DDR Version 2.04 20150121
1A1A1C1C 3
DDR3
1C1C1C1C F
mach:2
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1359
No.1 FLASH ID:2c 64 44 4b a9 0
ECC:60
apSize=0
FwPartOffset=2000 , 0
StorageInit ok = 395172
the▒
U-Boot 2014.10-RK3128-10 (Dec 28 2015 - 14:53:17)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma▒storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
pmic rk818 i2c probe failed
device rt5025 is disabled
device rt5036 is disabled
No pmic detect.
can’t find dts node for ADC
Enter power_led_init
#Boot ver: 2015-06-12#2.25
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
no fuel gauge found
failed to find part:logo
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x006a3658)
ramdisk @ 0x65bf0000 (0x0029a22c)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 65616640 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (liangkd@tchip-server) (gcc version 4.6.x-go ogle 20120106 (prerelease) (GCC) ) #1858 SMP PREEMPT Tue Jun 27 17:21:10 CST 201 7 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot lo go [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608 [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1669000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 261120 [ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,1 15200 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init= /sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x000040 00(misc),0x00008000@0x00006000(resource),0x00010000@0x0000E000(boot),0x00020000@ 0x0001E000(backup),-@0x0003E000(linuxroot) storagemedia=nand uboot_logo=0x020000 00@0x9dc00000 loader.timestamp=2015-12-28_14:53:17 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memor y cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 962900k/962900k available, 85676k reserved, 483328K highm em [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0ba6824 (11899 kB) [ 0.000000] .init : 0xc0ba7000 - 0xc0c016c0 ( 362 kB) [ 0.000000] .data : 0xc0c02000 - 0xc0d1e438 (1138 kB) [ 0.000000] .bss : 0xc0d1e438 - 0xc0e404fc (1161 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 25 [ 0.000000] rkclk_init_clks: cnt_rate = 17 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:26 [ 0.000000] target-temp:85 [ 0.000000] FirePrime hardware version: V01 [ 0.000000] channel:0, lkg:26 [ 0.000000] target-temp:85 [ 0.000000] channel:0, lkg:26 [ 0.000000] target-temp:85 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps ever y 4294967286ms [ 0.000000] Console: colour dummy device 80x30 [ 0.287910] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=240000) [ 0.287937] pid_max: default: 32768 minimum: 301 [ 0.288134] Security Framework initialized [ 0.288163] SELinux: Initializing. [ 0.288296] Mount-cache hash table entries: 512 [ 0.289513] Initializing cgroup subsys debug [ 0.289542] Initializing cgroup subsys memory [ 0.289593] Initializing cgroup subsys freezer [ 0.289657] CPU: Testing write buffer coherency: ok [ 0.290180] /cpus/cpu@0 missing clock-frequency property [ 0.290211] /cpus/cpu@1 missing clock-frequency property [ 0.290230] /cpus/cpu@2 missing clock-frequency property [ 0.290249] /cpus/cpu@3 missing clock-frequency property [ 0.290322] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.290394] Setting up static identity map for 0xc0852cd8 - 0xc0852d30 [ 0.292524] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, si ze 0x80000 early 0x1667 (version 3.0) [ 0.365710] CPU1: Booted secondary processor [ 0.365767] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.385414] CPU2: Booted secondary processor [ 0.385461] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.405163] CPU3: Booted secondary processor [ 0.405206] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.405391] Brought up 4 CPUs [ 0.405443] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.405458] CPU: All CPU(s) started in SVC mode. [ 0.406854] devtmpfs: initialized [ 0.416397] pinctrl core: initialized pinctrl subsystem [ 0.416893] regulator-dummy: no parameters [ 0.418406] NET: Registered protocol family 16 [ 0.421498] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.422177] ion_snapshot: 0x7e9c8000 map to 0xe0907000 and copy to 0xc0e1ba84 (version 0.1) [ 0.422403] Registered FIQ tty driver [ 0.424748] console [ttyFIQ0] enabled [ 0.425168] Registered fiq debugger ttyFIQ0 [ 0.426635] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 star t=0x2007c000,end=0x2007c0ff [ 0.426771] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 star t=0x20080000,end=0x200800ff [ 0.426855] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 star t=0x20084000,end=0x200840ff [ 0.426934] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 star t=0x20088000,end=0x200880ff [ 0.427023] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 sta rt=0x20086000,end=0x200860ff [ 0.427093] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5 [ 0.427124] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7 [ 0.427153] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3 [ 0.427181] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137 [ 0.427210] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103 [ 0.429931] rockchip_pinctrl_probe:init ok [ 0.437642] rk_iommu 1010e300.vop_mmu: (vop) Enter [ 0.437700] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq [ 0.437792] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.437821] rk_iommu 1010e300.vop_mmu: (vop) Initialized [ 0.438096] rk_iommu 10104440.hevc_mmu: (hevc) Enter [ 0.438241] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM fro m 0x10000000. [ 0.438272] rk_iommu 10104440.hevc_mmu: (hevc) Initialized [ 0.438534] rk_iommu 10106800.vpu_mmu: (vpu) Enter [ 0.438663] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.438693] rk_iommu 10106800.vpu_mmu: (vpu) Initialized [ 0.438958] rk_iommu 10108800.iep_mmu: (iep) Enter [ 0.439084] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.439114] rk_iommu 10108800.iep_mmu: (iep) Initialized [ 0.440707] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.440738] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.441022] DDR DEBUG: version 1.02 20140828 [ 0.441046] DDR DEBUG: DRAM Type:DDR3 [ 0.441071] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB [ 0.441116] DDR DEBUG: init success!!! freq=300MHz [ 0.495236] bio: create slab at 0 [ 0.496278] Rockchip