android 9.0 firefly rk3399pro 开发板 调试c2395 camera sensor
1:调试c2395 camera sensor 打开相机apk 后,黑屏: kernel中 mipi stream 数据流的库函数没有走到;
2:hal camera_profile.xml 没有注册成功,不知道为什么?
log:如下
Number of camera devices: 1
Number of normal camera devices: 1
Device 0 maps to “0”
Active Camera Clients:
Allowed user IDs: 0
== Camera service events log (most recent at top): ==
09-16 06:48:10 : DISCONNECT device 0 client for package com.android.camera2 (PID 1442)
09-16 06:48:10 : ADD device 0, reason: (Device status changed from 0 to 1)
09-16 06:48:10 : REMOVE device 0, reason: (Device status changed from -2 to 0)
09-16 06:48:09 : CONNECT device 0 client for package com.android.camera2 (PID 1442)
09-16 06:47:28 : USER_SWITCH previous allowed user IDs: , current allowed user IDs: 0
08-05 09:00:08 : ADD device 0, reason: (Device status changed from 0 to 1)
08-05 09:00:08 : ADD device 0, reason: (Device added)
== Camera Provider HAL external/0 (v2.4, remote) static info: 0 devices: ==
== Camera Provider HAL legacy/0 (v2.4, remote) static info: 1 devices: ==
== Camera HAL device device@3.3/legacy/0 (v3.3) static information: ==
Resource cost: 50
Conflicting devices: None
API1 info:
Has a flash unit: false
Facing: Back
Orientation: 180
API2 camera characteristics:
Dumping camera metadata array: 68 / 68 entries, 2080 / 2080 bytes of extra data.
Version: 1, Flags: 00000000
android.colorCorrection.availableAberrationModes (00004): byte[1]
[0 ]
android.control.aeAvailableAntibandingModes (10012): byte[4]
[0 1 2 3 ]
android.control.aeAvailableModes (10013): byte[2]
[1 0 ]
android.control.aeAvailableTargetFpsRanges (10014): int32[4]
[15 30 30 30 ]
android.control.aeCompensationRange (10015): int32[2]
[-6 6 ]
android.control.aeCompensationStep (10016): rational[1]
[(1 / 3) ]
android.control.afAvailableModes (10017): byte[6]
[0 1 2 3 4 5 ]
android.control.availableEffects (10018): byte[1]
[0 ]
android.control.availableSceneModes (10019): byte[1]
[0 ]
android.control.availableVideoStabilizationModes (1001a): byte[1]
[0 ]
android.control.awbAvailableModes (1001b): byte[5]
[1 2 3 5 6 ]
android.control.maxRegions (1001c): int32[3]
[1 0 1 ]
android.control.aeLockAvailable (10024): byte[1]
[FALSE ]
android.control.awbLockAvailable (10025): byte[1]
[FALSE ]
android.control.availableModes (10026): byte[1]
[1 ]
android.edge.availableEdgeModes (30002): byte[3]
[0 1 2 ]
android.flash.colorTemperature (40003): byte[1]
[0 ]
android.flash.maxEnergy (40004): byte[1]
[10 ]
[0 ]
android.flash.info.available (50000): byte[1]
[FALSE ]
然后 开始报错了????????????????????
