/usr/bin/install -c -m 644 ../../gcc/ubsan.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/ubsan.h
/usr/bin/install -c -m 644 ../../gcc/valtrack.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/valtrack.h
/usr/bin/install -c -m 644 ../../gcc/value-prof.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/value-prof.h
/usr/bin/install -c -m 644 ../../gcc/varasm.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/varasm.h
/usr/bin/install -c -m 644 ../../gcc/vec.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/vec.h
/usr/bin/install -c -m 644 ../../gcc/version.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/version.h
/usr/bin/install -c -m 644 ../../gcc/vmsdbg.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/vmsdbg.h
/usr/bin/install -c -m 644 ../../gcc/vtable-verify.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/vtable-verify.h
/usr/bin/install -c -m 644 ../../gcc/wide-int.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/wide-int.h
/usr/bin/install -c -m 644 ../../gcc/wide-int-print.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/wide-int-print.h
/usr/bin/install -c -m 644 ../../gcc/xcoff.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/xcoff.h
/usr/bin/install -c -m 644 ../../gcc/xcoffout.h /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/xcoffout.h
/usr/bin/install -c -m 644 b-header-vars /home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/lib/gcc/aarch64-buildroot-linux-gnu/6.5.0/plugin/include/b-header-vars
make[4]: write error
make[3]: *** [install-gcc] Error 1
make[2]: *** [install] Error 2
make[1]: *** [/home/cronggui/work/linux/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/host-gcc-final-6.5.0/.stamp_host_installed] Error 2
make: *** [_all] Error 2
you take 0:11.70 to build builroot
