442 I ServiceManagement: getService: Trying again for android.hardware.gatekeeper@1.0::IGatekeeper/default…
08-05 09:00:08.326 439 439 E DrmService: Unable to open path (/sys/class/android_usb/android0/iSerial),error is(No such file or directory)
08-05 09:00:08.326 439 439 E DrmService: try /config/usb_gadget/g1/strings/0x409/serialnumber
08-05 09:00:08.326 439 439 D DrmService: get serialno from idb,serialno = S0M79ZBRGE
08-05 09:00:08.327 439 439 E DrmService: ------detect not SecureBoot—
08-05 09:00:08.338 445 445 I /system/bin/tombstoned: tombstoned successfully initialized
08-05 09:00:08.377 432 432 I mediametrics: ServiceManager: 0x7f2183d740
08-05 09:00:08.377 432 432 D MediaAnalyticsService: MediaAnalyticsService created
08-05 09:00:08.393 437 437 I wificond: wificond is starting up…
08-05 09:00:08.408 431 431 V MediaUtils: physMem: 1986285568
08-05 09:00:08.408 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.usb.gadget@1.0::IUsbGadget/default in either framework or device manifest.
08-05 09:00:08.408 431 431 V MediaUtils: requested limit: 397257100
08-05 09:00:08.408 431 431 V MediaUtils: cfi shadow size: 2147483648
08-05 09:00:08.408 431 431 V MediaUtils: actual limit: 2544740748
08-05 09:00:08.408 431 431 V MediaUtils: original limits: -1/-1
08-05 09:00:08.408 431 431 V MediaUtils: new limits: 2544740748/-1
08-05 09:00:08.409 446 446 I usbd : Usb HAL not found
08-05 09:00:08.415 431 431 W /system/bin/mediaextractor: Could not read additional policy file ‘/vendor/etc/seccomp_policy/mediaextractor.policy’
08-05 09:00:08.416 431 431 W mediaextractor: libminijail[431]: failed to get path of fd 5: No such file or directory
08-05 09:00:08.416 431 431 W mediaextractor: libminijail[431]: allowing syscall: connect
08-05 09:00:08.416 431 431 W mediaextractor: libminijail[431]: allowing syscall: fcntl
08-05 09:00:08.416 431 431 W mediaextractor: libminijail[431]: allowing syscall: sendto
08-05 09:00:08.416 431 431 W mediaextractor: libminijail[431]: allowing syscall: socket
08-05 09:00:08.416 431 431 W mediaextractor: libminijail[431]: allowing syscall: writev
08-05 09:00:08.417 424 424 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
08-05 09:00:08.417 431 431 W mediaextractor: libminijail[431]: logging seccomp filter failures
08-05 09:00:08.441 424 424 I zygote : option[0]=-Xzygote
08-05 09:00:08.441 424 424 I zygote : option[1]=-Xusetombstonedtraces
08-05 09:00:08.441 424 424 I zygote : option[2]=exit
08-05 09:00:08.441 424 424 I zygote : option[3]=vfprintf
08-05 09:00:08.441 424 424 I zygote : option[4]=sensitiveThread
08-05 09:00:08.441 424 424 I zygote : option[5]=-verbose:gc
08-05 09:00:08.442 424 424 I zygote : option[6]=-Xms16m
08-05 09:00:08.442 424 424 I zygote : option[7]=-Xmx512m
08-05 09:00:08.442 424 424 I zygote : option[8]=-XX:HeapGrowthLimit=192m
08-05 09:00:08.442 424 424 I zygote : option[9]=-XX:HeapMinFree=512k
08-05 09:00:08.442 424 424 I zygote : option[10]=-XX:HeapMaxFree=8m
08-05 09:00:08.442 424 424 I zygote : option[11]=-XX:HeapTargetUtilization=0.75
08-05 09:00:08.442 424 424 I zygote : option[12]=-Xusejit:true
08-05 09:00:08.442 424 424 I zygote : option[13]=-Xjitsaveprofilinginfo
08-05 09:00:08.442 424 424 I zygote : option[14]=-XjdwpOptions:suspend=n,server=y
08-05 09:00:08.442 424 424 I zygote : option[15]=-XjdwpProvider:default
08-05 09:00:08.442 424 424 I zygote : option[16]=-Xlockprofthreshold:500
08-05 09:00:08.442 424 424 I zygote : option[17]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[18]=–runtime-arg
08-05 09:00:08.442 424 424 I zygote : option[19]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[20]=-Xms64m
08-05 09:00:08.442 424 424 I zygote : option[21]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[22]=–runtime-arg
08-05 09:00:08.442 424 424 I zygote : option[23]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[24]=-Xmx64m
08-05 09:00:08.442 424 424 I zygote : option[25]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[26]=–profile-file=/system/etc/boot-image.prof
08-05 09:00:08.442 424 424 I zygote : option[27]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[28]=–compiler-filter=speed-profile
08-05 09:00:08.442 424 424 I zygote : option[29]=-Xcompiler-option
08-05 09:00:08.442 424 424 I zygote : option[30]=–runtime-arg
08-05 09:00:08.442 424 424 I zygote : option[31]=-Xcompiler-option
08-05 09:00:08.442 424 424 I zygote : option[32]=-Xms64m
08-05 09:00:08.442 424 424 I zygote : option[33]=-Xcompiler-option
08-05 09:00:08.442 424 424 I zygote : option[34]=–runtime-arg
08-05 09:00:08.442 424 424 I zygote : option[35]=-Xcompiler-option
08-05 09:00:08.442 424 424 I zygote : option[36]=-Xmx512m
08-05 09:00:08.442 424 424 I zygote : option[37]=-Ximage-compiler-option
08-05 09:00:08.442 424 424 I zygote : option[38]=–instruction-set-variant=cortex-a15
08-05 09:00:08.442 424 424 I zygote : option[39]=-Xcompiler-option
08-05 09:00:08.442 424 424 I zygote : option[40]=–instruction-set-variant=cortex-a15
08-05 09:00:08.442 424 424 I zygote : option[41]=-Ximage-compiler-option
08-05 09:00:08.443 424 424 I zygote : option[42]=–instruction-set-features=default
08-05 09:00:08.443 424 424 I zygote : option[43]=-Xcompiler-option
08-05 09:00:08.443 424 424 I zygote : option[44]=–instruction-set-features=default
08-05 09:00:08.443 424 424 I zygote : option[45]=-Duser.locale=en-US
08-05 09:00:08.443 424 424 I zygote : option[46]=–cpu-abilist=armeabi-v7a,armeabi
08-05 09:00:08.443 424 424 I zygote : option[47]=-Xfingerprint:rockchip/rk3399pro_firefly_aioc/rk3399pro:9/PQ3B.190705.003/root09161442:userdebug/test-keys
08-05 09:00:08.450 434 434 I Netd : Netd 1.0 starting
08-05 09:00:08.454 434 434 D TetherController: Setting IP forward enable = 0
08-05 09:00:08.457 424 424 I zygote : VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm --instruction-set=arm --verify
08-05 09:00:08.490 434 434 I Netd : Creating child chains: 28.5ms
08-05 09:00:08.490 434 434 I Netd : Setting up OEM hooks: 0.3ms
08-05 09:00:08.496 438 438 I media.codec: mediacodecservice starting
08-05 09:00:08.497 438 438 W media.codec: Could not read additional policy file ‘/vendor/etc/seccomp_policy/mediacodec.policy’
08-05 09:00:08.497 438 438 W media.codec: libminijail[438]: failed to get path of fd 5: No such file or directory
08-05 09:00:08.497 438 438 W media.codec: libminijail[438]: allowing syscall: clock_gettime
08-05 09:00:08.497 438 438 W media.codec: libminijail[438]: allowing syscall: connect
08-05 09:00:08.497 438 438 W media.codec: libminijail[438]: allowing syscall: fcntl64
08-05 09:00:08.497 438 438 W media.codec: libminijail[438]: allowing syscall: socket
08-05 09:00:08.497 438 438 W media.codec: libminijail[438]: allowing syscall: writev
08-05 09:00:08.497 434 434 I Netd : Setting up FirewallController hooks: 7.6ms
08-05 09:00:08.498 438 438 W media.codec: libminijail[438]: logging seccomp filter failures
08-05 09:00:08.502 434 434 I Netd : Setting up TetherController hooks: 4.1ms
08-05 09:00:08.504 438 438 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
08-05 09:00:08.504 438 438 W MediaCodecsXmlParser: parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
08-05 09:00:08.504 438 438 E MediaCodecsXmlParser: Cannot find the role for a decoder of type video/mjpeg
08-05 09:00:08.504 438 438 I ServiceManagement: Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
08-05 09:00:08.506 434 434 I Netd : Setting up BandwidthController hooks: 4.8ms
08-05 09:00:08.506 434 434 I Netd : Setting up IdletimerController hooks: 0.1ms
08-05 09:00:08.506 434 434 I Netd : initializing traffic control: 0.0ms
08-05 09:00:08.515 434 434 I Netd : Disabling bandwidth control: 8.4ms
08-05 09:00:08.518 434 434 E Netd : cannot find interface dummy0
08-05 09:00:08.519 434 434 I Netd : Initializing RouteController: 3.7ms
08-05 09:00:08.519 434 434 D XfrmController: Sending Netlink XFRM Message: XFRM_MSG_FLUSHSA
08-05 09:00:08.519 434 434 D XfrmController: Sending Netlink XFRM Message: XFRM_MSG_FLUSHPOLICY
08-05 09:00:08.519 434 434 I Netd : Initializing XfrmController: 0.4ms
08-05 09:00:08.520 434 434 E Netd : Unable to create netlink socket: Protocol not supported
08-05 09:00:08.520 434 434 W Netd : Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler
08-05 09:00:08.523 438 438 I vpu_api : dlopen vpu lib /vendor/lib/librk_vpuapi.so success
08-05 09:00:08.524 434 434 D MDnsDS : MDnsSdListener::Hander starting up
08-05 09:00:08.525 434 484 D MDnsDS : MDnsSdListener starting to monitor
08-05 09:00:08.525 434 484 D MDnsDS : Going to poll with pollCount 1
08-05 09:00:08.526 434 434 I Netd : Registering NetdNativeService: 2.2ms
08-05 09:00:08.527 434 434 I Netd : Starting CommandListener: 1.0ms
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.h263
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.flv1
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp9
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vc1
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.wmv3
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.mjpeg
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.avc
08-05 09:00:08.528 438 438 I libstagefrighthw: OMX IL core libOMX_Core.so: contains 12 components
08-05 09:00:08.529 438 438 E vndksupport: Could not load libffmpeg_omx.so from default namespace: dlopen failed: library “libffmpeg_omx.so” not found.
08-05 09:00:08.532 438 438 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
08-05 09:00:08.532 438 438 W MediaCodecsXmlParser: parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
08-05 09:00:08.532 434 434 I Netd : Registering NetdHwService: 5.2ms
08-05 09:00:08.532 434 434 I Netd : Netd started in 83ms
08-05 09:00:08.532 438 438 I ServiceManagement: Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
08-05 09:00:08.534 438 438 I media.codec: IOmx HAL service created.
08-05 09:00:08.537 423 423 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
08-05 09:00:08.564 423 423 I zygote64: option[0]=-Xzygote
08-05 09:00:08.564 423 423 I zygote64: option[1]=-Xusetombstonedtraces
08-05 09:00:08.564 423 423 I zygote64: option[2]=exit
08-05 09:00:08.564 423 423 I zygote64: option[3]=vfprintf
08-05 09:00:08.564 423 423 I zygote64: option[4]=sensitiveThread
08-05 09:00:08.564 423 423 I zygote64: option[5]=-verbose:gc
08-05 09:00:08.565 423 423 I zygote64: option[6]=-Xms16m
08-05 09:00:08.565 423 423 I zygote64: option[7]=-Xmx512m
08-05 09:00:08.565 423 423 I zygote64: option[8]=-XX:HeapGrowthLimit=192m
08-05 09:00:08.565 423 423 I zygote64: option[9]=-XX:HeapMinFree=512k
08-05 09:00:08.565 423 423 I zygote64: option[10]=-XX:HeapMaxFree=8m
08-05 09:00:08.565 423 423 I zygote64: option[11]=-XX:HeapTargetUtilization=0.75
08-05 09:00:08.565 423 423 I zygote64: option[12]=-Xusejit:true
08-05 09:00:08.565 423 423 I zygote64: option[13]=-Xjitsaveprofilinginfo
08-05 09:00:08.565 423 423 I zygote64: option[14]=-XjdwpOptions:suspend=n,server=y
08-05 09:00:08.565 423 423 I zygote64: option[15]=-XjdwpProvider:default
08-05 09:00:08.565 423 423 I zygote64: option[16]=-Xlockprofthreshold:500
08-05 09:00:08.565 423 423 I zygote64: option[17]=-Ximage-compiler-option
08-05 09:00:08.565 423 423 I zygote64: option[18]=–runtime-arg
08-05 09:00:08.565 423 423 I zygote64: option[19]=-Ximage-compiler-option
08-05 09:00:08.565 423 423 I zygote64: option[20]=-Xms64m
08-05 09:00:08.565 423 423 I zygote64: option[21]=-Ximage-compiler-option
08-05 09:00:08.566 423 423 I zygote64: option[22]=–runtime-arg
08-05 09:00:08.566 423 423 I zygote64: option[23]=-Ximage-compiler-option
08-05 09:00:08.566 423 423 I zygote64: option[24]=-Xmx64m
08-05 09:00:08.566 423 423 I zygote64: option[25]=-Ximage-compiler-option
08-05 09:00:08.566 423 423 I zygote64: option[26]=–profile-file=/system/etc/boot-image.prof
08-05 09:00:08.566 423 423 I zygote64: option[27]=-Ximage-compiler-option
08-05 09:00:08.566 423 423 I zygote64: option[28]=–compiler-filter=speed-profile
08-05 09:00:08.566 423 423 I zygote64: option[29]=-Xcompiler-option
08-05 09:00:08.566 423 423 I zygote64: option[30]=–runtime-arg
08-05 09:00:08.566 423 423 I zygote64: option[31]=-Xcompiler-option
08-05 09:00:08.566 423 423 I zygote64: option[32]=-Xms64m
08-05 09:00:08.566 423 423 I zygote64: option[33]=-Xcompiler-option
08-05 09:00:08.566 423 423 I zygote64: option[34]=–runtime-arg
08-05 09:00:08.566 423 423 I zygote64: option[35]=-Xcompiler-option
08-05 09:00:08.566 423 423 I zygote64: option[36]=-Xmx512m
08-05 09:00:08.566 423 423 I zygote64: option[37]=-Ximage-compiler-option
08-05 09:00:08.566 423 423 I zygote64: option[38]=–instruction-set-variant=cortex-a53
08-05 09:00:08.566 423 423 I zygote64: option[39]=-Xcompiler-option
08-05 09:00:08.566 423 423 I zygote64: option[40]=–instruction-set-variant=cortex-a53
08-05 09:00:08.566 423 423 I zygote64: option[41]=-Ximage-compiler-option
08-05 09:00:08.566 423 423 I zygote64: option[42]=–instruction-set-features=default
08-05 09:00:08.567 423 423 I zygote64: option[43]=-Xcompiler-option
08-05 09:00:08.567 423 423 I zygote64: option[44]=–instruction-set-features=default
08-05 09:00:08.567 423 423 I zygote64: option[45]=-Duser.locale=en-US
08-05 09:00:08.567 423 423 I zygote64: option[46]=–cpu-abilist=arm64-v8a
08-05 09:00:08.567 423 423 I zygote64: option[47]=-Xfingerprint:rockchip/rk3399pro_firefly_aioc/rk3399pro:9/PQ3B.190705.003/root09161442:userdebug/test-keys
08-05 09:00:08.576 425 425 I cameraserver: ServiceManager: 0xe719c100
08-05 09:00:08.576 425 425 I CameraService: CameraService started (pid=425)
08-05 09:00:08.576 425 425 I CameraService: CameraService process starting
08-05 09:00:08.576 425 425 W BatteryNotifier: batterystats service unavailable!
08-05 09:00:08.579 433 433 I mediaserver: ServiceManager: 0xe6b9c1c0
08-05 09:00:08.580 425 425 I CameraProviderManager: Connecting to new camera provider: legacy/0, isRemote? 1
08-05 09:00:08.580 425 425 I CameraProviderManager: Enumerating new camera device: device@3.3/legacy/0
08-05 09:00:08.584 260 495 D RkCamera: Debug log file is not enabled
08-05 09:00:08.585 433 433 W BatteryNotifier: batterystats service unavailable!
08-05 09:00:08.585 425 425 I CameraProviderManager: Camera provider legacy/0 ready with 1 camera devices
08-05 09:00:08.587 425 425 I CameraProviderManager: Connecting to new camera provider: external/0, isRemote? 1
08-05 09:00:08.588 425 425 I CameraProviderManager: Camera provider external/0 ready with 0 camera devices
08-05 09:00:08.588 425 493 W CameraProviderManager: addProviderLocked: Camera provider HAL with name ‘external/0’ already registered
08-05 09:00:08.589 425 425 I CameraService: onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
08-05 09:00:08.589 425 425 I CameraService: onDeviceStatusChanged: Unknown camera ID 0, a new camera is added
08-05 09:00:08.589 425 493 I CameraService: onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
08-05 09:00:08.590 425 493 W CameraProviderManager: addProviderLocked: Camera provider HAL with name ‘legacy/0’ already registered
08-05 09:00:08.590 425 425 I : Waiting for activity service
08-05 09:00:08.591 425 493 I CameraService: onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
08-05 09:00:08.591 425 493 E CameraService: onDeviceStatusChanged: State transition to the same status 0x1 not allowed
08-05 09:00:08.603 423 423 I zygote64: VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm64 --instruction-set=arm64 --verify
08-05 09:00:08.627 499 499 W patchoat: Could not reserve sentinel fault page
08-05 09:00:09.134 424 424 I zygote : Explicit concurrent copying GC freed 178(9KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 95us total 5.694ms
08-05 09:00:09.139 424 424 I zygote : Explicit concurrent copying GC freed 5(32KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 84us total 4.847ms
08-05 09:00:09.139 424 424 D Zygote32Timing: PostZygoteInitGC took to complete: 12ms
08-05 09:00:09.139 424 424 D Zygote32Timing: ZygoteInit took to complete: 13ms
08-05 09:00:09.156 424 424 I Zygote : Accepting command socket connections
08-05 09:00:09.200 423 423 D Zygote : begin preload
08-05 09:00:09.201 423 423 I Zygote : Installing ICU cache reference pinning…
08-05 09:00:09.201 423 423 I Zygote : Preloading ICU data…
08-05 09:00:09.228 423 423 D Zygote64Timing: BeginIcuCachePinning took to complete: 27ms
08-05 09:00:09.228 423 423 I Zygote : Preloading classes…
08-05 09:00:09.249 423 423 I PackageBackwardCompatibility: Loaded android.content.pm.OrgApacheHttpLegacyUpdater
08-05 09:00:09.250 423 423 I PackageBackwardCompatibility: Could not find android.content.pm.AndroidTestBaseUpdater, ignoring
08-05 09:00:09.294 436 463 I ServiceManager: Waiting for service package_native…
08-05 09:00:09.325 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
08-05 09:00:09.639 423 423 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. class_init is effectively a no-op
08-05 09:00:09.693 423 423 I zygote64: Thread[1,tid=423,Native,Thread=0x7c0f014c00,peer=0x12c01d88,“main”] recursive attempt to load library “/system/lib64/libmedia_jni.so”
08-05 09:00:09.693 423 423 D MtpDeviceJNI: register_android_mtp_MtpDevice
08-05 09:00:09.843 423 423 I Zygote : …preloaded 6535 classes in 614ms.
08-05 09:00:09.843 423 423 I zygote64: VMRuntime.preloadDexCaches starting
08-05 09:00:09.878 423 423 I zygote64: VMRuntime.preloadDexCaches strings total=339863 before=12300 after=12300
08-05 09:00:09.878 423 423 I zygote64: VMRuntime.preloadDexCaches types total=31370 before=7826 after=7827
08-05 09:00:09.878 423 423 I zygote64: VMRuntime.preloadDexCaches fields total=141122 before=9172 after=9172
08-05 09:00:09.878 423 423 I zygote64: VMRuntime.preloadDexCaches methods total=248070 before=12783 after=12783
08-05 09:00:09.878 423 423 I zygote64: VMRuntime.preloadDexCaches finished
08-05 09:00:09.878 423 423 D Zygote64Timing: PreloadClasses took to complete: 650ms
08-05 09:00:10.043 510 510 W upgrade_tool: type=1400 audit(0.0:227): avc: denied { read } for name=“busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:10.043 510 510 W upgrade_tool: type=1400 audit(0.0:228): avc: denied { open } for path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.12.auto/usb3/busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:10.043 510 510 W upgrade_tool: type=1400 audit(0.0:229): avc: denied { getattr } for path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.12.auto/usb3/busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:10.066 423 423 I Zygote : Preloading resources…
08-05 09:00:10.083 423 423 W Resources: Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
08-05 09:00:10.108 423 423 I Zygote : …preloaded 64 resources in 42ms.
08-05 09:00:10.112 423 423 I Zygote : …preloaded 41 resources in 5ms.
08-05 09:00:10.112 423 423 D Zygote64Timing: PreloadResources took to complete: 235ms
08-05 09:00:10.140 423 423 D libEGL : loaded /vendor/lib64/egl/libGLES_mali.so
08-05 09:00:10.156 423 423 I Zygote : Preloading shared libraries…
08-05 09:00:10.165 423 423 I Zygote : Uninstalled ICU cache reference pinning…
08-05 09:00:10.166 423 423 I Zygote : Installed AndroidKeyStoreProvider in 1ms.
08-05 09:00:10.173 423 423 I Zygote : Warmed up JCA providers in 7ms.
08-05 09:00:10.173 423 423 D Zygote : end preload
08-05 09:00:10.173 423 423 D Zygote64Timing: ZygotePreload took to complete: 972ms
08-05 09:00:10.200 423 423 I zygote64: Explicit concurrent copying GC freed 59552(5MB) AllocSpace objects, 165(3MB) LOS objects, 50% free, 2MB/4MB, paused 67us total 27.311ms
08-05 09:00:10.225 423 423 I zygote64: Explicit concurrent copying GC freed 6486(228KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 2MB/4MB, paused 36us total 18.101ms
08-05 09:00:10.225 423 423 D Zygote64Timing: PostZygoteInitGC took to complete: 52ms
08-05 09:00:10.225 423 423 D Zygote64Timing: ZygoteInit took to complete: 1025ms
08-05 09:00:10.286 423 423 I Zygote : System server process 512 has been created
08-05 09:00:10.287 512 512 I Zygote : seccomp disabled by setenforce 0
08-05 09:00:10.288 423 423 I Zygote : Accepting command socket connections
08-05 09:00:10.297 436 463 I ServiceManager: Waiting for service package_native…
08-05 09:00:10.297 512 512 I Zygote : Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
08-05 09:00:10.316 512 512 I system_server: The ClassLoaderContext is a special shared library.
08-05 09:00:10.326 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
08-05 09:00:10.326 512 512 I system_server: The ClassLoaderContext is a special shared library.
08-05 09:00:10.328 512 512 I chatty : uid=1000 system_server identical 1 line
08-05 09:00:10.330 512 512 I system_server: The ClassLoaderContext is a special shared library.
08-05 09:00:10.351 512 512 I SystemServer: InitBeforeStartServices
08-05 09:00:10.352 512 512 I SystemServer: Entered the Android system server!
08-05 09:00:10.370 281 281 W npu_upgrade: type=1400 audit(0.0:230): avc: denied { append } for name=“npu.log” dev=“dm-0” ino=1919 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
08-05 09:00:10.370 281 281 W npu_upgrade: type=1400 audit(0.0:231): avc: denied { open } for path=“/data/npu.log” dev=“dm-0” ino=1919 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
08-05 09:00:10.510 512 512 E UsbAlsaJackDetectorJNI: Can’t register UsbAlsaJackDetector native methods
08-05 09:00:10.534 512 512 D SystemServerTiming: InitBeforeStartServices took to complete: 183ms
08-05 09:00:10.534 512 512 I SystemServer: StartServices
08-05 09:00:10.534 512 512 I SystemServer: Reading configuration…
08-05 09:00:10.534 512 512 I SystemServer: ReadingSystemConfig
08-05 09:00:10.534 512 512 D SystemServerTiming: ReadingSystemConfig took to complete: 1ms
08-05 09:00:10.535 512 512 I SystemServer: StartInstaller
08-05 09:00:10.535 512 512 I SystemServiceManager: Starting com.android.server.pm.Installer
08-05 09:00:10.535 512 527 D SystemServerInitThreadPool: Started executing ReadingSystemConfig
08-05 09:00:10.541 428 452 D installd: Found quota mount /dev/block/dm-0 at /data
08-05 09:00:10.542 512 512 D SystemServerTiming: StartInstaller took to complete: 7ms
08-05 09:00:10.542 512 512 I SystemServer: DeviceIdentifiersPolicyService
08-05 09:00:10.542 512 512 I SystemServiceManager: Starting com.android.server.os.DeviceIdentifiersPolicyService
08-05 09:00:10.543 512 512 D SystemServerTiming: DeviceIdentifiersPolicyService took to complete: 1ms
08-05 09:00:10.543 512 512 I SystemServer: StartActivityManager
08-05 09:00:10.543 512 512 I SystemServiceManager: Starting com.android.server.am.ActivityManagerService$Lifecycle
08-05 09:00:10.566 512 527 D SystemServerInitThreadPool: Finished executing ReadingSystemConfig
08-05 09:00:10.568 512 512 I ActivityManager: Memory class: 192
08-05 09:00:10.592 512 512 D BatteryStatsImpl: Reading daily items from /data/system/batterystats-daily.xml
08-05 09:00:10.599 512 533 E BluetoothAdapter: Bluetooth binder is null
08-05 09:00:10.609 512 533 E BatteryExternalStatsWorker: no controller energy info supplied for telephony
08-05 09:00:10.611 512 533 I KernelUidCpuFreqTimeReader: mPerClusterTimesAvailable=false
08-05 09:00:10.617 512 533 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/time_in_state
08-05 09:00:10.617 512 533 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/concurrent_active_time
08-05 09:00:10.618 512 533 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/concurrent_policy_time
08-05 09:00:10.621 512 533 I PowerManagerService-JNI: Loaded power HAL 1.0 service
08-05 09:00:10.662 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.memtrack@1.0::IMemtrack/default in either framework or device manifest.
08-05 09:00:10.662 512 512 E memtrack: Couldn’t load memtrack module
08-05 09:00:10.663 512 512 W android.os.Debug: failed to get memory consumption info: -1
08-05 09:00:10.667 512 512 W AppOps : Unknown attribute in ‘op’ tag: n
08-05 09:00:10.669 512 512 I chatty : uid=1000 system_server identical 73 lines
08-05 09:00:10.669 512 512 W AppOps : Unknown attribute in ‘op’ tag: n
08-05 09:00:10.682 512 512 I IntentFirewall: Read new rules (A:0 B:0 S:0)
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_208: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_244: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_256: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_277: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_280: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_281: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_282: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_422: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_423: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_424: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_428: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_434: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_436: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_440: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_441: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0/pid_443: Device or resource busy
08-05 09:00:10.689 512 512 W libprocessgroup: Failed to remove /acct/uid_0: Permission denied
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_235: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_236: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_237: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_243: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_255: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_262: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_266: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_267: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_268: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_269: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_270: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_271: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_272: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_273: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_275: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_278: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_279: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000/pid_442: Device or resource busy
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1000: Permission denied
08-05 09:00:10.690 512 512 W libprocessgroup: Failed to remove /acct/uid_1002/pid_258: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1002: Permission denied
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1003/pid_385: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1003: Permission denied
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1010/pid_274: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1010/pid_437: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1010: Permission denied
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_261: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_263: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_264: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_265: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_430: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_432: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013/pid_433: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1013: Permission denied
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1017/pid_429: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1017: Permission denied
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1019/pid_426: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1019: Permission denied
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1020/pid_303: Device or resource busy
08-05 09:00:10.691 512 512 W libprocessgroup: Failed to remove /acct/uid_1020: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1036/pid_234: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1036: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1040/pid_431: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1040: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1041/pid_257: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1041/pid_276: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1041: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1046/pid_438: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1046: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1047/pid_259: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1047/pid_260: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1047/pid_425: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1047: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1058/pid_445: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1058: Permission denied
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1066/pid_435: Device or resource busy
08-05 09:00:10.692 512 512 W libprocessgroup: Failed to remove /acct/uid_1066: Permission denied
08-05 09:00:10.693 512 512 W libprocessgroup: Failed to remove /acct/uid_1067/pid_427: Device or resource busy
08-05 09:00:10.693 512 512 W libprocessgroup: Failed to remove /acct/uid_1067: Permission denied
08-05 09:00:10.693 512 512 W libprocessgroup: Failed to remove /acct/uid_2000/pid_284: Device or resource busy
08-05 09:00:10.693 512 512 W libprocessgroup: Failed to remove /acct/uid_2000: Permission denied
08-05 09:00:10.694 512 512 D AppOps : AppOpsService published
08-05 09:00:10.694 512 512 D SystemServerTiming: StartActivityManager took to complete: 151ms
08-05 09:00:10.694 512 512 I SystemServer: StartPowerManager
08-05 09:00:10.694 512 512 I SystemServiceManager: Starting com.android.server.power.PowerManagerService
08-05 09:00:10.703 512 512 D SystemServerTiming: StartPowerManager took to complete: 9ms
08-05 09:00:10.703 512 512 I SystemServer: InitPowerManagement
08-05 09:00:10.704 512 512 D SystemServerTiming: InitPowerManagement took to complete: 1ms
08-05 09:00:10.704 512 512 I SystemServer: StartRecoverySystemService
08-05 09:00:10.704 512 512 I SystemServiceManager: Starting com.android.server.RecoverySystemService
08-05 09:00:10.710 512 512 D SystemServerTiming: StartRecoverySystemService took to complete: 6ms
08-05 09:00:10.716 512 512 W RescueParty: Noticed 1 events for UID 0 in last 7 sec
08-05 09:00:10.716 512 512 I SystemServer: StartLightsService
08-05 09:00:10.716 512 512 I SystemServiceManager: Starting com.android.server.lights.LightsService
08-05 09:00:10.718 512 512 D SystemServerTiming: StartLightsService took to complete: 2ms
08-05 09:00:10.718 512 512 I SystemServer: StartSidekickService
08-05 09:00:10.718 512 512 D SystemServerTiming: StartSidekickService took to complete: 0ms
08-05 09:00:10.718 512 512 I SystemServer: StartDisplayManager
08-05 09:00:10.718 512 512 I SystemServiceManager: Starting com.android.server.display.DisplayManagerService
08-05 09:00:10.725 512 512 D SystemServerTiming: StartDisplayManager took to complete: 7ms
08-05 09:00:10.725 512 512 I SystemServer: WaitForDisplay
08-05 09:00:10.725 512 512 I SystemServiceManager: Starting phase 100
08-05 09:00:10.734 512 537 I DisplayManagerService: Display device added: DisplayDeviceInfo{“Built-in Screen”: uniqueId=“local:0”, 1280 x 720, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1280, height=720, fps=60.000004}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@40f16308, density 280, 213.0 x 213.0 dpi, appVsyncOff 1000000, presDeadline 16666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
08-05 09:00:10.735 278 278 D SurfaceFlinger: Set power mode=2, type=0 flinger=0x7759458000
08-05 09:00:10.736 512 537 E LightsService: Light requested not available on this device. 0
08-05 09:00:10.736 512 512 D SystemServerTiming: WaitForDisplay took to complete: 11ms
08-05 09:00:10.737 512 537 I DisplayManagerService: Display device changed state: “Built-in Screen”, ON
08-05 09:00:10.737 512 512 I SystemServer: StartPackageManagerService
08-05 09:00:10.759 512 512 D PackageSettings: Settings’ Object Creat!
08-05 09:00:10.760 512 512 D PackageSettings: mSettingsFilename exist! Closed performance mode!/oem/etc/package_performance.xml
08-05 09:00:10.765 512 512 D SELinuxMMAC: Using policy file /system/etc/selinux/plat_mac_permissions.xml
08-05 09:00:10.766 512 512 D SELinuxMMAC: Using policy file /vendor/etc/selinux/vendor_mac_permissions.xml
08-05 09:00:10.771 512 512 D FallbackCategoryProvider: Found 1 fallback categories
08-05 09:00:10.876 545 548 I adbd : initializing functionfs
08-05 09:00:10.876 545 548 I adbd : opening control endpoint /dev/usb-ffs/adb/ep0
08-05 09:00:10.877 545 548 I adbd : functionfs successfully initialized
08-05 09:00:10.877 545 548 I adbd : registering usb transport
08-05 09:00:10.880 512 512 D PackageManager: No files in app dir /product/overlay
08-05 09:00:10.882 512 512 W PackageManager: Failed to parse /system/framework/oat: Missing base APK in /system/framework/oat
08-05 09:00:10.882 512 512 W PackageManager: Failed to parse /system/framework/arm64: Missing base APK in /system/framework/arm64
08-05 09:00:10.887 512 512 W PackageManager: Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm
08-05 09:00:10.974 512 512 D PackageManager: No files in app dir /vendor/priv-app
08-05 09:00:10.978 512 512 D PackageManager: No files in app dir /vendor/odm/priv-app
08-05 09:00:10.978 512 512 D PackageManager: No files in app dir /vendor/odm/app
08-05 09:00:10.978 512 512 D PackageManager: No files in app dir /oem/app
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /system/product/priv-app
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /system/product/app
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /oem/bundled_uninstall_gone-app
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /oem/bundled_uninstall_back-app
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /oem/bundled_persist-app
08-05 09:00:10.979 512 512 I PackageManager: Finished scanning system apps. Time: 107 ms, packageCount: 89 , timePerPackage: 1 , cached: 89
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /data/app
08-05 09:00:10.979 512 512 D PackageManager: No files in app dir /data/app-private
08-05 09:00:10.979 512 512 I PackageManager: Finished scanning non-system apps. Time: 1 ms, packageCount: 0 , timePerPackage: 0 , cached: 0
08-05 09:00:10.983 512 512 I PackageManager: Time to scan packages: 0.111 seconds
08-05 09:00:10.986 512 512 V PackageManager: reconcileAppsData for null u0 0x3 migrateAppData=true
08-05 09:00:11.006 428 452 I SELinux : SELinux: Loaded file_contexts
08-05 09:00:11.078 512 512 V PackageManager: reconcileAppsData finished 18 packages
08-05 09:00:11.079 512 571 D SystemServerInitThreadPool: Started executing prepareAppData
08-05 09:00:11.108 428 428 W installd: Ignoring /data/data/com.android.webview/lib with unexpected GID 0 instead of 10041
08-05 09:00:11.118 428 428 W installd: Ignoring /data/data/acr.browser.barebones/lib with unexpected GID 0 instead of 10033
08-05 09:00:11.125 512 512 E PackageManager: There should probably be a verifier, but, none were found
08-05 09:00:11.127 512 512 D PackageManager: Ephemeral resolver NOT found; no matching intent filters
08-05 09:00:11.128 512 512 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
08-05 09:00:11.128 512 512 D PackageManager: Clear ephemeral installer activity
08-05 09:00:11.155 512 571 D SystemServerTimingAsync: AppDataFixup took to complete: 76ms
08-05 09:00:11.170 512 512 I system_server: Explicit concurrent copying GC freed 46440(2MB) AllocSpace objects, 13(532KB) LOS objects, 42% free, 2MB/5MB, paused 44us total 37.851ms
08-05 09:00:11.172 512 512 D SystemServerTiming: StartPackageManagerService took to complete: 435ms
08-05 09:00:11.172 512 512 I SystemServer: StartOtaDexOptService
08-05 09:00:11.173 512 512 D OTADexopt: No upgrade, skipping A/B artifacts check.
