libc : Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x6 in tid 475 (HwBinder:260_2), pid 260 (provider@2.4-se)
09-24 00:39:20.756 1487 1487 W CAM_IndicatorIconCtrlr: Trying to sync a pano indicator that is not initialized.
09-24 00:39:20.762 507 631 E LightsService: Light requested not available on this device. 0
09-24 00:39:20.779 507 631 E LightsService: Light requested not available on this device. 0
09-24 00:39:20.788 1571 1571 I crash_dump32: obtaining output fd from tombstoned, type: kDebuggerdTombstone
09-24 00:39:20.789 442 442 I /system/bin/tombstoned: received crash request for pid 475
09-24 00:39:20.790 1571 1571 I crash_dump32: performing dump of process 260 (target tid = 475)
09-24 00:39:20.793 1571 1571 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
09-24 00:39:20.794 1571 1571 F DEBUG : Build fingerprint: ‘rockchip/rk3399pro_firefly_aioc/rk3399pro:9/PQ3B.190705.003/root09231613:userdebug/test-keys’
09-24 00:39:20.794 1571 1571 F DEBUG : Revision: ‘0’
09-24 00:39:20.794 1571 1571 F DEBUG : ABI: ‘arm’
09-24 00:39:20.794 1571 1571 F DEBUG : pid: 260, tid: 475, name: HwBinder:260_2 >>> /vendor/bin/hw/android.hardware.camera.provider@2.4-service <<<
09-24 00:39:20.794 1571 1571 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x6
09-24 00:39:20.794 1571 1571 F DEBUG : Cause: null pointer dereference
09-24 00:39:20.794 1571 1571 F DEBUG : r0 00000006 r1 00000006 r2 0000001c r3 00000002
09-24 00:39:20.794 1571 1571 F DEBUG : r4 00000002 r5 e66fe6f4 r6 e6b7b505 r7 00000000
09-24 00:39:20.794 1571 1571 F DEBUG : r8 0ccccccc r9 e66fe757 r10 8000002f r11 0000001c
09-24 00:39:20.794 1571 1571 F DEBUG : ip 00000002 sp e66fe5e8 lr e83d5cdb pc e83a5cb8
09-24 00:39:20.795 507 631 E LightsService: Light requested not available on this device. 0
09-24 00:39:20.807 1571 1571 F DEBUG :
09-24 00:39:20.807 1571 1571 F DEBUG : backtrace:
09-24 00:39:20.807 1571 1571 F DEBUG : #00 pc 0001acb8 /system/lib/libc.so (strlen+36)
09-24 00:39:20.807 1571 1571 F DEBUG : #01 pc 0004acd7 /system/lib/libc.so (__vfprintf+3366)
09-24 00:39:20.807 1571 1571 F DEBUG : #02 pc 0005fc2f /system/lib/libc.so (vsnprintf+110)
09-24 00:39:20.807 1571 1571 F DEBUG : #03 pc 00081a7d /vendor/lib/hw/camera.rk30board.so (rk_camera_debug_log(cam_modules_t, cam_global_debug_level_t, char const*, char const*, …)+60)
09-24 00:39:20.808 1571 1571 F DEBUG : #04 pc 000633eb /vendor/lib/hw/camera.rk30board.so (android::camera2::RequestThread::configureStreams(camera3_stream_configuration*)+54)
09-24 00:39:20.808 1571 1571 F DEBUG : #05 pc 0005e91f /vendor/lib/hw/camera.rk30board.so (android::camera2::Camera3HAL::configure_streams(camera3_stream_configuration*)+66)
09-24 00:39:20.808 1571 1571 F DEBUG : #06 pc 0005f14d /vendor/lib/hw/camera.rk30board.so (android::camera2::hal_dev_configure_streams(camera3_device const*, camera3_stream_configuration*)+88)
09-24 00:39:20.808 1571 1571 F DEBUG : #07 pc 00004e33 /vendor/lib/camera.device@3.3-impl.so (android::hardware:
:device::V3_3::implementation::CameraDeviceSession::configureStreams_3_3(android::hardware:
:device::V3_2::StreamConfiguration const&, std::__1::function<void (android::hardware:
:common::V1_0::Status, android::hardware:
:device::V3_3::HalStreamConfiguration const&)>)+274)
09-24 00:39:20.808 1571 1571 F DEBUG : #08 pc 00005475 /vendor/lib/camera.device@3.3-impl.so (android::hardware:
:device::V3_3::implementation::CameraDeviceSession::TrampolineSessionInterface_3_3::configureStreams_3_3(android::hardware:
:device::V3_3::HalStreamConfiguration const&)>)+64)
09-24 00:39:20.808 1571 1571 F DEBUG : #09 pc 0000c0b7 /system/lib/vndk-28/android.hardware.camera.device@3.3.so (android::hardware:
:device::V3_3::BnHwCameraDeviceSession::_hidl_configureStreams_3_3(android::hidl::base::V1_0::BnHwBase*, android::hardware::Parcel const&, android::hardware::Parcel*, std::__1::function<void (android::hardware::Parcel&)>)+210)
09-24 00:39:20.808 1571 1571 F DEBUG : #10 pc 0000c4e1 /system/lib/vndk-28/android.hardware.camera.device@3.3.so (android::hardware:
:device::V3_3::BnHwCameraDeviceSession::onTransact(unsigned int, android::hardware::Parcel const&, android::hardware::Parcel*, unsigned int, std::__1::function<void (android::hardware::Parcel&)>)+636)
