急,急,急,AIO-3399C开发板换了一颗emmc,然后固件跑一半没起来
本想给AIO3399开发板换一颗32G的emmc,刷完固件后却跑不起来,然后换了一颗和开发板一样的KLMAG1JETD-B041 emmc,却怎么也跑不起来,总是到一半就卡住了。换emmc后需要对emmc做什么操作才能刷固件吗
开机log如下:
DDR Version 1.23 20190709
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
CPUId = 0x0
ChipType = 0x10, 223
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67768
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x84184
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):22b599a
NOTICE: BL31: Built : 11:03:32, Jul 10 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (May 06 2020 - 16:46:32)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=60
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find panel driver
no fuel gauge found
rockchip_panel_deinit: failed to find panel deinit funcs
failed to display kernel logo
got recovery cmd from misc.
load fdt from resouce.
hwversion: disabled!
Secure Boot state: 0
kernel @ 0x00280000 (0x0133e008)
ramdisk @ 0x04bf0000 (0x007552f0)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616bfd … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.126 (chengd@tchipserver2) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #24 SMP PREEMPT Thu Apr 16 14:41:25 CST 2020
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef8000 s45528 r8192 d32296 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00100000@0x003C4000(oem),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(reserved),0x00000400@0x004CE040(frp),-@0x004CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2020-05-06_16:46:32 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeb0000-0x7eef0000] (0MB) mapped at [ffffffc07eeb0000-ffffffc07eeeffff]
[ 0.000000] Memory: 1981812K/2064384K available (11390K kernel code, 1720K rwdata, 5716K rodata, 832K init, 1137K bss, 66188K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009140000 - 0xffffff8009210000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ba0000 ( 11392 KB)
[ 0.000000] .rodata : 0xffffff8008ba0000 - 0xffffff8009140000 ( 5760 KB)
[ 0.000000] .data : 0xffffff8009210000 - 0xffffff80093be008 ( 1721 KB)
[ 0.001946] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002933] pid_max: default: 32768 minimum: 301
[ 0.003438] Security Framework initialized
[ 0.003836] SELinux: Initializing.
[ 0.004280] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004924] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006401] Initializing cgroup subsys memory
[ 0.006842] Initializing cgroup subsys freezer
[ 0.008180] sched-energy: Sched-energy-costs installed from DT
[ 0.008743] CPU0: update cpu_capacity 401
[ 0.009205] ASID allocator initialised with 32768 entries
[ 0.026041] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027342] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039450] Detected VIPT I-cache on CPU1
[ 0.039484] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039518] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039561] CPU1: update cpu_capacity 401
[ 0.039565] CPU1: Booted secondary processor [410fd034]
[ 0.049427] Detected VIPT I-cache on CPU2
[ 0.049447] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049479] CPU2: using LPI pending table @0x000000007c020000
[ 0.049508] CPU2: update cpu_capacity 401
[ 0.049511] CPU2: Booted secondary processor [410fd034]
[ 0.059458] Detected VIPT I-cache on CPU3
[ 0.059477] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059509] CPU3: using LPI pending table @0x000000007c060000
[ 0.059534] CPU3: update cpu_capacity 401
[ 0.059538] CPU3: Booted secondary processor [410fd034]
[ 0.069508] Detected PIPT I-cache on CPU4
[ 0.069534] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069573] CPU4: using LPI pending table @0x000000007c0b0000
[ 0.069613] CPU4: update cpu_capacity 1024
[ 0.069616] CPU4: Booted secondary processor [410fd082]
[ 0.079531] Detected PIPT I-cache on CPU5
[ 0.079548] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079584] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079611] CPU5: update cpu_capacity 1024
[ 0.079614] CPU5: Booted secondary processor [410fd082]
[ 0.079699] Brought up 6 CPUs
[ 0.092097] SMP: Total of 6 processors activated.