hdmi driver version 2.0 . [ 0.498122] SCSI subsystem initialized [ 0.498487] usbcore: registered new interface driver usbfs [ 0.498594] usbcore: registered new interface driver hub [ 0.498806] usbcore: registered new device driver usb [ 0.500992] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter [ 0.503179] media: Linux media interface: v0.10 [ 0.503274] Linux video capture ▒▒r▒▒▒▒º▒pps_core: LinuxPPS API ver. 1 regist ered [ 0.503512] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <[email]giometti@linux.it[/email]> [ 0.503560] PTP clock support registered [ 0.503701] i2c-core: driver [bq24296] using legacy suspend method [ 0.503727] i2c-core: driver [bq24296] using legacy resume method [ 0.505145] Rockchip ion module is successfully loaded (v1.1) [ 0.505414] Advanced Linux Sound Architecture Driver Initialized. [ 0.506181] Bluetooth: Core ver 2.16 [ 0.506260] NET: Registered protocol family 31 [ 0.506283] Bluetooth: HCI device and connection manager initialized [ 0.506318] Bluetooth: HCI socket layer initialized [ 0.506348] Bluetooth: L2CAP socket layer initialized [ 0.506401] Bluetooth: SCO socket layer initialized [ 0.506845] cfg80211: Calling CRDA to update world regulatory domain [ 0.508527] act8931_i2c_probe,line=715 [ 0.509330] The device is not act8931 [ 0.509976] rk818_i2c_probe,line=1286 [ 0.510763] The device is not rk818 255 [ 0.510808] rk818: probe of 0-001c failed with error 255 [ 0.510876] i2c-core: driver [rk818] using legacy suspend method [ 0.510898] i2c-core: driver [rk818] using legacy resume method [ 0.512654] Switching to clocksource arch_sys_counter [ 0.549312] fb disp policy is box [ 0.549416] rk-fb rockchip-fb: rk fb ion client create success! [ 0.549444] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.549913] rk-screen rk_screen.9: rockchip screen probe success [ 0.550499] rk31xx-lvds 20038000.lvds: screen is not lvds/rgb! [ 0.550546] rk31xx-lvds: probe of 20038000.lvds failed with error -22 [ 0.551578] rk312x-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.551609] rk_fb_trsm_ops_get:un supported transmitter:6! [ 0.552184] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.553009] graphics fb1: rockchip framebuffer registerd:fb1Lo[d n , .5e34e7w ira.h s fb2: rockchip framebuffer registerd:fb2 [ 0.554026] rk312x-lcdc lcdc0: set lcdc0 dclk failed [ 0.554061] rk312x-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60 [ 0.554086] rk312x-lcdc lcdc0: wakeup from standby! [ 0.572938] alloc_buffer:ion_phy_addr=0x10000000 [ 0.579756] fb0:phy:10000000>>vir:e0930000>>len:0xb00000 [ 0.590192] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 0.604005] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.606270] NET: Registered protocol family 2 [ 0.607196] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.607326] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.607440] TCP: Hash tables configured (established 4096 bind 4096) [ 0.607542] TCP: reno registered [ 0.607573] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.607620] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.607985] NET: Registered protocol family 1 [ 0.608998] Unpacking initramfs... [ 0.890802] Freeing initrd memory: 2664K (c5bf0000 - c5e8a000) [ 0.892069] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counter s available [ 0.892797] vcodec_service: probe device vpu_combo.10 [ 0.892834] vcodec_service: No reset resource define [ 0.892853] vcodec_service: No reset resource define [ 0.892870] vcodec_service: No reset resource define [ 0.892991] vcodec vpu_combo.10: failed on clk_get clk_cabac [ 0.893099] vcodec_service: vpu_combo.10: power on [ 0.893243] vcodec_service: probe device 10106000.vpu_service [ 0.893302] vcodec_service: checking hw id 4831 [ 0.894601] vcodec_service: probe device 10104000.hevc_service [ 0.894668] vcodec_service: checking hw id 6867 [ 0.895597] vcodec_service: vpu_combo.10: power off... [ 0.895669] vcodec_service: done [ 0.895688] vcodec_service: init success [ 0.895843] rknandbase v1.0 2014-03-31 [ 0.896115] rknand_probe clk rate = 148500000 [ 0.896303] rknand_driver:ret = 0 [ 0.897178] rk_dts_sensor_probe:Get s5k4ec rockchip,power failed! [ 0.897222] s5k4ec_io==1 [ 0.897277] the gpiorst1 is 107 [ 0.897308] the gpiorst2 is 107 [ 0.897366] rk_dts_sensor_probe:Get ov2659 rockchip,power failed! [ 0.897398] s5k4ec_io==2 [ 0.897436] rk_dts_sensor_probe:Get gc0329 rockchip,power failed! [ 0.897467] s5k4ec_io==2 [ 0.897503] rk_dts_sensor_probe:Get gc2035 rockchip,powerdown failed! [ 0.897533] s5k4ec_io==2 [ 0.897577] s5k4ec_io==2 [ 0.899132] audit: initializing netlink socket (disabled) [ 0.899205] type=2000 audit(0.610:1): initialized [ 0.900632] bounce pool size: 64 pages [ 0.911125] fuse init (API version 7.22) [ 0.911910] msgmni has been set to 973 [ 0.915387] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 46) [ 0.915424] io scheduler noop registered [ 0.915444] io scheduler deadline registered [ 0.915631] io scheduler cfq registered (default) [ 0.921093] rga 1010c000.rga: rga ion client create success! [ 0.921408] rga: Driver loaded succesfully [ 0.921548] rga: Module initialized. [ 1.024736] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mo de 0 --> 1 [ 1.024776] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mo de LOWER_PWR [ 1.024989] rk-hdmi 20034000.hdmi: hdmi probe success. [ 1.025929] IEP Power ON [ 1.026011] iep ion client create success! [ 1.026469] IEP Power OFF [ 1.026505] IEP Driver loaded succesfully [ 1.026648] Module initialized. [ 1.027146] cvbs connect to lcdc0 [ 1.027213] rk312x-lcdc lcdc0: lcdc0: dclk:27000000>>fps:63 [ 1.027410] rk3036-tve 1010e200.tve: rockchip,rk312x-tve tv encoder probe ok [ 1.030308] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.030348] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_ Peri-16 Num_Events-16 [ 1.031211] rk_serial.c v1.8 2014-03-04 [ 1.031552] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_se rial.0 [ 1.031991] serial 20060000.serial: membase e3452000 [ 1.038308] loop: module loaded [ 1.038433] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.038457] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.038483] mpu_init: Probe name mpu6050B1 [ 1.038797] ak8963_mod_init: Probe name ak8963_mod [ 1.040013] SCSI Media Changer driver v0.25 [ 1.040629] tun: Universal TUN/TAP