09-24 00:39:20.808 1571 1571 F DEBUG : #11 pc 00016651 /system/lib/vndk-sp-28/libhwbinder.so (android::hardware::BHwBinder::transact(unsigned int, android::hardware::Parcel const&, android::hardware::Parcel*, unsigned int, std::__1::function<void (android::hardware::Parcel&)>)+52)
09-24 00:39:20.808 1571 1571 F DEBUG : #12 pc 0000f75f /system/lib/vndk-sp-28/libhwbinder.so (android::hardware::IPCThreadState::executeCommand(int)+806)
09-24 00:39:20.808 1571 1571 F DEBUG : #13 pc 0000f32b /system/lib/vndk-sp-28/libhwbinder.so (android::hardware::IPCThreadState::getAndExecuteCommand()+122)
09-24 00:39:20.808 1571 1571 F DEBUG : #14 pc 0000fbe7 /system/lib/vndk-sp-28/libhwbinder.so (android::hardware::IPCThreadState::joinThreadPool(bool)+190)
09-24 00:39:20.808 1571 1571 F DEBUG : #15 pc 00015fd5 /system/lib/vndk-sp-28/libhwbinder.so (android::hardware::PoolThread::threadLoop()+12)
09-24 00:39:20.808 1571 1571 F DEBUG : #16 pc 0000bfcb /system/lib/vndk-sp-28/libutils.so (android:
:_threadLoop(void*)+170)
09-24 00:39:20.808 1571 1571 F DEBUG : #17 pc 00064323 /system/lib/libc.so (__pthread_start(void*)+22)
09-24 00:39:20.808 1571 1571 F DEBUG : #18 pc 0001dfad /system/lib/libc.so (__start_thread+32)
09-24 00:39:20.829 507 631 I chatty : uid=1000(system) PhotonicModulat identical 2 lines
09-24 00:39:20.846 507 631 E LightsService: Light requested not available on this device. 0
fingerprint 这个对应的属性超过91个字符,导致一些apk读取属性溢出
rk3399pro android9.0 打开 c2395 camera 报错: 麻烦帮忙看下
dmesg log:
u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
[ 77.355524] type=1400 audit(1603335705.010:296): avc: denied { read } for pid=440 comm=“npu_monitor” name=“temp” dev=“sysfs” ino=9507 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
[ 77.355841] type=1400 audit(1603335705.010:296): avc: denied { read } for pid=440 comm=“npu_monitor” name=“temp” dev=“sysfs” ino=9507 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
[ 77.355919] type=1400 audit(1603335705.010:297): avc: denied { open } for pid=440 comm=“npu_monitor” path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9507 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
[ 122.806557] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 122.895519] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 182.806371] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 182.895293] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 242.806362] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 242.895170] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 279.053724] rkisp1: waiting on event return error 0
[ 280.060259] rkisp1: waiting on event return error 0
[ 280.060441] c2395:ov13850_s_stream
[ 280.060462] c2395:__ov13850_stop_stream
[ 286.119406] type=1400 audit(1603335705.010:297): avc: denied { open } for pid=440 comm=“npu_monitor” path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=9507 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=f
[ 286.119503] type=1400 audit(1603335913.770:298): avc: denied { write } for pid=424 comm=“Binder:424_3” name=“property_service” dev=“tmpfs” ino=2936 scontext=u:r:cameraserver:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_f
[ 286.119826] type=1400 audit(1603335913.770:298): avc: denied { write } for pid=424 comm=“Binder:424_3” name=“property_service” dev=“tmpfs” ino=2936 scontext=u:r:cameraserver:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_f
[ 286.119876] type=1400 audit(1603335913.770:299): avc: denied { connectto } for pid=424 comm=“Binder:424_3” path=“/dev/socket/property_service” scontext=u:r:cameraserver:s0 tcontext=u:r:init:s0 tclass=unix_stream_soc
[ 286.273820] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for 1-0036
[ 286.273846] rockchip-pinctrl pinctrl: pin-75 (1-0036) status -22
[ 286.273854] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 286.273862] ov13850 1-0036: Error applying setting, reverse things back
[ 286.273868] ov13850 1-0036: could not set pins
[ 286.306352] c2395:ov13850_s_stream
[ 286.306384] c2395:__ov13850_start_stream
[ 286.525955] OV13850_REG_VTS = 120,438
[ 286.526794] V4L2_CID_EXPOSURE = 1080