[ 0.092551] CPU features: detected feature: GIC system register CPU interface
[ 0.093239] CPU: All CPU(s) started at EL2
[ 0.093673] alternatives: patching kernel code
[ 0.096059] devtmpfs: initialized
[ 0.117123] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.118048] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.119355] pinctrl core: initialized pinctrl subsystem
[ 0.121426] Failed to find legacy iommu devices
[ 0.122222] NET: Registered protocol family 16
[ 0.123064] schedtune: init normalization constants…
[ 0.123568] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.124183] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.124793] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.125402] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.126009] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.126618] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.127232] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.127843] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.128456] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.129070] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.129785] schedtune: verify normalization constants…
[ 0.130284] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.130810] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.131332] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131856] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.132378] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132899] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.133421] schedtune: configured to support 5 boost groups
[ 0.144187] cpuidle: using governor ladder
[ 0.154186] cpuidle: using governor menu
[ 0.154570] Registered FIQ tty driver
[ 0.155299] vdso: 2 pages (1 code @ ffffff8008ba6000, 1 data @ ffffff8009214000)
[ 0.156015] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.157706] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.178670] console [pstore-1] enabled
[ 0.179264] pstore: Registered ramoops as persistent store backend
[ 0.179847] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.183003] fiq debugger fiq mode enabled
[ [ 0.183633] console [ttyFIQ0] enabled
[ 0.184318] bootconsole [uart0] disabled
[ 0.184876] Registered fiq debugger ttyFIQ0
[ 0.218900] iommu: Adding device ff650000.vpu_service to group 0
[ 0.218977] iommu: Adding device ff660000.rkvdec to group 1
[ 0.219046] iommu: Adding device ff670000.iep to group 2
[ 0.219139] iommu: Adding device ff8f0000.vop to group 3
[ 0.219209] iommu: Adding device ff900000.vop to group 4
[ 0.219313] iommu: Adding device ff910000.isp to group 5
[ 0.219385] iommu: Adding device ff920000.isp to group 6
[ 0.220098] rk_iommu ff670800.iommu: can’t get aclk
[ 0.220112] rk_iommu ff670800.iommu: can’t get hclk
[ 0.220977] SCSI subsystem initialized
[ 0.221307] usbcore: registered new interface driver usbfs
[ 0.221353] usbcore: registered new interface driver hub
[ 0.221430] usbcore: registered new device driver usb
[ 0.221805] media: Linux media interface: v0.10
[ 0.221840] Linux video capture interface: v2.00
[ 0.222006] pps_core: LinuxPPS API ver. 1 registered
[ 0.222015] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.222037] PTP clock support registered
[ 0.223708] Advanced Linux Sound Architecture Driver Initialized.
[ 0.224237] Bluetooth: Core ver 2.21
[ 0.224270] NET: Registered protocol family 31
[ 0.224278] Bluetooth: HCI device and connection manager initialized
[ 0.224292] Bluetooth: HCI socket layer initialized
[ 0.224304] Bluetooth: L2CAP socket layer initialized
[ 0.224330] Bluetooth: SCO socket layer initialized
[ 0.225099] rockchip-cpuinfo cpuinfo: Serial : d46f4da18d7efaa0
[ 0.225658] clocksource: Switched to clocksource arch_sys_counter
[ 0.270600] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.270837] NET: Registered protocol family 2
[ 0.271282] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.271425] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.271698] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.271777] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.271835] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.272014] NET: Registered protocol family 1
[ 0.272940] Trying to unpack rootfs image as initramfs…
[ 0.604475] Freeing initrd memory: 7508K
[ 0.605083] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.605171] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.608044] audit: initializing netlink subsys (disabled)
[ 0.608116] audit: type=2000 audit(0.603:1): initialized
[ 0.613328] VFS: Disk quotas dquot_6.6.0
[ 0.613460] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.614504] Registering sdcardfs 0.1
[ 0.615089] fuse init (API version 7.23)
[ 0.616210]
[ 0.616210] TEE Core Framework initialization (ver 1:0.1)
[ 0.616237] TEE armv7 Driver initialization
[ 0.616627] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.616644] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.616824] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.620829] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.620851] io scheduler noop registered
[ 0.621014] io scheduler cfq registered (default)
[ 0.622287] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.625375] ace test_init function.