08-05 09:00:11.173 512 512 D SystemServerTiming: StartOtaDexOptService took to complete: 1ms
08-05 09:00:11.173 512 512 I SystemServer: StartUserManagerService
08-05 09:00:11.173 512 512 I SystemServiceManager: Starting com.android.server.pm.UserManagerService$LifeCycle
08-05 09:00:11.173 512 512 D SystemServerTiming: StartUserManagerService took to complete: 0ms
08-05 09:00:11.173 512 512 I SystemServer: InitAttributerCache
08-05 09:00:11.173 512 512 D SystemServerTiming: InitAttributerCache took to complete: 0ms
08-05 09:00:11.173 512 512 I SystemServer: SetSystemProcess
08-05 09:00:11.185 276 276 I SoundTriggerHalHidl: getProperties res implementor
08-05 09:00:11.185 276 276 I SoundTriggerHalHidl: getProperties ret -19
08-05 09:00:11.185 276 276 E SoundTriggerHwService: could not read implementation properties
08-05 09:00:11.188 277 277 I lowmemorykiller: lmkd data connection established
08-05 09:00:11.190 512 512 D SystemServerTiming: SetSystemProcess took to complete: 16ms
08-05 09:00:11.193 512 512 I SystemServer: StartOverlayManagerService
08-05 09:00:11.197 512 512 D SystemServerTiming: StartOverlayManagerService took to complete: 3ms
08-05 09:00:11.197 512 578 D SystemServerInitThreadPool: Started executing Init OverlayManagerService
08-05 09:00:11.197 512 512 I SystemServer: StartBatteryService
08-05 09:00:11.197 512 512 I SystemServiceManager: Starting com.android.server.BatteryService
08-05 09:00:11.197 512 579 D SystemServerInitThreadPool: Started executing StartSensorService
08-05 09:00:11.198 512 579 D SensorService: nuSensorService starting…
08-05 09:00:11.202 273 581 I Sensors : set active: handle = 8, enable = 0
08-05 09:00:11.202 273 581 I Sensors : set active: handle = 2, enable = 0
08-05 09:00:11.202 273 581 I Sensors : set active: handle = 7, enable = 0
08-05 09:00:11.202 273 581 I Sensors : set active: handle = 12, enable = 0
08-05 09:00:11.205 512 584 D SensorService: nuSensorService thread starting…
08-05 09:00:11.205 512 579 D SystemServerTimingAsync: StartSensorService took to complete: 7ms
08-05 09:00:11.205 512 583 D SensorService: new thread SensorEventAckReceiver
08-05 09:00:11.205 512 579 D SystemServerInitThreadPool: Finished executing StartSensorService
08-05 09:00:11.206 436 463 I storaged: storaged: Start
08-05 09:00:11.206 436 463 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
08-05 09:00:11.211 512 512 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hardware.health@2.0::IHealth
08-05 09:00:11.217 512 580 E LightsService: Light requested not available on this device. 3
08-05 09:00:11.218 512 512 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
08-05 09:00:11.219 512 512 I HealthServiceWrapper: health: HealthServiceWrapper listening to instance default
08-05 09:00:11.219 512 512 I BatteryService: health: Waited 0ms and received the update.
08-05 09:00:11.221 512 587 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hardware.health@2.0::IHealth
08-05 09:00:11.223 512 512 D SystemServerTiming: StartBatteryService took to complete: 25ms
08-05 09:00:11.223 512 512 I SystemServer: StartUsageService
08-05 09:00:11.223 512 512 I SystemServiceManager: Starting com.android.server.usage.UsageStatsService
08-05 09:00:11.241 512 512 I UsageStatsService: User[0] Rollover scheduled @ 2017-08-06 09:00:11(1502010011234)
08-05 09:00:11.241 512 512 D SystemServerTiming: StartUsageService took to complete: 19ms
08-05 09:00:11.242 512 512 I SystemServer: StartWebViewUpdateService
08-05 09:00:11.242 512 512 I SystemServiceManager: Starting com.android.server.webkit.WebViewUpdateService
08-05 09:00:11.247 512 512 D SystemServerTiming: StartWebViewUpdateService took to complete: 5ms
08-05 09:00:11.247 512 512 I SystemServer: StartBinderCallsStatsService
08-05 09:00:11.248 512 512 D SystemServerTiming: StartBinderCallsStatsService took to complete: 1ms
08-05 09:00:11.248 512 512 I SystemServer: StartKeyAttestationApplicationIdProviderService
08-05 09:00:11.248 512 527 D SystemServerInitThreadPool: Started executing SecondaryZygotePreload
08-05 09:00:11.248 512 527 I SystemServer: SecondaryZygotePreload
08-05 09:00:11.249 512 512 D SystemServerTiming: StartKeyAttestationApplicationIdProviderService took to complete: 0ms
08-05 09:00:11.249 512 512 I SystemServer: StartKeyChainSystemService
08-05 09:00:11.249 512 512 I SystemServiceManager: Starting com.android.server.security.KeyChainSystemService
08-05 09:00:11.250 512 512 D SystemServerTiming: StartKeyChainSystemService took to complete: 0ms
08-05 09:00:11.250 512 512 I SystemServer: StartSchedulingPolicyService
08-05 09:00:11.250 512 579 D SystemServerInitThreadPool: Started executing SchedulingPolicyService.
08-05 09:00:11.251 512 512 D SystemServerTiming: StartSchedulingPolicyService took to complete: 1ms
08-05 09:00:11.251 512 512 I SystemServer: StartTelecomLoaderService
08-05 09:00:11.251 512 512 I SystemServiceManager: Starting com.android.server.telecom.TelecomLoaderService
08-05 09:00:11.252 512 512 D SystemServerTiming: StartTelecomLoaderService took to complete: 2ms
08-05 09:00:11.252 512 512 I SystemServer: StartTelephonyRegistry
08-05 09:00:11.255 512 512 D SystemServerTiming: StartTelephonyRegistry took to complete: 2ms
08-05 09:00:11.255 512 512 I SystemServer: StartEntropyMixer
08-05 09:00:11.255 512 579 I SchedulingPolicyService: Moving 438 back to group default
08-05 09:00:11.256 512 579 D SystemServerInitThreadPool: Finished executing SchedulingPolicyService.
08-05 09:00:11.258 512 512 I EntropyMixer: Writing entropy…
08-05 09:00:11.259 512 527 I Zygote : Process: zygote socket RESERVED/zygote opened, supported ABIS: arm64-v8a
08-05 09:00:11.261 512 512 D SystemServerTiming: StartEntropyMixer took to complete: 6ms
08-05 09:00:11.261 512 512 I SystemServer: StartAccountManagerService
08-05 09:00:11.261 512 512 I SystemServiceManager: Starting com.android.server.accounts.AccountManagerService$Lifecycle
08-05 09:00:11.266 512 512 D SystemServerTiming: StartAccountManagerService took to complete: 6ms
08-05 09:00:11.267 512 512 I SystemServer: StartContentService
08-05 09:00:11.268 512 512 I SystemServiceManager: Starting com.android.server.content.ContentService$Lifecycle
08-05 09:00:11.272 512 512 D SystemServerTiming: StartContentService took to complete: 5ms
08-05 09:00:11.272 512 512 I SystemServer: InstallSystemProviders
08-05 09:00:11.280 440 440 W npu_monitor: type=1400 audit(0.0:232): avc: denied { read } for name=“temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
08-05 09:00:11.280 440 440 W npu_monitor: type=1400 audit(0.0:233): avc: denied { open } for path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
08-05 09:00:11.280 512 527 I Zygote : Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
08-05 09:00:11.283 512 512 I system_server: The ClassLoaderContext is a special shared library.
08-05 09:00:11.291 424 424 I Zygote : Lazily preloading resources.
08-05 09:00:11.291 424 424 D Zygote : begin preload
08-05 09:00:11.291 424 424 I Zygote : Installing ICU cache reference pinning…
08-05 09:00:11.291 424 424 I Zygote : Preloading ICU data…
08-05 09:00:11.296 589 589 W upgrade_tool: type=1400 audit(0.0:234): avc: denied { read } for name=“busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:11.296 589 589 W upgrade_tool: type=1400 audit(0.0:235): avc: denied { open } for path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.12.auto/usb3/busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:11.296 589 589 W upgrade_tool: type=1400 audit(0.0:236): avc: denied { getattr } for path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.12.auto/usb3/busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
08-05 09:00:11.304 512 512 I SettingsState: No settings state /data/system/users/0/settings_ssaid.xml
08-05 09:00:11.308 424 424 D ZygoteInitTiming_lazy: BeginIcuCachePinning took to complete: 18ms
08-05 09:00:11.309 424 424 I Zygote : Preloading classes…
08-05 09:00:11.318 512 512 D SystemServerTiming: InstallSystemProviders took to complete: 46ms
08-05 09:00:11.318 512 512 I SystemServer: StartDropBoxManager
08-05 09:00:11.318 512 512 I SystemServiceManager: Starting com.android.server.DropBoxManagerService
08-05 09:00:11.319 512 512 D SystemServerTiming: StartDropBoxManager took to complete: 1ms
08-05 09:00:11.319 512 512 I SystemServer: StartVibratorService
08-05 09:00:11.321 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
08-05 09:00:11.322 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
08-05 09:00:11.322 512 512 E VibratorService: vibratorOff command failed (1).
08-05 09:00:11.324 512 512 D SystemServerTiming: StartVibratorService took to complete: 4ms
08-05 09:00:11.324 512 512 I SystemServer: StartConsumerIrService
08-05 09:00:11.325 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.ir@1.0::IConsumerIr/default in either framework or device manifest.
08-05 09:00:11.326 512 512 D SystemServerTiming: StartConsumerIrService took to complete: 2ms
08-05 09:00:11.326 512 512 I SystemServer: StartAlarmManagerService
08-05 09:00:11.326 512 512 I SystemServiceManager: Starting com.android.server.AlarmManagerService
08-05 09:00:11.326 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
08-05 09:00:11.330 512 512 D AlarmManagerService: Kernel timezone updated to 0 minutes west of GMT
08-05 09:00:11.330 512 512 I AlarmManager: Current time only 1501923611330, advancing to build time 1600238847000
08-05 09:00:11.331 512 512 D AlarmManagerService: Setting time of day to sec=1600238847
09-16 06:47:27.003 512 512 V AlarmManager: setImplLocked type=3 ,when=41504
09-16 06:47:27.003 512 512 V AlarmManager: setImplLocked type=1 ,when=1600300800000
09-16 06:47:27.004 424 424 I PackageBackwardCompatibility: Loaded android.content.pm.OrgApacheHttpLegacyUpdater
09-16 06:47:27.004 424 424 I PackageBackwardCompatibility: Could not find android.content.pm.AndroidTestBaseUpdater, ignoring
09-16 06:47:27.005 512 593 V AlarmManager: setImplLocked type=3 ,when=41504
09-16 06:47:27.005 512 593 V AlarmManager: setImplLocked type=1 ,when=1600300800000
09-16 06:47:27.006 512 512 D SystemServerTiming: StartAlarmManagerService took to complete: 11ms
09-16 06:47:27.006 512 512 I SystemServer: InitWatchdog
09-16 06:47:27.009 512 512 D SystemServerTiming: InitWatchdog took to complete: 3ms
09-16 06:47:27.009 512 512 I SystemServer: StartInputManagerService
09-16 06:47:27.009 512 512 I InputManager: Initializing input manager, mUseDevInputEventForAudioJack=false
09-16 06:47:27.010 512 512 D SystemServerTiming: StartInputManagerService took to complete: 1ms
09-16 06:47:27.010 512 512 I SystemServer: StartWindowManagerService
09-16 06:47:27.030 512 537 I WindowManager: No existing display settings /data/system/display_settings.xml; starting empty
09-16 06:47:27.051 512 512 D SystemServerTiming: StartWindowManagerService took to complete: 41ms
09-16 06:47:27.051 512 512 I SystemServer: SetWindowManagerService
09-16 06:47:27.103 512 512 D SystemServerTiming: SetWindowManagerService took to complete: 51ms
09-16 06:47:27.103 512 512 I SystemServer: WindowManagerServiceOnInitReady
09-16 06:47:27.129 512 512 D SystemServerTiming: WindowManagerServiceOnInitReady took to complete: 26ms
09-16 06:47:27.129 512 512 I SystemServer: StartInputManager
09-16 06:47:27.129 512 579 D SystemServerInitThreadPool: Started executing StartHidlServices
09-16 06:47:27.129 512 512 I InputManager: Starting input manager
09-16 06:47:27.131 512 512 D SystemServerTiming: StartInputManager took to complete: 2ms
09-16 06:47:27.131 512 512 I SystemServer: DisplayManagerWindowManagerAndInputReady
09-16 06:47:27.131 512 599 D EventHub: No input device configuration file found for device ‘Dell KB216 Wired Keyboard’.
09-16 06:47:27.132 512 512 D SystemServerTiming: DisplayManagerWindowManagerAndInputReady took to complete: 0ms
09-16 06:47:27.132 512 512 I SystemServer: StartBluetoothService
09-16 06:47:27.132 512 512 I SystemServiceManager: Starting com.android.server.BluetoothService
09-16 06:47:27.133 512 579 D SystemServerTimingAsync: StartHidlServices took to complete: 5ms
09-16 06:47:27.134 512 579 D SystemServerInitThreadPool: Finished executing StartHidlServices
09-16 06:47:27.135 512 599 W EventHub: Unable to disable kernel key repeat for /dev/input/event9: Function not implemented
09-16 06:47:27.135 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.135 512 599 I EventHub: New device: id=1, fd=116, path=‘/dev/input/event9’, name=‘Dell KB216 Wired Keyboard’, classes=0x80004121, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.136 512 512 D BluetoothManagerService: Loading stored name and address
09-16 06:47:27.136 512 599 D EventHub: No input device configuration file found for device ‘ff420030.pwm’.
09-16 06:47:27.136 512 512 D BluetoothManagerService: Stored bluetooth Name=rk3399,Address=null
09-16 06:47:27.136 512 512 D BluetoothManagerService: Bluetooth persisted state: 0
09-16 06:47:27.137 512 512 D BluetoothManagerService: Detected SystemUiUid: 10025
09-16 06:47:27.137 512 512 D SystemServerTiming: StartBluetoothService took to complete: 5ms
09-16 06:47:27.137 512 512 I SystemServer: IpConnectivityMetrics
09-16 06:47:27.137 512 512 I SystemServiceManager: Starting com.android.server.connectivity.IpConnectivityMetrics
09-16 06:47:27.138 512 599 W EventHub: Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
09-16 06:47:27.138 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.138 512 599 I EventHub: New device: id=2, fd=117, path=‘/dev/input/event0’, name=‘ff420030.pwm’, classes=0x4021, configuration=‘’, keyLayout=‘/system/usr/keylayout/ff420030_pwm.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.138 512 599 D EventHub: No input device configuration file found for device ‘rockchip-cdndp-sound DP Jack’.
09-16 06:47:27.138 512 599 I EventHub: New device: id=3, fd=118, path=‘/dev/input/event7’, name=‘rockchip-cdndp-sound DP Jack’, classes=0x80, configuration=‘’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false,
09-16 06:47:27.138 512 599 D EventHub: No input device configuration file found for device ‘RAPOO Rapoo 2.4G Wireless Device’.
09-16 06:47:27.140 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.140 512 599 I EventHub: New device: id=4, fd=119, path=‘/dev/input/event3’, name=‘RAPOO Rapoo 2.4G Wireless Device’, classes=0x80004003, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.141 512 599 D EventHub: No input device configuration file found for device ‘RAPOO Rapoo 2.4G Wireless Device’.
09-16 06:47:27.143 512 599 W EventHub: Unable to disable kernel key repeat for /dev/input/event4: Function not implemented
09-16 06:47:27.143 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.143 512 599 I EventHub: New device: id=5, fd=120, path=‘/dev/input/event4’, name=‘RAPOO Rapoo 2.4G Wireless Device’, classes=0x80004129, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.143 512 599 D EventHub: No input device configuration file found for device ‘rockchip,rk809-codec Headphone Jack’.
09-16 06:47:27.143 512 599 I EventHub: New device: id=6, fd=121, path=‘/dev/input/event6’, name=‘rockchip,rk809-codec Headphone Jack’, classes=0x80, configuration=‘’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false,
09-16 06:47:27.143 512 512 D SystemServerTiming: IpConnectivityMetrics took to complete: 6ms
09-16 06:47:27.143 512 512 I SystemServer: NetworkWatchlistService
09-16 06:47:27.143 512 599 D EventHub: No input device configuration file found for device ‘adc-keys’.
09-16 06:47:27.143 512 512 I SystemServiceManager: Starting com.android.server.net.watchlist.NetworkWatchlistService$Lifecycle
09-16 06:47:27.146 512 599 W EventHub: Unable to disable kernel key repeat for /dev/input/event5: Function not implemented
09-16 06:47:27.146 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.146 512 599 I EventHub: New device: id=7, fd=122, path=‘/dev/input/event5’, name=‘adc-keys’, classes=0x4001, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.146 512 599 D EventHub: No input device configuration file found for device ‘Typec_Headphone’.
09-16 06:47:27.146 512 599 I EventHub: New device: id=8, fd=123, path=‘/dev/input/event2’, name=‘Typec_Headphone’, classes=0x80, configuration=‘’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false,
09-16 06:47:27.146 512 599 D EventHub: No input device configuration file found for device ‘Dell KB216 Wired Keyboard’.
09-16 06:47:27.148 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.148 512 599 I EventHub: New device: id=9, fd=124, path=‘/dev/input/event8’, name=‘Dell KB216 Wired Keyboard’, classes=0x80004003, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.148 512 599 D EventHub: No input device configuration file found for device ‘rk8xx_pwrkey’.
09-16 06:47:27.150 512 599 W EventHub: Unable to disable kernel key repeat for /dev/input/event1: Function not implemented
09-16 06:47:27.151 512 599 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
09-16 06:47:27.151 512 599 I EventHub: New device: id=10, fd=125, path=‘/dev/input/event1’, name=‘rk8xx_pwrkey’, classes=0x4001, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false,
09-16 06:47:27.166 512 512 I WatchlistSettings: Reload watchlist settings done
09-16 06:47:27.166 512 599 I InputReader: Device added: id=-1, name=‘Virtual’, sources=0x00000301
09-16 06:47:27.167 512 599 I InputReader: Device added: id=10, name=‘rk8xx_pwrkey’, sources=0x00002103
09-16 06:47:27.167 512 599 I InputReader: Device added: id=9, name=‘Dell KB216 Wired Keyboard’, sources=0x00002103
09-16 06:47:27.167 512 599 I InputReader: Device added: id=8, name=‘Typec_Headphone’, sources=0x80000000
09-16 06:47:27.167 512 599 I InputReader: Device added: id=7, name=‘adc-keys’, sources=0x00002103
09-16 06:47:27.167 512 599 I InputReader: Device added: id=6, name=‘rockchip,rk809-codec Headphone Jack’, sources=0x80000000
09-16 06:47:27.167 512 600 I WatchlistLoggingHandler: No need to aggregate record yet.
09-16 06:47:27.167 512 600 I WatchlistLoggingHandler: Milliseconds spent on tryAggregateRecords(): 0
09-16 06:47:27.168 512 512 D SystemServerTiming: NetworkWatchlistService took to complete: 24ms
09-16 06:47:27.168 512 512 I SystemServer: PinnerService
09-16 06:47:27.168 512 512 I SystemServiceManager: Starting com.android.server.PinnerService
09-16 06:47:27.173 512 512 D SystemServerTiming: PinnerService took to complete: 6ms
09-16 06:47:27.174 512 512 I SystemServer: StartInputMethodManagerLifecycle
09-16 06:47:27.174 512 512 I SystemServiceManager: Starting com.android.server.InputMethodManagerService$Lifecycle
09-16 06:47:27.183 512 599 I InputReader: Device added: id=5, name=‘RAPOO Rapoo 2.4G Wireless Device’, sources=0x01002313
09-16 06:47:27.183 512 599 I InputReader: Device added: id=4, name=‘RAPOO Rapoo 2.4G Wireless Device’, sources=0x00002103
09-16 06:47:27.183 512 599 I InputReader: Device added: id=3, name=‘rockchip-cdndp-sound DP Jack’, sources=0x80000000
09-16 06:47:27.183 512 599 I InputReader: Device added: id=2, name=‘ff420030.pwm’, sources=0x00002303
09-16 06:47:27.183 512 599 I InputReader: Device added: id=1, name=‘Dell KB216 Wired Keyboard’, sources=0x01002313
09-16 06:47:27.187 512 512 D SystemServerTiming: StartInputMethodManagerLifecycle took to complete: 14ms
09-16 06:47:27.188 512 512 I SystemServer: StartAccessibilityManagerService
09-16 06:47:27.195 512 578 D SystemServerInitThreadPool: Finished executing Init OverlayManagerService
09-16 06:47:27.203 512 512 D SystemServerTiming: StartAccessibilityManagerService took to complete: 15ms
09-16 06:47:27.203 512 512 I SystemServer: MakeDisplayReady
09-16 06:47:27.204 512 512 I ActivityManager: Config changes=20005df8 {1.0 ?mcc?mnc [en_US] ldltr sw411dp w731dp h411dp 280dpi nrml long land ?uimode ?night -touch qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1280, 720) mWindowingMode=fullscreen mActivityType=undefined} s.2}
09-16 06:47:27.205 512 528 I UsageStatsService: Time changed in UsageStats by 98315235 seconds
09-16 06:47:27.205 512 528 I UsageStatsDatabase: Time changed by +1137d21h47m15s669ms. files deleted: 0 files moved: 0
09-16 06:47:27.206 512 528 I UsageStatsService: User[0] Rollover scheduled @ 2020-09-17 06:47:27(1600325247205)
09-16 06:47:27.214 424 424 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. class_init is effectively a no-op
09-16 06:47:27.215 512 512 I ActivityManager: Override config changes=60007dfc {1.0 ?mcc?mnc [en_US] ldltr sw411dp w731dp h411dp 280dpi nrml long land ?uimode ?night -touch qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 1280, 720) mAppBounds=Rect(0, 0 - 1280, 720) mWindowingMode=fullscreen mActivityType=undefined} s.2} for displayId=0
09-16 06:47:27.219 512 512 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:27.220 512 512 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:27.222 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:27.223 512 512 I ActivityManager: Config changes=20000500 {1.0 ?mcc?mnc [en_US] ldltr sw411dp w683dp h387dp 280dpi nrml land ?uimode ?night -touch qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1196, 720) mWindowingMode=fullscreen mActivityType=undefined} s.3}
09-16 06:47:27.231 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:27.231 512 512 I ActivityManager: Override config changes=20000500 {1.0 ?mcc?mnc [en_US] ldltr sw411dp w683dp h387dp 280dpi nrml land ?uimode ?night -touch qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 1280, 720) mAppBounds=Rect(0, 0 - 1196, 720) mWindowingMode=fullscreen mActivityType=undefined} s.3} for displayId=0
09-16 06:47:27.240 512 512 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:27.240 512 512 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:27.242 512 512 D SystemServerTiming: MakeDisplayReady took to complete: 39ms
09-16 06:47:27.242 512 512 I SystemServer: StartStorageManagerService
09-16 06:47:27.242 512 512 I SystemServiceManager: Starting com.android.server.StorageManagerService$Lifecycle
09-16 06:47:27.245 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:27.252 512 601 D StorageManagerService: Thinking about init, mSystemReady=false, mDaemonConnected=true
09-16 06:47:27.252 512 512 D SystemServerTiming: StartStorageManagerService took to complete: 10ms
09-16 06:47:27.252 512 601 D StorageManagerService: Thinking about reset, mSystemReady=false, mDaemonConnected=true
09-16 06:47:27.252 512 512 I SystemServer: StartStorageStatsService
09-16 06:47:27.252 512 512 I SystemServiceManager: Starting com.android.server.usage.StorageStatsService$Lifecycle
09-16 06:47:27.253 244 250 E vold : Failed to read field SystemLocale: No such file or directory
09-16 06:47:27.254 512 601 E StorageManagerService: Failed to read field SystemLocale
09-16 06:47:27.254 512 601 E StorageManagerService: android.os.ServiceSpecificException: Failed to read field SystemLocale (code 2)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.Parcel.createException(Parcel.java:1964)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.Parcel.readException(Parcel.java:1918)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.Parcel.readException(Parcel.java:1868)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.IVold$Stub$Proxy.fdeGetField(IVold.java:1094)
09-16 06:47:27.254 512 601 E StorageManagerService: at com.android.server.StorageManagerService.getField(StorageManagerService.java:2420)
09-16 06:47:27.254 512 601 E StorageManagerService: at com.android.server.StorageManagerService.copyLocaleFromMountService(StorageManagerService.java:983)
09-16 06:47:27.254 512 601 E StorageManagerService: at com.android.server.StorageManagerService.handleDaemonConnected(StorageManagerService.java:976)
09-16 06:47:27.254 512 601 E StorageManagerService: at com.android.server.StorageManagerService.access$900(StorageManagerService.java:172)
09-16 06:47:27.254 512 601 E StorageManagerService: at com.android.server.StorageManagerService$StorageManagerServiceHandler.handleMessage(StorageManagerService.java:573)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.Handler.dispatchMessage(Handler.java:106)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.Looper.loop(Looper.java:193)
09-16 06:47:27.254 512 601 E StorageManagerService: at android.os.HandlerThread.run(HandlerThread.java:65)
09-16 06:47:27.255 428 570 D installd: Found quota mount /dev/block/dm-0 at /data
09-16 06:47:27.256 428 570 D installd: Found quota mount /dev/block/dm-0 at /data
09-16 06:47:27.259 512 512 D SystemServerTiming: StartStorageStatsService took to complete: 6ms
09-16 06:47:27.259 512 512 I SystemServer: StartUiModeManager
09-16 06:47:27.259 512 512 I SystemServiceManager: Starting com.android.server.UiModeManagerService
09-16 06:47:27.261 512 579 D SystemServerInitThreadPool: Started executing UiModeManager.onStart
09-16 06:47:27.262 512 579 I ActivityManager: Config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw411dp w683dp h387dp 280dpi nrml land -touch qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1196, 720) mWindowingMode=fullscreen mActivityType=undefined} s.4}
09-16 06:47:27.264 512 512 D SystemServerTiming: StartUiModeManager took to complete: 5ms
09-16 06:47:27.264 512 512 I SystemServer: UpdatePackagesIfNeeded
09-16 06:47:27.264 512 512 D SystemServerTiming: UpdatePackagesIfNeeded took to complete: 0ms
09-16 06:47:27.264 512 512 I SystemServer: PerformFstrimIfNeeded
09-16 06:47:27.265 512 512 D SystemServerTiming: PerformFstrimIfNeeded took to complete: 1ms
09-16 06:47:27.265 512 512 I SystemServer: StartLockSettingsService
09-16 06:47:27.266 512 512 I SystemServiceManager: Starting com.android.server.locksettings.LockSettingsService$Lifecycle
09-16 06:47:27.281 512 579 I ActivityManager: Override config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw411dp w683dp h387dp 280dpi nrml land -touch qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 1280, 720) mAppBounds=Rect(0, 0 - 1196, 720) mWindowingMode=fullscreen mActivityType=undefined} s.4} for displayId=0
09-16 06:47:27.284 512 579 D SystemServerInitThreadPool: Finished executing UiModeManager.onStart
09-16 06:47:27.288 512 512 D SystemServerTiming: StartLockSettingsService took to complete: 24ms
09-16 06:47:27.290 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.oemlock@1.0::IOemLock/default in either framework or device manifest.
09-16 06:47:27.291 512 512 I OemLock : OemLock HAL not present on device
09-16 06:47:27.291 512 512 I SystemServer: StartDeviceIdleController
09-16 06:47:27.291 512 512 I SystemServiceManager: Starting com.android.server.DeviceIdleController
09-16 06:47:27.296 512 512 D SystemServerTiming: StartDeviceIdleController took to complete: 6ms
09-16 06:47:27.297 512 512 I SystemServer: StartDevicePolicyManager
09-16 06:47:27.297 512 512 I SystemServiceManager: Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
09-16 06:47:27.300 424 424 I zygote : Thread[1,tid=424,Native,Thread=0xf1748000,peer=0x12ec0000,“main”] recursive attempt to load library “/system/lib/libmedia_jni.so”
09-16 06:47:27.300 424 424 D MtpDeviceJNI: register_android_mtp_MtpDevice
09-16 06:47:27.309 512 512 D SystemServerTiming: StartDevicePolicyManager took to complete: 12ms
09-16 06:47:27.309 512 512 I SystemServer: StartStatusBarManagerService
09-16 06:47:27.310 512 512 D SystemServerTiming: StartStatusBarManagerService took to complete: 1ms
09-16 06:47:27.310 512 512 I SystemServer: StartClipboardService
09-16 06:47:27.310 512 512 I SystemServiceManager: Starting com.android.server.clipboard.ClipboardService
09-16 06:47:27.312 512 512 D SystemServerTiming: StartClipboardService took to complete: 1ms
09-16 06:47:27.312 512 512 I SystemServer: StartNetworkManagementService
09-16 06:47:27.315 512 602 I NetworkManagement: onDaemonConnected()
09-16 06:47:27.317 512 512 D SystemServerTiming: StartNetworkManagementService took to complete: 4ms
09-16 06:47:27.317 512 512 I SystemServer: StartIpSecService
09-16 06:47:27.320 512 512 D SystemServerTiming: StartIpSecService took to complete: 3ms
09-16 06:47:27.320 512 512 I SystemServer: StartTextServicesManager
09-16 06:47:27.320 512 512 I SystemServiceManager: Starting com.android.server.TextServicesManagerService$Lifecycle
09-16 06:47:27.322 512 512 D SystemServerTiming: StartTextServicesManager took to complete: 2ms
09-16 06:47:27.322 512 512 I SystemServer: StartTextClassificationManagerService
09-16 06:47:27.322 512 512 I SystemServiceManager: Starting com.android.server.textclassifier.TextClassificationManagerService$Lifecycle
09-16 06:47:27.323 512 512 D SystemServerTiming: StartTextClassificationManagerService took to complete: 1ms
09-16 06:47:27.323 512 512 I SystemServer: StartNetworkScoreService
09-16 06:47:27.323 512 512 I SystemServiceManager: Starting com.android.server.NetworkScoreService$Lifecycle
09-16 06:47:27.325 512 512 I NetworkScoreService: Registering network_score
09-16 06:47:27.326 512 512 D SystemServerTiming: StartNetworkScoreService took to complete: 2ms
09-16 06:47:27.326 512 512 I SystemServer: StartNetworkStatsService
09-16 06:47:27.329 512 512 D SystemServerTiming: StartNetworkStatsService took to complete: 3ms
09-16 06:47:27.329 512 512 I SystemServer: StartNetworkPolicyManagerService
09-16 06:47:27.335 512 512 D SystemServerTiming: StartNetworkPolicyManagerService took to complete: 6ms
09-16 06:47:27.335 512 512 I SystemServer: StartWifi
09-16 06:47:27.356 512 512 I SystemServiceManager: Starting com.android.server.wifi.WifiService
09-16 06:47:27.434 512 512 D WifiCountryCode: Country code will be reverted to CN on MCC loss
09-16 06:47:27.434 512 512 D WifiApConfigStore: 2G band allowed channels are:1,6,11
09-16 06:47:27.443 512 512 I WifiScoringParams: rssi2=-85:-85:-73:-60,rssi5=-82:-82:-70:-57,pps=0:1:100,horizon=15,nud=8,expid=0
09-16 06:47:27.462 424 424 I Zygote : …preloaded 6535 classes in 484ms.
09-16 06:47:27.462 424 424 I zygote : VMRuntime.preloadDexCaches starting
09-16 06:47:27.477 512 512 D WifiStateMachine: EnableConnectedMacRandomization Setting changed to false
09-16 06:47:27.477 512 512 E WifiStateMachine: getWifiLinkLayerStats called without an interface
09-16 06:47:27.477 512 512 D WifiStateMachinePrime: Starting Wifi in WifiDisabledState
09-16 06:47:27.478 512 608 D WifiStateMachinePrime: Entering WifiDisabledState
09-16 06:47:27.478 512 608 D ActiveModeManager: sending scan available broadcast: false
09-16 06:47:27.479 512 512 D WifiOpenNetworkNotifier: Settings toggle enabled=true
09-16 06:47:27.479 512 512 D WifiCarrierNetworkNotifier: Settings toggle enabled=true
09-16 06:47:27.480 512 512 D WakeupController: WifiWake enabled
09-16 06:47:27.482 512 512 D WifiController: isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false, isLocationModeActive = false
09-16 06:47:27.486 512 512 E SupplicantStaIfaceHal: Can’t call setDebugParams, ISupplicant is null
09-16 06:47:27.486 512 512 W WifiDiags: no ring buffers found
09-16 06:47:27.486 512 512 W WifiDiags: Failed to start packet fate monitoring
09-16 06:47:27.486 512 512 I WifiService: Registering wifi
09-16 06:47:27.487 512 512 D SystemServerTiming: StartWifi took to complete: 152ms
09-16 06:47:27.487 512 512 I SystemServer: StartWifiScanning
09-16 06:47:27.488 512 512 I SystemServiceManager: Starting com.android.server.wifi.scanner.WifiScanningService
09-16 06:47:27.488 512 512 I WifiScanningService: Creating wifiscanner
09-16 06:47:27.489 512 512 I WifiScanningService: Publishing wifiscanner
09-16 06:47:27.490 512 512 D SystemServerTiming: StartWifiScanning took to complete: 3ms
09-16 06:47:27.490 512 512 I SystemServer: StartWifiP2P
09-16 06:47:27.491 512 512 I SystemServiceManager: Starting com.android.server.wifi.p2p.WifiP2pService
09-16 06:47:27.499 512 512 W HalDevMgr: isWifiStarted called but mWifi is null!?
09-16 06:47:27.499 512 512 I WifiP2pService: Registering wifip2p
09-16 06:47:27.500 512 512 D SystemServerTiming: StartWifiP2P took to complete: 11ms
09-16 06:47:27.501 512 512 I SystemServer: StartEthernet
09-16 06:47:27.501 424 424 I zygote : VMRuntime.preloadDexCaches strings total=339863 before=12300 after=12300
09-16 06:47:27.501 424 424 I zygote : VMRuntime.preloadDexCaches types total=31370 before=7826 after=7827
09-16 06:47:27.501 424 424 I zygote : VMRuntime.preloadDexCaches fields total=141122 before=9172 after=9172
09-16 06:47:27.501 424 424 I zygote : VMRuntime.preloadDexCaches methods total=248070 before=12783 after=12783
09-16 06:47:27.501 424 424 I zygote : VMRuntime.preloadDexCaches finished
09-16 06:47:27.501 424 424 D ZygoteInitTiming_lazy: PreloadClasses took to complete: 523ms
09-16 06:47:27.501 512 512 I SystemServiceManager: Starting com.android.server.ethernet.EthernetService
09-16 06:47:27.502 512 512 I EthernetService: Registering service ethernet
09-16 06:47:27.503 512 512 D SystemServerTiming: StartEthernet took to complete: 2ms
09-16 06:47:27.503 512 512 I SystemServer: StartConnectivityService
09-16 06:47:27.507 512 512 D ConnectivityService: ConnectivityService starting up
09-16 06:47:27.508 512 512 D ConnectivityService: wifiOnly=false
09-16 06:47:27.508 512 512 E ConnectivityService: Ignoring protectedNetwork 14
09-16 06:47:27.520 512 512 D SystemServerTiming: StartConnectivityService took to complete: 17ms
09-16 06:47:27.520 512 512 I SystemServer: StartNsdService
09-16 06:47:27.522 512 512 D NsdService: Network service discovery is enabled
09-16 06:47:27.527 512 512 D SystemServerTiming: StartNsdService took to complete: 7ms
09-16 06:47:27.527 512 512 I SystemServer: StartSystemUpdateManagerService
09-16 06:47:27.527 512 512 I SystemUpdateManagerService: No existing info file /data/system/system-update-info.xml
09-16 06:47:27.528 512 512 D SystemServerTiming: StartSystemUpdateManagerService took to complete: 1ms
09-16 06:47:27.528 512 512 I SystemServer: StartUpdateLockService
09-16 06:47:27.530 512 512 D SystemServerTiming: StartUpdateLockService took to complete: 3ms
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution + clock 27000 txt: 27000
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution flags: 10 txt: a
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution + clock 74250 txt: 74250
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution flags: 5 txt: 5
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution flags: 21 txt: 15
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution + clock 13500 txt: 13500
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution flags: 4122 txt: 101A
09-16 06:47:27.534 512 512 W PullResolutionParser: parse resolution + clock 148500 txt: 148500
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution flags: 4122 txt: 101A
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution + clock 148500 txt: 148500
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution flags: 5 txt: 5
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution + clock 74250 txt: 74250
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution + clock 59400 txt: 59400
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution + clock 297000 txt: 297000
09-16 06:47:27.535 512 512 W PullResolutionParser: parse resolution + clock 594000 txt: 594000
09-16 06:47:27.536 512 512 W PullResolutionParser: parse resolution flags: 5 txt: 5
09-16 06:47:27.536 512 512 W PullResolutionParser: parse resolution + clock 297000 txt: 297000
09-16 06:47:27.536 512 512 W PullResolutionParser: parse resolution + clock 594000 txt: 594000
09-16 06:47:27.538 275 275 D rkdisplay-resources: Frame buffers:
09-16 06:47:27.538 275 275 D rkdisplay-resources: id size pitch
09-16 06:47:27.540 275 275 D rkdisplay-resources: FEATURE:
09-16 06:47:27.540 275 275 D rkdisplay-resources: flags: immutable bitmask
09-16 06:47:27.540 275 275 D rkdisplay-resources: values:afbdc=1
09-16 06:47:27.540 275 275 D rkdisplay-resources: value:0
09-16 06:47:27.540 275 275 D rkdisplay-resources: current_crtc id : 90 crtid : 64
09-16 06:47:27.540 275 275 D rkdisplay-resources: current_crtc id : 98 crtid : 0
09-16 06:47:27.540 275 275 D rkdisplay-resources: Encoders:
09-16 06:47:27.540 275 275 D rkdisplay-resources: id crtc type possible crtcs possible clones
09-16 06:47:27.540 275 275 D rkdisplay-resources: 5a 40 TMDS 1 0
09-16 06:47:27.540 275 275 D rkdisplay-resources: 62 0 TMDS 2 0
09-16 06:47:27.578 424 424 I Zygote : Preloading resources…
09-16 06:47:27.605 424 424 W Resources: Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
09-16 06:47:27.622 424 424 I Zygote : …preloaded 64 resources in 44ms.
