--------- beginning of main
11-09 06:51:04.286 365 426 D InputReader: CursorInputMapper::sync motionEventAction==DOWN or UP
11-09 06:51:04.401 251 752 D AudioHardwareTiny: start_output_stream
11-09 06:51:04.480 251 752 E alsa_route: get_route_config() route_table is NULL!
11-09 06:51:04.480 251 752 E alsa_route: route_pcm_open() Can not get config of route
11-09 06:51:04.482 251 752 W StreamHAL: Error from HAL stream in function get_presentation_position: Operation not permitted
11-09 06:51:07.598 251 251 D AudioHardwareTiny: close device
11-09 06:51:12.785 1651 1651 I wpa_supplicant: P2P-FIND-STOPPED
11-09 06:51:12.785 365 421 D SupplicantP2pIfaceCallback: Search stopped on p2p0
11-09 06:51:12.789 1349 1349 D RKWifiDisplayService: Discovery state changed: 1
11-09 06:51:12.789 1349 1349 D RKWifiDisplayService: Discovery finished, try to discovery after 8000
11-09 06:51:14.296 1349 1349 D WifiDisplayActivity: Do search action.
11-09 06:51:14.296 365 444 D SupplicantP2pIfaceHal: entering find(120)
11-09 06:51:14.297 1651 1651 I wpa_supplicant: p2p0: P2P: Reject scan trigger since one is already pending
11-09 06:51:14.298 365 444 D SupplicantP2pIfaceHal: find(120) completed successfully.
11-09 06:51:14.299 365 444 D SupplicantP2pIfaceHal: leaving find(120)
11-09 06:51:14.303 1349 1349 D RKWifiDisplayService: Discovery state changed: 2
11-09 06:51:22.696 365 438 I WifiConfigManager: No scan detail and linked configs associated with networkId 0
11-09 06:51:22.956 1651 1651 I wpa_supplicant: P2P-DEVICE-LOST p2p_dev_addr=a6:50:46:49:2d:e1
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: Device lost on p2p0: Device:
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: deviceAddress: a6:50:46:49:2d:e1
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: primary type: null
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: secondary type: null
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: wps: 0
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: grpcapab: 0
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: devcapab: 0
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: status: 4
11-09 06:51:22.958 365 421 D SupplicantP2pIfaceCallback: wfdInfo: null
11-09 06:51:22.961 1349 1349 D RKWifiDisplayService: Received WIFI_P2P_PEERS_CHANGED_ACTION.
11-09 06:51:24.310 365 532 D WificondControl: Scan result ready event
^C
130|rk3328_roc_pc_box:/ #