[ 0.625523] ace test_init end.ret=0
[ 0.625835] radar end.ret=0
[ 0.627757] iep: failed to find iep power down clock source.
[ 0.628108] IEP Power ON
[ 0.628274] IEP Power OFF
[ 0.628343] IEP Driver loaded succesfully
[ 0.628462] Module initialized.
[ 0.628734] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.628951] rk-vcodec ff650000.vpu_service: probe device
[ 0.629139] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.629651] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.629667] rk-vcodec ff650000.vpu_service: init success
[ 0.629867] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.630303] rk-vcodec ff660000.rkvdec: probe device
[ 0.630467] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.630847] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.630859] rk-vcodec ff660000.rkvdec: init success
[ 0.632532] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.632549] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.633916] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.633934] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.635813] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.636377] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.636818] [drm] Initialized drm 1.1.0 20060810
[ 0.640510] [drm] Rockchip DRM driver version: v1.0.0
[ 0.642836] mali ff9a0000.gpu: Failed to get regulator
[ 0.642853] mali ff9a0000.gpu: Power control initialization failed
[ 0.643149] Unable to detect cache hierarchy for CPU 0
[ 0.651229] brd: module loaded
[ 0.656313] loop: module loaded
[ 0.656838] zram: Added device: zram0
[ 0.657559] Loading dl1825 driver
[ 0.657794] SCSI Media Changer driver v0.25
[ 0.658678] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.658697] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.658707] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 0.659533] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 0.829880] wk2xxx_probe() GENA = 0xFF
[ 0.829893] spi driver error!!!
[ 0.829920] wk2xxxspi: probe of spi32766.0 failed with error 1
[ 0.829948] register spi return v = :0
[ 0.830023] register firefly_spi_init spi return v = :0
[ 0.830080] tun: Universal TUN/TAP device driver, 1.6
[ 0.830087] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.831013] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.831107] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.831124] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2b).
[ 0.831135] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 0.831164] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.831330] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.831339] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.836354] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.836482] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.836493] Ring mode enabled
[ 0.836500] DMA HW capability register supported
[ 0.836507] Normal descriptors
[ 0.836517] RX Checksum Offload Engine supported (type 2)
[ 0.836523] Wake-Up On Lan supported
[ 0.836562] Enable RX Mitigation via HW Watchdog Timer
[ 0.904996] libphy: stmmac: probed
[ 0.905038] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.905048] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.906008] PPP generic driver version 2.4.2
[ 0.906273] PPP BSD Compression module registered
[ 0.906334] PPP Deflate Compression module registered
[ 0.906375] PPP MPPE Compression module registered
[ 0.906431] NET: Registered protocol family 24
[ 0.906502] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.906511] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.906651] usbcore: registered new interface driver mt7601u
[ 0.906696] Rockchip WiFi SYS interface (V1.00) …
[ 0.906799] usbcore: registered new interface driver catc
[ 0.906859] usbcore: registered new interface driver kaweth
[ 0.906899] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.906950] usbcore: registered new interface driver pegasus
[ 0.907012] usbcore: registered new interface driver rtl8150
[ 0.907075] usbcore: registered new interface driver r8152
[ 0.907114] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.907192] usbcore: registered new interface driver hso
[ 0.907258] usbcore: registered new interface driver asix
[ 0.907316] usbcore: registered new interface driver ax88179_178a
[ 0.907400] usbcore: registered new interface driver cdc_ether
[ 0.907457] usbcore: registered new interface driver cdc_eem
[ 0.907519] usbcore: registered new interface driver dm9601
[ 0.907610] usbcore: registered new interface driver smsc75xx
[ 0.907679] usbcore: registered new interface driver smsc95xx
[ 0.907743] usbcore: registered new interface driver gl620a
[ 0.907823] usbcore: registered new interface driver net1080
[ 0.907880] usbcore: registered new interface driver plusb