09-16 06:47:27.626 424 424 I Zygote : …preloaded 41 resources in 4ms.
09-16 06:47:27.626 424 424 D ZygoteInitTiming_lazy: PreloadResources took to complete: 125ms
09-16 06:47:27.668 512 571 D SystemServerTimingAsync: AppDataPrepare took to complete: 843ms
09-16 06:47:27.668 512 571 I PackageManager: Deferred reconcileAppsData finished 71 packages
09-16 06:47:27.668 512 571 D SystemServerInitThreadPool: Finished executing prepareAppData
09-16 06:47:27.693 424 424 D libEGL : loaded /vendor/lib/egl/libGLES_mali.so
09-16 06:47:27.717 424 424 I Zygote : Preloading shared libraries…
09-16 06:47:27.724 424 424 I Zygote : Uninstalled ICU cache reference pinning…
09-16 06:47:27.725 424 424 I Zygote : Installed AndroidKeyStoreProvider in 0ms.
09-16 06:47:27.732 424 424 I Zygote : Warmed up JCA providers in 6ms.
09-16 06:47:27.732 424 424 D Zygote : end preload
09-16 06:47:27.732 512 527 D SystemServerTimingAsync: SecondaryZygotePreload took to complete: 814ms
09-16 06:47:27.732 512 527 D SystemServerInitThreadPool: Finished executing SecondaryZygotePreload
09-16 06:47:27.749 275 275 D hwc-drm-connector: crtc_id_property_: name CRTC_ID
09-16 06:47:27.967 275 275 D hwc-drm-connector: crtc_id_property_: name CRTC_ID
09-16 06:47:27.967 275 275 W hwc-drm-connector: Could not get hdmi_output_colorimetry property
09-16 06:47:27.968 275 275 W hwc-drm-connector: Could not get hdmi_output_format property
09-16 06:47:27.968 275 275 W hwc-drm-connector: UpdateModes Could not get hdmi_output_colorimetry property
09-16 06:47:27.969 275 275 W hwc-drm-connector: UpdateModes Could not get hdmi_output_format property
09-16 06:47:27.969 275 275 D rkdisplay-resources: hue:
09-16 06:47:27.969 275 275 D rkdisplay-resources: flags: range
09-16 06:47:27.969 275 275 D rkdisplay-resources: values:064
09-16 06:47:27.969 275 275 D rkdisplay-resources: value:32
09-16 06:47:27.969 275 275 D hw_output: nativeInit:
09-16 06:47:27.995 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:28.190 275 275 D hw_output: old_state 1 cur_state 1 conn->get_type() 11
09-16 06:47:28.191 275 275 W hwc-drm-connector: UpdateModes Could not get hdmi_output_colorimetry property
09-16 06:47:28.191 275 275 W hwc-drm-connector: UpdateModes Could not get hdmi_output_format property
09-16 06:47:28.191 275 275 D hw_output: old_state 2 cur_state 2 conn->get_type() 10
09-16 06:47:28.191 275 275 D hw_output: encoderId1: 90
09-16 06:47:28.191 275 275 D hw_output: crtc: 64 0 foundHdmi 1 2222
09-16 06:47:28.191 275 275 D hw_output: primary: 0x710c855000 extend: 0x0
09-16 06:47:28.194 512 512 I SystemServer: StartNotificationManager
09-16 06:47:28.195 512 512 I SystemServiceManager: Starting com.android.server.notification.NotificationManagerService
09-16 06:47:28.213 512 512 D ConditionProviders.SCP: new ScheduleConditionProvider()
09-16 06:47:28.224 512 512 I NotificationListeners: Read notification listener permissions from xml
09-16 06:47:28.224 512 512 I NotificationAssistants: Read notification assistant permissions from xml
09-16 06:47:28.224 512 512 I ConditionProviders: Read condition provider permissions from xml
09-16 06:47:28.225 512 512 I ConditionProviders: Read condition provider permissions from xml
09-16 06:47:28.233 512 512 D SystemServerTiming: StartNotificationManager took to complete: 38ms
09-16 06:47:28.233 512 512 I SystemServer: StartDeviceMonitor
09-16 06:47:28.233 512 512 I SystemServiceManager: Starting com.android.server.storage.DeviceStorageMonitorService
09-16 06:47:28.236 512 512 D SystemServerTiming: StartDeviceMonitor took to complete: 3ms
09-16 06:47:28.236 512 512 I SystemServer: StartLocationManagerService
09-16 06:47:28.238 512 512 D SystemServerTiming: StartLocationManagerService took to complete: 1ms
09-16 06:47:28.238 512 512 I SystemServer: StartCountryDetectorService
09-16 06:47:28.239 512 512 D SystemServerTiming: StartCountryDetectorService took to complete: 1ms
09-16 06:47:28.239 512 512 I SystemServer: StartSearchManagerService
09-16 06:47:28.239 512 512 I SystemServiceManager: Starting com.android.server.search.SearchManagerService$Lifecycle
09-16 06:47:28.241 512 512 D SystemServerTiming: StartSearchManagerService took to complete: 2ms
09-16 06:47:28.241 512 512 I SystemServer: StartWallpaperManagerService
09-16 06:47:28.242 512 512 I SystemServiceManager: Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
09-16 06:47:28.244 512 512 D SystemServerTiming: StartWallpaperManagerService took to complete: 3ms
09-16 06:47:28.244 512 512 I SystemServer: StartAudioService
09-16 06:47:28.244 512 512 I SystemServiceManager: Starting com.android.server.audio.AudioService$Lifecycle
09-16 06:47:28.253 512 512 W TelecomManager: Telecom Service not found.
09-16 06:47:28.255 276 276 D PermissionCache: checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (766 us)
09-16 06:47:28.255 276 346 D PermissionCache: checking android.permission.MODIFY_AUDIO_ROUTING for uid=1000 => granted (484 us)
09-16 06:47:28.257 276 355 W AudioFlinger: no wake lock to update, system not ready yet
09-16 06:47:28.258 257 257 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
09-16 06:47:28.258 257 338 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
09-16 06:47:28.281 276 276 D AudioFlinger: isLowRamDevice:false totalMemory:1986285568 mClientSharedHeapSize:8388608
09-16 06:47:28.282 512 512 D SystemServerTiming: StartAudioService took to complete: 39ms
09-16 06:47:28.283 512 512 I SystemServer: StartDockObserver
09-16 06:47:28.283 512 512 I SystemServiceManager: Starting com.android.server.DockObserver
09-16 06:47:28.283 512 512 W DockObserver: This kernel does not have dock station support
09-16 06:47:28.284 512 512 D SystemServerTiming: StartDockObserver took to complete: 1ms
09-16 06:47:28.284 512 512 I SystemServer: StartWiredAccessoryManager
09-16 06:47:28.285 512 512 W WiredAccessoryManager: This kernel does not have wired headset support
09-16 06:47:28.285 512 512 W WiredAccessoryManager: This kernel does not have usb audio support
09-16 06:47:28.285 512 512 D SystemServerTiming: StartWiredAccessoryManager took to complete: 1ms
09-16 06:47:28.285 512 512 I SystemServer: StartUsbService
09-16 06:47:28.286 512 512 I SystemServiceManager: Starting com.android.server.usb.UsbService$Lifecycle
09-16 06:47:28.287 512 512 E UsbDeviceManager: failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
09-16 06:47:28.288 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.usb.gadget@1.0::IUsbGadget/default in either framework or device manifest.
09-16 06:47:28.292 512 512 I UsbDeviceManager: USB GADGET HAL not present in the device
09-16 06:47:28.292 512 512 I UsbDeviceManager: java.util.NoSuchElementException
09-16 06:47:28.292 512 512 I UsbDeviceManager: at android.os.HwBinder.getService(Native Method)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at android.hardware.usb.gadget.V1_0.IUsbGadget.getService(IUsbGadget.java:40)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at android.hardware.usb.gadget.V1_0.IUsbGadget.getService(IUsbGadget.java:44)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.usb.UsbDeviceManager.(UsbDeviceManager.java:268)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.usb.UsbService.(UsbService.java:139)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.usb.UsbService$Lifecycle.onStart(UsbService.java:73)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:126)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:113)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:72)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.SystemServer.startOtherServices(SystemServer.java:1323)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.SystemServer.run(SystemServer.java:437)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.server.SystemServer.main(SystemServer.java:296)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at java.lang.reflect.Method.invoke(Native Method)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
09-16 06:47:28.292 512 512 I UsbDeviceManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:838)
09-16 06:47:28.292 512 512 E UsbDeviceManagerJNI: could not open control for mtp Permission denied
09-16 06:47:28.292 512 512 E UsbDeviceManager: Failed to open control for mtp
09-16 06:47:28.292 512 512 E UsbDeviceManagerJNI: could not open control for ptp Permission denied
09-16 06:47:28.300 512 512 W StorageManagerService: No primary storage defined yet; hacking together a stub
09-16 06:47:28.304 512 512 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
09-16 06:47:28.306 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.usb@1.0::IUsb/default in either framework or device manifest.
09-16 06:47:28.306 512 512 E UsbPortManager: connectToProxy: usb hal service not found. Did the service fail to start?
09-16 06:47:28.306 512 512 E UsbPortManager: java.util.NoSuchElementException
09-16 06:47:28.306 512 512 E UsbPortManager: at android.os.HwBinder.getService(Native Method)
09-16 06:47:28.306 512 512 E UsbPortManager: at android.os.HwBinder.getService(HwBinder.java:91)
09-16 06:47:28.306 512 512 E UsbPortManager: at android.hardware.usb.V1_0.IUsb.getService(IUsb.java:48)
09-16 06:47:28.306 512 512 E UsbPortManager: at android.hardware.usb.V1_0.IUsb.getService(IUsb.java:52)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.usb.UsbPortManager.connectToProxy(UsbPortManager.java:531)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.usb.UsbPortManager.(UsbPortManager.java:137)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.usb.UsbService.(UsbService.java:142)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.usb.UsbService$Lifecycle.onStart(UsbService.java:73)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:126)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:113)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:72)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.SystemServer.startOtherServices(SystemServer.java:1323)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.SystemServer.run(SystemServer.java:437)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.server.SystemServer.main(SystemServer.java:296)
09-16 06:47:28.306 512 512 E UsbPortManager: at java.lang.reflect.Method.invoke(Native Method)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
09-16 06:47:28.306 512 512 E UsbPortManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:838)
09-16 06:47:28.309 512 512 D SystemServerTiming: StartUsbService took to complete: 24ms
09-16 06:47:28.309 512 512 I SystemServer: StartSerialService
09-16 06:47:28.309 512 512 D SystemServerTiming: StartSerialService took to complete: 1ms
09-16 06:47:28.309 512 512 I SystemServer: StartHardwarePropertiesManagerService
09-16 06:47:28.310 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.thermal@1.0::IThermal/default in either framework or device manifest.
09-16 06:47:28.310 512 512 E HardwarePropertiesManagerService-JNI: Unable to get Thermal service.
09-16 06:47:28.311 512 512 D SystemServerTiming: StartHardwarePropertiesManagerService took to complete: 1ms
09-16 06:47:28.311 512 512 I SystemServer: StartTwilightService
09-16 06:47:28.311 512 512 I SystemServiceManager: Starting com.android.server.twilight.TwilightService
09-16 06:47:28.311 512 512 D SystemServerTiming: StartTwilightService took to complete: 1ms
09-16 06:47:28.311 512 512 I SystemServer: StartJobScheduler
09-16 06:47:28.312 512 512 I SystemServiceManager: Starting com.android.server.job.JobSchedulerService
09-16 06:47:28.316 512 512 D JobStore: Start tag: job-info
09-16 06:47:28.317 512 512 I JobStore: Read 2 jobs
09-16 06:47:28.321 512 512 W JobScheduler: !!! RTC not yet good; tracking time updates for job scheduling
09-16 06:47:28.322 512 512 D SystemServerTiming: StartJobScheduler took to complete: 10ms
09-16 06:47:28.322 512 512 I SystemServer: StartSoundTrigger
09-16 06:47:28.322 512 512 I SystemServiceManager: Starting com.android.server.soundtrigger.SoundTriggerService
09-16 06:47:28.323 512 512 D SystemServerTiming: StartSoundTrigger took to complete: 1ms
09-16 06:47:28.323 512 512 I SystemServer: StartTrustManager
09-16 06:47:28.323 512 512 I SystemServiceManager: Starting com.android.server.trust.TrustManagerService
09-16 06:47:28.324 512 512 D SystemServerTiming: StartTrustManager took to complete: 1ms
09-16 06:47:28.324 512 512 I SystemServer: StartBackupManager
09-16 06:47:28.324 512 512 I SystemServiceManager: Starting com.android.server.backup.BackupManagerService$Lifecycle
09-16 06:47:28.327 512 512 D SystemServerTiming: StartBackupManager took to complete: 4ms
09-16 06:47:28.328 512 512 I SystemServer: StartAppWidgerService
09-16 06:47:28.328 512 512 I SystemServiceManager: Starting com.android.server.appwidget.AppWidgetService
09-16 06:47:28.329 512 512 D OpenGLRenderer: Skia GL Pipeline
09-16 06:47:28.332 512 512 D SystemServerTiming: StartAppWidgerService took to complete: 4ms
09-16 06:47:28.332 512 512 I SystemServer: StartVoiceRecognitionManager
09-16 06:47:28.332 512 512 I SystemServiceManager: Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
09-16 06:47:28.333 512 512 D SystemServerTiming: StartVoiceRecognitionManager took to complete: 1ms
09-16 06:47:28.333 512 512 I SystemServer: StartGestureLauncher
09-16 06:47:28.334 512 512 I SystemServiceManager: Starting com.android.server.GestureLauncherService
09-16 06:47:28.334 512 512 D SystemServerTiming: StartGestureLauncher took to complete: 0ms
09-16 06:47:28.334 512 512 I SystemServer: StartSensorNotification
09-16 06:47:28.334 512 512 I SystemServiceManager: Starting com.android.server.SensorNotificationService
09-16 06:47:28.334 512 512 D SystemServerTiming: StartSensorNotification took to complete: 0ms
09-16 06:47:28.334 512 512 I SystemServer: StartContextHubSystemService
09-16 06:47:28.334 512 512 I SystemServiceManager: Starting com.android.server.ContextHubSystemService
09-16 06:47:28.334 512 512 D SystemServerTiming: StartContextHubSystemService took to complete: 0ms
09-16 06:47:28.334 512 512 I SystemServer: StartDiskStatsService
09-16 06:47:28.334 512 578 D SystemServerInitThreadPool: Started executing Init ContextHubSystemService
09-16 06:47:28.336 512 512 D SystemServerTiming: StartDiskStatsService took to complete: 1ms
09-16 06:47:28.336 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.contexthub@1.0::IContexthub/default in either framework or device manifest.
09-16 06:47:28.336 512 512 I SystemServer: StartNetworkTimeUpdateService
09-16 06:47:28.337 512 578 I ContextHubService: Context Hub HAL service not found
09-16 06:47:28.337 512 578 D SystemServerInitThreadPool: Finished executing Init ContextHubSystemService
09-16 06:47:28.338 512 512 D SystemServerTiming: StartNetworkTimeUpdateService took to complete: 2ms
09-16 06:47:28.338 512 512 I SystemServer: StartCommonTimeManagementService
09-16 06:47:28.339 512 512 D SystemServerTiming: StartCommonTimeManagementService took to complete: 1ms
09-16 06:47:28.339 512 512 I SystemServer: CertBlacklister
09-16 06:47:28.339 512 512 D SystemServerTiming: CertBlacklister took to complete: 1ms
09-16 06:47:28.339 512 512 I SystemServer: StartEmergencyAffordanceService
09-16 06:47:28.340 512 512 I SystemServiceManager: Starting com.android.server.emergency.EmergencyAffordanceService
09-16 06:47:28.340 512 512 D SystemServerTiming: StartEmergencyAffordanceService took to complete: 0ms
09-16 06:47:28.340 512 512 I SystemServer: StartDreamManager
09-16 06:47:28.340 512 512 I SystemServiceManager: Starting com.android.server.dreams.DreamManagerService
09-16 06:47:28.341 512 512 D SystemServerTiming: StartDreamManager took to complete: 1ms
09-16 06:47:28.341 512 512 I SystemServer: AddGraphicsStatsService
09-16 06:47:28.343 512 512 D SystemServerTiming: AddGraphicsStatsService took to complete: 2ms
09-16 06:47:28.344 512 512 I SystemServer: StartPrintManager
09-16 06:47:28.344 512 512 I SystemServiceManager: Starting com.android.server.print.PrintManagerService
09-16 06:47:28.345 512 512 D SystemServerTiming: StartPrintManager took to complete: 2ms
09-16 06:47:28.346 512 512 I SystemServer: StartCompanionDeviceManager
09-16 06:47:28.346 512 512 I SystemServiceManager: Starting com.android.server.companion.CompanionDeviceManagerService
09-16 06:47:28.348 512 512 D SystemServerTiming: StartCompanionDeviceManager took to complete: 2ms
09-16 06:47:28.348 512 512 I SystemServer: StartRestrictionManager
09-16 06:47:28.348 512 512 I SystemServiceManager: Starting com.android.server.restrictions.RestrictionsManagerService
09-16 06:47:28.349 512 512 D SystemServerTiming: StartRestrictionManager took to complete: 1ms
09-16 06:47:28.349 512 512 I SystemServer: StartMediaSessionService
09-16 06:47:28.349 512 512 I SystemServiceManager: Starting com.android.server.media.MediaSessionService
09-16 06:47:28.353 512 512 D SystemServerTiming: StartMediaSessionService took to complete: 4ms
09-16 06:47:28.353 512 512 I SystemServer: StartMediaUpdateService
09-16 06:47:28.353 512 512 I SystemServiceManager: Starting com.android.server.media.MediaUpdateService
09-16 06:47:28.353 512 512 D SystemServerTiming: StartMediaUpdateService took to complete: 0ms
09-16 06:47:28.353 512 512 I SystemServer: StartMediaResourceMonitor
09-16 06:47:28.353 512 512 I SystemServiceManager: Starting com.android.server.media.MediaResourceMonitorService
09-16 06:47:28.354 512 512 D SystemServerTiming: StartMediaResourceMonitor took to complete: 1ms
09-16 06:47:28.354 512 512 I SystemServer: StartMediaRouterService
09-16 06:47:28.355 512 512 D SystemServerTiming: StartMediaRouterService took to complete: 1ms
09-16 06:47:28.355 512 512 I SystemServer: StartBackgroundDexOptService
09-16 06:47:28.355 512 512 W BackgroundDexOptService: SysProp pm.dexopt.downgrade_after_inactive_days not set
09-16 06:47:28.356 512 512 D SystemServerTiming: StartBackgroundDexOptService took to complete: 1ms
09-16 06:47:28.356 512 512 I SystemServer: StartPruneInstantAppsJobService
09-16 06:47:28.356 512 512 D SystemServerTiming: StartPruneInstantAppsJobService took to complete: 0ms
09-16 06:47:28.356 512 512 I SystemServer: StartShortcutServiceLifecycle
09-16 06:47:28.356 512 512 I SystemServiceManager: Starting com.android.server.pm.ShortcutService$Lifecycle
09-16 06:47:28.359 512 512 D SystemServerTiming: StartShortcutServiceLifecycle took to complete: 3ms
09-16 06:47:28.359 512 512 I SystemServer: StartLauncherAppsService
09-16 06:47:28.359 512 512 I SystemServiceManager: Starting com.android.server.pm.LauncherAppsService
09-16 06:47:28.360 512 512 D SystemServerTiming: StartLauncherAppsService took to complete: 1ms
09-16 06:47:28.360 512 512 I SystemServer: StartCrossProfileAppsService
09-16 06:47:28.360 512 512 I SystemServiceManager: Starting com.android.server.pm.CrossProfileAppsService
09-16 06:47:28.361 512 512 D SystemServerTiming: StartCrossProfileAppsService took to complete: 1ms
09-16 06:47:28.361 512 512 I SystemServer: StartMediaProjectionManager
09-16 06:47:28.361 512 512 I SystemServiceManager: Starting com.android.server.media.projection.MediaProjectionManagerService
09-16 06:47:28.363 512 512 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
09-16 06:47:28.365 512 512 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
09-16 06:47:28.366 512 512 D SystemServerTiming: StartMediaProjectionManager took to complete: 5ms
09-16 06:47:28.366 512 512 I SystemServer: StartSliceManagerService
09-16 06:47:28.366 512 512 I SystemServiceManager: Starting com.android.server.slice.SliceManagerService$Lifecycle
09-16 06:47:28.368 512 512 D SystemServerTiming: StartSliceManagerService took to complete: 3ms
09-16 06:47:28.369 512 512 I SystemServer: StartCameraServiceProxy
09-16 06:47:28.369 512 512 I SystemServiceManager: Starting com.android.server.camera.CameraServiceProxy
09-16 06:47:28.371 512 512 D SystemServerTiming: StartCameraServiceProxy took to complete: 2ms
09-16 06:47:28.371 512 512 I SystemServer: StartStatsCompanionService
09-16 06:47:28.371 512 512 I SystemServiceManager: Starting com.android.server.stats.StatsCompanionService$Lifecycle
09-16 06:47:28.373 512 512 I KernelUidCpuFreqTimeReader: mPerClusterTimesAvailable=false
09-16 06:47:28.373 235 235 E SELinux : avc: denied { find } for service=thermalservice pid=512 uid=1000 scontext=u:r:system_server:s0 tcontext=u:object_r:thermal_service:s0 tclass=service_manager permissive=1
09-16 06:47:28.374 512 512 I StatsCompanionService: register thermal listener successfully
09-16 06:47:28.375 512 512 D SystemServerTiming: StartStatsCompanionService took to complete: 4ms
09-16 06:47:28.375 512 512 I WindowManager: SAFE MODE not enabled
09-16 06:47:28.375 512 512 I SystemServer: StartJitCompilation
09-16 06:47:28.376 512 512 D SystemServerTiming: StartJitCompilation took to complete: 0ms
09-16 06:47:28.376 512 512 I SystemServer: StartMmsService
09-16 06:47:28.376 512 512 I SystemServiceManager: Starting com.android.server.MmsServiceBroker
09-16 06:47:28.377 512 512 D SystemServerTiming: StartMmsService took to complete: 1ms
09-16 06:47:28.377 512 512 I SystemServer: StartAutoFillService
09-16 06:47:28.377 512 512 I SystemServiceManager: Starting com.android.server.autofill.AutofillManagerService
09-16 06:47:28.379 512 512 I AutofillManagerService: Setting debug to true
09-16 06:47:28.382 512 512 D SystemServerTiming: StartAutoFillService took to complete: 5ms
09-16 06:47:28.382 512 512 I SystemServer: MakeVibratorServiceReady
09-16 06:47:28.383 512 512 D SystemServerTiming: MakeVibratorServiceReady took to complete: 2ms
09-16 06:47:28.384 512 512 I SystemServer: MakeLockSettingsServiceReady
09-16 06:47:28.402 512 512 E LockSettingsService: Unable to acquire GateKeeperService
09-16 06:47:28.404 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.weaver@1.0::IWeaver/default in either framework or device manifest.
09-16 06:47:28.404 512 512 I SyntheticPasswordManager: Device does not support weaver
09-16 06:47:28.405 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.authsecret@1.0::IAuthSecret/default in either framework or device manifest.
09-16 06:47:28.405 512 512 I LockSettingsService: Device doesn’t implement AuthSecret HAL
09-16 06:47:28.407 512 512 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.password.key: open failed: ENOENT (No such file or directory)
09-16 06:47:28.407 512 512 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
09-16 06:47:28.407 512 512 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.pattern.key: open failed: ENOENT (No such file or directory)
09-16 06:47:28.407 512 512 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
09-16 06:47:28.407 512 512 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
09-16 06:47:28.408 512 512 D SystemServerTiming: MakeLockSettingsServiceReady took to complete: 24ms
09-16 06:47:28.408 512 512 I SystemServer: StartBootPhaseLockSettingsReady
09-16 06:47:28.408 512 512 I SystemServiceManager: Starting phase 480
09-16 06:47:28.412 512 512 I DevicePolicyManager: Set ro.device_owner property to false
09-16 06:47:28.414 512 579 D SystemServerInitThreadPool: Started executing DevicePolicyManager
09-16 06:47:28.414 512 579 D SystemServerInitThreadPool: Finished executing DevicePolicyManager
09-16 06:47:28.415 512 512 W ShortcutService: Clock rewound
09-16 06:47:28.416 512 512 D SystemServerTiming: StartBootPhaseLockSettingsReady took to complete: 8ms
09-16 06:47:28.416 512 512 I SystemServer: StartBootPhaseSystemServicesReady
09-16 06:47:28.416 512 512 I SystemServiceManager: Starting phase 500
09-16 06:47:28.417 512 512 D AppStandbyController: Setting app idle enabled state
09-16 06:47:28.424 512 520 W System : A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
09-16 06:47:28.425 512 520 W System : java.lang.Throwable: Explicit termination method ‘close’ not called
09-16 06:47:28.425 512 520 W System : at dalvik.system.CloseGuard.open(CloseGuard.java:221)
09-16 06:47:28.425 512 520 W System : at java.io.FileInputStream.(FileInputStream.java:168)
09-16 06:47:28.425 512 520 W System : at com.android.internal.os.AtomicFile.openRead(AtomicFile.java:147)
09-16 06:47:28.425 512 520 W System : at com.android.server.storage.CacheQuotaStrategy.setupQuotasFromFile(CacheQuotaStrategy.java:301)
09-16 06:47:28.425 512 520 W System : at com.android.server.usage.StorageStatsService$H.handleMessage(StorageStatsService.java:508)
09-16 06:47:28.425 512 520 W System : at android.os.Handler.dispatchMessage(Handler.java:106)
09-16 06:47:28.425 512 520 W System : at android.os.Looper.loop(Looper.java:193)
09-16 06:47:28.425 512 520 W System : at android.os.HandlerThread.run(HandlerThread.java:65)
09-16 06:47:28.425 512 520 W System : at com.android.server.ServiceThread.run(ServiceThread.java:44)
09-16 06:47:28.425 512 528 E AppIdleHistory: Unable to read app idle file for user 0
09-16 06:47:28.432 512 512 I WifiService: WifiService starting up with Wi-Fi disabled
09-16 06:47:28.437 512 608 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
09-16 06:47:28.438 512 580 D HalDevMgr: IWifi registration notification: fqName=android.hardware.wifi@1.0::IWifi, name=default, preexisting=true
09-16 06:47:28.439 512 608 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hardware.wifi@1.0::IWifi
09-16 06:47:28.441 512 608 D WificondControl: tearing down interfaces in wificond
09-16 06:47:28.443 512 512 I WifiScanningService: Starting wifiscanner
09-16 06:47:28.452 512 512 I EthernetServiceImpl: Starting Ethernet service
09-16 06:47:28.458 512 512 D Ethernet: Registering NetworkFactory
09-16 06:47:28.459 512 612 D ConnectivityService: Got NetworkFactory Messenger for Ethernet
09-16 06:47:28.459 512 512 E IpConfigStore: Error opening configuration file: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory)
09-16 06:47:28.459 512 633 D Ethernet: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
09-16 06:47:28.461 512 512 V AlarmManager: setImplLocked type=3 ,when=660000
09-16 06:47:28.462 512 633 I EthernetTracker: maybeTrackInterface can0
09-16 06:47:28.462 512 633 I EthernetTracker: maybeTrackInterface eth0
09-16 06:47:28.464 434 488 D CommandListener: Setting iface cfg
09-16 06:47:28.464 434 488 D CommandListener: Trying to bring up eth0
09-16 06:47:28.465 276 276 D PermissionCache: checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (138 us)
09-16 06:47:28.466 512 512 W SoundTriggerHelper: listModules status=0, # of modules=0
09-16 06:47:28.469 512 512 D ContextHubSystemService: onBootPhase: PHASE_SYSTEM_SERVICES_READY
09-16 06:47:28.470 512 512 D SystemServerTiming: StartBootPhaseSystemServicesReady took to complete: 54ms
09-16 06:47:28.470 512 512 I SystemServer: MakeWindowManagerServiceReady
09-16 06:47:28.474 512 512 I android_os_HwBinder: HwBinder: Starting thread pool for default::android.hardware.configstore@1.0::ISurfaceFlingerConfigs
09-16 06:47:28.475 512 512 D SystemServerTiming: MakeWindowManagerServiceReady took to complete: 5ms
09-16 06:47:28.476 512 512 I SystemServer: MakePowerManagerServiceReady
09-16 06:47:28.481 512 608 D WifiStateMachinePrime: received a message in WifiDisabledState: { when=0 what=3 target=com.android.internal.util.StateMachine$SmHandler }
09-16 06:47:28.481 512 608 D WifiStateMachinePrime: Switching from WifiDisabledState to WifiDisabled
09-16 06:47:28.481 512 608 D WifiStateMachinePrime: Entering WifiDisabledState
09-16 06:47:28.481 512 608 D ActiveModeManager: sending scan available broadcast: false
09-16 06:47:28.490 512 539 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
09-16 06:47:28.492 512 512 D SystemServerTiming: MakePowerManagerServiceReady took to complete: 16ms
09-16 06:47:28.492 512 512 I SystemServer: MakePackageManagerServiceReady
09-16 06:47:28.499 512 535 I EthernetTracker: interfaceLinkStateChanged, iface: eth0, up: true
09-16 06:47:28.501 512 633 D EthernetTracker: Started tracking interface eth0
09-16 06:47:28.501 512 633 D EthernetNetworkFactory: addInterface, iface: eth0, capabilities: [ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&NOT_CONGESTED Unwanted: LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
09-16 06:47:28.503 512 512 V UserDataPreparer: Found /data/user_de/0 with serial number 0
09-16 06:47:28.503 512 512 V UserDataPreparer: Found /data/user/0 with serial number 0
09-16 06:47:28.503 512 512 V UserDataPreparer: Found /data/system_de/0 with serial number 0
09-16 06:47:28.503 512 512 V UserDataPreparer: Found /data/system_ce/0 with serial number 0
09-16 06:47:28.503 512 512 V UserDataPreparer: Found /data/misc_ce/0 with serial number 0
09-16 06:47:28.503 512 633 D EthernetNetworkFactory: updateCapabilityFilter: [ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&NOT_CONGESTED Unwanted: LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
09-16 06:47:28.503 512 633 D EthernetNetworkFactory: updateInterfaceLinkState, iface: eth0, up: true
09-16 06:47:28.503 512 512 D SystemServerTiming: MakePackageManagerServiceReady took to complete: 10ms
09-16 06:47:28.503 512 633 D EthernetNetworkFactory: starting IpClient(eth0): mNetworkInfo=[type: Ethernet, state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
09-16 06:47:28.503 512 512 I SystemServer: MakeDisplayManagerServiceReady
09-16 06:47:28.503 512 512 D SystemServerTiming: MakeDisplayManagerServiceReady took to complete: 0ms
09-16 06:47:28.503 512 512 I SystemServer: StartDeviceSpecificServices
09-16 06:47:28.504 512 512 D SystemServerTiming: StartDeviceSpecificServices took to complete: 0ms
09-16 06:47:28.504 512 512 I SystemServer: StartBootPhaseDeviceSpecificServicesReady
09-16 06:47:28.504 512 512 I SystemServiceManager: Starting phase 520
09-16 06:47:28.504 512 512 D SystemServerTiming: StartBootPhaseDeviceSpecificServicesReady took to complete: 0ms
09-16 06:47:28.505 512 512 W UsageStatsService: Event reported without a package name
09-16 06:47:28.506 512 512 I AppOps : Pruning old package system/com.android.server.AppOpsService$UidState@bacca57: new uid=-1
09-16 06:47:28.506 512 512 D ActivityManager: OK, system ready!
09-16 06:47:28.507 512 512 I ActivityManager: System now ready
09-16 06:47:28.508 512 610 E WifiP2pService: Ignore P2P enable since wifi is disabled
09-16 06:47:28.513 512 512 I SystemServer: Making services ready
09-16 06:47:28.513 434 488 D CommandListener: Clearing all IP addresses on eth0
09-16 06:47:28.513 512 512 I SystemServer: StartActivityManagerReadyPhase
09-16 06:47:28.513 512 512 I SystemServiceManager: Starting phase 550
09-16 06:47:28.516 512 633 D EthernetNetworkFactory: updateInterfaceLinkState, iface: eth0, up: true
09-16 06:47:28.516 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 0
09-16 06:47:28.517 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet, state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {LinkAddresses: Routes: DnsAddresses: UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
09-16 06:47:28.517 512 633 D EthernetNetworkFactory: IpClient already started
09-16 06:47:28.518 512 512 W ActivityManager: Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
09-16 06:47:28.534 512 512 D BluetoothManagerService: Bluetooth boot completed
09-16 06:47:28.534 512 512 D BluetoothManagerService: Getting adapter name and address
09-16 06:47:28.535 512 536 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
09-16 06:47:28.535 512 536 D BluetoothManagerService: Binding to service to get name and address
09-16 06:47:28.546 512 641 D DhcpClient: Receive thread started
09-16 06:47:28.548 512 637 D DhcpClient: Broadcasting DHCPDISCOVER
09-16 06:47:28.548 640 640 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.549 512 531 I ActivityManager: Start proc 640:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
09-16 06:47:28.549 512 637 V AlarmManager: setImplLocked type=2 ,when=11909
09-16 06:47:28.590 640 640 I droid.bluetoot: The ClassLoaderContext is a special shared library.
09-16 06:47:28.595 640 640 I droid.bluetoot: The ClassLoaderContext is a special shared library.
