AIO3399 HDMI IN功能异常
1.进入界面后,点击HDMI IN apk,apk弹出无响应
2.量硬件信,3.3V 1.8V 1.2V正常,27M晶振正常。下面是开机到点击HDMI IN报错的log.
DDR Version 1.17 20190115
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1833
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66689
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x7a274
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):2bb878d
NOTICE: BL31: Built : 11:57:30, Jan 4 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Apr 11 2019 - 11:52:29)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-04-11#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID] check header error
[HDMI] parse edid base block error-2
no edid message:use default vic config:4
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 1 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 0
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0125a008)
ramdisk @ 0x04bf0000 (0x001ad8d4)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616a02 … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.103 (liangkd@tchip-server) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1947 SMP PREEMPT Thu Apr 11 11:35:03 CST 2019
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef7000 s45504 r8192 d32320 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2019-04-11_11:52:29 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeaf000-0x7eeef000] (0MB) mapped at [ffffffc07eeaf000-ffffffc07eeeefff]
[ 0.000000] Memory: 1988584K/2064384K available (11006K kernel code, 1640K rwdata, 5256K rodata, 832K init, 1073K bss, 59416K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009070000 - 0xffffff8009140000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009070000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092da008 ( 1641 KB)
[ 0.001963] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002928] pid_max: default: 32768 minimum: 301
[ 0.003445] Security Framework initialized
[ 0.003836] SELinux: Initializing.
[ 0.004252] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004882] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006319] Initializing cgroup subsys freezer
[ 0.006746] Initializing cgroup subsys debug
[ 0.008039] sched-energy: Sched-energy-costs installed from DT
[ 0.008588] CPU0: update cpu_capacity 401
[ 0.009043] ASID allocator initialised with 65536 entries
[ 0.025869] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027144] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039264] Detected VIPT I-cache on CPU1
[ 0.039296] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039331] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039374] CPU1: update cpu_capacity 401
[ 0.039378] CPU1: Booted secondary processor [410fd034]
[ 0.049260] Detected VIPT I-cache on CPU2
[ 0.049280] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049312] CPU2: using LPI pending table @0x000000007c020000
[ 0.049340] CPU2: update cpu_capacity 401
[ 0.049343] CPU2: Booted secondary processor [410fd034]
[ 0.059297] Detected VIPT I-cache on CPU3
[ 0.059315] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059348] CPU3: using LPI pending table @0x000000007c060000
[ 0.059374] CPU3: update cpu_capacity 401
[ 0.059378] CPU3: Booted secondary processor [410fd034]
[ 0.069346] Detected PIPT I-cache on CPU4
[ 0.069374] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069413] CPU4: using LPI pending table @0x000000007c0a0000
[ 0.069453] CPU4: update cpu_capacity 1024
[ 0.069456] CPU4: Booted secondary processor [410fd082]
[ 0.079368] Detected PIPT I-cache on CPU5
[ 0.079386] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079422] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079449] CPU5: update cpu_capacity 1024
[ 0.079452] CPU5: Booted secondary processor [410fd082]
[ 0.079537] Brought up 6 CPUs
[ 0.091643] SMP: Total of 6 processors activated.
[ 0.092086] CPU features: detected feature: GIC system register CPU interface
[ 0.092757] CPU: All CPU(s) started at EL2
[ 0.093179] alternatives: patching kernel code
[ 0.095270] devtmpfs: initialized
[ 0.115995] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116971] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.118267] pinctrl core: initialized pinctrl subsystem
[ 0.120361] Failed to find legacy iommu devices
[ 0.121181] NET: Registered protocol family 16
[ 0.121960] schedtune: init normalization constants…
[ 0.122464] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123099] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123746] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124380] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.125014] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.125649] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126283] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126916] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127555] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128189] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128930] schedtune: verify normalization constants…
[ 0.129447] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129988] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130528] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131075] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131615] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132157] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.132697] schedtune: configured to support 5 boost groups
[ 0.141111] cpuidle: using governor ladder
[ 0.151114] cpuidle: using governor menu
[ 0.151508] Registered FIQ tty driver
[ 0.152181] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009144000)
[ 0.152923] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154978] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.175781] console [pstore0] enabled
[ 0.176369] pstore: Registered ramoops as persistent store backend
[ 0.176973] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.179778] fiq debugger fiq mode enabled
[[ 0.180428] console [ttyFIQ0] enabled
[[ 0.181113] bootconsole [uart0] disabled
[ 0.182034] Registered fiq debugger ttyFIQ0
[ 0.212888] Rockchip hdmi driver version 2.0
[ 0.215172] iommu: Adding device ff650000.vpu_service to group 0
[ 0.215274] iommu: Adding device ff660000.rkvdec to group 1
[ 0.215342] iommu: Adding device ff670000.iep to group 2
[ 0.215436] iommu: Adding device ff8f0000.vop to group 3
[ 0.215512] iommu: Adding device ff900000.vop to group 4
[ 0.215620] iommu: Adding device ff910000.isp to group 5
[ 0.215702] iommu: Adding device ff920000.isp to group 6
[ 0.216392] rk_iommu ff670800.iommu: can’t get aclk
[ 0.216412] rk_iommu ff670800.iommu: can’t get hclk
[ 0.217285] SCSI subsystem initialized
[ 0.222158] usbcore: registered new interface driver usbfs
[ 0.222211] usbcore: registered new interface driver hub
[ 0.222289] usbcore: registered new device driver usb
[ 0.222698] media: Linux media interface: v0.10
[ 0.222738] Linux video capture interface: v2.00
[ 0.222867] pps_core: LinuxPPS API ver. 1 registered
[ 0.222880] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.222912] PTP clock support registered
[ 0.226162] Advanced Linux Sound Architecture Driver Initialized.
[ 0.226637] Bluetooth: Core ver 2.21
[ 0.226685] NET: Registered protocol family 31
[ 0.226696] Bluetooth: HCI device and connection manager initialized
[ 0.226712] Bluetooth: HCI socket layer initialized
[ 0.226736] Bluetooth: L2CAP socket layer initialized
[ 0.226769] Bluetooth: SCO socket layer initialized
[ 0.227787] rockchip-cpuinfo cpuinfo: Serial : 63e887619e731ae0
[ 0.228257] clocksource: Switched to clocksource arch_sys_counter
[ 0.272579] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.272823] NET: Registered protocol family 2
[ 0.273277] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.273420] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.273698] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.273779] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.273842] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.274021] NET: Registered protocol family 1
[ 0.274537] Trying to unpack rootfs image as initramfs…
[ 0.363603] Freeing initrd memory: 1716K
[ 0.364118] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.364210] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.366835] audit: initializing netlink subsys (disabled)
[ 0.366897] audit: type=2000 audit(0.363:1): initialized
[ 0.371919] VFS: Disk quotas dquot_6.6.0
[ 0.372044] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.373431] fuse init (API version 7.23)
[ 0.374546]
[ 0.374546] TEE Core Framework initialization (ver 1:0.1)
[ 0.374578] TEE armv7 Driver initialization
[ 0.374980] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.374997] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.375178] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.379173] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.379201] io scheduler noop registered
[ 0.379376] io scheduler cfq registered (default)
[ 0.380636] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 0.381674] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.386766] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.386793] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.386817] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.908306] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.909053] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.911015] iep: failed to find iep power down clock source.