[ 0.907945] usbcore: registered new interface driver rndis_host
[ 0.908025] usbcore: registered new interface driver cdc_subset
[ 0.908085] usbcore: registered new interface driver zaurus
[ 0.908146] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.908228] usbcore: registered new interface driver int51x1
[ 0.908306] usbcore: registered new interface driver kalmia
[ 0.908364] usbcore: registered new interface driver ipheth
[ 0.908424] usbcore: registered new interface driver sierra_net
[ 0.908507] usbcore: registered new interface driver cx82310_eth
[ 0.908574] usbcore: registered new interface driver cdc_ncm
[ 0.908634] usbcore: registered new interface driver qmi_wwan
[ 0.908714] usbcore: registered new interface driver cdc_mbim
[ 0.910826] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 0.915767] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 0.916968] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.916989] ehci-pci: EHCI PCI platform driver
[ 0.917053] ehci-platform: EHCI generic platform driver
[ 0.920885] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 0.921102] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 0.921287] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 0.929034] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 0.929254] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.929279] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.929293] usb usb1: Product: EHCI Host Controller
[ 0.929306] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 0.929318] usb usb1: SerialNumber: fe3c0000.usb
[ 0.930008] hub 1-0:1.0: USB hub found
[ 0.930060] hub 1-0:1.0: 1 port detected
[ 0.931023] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.931076] ohci-platform: OHCI generic platform driver
[ 0.931747] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 0.931970] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 0.932185] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 0.986489] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.986525] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.986535] usb usb2: Product: Generic Platform OHCI controller
[ 0.986545] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 0.986555] usb usb2: SerialNumber: fe3e0000.usb
[ 0.987235] hub 2-0:1.0: USB hub found
[ 0.987362] hub 2-0:1.0: 1 port detected
[ 0.989174] usbcore: registered new interface driver cdc_acm
[ 0.989194] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.989282] usbcore: registered new interface driver usblp
[ 0.989355] usbcore: registered new interface driver cdc_wdm
[ 0.989424] usbcore: registered new interface driver uas
[ 0.989531] usbcore: registered new interface driver usb-storage
[ 0.989596] usbcore: registered new interface driver ums-alauda
[ 0.989657] usbcore: registered new interface driver ums-cypress
[ 0.989720] usbcore: registered new interface driver ums-datafab
[ 0.989785] usbcore: registered new interface driver ums_eneub6250
[ 0.989840] usbcore: registered new interface driver ums-freecom
[ 0.989897] usbcore: registered new interface driver ums-isd200
[ 0.989957] usbcore: registered new interface driver ums-jumpshot
[ 0.990019] usbcore: registered new interface driver ums-karma
[ 0.990075] usbcore: registered new interface driver ums-onetouch
[ 0.990140] usbcore: registered new interface driver ums-sddr09
[ 0.990199] usbcore: registered new interface driver ums-sddr55
[ 0.990255] usbcore: registered new interface driver ums-usbat
[ 0.990373] usbcore: registered new interface driver usbserial
[ 0.990433] usbcore: registered new interface driver usbserial_generic
[ 0.990471] usbserial: USB Serial support registered for generic
[ 0.990529] usbcore: registered new interface driver option
[ 0.990569] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.990737] usbcore: registered new interface driver trancevibrator
[ 0.990764] usb20_otg: version 3.10a 21-DEC-2012
[ 0.991075] usb20_host: version 3.10a 21-DEC-2012
[ 0.991808] usbcore: registered new interface driver xpad
[ 0.991866] usbcore: registered new interface driver usb_acecad
[ 0.991910] usbcore: registered new interface driver aiptek
[ 0.991953] usbcore: registered new interface driver gtco
[ 0.991996] usbcore: registered new interface driver hanwang
[ 0.992040] usbcore: registered new interface driver kbtab
[ 0.992603] .. rk pwm remotectl v1.1 init
[ 0.992836] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.993287] sensor_register_slave:mma8452,id=17
[ 0.993305] sensor_register_slave:lis3dh,id=7
[ 0.993317] sensor_register_slave:mma7660,id=18
[ 0.993329] sensor_register_slave:lsm303d,id=22
[ 0.993340] sensor_register_slave:gs_mc3230,id=23
[ 0.993347] [Gsensor] gsensor_init
[ 0.993359] sensor_register_slave:mpu6880_acc,id=24
[ 0.993369] sensor_register_slave:mpu6500_acc,id=25
