按照这个帖子编译的boot.img http://developer.t-firefly.com/forum.php?mod=viewthread&tid=1085&highlight=usb
重新开机后无法启动要怎么半?
es8323_create file error
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
–check rootdelay = (did the system wait long enough?)
–check root = ( did the system wait for the right device?) - Missing modules (cat /proc/moudles: ls /dev)
ALERT! /dev/block/mtd/by-name/linuxroot does not exist . Dropping to a shell!
FATAL: Could not load /lib/moudles/3.10.0/moudles.dep: No such file or directory
/bin/sh: can’t access tty; job control turned off
(initramfs)