[ 0.912097] IEP Power ON
[ 0.912554] IEP Power OFF
[ 0.912899] IEP Driver loaded succesfully
[ 0.913518] Module initialized.
[ 0.914138] rk-vcodec ff650000.vpu_service: probe device
[ 0.914197] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2da010
[ 0.914373] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.914430] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.914937] rk-vcodec ff650000.vpu_service: init success
[ 0.915523] rk-vcodec ff660000.rkvdec: probe device
[ 0.915572] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2da810
[ 0.915708] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.915762] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.916090] rk-vcodec ff660000.rkvdec: init success
[ 0.917776] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.917796] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.919159] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.919178] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.920906] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.923258] console [ttyS0] disabled
[ 0.923472] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.924323] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.925026] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.930352] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.930686] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.930998] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.931020] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.931112] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.932007] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.932027] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.932040] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 0.933667] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 1.000115] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 1.033773] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.047946] mali ff9a0000.gpu: Failed to get regulator
[ 1.047988] mali ff9a0000.gpu: Power control initialization failed
[ 1.048335] Unable to detect cache hierarchy from DT for CPU 0
[ 1.056260] brd: module loaded
[ 1.061003] loop: module loaded
[ 1.061524] zram: Added device: zram0
[ 1.062210] SCSI Media Changer driver v0.25
[ 1.063550] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.063576] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.064393] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.234734] wk2xxx_serial_init()
[ 1.234752] wk2xxx_request_port
[ 1.234766] ttysWK0 at I/O 0x1 (irq = 103, base_baud = 460800) is a wk2xxx
[ 1.235069] uart_add_one_port success for line i:= 0 with right 0
[ 1.235082] wk2xxx_request_port
[ 1.235094] ttysWK1 at I/O 0x2 (irq = 103, base_baud = 460800) is a wk2xxx
[ 1.235287] uart_add_one_port success for line i:= 1 with right 0
[ 1.235299] wk2xxx_request_port
[ 1.235312] ttysWK2 at I/O 0x3 (irq = 103, base_baud = 460800) is a wk2xxx
[ 1.235500] uart_add_one_port success for line i:= 2 with right 0
[ 1.235512] wk2xxx_request_port
[ 1.235523] ttysWK3 at I/O 0x4 (irq = 103, base_baud = 460800) is a wk2xxx
[ 1.235709] uart_add_one_port success for line i:= 3 with right 0
[ 1.235722] uart_add_one_port = 0x0
[ 1.235751] register spi return v = :0
[ 1.235804] tun: Universal TUN/TAP device driver, 1.6
[ 1.235815] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.236729] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.236828] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.236849] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.236863] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.236891] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.237063] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.242083] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.242209] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.242221] Ring mode enabled
[ 1.242230] DMA HW capability register supported
[ 1.242240] Normal descriptors
[ 1.242251] RX Checksum Offload Engine supported (type 2)
[ 1.242262] Wake-Up On Lan supported
[ 1.242305] Enable RX Mitigation via HW Watchdog Timer
[ 1.317018] libphy: stmmac: probed
[ 1.317044] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.317058] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.317071] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 1.317083] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 1.317095] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 1.317106] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 1.317118] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 1.317129] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 1.317140] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 1.317152] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 1.317163] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 1.317174] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 1.317185] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 1.317196] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 1.317207] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 1.317219] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 1.317230] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 1.317241] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 1.317252] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 1.317264] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 1.317275] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 1.317286] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 1.317298] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 1.317308] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 1.317320] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 1.317330] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 1.317342] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 1.317352] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 1.317363] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 1.317375] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 1.317385] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 1.317396] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 1.318323] PPP generic driver version 2.4.2
[ 1.318501] PPP BSD Compression module registered
[ 1.318517] PPP Deflate Compression module registered
[ 1.318548] PPP MPPE Compression module registered
[ 1.318566] NET: Registered protocol family 24
[ 1.318604] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.318618] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.318687] usbcore: registered new interface driver mt7601u
[ 1.318713] Rockchip WiFi SYS interface (V1.00) …
[ 1.318776] usbcore: registered new interface driver catc
[ 1.318818] usbcore: registered new interface driver kaweth
[ 1.318833] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.318872] usbcore: registered new interface driver pegasus
[ 1.318913] usbcore: registered new interface driver rtl8150
[ 1.318958] usbcore: registered new interface driver r8152
[ 1.318973] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.319028] usbcore: registered new interface driver hso
[ 1.319074] usbcore: registered new interface driver asix
[ 1.319116] usbcore: registered new interface driver ax88179_178a
[ 1.319160] usbcore: registered new interface driver cdc_ether
[ 1.319202] usbcore: registered new interface driver cdc_eem
[ 1.319244] usbcore: registered new interface driver dm9601
[ 1.319293] usbcore: registered new interface driver smsc75xx
[ 1.319342] usbcore: registered new interface driver smsc95xx
[ 1.319386] usbcore: registered new interface driver gl620a
[ 1.319427] usbcore: registered new interface driver net1080
[ 1.319469] usbcore: registered new interface driver plusb
[ 1.319511] usbcore: registered new interface driver rndis_host
[ 1.319553] usbcore: registered new interface driver cdc_subset
[ 1.319595] usbcore: registered new interface driver zaurus
[ 1.319641] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.319705] usbcore: registered new interface driver int51x1
[ 1.319747] usbcore: registered new interface driver kalmia
[ 1.319789] usbcore: registered new interface driver ipheth
[ 1.319833] usbcore: registered new interface driver sierra_net
[ 1.319879] usbcore: registered new interface driver cx82310_eth
[ 1.319930] usbcore: registered new interface driver cdc_ncm
[ 1.319971] usbcore: registered new interface driver qmi_wwan
[ 1.320015] usbcore: registered new interface driver cdc_mbim
[ 1.325868] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 1.331012] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.331802] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.331822] ehci-pci: EHCI PCI platform driver
[ 1.331885] ehci-platform: EHCI generic platform driver
[ 1.335542] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.335571] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.335767] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.344937] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.345072] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.345088] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.345103] usb usb1: Product: EHCI Host Controller
[ 1.345115] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.345127] usb usb1: SerialNumber: fe380000.usb
[ 1.345625] hub 1-0:1.0: USB hub found
[ 1.345658] hub 1-0:1.0: 1 port detected
[ 1.349543] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.349570] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.349723] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.358293] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.358415] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.358431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.358445] usb usb2: Product: EHCI Host Controller
[ 1.358457] usb usb2: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.358469] usb usb2: SerialNumber: fe3c0000.usb