[ 0.993388] sensor_register_slave:lsm330_acc,id=26
[ 0.993399] sensor_register_slave:bma2xx_acc,id=27
[ 0.993411] sensor_register_slave:akm8975,id=30
[ 0.993422] sensor_register_slave:akm8963,id=31
[ 0.993433] sensor_register_slave:l3g4200d,id=45
[ 0.993444] sensor_register_slave:l3g20d,id=46
[ 0.993455] sensor_register_slave:ewtsa,id=47
[ 0.993466] sensor_register_slave:lsm330_gyro,id=51
[ 0.993477] sensor_register_slave:cm3217,id=53
[ 0.993487] sensor_register_slave:cm3218,id=54
[ 0.993499] sensor_register_slave:ls_stk3410,id=62
[ 0.993510] sensor_register_slave:ps_stk3410,id=67
[ 0.994304] i2c /dev entries driver
[ 0.995466] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.995551] fan53555-reg: supplied by vcc5v0_sys
[ 0.997934] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.997994] fan53555-reg: supplied by vcc5v0_sys
[ 0.999996] rockchip-pinctrl pinctrl: pin gpio1-18 already requested by 0-0040; cannot claim for 0-001b
[ 1.000025] rockchip-pinctrl pinctrl: pin-50 (0-001b) status -22
[ 1.000037] rockchip-pinctrl pinctrl: could not request pin 50 (gpio1-18) from group pmic-dvs2 on device rockchip-pinctrl
[ 1.000046] rk808 0-001b: Error applying setting, reverse things back
[ 1.000453] rk808 0-001b: Pmic Chip id: 0x0
[ 1.003728] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.003806] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.003890] DCDC_REG1: supplied by vcc3v3_sys
[ 1.004628] DCDC_REG2: supplied by vcc3v3_sys
[ 1.005189] DCDC_REG3: supplied by vcc3v3_sys
[ 1.005455] DCDC_REG4: supplied by vcc3v3_sys
[ 1.005928] LDO_REG1: supplied by vcc3v3_sys
[ 1.007046] LDO_REG2: supplied by vcc3v3_sys
[ 1.008032] LDO_REG3: supplied by vcc3v3_sys
[ 1.009042] LDO_REG4: supplied by vcc3v3_sys
[ 1.009876] vcc_sd: Failed to create debugfs directory
[ 1.009979] LDO_REG5: supplied by vcc3v3_sys
[ 1.010967] LDO_REG6: supplied by vcc3v3_sys
[ 1.011939] LDO_REG7: supplied by vcc3v3_sys
[ 1.012933] LDO_REG8: supplied by vcc3v3_sys
[ 1.013925] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.014205] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.014605] firefly_hwversion_in_range 茺{
[ 1.017741] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.018269] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097fc000
[ 1.018881] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80097fe000
[ 1.019447] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80098d2000
[ 1.020622] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.023916] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.024092] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input1
[ 1.024273] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098d4000
[ 1.025174] IR NEC protocol handler initialized
[ 1.025203] IR RC5(x/sz) protocol handler initialized
[ 1.025216] IR RC6 protocol handler initialized
[ 1.025229] IR JVC protocol handler initialized
[ 1.025243] IR Sony protocol handler initialized
[ 1.025255] IR SANYO protocol handler initialized
[ 1.025268] IR Sharp protocol handler initialized
[ 1.025281] IR MCE Keyboard/mouse protocol handler initialized
[ 1.025295] IR XMP protocol handler initialized
[ 1.025488] usbcore: registered new interface driver uvcvideo
[ 1.025510] USB Video Class driver (1.1.1)
[ 1.025527] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 1.029870] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.030001] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.030270] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.030384] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.032792] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.033496] device-mapper: uevent: version 1.0.3
[ 1.033825] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.033999] Bluetooth: HCI UART driver ver 2.3
[ 1.034014] Bluetooth: HCI UART protocol H4 registered
[ 1.034023] Bluetooth: HCI UART protocol LL registered
[ 1.034034] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.034042] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.034049] rtk_btusb: Register usb char device interface for BT driver
[ 1.034247] usbcore: registered new interface driver rtk_btusb
[ 1.034643] cpu cpu0: bin=1
[ 1.034700] cpu cpu0: leakage=24
[ 1.046395] cpu cpu0: temp=40000, pvtm=152542 (152657 + -115)
[ 1.046636] cpu cpu0: pvtm-volt-sel=3
[ 1.046701] cpu cpu0: bin-scale=34
[ 1.046978] cpu cpu4: bin=1
[ 1.047035] cpu cpu4: leakage=41
[ 1.059131] cpu cpu4: temp=40000, pvtm=157739 (157810 + -71)
[ 1.059308] cpu cpu4: pvtm-volt-sel=2
[ 1.059370] cpu cpu4: bin-scale=17
[ 1.060402] cpu cpu0: avs=0, target-scale=34
[ 1.060496] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.061803] cpu cpu4: avs=0, target-scale=17
[ 1.061896] cpu cpu4: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.063930] sdhci: Secure Digital Host Controller Interface driver