device driver, 1.6 [ 1.040655] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.040959] vmac_init. [ 1.042050] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 1.042081] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 1.042105] stmmac_probe_config_dt: clock input or output? (input). [ 1.042129] stmmac_probe_config_dt: TX delay(0x30). [ 1.042150] stmmac_probe_config_dt: RX delay(0x10). [ 1.042253] stmmac_probe_config_dt: is rockchip,rk312x-gmac [ 1.042272] stmmc_pltfr_init: [ 1.042291] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 1.042386] stmmc_pltfr_init: init for RGMII [ 1.042410] tx delay=0x30 [ 1.042410] rx delay=0x10 [ 1.042642] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.042664] Normal descriptors [ 1.042680] Ring mode enabled [ 1.042697] DMA HW capability register supported [ 1.042716] RX Checksum Offload Engine supported (type 2) [ 1.042735] TX Checksum insertion supported [ 1.042752] Wake-Up On Lan supported [ 1.042829] Enable RX Mitigation via HW Watchdog Timer [ 1.043717] PPP generic driver version 2.4.2 [ 1.044068] PPP BSD Compression module registered [ 1.044129] PPP Deflate Compression module registered [ 1.044168] PPP MPPE Compression module registered [ 1.044191] NET: Registered protocol family 24 [ 1.044250] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) ( 6 bit encapsulation enabled). [ 1.044276] CSLIP: code copyright 1989 Regents of the University of Californi a. [ 1.044298] Rockchip WiFi SYS interface (V1.00) ... [ 1.044374] esp_mem_init enter date Jun 27 2017 17:20:44 [ 1.044396] esp_mem_init VERSION [V2.5] [ 1.044472] esp_mem_init complete [ 1.044613] usbcore: registered new interface driver catc [ 1.044704] usbcore: registered new interface driver kaweth [ 1.044728] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet dri ver [ 1.044812] usbcore: registered new interface driver pegasus [ 1.044896] usbcore: registered new interface driver rtl8150 [ 1.045002] usbcore: registered new interface driver r8152 [ 1.045025] hso: drivers/net/usb/hso.c: Option Wireless [ 1.045165] usbcore: registered new interface driver hso [ 1.045275] usbcore: registered new interface driver asix [ 1.045363] usbcore: registered new interface driver ax88179_178a [ 1.045449] usbcore: registered new interface driver cdc_ether [ 1.045533] usbcore: registered new interface driver cdc_eem [ 1.045617] usbcore: registered new interface driver dm9601 [ 1.045701] usbcore: registered new interface driver dm9620 [ 1.045806] usbcore: registered new interface driver smsc75xx [ 1.045924] usbcore: registered new interface driver smsc95xx [ 1.046011] usbcore: registered new interface driver gl620a [ 1.046096] usbcore: registered new interface driver net1080 [ 1.046180] usbcore: registered new interface driver plusb [ 1.046266] usbcore: registered new interface driver rndis_host [ 1.046351] usbcore: registered new interface driver cdc_subset [ 1.046434] usbcore: registered new interface driver zaurus [ 1.046533] usbcore: registered new interface driver MOSCHIP usb-ethernet dri ver [ 1.046671] usbcore: registered new interface driver int51x1 [ 1.046759] usbcore: registered new interface driver kalmia [ 1.046844] usbcore: registered new interface driver ipheth [ 1.046938] usbcore: registered new interface driver sierra_net [ 1.047023] usbcore: registered new interface driver cx82310_eth [ 1.047131] usbcore: registered new interface driver cdc_ncm [ 1.047229] usbcore: registered new interface driver qmi_wwan [ 1.047317] usbcore: registered new interface driver cdc_mbim [ 1.047340] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.049291] EHCI: ehci_rk_probe e3480000 e3480010 [ 1.049328] rockchip_ehci_host 101c0000.usb: EHCI Host Controller [ 1.049382] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1 [ 1.050064] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000 [ 1.063841] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.063988] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.064020] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.064047] usb usb1: Product: EHCI Host Controller [ 1.064070] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.064094] usb usb1: SerialNumber: 101c0000.usb [ 1.065076] hub 1-0:1.0: USB hub found [ 1.065127] hub 1-0:1.0: 1 port detected [ 1.065515] EHCI: ehci_rk_probe ok [ 1.065693] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.065924] ohci-rockchip 101e0000.usb: RK OHCI Host Controller [ 1.065977] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2 [ 1.066060] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000 [ 1.126896] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.126932] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.126958] usb usb2: Product: RK OHCI Host Controller [ 1.126983] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd [ 1.127007] usb usb2: SerialNumber: 101e0000.usb [ 1.127891] hub 2-0:1.0: USB hub found [ 1.127939] hub 2-0:1.0: 1 port detected [ 1.128601] usbcore: registered new interface driver cdc_acm [ 1.128628] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters [ 1.128757] usbcore: registered new interface driver usblp [ 1.128870] usbcore: registered new interface driver cdc_wdm [ 1.129026] usbcore: registered new interface driver usb-storage [ 1.129113] usbcore: registered new interface driver ums-alauda [ 1.129209] usbcore: registered new interface driver ums-cypress [ 1.129297] usbcore: registered new interface driver ums-datafab [ 1.129380] usbcore: registered new interface driver ums_eneub6250 [ 1.129464] usbcore: registered new interface driver ums-freecom [ 1.129549] usbcore: registered new interface driver ums-isd200 [ 1.129632] usbcore: registered new interface driver ums-jumpshot [ 1.129714] usbcore: registered new interface driver ums-karma [ 1.129798] usbcore: registered new interface driver ums-onetouch [ 1.129885] usbcore: registered new interface driver ums-sddr09 [ 1.129970] usbcore: registered new interface driver ums-sddr55 [ 1.130053] usbcore: registered new interface driver ums-usbat [ 1.130285] usbcore: registered new interface driver usbserial [ 1.130372] usbcore: registered new interface driver usbserial_generic [ 1.130441] usbserial: USB Serial support registered for generic [ 1.130524] usbcore: registered new interface driver option [ 