[ 1.358954] hub 2-0:1.0: USB hub found
[ 1.358990] hub 2-0:1.0: 1 port detected
[ 1.359533] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.359569] ohci-platform: OHCI generic platform driver
[ 1.359882] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.359907] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.360045] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.415831] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.415877] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.415895] usb usb3: Product: Generic Platform OHCI controller
[ 1.415911] usb usb3: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.415925] usb usb3: SerialNumber: fe3a0000.usb
[ 1.416565] hub 3-0:1.0: USB hub found
[ 1.416608] hub 3-0:1.0: 1 port detected
[ 1.417376] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.417409] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.417641] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.472455] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.472525] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.472542] usb usb4: Product: Generic Platform OHCI controller
[ 1.472557] usb usb4: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.472570] usb usb4: SerialNumber: fe3e0000.usb
[ 1.473178] hub 4-0:1.0: USB hub found
[ 1.473219] hub 4-0:1.0: 1 port detected
[ 1.474657] usbcore: registered new interface driver cdc_acm
[ 1.474671] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.474757] usbcore: registered new interface driver usblp
[ 1.474821] usbcore: registered new interface driver cdc_wdm
[ 1.474888] usbcore: registered new interface driver uas
[ 1.475051] usbcore: registered new interface driver usb-storage
[ 1.475112] usbcore: registered new interface driver ums-alauda
[ 1.475170] usbcore: registered new interface driver ums-cypress
[ 1.475235] usbcore: registered new interface driver ums-datafab
[ 1.475291] usbcore: registered new interface driver ums_eneub6250
[ 1.475346] usbcore: registered new interface driver ums-freecom
[ 1.475404] usbcore: registered new interface driver ums-isd200
[ 1.475465] usbcore: registered new interface driver ums-jumpshot
[ 1.475522] usbcore: registered new interface driver ums-karma
[ 1.475579] usbcore: registered new interface driver ums-onetouch
[ 1.475637] usbcore: registered new interface driver ums-sddr09
[ 1.475695] usbcore: registered new interface driver ums-sddr55
[ 1.475756] usbcore: registered new interface driver ums-usbat
[ 1.475867] usbcore: registered new interface driver usbserial
[ 1.475918] usbcore: registered new interface driver usbserial_generic
[ 1.475959] usbserial: USB Serial support registered for generic
[ 1.476020] usbcore: registered new interface driver ch341
[ 1.476058] usbserial: USB Serial support registered for ch341-uart
[ 1.476124] usbcore: registered new interface driver cp210x
[ 1.476162] usbserial: USB Serial support registered for cp210x
[ 1.476250] usbcore: registered new interface driver option
[ 1.476288] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.476562] usbcore: registered new interface driver pl2303
[ 1.476600] usbserial: USB Serial support registered for pl2303
[ 1.476677] usbcore: registered new interface driver trancevibrator
[ 1.476695] usb20_otg: version 3.10a 21-DEC-2012
[ 1.476995] usb20_host: version 3.10a 21-DEC-2012
[ 1.477697] usbcore: registered new interface driver xpad
[ 1.477755] usbcore: registered new interface driver usb_acecad
[ 1.477808] usbcore: registered new interface driver aiptek
[ 1.477859] usbcore: registered new interface driver gtco
[ 1.477918] usbcore: registered new interface driver hanwang
[ 1.477968] usbcore: registered new interface driver kbtab
[ 1.477985] ==gsl_ts_init==
[ 1.478018] ret=0
[ 1.478454] .. rk pwm remotectl v1.1 init
[ 1.478687] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.479226] sensor_register_slave:mma8452,id=17
[ 1.479250] sensor_register_slave:lis3dh,id=7
[ 1.479268] sensor_register_slave:mma7660,id=18
[ 1.479285] sensor_register_slave:lsm303d,id=22
[ 1.479302] sensor_register_slave:gs_mc3230,id=23
[ 1.479311] [Gsensor] gsensor_init
[ 1.479328] sensor_register_slave:mpu6880_acc,id=24
[ 1.479344] sensor_register_slave:mpu6500_acc,id=25
[ 1.479361] sensor_register_slave:lsm330_acc,id=26
[ 1.479378] sensor_register_slave:akm8975,id=29
[ 1.479396] sensor_register_slave:akm8963,id=30
[ 1.479413] sensor_register_slave:l3g4200d,id=44
[ 1.479429] sensor_register_slave:l3g20d,id=45
[ 1.479446] sensor_register_slave:ewtsa,id=46
[ 1.479463] sensor_register_slave:lsm330_gyro,id=50
[ 1.479480] sensor_register_slave:cm3217,id=52
[ 1.479497] sensor_register_slave:cm3218,id=53
[ 1.480525] i2c /dev entries driver
[ 1.482334] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.482449] fan53555-reg: supplied by vcc5v0_sys
[ 1.484382] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.484452] fan53555-reg: supplied by vcc5v0_sys
[ 1.486643] rk808 0-001b: Pmic Chip id: 0x0
[ 1.490461] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.490538] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.490657] DCDC_REG1: supplied by vcc3v3_sys
[ 1.491445] DCDC_REG2: supplied by vcc3v3_sys
[ 1.492040] DCDC_REG3: supplied by vcc3v3_sys
[ 1.492348] DCDC_REG4: supplied by vcc3v3_sys
[ 1.492811] LDO_REG1: supplied by vcc3v3_sys
[ 1.493959] LDO_REG2: supplied by vcc3v3_sys
[ 1.495020] LDO_REG3: supplied by vcc3v3_sys
[ 1.496031] LDO_REG4: supplied by vcc3v3_sys
[ 1.497039] LDO_REG5: supplied by vcc3v3_sys
[ 1.498072] LDO_REG6: supplied by vcc3v3_sys
[ 1.499074] LDO_REG7: supplied by vcc3v3_sys
[ 1.500083] LDO_REG8: supplied by vcc3v3_sys
[ 1.501081] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.501394] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.505206] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.505821] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009950000
[ 1.506682] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009952000
[ 1.506809] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.506826] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.506842] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.506857] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.507325] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff8009954000
[ 1.507967] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009956000
[ 1.509226] IR NEC protocol handler initialized
[ 1.509242] IR RC5(x/sz) protocol handler initialized
[ 1.509257] IR RC6 protocol handler initialized
[ 1.509271] IR JVC protocol handler initialized
[ 1.509285] IR Sony protocol handler initialized
[ 1.509300] IR SANYO protocol handler initialized
[ 1.509314] IR Sharp protocol handler initialized
[ 1.509329] IR MCE Keyboard/mouse protocol handler initialized
[ 1.509343] IR XMP protocol handler initialized
[ 1.509647] usbcore: registered new interface driver uvcvideo
[ 1.509658] USB Video Class driver (1.1.1)
[ 1.509677] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 1.515504] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.515683] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.516009] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.516140] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.519501] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.520651] device-mapper: uevent: version 1.0.3
[ 1.521060] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.521283] Bluetooth: HCI UART driver ver 2.3
[ 1.521297] Bluetooth: HCI UART protocol H4 registered
[ 1.521308] Bluetooth: HCI UART protocol LL registered
[ 1.521323] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.521333] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.521344] rtk_btusb: Register usb char device interface for BT driver
[ 1.521662] usbcore: registered new interface driver rtk_btusb
[ 1.522241] cpu cpu0: leakage=26
[ 1.539505] cpu cpu0: temp=42777, pvtm=146639 (146573 + 66)
[ 1.539883] cpu cpu0: pvtm-sel=1
[ 1.540291] cpu cpu4: leakage=45
[ 1.552459] cpu cpu4: temp=43333, pvtm=156477 (156407 + 70)
[ 1.552601] cpu cpu4: pvtm-sel=2
[ 1.558217] sdhci: Secure Digital Host Controller Interface driver
[ 1.558287] sdhci: Copyright(c) Pierre Ossman
[ 1.558307] Synopsys Designware Multimedia Card Interface Driver
[ 1.559530] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.559698] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.559720] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.559790] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.559819] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.559873] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.559886] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.560946] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.561058] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.561078] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.561126] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.561151] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.561281] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.562207] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.564195] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.564209] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.591799] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.594089] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.599104] usbcore: registered new interface driver usbhid
[ 1.599157] usbhid: USB HID core driver
[ 1.599348] inv_mpu_iio: inv_mpu_init:746
[ 1.600570] ashmem: initialized
[ 1.603332] ff100000.saradc supply vref not found, using dummy regulator
[ 1.605542] rknandbase v1.1 2016-11-08
[ 1.606572] usbcore: registered new interface driver snd-usb-audio
[ 1.609132] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.609158] rt5640 1-001c: Can not read property: linein-mute.