== Camera HAL device device@3.3/legacy/0 (v3.3) dumpState: ==
No active camera device session instance
== Vendor tags: ==
Dumping vendor tag descriptors for vendor with id 3854507339
Dumping configured vendor tag descriptors: 38 entries
0x80000000 (privatedata_effective_driver_frame_id) with type 3 (int64) defined in section org.codeaurora.rkcamera3.privatedata
0x80000001 (privatedata_frame_sof_timestamp) with type 3 (int64) defined in section org.codeaurora.rkcamera3.privatedata
0x80000002 (privatedata_stillcap_sync_needed) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000003 (privatedata_stillcap_sync_cmd) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000004 (privatedata_isp_bls) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000005 (privatedata_isp_lsc_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000006 (privatedata_isp_ccm_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000007 (privatedata_isp_awb_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000008 (privatedata_isp_awb_wp) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000009 (privatedata_isp_awb_curv) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000a (privatedata_isp_awb_refgain) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000b (privatedata_isp_goc_normal) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000c (privatedata_isp_goc_night) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000d (privatedata_isp_cproc_preview) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000e (privatedata_isp_cproc_capture) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000000f (privatedata_isp_cproc_video) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000010 (privatedata_isp_dpf_get) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000011 (privatedata_isp_flt_normal) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000012 (privatedata_isp_flt_night) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000013 (privatedata_isp_sensor_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000014 (privatedata_isp_module_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000015 (privatedata_isp_sensor_reg) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000016 (privatedata_isp_sensor_flip) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000017 (privatedata_isp_system_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000018 (privatedata_isp_bls_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000019 (privatedata_isp_lsc_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001a (privatedata_isp_ccm_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001b (privatedata_isp_awb_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001c (privatedata_isp_awb_wp_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001d (privatedata_isp_awb_curv_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001e (privatedata_isp_awb_refgain_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x8000001f (privatedata_isp_goc_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000020 (privatedata_isp_cproc_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000021 (privatedata_isp_dpf_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000022 (privatedata_isp_flt_set) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000023 (privatedata_isp_restart) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000024 (privatedata_isp_protocol_info) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
0x80000025 (privatedata_tuning_flag) with type 0 (byte) defined in section org.codeaurora.rkcamera3.privatedata
Dumping vendor tag descriptors for vendor with id 2592128789
Dumping configured vendor tag descriptors: None set
== Camera error traces (1): ==
----- pid 425 at 2020-09-16 06:48:10 -----
Cmd line: /system/bin/cameraserver
“cameraserver” sysTid=425
#00 pc 000d79b5 /system/lib/libcameraservice.so (android::camera3::CameraTraces::saveTrace()+100)
#01 pc 000bff03 /system/lib/libcameraservice.so (android::Camera3Device::setErrorStateLockedV(char const*, std::__va_list)+178)
#02 pc 000b6319 /system/lib/libcameraservice.so (android::Camera3Device::setErrorStateLocked(char const*, …)+32)
#03 pc 000bb163 /system/lib/libcameraservice.so (android::Camera3Device::configureStreamsLocked(int, android::CameraMetadata const&, bool)+738)
#04 pc 000ba3b9 /system/lib/libcameraservice.so (android::Camera3Device::filterParamsAndConfigureLocked(android::CameraMetadata const&, int)+132)
#05 pc 000bc355 /system/lib/libcameraservice.so (android::Camera3Device::configureStreams(android::CameraMetadata const&, int)+116)
#06 pc 000ac8bf /system/lib/libcameraservice.so (android::CameraDeviceClient::endConfigure(int, android::CameraMetadata const&)+262)
#07 pc 000acb55 /system/lib/libcameraservice.so (non-virtual thunk to android::CameraDeviceClient::endConfigure(int, android::CameraMetadata const&)+4)