1.130588] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.130803] usbcore: registered new interface driver trancevibrator [ 1.130828] usb20_otg: version 3.10a 21-DEC-2012 [ 1.131456] e3500040 [ 1.131484] Core Release: 2.91a [ 1.131505] Setting default values for core params [ 1.131742] Using Buffer DMA mode [ 1.131766] Periodic Transfer Interrupt Enhancement - disabled [ 1.131786] Multiprocessor Interrupt Enhancement - disabled [ 1.131807] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.131826] ^^^^^^^^^^^^^^^^^Device Mode [ 1.131850] Dedicated Tx FIFOs mode [ 1.131886] pcd_init otg_dev = c5a32f00 [ 1.132226] usb20_otg 10180000.usb: DWC OTG Controller [ 1.132287] usb20_otg 10180000.usb: new USB bus registered, assigned bus numb er 3 [ 1.132348] usb20_otg 10180000.usb: irq 42, io mem 0x00000000 [ 1.132477] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.132508] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.132535] usb usb3: Product: DWC OTG Controller [ 1.132560] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.132584] usb usb3: SerialNumber: 10180000.usb [ 1.133479] hub 3-0:1.0: USB hub found [ 1.133530] hub 3-0:1.0: 1 port detected [ 1.134135] usb20_host: version 3.10a 21-DEC-2012 [ 1.135047] usbcore: registered new interface driver xpad [ 1.135162] usbcore: registered new interface driver usb_acecad [ 1.135258] usbcore: registered new interface driver aiptek [ 1.135350] usbcore: registered new interface driver gtco [ 1.135442] usbcore: registered new interface driver hanwang [ 1.135546] usbcore: registered new interface driver kbtab [ 1.135657] usbcore: registered new interface driver wacom [ 1.136469] sensor_register_slave:mma8452,id=17 [ 1.136499] sensor_register_slave:gs_mc3230,id=23 [ 1.136517] gsensor_init [ 1.136535] sensor_register_slave:mpu6880_acc,id=24 [ 1.136556] sensor_register_slave:cm3217,id=47 [ 1.136576] sensor_register_slave:cm3218,id=48 [ 1.136943] .. rk pwm remotectl v1.1 init [ 1.137325] input: 20050030.pwm as /devices/20050030.pwm/input/input0 [ 1.143536] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 1.143626] i2c /dev entries driver [ 1.144258] IR NEC protocol handler initialized [ 1.144284] IR RC5(x) protocol handler initialized [ 1.144304] IR RC6 protocol handler initialized [ 1.144321] IR JVC protocol handler initialized [ 1.144339] IR Sony protocol handler initialized [ 1.144358] IR RC5 (streamzap) protocol handler initialized [ 1.144377] IR SANYO protocol handler initialized [ 1.144395] IR MCE Keyboard/mouse protocol handler initialized [ 1.144898] usbcore: registered new interface driver uvcvideo [ 1.144924] USB Video Class driver (1.1.1) [ 1.144947] CamSys driver version: v0.27.1, CamSys head file version: v0.10. 0 [ 1.144973] E:camsys_soc_init(87): camsys isn't support soc: 0x31260001! [ 1.147086] i2c-core: driver [bq27320] using legacy suspend method [ 1.147118] i2c-core: driver [bq27320] using legacy resume method [ 1.147912] device-mapper: uevent: version 1.0.3 [ 1.148449] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-d [email]evel@redhat.com[/email] [ 1.149139] Bluetooth: HCI UART driver ver 2.2 [ 1.149168] Bluetooth: HCI H4 protocol initialized [ 1.149189] Bluetooth: HCILL protocol initialized [ 1.149210] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19 [ 1.149230] rtk_btusb: Register usb char device interface for BT driver [ 1.149648] usbcore: registered new interface driver rtk_btusb [ 1.149756] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulato r(vdd_logic)! [ 1.149787] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulato r(vdd_logic)! [ 1.149815] DVFS ERR: clk_enable_dvfs: vd(vd_arm) can't get regulator( vdd_arm)! [ 1.149838] cpufreq version 1.0, suspend freq 1008 MHz [ 1.150209] cpuidle: using governor ladder [ 1.150234] cpuidle: using governor menu [ 1.150308] Synopsys Designware Multimedia Card Interface Driver [ 1.150330] MHSC version = Ver 2.00 2015-06-10 [ 1.150748] dw cru_regsbase addr 0x124. [ 1.150774] dw cru_reset_offset val 3. [ 1.150802] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a [ 1.150862] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc [ 1.151308] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller. [ 1.151722] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0] [ 1.151985] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.162230] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.182002] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800 000Hz for init[mmc0] [ 1.182030] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo [ 1.182048] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized [ 1.182577] dw cru_regsbase addr 0x124. [ 1.182604] dw cru_reset_offset val 1. [ 1.182631] dwmmc_rockchip 10214000.rksdmmc: Version ID is 270a [ 1.182691] dwmmc_rockchip 10214000.rksdmmc: failed to get hpclk_mmc [ 1.183352] dwmmc_rockchip 10214000.rksdmmc: Using external DMA controller. [ 1.183808] dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1] [ 1.183924] mmc1: no vmmc regulator found [ 1.184246] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.201571] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.221324] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.221370] dwmmc_rockchip 10214000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo [ 1.221404] dwmmc_rockchip 10214000.rksdmmc: 1 slots initialized [ 1.221913] dw cru_regsbase addr 0x124. [ 1.221940] dw cru_reset_offset val 2. [ 1.221966] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a [ 1.222027] dwmmc_rockchip 10218000.rksdmmc: failed to get hpclk_mmc [ 1.222414] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller. [ 1.222835] dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2] [ 1.223182] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.231233] dwc_otg_hcd_suspend, usb device mode [ 1.240992] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.260702] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.260762] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo [ 1.260796] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized [ 1.261218] leds-gpio leds.18: pins are not configured from the driver [ 1.261936] hidraw: raw HID events driver (C) Jiri Kosina [ 1.266346] usbcore: registered new interface driver usbhid [ 1.266376] usbhid: USB HID core driver [ 1.267249] zram: Created 1 device(s) ... [ 