[ 1.611813] lkd tc358749x_parse_dts: power(1)
[ 1.611912] lkd tc358749x_parse_dts: int(0)
[ 1.612000] lkd tc358749x_parse_dts: reset(1)
[ 1.623168] tc358749x 1-000f: tc358749x_parse_dts success
[ 1.623377] tc358749x 1-000f: tc358749x_i2c_probe success
[ 1.630398] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.633887] mmc0: MAN_BKOPS_EN bit is not set
[ 1.634109] u32 classifier
[ 1.634129] Actions configured
[ 1.634199] Netfilter messages via NETLINK v0.30.
[ 1.634296] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.634772] ctnetlink v0.93: registering with nfnetlink.
[ 1.635839] xt_time: kernel timezone is -0000
[ 1.636693] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.636949] arp_tables: (C) 2002 David S. Miller
[ 1.637693] Initializing XFRM netlink socket
[ 1.638301] NET: Registered protocol family 10
[ 1.639605] mip6: Mobile IPv6
[ 1.639666] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.641346] sit: IPv6 over IPv4 tunneling driver
[ 1.641894] NET: Registered protocol family 17
[ 1.641951] NET: Registered protocol family 15
[ 1.641992] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.642830] Bridge firewalling registered
[ 1.642850] Ebtables v2.0 registered
[ 1.643065] Bluetooth: RFCOMM TTY layer initialized
[ 1.643096] Bluetooth: RFCOMM socket layer initialized
[ 1.643131] Bluetooth: RFCOMM ver 1.11
[ 1.643159] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.643169] Bluetooth: BNEP filters: protocol multicast
[ 1.643186] Bluetooth: BNEP socket layer initialized
[ 1.643204] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.643219] Bluetooth: HIDP socket layer initialized
[ 1.643269] l2tp_core: L2TP core driver, V2.0
[ 1.643295] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.643317] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.643808] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.643899] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.643911] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.643922] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.644041] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.644052] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.644065] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.644150] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.644732] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.644787] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.644827] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.644867] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.645357] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.645399] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.645443] [BT_RFKILL]: ** disable irq
[ 1.645610] [BT_RFKILL]: bt_default device registered.
[ 1.645894] sensor_register_slave:mpu6880_gyro,id=49
[ 1.646879] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.647567] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 1.647661] Registered cp15_barrier emulation handler
[ 1.647777] Registered setend emulation handler
[ 1.648966] registered taskstats version 1
[ 1.650451] rockchip ion idev is NULL
[ 1.650472] rga2 ff680000.rga: rga ion client create success!
[ 1.650808] rga: Driver loaded successfully ver:3.02
[ 1.651452] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 1.652414] mali ff9a0000.gpu: leakage=37
[ 1.655278] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 1.655756] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 1.656246] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.656262] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.656277] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.656290] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.656302] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.656313] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.656325] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 1.656337] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 1.656348] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 1.656361] system: 0x016800000 – 0x076800000 (1536 MB)
[ 1.656372] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 1.656384] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 1.656396] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 1.656444] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 1.664971] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.665160] mali ff9a0000.gpu: temp=43888, pvtm=123992 (123968 + 24)
[ 1.666143] mali ff9a0000.gpu: pvtm-sel=1
[ 1.667134] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.668019] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.668770] mali ff9a0000.gpu: Probed as mali0
[ 1.674628] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.674688] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 1.675269] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.675368] xhci-hcd xhci-hcd.9.auto: irq 234, io mem 0xfe800000
[ 1.675629] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.675664] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.675694] usb usb5: Product: xHCI Host Controller
[ 1.675718] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.675742] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 1.676599] hub 5-0:1.0: USB hub found
[ 1.676666] hub 5-0:1.0: 1 port detected
[ 1.677161] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.677205] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[ 1.677332] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.677517] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.677550] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.677577] usb usb6: Product: xHCI Host Controller
[ 1.677600] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.677623] usb usb6: SerialNumber: xhci-hcd.9.auto
[ 1.678462] hub 6-0:1.0: USB hub found
[ 1.678532] hub 6-0:1.0: 1 port detected
[ 1.681178] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 1.681225] usb usb6: USB disconnect, device number 1
[ 1.710181] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[ 1.710269] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[ 1.710506] xhci-hcd xhci-hcd.9.auto: USB bus 6 deregistered
[ 1.710543] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 1.710584] usb usb5: USB disconnect, device number 1
[ 1.711292] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[ 1.716114] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.716162] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 1.716505] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.716562] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe900000
[ 1.716706] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.716718] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.716728] usb usb5: Product: xHCI Host Controller
[ 1.716736] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.716745] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 1.717261] hub 5-0:1.0: USB hub found
[ 1.717292] hub 5-0:1.0: 1 port detected
[ 1.717553] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.717569] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[ 1.717626] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.717711] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.717722] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.717731] usb usb6: Product: xHCI Host Controller
[ 1.717740] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.717749] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 1.718215] hub 6-0:1.0: USB hub found
[ 1.718242] hub 6-0:1.0: 1 port detected
[ 1.719884] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.720072] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.720089] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.720119] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.720145] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.720191] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.720200] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.720515] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.735019] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.748566] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.749780] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.749944] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.749972] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.750007] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.750048] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.750146] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.750511] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 1.750646] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.750866] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.761736] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.776238] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.776909] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.776950] rt5640 1-001c: Can not read property: linein-mute.
[ 1.779967] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 1.782393] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.782432] rt5640 1-001c: Can not read property: linein-mute.