[ 1.063954] sdhci: Copyright(c) Pierre Ossman
[ 1.063966] Synopsys Designware Multimedia Card Interface Driver
[ 1.064804] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.064974] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.064993] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.065048] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.065095] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.065137] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.065146] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.065949] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.066022] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.066053] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.066092] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.066110] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.066520] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.066676] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.079264] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.093554] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.094082] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.096253] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.096293] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.125781] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.129718] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.133278] usbcore: registered new interface driver usbhid
[ 1.133299] usbhid: USB HID core driver
[ 1.133494] inv_mpu_iio: inv_mpu_init:746
[ 1.134574] ashmem: initialized
[ 1.136656] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.143394] rknandbase v1.1 2016-11-08
[ 1.144371] usbcore: registered new interface driver snd-usb-audio
[ 1.145847] rt5640 1-001c: rt5640 have no io-channels defined
[ 1.145873] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.156529] rockchip-pinctrl pinctrl: pin gpio3-28 already requested by pinctrl; cannot claim for ff880000.i2s
[ 1.156576] rockchip-pinctrl pinctrl: pin-124 (ff880000.i2s) status -22
[ 1.156591] rockchip-pinctrl pinctrl: could not request pin 124 (gpio3-28) from group i2s0-8ch-bus on device rockchip-pinctrl
[ 1.156606] rockchip-i2s ff880000.i2s: Error applying setting, reverse things back
[ 1.161759] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.161813] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.162060] u32 classifier
[ 1.162093] Actions configured
[ 1.162155] Netfilter messages via NETLINK v0.30.
[ 1.162260] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.162801] ctnetlink v0.93: registering with nfnetlink.
[ 1.163879] xt_time: kernel timezone is -0000
[ 1.165211] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.165501] arp_tables: (C) 2002 David S. Miller
[ 1.166294] Initializing XFRM netlink socket
[ 1.166810] mmc1: MAN_BKOPS_EN bit is not set
[ 1.166950] NET: Registered protocol family 10
[ 1.168389] mip6: Mobile IPv6
[ 1.168440] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.171266] sit: IPv6 over IPv4 tunneling driver
[ 1.171941] NET: Registered protocol family 17
[ 1.172007] NET: Registered protocol family 15
[ 1.172063] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.173577] Bridge firewalling registered
[ 1.173610] Ebtables v2.0 registered
[ 1.173992] Bluetooth: RFCOMM TTY layer initialized
[ 1.174025] Bluetooth: RFCOMM socket layer initialized
[ 1.174066] Bluetooth: RFCOMM ver 1.11
[ 1.174087] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.174096] Bluetooth: BNEP filters: protocol multicast
[ 1.174134] Bluetooth: BNEP socket layer initialized
[ 1.174149] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.174160] Bluetooth: HIDP socket layer initialized
[ 1.174231] l2tp_core: L2TP core driver, V2.0
[ 1.174252] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.174267] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.174803] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.174897] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 1.174923] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.174931] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.175024] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.175033] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.175045] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.175111] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.175801] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.175876] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.175908] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.175939] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.176328] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.176401] [BT_RFKILL]: ** disable irq
[ 1.176579] [BT_RFKILL]: bt_default device registered.