[ 286.527660] V4L2_CID_EXPOSURE reg = 1080
[ 286.528212] V4L2_CID_ANALOGUE_GAIN = 16
[ 286.528920] V4L2_CID_ANALOGUE_GAIN reg = 16
[ 292.606917] rkisp1: waiting on event return error 0
[ 293.613583] rkisp1: waiting on event return error 0
[ 293.613643] c2395:ov13850_s_stream
[ 293.613661] c2395:__ov13850_stop_stream
[ 300.197205] type=1400 audit(1603335913.770:299): avc: denied { connectto } for pid=424 comm=“Binder:424_3” path=“/dev/socket/property_service” scontext=u:r:cameraserver:s0 tcontext=u:r:init:s0 tclass=unix_stream_soc
[ 300.197290] type=1400 audit(1603335927.850:300): avc: denied { write } for pid=424 comm=“Binder:424_3” name=“property_service” dev=“tmpfs” ino=2936 scontext=u:r:cameraserver:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_f
[ 300.338051] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for 1-0036
[ 300.338085] rockchip-pinctrl pinctrl: pin-75 (1-0036) status -22
[ 300.338095] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 300.338104] ov13850 1-0036: Error applying setting, reverse things back
[ 300.338109] ov13850 1-0036: could not set pins
[ 300.381260] c2395:ov13850_s_stream
[ 300.381283] c2395:__ov13850_start_stream
[ 300.592518] OV13850_REG_VTS = 120,438
[ 300.593178] V4L2_CID_EXPOSURE = 1080
[ 300.593924] V4L2_CID_EXPOSURE reg = 1080
[ 300.594378] V4L2_CID_ANALOGUE_GAIN = 16
[ 300.594934] V4L2_CID_ANALOGUE_GAIN reg = 16
[ 302.806549] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 302.895411] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 306.083571] rkisp1: waiting on event return error 0
[ 307.090384] rkisp1: waiting on event return error 0
[ 307.090478] c2395:ov13850_s_stream
[ 307.090496] c2395:__ov13850_stop_stream
[ 350.180955] type=1400 audit(1603335927.850:300): avc: denied { write } for pid=424 comm=“Binder:424_3” name=“property_service” dev=“tmpfs” ino=2936 scontext=u:r:cameraserver:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_f
[ 350.181027] type=1400 audit(1603335977.816:301): avc: denied { connectto } for pid=424 comm=“Binder:424_3” path=“/dev/socket/property_service” scontext=u:r:cameraserver:s0 tcontext=u:r:init:s0 tclass=unix_stream_soc
[ 350.281203] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for 1-0036
[ 350.281264] rockchip-pinctrl pinctrl: pin-75 (1-0036) status -22
[ 350.281276] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 350.281288] ov13850 1-0036: Error applying setting, reverse things back
[ 350.281296] ov13850 1-0036: could not set pins
[ 350.327291] c2395:ov13850_s_stream
[ 350.327328] c2395:__ov13850_start_stream
[ 350.557750] OV13850_REG_VTS = 120,438
[ 350.559489] V4L2_CID_EXPOSURE = 1080
[ 350.560307] V4L2_CID_EXPOSURE reg = 1080
[ 350.560813] V4L2_CID_ANALOGUE_GAIN = 16
[ 350.561413] V4L2_CID_ANALOGUE_GAIN reg = 16
[ 353.391379] type=1400 audit(1603335977.816:301
打开camera 后 logcat log
130|console:/ $ logcat | grep RkCamera
^[[A10-22 03:01:23.859 259 259 D RkCamera: Debug log file is not enabled
10-22 03:01:23.863 259 259 D RkCamera: Debug log file is not enabled
10-22 03:01:23.863 259 259 E RkCamera: FlashLight: init: No flash available for camera id: 0
10-22 03:01:27.485 259 1503 E RkCamera: V4L2DevBase: Device /dev/video1 poll failed (timeout)
10-22 03:01:27.485 259 1503 E RkCamera: ImguUnit: Device poll failed
10-22 03:01:27.485 259 1504 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:01:27.487 259 1504 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:01:27.487 259 1504 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:01:27.488 259 1504 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:01:27.488 259 1504 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:01:27.489 259 1504 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:01:27.490 259 1504 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:01:27.491 259 1504 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:01:27.491 259 1504 E RkCamera: ImguUnit: error -2147483648 in handling message: 2
10-22 03:05:13.811 259 491 D RkCamera: Debug log file is not enabled
10-22 03:05:13.816 259 491 D RkCamera: Debug log file is not enabled
10-22 03:05:13.816 259 491 E RkCamera: FlashLight: init: No flash available for camera id: 0