1.268080] ashmem: initialized [ 1.268424] logger: created 256K log 'log_main' [ 1.268726] logger: created 256K log 'log_events' [ 1.269031] logger: created 256K log 'log_radio' [ 1.269338] logger: created 256K log 'log_system' [ 1.271831] input: rk29-keypad as /devices/2006c000.adc/key.21/input/input1 [ 1.274082] ------------[ cut here ]------------ [ 1.274120] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c /0xb4() [ 1.274142] autorequest GPIO-27 [ 1.274158] Modules linked in: [ 1.274188] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #1858 [ 1.274239] [] (unwind_backtrace+0x0/0xe0) from [] (show_ stack+0x10/0x14) [ 1.274280] [] (show_stack+0x10/0x14) from [] (warn_slowp ath_common+0x4c/0x68) [ 1.274321] [] (warn_slowpath_common+0x4c/0x68) from [] ( warn_slowpath_fmt+0x2c/0x3c) [ 1.274361] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpi o_ensure_requested+0x4c/0xb4) [ 1.274402] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0) [ 1.274447] [] (gpiod_direction_input+0x58/0x1f0) from [] (rk312x_platform_probe+0x46c/0x5a4) [ 1.274492] [] (rk312x_platform_probe+0x46c/0x5a4) from [ ] (platform_drv_probe+0x14/0x18) [ 1.274534] [] (platform_drv_probe+0x14/0x18) from [] (re ally_probe+0xa8/0x20c) [ 1.274573] [] (really_probe+0xa8/0x20c) from [] (driver_ probe_device+0x30/0x48) [ 1.274611] [] (driver_probe_device+0x30/0x48) from [] (_ _driver_attach+0x60/0x84) [ 1.274649] [] (__driver_attach+0x60/0x84) from [] (bus_f or_each_dev+0x50/0x90) [ 1.274686] [] (bus_for_each_dev+0x50/0x90) from [] (bus_ add_driver+0xac/0x20c) [ 1.274724] [] (bus_add_driver+0xac/0x20c) from [] (drive r_register+0x9c/0x138) [ 1.274764] [] (driver_register+0x9c/0x138) from [] (do_o ne_initcall+0x34/0xc8) [ 1.274804] [] (do_one_initcall+0x34/0xc8) from [] (do_in itcalls+0x70/0xa0) [ 1.274843] [] (do_initcalls+0x70/0xa0) from [] (kernel_i nit_freeable+0x90/0x130) [ 1.274884] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 1.274924] [] (kernel_init+0x8/0xe4) from [] (ret_from_f ork+0x14/0x3c) [ 1.274987] ---[ end trace cf8446496bbaf77b ]--- [ 1.275398] This platfrom have not i2s_mclk,no need to set i2s_mclk. [ 1.276072] rockchip-spdif 10204000.spdif: spdif ready. [ 1.279237] audio-rk312x audio-rk312x.14: rk312x-hifi <-> rockchip-i2s.1 map ping ok [ 1.280593] audio-rk312x audio-rk312x.14: rk312x-voice <-> rockchip-i2s.1 ma pping ok [ 1.280661] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias [ 1.280691] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack -> direct -> Mic Bias [ 1.280721] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mi c Bias [ 1.280749] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias -> direct -> MICP [ 1.280778] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mi c Bias [ 1.280806] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias -> direct -> MICN [ 1.280835] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias [ 1.280862] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Headset J ack -> direct -> Mic Bias [ 1.280891] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HP OUTR [ 1.280919] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR -> direct -> Ext Spk [ 1.280947] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HP OUTL [ 1.280975] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL -> direct -> Ext Spk [ 1.281003] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HP OUTR [ 1.281031] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR -> direct -> Headphone Jack [ 1.281060] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HP OUTL [ 1.281087] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL -> direct -> Headphone Jack [ 1.284648] rockchip-hdmi-spdif rockchip-hdmi-spdif.13: rk-hdmi-spdif-hifi < -> 10204000.spdif mapping ok [ 1.286181] u32 classifier [ 1.286208] Actions configured [ 1.286233] Netfilter messages via NETLINK v0.30. [ 1.286352] nf_conntrack version 0.5.0 (15470 buckets, 61880 max) [ 1.287215] ctnetlink v0.93: registering with nfnetlink. [ 1.287366] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 1.287391] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1.288195] xt_time: kernel timezone is -0000 [ 1.288741] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.289128] arp_tables: (C) 2002 David S. Miller [ 1.289234] TCP: cubic registered [ 1.289254] Initializing XFRM netlink socket [ 1.290014] NET: Registered protocol family 10 [ 1.291475] mip6: Mobile IPv6 [ 1.291551] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.291891] sit: IPv6 over IPv4 tunneling driver [ 1.292875] NET: Registered protocol family 17 [ 1.292947] NET: Registered protocol family 15 [ 1.293099] Bridge firewalling registered [ 1.293134] Ebtables v2.0 registered [ 1.293489] Bluetooth: RFCOMM TTY layer initialized [ 1.293561] Bluetooth: RFCOMM socket layer initialized [ 1.293585] Bluetooth: RFCOMM ver 1.11 [ 1.293606] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.293627] Bluetooth: BNEP filters: protocol multicast [ 1.293660] Bluetooth: BNEP socket layer initialized [ 1.293682] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.293713] Bluetooth: HIDP socket layer initialized [ 1.293783] l2tp_core: L2TP core driver, V2.0 [ 1.293822] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 1.293843] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.294123] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.294154] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212a [ 1.294178] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.294201] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.294225] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gp io. [ 1.294305] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren _gpio = 43, flags = 0. [ 1.294373] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wa ke_irq = 2, flags = 0. [ 1.294398] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.294449] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.294545] [BT_RFKILL]: Enter rfkill_rk_init [ 1.294857] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_ gpios = 17. [ 1.294927] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_ gpio = 35. [ 1.294973] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_g pio = 42. [ 1.295019] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_h ost_irq = 41. [ 1.295140] [BT_RFKILL]: Request irq