09-16 06:47:28.600 512 512 W SystemServiceManager: Service com.android.server.InputMethodManagerService$Lifecycle took 62 ms in onBootPhase
09-16 06:47:28.600 512 601 D StorageManagerService: Thinking about init, mSystemReady=true, mDaemonConnected=true
09-16 06:47:28.600 512 601 D StorageManagerService: Setting up emulation state, initlocked=false
09-16 06:47:28.601 244 250 D vold : e4crypt_unlock_user_key 0 serial=0 token_present=0
09-16 06:47:28.602 512 601 D StorageManagerService: Thinking about reset, mSystemReady=true, mDaemonConnected=true
09-16 06:47:28.603 512 529 I ActivityManager: Force stopping com.android.providers.media appid=10012 user=-1: vold reset
09-16 06:47:28.605 512 512 I WallpaperManagerService: No static wallpaper imagery; defaults will be shown
09-16 06:47:28.605 512 523 V StorageManagerService: Found primary storage at VolumeInfo{emulated}:
09-16 06:47:28.605 512 523 V StorageManagerService: type=EMULATED diskId=null partGuid= mountFlags=0 mountUserId=-1
09-16 06:47:28.605 512 523 V StorageManagerService: state=UNMOUNTED
09-16 06:47:28.605 512 523 V StorageManagerService: fsType=null fsUuid=null fsLabel=null
09-16 06:47:28.605 512 523 V StorageManagerService: path=null internalPath=null
09-16 06:47:28.606 512 512 E BitmapFactory: Unable to decode stream: java.io.FileNotFoundException: /data/system/users/0/wallpaper_orig (No such file or directory)
09-16 06:47:28.606 512 512 W WallpaperManagerService: Invalid wallpaper data
09-16 06:47:28.606 512 512 E WallpaperManagerService: Unable to apply new wallpaper
09-16 06:47:28.607 257 257 D AudioHardwareTiny: adev_set_parameters: kvpairs = A2dpSuspended=false
09-16 06:47:28.608 512 623 I AudioService: setBluetoothScoOnInt: false resetBluetoothSco
09-16 06:47:28.608 257 257 D AudioHardwareTiny: adev_set_parameters: kvpairs = BT_SCO=off
09-16 06:47:28.609 512 512 D SystemServerTiming: StartActivityManagerReadyPhase took to complete: 96ms
09-16 06:47:28.610 512 623 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
09-16 06:47:28.611 512 512 I SystemServer: StartObservingNativeCrashes
09-16 06:47:28.611 244 250 V vold : Waiting for FUSE to spin up…
09-16 06:47:28.611 512 531 I ActivityManager: Start proc 656:com.android.inputmethod.latin/u0a42 for service com.android.inputmethod.latin/.LatinIME
09-16 06:47:28.612 512 512 D SystemServerTiming: StartObservingNativeCrashes took to complete: 1ms
09-16 06:47:28.612 512 512 I SystemServer: StartSystemUI
09-16 06:47:28.612 512 571 D SystemServerInitThreadPool: Started executing WebViewFactoryPreparation
09-16 06:47:28.613 656 656 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.613 512 571 I SystemServer: WebViewFactoryPreparation
09-16 06:47:28.614 512 512 D SystemServerTiming: StartSystemUI took to complete: 2ms
09-16 06:47:28.614 512 512 I SystemServer: MakeNetworkManagementServiceReady
09-16 06:47:28.614 276 276 I AudioFlinger: systemReady
09-16 06:47:28.614 512 512 D NetworkManagement: enabling bandwidth control
09-16 06:47:28.628 512 571 D WebViewLibraryLoader: Setting new address space to 147551200
09-16 06:47:28.628 512 657 D UsbHostManager: USB device attached: vidpid 2207:180a mfg/product/ver/serial RockChip/USB-MSC/1.00/rockchip纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮 hasAudio/HID/Storage: false/false/false
09-16 06:47:28.633 512 531 I ActivityManager: Start proc 670:com.android.systemui/u0a25 for service com.android.systemui/.SystemUIService
09-16 06:47:28.633 512 571 D SystemServerTimingAsync: WebViewFactoryPreparation took to complete: 20ms
09-16 06:47:28.633 512 571 D SystemServerInitThreadPool: Finished executing WebViewFactoryPreparation
09-16 06:47:28.635 512 657 D UsbDeviceDescriptor: 1 configs
09-16 06:47:28.637 512 657 D UsbHostManager: Added device UsbDevice[mName=/dev/bus/usb/005/003,mVendorId=8711,mProductId=6154,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=RockChip,mProductName=USB-MSC,mVersion=1.00,mSerialNumber=rockchip纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮纮,mConfigurations=[
09-16 06:47:28.637 512 657 D UsbHostManager: UsbConfiguration[mId=1,mName=null,mAttributes=128,mMaxPower=200,mInterfaces=[
09-16 06:47:28.637 512 657 D UsbHostManager: UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=255,mSubclass=6,mProtocol=5,mEndpoints=[
09-16 06:47:28.637 512 657 D UsbHostManager: UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=512,mInterval=0]
09-16 06:47:28.637 512 657 D UsbHostManager: UsbEndpoint[mAddress=1,mAttributes=2,mMaxPacketSize=512,mInterval=0]]]]
09-16 06:47:28.640 661 661 W sdcard : Device explicitly enabled sdcardfs
09-16 06:47:28.640 512 512 W NetworkManagement: setDataSaverMode(): already false
09-16 06:47:28.642 512 512 D SystemServerTiming: MakeNetworkManagementServiceReady took to complete: 28ms
09-16 06:47:28.642 512 512 I SystemServer: MakeIpSecServiceReady
09-16 06:47:28.644 512 533 E BatteryExternalStatsWorker: no controller energy info supplied for wifi
09-16 06:47:28.644 512 533 E BatteryExternalStatsWorker: no controller energy info supplied for telephony
09-16 06:47:28.645 670 670 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.647 512 512 D IpSecService: IpSecService is ready
09-16 06:47:28.647 512 512 D SystemServerTiming: MakeIpSecServiceReady took to complete: 4ms
09-16 06:47:28.647 512 512 I SystemServer: MakeNetworkStatsServiceReady
09-16 06:47:28.648 431 465 E linker : library “/system/lib64/extractors/..” (“/system/lib64”) needed or dlopened by “/system/lib64/libstagefright.so” is not accessible for the namespace: [name=“(default)”, ld_library_paths=“”, default_library_paths=“/system/lib64”, permitted_paths=“/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand”]
09-16 06:47:28.648 431 465 W MediaExtractorFactory: couldn’t dlopen(/system/lib64/extractors/..) Permission denied
09-16 06:47:28.648 512 605 W NetworkPolicy: setRestrictBackgroundUL: already false
09-16 06:47:28.650 512 512 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:28.651 431 465 W MediaExtractorFactory: couldn’t dlopen(/system/lib64/extractors/.) Is a directory
09-16 06:47:28.662 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:28.666 512 512 V AlarmManager: setImplLocked type=3 ,when=10169
09-16 06:47:28.672 512 512 D SystemServerTiming: MakeNetworkStatsServiceReady took to complete: 25ms
09-16 06:47:28.672 512 512 I SystemServer: MakeConnectivityServiceReady
09-16 06:47:28.675 512 512 D PermissionMonitor: Monitoring
09-16 06:47:28.676 512 633 D Ethernet: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
09-16 06:47:28.686 512 512 D PermissionMonitor: Users: 1, Apps: 70
09-16 06:47:28.690 656 656 I putmethod.lati: The ClassLoaderContext is a special shared library.
09-16 06:47:28.693 512 512 D SystemServerTiming: MakeConnectivityServiceReady took to complete: 20ms
09-16 06:47:28.693 512 512 I SystemServer: MakeNetworkPolicyServiceReady
09-16 06:47:28.693 512 512 D SystemServerTiming: MakeNetworkPolicyServiceReady took to complete: 0ms
09-16 06:47:28.693 512 512 I SystemServer: StartWatchdog
09-16 06:47:28.693 512 512 D SystemServerTiming: StartWatchdog took to complete: 1ms
09-16 06:47:28.693 512 512 I SystemServer: PhaseThirdPartyAppsCanStart
09-16 06:47:28.694 512 512 I SystemServiceManager: Starting phase 600
09-16 06:47:28.695 431 465 E MediaExtractorFactory: couldn’t opendir(/vendor/lib64/extractors)
09-16 06:47:28.695 512 512 E LightsService: Light requested not available on this device. 4
09-16 06:47:28.697 656 656 I putmethod.lati: The ClassLoaderContext is a special shared library.
09-16 06:47:28.697 512 512 V WallpaperManagerService: bindWallpaperComponentLocked: componentName=ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
09-16 06:47:28.703 281 281 W npu_upgrade: type=1400 audit(0.0:240): avc: denied { append } for name=“npu.log” dev=“dm-0” ino=1919 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
09-16 06:47:28.703 281 281 W npu_upgrade: type=1400 audit(0.0:241): avc: denied { open } for path=“/data/npu.log” dev=“dm-0” ino=1919 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
09-16 06:47:28.710 512 512 V AlarmManager: setImplLocked type=2 ,when=8267207
09-16 06:47:28.710 512 512 V AlarmManager: setImplLocked type=2 ,when=94667207
09-16 06:47:28.711 512 512 V AlarmManager: setImplLocked type=2 ,when=10215
09-16 06:47:28.711 512 512 V AlarmManager: setImplLocked type=2 ,when=86409860
09-16 06:47:28.711 512 593 V AlarmManager: setImplLocked type=3 ,when=1810169
09-16 06:47:28.713 433 496 D StagefrightPluginLoader: Failed to load library: libstagefright_ccodec.so (dlopen failed: library “libstagefright_ccodec.so” not found)
09-16 06:47:28.713 433 496 D StagefrightPluginLoader: Handle or CreateInputSurface symbol is null
09-16 06:47:28.715 512 512 V AlarmManager: setImplLocked type=2 ,when=10215
09-16 06:47:28.715 512 604 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:28.715 512 512 V AlarmManager: setImplLocked type=2 ,when=10219
09-16 06:47:28.716 512 512 V AlarmManager: setImplLocked type=2 ,when=86409839
09-16 06:47:28.717 433 496 D StagefrightPluginLoader: Handle or CreateBuilder symbol is null
09-16 06:47:28.717 512 512 V AlarmManager: setImplLocked type=2 ,when=10221
09-16 06:47:28.717 512 512 V AlarmManager: setImplLocked type=2 ,when=43210041
09-16 06:47:28.718 512 512 V AlarmManager: setImplLocked type=2 ,when=69860
09-16 06:47:28.723 512 604 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:28.727 670 670 I ndroid.systemu: The ClassLoaderContext is a special shared library.
09-16 06:47:28.727 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:28.728 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.729 438 438 I OMXMaster: makeComponentInstance(OMX.google.aac.decoder) in omx@1.0-service process
09-16 06:47:28.731 640 640 V AdapterServiceConfig: Adding A2dpService
09-16 06:47:28.735 640 640 V AdapterServiceConfig: Adding HidHostService
09-16 06:47:28.735 640 640 V AdapterServiceConfig: Adding PanService
09-16 06:47:28.735 640 640 V AdapterServiceConfig: Adding GattService
09-16 06:47:28.735 640 640 V AdapterServiceConfig: Adding AvrcpTargetService
09-16 06:47:28.735 640 640 V AdapterServiceConfig: Adding HidDeviceService
09-16 06:47:28.735 640 640 V AdapterServiceConfig: Adding BluetoothOppService
09-16 06:47:28.738 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.739 438 438 I OMXMaster: makeComponentInstance(OMX.google.amrnb.decoder) in omx@1.0-service process
09-16 06:47:28.743 699 699 W upgrade_tool: type=1400 audit(0.0:242): avc: denied { read } for name=“busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
09-16 06:47:28.743 699 699 W upgrade_tool: type=1400 audit(0.0:243): avc: denied { open } for path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.12.auto/usb3/busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
09-16 06:47:28.743 699 699 W upgrade_tool: type=1400 audit(0.0:244): avc: denied { getattr } for path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.12.auto/usb3/busnum” dev=“sysfs” ino=23456 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
09-16 06:47:28.748 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.748 438 475 I OMXMaster: makeComponentInstance(OMX.google.amrwb.decoder) in omx@1.0-service process
09-16 06:47:28.748 512 512 I StatsCompanionService: Told statsd that StatsCompanionService is alive.
09-16 06:47:28.751 512 512 D SystemServerTiming: PhaseThirdPartyAppsCanStart took to complete: 57ms
09-16 06:47:28.751 512 512 I SystemServer: MakeLocationServiceReady
09-16 06:47:28.754 512 531 W ActivityManager: Slow operation: 122ms so far, now at startProcess: returned from zygote!
09-16 06:47:28.755 512 531 W ActivityManager: Slow operation: 123ms so far, now at startProcess: done updating battery stats
09-16 06:47:28.755 512 531 W ActivityManager: Slow operation: 123ms so far, now at startProcess: building log message
09-16 06:47:28.755 512 531 I ActivityManager: Start proc 708:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
09-16 06:47:28.755 512 531 W ActivityManager: Slow operation: 123ms so far, now at startProcess: starting to update pids map
09-16 06:47:28.755 512 531 W ActivityManager: Slow operation: 123ms so far, now at startProcess: done updating pids map
09-16 06:47:28.755 512 531 W ActivityManager: Slow operation: 123ms so far, now at startProcess: asking zygote to start proc
09-16 06:47:28.757 656 656 I LatinIME: Hardware accelerated drawing: true
09-16 06:47:28.757 708 708 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.762 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.gnss@1.1::IGnss/default in either framework or device manifest.
09-16 06:47:28.762 512 512 D GnssLocationProvider: gnssHal 1.1 was null, trying 1.0
09-16 06:47:28.763 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.gnss@1.0::IGnss/default in either framework or device manifest.
09-16 06:47:28.764 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.765 438 475 I OMXMaster: makeComponentInstance(OMX.google.flac.decoder) in omx@1.0-service process
09-16 06:47:28.765 512 657 D UsbHostManager: USB device attached: vidpid 413c:2113 mfg/product/ver/serial null/Dell KB216 Wired Keyboard/33.08/null hasAudio/HID/Storage: false/true/false
09-16 06:47:28.768 512 512 W LocationManagerService: no network location provider found
09-16 06:47:28.768 512 657 D UsbDeviceDescriptor: 1 configs
09-16 06:47:28.769 512 657 D UsbHostManager: Added device UsbDevice[mName=/dev/bus/usb/001/004,mVendorId=16700,mProductId=8467,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=null,mProductName=Dell KB216 Wired Keyboard,mVersion=33.08,mSerialNumber=null,mConfigurations=[
09-16 06:47:28.769 512 657 D UsbHostManager: UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
09-16 06:47:28.769 512 657 D UsbHostManager: UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=1,mEndpoints=[
09-16 06:47:28.769 512 657 D UsbHostManager: UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=8,mInterval=10]]
09-16 06:47:28.769 512 657 D UsbHostManager: UsbInterface[mId=1,mAlternateSetting=0,mName=null,mClass=3,mSubclass=0,mProtocol=0,mEndpoints=[
09-16 06:47:28.769 512 657 D UsbHostManager: UsbEndpoint[mAddress=130,mAttributes=3,mMaxPacketSize=8,mInterval=10]]]]
09-16 06:47:28.772 715 715 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.772 512 657 D UsbHostManager: USB device attached: vidpid 1a40:0101 mfg/product/ver/serial null/USB 2.0 Hub [MTT]/1.00/null hasAudio/HID/Storage: false/false/false
09-16 06:47:28.774 512 512 E LocationManagerService: no geocoder provider found
09-16 06:47:28.776 512 531 W ActivityManager: Slow operation: 144ms so far, now at startProcess: returned from zygote!
09-16 06:47:28.776 512 657 D UsbHostManager: USB device attached: vidpid 24ae:1813 mfg/product/ver/serial RAPOO/Rapoo 2.4G Wireless Device/1.10/null hasAudio/HID/Storage: false/true/false
09-16 06:47:28.778 512 512 D LocationManagerService: Unable to bind FLP Geofence proxy.
09-16 06:47:28.778 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: done updating battery stats
09-16 06:47:28.778 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: building log message
09-16 06:47:28.778 512 512 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. is_supported is effectively a no-op
09-16 06:47:28.778 512 531 I ActivityManager: Start proc 715:WebViewLoader-arm64-v8a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
09-16 06:47:28.778 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: starting to update pids map
09-16 06:47:28.778 512 512 D LocationManagerService: Hardware Activity-Recognition not supported.
09-16 06:47:28.778 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: done updating pids map
09-16 06:47:28.778 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.779 438 475 I OMXMaster: makeComponentInstance(OMX.google.g711.alaw.decoder) in omx@1.0-service process
09-16 06:47:28.779 512 512 E ActivityRecognitionProxy: ServiceWatcher could not start.
09-16 06:47:28.779 512 512 D LocationManagerService: Unable to bind ActivityRecognitionProxy.
09-16 06:47:28.780 512 657 D UsbDeviceDescriptor: 1 configs
09-16 06:47:28.780 512 657 D UsbHostManager: Added device UsbDevice[mName=/dev/bus/usb/001/003,mVendorId=9390,mProductId=6163,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=RAPOO,mProductName=Rapoo 2.4G Wireless Device,mVersion=1.10,mSerialNumber=null,mConfigurations=[
09-16 06:47:28.780 512 657 D UsbHostManager: UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
09-16 06:47:28.780 512 657 D UsbHostManager: UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=1,mEndpoints=[
09-16 06:47:28.780 512 657 D UsbHostManager: UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=64,mInterval=10]]
09-16 06:47:28.780 512 657 D UsbHostManager: UsbInterface[mId=1,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=2,mEndpoints=[
09-16 06:47:28.780 512 657 D UsbHostManager: UsbEndpoint[mAddress=130,mAttributes=3,mMaxPacketSize=64,mInterval=10]]]]
09-16 06:47:28.786 512 512 D SystemServerTiming: MakeLocationServiceReady took to complete: 34ms
09-16 06:47:28.786 512 512 I SystemServer: MakeCountryDetectionServiceReady
09-16 06:47:28.786 512 512 D SystemServerTiming: MakeCountryDetectionServiceReady took to complete: 0ms
09-16 06:47:28.786 512 512 I SystemServer: MakeNetworkTimeUpdateReady
09-16 06:47:28.790 512 512 D ConnectivityService: requestNetwork for uid/pid:1000/512 NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ]
09-16 06:47:28.791 512 512 D SystemServerTiming: MakeNetworkTimeUpdateReady took to complete: 5ms
09-16 06:47:28.791 512 512 I SystemServer: MakeCommonTimeManagementServiceReady
09-16 06:47:28.791 512 633 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
09-16 06:47:28.791 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ], score: 0
09-16 06:47:28.792 512 512 I CommonTimeManagementService: No common time service detected on this platform. Common time services will be unavailable.
09-16 06:47:28.792 512 512 D SystemServerTiming: MakeCommonTimeManagementServiceReady took to complete: 1ms
09-16 06:47:28.792 512 512 I SystemServer: MakeInputManagerServiceReady
09-16 06:47:28.792 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet, state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,] Routes: [fe80::/64 → :: eth0,] DnsAddresses: UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:28.793 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.793 438 475 I OMXMaster: makeComponentInstance(OMX.google.g711.mlaw.decoder) in omx@1.0-service process
09-16 06:47:28.794 512 512 D SystemServerTiming: MakeInputManagerServiceReady took to complete: 2ms
09-16 06:47:28.794 512 512 I SystemServer: MakeTelephonyRegistryReady
09-16 06:47:28.794 512 599 I InputReader: Reconfiguring input devices. changes=0x00000020
09-16 06:47:28.794 734 734 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.795 512 512 D SystemServerTiming: MakeTelephonyRegistryReady took to complete: 1ms
09-16 06:47:28.795 512 512 I SystemServer: MakeMediaRouterServiceReady
09-16 06:47:28.795 512 679 W ZygoteProcess: Got error connecting to zygote, retrying. msg= Connection refused
09-16 06:47:28.796 512 512 D SystemServerTiming: MakeMediaRouterServiceReady took to complete: 1ms
09-16 06:47:28.796 512 512 I SystemServer: MakeMmsServiceReady
09-16 06:47:28.797 512 512 I MmsServiceBroker: Delay connecting to MmsService until an API is called
09-16 06:47:28.797 512 512 D SystemServerTiming: MakeMmsServiceReady took to complete: 0ms
09-16 06:47:28.797 512 512 I SystemServer: IncidentDaemonReady
09-16 06:47:28.798 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.798 512 512 D SystemServerTiming: IncidentDaemonReady took to complete: 1ms
09-16 06:47:28.798 512 512 I SystemServiceManager: Calling onStartUser u0
09-16 06:47:28.798 438 438 I OMXMaster: makeComponentInstance(OMX.google.mp3.decoder) in omx@1.0-service process
09-16 06:47:28.801 512 599 I InputReader: Reconfiguring input devices. changes=0x00000010
09-16 06:47:28.803 734 734 I WebViewZygoteInit: Starting WebViewZygoteInit
09-16 06:47:28.803 734 734 I WebViewZygoteInit: --zygote-socket=com.android.internal.os.WebViewZygoteInit/0e486de8-e088-4ebe-bd8b-d9124eca348d
09-16 06:47:28.804 512 512 W VoiceInteractionManagerService: no available voice interaction services found for user 0
09-16 06:47:28.805 512 512 W VoiceInteractionManagerService: no available voice recognition services found for user 0
09-16 06:47:28.811 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.811 438 438 I OMXMaster: makeComponentInstance(OMX.google.opus.decoder) in omx@1.0-service process
09-16 06:47:28.811 512 512 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0
09-16 06:47:28.824 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.824 438 475 I OMXMaster: makeComponentInstance(OMX.google.raw.decoder) in omx@1.0-service process
09-16 06:47:28.830 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.830 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:28.831 640 640 I : [0916/064728.830905:INFO:com_android_bluetooth_btservice_AdapterService.cpp(630)] hal_util_load_bt_library loaded HAL: btinterface=0x7bf51421f0, handle=0x86e5bb9491a25a89
09-16 06:47:28.832 640 640 D BluetoothAdapterService: onCreate()
09-16 06:47:28.840 512 657 I UsbDescriptorParser: Unknown Descriptor len: 6 type:0x30
09-16 06:47:28.840 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.840 438 438 I OMXMaster: makeComponentInstance(OMX.google.aac.encoder) in omx@1.0-service process
09-16 06:47:28.851 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.852 438 438 I OMXMaster: makeComponentInstance(OMX.google.amrnb.encoder) in omx@1.0-service process
09-16 06:47:28.857 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.857 438 438 I OMXMaster: makeComponentInstance(OMX.google.amrwb.encoder) in omx@1.0-service process
09-16 06:47:28.862 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.863 438 438 I OMXMaster: makeComponentInstance(OMX.google.flac.encoder) in omx@1.0-service process
09-16 06:47:28.869 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.870 438 475 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.avc) in omx@1.0-service process
09-16 06:47:28.873 438 475 E OMXNodeInstance: getExtensionIndex(0xf0627de0:rk._decoder.avc, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.873 438 475 I mpp_rt : NOT found ion allocator
09-16 06:47:28.873 438 475 I mpp_rt : found drm allocator
09-16 06:47:28.874 438 475 W OMXNodeInstance: [0xf0627de0:rk._decoder.avc] component does not support metadata mode; using fallback
09-16 06:47:28.876 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.876 438 475 I OMXMaster: makeComponentInstance(OMX.google.h264.decoder) in omx@1.0-service process
09-16 06:47:28.882 438 475 E OMXNodeInstance: getExtensionIndex(0xf0627de0:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.882 512 522 I system_server: Background concurrent copying GC freed 32378(2MB) AllocSpace objects, 21(580KB) LOS objects, 42% free, 6MB/10MB, paused 884us total 143.902ms
09-16 06:47:28.883 438 475 E OMXNodeInstance: getExtensionIndex(0xf0627de0:google.h264.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.885 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.885 438 438 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.flv1) in omx@1.0-service process
09-16 06:47:28.887 438 438 E OMXNodeInstance: getExtensionIndex(0xf06280e0:rk._decoder.flv1, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.887 438 438 W OMXNodeInstance: [0xf06280e0:rk._decoder.flv1] component does not support metadata mode; using fallback
09-16 06:47:28.889 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.890 438 438 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.h263) in omx@1.0-service process
09-16 06:47:28.891 438 438 E OMXNodeInstance: getExtensionIndex(0xf06280e0:rk._decoder.h263, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.892 438 438 W OMXNodeInstance: [0xf06280e0:rk._decoder.h263] component does not support metadata mode; using fallback
09-16 06:47:28.894 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.894 438 475 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.hevc) in omx@1.0-service process
09-16 06:47:28.896 438 475 E OMXNodeInstance: getExtensionIndex(0xf06280e0:rk._decoder.hevc, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.896 438 475 W OMXNodeInstance: [0xf06280e0:rk._decoder.hevc] component does not support metadata mode; using fallback
09-16 06:47:28.899 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.899 438 475 I OMXMaster: makeComponentInstance(OMX.google.hevc.decoder) in omx@1.0-service process
09-16 06:47:28.904 438 438 E OMXNodeInstance: getExtensionIndex(0xf06280e0:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.904 438 438 E OMXNodeInstance: getExtensionIndex(0xf06280e0:google.hevc.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.906 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.907 438 438 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.m2v) in omx@1.0-service process
09-16 06:47:28.908 438 438 E OMXNodeInstance: getExtensionIndex(0xf06280e0:rk._decoder.m2v, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.909 438 438 W OMXNodeInstance: [0xf06280e0:rk._decoder.m2v] component does not support metadata mode; using fallback
09-16 06:47:28.914 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.914 438 475 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.m4v) in omx@1.0-service process
09-16 06:47:28.917 438 475 E OMXNodeInstance: getExtensionIndex(0xf0627de0:rk._decoder.m4v, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.917 438 475 W OMXNodeInstance: [0xf0627de0:rk._decoder.m4v] component does not support metadata mode; using fallback
09-16 06:47:28.917 512 512 I ActivityManager: Loaded persisted task ids for user 0
09-16 06:47:28.919 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.919 438 475 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.vp8) in omx@1.0-service process
09-16 06:47:28.922 438 475 E OMXNodeInstance: getExtensionIndex(0xf0627de0:rk._decoder.vp8, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.922 438 475 W OMXNodeInstance: [0xf0627de0:rk._decoder.vp8] component does not support metadata mode; using fallback
09-16 06:47:28.924 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.924 438 438 I OMXMaster: makeComponentInstance(OMX.google.vp8.decoder) in omx@1.0-service process
09-16 06:47:28.929 438 438 E OMXNodeInstance: getExtensionIndex(0xf06281a0:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.929 438 793 E OMXNodeInstance: getExtensionIndex(0xf06281a0:google.vp8.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.930 512 512 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.settings/com.android.settings.FallbackHome}----com.android.settings
09-16 06:47:28.932 512 512 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.settings/com.android.settings.FallbackHome}----com.android.settings
09-16 06:47:28.933 512 512 D SystemServerTiming: ActivityManagerStartApps took to complete: 135ms
09-16 06:47:28.933 512 512 D SystemServerTiming: PhaseActivityManagerReady took to complete: 429ms
09-16 06:47:28.934 512 531 W ActivityManager: Slow operation: 124ms so far, now at startProcess: asking zygote to start proc
09-16 06:47:28.936 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.937 438 793 I OMXMaster: makeComponentInstance(OMX.rk.video_decoder.vp9) in omx@1.0-service process
09-16 06:47:28.938 512 512 D SystemServerInitThreadPool: Shutdown successful
09-16 06:47:28.938 512 512 D SystemServerTiming: StartServices took to complete: 2735ms
09-16 06:47:28.939 708 708 V WebViewLibraryLoader: RelroFileCreator (64bit = false), lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so
09-16 06:47:28.939 715 715 V WebViewLibraryLoader: RelroFileCreator (64bit = true), lib: /system/app/webview/webview.apk!/lib/arm64-v8a/libwebviewchromium.so
09-16 06:47:28.943 512 530 W Looper : Slow dispatch took 130ms android.ui h=com.android.server.am.ActivityManagerService$UiHandler c=null m=53
09-16 06:47:28.945 670 670 W AlarmManager: Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@445d20d
09-16 06:47:28.945 512 512 W Looper : Slow delivery took 2059ms main h=android.os.Handler c=com.android.server.-$$Lambda$BatteryService$2x73lvpB0jctMSVP4qb9sHAqRPw@67572f3 m=0
09-16 06:47:28.950 640 640 D AdapterState: make() - Creating AdapterState
09-16 06:47:28.953 438 475 E OMXNodeInstance: getExtensionIndex(0xf06281a0:rk._decoder.vp9, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
09-16 06:47:28.953 438 475 W OMXNodeInstance: [0xf06281a0:rk._decoder.vp9] component does not support metadata mode; using fallback
09-16 06:47:28.956 797 797 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.956 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: returned from zygote!
09-16 06:47:28.956 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: done updating battery stats
09-16 06:47:28.956 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: building log message
09-16 06:47:28.956 512 531 I ActivityManager: Start proc 797:com.android.phone/1001 for added application com.android.phone
09-16 06:47:28.956 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: starting to update pids map
09-16 06:47:28.956 512 531 W ActivityManager: Slow operation: 146ms so far, now at startProcess: done updating pids map
09-16 06:47:28.959 640 640 I bt_btif : init
09-16 06:47:28.960 640 640 D bt_osi_allocation_tracker: canary initialized
09-16 06:47:28.960 640 802 I AdapterState: OFF : entered
09-16 06:47:28.960 640 802 D AdapterProperties: Setting state to OFF
09-16 06:47:28.962 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.962 438 475 I OMXMaster: makeComponentInstance(OMX.google.vp9.decoder) in omx@1.0-service process
09-16 06:47:28.964 438 475 E OMXNodeInstance: getExtensionIndex(0xf06281a0:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.964 438 475 E OMXNodeInstance: getExtensionIndex(0xf06281a0:google.vp9.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.967 640 807 I bt_osi_thread: run_thread: thread id 807, thread name stack_manager started
09-16 06:47:28.967 640 807 I bt_stack_manager: event_init_stack is initializing the stack
09-16 06:47:28.968 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.968 438 475 I OMXMaster: makeComponentInstance(OMX.rk.video_encoder.avc) in omx@1.0-service process
09-16 06:47:28.973 433 496 W ACodec : [OMX.rk.video_encoder.avc] stopping checking profiles after 32: 8/1
09-16 06:47:28.974 433 496 W OMXUtils: do not know color format 0x7f000789 = 2130708361
09-16 06:47:28.974 438 793 E OMXNodeInstance: getConfig(0xf06281a0:rk._encoder.avc, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a)
09-16 06:47:28.975 656 656 W InputAttributes: No editor info for this field. Bug?
09-16 06:47:28.977 640 807 E bt_btif_config: Config is missing adapter section
09-16 06:47:28.978 640 807 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
09-16 06:47:28.978 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.978 438 793 I OMXMaster: makeComponentInstance(OMX.google.h264.encoder) in omx@1.0-service process
09-16 06:47:28.979 640 807 E bt_btif_config: Config is missing adapter section
09-16 06:47:28.979 640 807 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
09-16 06:47:28.979 640 807 E bt_btif_config_transcode: btif_config_transcode unable to load XML file ‘/data/misc/bluedroid/bt_config.xml’: 3
09-16 06:47:28.979 640 807 E bt_btif_config: init unable to transcode legacy file; creating empty config.
09-16 06:47:28.984 512 531 W ActivityManager: Slow operation: 54ms so far, now at startProcess: returned from zygote!
09-16 06:47:28.984 512 531 W ActivityManager: Slow operation: 55ms so far, now at startProcess: done updating battery stats
09-16 06:47:28.985 512 531 W ActivityManager: Slow operation: 55ms so far, now at startProcess: building log message
09-16 06:47:28.985 512 531 I ActivityManager: Start proc 817:com.android.settings/1000 for activity com.android.settings/.FallbackHome
09-16 06:47:28.985 512 531 W ActivityManager: Slow operation: 55ms so far, now at startProcess: starting to update pids map
09-16 06:47:28.985 512 531 W ActivityManager: Slow operation: 55ms so far, now at startProcess: done updating pids map
09-16 06:47:28.985 640 824 I bt_osi_thread: run_thread: thread id 824, thread name alarm_default_ca started
09-16 06:47:28.986 640 825 I bt_osi_thread: run_thread: thread id 825, thread name alarm_dispatcher started
09-16 06:47:28.987 817 817 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:28.989 640 807 I bt_btif_core: btif_init_bluetooth entered
09-16 06:47:28.991 433 496 W OMXUtils: do not know color format 0x7f000789 = 2130708361
09-16 06:47:28.991 640 807 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
09-16 06:47:28.994 640 828 I bt_osi_thread: run_thread: thread id 828, thread name bt_jni_workqueue started
09-16 06:47:28.995 640 807 I bt_btif_core: btif_init_bluetooth finished
09-16 06:47:28.995 640 828 I bt_btif_core: run_message_loop entered
09-16 06:47:28.995 640 807 I bt_stack_manager: event_init_stack finished
09-16 06:47:28.995 640 640 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
09-16 06:47:28.995 640 640 I bt_btif : get_profile_interface: id = socket
09-16 06:47:28.995 433 496 I OMXClient: IOmx service obtained
09-16 06:47:28.995 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:28.996 438 475 I OMXMaster: makeComponentInstance(OMX.google.h263.encoder) in omx@1.0-service process
09-16 06:47:28.999 640 828 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
09-16 06:47:28.999 640 828 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
09-16 06:47:29.000 438 475 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
09-16 06:47:29.001 433 496 W OMXUtils: do not know color format 0x7f000789 = 2130708361
09-16 06:47:29.001 438 475 E OMXNodeInstance: getConfig(0xf06281a0:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
09-16 06:47:29.002 640 640 I bt_btif : get_profile_interface: id = sdp
09-16 06:47:29.005 433 496 I OMXClient: IOmx service obtained
09-16 06:47:29.006 438 475 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.encoder) in omx@1.0-service process
09-16 06:47:29.006 438 475 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
09-16 06:47:29.007 433 496 W OMXUtils: do not know color format 0x7f000789 = 2130708361
09-16 06:47:29.007 438 475 E OMXNodeInstance: getConfig(0xf06281a0:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
09-16 06:47:29.010 433 496 I OMXClient: IOmx service obtained
09-16 06:47:29.010 438 475 I OMXMaster: makeComponentInstance(OMX.google.vp8.encoder) in omx@1.0-service process
09-16 06:47:29.019 433 496 W OMXUtils: do not know color format 0x7f000789 = 2130708361
09-16 06:47:29.019 438 475 E OMXNodeInstance: getConfig(0xf06281a0:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
09-16 06:47:29.020 656 842 I LatinIME:LogUtils: Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 1600238849 ; date = ?
09-16 06:47:29.020 433 496 D MediaCodecList: ignored a null builder
09-16 06:47:29.024 512 698 I OMXClient: IOmx service obtained
09-16 06:47:29.024 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.027 438 475 E OMXNodeInstance: getConfig(0xf06281a0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.029 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.043 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 1 line
09-16 06:47:29.043 512 768 W ActivityManager: Slow operation: 56ms so far, now at attachApplicationLocked: after mServices.attachApplicationLocked
09-16 06:47:29.044 512 768 W ActivityManager: Slow operation: 57ms so far, now at attachApplicationLocked: after updateOomAdjLocked
09-16 06:47:29.044 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.045 512 512 D HdmiReceiver: action =android.intent.action.HDMI_PLUGGED
09-16 06:47:29.045 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.045 640 828 D AdapterProperties: Name is: rk3399
09-16 06:47:29.046 512 512 D HdmiReceiver: onReceive mTaskVector.size() = 0
09-16 06:47:29.046 640 828 D AdapterProperties: BT Class:1a0110
09-16 06:47:29.046 512 512 D ConditionProviders.SCP: onConnected
09-16 06:47:29.046 656 842 I LatinIME:LogUtils: Dictionary info: dictionary = userunigram.en_US ; version = 1600238849 ; date = ?
09-16 06:47:29.047 512 512 D ConditionProviders: Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
09-16 06:47:29.048 708 708 I WebViewLoader-: System.exit called, status: 0
09-16 06:47:29.048 708 708 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
09-16 06:47:29.050 512 512 D ConditionProviders: Subscribing to condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
09-16 06:47:29.052 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.056 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.057 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.062 424 424 I Zygote : Process 708 exited cleanly (0)
09-16 06:47:29.064 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.065 797 797 I m.android.phon: The ClassLoaderContext is a special shared library.
09-16 06:47:29.065 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.065 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 1 line
09-16 06:47:29.066 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.071 656 842 E ActivityThread: Failed to find provider info for user_dictionary
09-16 06:47:29.071 512 768 I ActivityManager: Process WebViewLoader-armeabi-v7a (pid 708) has died: psvc PER
09-16 06:47:29.071 512 609 I WifiScanningService: wifi driver unloaded
09-16 06:47:29.071 512 532 W libprocessgroup: kill(-708, 9) failed: No such process
09-16 06:47:29.071 512 532 I libprocessgroup: Successfully killed process cgroup uid 1037 pid 708 in 0ms
09-16 06:47:29.078 512 609 I WifiScanningService: wifi driver unloaded
09-16 06:47:29.081 512 512 V SettingsProvider: Notifying for 0: content://settings/secure/location_providers_allowed
09-16 06:47:29.081 640 640 I BluetoothAdapterService: Phone policy enabled
09-16 06:47:29.083 512 512 V SettingsProvider: Notifying for 0: content://settings/global/location_global_kill_switch
09-16 06:47:29.084 817 817 I ndroid.setting: The ClassLoaderContext is a special shared library.
09-16 06:47:29.086 640 640 D BluetoothActiveDeviceManager: start()
09-16 06:47:29.088 797 797 I m.android.phon: The ClassLoaderContext is a special shared library.
09-16 06:47:29.100 817 817 I ndroid.setting: The ClassLoaderContext is a special shared library.
09-16 06:47:29.101 640 640 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@e8e4c0e
09-16 06:47:29.104 512 512 I system_server: The ClassLoaderContext is a special shared library.
09-16 06:47:29.107 640 852 D BluetoothActiveDeviceManager: onAudioDevicesAdded
09-16 06:47:29.107 640 852 D BluetoothActiveDeviceManager: Audio device added: AIO-3399ProC type: 2
09-16 06:47:29.107 640 852 D BluetoothActiveDeviceManager: Audio device added: AIO-3399ProC type: 15
09-16 06:47:29.112 715 715 I WebViewLoader-: System.exit called, status: 0
09-16 06:47:29.112 715 715 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
09-16 06:47:29.115 640 640 D BluetoothAdapterService: onBind()
09-16 06:47:29.120 512 861 I OMXClient: IOmx service obtained
09-16 06:47:29.120 438 851 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.124 438 851 E OMXNodeInstance: getConfig(0xf06281a0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.127 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.129 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.130 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.131 512 574 I ActivityManager: Process WebViewLoader-arm64-v8a (pid 715) has died: psvc PER
09-16 06:47:29.131 512 532 W libprocessgroup: kill(-715, 9) failed: No such process
09-16 06:47:29.131 423 423 I Zygote : Process 715 exited cleanly (0)
09-16 06:47:29.132 512 532 I libprocessgroup: Successfully killed process cgroup uid 1037 pid 715 in 1ms
09-16 06:47:29.135 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.139 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.140 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.146 512 618 D RkNativeDisplayManager: nativeInit failed to get IRkOutputManager
09-16 06:47:29.150 670 670 V SystemUIService: Starting SystemUI services for user 0.
