为什么编译ROC-RK3308B-CC-PLUS出现文件不存在
pzw@haitu-PowerEdge-R720:~/share/RK3308$ git remote -v
gitlab git@gitlab.com:TeeFirefly/rk3308-linux.git (fetch)
gitlab git@gitlab.com:TeeFirefly/rk3308-linux.git (push)
pzw@haitu-PowerEdge-R720:~/share/RK3308$ git remote set-url gitlab https://gitlab.com/TeeFirefly/rk3308-linux.git
pzw@haitu-PowerEdge-R720:~/share/RK3308$ cd ./.git/
pzw@haitu-PowerEdge-R720:~/share/RK3308/.git$ ./build.sh roc-rk3308b-cc-plus_release_BoardConfig.mk
-bash: ./build.sh: No such file or directory
当前目录下是否有build.sh文件? 编译参考http://wiki.t-firefly.com/zh_CN/Core-3308Y/sdkbuilding.html
还是不行
pzw@haitu-PowerEdge-R720:~/share/RK3308$ source envsetup.sh
Top of tree: /home/pzw/share/RK3308
You’re building on Linux
Lunch menu…pick a combo:
  1. firefly_rk3308_release
  2. firefly_rk3308_recovery
  3. firefly_rk3308_pcba
Which would you like? [1] 1
#TARGET_BOARD=rk3308
#BUILD_TYPE=64
#OUTPUT_DIR=output/firefly_rk3308_release
#CONFIG=firefly_rk3308_release_defconfig
make: Entering directory ‘/home/pzw/share/RK3308/buildroot’
GEN /home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/Makefile
/home/pzw/share/RK3308/buildroot/build/defconfig_hook.py -m /home/pzw/share/RK3308/buildroot/configs/firefly_rk3308_release_defconfig /home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/.rockchipconfig
BR2_DEFCONFIG=‘’ KCONFIG_AUTOCONFIG=/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/tristate.config BR2_CONFIG=/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/.config HOST_GCC_VERSION=“5” BUILD_DIR=/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/build SKIP_LEGACY= BR2_DEFCONFIG=/home/pzw/share/RK3308/buildroot/configs/firefly_rk3308_release_defconfig /home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/conf --defconfig=/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/.rockchipconfig Config.in
/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/.rockchipconfig:145:warning: override: reassigning to symbol BR2_PACKAGE_NTP
/home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/.rockchipconfig:146:warning: override: reassigning to symbol BR2_PACKAGE_NTP_NTPDATE
# configuration written to /home/pzw/share/RK3308/buildroot/output/firefly_rk3308_release/.config
make: Leaving directory ‘/home/pzw/share/RK3308/buildroot’
relink…
pzw@haitu-PowerEdge-R720:~/share/RK3308$ ./build.sh roc-rk3308b-cc-plus_release_BoardConfig.mk
Can’t found build config, please check again
====USAGE: build.sh modules====
uboot -build uboot
kernel -build kernel
modules -build kernel modules
rootfs -build default rootfs, currently build buildroot as default
buildroot -build buildroot rootfs
ramboot -build ramboot image
yocto -build yocto rootfs, currently build ros as default
ros -build ros rootfs
debian -build debian rootfs
pcba -build pcba
recovery -build recovery
all -build uboot, kernel, rootfs, recovery image
cleanall -clean uboot, kernel, rootfs, recovery
firmware -pack all the image we need to boot up system
updateimg -pack update image
otapackage -pack ab update otapackage image
save -save images, patches, commands used to debug
default -build all modules
请问你有没有改过build.sh文件,pull拉取一下更新看看
已经解决了,谢谢