[ 1.784359] otg_wakelock_init: No USB transceiver found
[ 1.785321] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[ 1.787767] It doesn’t contain Rogue gpu
[ 1.792556] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.792647] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.792675] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 1.793975] hub 2-1:1.0: USB hub found
[ 1.794053] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.794166] hub 2-1:1.0: 7 ports detected
[ 1.796981] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.797543] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.797571] rt5640 1-001c: Can not read property: linein-mute.
[ 1.798712] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.801719] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.818025] ret 1024
[ 1.818601] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-Firefly-RK3399_Android7.1.1_170516_internal-2655-g05181af’, rk_ko_ver is ‘5’, built at ‘11:32:17’, on ‘Apr 11 2019’.
[ 1.819164] Mali: Mali device driver loaded
[ 1.819733] input: rk29-keypad as /devices/platform/rockchip-key/input/input1
[ 1.820571] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.820583] rt5640 1-001c: Can not read property: linein-mute.
[ 1.821041] ALSA device list:
[ 1.821052] #0: rk-hdmi-dp-sound
[ 1.821059] #1: ROCKCHIP,SPDIF
[ 1.821702] Freeing unused kernel memory: 832K
[ 1.824380] init: init first stage started!
[ 1.825997] init: init second stage started!
[ 1.829055] init: Setting ro.rk.soc=rk3399
[ 1.829214] init: OK,EMMC DRIVERS INIT OK
[ 1.829246] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 1.829327] init: property_set(“ro.hardware”, “rk30board”) failed
[ 1.829399] init: Running restorecon…
[ 1.829554] init: waitpid failed: No child processes
[ 1.830043] init: (Loading properties from /default.prop took 0.00s.)
[ 1.832271] init: /init.rc: 588: invalid keyword ‘echo’
[ 1.832870] init: (Parsing /init.environ.rc took 0.00s.)
[ 1.833505] init: (Parsing /init.usb.rc took 0.00s.)
[ 1.834908] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 1.836110] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 1.836237] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 1.836351] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.836613] init: (Parsing /init.logs.rc took 0.00s.)
[ 1.836728] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 1.836855] init: (Parsing /init.coredump.rc took 0.00s.)
[ 1.836930] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 1.837012] init: (Parsing /init.kernel.rc took 0.00s.)
[ 1.837166] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 1.837191] init: (Parsing /init.debug.rc took 0.00s.)
[ 1.837214] init: (Parsing init.rockchip.rc took 0.00s.)
[ 1.837934] init: (Parsing init.connectivity.rc took 0.00s.)
[ 1.838078] init: (Parsing init.box.samba.rc took 0.00s.)
[ 1.838231] init: (Parsing init.rk3399.rc took 0.00s.)
[ 1.838436] init: init.box.rc: 25: invalid keyword ‘ioprio’
[ 1.838471] init: (Parsing init.box.rc took 0.00s.)
[ 1.838523] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.838565] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.838590] init: (Parsing /init.rk30board.rc took 0.01s.)
[ 1.839650] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 1.839794] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 1.839818] init: (Parsing /init.rc took 0.01s.)
[ 1.840280] init: Starting service ‘ueventd’…
[ 1.842202] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 1.842266] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 1.844958] ueventd: ueventd started!
[ 1.846523] ueventd: invalid gid ‘trace’
[ 1.856523] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.863922] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 110
[ 1.865932] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.865979] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.893343] init: Waiting for /dev/.coldboot_done…
[ 1.959385] ueventd: Coldboot took 0.11s.
[ 1.964543] init: Waiting for /dev/.coldboot_done took 0.07s.
[ 1.964688] init: /dev/hw_random not found
[ 1.965353] keychord: using input dev ff420030.pwm for fevent
[ 1.965363] keychord: using input dev rk29-keypad for fevent
[ 1.970064] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 1.976739] Registered swp emulation handler
[ 1.976959] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 1.977474] init: /dev/hw_random not found
[ 1.978388] fs_mgr: Warning: unknown flag resize
[ 1.981769] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 1.981822] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 1.982555] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 1.983030] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 1.989316] random: e2fsck: uninitialized urandom read (40 bytes read, 32 bits of entropy available)
[ 2.035082] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.035082]
[ 2.035652] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 2.035652]
[ 2.036498] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 21/8192 files, 1589/32768 blocks
[ 2.036498]
[ 2.040956] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.040998] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 2.042114] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.044010] EXT4-fs (mmcblk0p11): recovery complete
[ 2.044026] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.044058] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 2.059402] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 2.059439] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 2.060336] random: e2fsck: uninitialized urandom read (40 bytes read, 34 bits of entropy available)
[ 2.075065] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.075065]
[ 2.075100] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.075100]
[ 2.077605] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.077646] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.077696] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 2.078927] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.078927]
[ 2.078955] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.078955]
[ 2.132476] F2FS-fs (mmcblk0p13): recover_inode: ino = 89f, name = .temp.whAbU5
[ 2.135068] F2FS-fs (mmcblk0p13): recover_dentry: ino = 89f, name = .temp.whAbU5, dir = 2c, err = 0
[ 2.135121] F2FS-fs (mmcblk0p13): recover_data: ino = 89f (i_size: recover) recovered = 0, err = 0
[ 2.135136] F2FS-fs (mmcblk0p13): recover_inode: ino = 8a9, name = journal35001991.tmp
[ 2.135516] F2FS-fs (mmcblk0p13): recover_dentry: ino = 8a9, name = journal35001991.tmp, dir = 3e8, err = 0
[ 2.135539] F2FS-fs (mmcblk0p13): recover_data: ino = 8a9 (i_size: recover) recovered = 0, err = 0
[ 2.135548] F2FS-fs (mmcblk0p13): recover_inode: ino = 8a9, name = journal35001991.tmp
[ 2.135561] F2FS-fs (mmcblk0p13): recover_data: ino = 8a9 (i_size: recover) recovered = 0, err = 0
[ 2.135569] F2FS-fs (mmcblk0p13): recover_inode: ino = 8a9, name = journal35001991.tmp
[ 2.135582] F2FS-fs (mmcblk0p13): recover_data: ino = 8a9 (i_size: recover) recovered = 0, err = 0
[ 2.138074] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[ 2.140894] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 2.141126] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 2.141314] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 2.141565] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 2.141838] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 2.142021] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 2.142201] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 2.142399] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 2.142668] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 2.142855] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 2.143066] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 2.143256] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 2.143442] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 2.143631] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 2.143980] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 2.144186] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 2.144375] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 2.144563] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 2.144749] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 2.144972] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 2.145179] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 2.145377] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 2.145569] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 2.145753] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 2.145942] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 2.146140] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 2.146371] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 2.146562] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 2.146768] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 2.146968] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 2.147208] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 2.148144] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 2.148643] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 2.148899] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 2.149067] init: (Loading properties from /system/build.prop took 0.00s.)