09-16 06:47:29.156 656 842 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
09-16 06:47:29.171 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.Dependency took to complete: 21ms
09-16 06:47:29.182 512 512 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
09-16 06:47:29.185 512 867 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
09-16 06:47:29.185 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.util.NotificationChannels took to complete: 14ms
09-16 06:47:29.188 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.statusbar.CommandQueue$CommandQueueStart took to complete: 3ms
09-16 06:47:29.193 512 869 I OMXClient: IOmx service obtained
09-16 06:47:29.193 438 851 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.195 438 851 E OMXNodeInstance: getConfig(0xf06281a0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.197 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.200 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 6 lines
09-16 06:47:29.201 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.203 797 797 I m.android.phon: The ClassLoaderContext is a special shared library.
09-16 06:47:29.203 512 512 I Telecom : SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@32a5184: TS.init@AAA
09-16 06:47:29.210 670 670 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
09-16 06:47:29.213 670 670 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
09-16 06:47:29.217 817 817 D OpenGLRenderer: Skia GL Pipeline
09-16 06:47:29.226 512 873 I Telecom : Logging.Events: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentSpeakerRoute
09-16 06:47:29.226 512 873 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
09-16 06:47:29.229 512 574 V AlarmManager: setImplLocked type=1 ,when=1600300800000
09-16 06:47:29.235 512 875 I Telecom : CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA
09-16 06:47:29.240 512 876 I OMXClient: IOmx service obtained
09-16 06:47:29.241 438 851 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.242 512 512 I Telecom : MissedCallNotifierImpl: reloadFromDatabase: Boot not yet complete – call log db may not be available. Deferring loading until boot complete for user 0: TS.init@AAA
09-16 06:47:29.243 438 851 E OMXNodeInstance: getConfig(0xf06281a0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.246 512 512 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
09-16 06:47:29.248 817 874 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:47:29.248 817 874 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
09-16 06:47:29.248 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.248 817 874 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
09-16 06:47:29.248 817 874 I mali_so : cmdline : com.android.settings, we should GO THROUGH patch_for_sf_memory_leak.
09-16 06:47:29.248 817 874 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:47:29.248 817 874 D mali_so : current process is NOT sf, to bail out.
09-16 06:47:29.251 512 512 I Telecom : Class: TelecomSystem.INSTANCE being set
09-16 06:47:29.252 512 512 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:197 com.android.server.telecom.components.TelecomService.onBind:67 android.app.ActivityThread.handleBindService:3597
09-16 06:47:29.253 512 512 W Looper : Slow dispatch took 102ms main h=android.app.ActivityThread$H c=null m=121
09-16 06:47:29.253 512 512 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 com.android.server.content.SyncManager$14.run:758 android.os.Handler.handleCallback:873 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:193
09-16 06:47:29.254 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 5 lines
09-16 06:47:29.254 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.256 428 570 D installd: Found quota mount /dev/block/dm-0 at /data
09-16 06:47:29.257 428 570 D installd: Found storage mount /data/media at /mnt/runtime/default/emulated
09-16 06:47:29.258 512 512 V SettingsProvider: Notifying for 0: content://settings/global/boot_count
09-16 06:47:29.260 512 512 V AlarmManager: setImplLocked type=2 ,when=69860
09-16 06:47:29.263 512 512 I chatty : uid=1000 system_server identical 1 line
09-16 06:47:29.264 512 512 V AlarmManager: setImplLocked type=2 ,when=69860
09-16 06:47:29.264 817 874 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
09-16 06:47:29.264 817 874 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
09-16 06:47:29.264 817 874 I OpenGLRenderer: Initialized EGL, version 1.4
09-16 06:47:29.264 817 874 D OpenGLRenderer: Swap behavior 2
09-16 06:47:29.267 512 512 I system_server: The ClassLoaderContext is a special shared library.
09-16 06:47:29.275 670 670 W SoundPool: Use of stream types is deprecated for operations other than volume control
09-16 06:47:29.275 670 670 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
09-16 06:47:29.277 512 512 I system_server: The ClassLoaderContext is a special shared library.
09-16 06:47:29.279 797 797 D TelephonyProvider: dbh.onOpen: ok, queried table=siminfo
09-16 06:47:29.280 797 797 D TelephonyProvider: dbh.onOpen: ok, queried table=carriers
09-16 06:47:29.286 817 874 D mali_winsys: EGLint new_window_surface(egl_winsys_display , void , EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
09-16 06:47:29.287 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.keyguard.KeyguardViewMediator took to complete: 99ms
09-16 06:47:29.294 512 895 I OMXClient: IOmx service obtained
09-16 06:47:29.294 438 793 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.297 438 793 E OMXNodeInstance: getConfig(0xf0217060:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.298 797 797 D CarrierIdProvider: onCreate
09-16 06:47:29.300 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.304 512 512 V WiredAccessoryManager: init()
09-16 06:47:29.305 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 4 lines
09-16 06:47:29.305 512 512 V WiredAccessoryManager: newName=hdmi newState=16 headsetState=16 prev headsetState=0
09-16 06:47:29.306 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.306 512 512 I WiredAccessoryManager: MSG_NEW_DEVICE_STATE
09-16 06:47:29.307 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.308 797 797 D CarrierIdProvider: update database from pb file
09-16 06:47:29.311 670 898 I OMXClient: IOmx service obtained
09-16 06:47:29.312 670 670 D OpenGLRenderer: Skia GL Pipeline
09-16 06:47:29.312 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.314 438 903 E OMXNodeInstance: getConfig(0xf0627ea0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.318 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.322 817 874 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
09-16 06:47:29.324 512 512 V NotificationListeners: enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
09-16 06:47:29.325 512 512 V NotificationListeners: binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
09-16 06:47:29.326 512 512 W ActivityManager: Unable to start service Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener } U=0: not found
09-16 06:47:29.326 512 512 W NotificationListeners: Unable to bind notification listener service: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
09-16 06:47:29.326 512 512 V NotificationAssistants: enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
09-16 06:47:29.326 512 512 V NotificationAssistants: binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
09-16 06:47:29.327 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.328 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.339 257 257 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
09-16 06:47:29.340 257 257 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
09-16 06:47:29.342 512 576 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:29.342 512 576 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:29.343 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.345 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.345 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:29.346 797 797 E CarrierIdProvider: read carrier list from ota pb failure: java.io.FileNotFoundException: /data/misc/carrierid/carrier_list.pb (No such file or directory)
09-16 06:47:29.346 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.346 797 797 D CarrierIdProvider: latest version: 4 need update: false
09-16 06:47:29.347 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.352 797 797 D CarrierProvider: onCreate
09-16 06:47:29.359 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.360 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.361 512 531 I ActivityManager: Start proc 907:android.ext.services/u0a24 for service android.ext.services/.notification.Assistant
09-16 06:47:29.361 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.362 512 529 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
09-16 06:47:29.366 512 512 D ConditionProviders.SCP: onSubscribe condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true
09-16 06:47:29.366 512 512 D ConditionProviders.SCP: setRegistered true
09-16 06:47:29.373 512 512 D ConditionProviders.SCP: evaluateSubscriptionLocked cal=ScheduleCalendar[mDays={1, 2, 3, 4, 5, 6, 7}, mSchedule=ScheduleInfo{days=[1, 2, 3, 4, 5, 6, 7], startHour=22, startMinute=0, endHour=7, endMinute=0, exitAtAlarm=true, nextAlarm=Thu Jan 01 00:00:00 GMT 1970 (0)}], now=Wed Sep 16 06:47:29 GMT 2020 (1600238849366), nextUserAlarmTime=Thu Jan 01 00:00:00 GMT 1970 (0)
09-16 06:47:29.373 512 512 D ConditionProviders.SCP: notifyCondition condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true STATE_TRUE reason=meetsSchedule
09-16 06:47:29.375 512 512 D ConditionProviders.SCP: Scheduling evaluate for Wed Sep 16 07:00:00 GMT 2020 (1600239600000), in +12m30s634ms, now=Wed Sep 16 06:47:29 GMT 2020 (1600238849366)
09-16 06:47:29.375 512 915 I OMXClient: IOmx service obtained
09-16 06:47:29.375 512 512 V AlarmManager: setImplLocked type=0 ,when=1600239600000
09-16 06:47:29.375 512 512 D BluetoothManagerService: Bluetooth Adapter name changed to rk3399
09-16 06:47:29.376 512 512 D BluetoothManagerService: Stored Bluetooth name: rk3399
09-16 06:47:29.376 438 903 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.377 512 512 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
09-16 06:47:29.379 907 907 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:29.379 797 797 I ImsResolver: ImsResolver initialized with static binding.
09-16 06:47:29.379 512 536 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
09-16 06:47:29.379 512 536 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
09-16 06:47:29.381 797 797 I ImsResolver: Initializing cache and binding.
09-16 06:47:29.383 438 475 E OMXNodeInstance: getConfig(0xf0217360:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.386 512 762 W ActivityManager: Unable to start service Intent { act=android.intent.action.QUICKSTEP_SERVICE pkg=com.android.launcher3 } U=0: not found
09-16 06:47:29.386 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.387 512 512 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
09-16 06:47:29.387 275 275 D hw_output: old_state 1 cur_state 1 conn->get_type() 11
09-16 06:47:29.387 512 536 D BluetoothManagerService: Stored Bluetooth name: rk3399
09-16 06:47:29.387 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.388 512 536 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@199a0ed mBinding = false mUnbinding = false
09-16 06:47:29.388 670 670 W OverviewProxyService: Failed to connect on attempt 1 will try again in 5000ms
09-16 06:47:29.391 512 512 D MediaSessionService: Global priority session is changed from null to com.android.server.telecom/HeadsetMediaButton (userId=0)
09-16 06:47:29.392 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.393 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.394 797 797 I ServiceManagement: getService: Trying again for android.hardware.radio@1.0::IRadio/slot1…
09-16 06:47:29.395 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.396 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.397 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.398 275 275 W hwc-drm-connector: UpdateModes Could not get hdmi_output_colorimetry property
09-16 06:47:29.398 275 275 W hwc-drm-connector: UpdateModes Could not get hdmi_output_format property
09-16 06:47:29.399 275 275 D hw_output: old_state 2 cur_state 2 conn->get_type() 10
09-16 06:47:29.399 275 275 D hw_output: encoderId1: 90
09-16 06:47:29.399 275 275 D hw_output: crtc: 64 0 foundHdmi 1 2222
09-16 06:47:29.401 640 640 D BluetoothAdapterService: onUnbind() - calling cleanup
09-16 06:47:29.401 640 640 D BluetoothAdapterService: cleanup()
09-16 06:47:29.402 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.404 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.404 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.408 640 640 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface…
09-16 06:47:29.408 640 640 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
09-16 06:47:29.408 640 640 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
09-16 06:47:29.408 640 807 I bt_stack_manager: event_clean_up_stack is cleaning up the stack
09-16 06:47:29.409 640 807 I bt_btif_core: btif_cleanup_bluetooth entered
09-16 06:47:29.409 512 639 I SyncManager: Got SyncJobService instance.
09-16 06:47:29.409 670 925 I OMXClient: IOmx service obtained
09-16 06:47:29.409 512 512 V WiredAccessoryManager: headsetName: connected
09-16 06:47:29.410 640 807 E bt_btif : do_in_bta_thread: MessageLooper not initialized
09-16 06:47:29.410 512 621 E ActivityThread: Failed to find provider info for com.android.calendar
09-16 06:47:29.410 438 474 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.410 640 807 E BluetoothServiceJni: Callback: ‘callback_thread_event’ is not called on the correct thread
09-16 06:47:29.411 640 807 I bt_btif_queue: btif_queue_release
09-16 06:47:29.411 512 621 E ActivityThread: Failed to find provider info for com.android.calendar
09-16 06:47:29.411 640 828 I bt_btif_core: run_message_loop finished
09-16 06:47:29.411 640 828 W bt_osi_thread: run_thread: thread id 828, thread name bt_jni_workqueue exited
09-16 06:47:29.412 512 621 V AlarmManager: setImplLocked type=0 ,when=1600325249367
09-16 06:47:29.412 640 807 I bt_core_module: module_clean_up Cleaning up module “stack_config_module”
09-16 06:47:29.412 640 807 I bt_core_module: module_clean_up Cleanup of module “stack_config_module” completed
09-16 06:47:29.413 640 807 I bt_core_module: module_clean_up Cleaning up module “interop_module”
09-16 06:47:29.413 640 807 I bt_core_module: module_clean_up Cleanup of module “interop_module” completed
09-16 06:47:29.413 640 807 I bt_btif_core: btif_cleanup_bluetooth finished
09-16 06:47:29.413 512 512 D AutofillManagerService: Autofill restriction did not change for user 0
09-16 06:47:29.413 640 807 I bt_core_module: module_clean_up Cleaning up module “btif_config_module”
09-16 06:47:29.413 438 903 E OMXNodeInstance: getConfig(0xf0217180:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.419 512 512 W Looper : Drained
09-16 06:47:29.419 512 512 I FusedLocation: engine started (com.android.location.fused)
09-16 06:47:29.420 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.436 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 8 lines
09-16 06:47:29.437 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.439 257 257 D AudioHardwareTiny: adev_set_parameters: kvpairs = connect=1024
09-16 06:47:29.440 276 276 I AudioFlinger: openOutput() this 0xf053e000, module 10 Device 0x400, SamplingRate 32000, Format 0xd000000, Channels 0x3, flags 0x1
09-16 06:47:29.440 257 338 D AudioHardwareTiny: audio hal adev_open_output_stream devices = 0x400, flags = 1025, samplerate = 32000,format = 0xd000000
09-16 06:47:29.441 257 338 D AudioHardwareTiny: get_hdmi_support_channels_masks: HDMI Support 2 channels pcm
09-16 06:47:29.441 257 338 D AudioHardwareTiny: adev_open_output_stream:out = 0xe74a9180 HDMI Bitstream
09-16 06:47:29.441 257 338 D AudioHardwareTiny: out->config.rate = 32000, out->config.channels = 2 out->config.format = 3,out->config.flag = 1
09-16 06:47:29.442 276 276 I AudioFlinger: HAL output buffer size 2048 frames, normal sink buffer size 2048 frames
09-16 06:47:29.443 276 940 I AudioFlinger: AudioFlinger’s thread 0xefd22000 tid=940 ready to run
09-16 06:47:29.445 257 257 D AudioHardwareTiny: out_get_parameters: keys = sup_formats
09-16 06:47:29.446 276 276 D APM_AudioPolicyManager: filterSurroundFormats: forced use = 0
09-16 06:47:29.446 257 257 D AudioHardwareTiny: do_out_standby,out = 0xe74a9180,device = 0x400
09-16 06:47:29.446 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=1;sup_sampling_rates
09-16 06:47:29.446 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=1;sup_channels
09-16 06:47:29.447 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=218103808;sup_sampling_rates
09-16 06:47:29.447 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=218103808;sup_channels
09-16 06:47:29.447 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=150994944;sup_sampling_rates
09-16 06:47:29.447 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=150994944;sup_channels
09-16 06:47:29.448 640 807 I bt_core_module: module_clean_up Cleanup of module “btif_config_module” completed
09-16 06:47:29.449 640 807 I bt_core_module: module_clean_up Cleaning up module “bt_utils_module”
09-16 06:47:29.449 640 807 I bt_core_module: module_clean_up Cleanup of module “bt_utils_module” completed
09-16 06:47:29.449 257 257 D AudioHardwareTiny: out_get_parameters: keys = format=218103808;sup_channels
09-16 06:47:29.451 257 257 D AudioHardwareTiny: out_set_parameters: kvpairs = closing=true
09-16 06:47:29.451 640 807 I bt_core_module: module_clean_up Cleaning up module “osi_module”
09-16 06:47:29.451 640 825 D bt_osi_alarm: callback_dispatch Callback thread exited
09-16 06:47:29.451 640 825 W bt_osi_thread: run_thread: thread id 825, thread name alarm_dispatcher exited
09-16 06:47:29.451 257 257 D AudioHardwareTiny: out_set_parameters: kvpairs = exiting=1
09-16 06:47:29.451 640 824 W bt_osi_thread: run_thread: thread id 824, thread name alarm_default_ca exited
09-16 06:47:29.452 276 276 I AudioFlinger: openOutput() this 0xf053e000, module 10 Device 0x400, SamplingRate 32000, Format 0xd000000, Channels 0x3, flags 0x1
09-16 06:47:29.453 257 338 D AudioHardwareTiny: audio hal adev_open_output_stream devices = 0x400, flags = 1025, samplerate = 32000,format = 0xd000000
09-16 06:47:29.453 640 807 I bt_core_module: module_clean_up Cleanup of module “osi_module” completed
09-16 06:47:29.453 640 807 I bt_stack_manager: event_clean_up_stack finished
09-16 06:47:29.453 257 257 D AudioHardwareTiny: adev_close_output_stream!
09-16 06:47:29.453 640 640 I BluetoothServiceJni: cleanupNative: return from cleanup
09-16 06:47:29.453 257 257 D AudioHardwareTiny: do_out_standby,out = 0xe74a9180,device = 0x400
09-16 06:47:29.453 257 338 D AudioHardwareTiny: get_hdmi_support_channels_masks: HDMI Support 2 channels pcm
09-16 06:47:29.453 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.453 257 338 D AudioHardwareTiny: adev_open_output_stream:out = 0xe74a9480 HDMI Bitstream
09-16 06:47:29.453 257 338 D AudioHardwareTiny: out->config.rate = 32000, out->config.channels = 2 out->config.format = 3,out->config.flag = 1
09-16 06:47:29.454 640 640 D BluetoothActiveDeviceManager: cleanup()
09-16 06:47:29.454 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.455 640 640 D BluetoothAdapterService: onDestroy()
09-16 06:47:29.456 512 512 V SettingsProvider: Notifying for 0: content://settings/global/zen_mode_config_etag
09-16 06:47:29.456 640 640 I BluetoothAdapterService: Force exit to cleanup internal state in Bluetooth stack
09-16 06:47:29.457 276 276 I AudioFlinger: HAL output buffer size 2048 frames, normal sink buffer size 2048 frames
09-16 06:47:29.458 276 943 I AudioFlinger: AudioFlinger’s thread 0xefd38000 tid=943 ready to run
09-16 06:47:29.459 257 941 D AudioHardwareTiny: do_out_standby,out = 0xe74a9480,device = 0x400
09-16 06:47:29.460 640 640 I droid.bluetoot: System.exit called, status: 0
09-16 06:47:29.460 640 640 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
09-16 06:47:29.462 907 907 I id.ext.service: The ClassLoaderContext is a special shared library.
09-16 06:47:29.462 257 941 D AudioHardwareTiny: out_set_parameters: kvpairs = closing=true
09-16 06:47:29.463 257 941 D AudioHardwareTiny: out_set_parameters: kvpairs = exiting=1
09-16 06:47:29.464 257 941 D AudioHardwareTiny: adev_close_output_stream!
09-16 06:47:29.464 257 941 D AudioHardwareTiny: do_out_standby,out = 0xe74a9480,device = 0x400
09-16 06:47:29.464 257 941 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=0
09-16 06:47:29.466 512 512 D AudioService: onChange
09-16 06:47:29.467 512 512 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAI
09-16 06:47:29.468 512 512 V MediaRouter: Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
09-16 06:47:29.468 512 512 V MediaRouter: Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
09-16 06:47:29.481 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.recents.Recents took to complete: 193ms
09-16 06:47:29.484 670 670 I vol.Events: writeEvent collection_started
09-16 06:47:29.492 670 948 I OMXClient: IOmx service obtained
09-16 06:47:29.493 438 474 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:47:29.494 438 474 E OMXNodeInstance: getConfig(0xf0217180:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:47:29.496 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.498 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 1 line
09-16 06:47:29.498 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.500 512 619 D NotificationSQLiteLog: Pruned event entries: 0
09-16 06:47:29.501 670 947 I vol.Events: writeEvent external_ringer_mode_changed normal
09-16 06:47:29.501 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.501 670 947 I vol.Events: writeEvent internal_ringer_mode_changed normal
09-16 06:47:29.503 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.504 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.505 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.510 907 953 D ExtAssistant: File doesn’t exist or isn’t readable yet
09-16 06:47:29.512 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.513 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:47:29.513 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:47:29.520 423 423 I Zygote : Process 640 exited cleanly (0)
09-16 06:47:29.520 512 574 I ActivityManager: Process com.android.bluetooth (pid 640) has died: fore SVC
09-16 06:47:29.520 512 532 W libprocessgroup: kill(-640, 9) failed: No such process
09-16 06:47:29.521 512 532 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 640 in 0ms
09-16 06:47:29.563 670 947 I vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
09-16 06:47:29.565 670 947 I vol.Events: writeEvent level_changed STREAM_SYSTEM 5
09-16 06:47:29.566 670 947 I vol.Events: writeEvent level_changed STREAM_RING 5
09-16 06:47:29.568 670 947 I vol.Events: writeEvent level_changed STREAM_MUSIC 5
09-16 06:47:29.570 670 947 I vol.Events: writeEvent level_changed STREAM_ALARM 6
09-16 06:47:29.571 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.volume.VolumeUI took to complete: 90ms
09-16 06:47:29.573 670 947 I vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
09-16 06:47:29.577 670 947 I vol.Events: writeEvent zen_mode_config_changed [disallowAlarms=false disallowMedia=false disallowSystem=true disallowRinger=false]
09-16 06:47:29.595 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.stackdivider.Divider took to complete: 24ms
09-16 06:47:29.613 512 574 I WifiService: getWifiServiceMessenger uid=10025
09-16 06:47:29.616 512 574 D ConnectivityService: requestNetwork for uid/pid:10025/670 NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ]
09-16 06:47:29.616 512 633 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ] with score 0
09-16 06:47:29.617 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ], score: 0
09-16 06:47:29.617 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet, state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,] Routes: [fe80::/64 → :: eth0,] DnsAddresses: UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:29.662 512 574 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
09-16 06:47:29.662 512 574 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
09-16 06:47:29.663 512 954 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
09-16 06:47:29.663 512 954 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
09-16 06:47:29.668 670 670 D StatusBar: disable disable2
09-16 06:47:29.670 512 574 I StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@b936f00
09-16 06:47:29.764 670 670 I CameraManagerGlobal: Connecting to camera service
09-16 06:47:29.799 427 427 D incidentd: Start uploading backlogs in /data/misc/incidents/
09-16 06:47:29.800 427 427 D incidentd: Successfully uploaded 0 files to Dropbox.
09-16 06:47:29.806 512 679 I Zygote : Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/0e486de8-e088-4ebe-bd8b-d9124eca348d opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
09-16 06:47:29.806 512 679 D WebViewZygote: Preloading package /system/app/webview/webview.apk /system/app/webview/lib/arm:/system/app/webview/webview.apk!/lib/armeabi-v7a
09-16 06:47:29.817 512 679 I Zygote : Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/0e486de8-e088-4ebe-bd8b-d9124eca348d opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
09-16 06:47:29.817 670 670 D NotificationEntryMgr: heads up is enabled
09-16 06:47:29.827 734 734 I WebViewZygoteInit: Beginning package preload
09-16 06:47:29.836 734 734 I webview_zygote: The ClassLoaderContext is a special shared library.
09-16 06:47:29.870 670 670 D BluetoothHidDevice: Bound to HID Device Service
09-16 06:47:29.870 670 670 D LocalBluetoothProfileManager: Adding local MAP profile
09-16 06:47:29.871 670 670 D BluetoothMap: Create BluetoothMap proxy object
09-16 06:47:29.871 734 734 I WebViewZygoteInit: Package preload done
09-16 06:47:29.871 670 670 E BluetoothMap: Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
09-16 06:47:29.871 670 670 D LocalBluetoothProfileManager: Adding local PBAP profile
09-16 06:47:29.872 670 670 E BluetoothPbap: Could not bind to Bluetooth Pbap Service with Intent { act=android.bluetooth.IBluetoothPbap }
09-16 06:47:29.872 670 670 D LocalBluetoothProfileManager: LocalBluetoothProfileManager construction complete
09-16 06:47:29.884 670 670 V WifiManager: registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@af56b69, handler=Handler (android.os.Handler) {d6ee9ee}
09-16 06:47:29.885 670 696 V WifiManager: SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
09-16 06:47:29.886 670 696 V WifiManager: SoftApCallbackProxy: onNumClientsChanged: numClients=0
09-16 06:47:29.893 670 956 D OpenGLRenderer: profile bars disabled
09-16 06:47:29.893 670 956 D OpenGLRenderer: ambientRatio = 1.50
09-16 06:47:29.909 670 670 D StatusBar: disable disable2
09-16 06:47:29.927 670 670 V WifiManager: registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@af56b69, handler=Handler (android.os.Handler) {d6ee9ee}
09-16 06:47:29.928 670 922 V WifiManager: SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
09-16 06:47:29.928 670 922 V WifiManager: SoftApCallbackProxy: onNumClientsChanged: numClients=0
09-16 06:47:29.936 670 963 I SecurityController: could not bind to KeyChainService
09-16 06:47:29.946 440 440 W npu_monitor: type=1400 audit(0.0:248): avc: denied { read } for name=“temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:47:29.946 440 440 W npu_monitor: type=1400 audit(0.0:249): avc: denied { open } for path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:47:29.951 670 959 E ActivityThread: Failed to find provider info for com.android.contacts
09-16 06:47:29.953 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.SystemBars took to complete: 359ms
09-16 06:47:29.957 670 670 D StorageNotification: Notifying about private volume: VolumeInfo{private}:
09-16 06:47:29.957 670 670 D StorageNotification: type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
09-16 06:47:29.957 670 670 D StorageNotification: state=MOUNTED
09-16 06:47:29.957 670 670 D StorageNotification: fsType=null fsUuid=null fsLabel=null
09-16 06:47:29.957 670 670 D StorageNotification: path=/data internalPath=null
09-16 06:47:29.958 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.usb.StorageNotification took to complete: 4ms
09-16 06:47:29.963 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.power.PowerUI took to complete: 5ms
09-16 06:47:29.964 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.media.RingtonePlayer took to complete: 2ms
09-16 06:47:29.965 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.keyboard.KeyboardUI took to complete: 1ms
09-16 06:47:29.975 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.pip.PipUI took to complete: 10ms
09-16 06:47:29.977 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.shortcut.ShortcutKeyDispatcher took to complete: 1ms
09-16 06:47:29.977 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.VendorServices took to complete: 0ms
09-16 06:47:29.978 670 670 V GarbageMonitor: Now tracking processes: 670
09-16 06:47:29.978 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.util.leak.GarbageMonitor$Service took to complete: 1ms
09-16 06:47:29.979 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.LatencyTester took to complete: 1ms
09-16 06:47:29.980 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.globalactions.GlobalActionsComponent took to complete: 2ms
09-16 06:47:29.984 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.ScreenDecorations took to complete: 4ms
09-16 06:47:29.985 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.fingerprint.FingerprintDialogImpl took to complete: 0ms
09-16 06:47:29.986 670 670 D SystemUIBootTiming: StartServicescom.android.systemui.SliceBroadcastRelayHandler took to complete: 1ms
09-16 06:47:29.986 670 670 D SystemUIBootTiming: StartServices took to complete: 837ms
09-16 06:47:29.996 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:29.996 670 670 V MediaRouter: Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
09-16 06:47:29.997 670 670 V MediaRouter: Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
09-16 06:47:30.017 512 523 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:30.017 512 523 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:30.021 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:30.027 512 576 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:30.027 512 576 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:30.031 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:30.039 670 956 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:47:30.039 670 956 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
09-16 06:47:30.039 670 956 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
09-16 06:47:30.039 670 956 I mali_so : cmdline : com.android.systemui, we should GO THROUGH patch_for_sf_memory_leak.
09-16 06:47:30.039 670 956 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:47:30.039 670 956 D mali_so : current process is NOT sf, to bail out.
09-16 06:47:30.042 670 670 D ViewRootImpl[StatusBar]: changeCanvasOpacity: opaque=true
09-16 06:47:30.047 670 956 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
09-16 06:47:30.047 670 956 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
09-16 06:47:30.047 670 956 I OpenGLRenderer: Initialized EGL, version 1.4
09-16 06:47:30.047 670 956 D OpenGLRenderer: Swap behavior 2
09-16 06:47:30.063 670 956 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
09-16 06:47:30.070 670 963 E ActivityThread: Failed to find provider info for com.android.contacts
09-16 06:47:30.078 512 954 E memtrack: Couldn’t load memtrack module
09-16 06:47:30.078 512 954 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:30.093 670 960 E ActivityThread: Failed to find provider info for com.android.contacts
09-16 06:47:30.134 512 522 I system_server: Background concurrent copying GC freed 44275(3MB) AllocSpace objects, 33(988KB) LOS objects, 42% free, 5MB/9MB, paused 240us total 100.780ms
09-16 06:47:30.137 670 956 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
09-16 06:47:30.151 512 607 D WifiService: New client listening to asynchronous messages
09-16 06:47:30.387 512 657 D UsbHostManager: Removed device at /dev/bus/usb/005/003: USB-MSC
09-16 06:47:30.387 512 657 I UsbAlsaManager: USB Audio Device Removed: null
09-16 06:47:30.394 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:30.397 670 670 V StatusBar/NavBarView: PW=1280, PH=720
09-16 06:47:30.405 512 637 D DhcpClient: Broadcasting DHCPDISCOVER
09-16 06:47:30.405 512 637 V AlarmManager: setImplLocked type=2 ,when=15782
09-16 06:47:30.423 670 670 W StatusBar/NavBarView: NBV updateRotatedViews mVertical= true, change rot0 rot90
09-16 06:47:30.535 512 954 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:30.536 512 954 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:30.539 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:30.548 512 576 D sjf : mTempDisplayRect=Rect(0, 0 - 1280, 720)
09-16 06:47:30.548 512 576 D sjf : -----------mTempDisplayRect=Rect(0, 0 - 1280, 720) orientation=0
09-16 06:47:30.557 512 599 I InputReader: Reconfiguring input devices. changes=0x00000004
09-16 06:47:30.571 670 956 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface *, egl_color_buffer_format , EGLBoolean) returns 0x3000
09-16 06:47:30.571 670 670 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1280.0, 1054.4811) with surface size: 1280x1024
09-16 06:47:30.582 670 956 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
09-16 06:47:30.609 670 670 I Choreographer: Skipped 35 frames! The application may be doing too much work on its main thread.
09-16 06:47:30.615 670 956 D : set stream to NULL
09-16 06:47:30.708 670 956 I chatty : uid=10025(com.android.systemui) RenderThread identical 3 lines
09-16 06:47:30.709 670 956 D : set stream to NULL
09-16 06:47:30.715 273 273 D Sensors : set batch: handle = 2, period_ns = 66667000ns, timeout = 100000000ns
09-16 06:47:30.716 273 273 D Sensors : setDelay : 66667000 ns, (15.00 Hz)
09-16 06:47:30.716 273 273 I Sensors : set active: handle = 2, enable = 1
09-16 06:47:30.770 278 908 E BufferQueueProducer: [BootAnimation#0] disconnect: not connected (req=1)
09-16 06:47:30.770 385 397 W libEGL : EGLNativeWindowType 0x770743b010 disconnect failed
09-16 06:47:30.774 670 670 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1280.0, 1054.4811) with surface size: 1280x1024
09-16 06:47:30.811 670 670 I chatty : uid=10025(com.android.systemui) identical 4 lines
09-16 06:47:30.820 670 670 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1280.0, 1054.4811) with surface size: 1280x1024
09-16 06:47:30.840 512 537 I WindowManager: ******* TELLING SURFACE FLINGER WE ARE BOOTED!
09-16 06:47:30.840 278 321 I SurfaceFlinger: Boot is finished (8920 ms)
09-16 06:47:30.844 512 537 I SystemServiceManager: Starting phase 1000
09-16 06:47:30.847 512 535 I UsbDeviceManager: Setting USB config to adb
09-16 06:47:30.851 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.854 512 537 D ActivityManager: Finishing user boot 0
09-16 06:47:30.854 512 537 I ActivityManager: User 0 state changed from BOOTING to RUNNING_LOCKED
09-16 06:47:30.856 512 537 D ActivityManager: Started unlocking user 0
09-16 06:47:30.856 512 537 D ActivityManager: Unlocking user 0 progress 0
09-16 06:47:30.857 512 537 D ActivityManager: Unlocking user 0 progress 5
09-16 06:47:30.864 512 608 D WifiConfigStore: Reading from stores completed in 0 ms.
09-16 06:47:30.865 512 608 W WifiConfigManager: No stored networks found.
09-16 06:47:30.867 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.882 512 608 D WIFI : Registering NetworkFactory
09-16 06:47:30.882 512 612 D ConnectivityService: Got NetworkFactory Messenger for WIFI
09-16 06:47:30.882 512 608 D WIFI_UT : Registering NetworkFactory
09-16 06:47:30.882 512 612 D ConnectivityService: Got NetworkFactory Messenger for WIFI_UT
09-16 06:47:30.883 512 608 D WIFI : got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
09-16 06:47:30.883 512 608 D WIFI : got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
09-16 06:47:30.883 512 608 D WIFI : got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
09-16 06:47:30.883 512 608 D WIFI : got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ] with score 0
09-16 06:47:30.883 512 608 D WIFI_UT : got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
09-16 06:47:30.883 512 608 D WIFI_UT : got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
09-16 06:47:30.883 512 608 D WIFI_UT : got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
09-16 06:47:30.883 512 608 D WIFI_UT : got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ] with score 0
09-16 06:47:30.884 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.884 656 669 W putmethod.lati: Receiving file descriptor from ADB failed (socket 33): Success
09-16 06:47:30.884 817 834 W ndroid.setting: Receiving file descriptor from ADB failed (socket 26): Success
09-16 06:47:30.884 656 669 E putmethod.lati: Something went wrong getting fds from adb. Retry!: Success
09-16 06:47:30.884 797 808 W m.android.phon: Receiving file descriptor from ADB failed (socket 26): Success
09-16 06:47:30.884 797 808 E m.android.phon: Something went wrong getting fds from adb. Retry!: Success
09-16 06:47:30.885 907 928 W id.ext.service: Receiving file descriptor from ADB failed (socket 33): Success
09-16 06:47:30.885 907 928 E id.ext.service: Something went wrong getting fds from adb. Retry!: Success
09-16 06:47:30.885 512 518 W system_server: Receiving file descriptor from ADB failed (socket 40): Connection refused
09-16 06:47:30.885 670 684 W ndroid.systemu: Receiving file descriptor from ADB failed (socket 32): Success
09-16 06:47:30.885 670 684 E ndroid.systemu: Something went wrong getting fds from adb. Retry!: Success
09-16 06:47:30.885 512 518 E system_server: Something went wrong getting fds from adb. Retry!: Connection refused
09-16 06:47:30.886 817 834 E ndroid.setting: Something went wrong getting fds from adb. Retry!: Success
09-16 06:47:30.886 670 670 W StatusBar/NavBarView: *** Invalid layout in navigation bar (sizeChanged this=84x720 cur=84x692)
09-16 06:47:30.893 670 670 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1280.0, 1054.4811) with surface size: 1280x1024
09-16 06:47:30.896 986 986 W init : type=1400 audit(0.0:250): avc: denied { entrypoint } for path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk1p14” ino=1570 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
09-16 06:47:30.900 986 986 W usb_mode_switch: type=1400 audit(0.0:251): avc: denied { read execute } for path=“/system/bin/sh” dev=“mmcblk1p14” ino=1416 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
09-16 06:47:30.900 986 986 W usb_mode_switch: type=1400 audit(0.0:252): avc: denied { getattr } for path=“/system/bin/sh” dev=“mmcblk1p14” ino=1416 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
09-16 06:47:30.901 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.901 512 531 I ActivityManager: Start proc 983:com.android.deskclock/u0a45 for broadcast com.android.deskclock/.AlarmInitReceiver
09-16 06:47:30.903 983 983 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:30.918 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.934 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.936 989 989 I bootstat: Service started: /system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l
09-16 06:47:30.951 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:47:30.956 983 983 I droid.deskcloc: The ClassLoaderContext is a special shared library.
09-16 06:47:30.963 983 983 I droid.deskcloc: The ClassLoaderContext is a special shared library.
