使用SD卡按照步骤将Ununtu16镜像烧写到SD卡后,插入SD卡启动后报错。请问这种问题是怎么导致的呢?该怎么解决呢?
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36
ChipType = 0x8, 227
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=29820MB
FwPartOffset=2000 , 2000
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29566MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 116413
LOADER Check OK! 0x0, 179054
TOS Check OK! 0x8400000, 253733
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-316-g7b4ec90 #59 Wed May 30 08:26:33 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x0
U-Boot 2017.09-g3947e40 (Feb 19 2019 - 10:20:55 +0800)
Model: Firefly-RK3288
DRAM: 4 GiB
Relocation Offset is: fbe54000
*** Warning - No MMC card found, using default environment
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Boot from SDcard
boot mode: None
DTB: rk-kernel.dtb
Using kernel dtb
vdd_log 1100000 uV
Can't get mcu-pix-total
Warn: can't find phy driver
In: serial@ff690000
Out: serial@ff690000
Err: serial@ff690000
Model: Firefly-RK3288 Board (Linux Opensource)
failed to display uboot logo
Net: No ethernet found.
Unknown command 'usb' - try 'help'
android_bootloader_boot_flow Could not find misc partition
Could not read from misc partition
WARNING: Unable to load the BCB.
ANDROID: reboot reason: "(none)"
android_bootloader_boot_flow boot part load fail
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
** fs_devread read error - block
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
