Firefly-RK3399J linux buildroot degug串口问题
Firefly-RK3399J编译出来 linux buildroot本后后,启动后uboot的degug串口有打印信息,但是进入kernel后串口就无打印信息了,只打印了内核一部分打印信息就停止了,HDMI界面一直打印。后来以为是dts禁止了,但是打开后还是不可以,烧录官方的固件是可以的,dts和系统log如下
dts代码
chosen {
bootargs = “earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 ro root=PARTLABEL=rootfs rootfstype=ext4 rootwait overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1”;
fiq_debugger: fiq-debugger {
//status = “disabled”;
compatible = “rockchip,fiq-debugger”;
rockchip,serial-id = <2>;
rockchip,signal-irq = <182>;
rockchip,wake-irq = <0>;
rockchip,irq-mode-enable = <1>; /* If enable uart uses irq instead of fiq /
rockchip,baudrate = <1500000>; /
Only 115200 and 1500000 */
pinctrl-names = “default”;
pinctrl-0 = <&uart2c_xfer>;
status = “okay”;
&uart2 {
status = “okay”;
串口打印信息
DDR Version 1.24 20191016
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1 Release Time: Dec 24 2019 18:00:26, version: 1.24
CPUId = 0x0
ChipType = 0x10, 330
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68359
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: oem, start:0x3a000, size:0x20000
GPT part: 7, name: rootfs, start:0x5a000, size:0xff800
GPT part: 8, name: userdata, start:0x159800, size:0x1bc57df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xda214
RunBL31 0x40000 @ 109120 us
NOTICE: BL31: v1.3(release):57824cc
NOTICE: BL31: Built : 10:59:12, Jan 6 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1190): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-230-g6c76e8a9 #191 Mon Nov 18 07:00:24 UTC 2019 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Oct 04 2020 - 17:36:26 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbeb000
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 950000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: AIO-3399J Board (Linux Opensource)
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:1920x1080
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 148000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 22211 KiB
RAM disk load addr 0x0a200000 size 8675 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c468
Can’t find file:logo_kernel.bmp
Total: 2965.381 ms
[ 0.000000] Linux version 4.4.194 (root@alen-System) (firefly: 442ad5955470e2f4f2336881e9bc14ec4c041572) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #3 SMP Sun Oct 4 16:14:29 CST 2020
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee0000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c491609b65f24318 ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0x7fe98000-0x7fed8000] (0MB)
[ 0.000000] Memory: 1993416K/2064384K available (13886K kernel code, 1794K rwdata, 5284K rodata, 1216K init, 2007K bss, 70968K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009340000 - 0xffffff8009470000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e10000 ( 13888 KB)
[ 0.000000] .rodata : 0xffffff8008e10000 - 0xffffff8009340000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009470000 - 0xffffff8009630808 ( 1795 KB)
[ 0.000000] ITS: allocated 65536 Devices @7d480000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007d410000
[ 0.000000] CPU0: using LPI pending table @0x000000007d420000
[ 0.002241] Console: colour dummy device 80x25
[ 0.002671] console [tty0] enabled
[ 0.003007] bootconsole [uart0] disabled
已解决,
&uart2 {
在设备上关闭uart本身串口功能后,debug口才可以用
18824714993 发表于 2020-10-7 18:47
已解决,
&uart2 {
大哥。你这个在哪找到的?我怎么只是看到uart4 。。。。
在这个rk3399-linux.dtsi设备树文件中.
大佬啊 已经成功解决,多谢!!!!
能请教一下,uboot怎么改将默认打印的串口从uart2改为uart1吗
很赞,解决了我在firefly-rk3399-aiojd4开发板编译common-sdk版本编译的问题,多谢