for bt wakeup host [ 1.295323] [BT_RFKILL]: ** disable irq [ 1.295535] [BT_RFKILL]: ap6212 device registered. [ 1.296001] rk_cam_cif(3083):rk312x-camera version: v0.1.14 Zoom by ipp [ 1.296169] rk_cif 1010a000.cif: rk_camera_cif_iomux:could not get cif_pin_al l pinstate [ 1.296845] soc-camera-pdrv s5k4ec_back_3: Probing s5k4ec_back_3 [ 1.297739] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 1.297787] rk312x_init_suspend [ 1.297805] rk312x_suspend_init [ 1.298181] Registering SWP/SWPB emulation handler [ 1.298212] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 2000000@ 9dc00000 [ 1.307299] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulato r(vdd_logic)! [ 1.308333] ddrfreq: verion 1.2 20140526 [ 1.308373] ddrfreq: normal 492MHz video_1080p 240MHz video_4k 396MHz dualvie w 396MHz idle 0MHz suspend 198MHz reboot 492MHz [ 1.308398] ddrfreq: auto-freq=0 [ 1.308417] ddrfreq: auto-freq-table[0] 240MHz [ 1.308435] ddrfreq: auto-freq-table[1] 324MHz [ 1.308454] ddrfreq: auto-freq-table[2] 396MHz [ 1.308473] ddrfreq: auto-freq-table[3] 528MHz [ 1.309838] regulator-dummy: disabling [ 1.310101] ======================================================= [ 1.310129] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.310149] ======================================================= [ 1.310170] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init. [ 1.310308] dhd_module_init: in [ 1.310334] ======== bcm_wlan_set_plat_data ======== [ 1.310355] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.310430] host_oob_irq: 164 [ 1.310448] host_oob_irq_flags=4 [ 1.310465] dhd_wifi_platform_load: Enter [ 1.310511] pcd_pullup, is_on 0 [ 1.310540] Power-up adapter 'DHD generic adapter' [ 1.310626] wifi_platform_set_power = 1 [ 1.310647] file system registered [ 1.310667] ======== PULL WL_REG_ON HIGH! ======== [ 1.310687] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.310708] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 1.310728] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference volta ge control is disabled. [ 1.312688] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 1.312721] android_usb gadget: Number of LUNs=2 [ 1.312744] lun0: LUN: removable file: (no medium) [ 1.312766] lun1: LUN: removable file: (no medium) [ 1.313241] android_usb gadget: android_usb ready [ 1.313429] sensor_init: Probe name sensors [ 1.313476] sensor-dev.c v1.4 add angle calculation support between two gsens ors 2013-09-01 [ 1.314142] rtc_hym8563 0-0051: setting system clock to 2011-01-01 13:24:13 U TC (1293888253) [ 1.325026] usbcore: registered new interface driver snd-usb-audio [ 1.325059] ALSA device list: [ 1.325077] #0: RK_RK312X [ 1.325094] #1: RK-HDMI-SPDIF [ 1.326043] Freeing unused kernel memory: 360K (c0ba7000 - c0c01000) [ 1.378830] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_h ost [ 1.384589] rk30xxnand_ko: module license '' taints kernel. [ 1.384628] Disabling lock debugging due to kernel taint [ 1.387131] rknand_init: [ 1.387241] FtlInit fffffffe [ 1.387261] NandInit fail [ 1.387278] init_nand_blk_dev:ret = ffffffff [ 1.398409] Cam_Powerdowm [ 1.398462] Unable to handle kernel paging request at virtual address fffffe2 b [ 1.527029] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201 [ 1.527050] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.527065] usb 1-1: Product: USB 2.0 Hub [MTT] [ 1.528130] hub 1-1:1.0: USB hub found [ 1.528252] hub 1-1:1.0: 7 ports detected [ 1.801938] usb 1-1.6: new high-speed USB device number 3 using rockchip_ehci _host [ 1.911643] usb 1-1.6: New USB device found, idVendor=0bda, idProduct=8152 [ 1.911663] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber =3 [ 1.911678] usb 1-1.6: Product: USB 10/100 LAN [ 1.911691] usb 1-1.6: Manufacturer: Realtek [ 1.911705] usb 1-1.6: SerialNumber: 303339383131 [ 1.976468] r8152 1-1.6:1.0 eth1: v1.0.0 (2013/05/03) [ 3.904870] [WLAN_RFKILL]: wifi turn on power. 43 [ 3.905069] pgd = c0004000 [ 3.905098] [fffffe2b] *pgd=7eff6821, *pte=00000000, *ppte=00000000 [ 3.905118] Internal error: Oops: 17 [#1] PREEMPT SMP ARM [ 3.905135] Modules linked in: rk30xxnand_ko(P-) [ 3.905153] CPU: 2 PID: 95 Comm: rk_camera_init Tainted: P W 3.10.0 #1858 [ 3.905168] task: de98cec0 ti: c5b38000 task.ti: c5b38000 [ 3.905190] PC is at regulator_set_voltage+0x8/0xe0 [ 3.905207] LR is at sensor_power_default_cb+0x90/0x270 [ 3.905224] pc : [] lr : [] psr: 20000013 [ 3.905224] sp : c5b39d10 ip : 00000000 fp : 002ab980 [ 3.905241] r10: fffffdfb r9 : 001b7740 r8 : c56111f4 [ 3.905255] r7 : 00000001 r6 : ffffffff r5 : c561121c r4 : fffffdfb [ 3.905268] r3 : 00000000 r2 : 001b7740 r1 : 001b7740 r0 : fffffdfb [ 3.905282] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kern el [ 3.905295] Control: 10c5387d Table: 65be006a DAC: 00000015 [ 3.905306] [ 3.905306] PC: 0xc02e26e4: [ 3.905341] 26e4 e3530000 1a000002 e5962018 e3520000 0a000013 e58d3000 e1a00 004 e5963018 [ 3.905372] 2704 e1a0100d e28d2004 e58d3004 ebfffa43 e2506000 ba00000b e1a00 004 e1a0100d [ 3.905403] 2724 e28d2004 ebffffb9 e2506000 ba000005 e1a00004 e89d0006 ebfff c14 e1a06000 [ 3.905433] 2744 ea000000 e3e06015 e1a00005 eb15b7a6 e1a00006 e8bd807c e92d4 5f7 e1a04000 [ 3.905464] 2764 e5905030 e58d2000 e2856038 e58d1004 e1a00006 eb15b833 e5942 014 e59d3004 [ 3.905494] 2784 e1520003 1a000004 e5942018 e59d3000 e1520003 03a0a000 0a000 022 e5953000 [ 3.905525] 27a4 e5933014 e5932004 e3520000 1a000003 e593300c e3530000 03e0a 015 0a000019 [ 3.905555] 27c4 e1a00005 e28d1004 e1a0200d ebfffa13 e250a000 ba000013 e59d3 004 e1a00005 [ 3.905566] [ 3.905566] LR: 0xc0032870: [ 3.905601] 2870 e1a07001 e5906004 e590b054 e58d3008 e5903018 e5909058 e5908 048 e58d300c [ 3.905631] 2890 e59f3210 e590504c e5933000 e3530002 da000007 e59f3200 e3002 1aa e59f01fc [ 3.905662] 28b0 e59f11fc e58d3004 e59f31f8 e58d2000 eb2012c1 e3550000 0a000 018 e3a00000 [ 3.905693] 28d0 e1a01005 eb0abde1 e3570000 e1a0a000 0a00000b e1a01009 e1a02 009 eb0abf9a [ 3.905724] 28f0 e1a0000a eb0ac095 e1a05000 e1a0000a eb0ab672 e3a0000a eb004 7af ea000007 [ 3.905754] 2910 eb0ac078 e1a0000a eb0ac1d6 e3500000 e1a0000a cafffff9 eb0ab 668 e3a05000 [ 3.905785] 2930 e3a0a033 e59f9180 ea000002 e5993004 e59f0178 e12fff33 e25aa 001 1afffffa [ 3.905816] 2950 e3580000 0a000017 e1a01008 e1a0000a eb0abdbe e3570000 e1a08 000 0a00000b [ 3.905826] [ 3.905826] SP: 