[ 2.149120] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 2.149151] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 2.149450] fs_mgr: Warning: unknown flag resize
[ 2.149668] init: /recovery not specified in fstab
[ 2.149906] init: Starting service ‘healthd’…
[ 2.150568] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 2.151063] init: Starting service ‘earlylogs’…
[ 2.151789] init: Starting service ‘zygote’…
[ 2.151922] binder: 225:225 transaction failed 29189/-22, size 0-0 line 2951
[ 2.152281] init: Starting service ‘zygote_secondary’…
[ 2.152880] init: Starting service ‘lmkd’…
[ 2.153517] init: Starting service ‘servicemanager’…
[ 2.154031] init: Starting service ‘surfaceflinger’…
[ 2.154486] init: Starting service ‘vold’…
[ 2.163073] vendor storage:20160801 ret = 0
[ 2.164932] random: surfaceflinger: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.165440] random: elogs.sh: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.165667] random: app_process64: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.167971] random: lmkd: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.169280] random: servicemanager: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.170468] random: app_process32: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 2.172426] random: vold: uninitialized urandom read (40 bytes read, 45 bits of entropy available)
[ 2.172973] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: Service ‘earlylogs’ (pid 226) exited with status 0
[ 2.173217] init: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 2.176693] zram0: detected capacity change from 0 to 533413888
[ 2.181442] random: mkswap: uninitialized urandom read (40 bytes read, 45 bits of entropy available)
[ 2.212127] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.215842] init: Starting service ‘debuggerd’…
[ 2.216400] init: Starting service ‘debuggerd64’…
[ 2.219906] init: Not bootcharting.
[ 2.311908] fs_mgr: Warning: unknown flag resize
[ 2.422653] init: Failed to reload policy
[ 2.422774] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 2.436419] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 247) exited with status 0
[ 2.451945] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 2.453877] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 2.456842] init: (Loading properties from /data/local.prop took 0.00s.)
[ 2.457914] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 2.471479] init: Starting service ‘logd’…
[ 2.472366] init: Starting service ‘logd-reinit’…
[ 2.473398] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 2.475820] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 2.477602] init: Starting service ‘fsud’…
[ 2.478993] init: Starting service ‘vm_daemon’…
[ 2.480251] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.480276] init: write: cannot expand ‘${ro.serialno}’
[ 2.481784] file system registered
[ 2.482330] using random self ethernet address
[ 2.482342] using random host ethernet address
[ 2.482389] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 2.501850] init: Starting service ‘console’…
[ 2.502552] init: Starting service ‘adbd’…
[ 2.504296] init: Starting service ‘ap_log_srv’…
[ 2.505097] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 2.505185] init: Starting service ‘ril-daemon’…
[ 2.505648] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 2.505709] init: Starting service ‘drmservice’…
[ 2.506038] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 2.506082] init: Starting service ‘up_eth0’…
[ 2.506572] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 2.506700] init: Starting service ‘akmd’…
[ 2.507385] init: Starting service ‘audioserver’…
[ 2.507869] init: Starting service ‘cameraserver’…
[ 2.510406] init: couldn’t write 274 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 2.511018] init: Starting service ‘drm’…
[ 2.511733] init: Starting service ‘installd’…
[ 2.512244] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 2a:1c:dc:ef:79:88
[ 2.512262] eth0: device MAC address 2a:1c:dc:ef:79:88
[ 2.512970] rt5640 1-001c: Can not read propertyrk3399_firefly_aio_box:/ $ hp-con-gpio
[ 2.512978] rt5640 1-001c: Can not read property: linein-mute.
[ 2.513224] init: Starting service ‘keystore’…
[ 2.513949] logd.auditd: start
[ 2.514358] logd.klogd: 2512421186
[ 2.515146] init: Starting service ‘mediacodec’…
[ 2.515895] init: Starting service ‘mediadrm’…
[ 2.516557] init: Starting service ‘mediaextractor’…
[ 2.517239] init: Starting service ‘media’…
[ 2.517862] init: Starting service ‘netd’…
[ 2.518844] init: Starting service ‘crashlogd’…
[ 2.519573] init: Starting service ‘log-watch’…
[ 2.520227] init: Starting service ‘gatekeeperd’…
[ 2.520861] init: Starting service ‘perfprofd’…
[ 2.522193] init: Service ‘logd-reinit’ (pid 262) exited with status 145
[ 2.524057] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 2.565347] init: Service ‘up_eth0’ (pid 271) exited with status 0
[ 2.565460] init: Service ‘akmd’ (pid 272) exited with status 254
[ 2.566733] ret = ffffffffffffffff
[ 2.568049] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 2.568070] init: setprop: cannot expand ‘${sys.serialno}’
[ 2.581019] init: Service ‘drmservice’ (pid 270) exited with status 0
[ 2.716198] read descriptors
[ 2.716490] read strings
[ 2.729890] init: Starting service ‘apk_logfs’…
[ 2.733525] init: Service ‘ap_log_srv’ (pid 268) exited with status 0
[ 2.969720] init: Starting service ‘bootanim’…
[ 3.049112] Freeing drm_logo memory: 488K
[ 3.087794] init: Untracked pid 354 exited with status 0
[ 3.145186] init: Untracked pid 367 exited with status 0
[ 3.153219] healthd: BatteryCurrentNowPath not found
[ 3.153244] healthd: BatteryCycleCountPath not found
[ 3.588068] E:camsys_extdev_register(258): Request RK30_PIN2_PD4(92) failed
[ 3.601955] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.602846] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.620705] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 3.621865] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.621880] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.621891] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.621899] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.633137] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 3.634867] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 3.648531] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 3.648549] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.648557] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.648567] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.648575] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.662123] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.663001] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.697530] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.698478] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.710865] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 3.711827] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.711842] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.711855] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.711863] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.724125] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 3.725070] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 3.737010] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 3.737086] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.737095] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.737108] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.737121] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.748907] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.749784] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.781616] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.782523] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.796759] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 3.796794] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.796804] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.796813] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.796821] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.810818] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 3.811677] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 3.823302] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 3.823345] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.823355] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.823365] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.823373] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.834701] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.835588] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.911746] random: nonblocking pool is initialized
[ 4.213903] init: Untracked pid 370 exited with status 1
[ 4.217800] init: Untracked pid 358 exited with status 1
[ 4.716036] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 6.922765] acc_open
[ 6.922797] acc_release
