重新编译内核无法启动
使用官方提供的Ubuntu固件,能够顺利启动,我按照教程重新编译内核后烧写zboot.img后就无法启动了,貌似是文件系统无法挂载,是编译内核需要额外配置哪些选项吗?
正常启动的日志如下
[ 1.865787] dwmmc_rockchip ff490000.dwmmc: Successfully tuned phase to 83
[ 1.865985] mmc1: new HS200 MMC card at address 0001
[ 1.867488] mmcblk1: mmc1:0001 4FTE4R 3.64 GiB
[ 1.868277] mmcblk1boot0: mmc1:0001 4FTE4R partition 1 4.00 MiB
[ 1.869188] mmcblk1boot1: mmc1:0001 4FTE4R partition 2 4.00 MiB
[ 1.870080] mmcblk1rpmb: mmc1:0001 4FTE4R partition 3 512 KiB
[ 1.876746] mmcblk1: p1 p2 p3 p4
[ 2.130580] ret 1024
[ 2.131901] ALSA device list:
[ 2.131954] #0: rockchip,rk3308b-acodec
[ 2.131975] #7: Loopback 1
[ 2.137711] vendor storage:20160801 ret = 0
[ 2.192947] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
[ 2.221398] EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: (null)
[ 2.221560] VFS: Mounted root (ext4 filesystem) on device 179:4.
失败启动的日志如下
[ 1.771995] EXT2-fs (mmcblk1p4): error: couldn’t mount because of unsupported optional features (44)
[ 1.772252] List of all partitions:
[ 1.772318] b300 3817472 mmcblk1 driver: mmcblk
[ 1.772370] b301 2048 mmcblk1p1 29370000-0000-4007-8000-4a0700004276
[ 1.772408] b302 2048 mmcblk1p2 c1060000-0000-446e-8000-595600004870
[ 1.772446] b303 12288 mmcblk1p3 c52d0000-0000-426f-8000-1afb00003ace
[ 1.772482] b304 3792879 mmcblk1p4 614e0000-0000-4b53-8000-1d28000054a9
[ 1.772521] b360 512 mmcblk1rpmb (driver?)
[ 1.772569] b340 4096 mmcblk1boot1 (driver?)
[ 1.772607] b320 4096 mmcblk1boot0 (driver?)
[ 1.772632] No filesystem could mount root, tried: ext2
[ 1.772678] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,4)
[ 1.779619] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.143 #5
[ 1.780159] Hardware name: Firefly ROC-RK3308B-CC-PLUS analog mic board (DT)
烧个buildroot的固件,编译用的是buildroot
您好,我在Ubuntu1604环境下按照教程编译
./build.sh roc-rk3308b-cc-plus_release_BoardConfig.mk
./build.sh
得到了update.img, 可烧入后还是无法启动{:5_228:}
下面是uboot的输出
dwmmc@ff480000: 1, dwmmc@ff490000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: recovery (misc)
init_resource_list: failed to get resource part, ret=-1
Failed to get kernel dtb, ret=-19
request for gpio0_a4 failed:-2
Model: Rockchip RK3308 EVB
apll 816000 KHz
dpll 1300000 KHz
vpll0 1177823 KHz
vpll1 901583 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98151 KHz
pclk_audio 98151 KHz
Net: No ethernet found.
** Invalid Android Image header **
MMC: block number 0x7f765b exceeds max(0x748000)
Android image load failed
=Booting Rockchip format image=
Could not found misc partition
mmc_init: -95, time 9
switch to partitions #0, OK
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
Device 0: …nandc_flash_init enter…
unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
您好
1.请问你是否尝试过烧录公版buildroot固件,公版固件能否正常启动
2.拉取的commit版本是多少
3.请问具体的板型是哪一种