0xc5b39c90: [ 3.905859] 9c90 c0d3efc8 c0037acc 0000001d c0d4c320 00000000 0000001d c0d4c 320 c0037f38 [ 3.905890] 9cb0 00000400 c02e2764 20000013 ffffffff c5b39cfc c000d598 fffff dfb 001b7740 [ 3.905919] 9cd0 001b7740 00000000 fffffdfb c561121c ffffffff 00000001 c5611 1f4 001b7740 [ 3.905949] 9cf0 fffffdfb 002ab980 00000000 c5b39d10 c00328f0 c02e2764 20000 013 ffffffff [ 3.905979] 9d10 fffffdfb 001b7740 001b7740 de024228 c561121c ffffffff 00000 001 c56111f4 [ 3.906007] 9d30 fffffdfb c00328f0 c0d3eac0 c00327e8 00000008 00000004 00000 000 00000001 [ 3.906036] 9d50 c0032860 de024228 de024000 00000000 00000467 00000000 016e3 600 c00314d4 [ 3.906064] 9d70 00000005 c029a2a0 de025228 00000000 0000007f 00000001 00000 008 de024080 [ 3.906074] [ 3.906074] R0: 0xfffffd7b: [ 3.906109] fd78 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906134] fd98 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906161] fdb8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906186] fdd8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906212] fdf8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906238] fe18 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906264] fe38 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906290] fe58 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906316] fe78 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906326] [ 3.906326] R4: 0xfffffd7b: [ 3.906356] fd78 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906382] fd98 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906408] fdb8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906435] fdd8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906461] fdf8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906487] fe18 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906513] fe38 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906539] fe58 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906565] fe78 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.906575] [ 3.906575] R5: 0xc561119c: [ 3.906609] 119c 04000000 e00f0000 00000000 03000000 04000000 fe0f0000 00000 000 01000000 [ 3.906638] 11bc 346b3573 00006365 03000000 05000000 f0020000 79616b6f 00000 000 03000000 [ 3.906668] 11dc 04000000 19100000 00000000 03000000 0b000000 22100000 31386 b72 646c5f38 [ 3.906698] 11fc 0000346f 03000000 04000000 3b100000 80b92a00 03000000 0b000 000 57100000 [ 3.906728] 121c 31386b72 646c5f38 0000386f 03000000 04000000 70100000 40771 b00 03000000 [ 3.906758] 123c 0c000000 8c100000 76000000 1f000000 00000000 03000000 04000 000 9f100000 [ 3.906787] 125c 00000000 03000000 0c000000 ab100000 76000000 0b000000 01000 000 03000000 [ 3.906817] 127c 00000000 b5100000 03000000 00000000 c5100000 03000000 04000 000 d1100000 [ 3.906827] [ 3.906827] R8: 0xc5611174: [ 3.906861] 1174 01000000 03000000 04000000 a00f0000 00000000 03000000 04000 000 be0f0000 [ 3.906890] 1194 00000000 03000000 04000000 e00f0000 00000000 03000000 04000 000 fe0f0000 [ 3.906919] 11b4 00000000 01000000 346b3573 00006365 03000000 05000000 f0020 000 79616b6f [ 3.906948] 11d4 00000000 03000000 04000000 19100000 00000000 03000000 0b000 000 22100000 [ 3.906978] 11f4 31386b72 646c5f38 0000346f 03000000 04000000 3b100000 80b92 a00 03000000 [ 3.907008] 1214 0b000000 57100000 31386b72 646c5f38 0000386f 03000000 04000 000 70100000 [ 3.907038] 1234 40771b00 03000000 0c000000 8c100000 76000000 1f000000 00000 000 03000000 [ 3.907067] 1254 04000000 9f100000 00000000 03000000 0c000000 ab100000 76000 000 0b000000 [ 3.907077] [ 3.907077] R10: 0xfffffd7b: [ 3.907108] fd78 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907134] fd98 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907160] fdb8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907186] fdd8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907212] fdf8 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907238] fe18 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907264] fe38 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907290] fe58 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907316] fe78 ******** ******** ******** ******** ******** ******** ***** *** ******** [ 3.907329] Process rk_camera_init (pid: 95, stack limit = 0xc5b38238) [ 3.907342] Stack: (0xc5b39d10 to 0xc5b3a000) [ 3.907360] 9d00: fffffdfb 001b7740 001b7 740 de024228 [ 3.907382] 9d20: c561121c ffffffff 00000001 c56111f4 fffffdfb c00328f0 c0d3e ac0 c00327e8 [ 3.907403] 9d40: 00000008 00000004 00000000 00000001 c0032860 de024228 de024 000 00000000 [ 3.907424] 9d60: 00000467 00000000 016e3600 c00314d4 00000005 c029a2a0 de025 228 00000000 [ 3.907445] 9d80: 0000007f 00000001 00000008 de024080 c0d3eac0 c00317e4 de024 080 00000467 [ 3.907467] 9da0: 00000001 00000467 de024080 016e3600 c0d3eac0 de024000 00000 001 00000001 [ 3.907488] 9dc0: 000004a5 c0031b74 de024080 00000001 00000000 de024028 de024 080 00000000 [ 3.907509] 9de0: 00000000 c0df9de4 c5a4d800 00000000 de02bc64 c0540204 de02b c10 de024028 [ 3.907532] 9e00: de02bc10 c05402a8 c0c0b2a8 00a6b000 ff0a0004 ffffffff 00000 001 c5a4d800 [ 3.907554] 9e20: c0c25e38 00000000 00000000 c0df9de4 c0c25e38 c0a5454b 00000 000 c0280a54 [ 3.907576] 9e40: c5a4d814 c5b39e54 c0a7ca21 c5a4d800 c0ca7708 de02bc10 00000 000 c0df9de4 [ 3.907598] 9e60: c0c25e38 c0a5454b 00000000 c0540810 00000000 c5a4d800 c0c25 e28 c0d3eae0 [ 3.907619] 9e80: 00000000 c0554a30 00000000 c5a4d800 0000000e c0ad0174 00000 000 c0c25e38 [ 3.907639] 9ea0: 00000000 c0ca955c 00000000 00000000 00000000 c030c858 c030c 844 c030b620 [ 3.907661] 9ec0: c0c25e38 c0ca955c c0ca955c 00000000 00000000 c030b87c 00000 000 c0c25e38 [ 3.907684] 9ee0: c0c25e6c c030b8f4 c0ca955c c5b39ef8 c030b894 c030a0d0 de8eb 65c debc7634 [ 3.907706] 9f00: c0ca955c c0ca955c c5a9b000 c0c47a38 00000000 c030ae80 c0a54 54b c0a5454d [ 3.907727] 9f20: c0ca955c 00000000 00000000 c0551d88 00000000 c030bdd0 00000 000 de867f00 [ 3.907747] 9f40: 00000000 00000000 c0551d88 00000000 00000000 c0551dc4 00000 000 c5b39f6c [ 3.907767] 9f60: c5b39f50 c0055984 c0c28468 00000000 c005b264 00000000 00000 000 00000000 [ 3.907790] 9f80: c5b39f80 c5b39f80 00000000 00000000 c5b39f90 c5b39f90 c5b39 fac de867f00 [ 3.907809] 9fa0: c00558e4 00000000 00000000 c000da98 00000000 00000000 00000 000 00000000 [ 3.907827] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000 000 