[ 1.176877] sensor_register_slave:mpu6500_gyro,id=49
[ 1.176899] sensor_register_slave:mpu6880_gyro,id=50
[ 1.178574] Registered cp15_barrier emulation handler
[ 1.178682] Registered setend emulation handler
[ 1.179041] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.179596] registered taskstats version 1
[ 1.179832] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.180278] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.180516] rockchip ion idev is NULL
[ 1.180537] rga2 ff680000.rga: rga ion client create success!
[ 1.180694] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.180811] rga: Driver loaded successfully ver:3.02
[ 1.181075] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.181532] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.181550] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.181559] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.181568] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.181578] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.181587] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.181596] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.181606] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 1.181615] backup: 0x009800000 – 0x010800000 (112 MB)
[ 1.181625] cache: 0x010800000 – 0x018800000 (128 MB)
[ 1.181634] system: 0x018800000 – 0x078800000 (1536 MB)
[ 1.181643] oem: 0x078800000 – 0x098800000 (512 MB)
[ 1.181652] metadata: 0x098800000 – 0x099800000 (16 MB)
[ 1.181662] verity_mode: 0x099800000 – 0x099808000 (0 MB)
[ 1.181670] reserved: 0x099808000 – 0x099c08000 (4 MB)
[ 1.181680] frp: 0x099c08000 – 0x099c88000 (0 MB)
[ 1.181689] userdata: 0x099c88000 – 0x3a3a00000 (12445 MB)
[ 1.181764] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.182153] phy phy-ff770000.syscon:usb2-phy@e450.5: Failed to get VBUS supply regulator
[ 1.185003] rockchip-drm display-subsystem: defer getting devfreq
[ 1.185409] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.185768] rockchip-vop ff900000.vop: unable to request PWM
[ 1.185801] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.185864] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.186072] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.186097] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.186624] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.186677] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.186809] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.188647] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.189260] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.189840] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.189901] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.189917] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.189926] [drm] No driver support for vblank timestamp query.
[ 1.190269] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.190302] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.190338] rockchip-drm display-subsystem: failed to show loader logo
[ 1.190444] Freeing drm_logo memory: 488K
[ 1.190462] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.190473] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.197598] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.215133] mali ff9a0000.gpu: leakage=33
[ 1.228529] mali ff9a0000.gpu: temp=39375, pvtm=126660 (126752 + -92)
[ 1.230341] mali ff9a0000.gpu: pvtm-volt-sel=2
[ 1.232711] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.233539] mali ff9a0000.gpu: Protected mode not available
[ 1.234611] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.234797] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.235119] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.236311] mali ff9a0000.gpu: Probed as mali0
[ 1.243262] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.243714] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 1.244088] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.244174] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe800000
[ 1.244422] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.244451] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.244471] usb usb3: Product: xHCI Host Controller
[ 1.244489] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.244507] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 1.245357] hub 3-0:1.0: USB hub found
[ 1.245422] hub 3-0:1.0: 1 port detected
[ 1.246007] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.246279] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 1.246401] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.246582] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.246616] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.246634] usb usb4: Product: xHCI Host Controller
[ 1.246652] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.246670] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 1.247481] hub 4-0:1.0: USB hub found
[ 1.247552] hub 4-0:1.0: 1 port detected
[ 1.250179] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.250240] usb usb4: USB disconnect, device number 1
[ 1.255436] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.255800] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 5
[ 1.256235] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.256322] xhci-hcd xhci-hcd.12.auto: irq 235, io mem 0xfe900000