[ 6.968764] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 6.970838] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 6.973118] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 7.224424] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 7.987953] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 7.988832] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 8.000225] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 8.000250] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 8.000262] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 8.000275] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 8.000284] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 8.011705] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 8.011950] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 8.022561] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 8.022585] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 8.022594] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 8.022606] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 8.022613] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 8.033967] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 8.034867] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 8.068495] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 8.069379] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 8.079917] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 8.079940] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 8.079951] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 8.079963] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 8.079971] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 8.091433] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 8.092347] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 8.102796] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 8.102821] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 8.102831] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 8.102841] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 8.102849] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 8.114384] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 8.114566] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 8.143706] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 8.144575] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 8.155107] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 8.155140] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 8.155153] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 8.155165] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 8.155175] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 8.166668] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 8.167544] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 8.177863] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 8.177884] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 8.177895] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 8.177908] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 8.177916] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 8.188953] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 8.189751] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 8.292771] FastMixer[373]: unhandled level 1 translation fault (11) at 0x000000cc, esr 0x92000005
[ 8.292794] pgd = ffffffc0764ae000
[ 8.292799] [000000cc] *pgd=0000000000000000, *pud=0000000000000000
[ 8.292809]
[ 8.292817] CPU: 5 PID: 373 Comm: FastMixer Not tainted 4.4.103 #1947
[ 8.292823] Hardware name: AIO Board BOX (Android) (DT)
[ 8.292830] task: ffffffc07bf82700 task.stack: ffffffc0703cc000
[ 8.292838] PC is at 0xf1a08c02
[ 8.292842] LR is at 0xf193c265
[ 8.292848] pc : [<00000000f1a08c02>] lr : [<00000000f193c265>] pstate: 00070030
[ 8.292854] sp : 00000000f077f4f8
[ 8.292858] x12: 00000000f1960db0
[ 8.292865] x11: 00000000f194ff0a x10: 0000000000000000
[ 8.292875] x9 : 00000000f194fff5 x8 : 00000000f0dd2200
[ 8.292884] x7 : 00000000f077f738 x6 : 00000000f077f510
[ 8.292894] x5 : 00000000f0dd2268 x4 : 0000000000000000
[ 8.292903] x3 : 0000000000000080 x2 : 00000000f181a33c
[ 8.292912] x1 : 0000000012dfc0f1 x0 : 00000000f1a0e008
[ 8.292921]
[ 8.296557] binder: release 273:378 transaction 9913 in, still active
[ 8.296574] binder: send failed reply for transaction 9913 to 619:689
[ 8.296595] binder: release 273:691 transaction 9919 in, still active
[ 8.296602] binder: send failed reply for transaction 9919 to 619:619
[ 8.297127] init: Service ‘audioserver’ (pid 273) killed by signal 11
[ 8.297168] init: Service ‘audioserver’ (pid 273) killing any children in process group
[ 8.297561] init: Starting service ‘audioserver’…
[ 8.578096] init: Untracked pid 1063 exited with status 0
[ 8.604566] init: Untracked pid 1071 exited with status 0
[ 8.730759] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 8.730843] init: Starting service ‘mode_switch’…
[ 8.731784] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 8.769207] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 1102) exited with status 0
[ 8.771377] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 8.791630] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 8.791694] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 7
[ 8.795245] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 1111) exited with status 0
[ 8.796086] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 8.796356] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 8.796403] xhci-hcd xhci-hcd.9.auto: irq 234, io mem 0xfe800000
[ 8.796561] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.796572] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.796580] usb usb7: Product: xHCI Host Controller
[ 8.796588] usb usb7: Manufacturer: Linux 4.4.103 xhci-hcd
[ 8.796596] usb usb7: SerialNumber: xhci-hcd.9.auto
[ 8.797346] hub 7-0:1.0: USB hub found
[ 8.797398] hub 7-0:1.0: 1 port detected
[ 8.797667] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 8.797685] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 8
[ 8.798492] rt5640 1-001c: Can not read property hp-con-gpio
[ 8.798503] rt5640 1-001c: Can not read property: linein-mute.
[ 8.798742] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 8.798857] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.798868] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.798877] usb usb8: Product: xHCI Host Controller
[ 8.798885] usb usb8: Manufacturer: Linux 4.4.103 xhci-hcd
[ 8.798892] usb usb8: SerialNumber: xhci-hcd.9.auto
[ 8.801937] hub 8-0:1.0: USB hub found
[ 8.802016] hub 8-0:1.0: 1 port detected
[ 8.802866] rt5640 1-001c: Can not read property hp-con-gpio
[ 8.802879] rt5640 1-001c: Can not read property: linein-mute.
[ 8.803236] rockchip-dwc3 usb@fe800000: USB HOST connected
[ 8.807531] rt5640 1-001c: Can not read property hp-con-gpio
[ 8.807543] rt5640 1-001c: Can not read property: linein-mute.
[ 8.810800] init: Service ‘mode_switch’ (pid 1100) exited with status 0
[ 8.827280] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1113) exited with status 0
[ 8.828130] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 8.848649] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1114) exited with status 0
[ 9.064953] FastMixer[1076]: unhandled level 1 translation fault (11) at 0x000000cc, esr 0x92000005
[ 9.064985] pgd = ffffffc049356000
[ 9.064991] [000000cc] *pgd=0000000000000000, *pud=0000000000000000
[ 9.065001]
[ 9.065009] CPU: 4 PID: 1076 Comm: FastMixer Not tainted 4.4.103 #1947
[ 9.065016] Hardware name: AIO Board BOX (Android) (DT)
[ 9.065022] task: ffffffc05205a700 task.stack: ffffffc047a50000
[ 9.065029] PC is at 0xf6950c02
[ 9.065034] LR is at 0xf6864265
[ 9.065039] pc : [<00000000f6950c02>] lr : [<00000000f6864265>] pstate: 00070030
[ 9.065045] sp : 00000000f56ff4f8
[ 9.065051] x12: 00000000f6888db0
[ 9.065057] x11: 00000000f6877f0a x10: 0000000000000000
[ 9.065067] x9 : 00000000f6877ff5 x8 : 00000000f5d52200
[ 9.065076] x7 : 00000000f56ff738 x6 : 00000000f56ff510
[ 9.065085] x5 : 00000000f5d52268 x4 : 0000000000000000
[ 9.065095] x3 : 0000000000000080 x2 : 00000000f622e33c
[ 9.065104] x1 : 0000000070ca981f x0 : 00000000f6956008
[ 9.065113]
[ 9.067338] binder: release 1041:1081 transaction 12011 in, still active
[ 9.067356] binder: send failed reply for transaction 12011 to 619:689
[ 9.067879] init: Service ‘audioserver’ (pid 1041) killed by signal 11
[ 9.067916] init: Service ‘audioserver’ (pid 1041) killing any children in process group
[ 9.108388] usb 7-1: new low-speed USB device number 2 using xhci-hcd
[ 9.235043] usb 7-1: New USB device found, idVendor=093a, idProduct=2510
[ 9.235079] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.235097] usb 7-1: Product: USB Optical Mouse
[ 9.235106] usb 7-1: Manufacturer: PixArt
[ 9.237705] usb 7-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 9.251793] input: PixArt USB Optical Mouse as /devices/platform/usb@fe800000/fe800000.dwc3/xhci-hcd.9.auto/usb7/7-1/7-1:1.0/0003:093A:2510.0001/input/input2
[ 9.252842] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.9.auto-1/input0
[ 9.254868] rt5640 1-001c: Can not read property hp-con-gpio
[ 9.254894] rt5640 1-001c: Can not read property: linein-mute.