10-22 03:05:17.326 259 1615 E RkCamera: V4L2DevBase: Device /dev/video1 poll failed (timeout)
10-22 03:05:17.326 259 1615 E RkCamera: ImguUnit: Device poll failed
10-22 03:05:17.327 259 1616 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:17.328 259 1616 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:17.328 259 1616 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:17.330 259 1616 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:17.331 259 1616 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:17.332 259 1616 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:17.332 259 1616 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:17.333 259 1616 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:17.334 259 1616 E RkCamera: ImguUnit: error -2147483648 in handling message: 2
10-22 03:05:27.886 259 259 D RkCamera: Debug log file is not enabled
10-22 03:05:27.906 259 259 D RkCamera: Debug log file is not enabled
10-22 03:05:27.907 259 259 E RkCamera: FlashLight: init: No flash available for camera id: 0
10-22 03:05:31.378 259 1666 E RkCamera: V4L2DevBase: Device /dev/video1 poll failed (timeout)
10-22 03:05:31.378 259 1666 E RkCamera: ImguUnit: Device poll failed
10-22 03:05:31.378 259 1667 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:31.380 259 1667 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:31.380 259 1667 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:31.381 259 1667 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:31.381 259 1667 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:31.382 259 1667 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:31.383 259 1667 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:05:31.384 259 1667 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:05:31.384 259 1667 E RkCamera: ImguUnit: error -2147483648 in handling message: 2
10-22 03:06:17.843 259 259 D RkCamera: Debug log file is not enabled
10-22 03:06:17.847 259 259 D RkCamera: Debug log file is not enabled
10-22 03:06:17.848 259 259 E RkCamera: FlashLight: init: No flash available for camera id: 0
10-22 03:06:21.361 259 1722 E RkCamera: V4L2DevBase: Device /dev/video1 poll failed (timeout)
10-22 03:06:21.361 259 1722 E RkCamera: ImguUnit: Device poll failed
10-22 03:06:21.361 259 1723 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:06:21.363 259 1723 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:06:21.363 259 1723 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:06:21.364 259 1723 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:06:21.364 259 1723 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:06:21.365 259 1723 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:06:21.366 259 1723 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:06:21.367 259 1723 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:06:21.367 259 1723 E RkCamera: ImguUnit: error -2147483648 in handling message: 2
10-22 03:35:41.029 259 259 D RkCamera: Debug log file is not enabled
10-22 03:35:41.034 259 259 D RkCamera: Debug log file is not enabled
10-22 03:35:41.034 259 259 E RkCamera: FlashLight: init: No flash available for camera id: 0
10-22 03:35:44.516 259 1898 E RkCamera: V4L2DevBase: Device /dev/video1 poll failed (timeout)
10-22 03:35:44.516 259 1898 E RkCamera: ImguUnit: Device poll failed
10-22 03:35:44.516 259 1899 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:35:44.517 259 1899 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:35:44.517 259 1899 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:35:44.518 259 1899 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:35:44.518 259 1899 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:35:44.519 259 1899 E RkCamera: OutputFrameWorker: postRun:379 device error!
10-22 03:35:44.519 259 1899 E RkCamera: OutputFrameWorker: run:336 device error!
10-22 03:35:44.519 259 1899 E RkCamera: ImguUnit: error -2147483648 in handling message: 2
[ 2162.806549] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 2162.895258] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
下发初始化后,打开camera 后,streamon mipi波形 如附件图片
你 好 可以加一下 你的QQ吗
您好,我也遇到这样的问题,请问您有解决吗