09-16 06:47:30.984 989 989 I bootstat: Battery level at startup 50%
09-16 06:47:30.984 989 989 I bootstat: Canonical boot reason: reboot
09-16 06:47:30.996 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:31.042 983 983 I AlarmClock: AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED
09-16 06:47:31.050 983 1010 I AlarmClock: Fixing alarm instances
09-16 06:47:31.054 1011 1012 I adbd : initializing functionfs
09-16 06:47:31.055 1011 1012 I adbd : opening control endpoint /dev/usb-ffs/adb/ep0
09-16 06:47:31.056 1011 1012 I adbd : functionfs successfully initialized
09-16 06:47:31.056 1011 1012 I adbd : registering usb transport
09-16 06:47:31.056 512 537 W WindowManager: App freeze timeout expired.
09-16 06:47:31.103 983 1010 V AlarmClock: AlarmInitReceiver finished
09-16 06:47:31.105 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.105 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.106 512 535 W Looper : Slow dispatch took 260ms android.fg h=com.android.server.usb.UsbDeviceManager$UsbHandlerLegacy c=null m=4
09-16 06:47:31.106 244 250 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2
09-16 06:47:31.107 244 250 D vold : Preparing: /data/system_ce/0
09-16 06:47:31.107 244 250 D vold : Preparing: /data/misc_ce/0
09-16 06:47:31.107 244 250 D vold : Preparing: /data/vendor_ce/0
09-16 06:47:31.107 244 250 D vold : Preparing: /data/media/0
09-16 06:47:31.107 244 250 D vold : Preparing: /data/data
09-16 06:47:31.108 244 250 V vold : Starting restorecon of /data/system_ce/0
09-16 06:47:31.109 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.110 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.110 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.111 244 250 V vold : Finished restorecon of /data/system_ce/0
09-16 06:47:31.111 244 250 V vold : Starting restorecon of /data/misc_ce/0
09-16 06:47:31.111 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.111 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.112 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.112 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.113 244 250 V vold : Finished restorecon of /data/misc_ce/0
09-16 06:47:31.113 244 250 V vold : /system/bin/vold_prepare_subdirs
09-16 06:47:31.113 244 250 V vold : prepare
09-16 06:47:31.113 244 250 V vold : 0
09-16 06:47:31.113 244 250 V vold : 2
09-16 06:47:31.116 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.117 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.122 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.122 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.123 670 956 D : set stream to NULL
09-16 06:47:31.124 670 956 I chatty : uid=10025(com.android.systemui) RenderThread identical 1 line
09-16 06:47:31.126 670 956 D : set stream to NULL
09-16 06:47:31.127 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.127 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.128 244 250 I vold_prepare_subdirs: SELinux: Loaded file_contexts
09-16 06:47:31.130 1020 1020 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_ce/0/vold
09-16 06:47:31.130 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.130 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.131 1020 1020 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_ce/0/storaged
09-16 06:47:31.132 512 535 V UserDataPreparer: Found /data/user/0 with serial number 0
09-16 06:47:31.132 512 535 V UserDataPreparer: Found /data/system_ce/0 with serial number 0
09-16 06:47:31.133 512 535 D UserDataPreparer: Setting property: sys.user.0.ce_available=true
09-16 06:47:31.134 512 535 V PackageManager: reconcileAppsData for null u0 0x2 migrateAppData=false
09-16 06:47:31.137 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.137 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.144 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.144 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.148 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.148 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.153 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.153 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.162 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.162 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.166 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.166 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.169 670 956 D : set stream to NULL
09-16 06:47:31.176 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.176 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.189 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.189 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.194 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.194 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.198 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.198 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.205 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.205 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.210 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.210 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.214 512 535 V PackageManager: reconcileAppsData finished 89 packages
09-16 06:47:31.214 512 535 I ActivityManager: User 0 state changed from RUNNING_LOCKED to RUNNING_UNLOCKING
09-16 06:47:31.214 512 535 D ActivityManager: Unlocking user 0 progress 20
09-16 06:47:31.214 512 535 W Looper : Slow delivery took 249ms android.fg h=android.os.Handler c=com.android.server.am.-$$Lambda$UserController$o6oQFjGYYIfx-I94cSakTLPLt6s@4ef5b4b m=0
09-16 06:47:31.214 512 529 I SystemServiceManager: Calling onUnlockUser u0
09-16 06:47:31.214 512 535 W Looper : Slow dispatch took 108ms android.fg h=android.os.Handler c=com.android.server.am.-$$Lambda$UserController$o6oQFjGYYIfx-I94cSakTLPLt6s@4ef5b4b m=0
09-16 06:47:31.215 512 529 D BluetoothManagerService: User 0 unlocked
09-16 06:47:31.215 512 536 D BluetoothManagerService: MESSAGE_USER_UNLOCKED
09-16 06:47:31.215 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.215 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.215 512 529 D StorageManagerService: onUnlockUser 0
09-16 06:47:31.215 244 250 D vold : Linking /storage/emulated/0 to /mnt/user/0/primary
09-16 06:47:31.217 512 535 W Looper : Drained
09-16 06:47:31.218 512 601 D StorageManagerService: Volume emulated broadcasting mounted to UserHandle{0}
09-16 06:47:31.225 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.225 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.227 512 608 D WifiConfigStore: Reading from user store completed in 0 ms.
09-16 06:47:31.228 512 529 W VoiceInteractionManagerService: no available voice interaction services found for user 0
09-16 06:47:31.228 512 529 W VoiceInteractionManagerService: no available voice recognition services found for user 0
09-16 06:47:31.228 512 608 D WakeupConfigStoreData: WifiWake user data has been read
09-16 06:47:31.229 512 1021 V BackupManagerService: Starting with transport android/com.android.internal.backup.LocalTransport
09-16 06:47:31.231 512 529 D AutofillManagerServiceImpl: Reset component for user 0 ()
09-16 06:47:31.231 512 529 D FieldClassificationStrategy: reset(): service is not bound. Do nothing.
09-16 06:47:31.231 512 530 D AutofillUI: destroySaveUiUiThread(): already destroyed
09-16 06:47:31.231 512 529 I ActivityManager: User 0 state changed from RUNNING_UNLOCKING to RUNNING_UNLOCKED
09-16 06:47:31.231 512 529 D SystemServerTiming: SystemUserUnlock took to complete: 375ms
09-16 06:47:31.232 512 608 D WifiConfigStore: Writing to stores completed in 3 ms.
09-16 06:47:31.238 512 535 I ActivityManager: Loading recents for user 0 into memory.
09-16 06:47:31.253 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.253 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.260 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.260 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.262 512 1021 I SELinux : SELinux: Loaded file_contexts
09-16 06:47:31.264 512 531 I ActivityManager: Start proc 1025:com.android.se/1068 for added application com.android.se
09-16 06:47:31.266 656 656 I InputAttributes: InputType.TYPE_NULL is specified
09-16 06:47:31.270 512 1021 E BackupPasswordManager: Unable to read backup pw version
09-16 06:47:31.270 1025 1025 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:31.270 512 1021 E BackupPasswordManager: Unable to read saved backup pw hash
09-16 06:47:31.274 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.274 512 1022 E system_server: No package ID 7f found for ID 0x7f080190.
09-16 06:47:31.274 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.274 512 1022 E system_server: No package ID 7f found for ID 0x7f120fa7.
09-16 06:47:31.274 512 1022 E system_server: No package ID 7f found for ID 0x7f08018f.
09-16 06:47:31.274 512 1022 E system_server: No package ID 7f found for ID 0x7f12047a.
09-16 06:47:31.275 512 1022 E system_server: No package ID 7f found for ID 0x7f08018e.
09-16 06:47:31.275 512 1022 E system_server: No package ID 7f found for ID 0x7f1209b4.
09-16 06:47:31.277 817 874 D : set stream to NULL
09-16 06:47:31.282 817 874 D : set stream to NULL
09-16 06:47:31.284 512 1021 V BackupManagerService: No ancestral data
09-16 06:47:31.289 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.290 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.292 817 874 D : set stream to NULL
09-16 06:47:31.296 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.296 512 531 W ActivityManager: Slow operation: 63ms so far, now at startProcess: returned from zygote!
09-16 06:47:31.296 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.297 512 531 W ActivityManager: Slow operation: 64ms so far, now at startProcess: done updating battery stats
09-16 06:47:31.297 1033 1033 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:31.299 512 531 W ActivityManager: Slow operation: 66ms so far, now at startProcess: building log message
09-16 06:47:31.299 512 531 I ActivityManager: Start proc 1033:com.cghs.stresstest/1000 for added application com.cghs.stresstest
09-16 06:47:31.299 512 531 W ActivityManager: Slow operation: 66ms so far, now at startProcess: starting to update pids map
09-16 06:47:31.299 512 531 W ActivityManager: Slow operation: 66ms so far, now at startProcess: done updating pids map
09-16 06:47:31.304 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.304 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.310 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.310 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.315 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.315 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.321 817 874 D : set stream to NULL
09-16 06:47:31.324 817 874 D : set stream to NULL
09-16 06:47:31.325 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.325 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.329 817 874 D : set stream to NULL
09-16 06:47:31.337 817 874 I chatty : uid=1000(system) RenderThread identical 2 lines
09-16 06:47:31.341 817 874 D : set stream to NULL
09-16 06:47:31.345 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.346 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.351 1025 1025 I com.android.se: The ClassLoaderContext is a special shared library.
09-16 06:47:31.357 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.358 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.364 512 1021 I BackupManagerService: Unlocking system user; mService=com.android.server.backup.BackupManagerService@a06e622
09-16 06:47:31.368 512 1021 I BackupManagerService: Backup enabled => false
09-16 06:47:31.371 1033 1033 I cghs.stresstes: The ClassLoaderContext is a special shared library.
09-16 06:47:31.376 512 1022 E system_server: No package ID 7f found for ID 0x7f08006d.
09-16 06:47:31.376 512 1022 E system_server: No package ID 7f found for ID 0x7f100215.
09-16 06:47:31.377 1025 1025 I SecureElementService: main onCreate
09-16 06:47:31.377 512 1021 V BackupManagerConstants: getKeyValueBackupIntervalMilliseconds(…) returns 14400000
09-16 06:47:31.378 512 1021 V BackupManagerConstants: getKeyValueBackupFuzzMilliseconds(…) returns 600000
09-16 06:47:31.378 512 1021 V BackupManagerConstants: getKeyValueBackupRequiredNetworkType(…) returns 1
09-16 06:47:31.378 512 1021 V BackupManagerConstants: getKeyValueBackupRequireCharging(…) returns true
09-16 06:47:31.378 512 1021 V KeyValueBackupJob: Scheduling k/v pass in 241 minutes
09-16 06:47:31.380 1033 1033 I cghs.stresstes: The ClassLoaderContext is a special shared library.
09-16 06:47:31.381 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.381 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.381 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.secure_element@1.0::ISecureElement/eSE1 in either framework or device manifest.
09-16 06:47:31.383 1025 1025 I SecureElementService: No HAL implementation for eSE1
09-16 06:47:31.385 236 236 W hwservicemanager: getTransport: Cannot find entry android.hardware.secure_element@1.0::ISecureElement/SIM1 in either framework or device manifest.
09-16 06:47:31.386 1025 1025 I SecureElementService: No HAL implementation for SIM1
09-16 06:47:31.391 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.391 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.394 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.394 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.395 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:31.395 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.395 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.395 512 1022 E system_server: No package ID 7f found for ID 0x7f07008d.
09-16 06:47:31.395 512 1022 E system_server: No package ID 7f found for ID 0x7f10007f.
09-16 06:47:31.397 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.398 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.399 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.399 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.401 512 529 I AppWidgetServiceImpl: Processing of handleUserUnlocked u0 took 163 ms
09-16 06:47:31.401 512 529 I ActivityManager: Sending BOOT_COMPLETE user #0
09-16 06:47:31.408 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.408 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.412 817 817 D FallbackHome: User unlocked and real home found; let’s go!
09-16 06:47:31.413 512 512 V NotificationListeners: enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
09-16 06:47:31.413 512 512 V NotificationListeners: binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
09-16 06:47:31.414 512 512 V NotificationAssistants: disabling notification assistant for user 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
09-16 06:47:31.414 512 512 D NotificationListeners: Removing active service ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
09-16 06:47:31.415 1033 1033 E VRMountReceiver: ---------------- action = android.intent.action.MEDIA_MOUNTED
09-16 06:47:31.416 1033 1033 E VRMountReceiver: ------------- mount path = /storage/emulated/0
09-16 06:47:31.419 1033 1033 E VRMountReceiver: ---------------- pathUri is null
09-16 06:47:31.423 512 512 V NotificationAssistants: enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
09-16 06:47:31.425 512 512 V NotificationAssistants: binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
09-16 06:47:31.432 512 523 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher3/.Launcher} from uid 0
09-16 06:47:31.444 1062 1062 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:31.451 512 523 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.launcher3/com.android.launcher3.Launcher}----com.android.launcher3
09-16 06:47:31.452 512 512 I AccountManagerService: User 0 is unlocked - opening CE database
09-16 06:47:31.454 512 529 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.launcher3/com.android.launcher3.Launcher}----com.android.launcher3
09-16 06:47:31.456 512 531 I ActivityManager: Start proc 1062:com.android.launcher3/u0a8 for service com.android.launcher3/.notification.NotificationListener
09-16 06:47:31.497 512 639 I SyncManager: Loaded persisted syncs: 0 periodic syncs, 0 oneshot syncs, 10 total system server jobs, JobStats: FirstLoad: 2/2/0 LastSave: -1/-1/-1
09-16 06:47:31.497 907 1078 D ExtAssistant: File doesn’t exist or isn’t readable yet
09-16 06:47:31.502 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.502 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.511 1062 1062 I droid.launcher: The ClassLoaderContext is a special shared library.
09-16 06:47:31.518 512 638 D EthernetTracker: eth0 isEthernetInterfaceActive = true
09-16 06:47:31.556 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.556 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.569 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.569 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.579 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.579 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.589 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.589 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.594 512 657 W UsbACInterface: Unknown Audio Streaming Interface subtype:0x0
09-16 06:47:31.594 512 657 I UsbDescriptorParser: Unknown Descriptor len: 5 type:0x24
09-16 06:47:31.594 512 657 W UsbDescriptor: OVERRRUN t:0x24 r: 7 > l: 5
09-16 06:47:31.595 512 657 W UsbDescriptor: OVERRRUN t:0x24 r: 12 > l: 4
09-16 06:47:31.595 512 657 W UsbACInterface: Unknown Audio Streaming Interface subtype:0x6
09-16 06:47:31.595 512 657 I UsbDescriptorParser: Unknown Descriptor len: 5 type:0x24
09-16 06:47:31.595 512 574 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
09-16 06:47:31.595 512 574 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
09-16 06:47:31.596 1062 1062 V Launcher: LauncherAppState initiated
09-16 06:47:31.597 512 657 D UsbHostManager: USB device attached: vidpid 2207:1005 mfg/product/ver/serial rockchip/rk3xxx/4.04/4d832427dc62c98d hasAudio/HID/Storage: false/false/false
09-16 06:47:31.597 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.598 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.598 512 657 D UsbDeviceDescriptor: 1 configs
09-16 06:47:31.602 512 657 D UsbHostManager: Added device UsbDevice[mName=/dev/bus/usb/005/004,mVendorId=8711,mProductId=4101,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=rockchip,mProductName=rk3xxx,mVersion=4.04,mSerialNumber=4d832427dc62c98d,mConfigurations=[
09-16 06:47:31.602 512 657 D UsbHostManager: UsbConfiguration[mId=1,mName=acm,mAttributes=128,mMaxPower=250,mInterfaces=[
09-16 06:47:31.602 512 657 D UsbHostManager: UsbInterface[mId=0,mAlternateSetting=0,mName=CDC Abstract Control Model (ACM),mClass=2,mSubclass=2,mProtocol=1,mEndpoints=[
09-16 06:47:31.602 512 657 D UsbHostManager: UsbEndpoint[mAddress=130,mAttributes=3,mMaxPacketSize=10,mInterval=9]]
09-16 06:47:31.602 512 657 D UsbHostManager: UsbInterface[mId=1,mAlternateSetting=0,mName=CDC ACM Data,mClass=10,mSubclass=0,mProtocol=0,mEndpoints=[
09-16 06:47:31.602 512 657 D UsbHostManager: UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=512,mInterval=0]
09-16 06:47:31.602 512 657 D UsbHostManager: UsbEndpoint[mAddress=1,mAttributes=2,mMaxPacketSize=512,mInterval=0]]]]
09-16 06:47:31.609 1062 1062 D OpenGLRenderer: Skia GL Pipeline
09-16 06:47:31.609 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.609 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.613 257 941 D AudioHardwareTiny: adev_set_parameters: kvpairs = A2dpSuspended=false
09-16 06:47:31.614 512 623 I AudioService: setBluetoothScoOnInt: false resetBluetoothSco
09-16 06:47:31.615 257 941 D AudioHardwareTiny: adev_set_parameters: kvpairs = BT_SCO=off
09-16 06:47:31.615 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.616 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.628 1062 1062 D ConfigMonitor: ConfigMonitor init
09-16 06:47:31.634 1085 1085 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:31.634 512 531 I ActivityManager: Start proc 1085:com.android.mtp/u0a12 for broadcast com.android.mtp/.UsbIntentReceiver
09-16 06:47:31.637 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.637 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.647 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.647 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.663 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.663 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.676 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.676 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.678 1085 1085 I com.android.mt: The ClassLoaderContext is a special shared library.
09-16 06:47:31.686 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.686 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.693 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.693 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.702 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.702 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.719 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.719 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.722 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.722 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.726 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.726 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.736 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.736 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.742 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.742 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.744 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.744 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.747 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.747 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.755 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.755 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.761 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.762 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.791 817 874 D : set stream to NULL
09-16 06:47:31.793 817 874 D : set stream to NULL
09-16 06:47:31.794 1062 1083 D LoaderTask: loadWorkspace: loading default favorites
09-16 06:47:31.799 817 874 D : set stream to NULL
09-16 06:47:31.820 1062 1062 D TouchInteractionService: Touch service connected
09-16 06:47:31.823 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.823 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.854 1062 1107 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:47:31.854 1062 1107 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
09-16 06:47:31.872 1062 1107 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
09-16 06:47:31.872 1062 1107 I mali_so : cmdline : com.android.launcher3, we should GO THROUGH patch_for_sf_memory_leak.
09-16 06:47:31.872 1062 1107 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:47:31.872 1062 1107 D mali_so : current process is NOT sf, to bail out.
09-16 06:47:31.883 1062 1107 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
09-16 06:47:31.883 1062 1107 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
09-16 06:47:31.884 1062 1107 I OpenGLRenderer: Initialized EGL, version 1.4
09-16 06:47:31.884 1062 1107 D OpenGLRenderer: Swap behavior 2
09-16 06:47:31.885 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.885 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.899 1062 1107 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
09-16 06:47:31.901 1062 1107 D mali_winsys: EGLint new_window_surface(egl_winsys_display , void , EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
09-16 06:47:31.946 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:31.946 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:31.997 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:32.030 1062 1062 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
09-16 06:47:32.055 1062 1107 D : set stream to NULL
09-16 06:47:32.066 1062 1107 I chatty : uid=10008(com.android.launcher3) RenderThread identical 3 lines
09-16 06:47:32.071 1062 1107 D : set stream to NULL
09-16 06:47:32.074 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:32.074 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:32.079 1062 1107 D : set stream to NULL
09-16 06:47:32.094 1062 1107 I chatty : uid=10008(com.android.launcher3) RenderThread identical 3 lines
09-16 06:47:32.096 1062 1107 D : set stream to NULL
09-16 06:47:32.161 278 447 E BufferQueueProducer: [com.android.settings/com.android.settings.FallbackHome#0] disconnect: not connected (req=1)
09-16 06:47:32.161 817 874 W libEGL : EGLNativeWindowType 0x7c06fbf010 disconnect failed
09-16 06:47:32.235 278 320 W SurfaceFlinger: Attempting to set client state on removed layer: com.android.settings/com.android.settings.FallbackHome#0
09-16 06:47:32.235 278 320 W SurfaceFlinger: Attempting to destroy on removed layer: com.android.settings/com.android.settings.FallbackHome#0
09-16 06:47:32.236 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:32.236 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:32.240 278 447 W SurfaceFlinger: Attempting to destroy on removed layer: AppWindowToken{68dc303 token=Token{b9457b2 ActivityRecord{620a5bd u0 com.android.settings/.FallbackHome t1}}}#0
09-16 06:47:32.347 1062 1062 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
09-16 06:47:32.395 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:32.397 1124 1124 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:32.397 512 531 I ActivityManager: Start proc 1124:com.android.printspooler/u0a43 for service com.android.printspooler/.model.PrintSpoolerService
09-16 06:47:32.438 1062 1062 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
09-16 06:47:32.441 1124 1124 I id.printspoole: The ClassLoaderContext is a special shared library.
09-16 06:47:32.481 512 531 I ActivityManager: Start proc 1141:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
09-16 06:47:32.482 1141 1141 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:32.517 1141 1141 I ndroid.keychai: The ClassLoaderContext is a special shared library.
09-16 06:47:32.930 1033 1033 D RecoveryReceiver: RECOVERY_STATE_FILE_TF:/mnt/external_sd/Recovery_state
09-16 06:47:32.946 440 440 W npu_monitor: type=1400 audit(0.0:266): avc: denied { read } for name=“temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:47:32.946 440 440 W npu_monitor: type=1400 audit(0.0:267): avc: denied { open } for path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:47:32.955 512 531 I ActivityManager: Start proc 1159:com.rockchip.devicetest/1000 for broadcast com.rockchip.devicetest/.BootReceiver
09-16 06:47:32.959 1159 1159 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:32.999 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:33.001 670 670 I vol.Events: writeEvent dismiss_dialog timeout
09-16 06:47:33.021 1159 1159 I chip.devicetes: The ClassLoaderContext is a special shared library.
09-16 06:47:33.067 1159 1159 V TestService: x action:android.intent.action.MEDIA_MOUNTED
09-16 06:47:33.069 1159 1159 V TestService: pathfile:///storage/emulated/0,bootcomplete=false
09-16 06:47:33.069 1159 1159 V TestService: path1:file:///storage/emulated/0
09-16 06:47:33.071 1159 1159 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 android.content.ContextWrapper.startService:664 com.rockchip.devicetest.BootReceiver.onReceive:59 android.app.ActivityThread.handleReceiver:3417
09-16 06:47:33.073 1159 1159 W chip.devicetest: type=1400 audit(0.0:268): avc: denied { read } for name=“force_usb_mode” dev=“sysfs” ino=16820 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=f
09-16 06:47:33.073 1159 1159 W chip.devicetest: type=1400 audit(0.0:269): avc: denied { open } for path=“/sys/bus/platform/drivers/usb20_otg/force_usb_mode” dev=“sysfs” ino=16820 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=f
09-16 06:47:33.073 1159 1159 W chip.devicetest: type=1400 audit(0.0:270): avc: denied { getattr } for path=“/sys/bus/platform/drivers/usb20_otg/force_usb_mode” dev=“sysfs” ino=16820 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=f
09-16 06:47:33.075 1159 1159 D TestService: onCreate
09-16 06:47:33.081 1159 1159 D TestService: onStartCommand,from:app
09-16 06:47:33.087 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:33.087 1159 1159 D StorageList: Storage’paths:/storage/emulated/0 state:mounted
09-16 06:47:33.088 1159 1159 D DeviceTest-FileUitls: find path:/storage/emulated/0
09-16 06:47:33.089 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Music
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Podcasts
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Ringtones
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Alarms
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Notifications
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Pictures
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Movies
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Download
09-16 06:47:33.090 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/DCIM
09-16 06:47:33.091 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Android
09-16 06:47:33.091 1159 1159 D TestService: no DeviceTest.apk
09-16 06:47:33.091 1159 1159 V TestService: isSystemReady()=trueisBootComplete()=true
09-16 06:47:33.096 512 531 I ActivityManager: Start proc 1178:android.rockchip.update.service/1000 for broadcast android.rockchip.update.service/.RKUpdateReceiver
09-16 06:47:33.098 1178 1178 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:33.144 1178 1178 I .update.servic: The ClassLoaderContext is a special shared library.
09-16 06:47:33.171 1178 1178 D RKUpdateReceiver: action = android.intent.action.MEDIA_MOUNTED
09-16 06:47:33.197 1194 1194 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:33.205 512 531 I ActivityManager: Start proc 1194:android.process.media/u0a12 for broadcast com.android.providers.downloads/.DownloadReceiver
09-16 06:47:33.306 656 656 I LatinIME: Timeout waiting for dictionary load
09-16 06:47:33.360 1194 1194 I d.process.medi: The ClassLoaderContext is a special shared library.
09-16 06:47:33.395 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:33.402 1194 1194 I d.process.medi: The ClassLoaderContext is a special shared library.
09-16 06:47:33.537 512 762 V AlarmManager: setImplLocked type=2 ,when=15041
09-16 06:47:33.542 1194 1194 D MediaScannerReceiver: action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0
09-16 06:47:33.558 1033 1033 D StressTest: =========onReceive===rebootFlag:0
09-16 06:47:33.558 512 1214 I RecoverySystem: No recovery log file
09-16 06:47:33.560 1159 1159 V TestService: x action:android.intent.action.BOOT_COMPLETED
09-16 06:47:33.565 512 1214 I BootReceiver: Copying audit failures to DropBox
09-16 06:47:33.566 512 1214 I BootReceiver: Checking for fsck errors
09-16 06:47:33.567 512 1214 I BootReceiver: fs_stat, partition:oem stat:0x3
09-16 06:47:33.567 512 1214 I BootReceiver: fs_stat, partition:cache stat:0xb
09-16 06:47:33.568 512 1214 I BootReceiver: fs_stat, partition:metadata fix:Free blocks count wrong (2934, counted=2932).
09-16 06:47:33.568 512 1214 I BootReceiver: fs_stat, partition:metadata stat:0x44b
09-16 06:47:33.569 512 1214 I BootReceiver: Copying /dev/fscklogs/log to DropBox (SYSTEM_FSCK)
09-16 06:47:33.674 1159 1159 E check_vendot: check_vendor:0
09-16 06:47:33.674 1159 1159 V TestService: getSystemAbnormalRestartTime0:0
09-16 06:47:33.675 1159 1159 V TestService: setSystemStart0:true
09-16 06:47:33.675 1159 1159 V TestService: SystemUtils.isBootComplete()=true
09-16 06:47:33.678 1159 1159 V TestService: setLastShutDownIsUnsafety =false
09-16 06:47:33.678 1159 1159 V TestService: setSystemStart1:true
09-16 06:47:33.680 1159 1159 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 android.content.ContextWrapper.startService:664 com.rockchip.devicetest.BootReceiver.onReceive:92 android.app.ActivityThread.handleReceiver:3417
09-16 06:47:33.682 1159 1159 V TestService: getSystemAbnormalRestartTime1:1
09-16 06:47:33.683 1159 1159 D TestService: onStartCommand,from:boot
09-16 06:47:33.685 512 512 I Telecom : DefaultDialerCache: Refreshing default dialer for user 0: now null: DDC.oR@AAg
09-16 06:47:33.685 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:33.685 1159 1159 D StorageList: Storage’paths:/storage/emulated/0 state:mounted
09-16 06:47:33.685 512 512 I Telecom : MissedCallNotifierImpl: reloadAfterBootComplete: user=0: TSBCR.oR@AAk
09-16 06:47:33.686 1159 1159 D DeviceTest-FileUitls: find path:/storage/emulated/0
09-16 06:47:33.687 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Music
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Podcasts
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Ringtones
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Alarms
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Notifications
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Pictures
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Movies
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Download
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/DCIM
09-16 06:47:33.688 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Android
09-16 06:47:33.688 1159 1159 D TestService: no DeviceTest.apk
09-16 06:47:33.688 1159 1159 D TestService: Rock Recv boot action. 15193
09-16 06:47:33.694 1178 1178 D RKUpdateReceiver: action = android.intent.action.BOOT_COMPLETED
09-16 06:47:33.694 1178 1178 D RKUpdateReceiver: RKUpdateReceiver recv ACTION_BOOT_COMPLETED.
09-16 06:47:33.697 1178 1178 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 android.content.ContextWrapper.startService:664 android.rockchip.update.service.RKUpdateReceiver.onReceive:59 android.app.ActivityThread.handleReceiver:3417
09-16 06:47:33.699 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:33.700 1159 1159 D StorageList: Storage’paths:/storage/emulated/0 state:mounted
09-16 06:47:33.702 1178 1178 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 android.content.ContextWrapper.startService:664 android.rockchip.update.service.RKUpdateReceiver.onReceive:65 android.app.ActivityThread.handleReceiver:3417
09-16 06:47:33.703 1159 1159 D TestService: Rock check storage, mounted.
09-16 06:47:33.706 512 531 I ActivityManager: Start proc 1235:android.process.acore/u0a13 for content provider com.android.providers.contacts/.CallLogProvider
09-16 06:47:33.707 1235 1235 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:33.713 1178 1178 I android_rockchip_update_UpdateService.cpp: JNI_OnLoad
09-16 06:47:33.719 1178 1178 D RKUpdateService: starting RKUpdateService, version is 1.8.2
09-16 06:47:33.721 1178 1178 D RKUpdateService: remote uri is http://www.rockchip.com:2300/OtaUpdater/android?product=AIO-3399ProC&version=v1.2.0&sn=S0M79ZBRGE&country=US&language=en
09-16 06:47:33.721 1178 1178 D RKUpdateService: remote uri backup is http://192.168.1.143:2300/OtaUpdater/android?product=AIO-3399ProC&version=v1.2.0&sn=S0M79ZBRGE&country=US&language=en
09-16 06:47:33.727 1178 1178 D RKUpdateService: first startup!!!
09-16 06:47:33.736 512 531 I ActivityManager: Start proc 1251:com.android.calendar/u0a35 for broadcast com.android.calendar/.alerts.AlertReceiver
09-16 06:47:33.738 1251 1251 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:33.760 1235 1235 I d.process.acor: The ClassLoaderContext is a special shared library.
09-16 06:47:33.760 656 697 I putmethod.lati: Waiting for a blocking GC ProfileSaver
09-16 06:47:33.773 1178 1178 D RKUpdateService: onStartCommand…
09-16 06:47:33.774 1178 1178 D RKUpdateService: command = 1 delaytime = 20000
09-16 06:47:33.784 1178 1178 D RKUpdateService: onStartCommand…
09-16 06:47:33.784 1178 1178 D RKUpdateService: command = 2 delaytime = 25000
09-16 06:47:33.791 1251 1251 I ndroid.calenda: The ClassLoaderContext is a special shared library.
09-16 06:47:33.797 1251 1251 I ndroid.calenda: The ClassLoaderContext is a special shared library.
09-16 06:47:33.818 1235 1235 I ContactsPerf: VoicemailContentProvider.onCreate start
09-16 06:47:33.821 1235 1235 I ContactsPerf: VoicemailContentProvider.onCreate finish
09-16 06:47:33.837 1235 1235 I d.process.acor: The ClassLoaderContext is a special shared library.
09-16 06:47:33.847 1251 1251 D ExtensionsFactory: No custom extensions.
09-16 06:47:33.853 1251 1251 D AlertReceiver: onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
09-16 06:47:33.857 1235 1235 I d.process.acor: The ClassLoaderContext is a special shared library.
09-16 06:47:33.867 1235 1271 D ContactsDatabaseHelper: WAL enabled for contacts2.db: true
09-16 06:47:33.888 512 531 I ActivityManager: Start proc 1282:com.android.contacts/u0a27 for broadcast com.android.contacts/.interactions.OnBootOrUpgradeReceiver
09-16 06:47:33.888 1282 1282 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:33.899 1251 1280 D AlertService: 0 Action = android.intent.action.BOOT_COMPLETED
09-16 06:47:33.902 1251 1280 D AlertService: Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
09-16 06:47:33.924 1223 1223 D AndroidRuntime: >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
09-16 06:47:33.925 512 531 I ActivityManager: Start proc 1297:com.android.providers.calendar/u0a6 for content provider com.android.providers.calendar/.CalendarProvider2
09-16 06:47:33.926 1297 1297 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:33.964 1282 1282 I ndroid.contact: The ClassLoaderContext is a special shared library.
09-16 06:47:33.976 1235 1271 I ContactLocale: AddressBook Labels [[en_US]]: [鈥? A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, 螒, 螔, 螕, 螖, 螘, 螙, 螚, 螛, 螜, 螝, 螞, 螠, 螡, 螢, 螣, 螤, 巍, 危, 韦, 违, 桅, 围, 唯, 惟, 鈥? 袗, 袘, 袙, 袚, 袛, 袀, 袝, 袆, 袞, 袟, 袠, 袉, 袡, 袌, 袣, 袥, 袎, 袦, 袧, 袏, 袨, 袩, 袪, 小, 孝, 袐, 校, 肖, 啸, 笑, 效, 袕, 楔, 些, 挟, 携, 鈥? 讗, 讘, 讙, 讚, 讛, 讜, 讝, 讞, 讟, 讬, 讻, 诇, 诪, 谞, 住, 注, 驻, 爪, 拽, 专, 砖, 转, 鈥? 丕, 亘, 鬲, 孬, 噩, 丨, 禺, 丿, 匕, 乇, 夭, 爻, 卮, 氐, 囟, 胤, 馗, 毓, 睾, 賮, 賯, 賰, 賱, 賲, 賳, 賴, 賵, 賷, 鈥? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 喔? 鈥? 銊? 銊? 銊? 銊? 銋? 銋? 銋? 銋? 銋? 銋? 銋? 銋? 銋? 銋? 鈥? 銇? 銇? 銇? 銇? 銇? 銇? 銇? 銈? 銈? 銈? #, 鈥
09-16 06:47:34.000 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:34.015 1297 1297 I viders.calenda: The ClassLoaderContext is a special shared library.
09-16 06:47:34.023 1231 1231 D AndroidRuntime: >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
09-16 06:47:34.053 1223 1223 I /system/bin/app_process: The ClassLoaderContext is a special shared library.
09-16 06:47:34.065 983 983 I AlarmClock: AlarmInitReceiver android.intent.action.BOOT_COMPLETED
09-16 06:47:34.073 1235 1271 D ContactsDatabaseHelper: WAL enabled for profile.db: false
09-16 06:47:34.076 512 762 W ShortcutService: Clock rewound
09-16 06:47:34.090 983 1010 I AlarmClock: Fixing alarm instances
09-16 06:47:34.099 1223 1223 D AndroidRuntime: Calling main entry com.android.commands.am.Am
09-16 06:47:34.101 235 235 E SELinux : avc: denied { find } for service=activity pid=1223 uid=0 scontext=u:r:sudaemon:s0 tcontext=u:object_r:activity_service:s0 tclass=service_manager permissive=1
09-16 06:47:34.102 235 235 E SELinux : avc: denied { find } for service=package pid=1223 uid=0 scontext=u:r:sudaemon:s0 tcontext=u:object_r:package_service:s0 tclass=service_manager permissive=1
09-16 06:47:34.104 983 1010 V AlarmClock: AlarmInitReceiver finished
09-16 06:47:34.111 512 762 D ActivityManager: Raise procstate to external provider: ProcessRecord{2dbd89e 1235:android.process.acore/u0a13}
09-16 06:47:34.113 512 762 W Binder : Outgoing transactions from this process must be FLAG_ONEWAY
09-16 06:47:34.113 512 762 W Binder : java.lang.Throwable
09-16 06:47:34.113 512 762 W Binder : at android.os.BinderProxy.transact(Binder.java:1114)
09-16 06:47:34.113 512 762 W Binder : at android.content.ContentProviderProxy.getType(ContentProviderNative.java:451)
09-16 06:47:34.113 512 762 W Binder : at com.android.server.am.ActivityManagerService.getProviderMimeType(ActivityManagerService.java:13116)
09-16 06:47:34.113 512 762 W Binder : at android.app.IActivityManager$Stub.onTransact(IActivityManager.java:1417)
09-16 06:47:34.113 512 762 W Binder : at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:3300)
09-16 06:47:34.113 512 762 W Binder : at android.os.Binder.execTransact(Binder.java:731)
09-16 06:47:34.122 512 531 I ActivityManager: Start proc 1325:com.android.email/u0a61 for broadcast com.android.email/.service.EmailBroadcastReceiver
09-16 06:47:34.122 1325 1325 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:34.134 1297 1297 I CalendarProvider2: Created com.android.providers.calendar.CalendarAlarmManager@2fc3710(com.android.providers.calendar.CalendarProvider2@48a8209)
09-16 06:47:34.153 1231 1231 I /system/bin/app_process: The ClassLoaderContext is a special shared library.
09-16 06:47:34.175 1325 1325 I m.android.emai: The ClassLoaderContext is a special shared library.
09-16 06:47:34.189 1325 1325 I m.android.emai: The ClassLoaderContext is a special shared library.