#08 pc 00023859 /system/lib/libcamera_client.so (android::hardware::camera2::BnCameraDeviceUser::onTransact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+504)
#09 pc 00036151 /system/lib/libbinder.so (android::BBinder::transact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+72)
#10 pc 0003d995 /system/lib/libbinder.so (android::IPCThreadState::executeCommand(int)+408)
#11 pc 0003d723 /system/lib/libbinder.so (android::IPCThreadState::getAndExecuteCommand()+106)
#12 pc 0003dc4b /system/lib/libbinder.so (android::IPCThreadState::joinThreadPool(bool)+38)
#13 pc 00000b7f /system/bin/cameraserver (main+102)
#14 pc 0008c67d /system/lib/libc.so (__libc_init+48)
#15 pc 00000ad9 /system/bin/cameraserver (_start_main+40)
#16 pc 00000306 anonymous:e91aa000
“HwBinder:425_1” sysTid=492
#00 pc 0005424c /system/lib/libc.so (__ioctl+8)
#01 pc 00021b93 /system/lib/libc.so (ioctl+38)
#02 pc 00016a65 /system/lib/libhwbinder.so (android::hardware::IPCThreadState::talkWithDriver(bool)+192)
#03 pc 0000f3cb /system/lib/libhwbinder.so (android::hardware::IPCThreadState::getAndExecuteCommand()+10)
#04 pc 0000fcf7 /system/lib/libhwbinder.so (android::hardware::IPCThreadState::joinThreadPool(bool)+190)
#05 pc 000160e5 /system/lib/libhwbinder.so (android::hardware::PoolThread::threadLoop()+12)
#06 pc 0000c0bf /system/lib/libutils.so (android::thread::_threadLoop(void*)+170)
#07 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#08 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“HwBinder:425_2” sysTid=493
#00 pc 00019d94 /system/lib/libc.so (syscall+28)
#01 pc 0001d13d /system/lib/libc.so (__futex_wait_ex(void volatile*, bool, int, bool, timespec const*)+88)
#02 pc 00064e99 /system/lib/libc.so (NonPI::MutexLockWithTimeout(pthread_mutex_internal_t*, bool, timespec const*)+156)
#03 pc 0008919b /system/lib/libcameraservice.so (android::Camera2ClientBaseandroid::CameraDeviceClientBase::disconnect()+54)
#04 pc 0007a313 /system/lib/libcameraservice.so (android::CameraService::onDeviceStatusChanged(android::String8 const&, android::hardware::camera::common::V1_0::CameraDeviceStatus)+586)
#05 pc 0008c111 /system/lib/libcameraservice.so (android::CameraProviderManager::removeProvider(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator> const&)+452)
#06 pc 0008d889 /system/lib/libcameraservice.so (_ZTv0_n16_N7android21CameraProviderManager12ProviderInfo11serviceDiedEyRKNS_2wpINS_4hidl4base4V1_05IBaseEEE+12)
#07 pc 0001c371 /system/lib/libhidltransport.so (android::hardware::hidl_binder_death_recipient::binderDied(android::wpandroid::hardware::IBinder const&)+68)
#08 pc 0000dd3b /system/lib/libhwbinder.so (android::hardware::BpHwBinder::reportOneDeath(android::hardware::BpHwBinder::Obituary const&)+78)
#09 pc 0000dcd3 /system/lib/libhwbinder.so (android::hardware::BpHwBinder::sendObituary()+182)
#10 pc 0000f96d /system/lib/libhwbinder.so (android::hardware::IPCThreadState::executeCommand(int)+1060)
#11 pc 0000f43b /system/lib/libhwbinder.so (android::hardware::IPCThreadState::getAndExecuteCommand()+122)
#12 pc 0000fcf7 /system/lib/libhwbinder.so (android::hardware::IPCThreadState::joinThreadPool(bool)+190)
#13 pc 000160e5 /system/lib/libhwbinder.so (android::hardware::PoolThread::threadLoop()+12)
#14 pc 0000c0bf /system/lib/libutils.so (android::thread::_threadLoop(void*)+170)
#15 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#16 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“HwBinder:425_3” sysTid=498
“Binder:425_1” sysTid=575
#02 pc 0003d573 /system/lib/libbinder.so (android::IPCThreadState::talkWithDriver(bool)+206)
#03 pc 0003d6c3 /system/lib/libbinder.so (android::IPCThreadState::getAndExecuteCommand()+10)
#04 pc 0003dc4b /system/lib/libbinder.so (android::IPCThreadState::joinThreadPool(bool)+38)
#05 pc 0005479d /system/lib/libbinder.so (android::PoolThread::threadLoop()+12)
“Binder:425_2” sysTid=688
“C3Dev-0-Status” sysTid=1539
#00 pc 00019d98 /system/lib/libc.so (syscall+32)
#02 pc 00063b27 /system/lib/libc.so (pthread_cond_timedwait+84)
#03 pc 000d0159 /system/lib/libcameraservice.so (android::camera3::StatusTracker::threadLoop()+656)
#04 pc 0000c139 /system/lib/libutils.so (android::thread::_threadLoop(void*)+292)
#05 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#06 pc 0001dfad /system/lib/libc.so (__start_thread+32)
“C3Dev-0-ReqQueu” sysTid=1540
#03 pc 000c45a1 /system/lib/libcameraservice.so (android::Camera3Device::RequestThread::waitIfPaused()+212)
#04 pc 000c425b /system/lib/libcameraservice.so (android::Camera3Device::RequestThread::threadLoop()+54)
#05 pc 0000c139 /system/lib/libutils.so (android::thread::_threadLoop(void*)+292)
#06 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
#07 pc 0001dfad /system/lib/libc.so (__start_thread+32)
太长了
…以上是 dumpsys media.camera 的log … .
遇到过此类问题,麻烦帮忙看看;感谢!!