[ 10.547033] init: Service ‘bootanim’ is being killed…
[ 10.656899] init: Service ‘bootanim’ (pid 344) killed by signal 9
[ 13.660620] init: Starting service ‘audioserver’…
[ 13.992728] init: Untracked pid 1371 exited with status 0
[ 14.037617] init: Untracked pid 1379 exited with status 0
[ 14.211786] init: Untracked pid 1419 exited with status 0
[ 14.250961] init: Untracked pid 1427 exited with status 0
[ 14.503537] FastMixer[1384]: unhandled level 1 translation fault (11) at 0x000000cc, esr 0x92000005
[ 14.503567] pgd = ffffffc04b8fb000
[ 14.503572] [000000cc] *pgd=0000000000000000, *pud=0000000000000000
[ 14.503582]
[ 14.503589] CPU: 4 PID: 1384 Comm: FastMixer Not tainted 4.4.103 #1947
[ 14.503596] Hardware name: AIO Board BOX (Android) (DT)
[ 14.503603] task: ffffffc04ea63400 task.stack: ffffffc04ea58000
[ 14.503610] PC is at 0xeb2e3c02
[ 14.503615] LR is at 0xeb217265
[ 14.503620] pc : [<00000000eb2e3c02>] lr : [<00000000eb217265>] pstate: 00070030
[ 14.503626] sp : 00000000ea07f4f8
[ 14.503631] x12: 00000000eb23bdb0
[ 14.503638] x11: 00000000eb22af0a x10: 0000000000000000
[ 14.503647] x9 : 00000000eb22aff5 x8 : 00000000ea6d2200
[ 14.503656] x7 : 00000000ea07f738 x6 : 00000000ea07f510
[ 14.503665] x5 : 00000000ea6d2268 x4 : 0000000000000000
[ 14.503675] x3 : 0000000000000080 x2 : 00000000eaa8b33c
[ 14.503684] x1 : 0000000013974db7 x0 : 00000000eb2e9008
[ 14.503693]
[ 14.507962] init: Service ‘audioserver’ (pid 1362) killed by signal 11
[ 14.508000] init: Service ‘audioserver’ (pid 1362) killing any children in process group
[ 15.295657] init: Untracked pid 1066 exited with status 0
[ 15.297983] init: Untracked pid 1074 exited with status 0
[ 15.328046] init: Untracked pid 1382 exited with status 0
[ 15.328735] init: Untracked pid 1430 exited with status 0
[ 15.344157] init: Untracked pid 1422 exited with status 0
[ 15.353755] init: Untracked pid 1374 exited with status 0
[ 18.596667] init: Starting service ‘audioserver’…
[ 18.958613] init: Untracked pid 1571 exited with status 0
[ 19.026049] init: Untracked pid 1579 exited with status 0
[ 19.375260] FastMixer[1584]: unhandled level 1 translation fault (11) at 0x000000cc, esr 0x92000005
[ 19.375295] pgd = ffffffc03cbb8000
[ 19.375302] [000000cc] *pgd=0000000000000000, *pud=0000000000000000
[ 19.375314]
[ 19.375324] CPU: 3 PID: 1584 Comm: FastMixer Not tainted 4.4.103 #1947
[ 19.375330] Hardware name: AIO Board BOX (Android) (DT)
[ 19.375337] task: ffffffc067b40d00 task.stack: ffffffc04a814000
[ 19.375346] PC is at 0xe8ce9c02
[ 19.375352] LR is at 0xe8c04265
[ 19.375358] pc : [<00000000e8ce9c02>] lr : [<00000000e8c04265>] pstate: 00070030
[ 19.375366] sp : 00000000e7a7f4f8
[ 19.375371] x12: 00000000e8c28db0
[ 19.375378] x11: 00000000e8c17f0a x10: 0000000000000000
[ 19.375388] x9 : 00000000e8c17ff5 x8 : 00000000e80d2200
[ 19.375399] x7 : 00000000e7a7f738 x6 : 00000000e7a7f510
[ 19.375409] x5 : 00000000e80d2268 x4 : 0000000000000000
[ 19.375419] x3 : 0000000000000080 x2 : 00000000e882433c
[ 19.375434] x1 : 0000000027a61f08 x0 : 00000000e8cef008
[ 19.375444]
[ 19.382184] binder: release 1562:1562 transaction 23307 in, still active
[ 19.382202] binder: send failed reply for transaction 23307 to 619:689
[ 19.382227] binder: release 1562:1590 transaction 23551 in, still active
[ 19.382235] binder: send failed reply for transaction 23551 to 295:793
[ 19.382493] init: Service ‘audioserver’ (pid 1562) killed by signal 11
[ 19.382525] init: Service ‘audioserver’ (pid 1562) killing any children in process group
[ 19.382790] binder: 619:689 transaction failed 29189/-22, size 80-0 line 2951
[ 19.514183] init: Untracked pid 1574 exited with status 0
[ 19.520233] init: Untracked pid 1582 exited with status 0
[ 20.702640] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 20.703544] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 20.714346] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 20.714402] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 20.714414] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 20.714426] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 20.714434] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 20.726430] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 20.727282] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 20.738066] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 20.738096] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 20.738109] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 20.738121] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 20.738129] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 20.753188] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 20.753995] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 20.790372] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 20.791132] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 20.801821] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 20.801861] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 20.801873] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 20.801885] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 20.801893] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 20.815985] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 20.816854] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 20.827590] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 20.827653] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 20.827665] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 20.827678] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 20.827687] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 20.839748] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 20.840794] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 20.883243] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 20.884072] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 20.894494] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 20.894557] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 20.894569] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 20.894581] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 20.894590] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 20.906185] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 20.907897] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 20.918547] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 20.918591] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 20.918603] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 20.918615] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 20.918623] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 20.930912] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 20.932002] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 23.864318] init: Starting service ‘audioserver’…
[ 24.129731] init: Untracked pid 1650 exited with status 0
[ 24.189419] init: Untracked pid 1658 exited with status 0
[ 24.341633] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 24.342498] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 24.353052] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 24.353074] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 24.353085] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 24.353098] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 24.353105] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 24.363911] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 24.364723] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 24.375750] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 24.375779] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 24.375789] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 24.375800] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 24.375808] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 24.386910] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 24.387726] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 24.428462] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 24.429328] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 24.443817] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 24.443851] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 24.443869] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 24.443886] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 24.443899] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 24.455089] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 24.455892] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 24.467443] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 24.467476] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 24.467494] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 24.467514] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 24.467528] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 24.479012] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 24.479773] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 24.520395] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 24.521238] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 24.532796] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 24.532830] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 24.532847] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 24.532863] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 24.532876] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 24.544395] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 24.545432] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 24.556764] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[ 24.556800] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 24.556818] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 24.556835] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 24.556848] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 24.568409] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 24.569410] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 24.592934] init: Untracked pid 1653 exited with status 0
[ 24.674969] init: Untracked pid 1661 exited with status 0
使用行业版本的最新固件试试,不行换其他HDMI输入源,如果还不行联系售后
log能看到358749 I2C通吗?
log能看出来I2C通了吗?
nero2019 发表于 2020-9-21 19:18
log能看出来I2C通了吗?
这版本的固件太旧了,建议用最新rk3399 industry7.1 版本的固件