09-16 06:47:34.192 1231 1231 D AndroidRuntime: Calling main entry com.android.commands.am.Am
09-16 06:47:34.278 512 637 D DhcpClient: Broadcasting DHCPDISCOVER
09-16 06:47:34.278 512 637 V AlarmManager: setImplLocked type=2 ,when=24088
09-16 06:47:34.289 512 641 D DhcpClient: Received packet: ba:a3:fd:36:81:f8 OFFER, ip /192.168.8.176, mask /255.255.255.0, DNS servers: /192.168.8.1 , gateways [/192.168.8.1] lease time 86400, domain null
09-16 06:47:34.289 512 637 D DhcpClient: Got pending lease: IP address 192.168.8.176/24 Gateway 192.168.8.1 DNS servers: [ 192.168.8.1 ] Domains DHCP server /192.168.8.1 Vendor info null lease 86400 seconds
09-16 06:47:34.291 512 512 V AlarmManager: setImplLocked type=2 ,when=69860
09-16 06:47:34.292 512 637 V AlarmManager: setImplLocked type=2 ,when=33795
09-16 06:47:34.293 512 637 D DhcpClient: Broadcasting DHCPREQUEST ciaddr=0.0.0.0 request=192.168.8.176 serverid=192.168.8.1
09-16 06:47:34.294 512 637 V AlarmManager: setImplLocked type=2 ,when=17896
09-16 06:47:34.301 512 523 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.316 1325 1352 D ActivityThread: Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
09-16 06:47:34.317 512 523 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.319 1251 1280 D AlarmScheduler: No events found starting within 1 week.
09-16 06:47:34.320 512 641 D DhcpClient: Received packet: ba:a3:fd:36:81:f8 ACK: your new IP /192.168.8.176, netmask /255.255.255.0, gateways [/192.168.8.1] DNS servers: /192.168.8.1 , lease time 86400
09-16 06:47:34.322 512 637 D DhcpClient: Confirmed lease: IP address 192.168.8.176/24 Gateway 192.168.8.1 DNS servers: [ 192.168.8.1 ] Domains DHCP server /192.168.8.1 Vendor info null lease 86400 seconds
09-16 06:47:34.324 1325 1353 D ActivityThread: Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
09-16 06:47:34.325 434 488 D CommandListener: Setting iface cfg
09-16 06:47:34.326 512 573 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.331 512 637 V AlarmManager: setImplLocked type=2 ,when=43215830
09-16 06:47:34.332 512 637 V AlarmManager: setImplLocked type=2 ,when=75615827
09-16 06:47:34.333 512 637 V AlarmManager: setImplLocked type=2 ,when=86415826
09-16 06:47:34.333 512 637 D DhcpClient: Scheduling renewal in 43199s
09-16 06:47:34.333 512 637 D DhcpClient: Scheduling rebind in 75599s
09-16 06:47:34.333 512 637 D DhcpClient: Scheduling expiry in 86399s
09-16 06:47:34.347 512 633 D ConnectivityService: registerNetworkAgent NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false]} network{100} nethandle{432902426637} lp{{InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}} nc{[ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted: LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]} Score{30} everValidated{false} lastValidated{false} created{false} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
09-16 06:47:34.347 512 612 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] EVENT_NETWORK_INFO_CHANGED, going from null to CONNECTED
09-16 06:47:34.348 434 488 D TcpSocketMonitor: resuming tcpinfo polling (interval=30000ms)
09-16 06:47:34.349 512 612 W DnsManager: updatePrivateDns(100, PrivateDnsConfig{true:/[]})
09-16 06:47:34.349 512 612 D ConnectivityService: Setting DNS servers for network 100 to [/fe80::aebd:70ff:fe6c:2518%eth0, /192.168.8.1]
09-16 06:47:34.351 512 612 D DnsManager: setDnsConfigurationForNetwork(100, [fe80::aebd:70ff:fe6c:2518%eth0, 192.168.8.1], [], [1800, 25, 8, 64], , [fe80::aebd:70ff:fe6c:2518%eth0, 192.168.8.1])
09-16 06:47:34.354 512 612 D ConnectivityService: Adding iface eth0 to network 100
09-16 06:47:34.357 434 1359 E DnsTlsSocket: Failed to increment eventfd by -9223372036854775808
09-16 06:47:34.359 434 1358 E DnsTlsSocket: Failed to increment eventfd by -9223372036854775808
09-16 06:47:34.364 512 612 D ConnectivityService: Setting DNS servers for network 100 to [/fe80::aebd:70ff:fe6c:2518%eth0, /192.168.8.1]
09-16 06:47:34.365 512 612 D DnsManager: setDnsConfigurationForNetwork(100, [fe80::aebd:70ff:fe6c:2518%eth0, 192.168.8.1], [], [1800, 25, 8, 64], , [fe80::aebd:70ff:fe6c:2518%eth0, 192.168.8.1])
09-16 06:47:34.368 512 612 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.374 656 656 I SystemBroadcastReceiver: Boot has been completed
09-16 06:47:34.374 656 656 I SystemBroadcastReceiver: toggleAppIcon() : FLAG_SYSTEM = true
09-16 06:47:34.374 434 1363 W DnsTlsSocket: SSL_connect error 5, errno=111
09-16 06:47:34.374 434 1362 W DnsTlsSocket: SSL_connect error 5, errno=111
09-16 06:47:34.374 434 1363 E DnsTlsSocket: Failed to increment eventfd by -9223372036854775808
09-16 06:47:34.374 434 1362 E DnsTlsSocket: Failed to increment eventfd by -9223372036854775808
09-16 06:47:34.377 512 612 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.379 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.380 512 612 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.386 512 612 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.390 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.390 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ], score: 30
09-16 06:47:34.390 512 1357 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Validation disabled.
09-16 06:47:34.391 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {b4208b2}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:34.391 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 30
09-16 06:47:34.391 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {b4208b2}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:34.392 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ], score: 30
09-16 06:47:34.392 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {b4208b2}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:34.392 512 612 D ConnectivityService: Switching to new default network: NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false]} network{100} nethandle{432902426637} lp{{InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}} nc{[ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted: LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]} Score{30} everValidated{false} lastValidated{false} created{true} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
09-16 06:47:34.398 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:34.399 512 612 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.403 512 612 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.405 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.406 512 732 D NetworkTimeUpdateService: New default network 100; checking time.
09-16 06:47:34.407 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.409 512 531 I ActivityManager: Start proc 1365:com.android.managedprovisioning/u0a15 for broadcast com.android.managedprovisioning/.preprovisioning.BootReminder
09-16 06:47:34.409 512 612 D ConnectivityService: Sending CONNECTED broadcast for type 9 NetworkAgentInfo [Ethernet () - 100] isDefaultNetwork=true
09-16 06:47:34.409 1365 1365 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:34.414 512 612 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation passed
09-16 06:47:34.415 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 70
09-16 06:47:34.416 512 612 D ConnectivityService: Setting DNS servers for network 100 to [/fe80::aebd:70ff:fe6c:2518%eth0, /192.168.8.1]
09-16 06:47:34.416 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {b4208b2}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:34.416 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ], score: 70
09-16 06:47:34.417 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {b4208b2}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:34.417 512 612 D DnsManager: setDnsConfigurationForNetwork(100, [fe80::aebd:70ff:fe6c:2518%eth0, 192.168.8.1], [], [1800, 25, 8, 64], , [fe80::aebd:70ff:fe6c:2518%eth0, 192.168.8.1])
09-16 06:47:34.417 512 633 D EthernetNetworkFactory: acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ], score: 70
09-16 06:47:34.418 512 633 I EthernetNetworkFactory: networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10025] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: ba:a3:fd:36:81:f8, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: ba:a3:fd:36:81:f8, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {b4208b2}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::b721:5eeb:3347:70fa/64,fdac:bd70:6c25:1800:2b0b:b09a:9bc8:6ab6/64,fdac:bd70:6c25:1800:1d00:417:cf3a:49cc/64,192.168.8.176/24,] Routes: [fe80::/64 → :: eth0,fdac:bd70:6c25:1800::/64 → :: eth0,192.168.8.0/24 → 0.0.0.0 eth0,0.0.0.0/0 → 192.168.8.1 eth0,] DnsAddresses: [fe80::aebd:70ff:fe6c:2518%eth0,192.168.8.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
09-16 06:47:34.418 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.419 512 512 I TransportClient: LocalTransportService#0: Notifying [TransportManager.registerTransport()] transport = IBackupTransport
09-16 06:47:34.419 512 605 W BestClock: java.time.DateTimeException: Missing NTP fix
09-16 06:47:34.421 434 1373 W DnsTlsSocket: SSL_connect error 5, errno=111
09-16 06:47:34.421 434 1373 E DnsTlsSocket: Failed to increment eventfd by -9223372036854775808
09-16 06:47:34.423 512 1021 D BackupTransportManager: Transport android/com.android.internal.backup.LocalTransportService registered
09-16 06:47:34.423 512 1021 D BackupManagerService: Transport android/com.android.internal.backup.LocalTransport registered 3061ms after first request (delay = 3000ms)
09-16 06:47:34.428 512 1021 I BackupManagerService: Found stale backup journal, scheduling
09-16 06:47:34.429 512 1021 I chatty : uid=1000(system) backup identical 14 lines
09-16 06:47:34.429 512 1021 I BackupManagerService: Found stale backup journal, scheduling
09-16 06:47:34.430 434 1372 W DnsTlsSocket: SSL_connect error 5, errno=111
09-16 06:47:34.430 434 1372 E DnsTlsSocket: Failed to increment eventfd by -9223372036854775808
09-16 06:47:34.450 670 956 D : set stream to NULL
09-16 06:47:34.473 1365 1365 I gedprovisionin: The ClassLoaderContext is a special shared library.
09-16 06:47:34.518 512 523 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
09-16 06:47:34.519 512 573 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
09-16 06:47:34.520 1384 1384 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:34.521 512 573 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.521 512 531 I ActivityManager: Start proc 1384:com.android.onetimeinitializer/u0a16 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
09-16 06:47:34.554 512 523 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
09-16 06:47:34.558 1384 1384 I timeinitialize: The ClassLoaderContext is a special shared library.
09-16 06:47:34.570 1325 1389 I Email : Observing account changes for notifications
09-16 06:47:34.574 512 523 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.576 1384 1384 V OneTimeInitializerReceiver: OneTimeInitializerReceiver.onReceive
09-16 06:47:34.583 1325 1364 W m.android.emai: Long monitor contention with owner AsyncTask #2 (1353) at android.database.sqlite.SQLiteDatabase com.android.email.provider.EmailProvider.getDatabase(android.content.Context)(EmailProvider.java:478) waiters=1 in void com.android.email.provider.AccountReconciler.reconcileAccounts(android.content.Context) for 205ms
09-16 06:47:34.607 512 531 I ActivityManager: Start proc 1403:com.android.packageinstaller/u0a28 for broadcast com.android.packageinstaller/.TemporaryFileManager
09-16 06:47:34.610 1403 1403 I Zygote : seccomp disabled by setenforce 0
09-16 06:47:34.621 1194 1213 V MediaProvider: pruneThumbnails
09-16 06:47:34.628 1194 1213 V MediaProvider: /pruneDeadThumbnailFiles…
09-16 06:47:34.637 512 574 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.639 512 523 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.641 1325 1325 E ActivityThread: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@b6fb83b that was originally bound here
09-16 06:47:34.641 1325 1325 E ActivityThread: android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@b6fb83b that was originally bound here
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.app.LoadedApk$ServiceDispatcher.(LoadedApk.java:1610)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1502)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1659)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.app.ContextImpl.bindService(ContextImpl.java:1612)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.content.ContextWrapper.bindService(ContextWrapper.java:698)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
09-16 06:47:34.641 1325 1325 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:76)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.os.Handler.dispatchMessage(Handler.java:106)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.os.Looper.loop(Looper.java:193)
09-16 06:47:34.641 1325 1325 E ActivityThread: at android.os.HandlerThread.run(HandlerThread.java:65)
09-16 06:47:34.647 512 574 W ActivityManager: Unbind failed: could not find connection for android.os.BinderProxy@e48a844
09-16 06:47:34.663 512 574 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
09-16 06:47:34.668 1403 1403 I ackageinstalle: The ClassLoaderContext is a special shared library.
09-16 06:47:35.000 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:35.399 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:35.745 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:35.745 1159 1159 D StorageList: Storage’paths:/storage/emulated/0 state:mounted
09-16 06:47:35.747 1159 1159 D DeviceTest-FileUitls: find path:/storage/emulated/0
09-16 06:47:35.748 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:35.749 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Music
09-16 06:47:35.749 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Podcasts
09-16 06:47:35.749 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Ringtones
09-16 06:47:35.749 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Alarms
09-16 06:47:35.749 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Notifications
09-16 06:47:35.750 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Pictures
09-16 06:47:35.750 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Movies
09-16 06:47:35.750 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Download
09-16 06:47:35.750 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/DCIM
09-16 06:47:35.750 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Android
09-16 06:47:35.753 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:35.753 1159 1159 D StorageList: Storage’paths:/storage/emulated/0 state:mounted
09-16 06:47:35.754 1159 1159 D DeviceTest-FileUitls: find path:/storage/emulated/0
09-16 06:47:35.755 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:35.756 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Music
09-16 06:47:35.756 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Podcasts
09-16 06:47:35.756 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Ringtones
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Alarms
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Notifications
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Pictures
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Movies
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Download
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/DCIM
09-16 06:47:35.757 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Android
09-16 06:47:35.759 1159 1159 D TestService: factoryFilePath: agingFilePath: externalStorageFilePath:/storage/emulated/0
09-16 06:47:35.762 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:35.762 1159 1159 D StorageList: Storage’paths:/storage/emulated/0 state:mounted
09-16 06:47:35.763 1159 1159 D DeviceTest-FileUitls: find path:/storage/emulated/0
09-16 06:47:35.764 1159 1159 D StorageList: VolumnState:mounted
09-16 06:47:35.765 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Music
09-16 06:47:35.765 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Podcasts
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Ringtones
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Alarms
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Notifications
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Pictures
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Movies
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Download
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/DCIM
09-16 06:47:35.766 1159 1159 D DeviceTest-FileUitls: find file:/storage/emulated/0/Android
09-16 06:47:35.768 1159 1159 D TestService: It is not in factory/aging test mode.
09-16 06:47:35.768 1159 1159 D TestService: onDestroy
09-16 06:47:35.770 1159 1159 D AndroidRuntime: Shutting down VM
--------- beginning of crash
09-16 06:47:35.771 1159 1159 E AndroidRuntime: FATAL EXCEPTION: main
09-16 06:47:35.771 1159 1159 E AndroidRuntime: Process: com.rockchip.devicetest, PID: 1159
09-16 06:47:35.771 1159 1159 E AndroidRuntime: java.lang.RuntimeException: Unable to stop service com.rockchip.devicetest.service.TestService@53a74a4: java.lang.NullPointerException: Attempt to invoke virtual method ‘boolean java.lang.String.equals(java.lang.Object)’ on a null object reference
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.app.ActivityThread.handleStopService(ActivityThread.java:3755)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.app.ActivityThread.access$1700(ActivityThread.java:200)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1693)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6718)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: Caused by: java.lang.NullPointerException: Attempt to invoke virtual method ‘boolean java.lang.String.equals(java.lang.Object)’ on a null object reference
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at com.rockchip.devicetest.service.TestService.onDestroy(TestService.java:205)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: at android.app.ActivityThread.handleStopService(ActivityThread.java:3735)
09-16 06:47:35.771 1159 1159 E AndroidRuntime: … 8 more
09-16 06:47:35.779 1159 1159 I Process : Sending signal. PID: 1159 SIG: 9
09-16 06:47:35.830 512 573 I ActivityManager: Process com.rockchip.devicetest (pid 1159) has died: fore SVC
09-16 06:47:35.830 512 532 W libprocessgroup: kill(-1159, 9) failed: No such process
09-16 06:47:35.830 512 532 I libprocessgroup: Successfully killed process cgroup uid 1000 pid 1159 in 0ms
09-16 06:47:35.831 423 423 I Zygote : Process 1159 exited due to signal (9)
09-16 06:47:35.906 278 320 E BufferQueueProducer: [com.android.systemui.ImageWallpaper#0] disconnect: not connected (req=1)
09-16 06:47:35.906 670 956 W libEGL : EGLNativeWindowType 0x7bf1478010 disconnect failed
09-16 06:47:35.950 440 440 W npu_monitor: type=1400 audit(0.0:282): avc: denied { read } for name=“temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:47:35.950 440 440 W npu_monitor: type=1400 audit(0.0:283): avc: denied { open } for path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:47:36.001 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:36.400 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:36.689 1085 1104 I com.android.mt: Waiting for a blocking GC ProfileSaver
09-16 06:47:36.702 1085 1104 I com.android.mt: WaitForGcToComplete blocked ProfileSaver on HeapTrim for 12.221ms
09-16 06:47:37.001 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:37.400 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:38.002 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:38.176 1178 1193 I .update.servic: Waiting for a blocking GC ProfileSaver
09-16 06:47:38.205 1178 1193 I .update.servic: WaitForGcToComplete blocked ProfileSaver on HeapTrim for 28.459ms
09-16 06:47:38.401 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:38.849 1251 1270 I ndroid.calenda: Waiting for a blocking GC ProfileSaver
09-16 06:47:39.002 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:39.401 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:39.571 512 732 D SntpClient: request time failed: java.net.SocketTimeoutException: Poll timed out
09-16 06:47:39.572 512 732 V AlarmManager: setImplLocked type=3 ,when=81076
09-16 06:47:39.609 1384 1400 I timeinitialize: Waiting for a blocking GC ProfileSaver
09-16 06:47:39.686 1403 1418 I ackageinstalle: Waiting for a blocking GC ProfileSaver
09-16 06:47:39.711 1403 1418 I ackageinstalle: WaitForGcToComplete blocked ProfileSaver on HeapTrim for 25.492ms
09-16 06:47:40.003 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:40.401 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:41.003 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:41.402 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:42.004 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:42.402 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:43.005 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:43.402 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:44.005 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:44.403 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:45.006 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:45.403 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:46.006 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:46.403 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:47.007 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:47.403 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:47.516 512 537 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
09-16 06:47:47.583 1178 1178 D RKUpdateReceiver: action = android.hardware.usb.action.USB_STATE
09-16 06:47:47.583 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:47.583 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:48.007 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:48.404 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:48.541 1178 1178 D RKUpdateReceiver: action = android.hardware.usb.action.USB_STATE
09-16 06:47:48.700 512 529 I ActivityManager: Waited long enough for: ServiceRecord{2a67833 u0 android.rockchip.update.service/.RKUpdateService}
09-16 06:47:48.902 512 529 I ActivityManager: Waited long enough for: ServiceRecord{b3b26d9 u0 com.android.calendar/.alerts.InitAlarmsService}
09-16 06:47:49.007 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:49.404 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:50.008 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:50.405 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:51.009 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:51.405 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:52.009 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:52.405 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:53.010 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:53.405 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:53.801 1178 1249 D RKUpdateService: WorkHandler::handleMessage() : To perform ‘COMMAND_CHECK_LOCAL_UPDATING’.
09-16 06:47:53.801 1178 1249 D RKUpdateService: getValidFirmwareImageFile() : Target image file path : /data/media/0/update.zip
09-16 06:47:53.802 1178 1249 D RKUpdateService: getValidFirmwareImageFile() : Target image file path : /storage/emulated/0/update.zip
09-16 06:47:54.010 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:54.406 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:55.011 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:55.406 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:56.011 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:56.406 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:57.012 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:57.277 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.277 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.354 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.354 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.401 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.401 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.407 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:57.445 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.445 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.488 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.488 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.532 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.532 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.578 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.578 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.624 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.624 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.669 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.669 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.713 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.713 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.757 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.757 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.806 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.806 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:57.850 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:47:57.850 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:47:58.013 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:58.407 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:47:58.802 1178 1249 D NetworkSecurityConfig: No Network Security Config specified, using platform default
09-16 06:47:59.013 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:47:59.407 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:00.007 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:00.007 512 512 V AlarmManager: setImplLocked type=3 ,when=101504
09-16 06:48:00.007 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:00.014 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:00.097 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:00.097 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:00.408 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:01.014 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:01.408 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:02.015 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:02.408 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:03.016 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:03.408 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:03.946 1251 1296 D InitAlarmsService: Clearing and rescheduling alarms.
09-16 06:48:03.952 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:03.954 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:03.960 512 768 V AlarmManager: setImplLocked type=2 ,when=50464
09-16 06:48:04.016 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:04.029 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:04.029 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:04.074 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:04.074 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:04.119 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:04.119 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:04.178 512 528 E memtrack: Couldn’t load memtrack module
09-16 06:48:04.178 512 528 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:04.409 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:05.016 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:05.021 1178 1249 D RKUpdateService: request remote server error…
09-16 06:48:05.409 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:06.017 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:06.410 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:07.017 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:07.410 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:08.017 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:08.411 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:08.753 1062 1107 D : set stream to NULL
09-16 06:48:08.882 512 768 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.android.camera2 cmp=com.android.camera2/com.android.camera.CameraLauncher bnds=[1098,42][1196,177]} from uid 10008
09-16 06:48:08.884 512 623 W AudioTrack: AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 → 4512
09-16 06:48:08.887 257 338 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=1024
09-16 06:48:08.909 512 768 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}----com.android.camera2
09-16 06:48:08.919 512 576 W System : ClassLoader referenced unknown path:
09-16 06:48:08.926 512 768 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}----com.android.camera2
09-16 06:48:08.954 1442 1442 I Zygote : seccomp disabled by setenforce 0
09-16 06:48:08.956 512 531 I ActivityManager: Start proc 1442:com.android.camera2/u0a48 for activity com.android.camera2/com.android.camera.CameraLauncher
09-16 06:48:09.001 1442 1442 I android.camera: The ClassLoaderContext is a special shared library.
09-16 06:48:09.009 1442 1442 I android.camera: The ClassLoaderContext is a special shared library.
09-16 06:48:09.018 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:09.044 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraApp onCreate() - START
09-16 06:48:09.044 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - START
09-16 06:48:09.046 1442 1442 V CAM_Profiler: [ 1.453ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 1.453ms] PreferenceManager.getDefaultSharedPreferences
09-16 06:48:09.048 1442 1442 V CAM_Profiler: [ 3.959ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 2.506ms] preferences.getLong
09-16 06:48:09.049 1442 1442 V CAM_Profiler: [ 4.210ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - STOP
09-16 06:48:09.049 1442 1442 V CAM_Profiler: [ 5.709ms][ui] GUARD: CameraApp onCreate() - [ 5.709ms] initializeTimeOfFirstRun
09-16 06:48:09.050 1442 1442 V CAM_Profiler: [ 5.996ms][ui] GUARD: CameraApp onCreate() - [ 0.287ms] UsageStatistics.initialize
09-16 06:48:09.051 1442 1442 V CAM_Profiler: [ 8.200ms][ui] GUARD: CameraApp onCreate() - [ 2.204ms] clearNotifications
09-16 06:48:09.052 1442 1442 V CAM_Profiler: [ 8.200ms][ui] GUARD: CameraApp onCreate() - STOP
09-16 06:48:09.056 1062 1107 D : set stream to NULL
09-16 06:48:09.058 278 320 W ServiceManager: Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10008 pid=1062
09-16 06:48:09.059 278 320 D PermissionCache: checking android.permission.ACCESS_SURFACE_FLINGER for uid=10008 => denied (2860 us)
09-16 06:48:09.076 1442 1442 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.077 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onCreateTasks - START
09-16 06:48:09.077 1442 1442 D CAM_LocationManager: Using legacy location provider.
09-16 06:48:09.087 1442 1442 D CAM_MemoryManagerImpl: Max native memory: 358 MB
09-16 06:48:09.090 1442 1442 W SoundPool: Use of stream types is deprecated for operations other than volume control
09-16 06:48:09.090 1442 1442 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
09-16 06:48:09.090 1442 1442 I CAM_OneCamFtrCnfgCrtr: CaptureModule? true
09-16 06:48:09.104 1442 1442 V CAM_Profiler: [ 26.780ms][ui] GUARD: CameraActivity.onCreateTasks - [12.408ms] Glide.setup
09-16 06:48:09.106 1442 1442 V CAM_Profiler: [ 29.735ms][ui] GUARD: CameraActivity.onCreateTasks - [ 2.955ms] OneCameraManager.get
09-16 06:48:09.110 512 523 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.android.camera2 cmp=com.android.camera2/com.android.camera.CameraLauncher bnds=[1098,83][1196,218]} from uid 10008
09-16 06:48:09.121 1442 1442 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
09-16 06:48:09.122 1442 1442 I CameraManagerGlobal: Connecting to camera service
09-16 06:48:09.125 512 623 W AudioTrack: AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 → 4512
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: start_output_stream:731 out = 0xe74a9000,device = 0x400,outputs[OUTPUT_HDMI_MULTI] = 0x0
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: read_out_sound_card: buf = 0 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: get_card_number: number =0,card_name = 0 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: read_out_sound_card: buf = rockchip,rk809-codec
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: read_out_sound_card: buf = 1 [rockchiphdmi ]: rockchip_hdmi - rockchip,hdmi
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: get_card_number: number =1,card_name = 1 [rockchiphdmi ]: rockchip_hdmi - rockchip,hdmi
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: read_out_sound_card: buf = rockchip,hdmi
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: read_out_sound_card: buf = 2 [rockchipcdndpso]: rockchip-cdndp- - rockchip-cdndp-sound
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: get_card_number: number =2,card_name = 2 [rockchipcdndpso]: rockchip-cdndp- - rockchip-cdndp-sound
09-16 06:48:09.126 257 1469 D AudioHardwareTiny: read_out_sound_card: buf = rockchip-cdndp-sound
09-16 06:48:09.126 257 1469 D alsa_route: route_info->sound_card 0, route_info->devices 0
09-16 06:48:09.126 257 1469 D alsa_route: route_set_controls() set route 11
09-16 06:48:09.130 257 1469 D AudioHardwareTiny: start_output_stream:826, out = 0xe74a9000
09-16 06:48:09.133 257 1469 W StreamHAL: Error from HAL stream in function get_presentation_position: Operation not permitted
09-16 06:48:09.134 1442 1442 V CAM_Profiler: [ 57.634ms][ui] GUARD: CameraActivity.onCreateTasks - [ 6.203ms] computePictureSizes
09-16 06:48:09.151 1442 1442 D OpenGLRenderer: Skia GL Pipeline
09-16 06:48:09.159 1442 1472 I OMXClient: IOmx service obtained
09-16 06:48:09.160 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.171 438 475 E OMXNodeInstance: getConfig(0xf0217180:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.174 1442 1442 W CAM_Log : Tag RoundedThumbnailView is 1 chars longer than limit.
09-16 06:48:09.174 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.196 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 6 lines
09-16 06:48:09.197 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.273 1442 1442 W CAM_Log : Tag ModeOptionsScreenEffects is 5 chars longer than limit.
09-16 06:48:09.321 1442 1442 I CAM_BottomBar: isHorizontal = false, isPortrait = false
09-16 06:48:09.384 1442 1442 I CAM_Profiler: [307.186ms][ui] GUARD: CameraActivity.onCreateTasks - [246.760ms] setContentView()
09-16 06:48:09.400 1442 1442 I CAM_Profiler: [323.623ms][ui] GUARD: CameraActivity.onCreateTasks - [16.437ms] Configure Camera UI
09-16 06:48:09.409 1442 1442 V CAM_CameraController: Closing camera
09-16 06:48:09.410 1442 1462 W CAM2PORT_AndCamAgntImp: Releasing camera without any camera opened.
09-16 06:48:09.411 1442 1442 V CAM_ModulesInfo: EnableCaptureModule = true
09-16 06:48:09.411 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:09.414 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: new CaptureModule - START
09-16 06:48:09.414 1442 1442 V CAM_Profiler: [ 0.542ms][ui] GUARD: new CaptureModule - STOP
09-16 06:48:09.415 1442 1442 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@88f4041]
09-16 06:48:09.419 1442 1442 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@88f4041, com.android.camera.ButtonManager@3c3b740]
09-16 06:48:09.419 1442 1442 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@88f4041, com.android.camera.ButtonManager@3c3b740, com.android.camera.widget.IndicatorIconController@1debfbe]
09-16 06:48:09.420 1442 1442 V CAM_Profiler: [343.107ms][ui] GUARD: CameraActivity.onCreateTasks - [ 5.162ms] Init Current Module UI
09-16 06:48:09.420 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.init - START
09-16 06:48:09.420 1442 1442 D CAM_CaptureModule: init UseAutotransformUiLayout = false
09-16 06:48:09.422 1442 1442 D CAM_CaptureModule: cameraIds=0
09-16 06:48:09.422 1442 1442 D CAM_Camera2OneCamMgr: Getting First BACK Camera
09-16 06:48:09.430 1442 1442 W SoundPool: Use of stream types is deprecated for operations other than volume control
09-16 06:48:09.430 1442 1442 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
09-16 06:48:09.432 1442 1442 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
09-16 06:48:09.434 1442 1442 V CAM_Profiler: [ 13.519ms][ui] GUARD: CaptureModule.init - STOP
09-16 06:48:09.435 1442 1442 V CAM_Profiler: [357.869ms][ui] GUARD: CameraActivity.onCreateTasks - [14.762ms] Init CurrentModule
09-16 06:48:09.437 1442 1442 V NFC : this device does not have NFC support
09-16 06:48:09.444 1442 1442 I CAM_Profiler: [367.105ms][ui] GUARD: CameraActivity.onCreateTasks - STOP
09-16 06:48:09.444 1442 1442 V CAM_QuickActivity: END onCreate: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.450 1442 1442 V CAM_QuickActivity: START onStart: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.452 1442 1484 I OMXClient: IOmx service obtained
09-16 06:48:09.453 1442 1442 V CAM_QuickActivity: END onStart: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.453 1442 1442 V CAM_QuickActivity: START onResume: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.453 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.454 1442 1442 V CAM_QuickActivity: onResume(): isKeyguardLocked() = false
09-16 06:48:09.455 1442 1442 V CAM_QuickActivity: onResume → onResumeTasks()
09-16 06:48:09.456 438 474 E OMXNodeInstance: getConfig(0xf0217180:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.457 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.resume - START
09-16 06:48:09.457 1442 1442 V CAM_CameraActivity: Build info: rk3399pro_firefly_aioc-userdebug 9 PQ3B.190705.003 144348 test-keys
09-16 06:48:09.460 1442 1442 I CAM_CameraActivity: get mediapath value = flash
09-16 06:48:09.460 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.462 1442 1442 D CAM_CameraActivity: mUpdateStorageTask = com.android.camera.CameraActivity$22@ce10896
09-16 06:48:09.464 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.465 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 1 line
09-16 06:48:09.469 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.473 1442 1489 D CAM_Storage: External storage state=mounted
09-16 06:48:09.473 1442 1488 I OMXClient: IOmx service obtained
09-16 06:48:09.473 438 474 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.474 1442 1489 E CAM_Storage: getOtherAvailableSpace DIRECTORY:/DCIM/Camera UNAVAILABLE
09-16 06:48:09.478 438 474 E OMXNodeInstance: getConfig(0xf0217240:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.480 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.489 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 8 lines
09-16 06:48:09.489 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.489 273 273 D Sensors : set flush: handle = 2
09-16 06:48:09.489 273 581 I Sensors : report 1 flush event
09-16 06:48:09.490 1442 1442 D CAM_CaptureModule: resume
09-16 06:48:09.490 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.resume - START
09-16 06:48:09.490 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.491 1442 1442 V CAM_Profiler: [ 0.536ms][ui] GUARD: CaptureModule.resume - [ 0.032ms] getRemoteShutterListener.onModuleReady
09-16 06:48:09.492 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.504 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:48:09.506 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.508 273 273 D Sensors : set flush: handle = 2
09-16 06:48:09.508 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.508 273 581 I Sensors : report 1 flush event
09-16 06:48:09.508 1442 1442 V CAM_Profiler: [ 18.169ms][ui] GUARD: CaptureModule.resume - [ 1.813ms] mHeadingSensor.activate()
09-16 06:48:09.509 1442 1442 I CAM_Profiler: [ 18.169ms][ui] GUARD: CaptureModule.resume - STOP
09-16 06:48:09.509 1442 1442 I CAM_Profiler: [ 51.723ms][ui] GUARD: CameraActivity.resume - [19.108ms] mCurrentModule.resume
09-16 06:48:09.510 1442 1442 V CAM_Profiler: [ 52.710ms][ui] GUARD: CameraActivity.resume - [ 0.026ms] mPanoramaViewHelper.onResume()
09-16 06:48:09.511 1442 1442 V CAM_LcyLocProvider: starting location updates
09-16 06:48:09.518 1442 1442 D CAM_LcyLocProvider: provider does not exist provider doesn’t exist: network
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: fail to request location update, ignore
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: java.lang.SecurityException: “gps” location provider requires ACCESS_FINE_LOCATION permission.
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.os.Parcel.createException(Parcel.java:1950)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.os.Parcel.readException(Parcel.java:1918)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.os.Parcel.readException(Parcel.java:1868)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.location.ILocationManager$Stub$Proxy.requestLocationUpdates(ILocationManager.java:755)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.location.LocationManager.requestLocationUpdates(LocationManager.java:1007)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.location.LocationManager.requestLocationUpdates(LocationManager.java:561)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.LegacyLocationProvider.startReceivingLocationUpdates(LegacyLocationProvider.java:101)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.LegacyLocationProvider.recordLocation(LegacyLocationProvider.java:68)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.LocationManager.recordLocation(LocationManager.java:45)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity.resume(CameraActivity.java:2401)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity.access$3300(CameraActivity.java:190)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity$14.onFirstRunStateReady(CameraActivity.java:1840)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.FirstRunDialog.showIfNecessary(FirstRunDialog.java:112)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity.onResumeTasks(CameraActivity.java:2144)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.camera.util.QuickActivity.onResume(QuickActivity.java:152)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.Instrumentation.callActivityOnResume(Instrumentation.java:1412)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.Activity.performResume(Activity.java:7327)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread.performResumeActivity(ActivityThread.java:3814)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread.handleResumeActivity(ActivityThread.java:3854)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.servertransaction.ResumeActivityItem.execute(ResumeActivityItem.java:51)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.servertransaction.TransactionExecutor.executeLifecycleState(TransactionExecutor.java:145)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:70)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.os.Handler.dispatchMessage(Handler.java:106)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.os.Looper.loop(Looper.java:193)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread.main(ActivityThread.java:6718)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at java.lang.reflect.Method.invoke(Native Method)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
09-16 06:48:09.520 1442 1442 I CAM_LcyLocProvider: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
09-16 06:48:09.520 1442 1442 D CAM_LcyLocProvider: startReceivingLocationUpdates
09-16 06:48:09.521 1442 1442 I CAM_BottomBar: isHorizontal = false, isPortrait = false
09-16 06:48:09.521 1442 1442 I CAM_Profiler: [ 63.812ms][ui] GUARD: CameraActivity.resume - STOP
09-16 06:48:09.522 1442 1442 V CAM_QuickActivity: END onResume: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.549 1442 1483 V CAM_CameraDataAdapter: retrieved photo metadata, number of items: 0
09-16 06:48:09.549 1442 1483 V CAM_CameraDataAdapter: retrieved video metadata, number of items: 0
09-16 06:48:09.552 1442 1483 V CAM_CameraDataAdapter: sorting video/photo metadata
09-16 06:48:09.553 1442 1483 V CAM_CameraDataAdapter: sorted video/photo metadata
09-16 06:48:09.565 278 320 W SurfaceFlinger: Attempting to set client state on removed layer: Surface(name=AppWindowToken{884476a token=Token{dd02155 ActivityRecord{a9ad40c u0 com.android.camera2/com.android.camera.CameraLauncher t11}}})/@0xcf55f1a - animation-leash#0
09-16 06:48:09.565 278 320 W SurfaceFlinger: Attempting to set client state on removed layer: Surface(name=AppWindowToken{68c2eef token=Token{d928fce ActivityRecord{12a7cc9 u0 com.android.launcher3/.Launcher t10}}})/@0x3239ea - animation-leash#0
09-16 06:48:09.565 278 320 W SurfaceFlinger: Attempting to destroy on removed layer: Surface(name=AppWindowToken{884476a token=Token{dd02155 ActivityRecord{a9ad40c u0 com.android.camera2/com.android.camera.CameraLauncher t11}}})/@0xcf55f1a - animation-leash#0
09-16 06:48:09.565 278 320 W SurfaceFlinger: Attempting to destroy on removed layer: Surface(name=AppWindowToken{68c2eef token=Token{d928fce ActivityRecord{12a7cc9 u0 com.android.launcher3/.Launcher t10}}})/@0x3239ea - animation-leash#0
09-16 06:48:09.572 512 768 E memtrack: Couldn’t load memtrack module
09-16 06:48:09.572 512 768 W android.os.Debug: failed to get memory consumption info: -1
09-16 06:48:09.578 278 320 E BufferQueueProducer: [com.android.launcher3/com.android.launcher3.Launcher#0] disconnect: not connected (req=1)
09-16 06:48:09.578 1062 1107 W libEGL : EGLNativeWindowType 0x7c05432010 disconnect failed
09-16 06:48:09.582 1442 1485 D CAM_MemoryQuery: timestamp=50951, availMem=1419, totalMem=1894, totalPSS=19, lastTrimLevel=0, largeMemoryClass=512, nativePSS=6, dalvikPSS=2, otherPSS=11,threshold=216, lowMemory=false
09-16 06:48:09.590 1442 1497 I OMXClient: IOmx service obtained
09-16 06:48:09.591 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.593 438 475 E OMXNodeInstance: getConfig(0xf0217240:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.593 512 598 I InputDispatcher: Dropping event because there is no touchable window at (1022, 299).