00000000 [ 3.907846] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00002 34e 00000000 [ 3.907881] [] (regulator_set_voltage+0x8/0xe0) from [] ( sensor_power_default_cb+0x90/0x270) [ 3.907907] [] (sensor_power_default_cb+0x90/0x270) from [] (rk_sensor_ioctrl+0xdc/0x2e4) [ 3.907932] [] (rk_sensor_ioctrl+0xdc/0x2e4) from [] (rk_ sensor_pwrseq+0xa0/0x230) [ 3.907956] [] (rk_sensor_pwrseq+0xa0/0x230) from [] (rk_ sensor_power+0x200/0x2dc) [ 3.907984] [] (rk_sensor_power+0x200/0x2dc) from [] (soc _camera_power_on+0x48/0x78) [ 3.908012] [] (soc_camera_power_on+0x48/0x78) from [] (s oc_camera_probe+0x74/0x41c) [ 3.908040] [] (soc_camera_probe+0x74/0x41c) from [] (soc _camera_host_register+0x1c0/0x220) [ 3.908069] [] (soc_camera_host_register+0x1c0/0x220) from [] (rk_camera_probe+0x3e8/0x598) [ 3.908099] [] (rk_camera_probe+0x3e8/0x598) from [] (pla tform_drv_probe+0x14/0x18) [ 3.908127] [] (platform_drv_probe+0x14/0x18) from [] (re ally_probe+0xa8/0x20c) [ 3.908152] [] (really_probe+0xa8/0x20c) from [] (driver_ probe_device+0x30/0x48) [ 3.908176] [] (driver_probe_device+0x30/0x48) from [] (_ _driver_attach+0x60/0x84) [ 3.908201] [] (__driver_attach+0x60/0x84) from [] (bus_f or_each_dev+0x50/0x90) [ 3.908225] [] (bus_for_each_dev+0x50/0x90) from [] (bus_ add_driver+0xac/0x20c) [ 3.908250] [] (bus_add_driver+0xac/0x20c) from [] (drive r_register+0x9c/0x138) [ 3.908277] [] (driver_register+0x9c/0x138) from [] (rk_c amera_init_async+0x3c/0x5c) [ 3.908306] [] (rk_camera_init_async+0x3c/0x5c) from [] ( kthread+0xa0/0xac) [ 3.908336] [] (kthread+0xa0/0xac) from [] (ret_from_fork +0x14/0x3c) [ 3.908358] Code: e1a00006 e8bd807c e92d45f7 e1a04000 (e5905030) [ 3.908386] [sched_delayed] sched: RT throttling activated [ 3.908449] ---[ end trace cf8446496bbaf77d ]--- [ 4.232311] rk312x_delay_workq [ 4.350456] [off] insmod: can't insert '/lib/modules/rk30xxnand_ko.ko.3.10.0': Operation not permi tted [ 5.006182] udevd[133]: starting version 175 Begin: Loading essential drivers ... FATAL: Could not load /lib/modules/3.10.0/m odules.dep: No such file or directory FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. [ 5.158247] wifi_platform_bus_enumerate device present 1 [ 5.163495] ======== Card detection to detect SDIO card! ======== [ 5.170744] mmc2:mmc host rescan start! [ 5.383747] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800 000Hz for init[mmc2] [ 5.419084] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000 Hz, actual 37500000HZ div = 0) [ 5.428725] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out nor mal clock [mmc2] [ 5.437389] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2] [ 5.445636] mmc2: new high speed SDIO card at address 0001 wait-for-root /dev/block/mtd/by-name/linuxroot, retry 2... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 3... [ 7.135182] failed to power up DHD generic adapter, 0 retry left [ 7.158198] wifi_platform_set_power = 0 [ 7.161985] ======== PULL WL_REG_ON LOW! ======== [ 7.166682] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 7.272868] [WLAN_RFKILL]: wifi shut off power. [ 7.277342] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0 [ 7.282484] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference volta ge control is disabled. [ 7.291510] wifi_platform_bus_enumerate device present 0 [ 7.296780] ======== Card detection to remove SDIO card! ======== [ 7.302822] mmc2:mmc host rescan start! [ 7.306617] failed to power up DHD generic adapter, max retry reached** [ 7.313195] unregister wifi platform drivers [ 7.317403] wifi_platform_bus_enumerate device present 0 [ 7.322695] ======== Card detection to remove SDIO card! ======== [ 7.328694] mmc2:mmc host rescan start! [ 7.332503] dhd_module_init: Failed to load the driver, try cnt 0 [ 7.338540] dhd_module_init: Failed to load driver max retry reached** [ 7.345005] dhd_module_init: Exit err=-19 [ 7.499449] mmc2: card 0001 removed [ 7.503047] 1358..dw_mci_set_ios: no card. [mmc2] wait-for-root /dev/block/mtd/by-name/linuxroot, retry 4... [ 9.014612] [otg id chg] last id -1 current id 256 [ 9.019352] PortPower off wait-for-root /dev/block/mtd/by-name/linuxroot, retry 5... [ 9.121362] Using Buffer DMA mode [ 9.124761] Periodic Transfer Interrupt Enhancement - disabled [ 9.130511] Multiprocessor Interrupt Enhancement - disabled [ 9.136069] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 9.140360] ^^^^^^^^^^^^^^^^^Device Mode [ 9.634490] ***************vbus detect***************** wait-for-root /dev/block/mtd/by-name/linuxroot, retry 6... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 7... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 8... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 9... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 10... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 11... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 12... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 13... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 14... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 15... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 16... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 17... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 18... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 19... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 20... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 21... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 22... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 23... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 24... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 25... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 26... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 27... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 28... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 29... wait-for-root /dev/block/mtd/by-name/linuxroot, retry 30... Gave up waiting for root device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Check root= (did the system wait for the right device?) - Missing modules (cat /proc/modules; ls /dev) ALERT! /dev/block/mtd/by-name/linuxroot does not exist. Dropping to a shell! FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory /bin/sh: can't access tty; job control turned off (initramfs)