[ 1.256572] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.256602] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.256621] usb usb5: Product: xHCI Host Controller
[ 1.256640] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.256658] usb usb5: SerialNumber: xhci-hcd.12.auto
[ 1.257458] hub 5-0:1.0: USB hub found
[ 1.257528] hub 5-0:1.0: 1 port detected
[ 1.258034] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.258295] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 6
[ 1.258416] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.258591] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.258618] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.258636] usb usb6: Product: xHCI Host Controller
[ 1.258655] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.258672] usb usb6: SerialNumber: xhci-hcd.12.auto
[ 1.259542] hub 6-0:1.0: USB hub found
[ 1.259614] hub 6-0:1.0: 1 port detected
[ 1.263218] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.263554] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 7
[ 1.263871] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.272398] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.272709] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.272743] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.272770] usb usb7: Product: EHCI Host Controller
[ 1.272788] usb usb7: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.272806] usb usb7: SerialNumber: fe380000.usb
[ 1.273709] hub 7-0:1.0: USB hub found
[ 1.273844] hub 7-0:1.0: 1 port detected
[ 1.275493] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.275999] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 8
[ 1.276332] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 1.276367] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 1.276425] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.276444] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 1.276897] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.276995] usb usb3: USB disconnect, device number 1
[ 1.278095] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 1.333853] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.333998] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.334024] usb usb8: Product: Generic Platform OHCI controller
[ 1.334048] usb usb8: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.334071] usb usb8: SerialNumber: fe3a0000.usb
[ 1.335495] hub 8-0:1.0: USB hub found
[ 1.335616] hub 8-0:1.0: 1 port detected
[ 1.338053] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.338501] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.338639] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.338922] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.339133] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.339394] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.339561] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.340426] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.352916] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.366324] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.369576] rockchip-dmc dmc: Failed to get leakage
[ 1.369734] rockchip-dmc dmc: Failed to get pvtm
[ 1.370541] rockchip-dmc dmc: could not find power_model node
[ 1.371966] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.386832] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 1.393426] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input2
[ 1.396662] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 1.396834] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 1.398730] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card2/input3
[ 1.401673] i2c i2c-2: sensor_probe: gs_mc3230,ffffffc004ea8400
[ 1.401819] sensors 2-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0xffffff80092dcfe8
[ 1.411040] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.412759] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.414460] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.417472] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.421140] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.475869] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.579191] usb 7-1: new high-speed USB device number 2 using ehci-platform
[ 1.685292] vendor storage:20160801 ret = 0
[ 1.704300] usb 7-1: New USB device found, idVendor=1a40, idProduct=0101
[ 1.704399] usb 7-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.704428] usb 7-1: Product: USB 2.0 Hub [MTT]
[ 1.706030] hub 7-1:1.0: USB hub found
[ 1.706405] hub 7-1:1.0: 4 ports detected
[ 1.831596] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 8
[ 1.835054] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.835157] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 4.956053] rk3x-i2c ff120000.i2c: timeout, ipd: 0x81, state: 3
[ 6.632733] rk3x-i2c ff120000.i2c: timeout, ipd: 0x81, state: 3
[ 8.134411] [Gsensor] init_3230_ctl_data 445 : error: -6
[ 8.134486] sensors 2-004c: sensor_initial:fail to init sensor
[ 8.134510] sensors 2-004c: sensor_chip_init:fail to init sensor
[ 8.134534] i2c i2c-2: sensor_probe failed -2
[ 8.134534]
[ 8.134590] sensors: probe of 2-004c failed with error -2
[ 8.136292] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:05:34 UTC (1358499934)
[ 8.138858] It doesn’t contain Rogue gpu
[ 8.173855] vdd3v3_pcie: disabling
[ 8.173994] vcc_sd: disabling
[ 8.175481] u
是不是升级扩展EMMC容量需要将板子寄回去,让厂家那边帮忙升级EMMC容量才行