09-16 06:48:09.596 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.619 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 10 lines
09-16 06:48:09.620 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.632 1442 1442 V CAM_QuickActivity: START onPause: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.633 1442 1442 V CAM_QuickActivity: onPause → onPauseTasks()
09-16 06:48:09.633 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onPause - START
09-16 06:48:09.634 1442 1442 D CAM_CaptureModule: pause
09-16 06:48:09.639 1442 1442 V CAM_ActvCamDevTrckr: Returning previously active camera: null
09-16 06:48:09.639 1442 1442 E CAM_CameraActivity: Retrieving Camera Setting Scope with -1
09-16 06:48:09.654 273 273 D Sensors : set batch: handle = 2, period_ns = 66667000ns, timeout = 100000000ns
09-16 06:48:09.654 273 273 D Sensors : setDelay : 66667000 ns, (15.00 Hz)
09-16 06:48:09.655 1442 1442 D CAM_CaptureModule: closeCamera
09-16 06:48:09.656 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.closeCamera() - START
09-16 06:48:09.656 1442 1442 V CAM_Profiler: [ 0.505ms][ui] GUARD: CaptureModule.closeCamera() - [ 0.505ms] mCameraOpenCloseLock.acquire()
09-16 06:48:09.656 1442 1442 D CAM_CaptureModule: closeCamera end
09-16 06:48:09.656 1442 1442 V CAM_Profiler: [ 0.844ms][ui] GUARD: CaptureModule.closeCamera() - STOP
09-16 06:48:09.657 512 598 I InputDispatcher: Dropping event because there is no touchable window at (1021, 300).
09-16 06:48:09.661 1442 1502 I OMXClient: IOmx service obtained
09-16 06:48:09.661 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.662 438 475 E OMXNodeInstance: getConfig(0xf0217240:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.664 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.673 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 10 lines
09-16 06:48:09.674 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.693 273 273 D Sensors : set batch: handle = 2, period_ns = 66667000ns, timeout = 100000000ns
09-16 06:48:09.693 273 273 D Sensors : setDelay : 66667000 ns, (15.00 Hz)
09-16 06:48:09.694 1442 1442 V CAM_LcyLocProvider: stopping location updates
09-16 06:48:09.694 1442 1442 D CAM_LcyLocProvider: stopReceivingLocationUpdates
09-16 06:48:09.694 1442 1442 V CAM_CameraActivity: onPause closing camera
09-16 06:48:09.695 1442 1442 V CAM_CameraController: Closing camera
09-16 06:48:09.695 1442 1462 W CAM2PORT_AndCamAgntImp: Releasing camera without any camera opened.
09-16 06:48:09.696 1442 1442 I CAM_Profiler: [ 62.743ms][ui] GUARD: CameraActivity.onPause - STOP
09-16 06:48:09.696 1442 1442 V CAM_QuickActivity: END onPause: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.696 1442 1442 V CAM_QuickActivity: START onNewIntent: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.696 1442 1442 V CAM_QuickActivity: Intent Action = android.intent.action.MAIN
09-16 06:48:09.696 1442 1442 I CAM_CameraActivity: onModeSelected = 0
09-16 06:48:09.696 1442 1442 V CAM_QuickActivity: END onNewIntent: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.696 1442 1442 V CAM_QuickActivity: START onResume: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.697 1442 1442 V CAM_QuickActivity: onResume(): isKeyguardLocked() = false
09-16 06:48:09.697 1442 1442 V CAM_QuickActivity: onResume → onResumeTasks()
09-16 06:48:09.698 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.resume - START
09-16 06:48:09.698 1442 1442 V CAM_CameraActivity: Build info: rk3399pro_firefly_aioc-userdebug 9 PQ3B.190705.003 144348 test-keys
09-16 06:48:09.700 512 573 W ActivityManager: Receiver with filter android.content.IntentFilter@95342f6 already registered for pid 1442, callerPackage is com.android.camera2
09-16 06:48:09.700 1442 1442 I CAM_CameraActivity: get mediapath value = flash
09-16 06:48:09.701 1442 1442 D CAM_CameraActivity: mUpdateStorageTask = com.android.camera.CameraActivity$22@66ab7f2
09-16 06:48:09.704 1442 1506 D CAM_Storage: External storage state=mounted
09-16 06:48:09.704 1442 1506 E CAM_Storage: getOtherAvailableSpace DIRECTORY:/DCIM/Camera UNAVAILABLE
09-16 06:48:09.704 273 273 D Sensors : set flush: handle = 2
09-16 06:48:09.704 273 581 I Sensors : report 1 flush event
09-16 06:48:09.705 1442 1442 D CAM_CaptureModule: resume
09-16 06:48:09.705 1442 1442 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.resume - START
09-16 06:48:09.705 1442 1442 V CAM_Profiler: [ 0.291ms][ui] GUARD: CaptureModule.resume - [ 0.012ms] getRemoteShutterListener.onModuleReady
09-16 06:48:09.707 1442 1442 W SoundPool: Use of stream types is deprecated for operations other than volume control
09-16 06:48:09.707 1442 1442 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
09-16 06:48:09.709 1442 1442 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
09-16 06:48:09.710 273 581 D Sensors : set flush: handle = 2
09-16 06:48:09.711 273 273 I Sensors : report 1 flush event
09-16 06:48:09.711 1442 1442 V CAM_Profiler: [ 5.895ms][ui] GUARD: CaptureModule.resume - [ 1.071ms] mHeadingSensor.activate()
09-16 06:48:09.711 1442 1442 V CAM_Profiler: [ 5.895ms][ui] GUARD: CaptureModule.resume - STOP
09-16 06:48:09.711 1442 1442 V CAM_Profiler: [ 13.348ms][ui] GUARD: CameraActivity.resume - [ 6.600ms] mCurrentModule.resume
09-16 06:48:09.712 1442 1442 V CAM_Profiler: [ 13.745ms][ui] GUARD: CameraActivity.resume - [ 0.005ms] mPanoramaViewHelper.onResume()
09-16 06:48:09.712 1442 1442 V CAM_LcyLocProvider: starting location updates
09-16 06:48:09.713 512 598 I InputDispatcher: Dropping event because there is no touchable window at (1021, 301).
09-16 06:48:09.713 1442 1442 D CAM_LcyLocProvider: provider does not exist provider doesn’t exist: network
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: fail to request location update, ignore
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: java.lang.SecurityException: “gps” location provider requires ACCESS_FINE_LOCATION permission.
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.os.Parcel.createException(Parcel.java:1950)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.os.Parcel.readException(Parcel.java:1918)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.os.Parcel.readException(Parcel.java:1868)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.location.ILocationManager$Stub$Proxy.requestLocationUpdates(ILocationManager.java:755)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.location.LocationManager.requestLocationUpdates(LocationManager.java:1007)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.location.LocationManager.requestLocationUpdates(LocationManager.java:561)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.LegacyLocationProvider.startReceivingLocationUpdates(LegacyLocationProvider.java:101)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.LegacyLocationProvider.recordLocation(LegacyLocationProvider.java:68)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.LocationManager.recordLocation(LocationManager.java:45)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity.resume(CameraActivity.java:2401)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity.access$3300(CameraActivity.java:190)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity$14.onFirstRunStateReady(CameraActivity.java:1840)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.app.FirstRunDialog.showIfNecessary(FirstRunDialog.java:112)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.CameraActivity.onResumeTasks(CameraActivity.java:2144)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.camera.util.QuickActivity.onResume(QuickActivity.java:152)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.Instrumentation.callActivityOnResume(Instrumentation.java:1412)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.Activity.performResume(Activity.java:7327)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread.performNewIntents(ActivityThread.java:3164)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread.handleNewIntent(ActivityThread.java:3179)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.servertransaction.NewIntentItem.execute(NewIntentItem.java:49)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.os.Handler.dispatchMessage(Handler.java:106)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.os.Looper.loop(Looper.java:193)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at android.app.ActivityThread.main(ActivityThread.java:6718)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at java.lang.reflect.Method.invoke(Native Method)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
09-16 06:48:09.714 1442 1442 I CAM_LcyLocProvider: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
09-16 06:48:09.715 1442 1442 D CAM_LcyLocProvider: startReceivingLocationUpdates
09-16 06:48:09.715 1442 1442 I CAM_BottomBar: isHorizontal = false, isPortrait = false
09-16 06:48:09.715 1442 1442 I CAM_Profiler: [ 16.937ms][ui] GUARD: CameraActivity.resume - STOP
09-16 06:48:09.716 1442 1442 V CAM_QuickActivity: END onResume: Activity = com.android.camera.CameraActivity@2fc3710
09-16 06:48:09.722 1442 1511 I OMXClient: IOmx service obtained
09-16 06:48:09.722 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.724 1442 1442 V CAM_FocusController: configurePreviewDimensions(RectF(0.0, 0.0, 0.0, 0.0))
09-16 06:48:09.726 438 475 E OMXNodeInstance: getConfig(0xf0217240:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.728 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.736 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 6 lines
09-16 06:48:09.737 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.737 512 598 I InputDispatcher: Dropping event because there is no touchable window at (1021, 303).
09-16 06:48:09.747 1442 1494 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:48:09.747 1442 1494 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
09-16 06:48:09.747 1442 1442 V CAM_TexViewHelper: onLayoutChange
09-16 06:48:09.747 1442 1514 I OMXClient: IOmx service obtained
09-16 06:48:09.747 1442 1494 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
09-16 06:48:09.747 1442 1494 I mali_so : cmdline : com.android.camera2, we should GO THROUGH patch_for_sf_memory_leak.
09-16 06:48:09.747 1442 1494 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
09-16 06:48:09.747 1442 1494 D mali_so : current process is NOT sf, to bail out.
09-16 06:48:09.747 1442 1442 V CAM_TexViewHelper: updateTransform
09-16 06:48:09.748 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.748 1442 1442 V CAM_TexViewHelper: setAspectRatio: 0.0
09-16 06:48:09.748 1442 1442 D CAM_CaptureModule: updatePreviewTransform: 1196 x 720
09-16 06:48:09.750 1442 1442 V CAM_TexViewHelper: setAspectRatio: NaN
09-16 06:48:09.751 1442 1442 V CAM_TexViewHelper: aspect ratio changed from: 0.0
09-16 06:48:09.753 438 475 E OMXNodeInstance: getConfig(0xf0217360:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.756 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.763 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 4 lines
09-16 06:48:09.763 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.764 1442 1494 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
09-16 06:48:09.764 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.765 1442 1494 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
09-16 06:48:09.765 1442 1494 I OpenGLRenderer: Initialized EGL, version 1.4
09-16 06:48:09.765 1442 1494 D OpenGLRenderer: Swap behavior 2
09-16 06:48:09.765 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.778 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 3 lines
09-16 06:48:09.778 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.782 1442 1494 D mali_winsys: EGLint new_window_surface(egl_winsys_display , void , EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
09-16 06:48:09.785 1442 1442 V CAM_CameraActivity: ignoring storage callback after activity pause
09-16 06:48:09.785 1442 1442 V CAM_FocusController: configurePreviewDimensions(RectF(0.0, 0.0, 0.0, 0.0))
09-16 06:48:09.823 1442 1442 V CAM_TexViewHelper: updateTransform
09-16 06:48:09.823 1442 1442 V CAM_CameraAppUI: SurfaceTexture is available
09-16 06:48:09.823 1442 1442 D CAM_CaptureModule: onSurfaceTextureAvailable
09-16 06:48:09.823 1442 1442 D CAM_CaptureModule: updatePreviewTransform: 1196 x 720
09-16 06:48:09.825 1442 1442 V CAM_TexViewHelper: setAspectRatio: NaN
09-16 06:48:09.825 1442 1442 V CAM_TexViewHelper: aspect ratio changed from: NaN
09-16 06:48:09.826 1442 1442 I CAM_FocusRingView: Computing center via view bounds.
09-16 06:48:09.826 1442 1483 D CAM_CaptureModule: closeCamera
09-16 06:48:09.826 1442 1483 V CAM_Profiler: [ 0.000ms] GUARD: CaptureModule.closeCamera() - START
09-16 06:48:09.826 1442 1483 V CAM_Profiler: [ 0.561ms] GUARD: CaptureModule.closeCamera() - [ 0.561ms] mCameraOpenCloseLock.acquire()
09-16 06:48:09.827 1442 1483 D CAM_CaptureModule: closeCamera end
09-16 06:48:09.827 1442 1483 V CAM_Profiler: [ 0.954ms] GUARD: CaptureModule.closeCamera() - STOP
09-16 06:48:09.827 1442 1483 V CAM_Profiler: [ 0.000ms] GUARD: CaptureModule.openCameraAndStartPreview() - START
09-16 06:48:09.827 1442 1483 V CAM_Profiler: [ 0.302ms] GUARD: CaptureModule.openCameraAndStartPreview() - [ 0.302ms] Acquired mCameraOpenCloseLock
09-16 06:48:09.828 1442 1483 D CAM_Camera2OneCamMgr: Getting First BACK Camera
09-16 06:48:09.830 1442 1483 D CAM_CaptureModule: cameraId=CameraId{Api2=‘0’,Api1:0}
09-16 06:48:09.830 1442 1483 D CAM_ResolutionSettings: cameraId=0
09-16 06:48:09.831 1442 1483 W CAM_Log : Tag OneCameraCaptureSetting is 4 chars longer than limit.
09-16 06:48:09.831 1442 1483 D CAM_OneCameraCaptureSet: OneCameraCaptureSetting.create()
09-16 06:48:09.832 1442 1483 I CAM_OneCamera1Opnr: Opening Camera: CameraId{Api2=‘0’,Api1:0}
09-16 06:48:09.832 1442 1483 V CAM_ActvCamDevTrckr: Tracking active camera: null
09-16 06:48:09.835 1442 1494 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
09-16 06:48:09.840 425 425 W cameraserver: type=1400 audit(0.0:284): avc: denied { write } for name=“property_service” dev=“tmpfs” ino=10197 scontext=u:r:cameraserver:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_f
09-16 06:48:09.845 1442 1528 I OMXClient: IOmx service obtained
09-16 06:48:09.845 438 475 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.845 425 425 I CameraService: CameraService::connect call (PID -1 “com.android.camera2”, camera ID 0) for HAL version default and Camera API version 2
09-16 06:48:09.849 438 475 E OMXNodeInstance: getConfig(0xf0217240:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.852 425 425 I Camera2ClientBase: Camera 0: Opened. Client: com.android.camera2 (PID 1442, UID 10048)
09-16 06:48:09.853 425 425 I CameraDeviceClient: CameraDeviceClient 0: Opened
09-16 06:48:09.856 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.858 1442 1494 D : set stream to NULL
09-16 06:48:09.859 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.859 1442 1494 D : set stream to NULL
09-16 06:48:09.860 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.861 1442 1494 D : set stream to NULL
09-16 06:48:09.861 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.862 1442 1494 D : set stream to NULL
09-16 06:48:09.863 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.863 1442 1494 D : set stream to NULL
09-16 06:48:09.864 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.865 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.865 257 941 D AudioHardwareTiny: adev_set_parameters: kvpairs = cameraFacing=back
09-16 06:48:09.869 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.870 260 494 D RkCamera: Debug log file is not enabled
09-16 06:48:09.872 1442 1442 V CAM_CameraDataAdapter: new photos query return num items: 0
09-16 06:48:09.876 1442 1442 I CAM_CameraActivity: mOrignalScreenBrightMode = 0,mOrignalScreenBrightness = 120
09-16 06:48:09.877 512 512 V SettingsProvider: Notifying for 0: content://settings/system/screen_brightness
09-16 06:48:09.879 260 494 D RkCamera: Debug log file is not enabled
09-16 06:48:09.879 260 494 E RkCamera: FlashLight: init: No flash available for camera id: 0
09-16 06:48:09.884 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.888 260 494 E RkCamera: PlatformData: cronggui:getSensorFormats
09-16 06:48:09.888 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.889 260 494 E RkCamera: PlatformData: cronggui:getSensorFormats 11
09-16 06:48:09.889 260 494 E RkCamera: PlatformData: @getAvailableSensorOutputFormats 1163: code: 0x3007, frame size: Min(1920x1080) Max(1920x1080)
09-16 06:48:09.889 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.891 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 1 line
09-16 06:48:09.892 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.894 512 528 I ActivityManager: Displayed com.android.camera2/com.android.camera.CameraLauncher: +997ms
09-16 06:48:09.900 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.909 260 494 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:538bfe4
09-16 06:48:09.909 260 494 I gralloc : [File] : hardware/rockchip/libgralloc/mali_gralloc_formats.cpp; [Line] : 76; [Func] : mali_gralloc_select_format;
09-16 06:48:09.909 260 494 I gralloc : to select NV12 for HAL_PIXEL_FORMAT_IMPLEMENTATION_DEFINED for usage : 0x30003.
09-16 06:48:09.909 260 494 I [Gralloc]: for nv12, w : 1920, h : 1080, pixel_stride : 1920, byte_stride : 1920, size : 4147200; internalHeight : 1080.
09-16 06:48:09.911 1442 1442 V CAM_FocusController: configurePreviewDimensions(RectF(NaN, NaN, NaN, NaN))
09-16 06:48:09.911 1442 1442 I CAM_FocusRingView: Computing center via view bounds.
09-16 06:48:09.912 1442 1442 I CAM_FocusRingView: Computing center via view bounds.
09-16 06:48:09.914 1442 1494 D : set stream to NULL
09-16 06:48:09.917 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.924 260 494 I gralloc : [File] : hardware/rockchip/libgralloc/mali_gralloc_formats.cpp; [Line] : 76; [Func] : mali_gralloc_select_format;
09-16 06:48:09.924 260 494 I gralloc : to select NV12 for HAL_PIXEL_FORMAT_IMPLEMENTATION_DEFINED for usage : 0x30003.
09-16 06:48:09.924 260 494 I [Gralloc]: for nv12, w : 1920, h : 1080, pixel_stride : 1920, byte_stride : 1920, size : 4147200; internalHeight : 1080.
09-16 06:48:09.930 260 494 I gralloc : [File] : hardware/rockchip/libgralloc/mali_gralloc_formats.cpp; [Line] : 76; [Func] : mali_gralloc_select_format;
09-16 06:48:09.930 260 494 I gralloc : to select NV12 for HAL_PIXEL_FORMAT_IMPLEMENTATION_DEFINED for usage : 0x30003.
09-16 06:48:09.930 260 494 I [Gralloc]: for nv12, w : 1920, h : 1080, pixel_stride : 1920, byte_stride : 1920, size : 4147200; internalHeight : 1080.
09-16 06:48:09.933 1442 1442 V CAM_FocusController: configurePreviewDimensions(RectF(NaN, NaN, NaN, NaN))
09-16 06:48:09.933 1442 1442 I CAM_FocusRingView: Computing center via view bounds.
09-16 06:48:09.939 260 494 I gralloc : [File] : hardware/rockchip/libgralloc/mali_gralloc_formats.cpp; [Line] : 76; [Func] : mali_gralloc_select_format;
09-16 06:48:09.939 260 494 I gralloc : to select NV12 for HAL_PIXEL_FORMAT_IMPLEMENTATION_DEFINED for usage : 0x30003.
09-16 06:48:09.939 260 494 I [Gralloc]: for nv12, w : 1920, h : 1080, pixel_stride : 1920, byte_stride : 1920, size : 4147200; internalHeight : 1080.
09-16 06:48:09.939 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.943 260 260 W HwBinder:260_1: type=1400 audit(0.0:286): avc: denied { read } for name=“u:object_r:system_prop:s0” dev=“tmpfs” ino=10171 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=f
09-16 06:48:09.951 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.943 260 260 W HwBinder:260_1: type=1400 audit(0.0:287): avc: denied { open } for path=“/dev/properties/u:object_r:system_prop:s0” dev=“tmpfs” ino=10171 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=f
09-16 06:48:09.946 260 260 W HwBinder:260_1: type=1400 audit(0.0:289): avc: denied { read } for name=“u:object_r:default_prop:s0” dev=“tmpfs” ino=10111 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:default_prop:s0 tclass=f
09-16 06:48:09.959 1442 1483 I CAM_Profiler: [131.890ms] GUARD: CaptureModule.openCameraAndStartPreview() - [131.588ms] mOneCameraOpener.open()
09-16 06:48:09.960 1442 1483 I CAM_Profiler: [131.890ms] GUARD: CaptureModule.openCameraAndStartPreview() - STOP
09-16 06:48:09.961 1442 1477 E CAM_OneCamFtrCnfgCrtr: Unknown support level: 0
09-16 06:48:09.961 1442 1477 I CAM_OneCamCreator: Camera support level: LIMITED_JPEG
09-16 06:48:09.963 1442 1477 W CAM_Log : Tag SimpleOneCameraFactory is 3 chars longer than limit.
09-16 06:48:09.965 1442 1477 I CAM_OneCamCreator: Picture Size Configuration: PictureSizeCalculator.Configuration{native size=1920x1080, crop=Rect(0, 0 - 1920, 1080)}
09-16 06:48:09.973 1442 1477 D CAM_CaptureModule: onCameraOpened: com.android.camera.one.v2.initialization.GenericOneCameraImpl@30bc10f
09-16 06:48:09.974 1442 1477 D CAM_CaptureModule: starting preview …
09-16 06:48:09.976 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.977 1442 1442 W CAM_IndicatorIconCtrlr: Trying to sync a pano indicator that is not initialized.
09-16 06:48:09.980 425 425 W CameraDeviceClient: createSurfaceFromGbp: Camera 0 with consumer usage flag: 256: Forcing asynchronous mode for stream
09-16 06:48:09.981 425 425 W CameraDeviceClient: createSurfaceFromGbp: Camera 0: Overriding format 0x1 to IMPLEMENTATION_DEFINED
09-16 06:48:09.982 260 1537 E RkCamera: PlatformData: cronggui:getSensorFormats
09-16 06:48:09.982 260 1537 E RkCamera: PlatformData: cronggui:getSensorFormats 11
09-16 06:48:09.982 260 1537 E RkCamera: PlatformData: @getAvailableSensorOutputFormats 1163: code: 0x3007, frame size: Min(1920x1080) Max(1920x1080)
09-16 06:48:09.984 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:09.992 1442 1544 I OMXClient: IOmx service obtained
09-16 06:48:09.992 438 1495 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
09-16 06:48:09.995 438 1495 E OMXNodeInstance: getConfig(0xf0217240:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
09-16 06:48:09.998 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:09.999 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.000 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.001 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.002 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.003 260 1533 I mpp_rt : NOT found ion allocator
09-16 06:48:10.003 260 1533 I mpp_rt : found drm allocator
09-16 06:48:10.009 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.010 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:48:10.011 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.018 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.018 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:10.019 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.021 255 255 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
09-16 06:48:10.022 255 255 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x708062c100, 32768)
09-16 06:48:10.036 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.051 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.057 278 320 W SurfaceFlinger: Attempting to set client state on removed layer: Splash Screen com.android.camera2#0
09-16 06:48:10.057 278 320 W SurfaceFlinger: Attempting to destroy on removed layer: Splash Screen com.android.camera2#0
09-16 06:48:10.067 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.117 512 635 I chatty : uid=1000(system) PhotonicModulat identical 3 lines
09-16 06:48:10.134 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.136 260 1537 E rkisp : [AWB]:XCAM ERROR awb_v11.c:113: AwbPrepareCalibDbAccess: resolution (1920x1080@0.000000) not found in database
09-16 06:48:10.136 260 1537 F libc : Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x24 in tid 1537 (Cam3ReqThread), pid 260 (provider@2.4-se)
09-16 06:48:10.150 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.168 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.174 1552 1552 I crash_dump32: obtaining output fd from tombstoned, type: kDebuggerdTombstone
09-16 06:48:10.174 445 445 I /system/bin/tombstoned: received crash request for pid 1537
09-16 06:48:10.175 1552 1552 I crash_dump32: performing dump of process 260 (target tid = 1537)
09-16 06:48:10.180 1552 1552 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
09-16 06:48:10.180 1552 1552 F DEBUG : Build fingerprint: ‘rockchip/rk3399pro_firefly_aioc/rk3399pro:9/PQ3B.190705.003/root09161442:userdebug/test-keys’
09-16 06:48:10.180 1552 1552 F DEBUG : Revision: ‘0’
09-16 06:48:10.180 1552 1552 F DEBUG : ABI: ‘arm’
09-16 06:48:10.180 1552 1552 F DEBUG : pid: 260, tid: 1537, name: Cam3ReqThread >>> /vendor/bin/hw/android.hardware.camera.provider@2.4-service <<<
09-16 06:48:10.180 1552 1552 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x24
09-16 06:48:10.180 1552 1552 F DEBUG : Cause: null pointer dereference
09-16 06:48:10.180 1552 1552 F DEBUG : r0 e9ce80b4 r1 00000024 r2 00000018 r3 0000000c
09-16 06:48:10.180 1552 1552 F DEBUG : r4 e9ce3a00 r5 e9e2bda8 r6 00000000 r7 00000001
09-16 06:48:10.180 1552 1552 F DEBUG : r8 00000003 r9 00002da8 r10 e9ce67a8 r11 00002ec8
09-16 06:48:10.180 1552 1552 F DEBUG : ip 80000000 sp eb8ac9a8 lr e9f12343 pc ef35be20
09-16 06:48:10.186 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.197 1552 1552 F DEBUG :
09-16 06:48:10.197 1552 1552 F DEBUG : backtrace:
09-16 06:48:10.197 1552 1552 F DEBUG : #00 pc 00019e20 /system/lib/libc.so (memcpy+68)
09-16 06:48:10.197 1552 1552 F DEBUG : #01 pc 0000f33f /vendor/lib/rkisp/awb/librkisp_awb.so (V11_AwbStart+210)
09-16 06:48:10.197 1552 1552 F DEBUG : #02 pc 00008f4d /vendor/lib/rkisp/awb/librkisp_awb.so (AwbStart+60)
09-16 06:48:10.197 1552 1552 F DEBUG : #03 pc 00004aff /vendor/lib/rkisp/awb/librkisp_awb.so (xcam_update_awb_params(_XCam3AContext, void)+178)
09-16 06:48:10.197 1552 1552 F DEBUG : #04 pc 0005258d /vendor/lib/librkisp.so (CamIA10Engine::updateAwbConfig(CamIA10_DyCfg)+1384)
09-16 06:48:10.197 1552 1552 F DEBUG : #05 pc 00051563 /vendor/lib/librkisp.so (CamIA10Engine::initDynamic(CamIA10_DyCfg)+162)
09-16 06:48:10.197 1552 1552 F DEBUG : #06 pc 0004e05d /vendor/lib/librkisp.so (IspEngine::updateDynamicConfig(CamIA10_DyCfg)+28)
09-16 06:48:10.197 1552 1552 F DEBUG : #07 pc 00046193 /vendor/lib/librkisp.so (XCam::RKiqCompositor::set_sensor_mode_data(isp_supplemental_sensor_mode_data, bool)+682)
09-16 06:48:10.197 1552 1552 F DEBUG : #08 pc 0003e89f /vendor/lib/librkisp.so (XCam::X3aAnalyzerRKiq::configure_3a()+138)
09-16 06:48:10.197 1552 1552 F DEBUG : #09 pc 0005ff5f /vendor/lib/librkisp.so (XCam::XAnalyzer::start()+14)
09-16 06:48:10.197 1552 1552 F DEBUG : #10 pc 00059485 /vendor/lib/librkisp.so (XCam::DeviceManager::start()+216)
09-16 06:48:10.197 1552 1552 F DEBUG : #11 pc 00035547 /vendor/lib/librkisp.so (rkisp_cl_start+102)
09-16 06:48:10.197 1552 1552 F DEBUG : #12 pc 000c5289 /vendor/lib/hw/camera.rk30board.so (android::camera2::RkCtrlLoop::start(rkisp_cl_prepare_params_s const&)+140)
09-16 06:48:10.198 1552 1552 F DEBUG : #13 pc 000a4149 /vendor/lib/hw/camera.rk30board.so (android::camera2::ControlUnit::configStreams(std::__1::vector<camera3_stream, std::__1::allocator<camera3_stream>>&, bool)+588)
09-16 06:48:10.198 1552 1552 F DEBUG : #14 pc 0009f039 /vendor/lib/hw/camera.rk30board.so (android::camera2::RKISP1CameraHw::doConfigureStreams(android::camera2::RKISP1CameraHw::UseCase, unsigned int, int)+320)
09-16 06:48:10.198 1552 1552 F DEBUG : #15 pc 0009ee6d /vendor/lib/hw/camera.rk30board.so (android::camera2::RKISP1CameraHw::configStreams(std::__1::vector<camera3_stream, std::__1::allocator<camera3_stream>>&, unsigned int)+492)
09-16 06:48:10.198 1552 1552 F DEBUG : #16 pc 00063577 /vendor/lib/hw/camera.rk30board.so (android::camera2::RequestThread::handleConfigureStreams(android::camera2::RequestThread::Message&)+494)
09-16 06:48:10.198 1552 1552 F DEBUG : #17 pc 000642e1 /vendor/lib/hw/camera.rk30board.so (android::camera2::RequestThread::messageThreadLoop()+280)
09-16 06:48:10.198 1552 1552 F DEBUG : #18 pc 00082999 /vendor/lib/hw/camera.rk30board.so (android::camera2::MessageThread::threadLoop(void)+8)
09-16 06:48:10.198 1552 1552 F DEBUG : #19 pc 00064323 /system/lib/libc.so (__pthread_start(void)+22)
09-16 06:48:10.198 1552 1552 F DEBUG : #20 pc 0001dfad /system/lib/libc.so (__start_thread+32)
09-16 06:48:10.276 512 663 W NativeCrashListener: Couldn’t find ProcessRecord for pid 260
09-16 06:48:10.251 512 635 I chatty : uid=1000(system) PhotonicModulat identical 4 lines
09-16 06:48:10.267 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.277 445 445 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_01
09-16 06:48:10.283 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.291 512 534 I BootReceiver: Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
09-16 06:48:10.302 425 425 E Camera3-Device: configureStreams: Transaction error: Status(EX_TRANSACTION_FAILED): 'DEAD_OBJECT: ’
09-16 06:48:10.302 425 425 E Camera3-Device: Camera 0: configureStreamsLocked: Unable to configure streams with HAL: Broken pipe (-32)
09-16 06:48:10.305 425 493 I CameraProviderManager: Camera provider ‘legacy/0’ has died; removing it
09-16 06:48:10.305 425 493 I CameraService: onDeviceStatusChanged: Status changed for cameraId=0, newStatus=0
09-16 06:48:10.310 425 493 I CameraService: onDeviceStatusChanged: Client for camera ID 0 evicted due to device status change from HAL
09-16 06:48:10.311 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.335 512 635 I chatty : uid=1000(system) PhotonicModulat identical 2 lines
09-16 06:48:10.352 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.364 1559 1559 I android.hardware.camera.provider@2.4-service: Camera provider Service is starting.
09-16 06:48:10.367 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.384 512 635 I chatty : uid=1000(system) PhotonicModulat identical 1 line
09-16 06:48:10.400 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.411 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:10.419 512 522 I system_server: Background concurrent copying GC freed 34568(2MB) AllocSpace objects, 14(1816KB) LOS objects, 42% free, 6MB/11MB, paused 976us total 123.649ms
09-16 06:48:10.421 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.427 1559 1559 I vpu_api : dlopen vpu lib /vendor/lib/librk_vpuapi.so success
09-16 06:48:10.431 1559 1559 D RkCamera: Debug log file is not enabled
09-16 06:48:10.431 1559 1559 I Camera3HALModule: @initCameraHAL: RockChip Camera Hal3 Release version v1.9.1
09-16 06:48:10.436 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.443 1559 1559 D RkCamera: Debug log file is not enabled
09-16 06:48:10.443 1559 1559 I CamProvider@2.4-impl: Loaded “Rockchip Camera3HAL Module” camera module
09-16 06:48:10.445 1559 1559 D RkCamera: Debug log file is not enabled
09-16 06:48:10.447 1559 1559 D RkCamera: Debug log file is not enabled
09-16 06:48:10.448 1559 1559 I ServiceManagement: Removing namespace from process name android.hardware.camera.provider@2.4-service to provider@2.4-service.
09-16 06:48:10.453 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.454 1559 1559 I android.hardware.camera.provider@2.4-service: Registration complete for android.hardware.camera.provider@2.4::ICameraProvider/legacy/0.
09-16 06:48:10.457 425 498 I CameraProviderManager: Connecting to new camera provider: legacy/0, isRemote? 1
09-16 06:48:10.457 425 498 I CameraProviderManager: Enumerating new camera device: device@3.3/legacy/0
09-16 06:48:10.459 1559 1559 D RkCamera: Debug log file is not enabled
09-16 06:48:10.460 425 498 I CameraProviderManager: Camera provider legacy/0 ready with 1 camera devices
09-16 06:48:10.460 425 498 I CameraService: onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
09-16 06:48:10.469 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.484 512 635 E LightsService: Light requested not available on this device. 0
09-16 06:48:10.500 425 425 D CameraTraces: Process trace saved. Use dumpsys media.camera to view.
09-16 06:48:10.500 425 425 E CameraDeviceClient: endConfigure: Camera 0: Error configuring streams: Broken pipe (-32)
09-16 06:48:10.501 1442 1477 E CameraCaptureSession: Session 0: Failed to create capture session; configuration failed
09-16 06:48:10.502 1442 1505 W android.camera: Long monitor contention with owner CaptureModule.mCameraHandler (1477) at boolean android.os.BinderProxy.transactNative(int, android.os.Parcel, android.os.Parcel, int)(Binder.java:-2) waiters=0 in void android.hardware.camera2.impl.CameraDeviceImpl$CameraDeviceCallbacks.onDeviceError(int, android.hardware.camera2.impl.CaptureResultExtras) for 198ms
09-16 06:48:10.505 1442 1477 E CAM_CaptureModule: Could not set up preview.
09-16 06:48:10.510 425 493 E Camera3-Device: Camera 0: clearStreamingRequest: Device has encountered a serious error
09-16 06:48:10.510 425 493 I Camera3-Device: disconnect: E
09-16 06:48:10.510 425 493 E Camera3-Device: Camera 0: disconnect: Shutting down in an error state
09-16 06:48:10.510 425 493 I Camera3-Device: disconnect: X
09-16 06:48:10.512 425 493 I CameraService: disconnect: Disconnected client for camera 0 for PID 1442
09-16 06:48:10.513 1442 1442 D CAM_LoggingImageReader: Closing: ImageReader{width=1920, height=1080, format=JPEG}
09-16 06:48:11.018 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:11.412 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:11.953 440 440 W npu_monitor: type=1400 audit(0.0:292): avc: denied { read } for name=“temp” dev=“sysfs” ino=9494 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
09-16 06:48:12.019 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:12.100 1178 1249 D RKUpdateService: request remote server error…
09-16 06:48:12.247 257 941 D AudioHardwareTiny: do_out_standby,out = 0xe74a9000,device = 0x80408
09-16 06:48:12.249 257 941 D alsa_route: route_set_controls() set route 24
09-16 06:48:12.254 257 941 D AudioHardwareTiny: close device
09-16 06:48:12.412 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:12.985 512 636 E TaskPersister: File error accessing recents directory (directory doesn’t exist?).
09-16 06:48:13.019 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:13.413 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:14.020 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:14.413 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:15.020 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:15.413 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:16.021 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:16.414 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:17.021 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:17.414 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:18.022 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:18.414 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:19.022 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:19.415 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:20.023 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:20.415 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:21.023 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:21.416 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:22.024 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:22.416 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:23.024 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:23.416 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:24.025 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:24.417 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:25.026 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:25.417 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:26.026 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:26.417 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:26.878 436 463 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
09-16 06:48:27.027 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
09-16 06:48:27.418 797 797 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
09-16 06:48:28.027 442 442 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
